[Mapbender-commits] r3629 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Tue Mar 3 07:29:11 EST 2009
Author: verenadiewald
Date: 2009-03-03 07:29:11 -0500 (Tue, 03 Mar 2009)
New Revision: 3629
trunk/mapbender/resources/db/update/update_2.6.sql
set popup.js as required module for gui element loadwmc
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql 2009-03-03 12:09:44 UTC (rev 3628)
+++ trunk/mapbender/resources/db/update/update_2.6.sql 2009-03-03 12:29:11 UTC (rev 3629)
@@ -368,3 +368,6 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all configured wms from db"' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load configured wms by group"' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load configured wms by gui"' ,'var');
+-- set popup.js as required module for gui element loadwmc
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'loadwmc';
\ No newline at end of file
More information about the Mapbender_commits
