[Mapbender-commits] r3630 - trunk/mapbender/conf
svn_mapbender at osgeo.org
Tue Mar 3 07:33:37 EST 2009
Author: verenadiewald
Date: 2009-03-03 07:33:37 -0500 (Tue, 03 Mar 2009)
New Revision: 3630
trunk/mapbender/conf/wfs_additional_spatial_search.conf
changed popup parameter width, height, top, left + labels
Modified: trunk/mapbender/conf/wfs_additional_spatial_search.conf
--- trunk/mapbender/conf/wfs_additional_spatial_search.conf 2009-03-03 12:29:11 UTC (rev 3629)
+++ trunk/mapbender/conf/wfs_additional_spatial_search.conf 2009-03-03 12:33:37 UTC (rev 3630)
@@ -7,17 +7,17 @@
* [@param {string} filteroption type of filter for search (values: "intersects" or "within"), used for buttons buttonRectangle and buttonPolygon
-var buttonRectangle = {"status":1,"img":"select_rectangle_off.png","title":"Rechteckauswahl","filteroption":"intersects"};
-var buttonPolygon = {"status":1,"img":"select_polygon_off.png","title":"Vieleckauswahl","filteroption":"intersects"};
-var buttonPoint = {"status":1, "img":"select_point_off.png","title":"Punktauswahl"};
-var buttonExtent = {"status":1,"img":"select_extent_off.png","title":"Auswahl Kartenrahmen"};
+var buttonRectangle = {"status":1,"img":"select_rectangle_off.png","title":"select by rectangle","filteroption":"intersects"};
+var buttonPolygon = {"status":1,"img":"select_polygon_off.png","title":"select by polygon","filteroption":"intersects"};
+var buttonPoint = {"status":1, "img":"select_point_off.png","title":"select by point"};
+var buttonExtent = {"status":1,"img":"select_extent_off.png","title":"select by extent"};
var mb_wfs_tolerance = 8;
-var spatialRequestIsSetMessage = "Gebiet eingegrenzt, bitte OK klicken!";
-var clearFilterButtonLabel = "Neu";
+var spatialRequestIsSetMessage = "Spatial filter is set.";
+var clearFilterButtonLabel = "New";
-var noResultMsg = "Kein Ergebnis";
+var noResultMsg = "No result";
var buttonWfs_imgdir = "../img/button_gray/";
var buttonWfs_zIndex = 10;
@@ -28,14 +28,14 @@
var wfsResultModulePath = "php/";
var wfsResultModuleFilename = "mod_wfs_result.php";
-var searchPopupTitle = "Suchergebnisse";
-var searchPopupWidth = 985;
-var searchPopupHeight =300;
-var searchPopupX = 220;
-var searchPopupY = 575;
+var searchPopupTitle = "Search results";
+var searchPopupWidth = 400;
+var searchPopupHeight =250;
+var searchPopupX = 750;
+var searchPopupY = 80;
var detailPopupTitle = "Details";
-var detailPopupWidth = 350;
+var detailPopupWidth = 400;
var detailPopupHeight = 200;
-var detailPopupX = 840;
-var detailPopupY = 575;
+var detailPopupX = 750;
+var detailPopupY = 410;
More information about the Mapbender_commits
