[Mapbender-commits] r3646 - trunk/mapbender/http/extensions
    svn_mapbender at osgeo.org
    Sun Mar  8 14:22:05 EDT 2009
Author: verenadiewald
Date: 2009-03-08 14:22:05 -0400 (Sun, 08 Mar 2009)
New Revision: 3646
Added:
   trunk/mapbender/http/extensions/jquery.form.js
this jquery lib was missing in extensions folder
Added: trunk/mapbender/http/extensions/jquery.form.js
--- trunk/mapbender/http/extensions/jquery.form.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.form.js	2009-03-08 18:22:05 UTC (rev 3646)
@@ -0,0 +1,632 @@
+ * jQuery Form Plugin
+ * version: 2.21 (08-FEB-2009)
+ * @requires jQuery v1.2.2 or later
+ * Examples and documentation at: http://malsup.com/jquery/form/
+ * Dual licensed under the MIT and GPL licenses:
+ *   http://www.opensource.org/licenses/mit-license.php
+ *   http://www.gnu.org/licenses/gpl.html
+;(function($) {
+    Usage Note:
+    Do not use both ajaxSubmit and ajaxForm on the same form.  These
+    functions are intended to be exclusive.  Use ajaxSubmit if you want
+    to bind your own submit handler to the form.  For example,
+    $(document).ready(function() {
+        $('#myForm').bind('submit', function() {
+            $(this).ajaxSubmit({
+                target: '#output'
+            return false; // <-- important!
+    Use ajaxForm when you want the plugin to manage all the event binding
+    for you.  For example,
+        $('#myForm').ajaxForm({
+            target: '#output'
+    When using ajaxForm, the ajaxSubmit function will be invoked for you
+    at the appropriate time.
+ * ajaxSubmit() provides a mechanism for immediately submitting
+ * an HTML form using AJAX.
+$.fn.ajaxSubmit = function(options) {
+    // fast fail if nothing selected (http://dev.jquery.com/ticket/2752)
+    if (!this.length) {
+        log('ajaxSubmit: skipping submit process - no element selected');
+        return this;
+    if (typeof options == 'function')
+        options = { success: options };
+    options = $.extend({
+        url:  this.attr('action') || window.location.toString(),
+        type: this.attr('method') || 'GET'
+    }, options || {});
+    // hook for manipulating the form data before it is extracted;
+    // convenient for use with rich editors like tinyMCE or FCKEditor
+    var veto = {};
+    this.trigger('form-pre-serialize', [this, options, veto]);
+    if (veto.veto) {
+        log('ajaxSubmit: submit vetoed via form-pre-serialize trigger');
+        return this;
+    // provide opportunity to alter form data before it is serialized
+    if (options.beforeSerialize && options.beforeSerialize(this, options) === false) {
+        log('ajaxSubmit: submit aborted via beforeSerialize callback');
+        return this;
+    var a = this.formToArray(options.semantic);
+    if (options.data) {
+        options.extraData = options.data;
+        for (var n in options.data) {
+          if(options.data[n] instanceof Array) {
+            for (var k in options.data[n])
+              a.push( { name: n, value: options.data[n][k] } )
+          else
+             a.push( { name: n, value: options.data[n] } );
+    // give pre-submit callback an opportunity to abort the submit
+    if (options.beforeSubmit && options.beforeSubmit(a, this, options) === false) {
+        log('ajaxSubmit: submit aborted via beforeSubmit callback');
+        return this;
+    // fire vetoable 'validate' event
+    this.trigger('form-submit-validate', [a, this, options, veto]);
+    if (veto.veto) {
+        log('ajaxSubmit: submit vetoed via form-submit-validate trigger');
+        return this;
+    var q = $.param(a);
+    if (options.type.toUpperCase() == 'GET') {
+        options.url += (options.url.indexOf('?') >= 0 ? '&' : '?') + q;
+        options.data = null;  // data is null for 'get'
+    else
+        options.data = q; // data is the query string for 'post'
+    var $form = this, callbacks = [];
+    if (options.resetForm) callbacks.push(function() { $form.resetForm(); });
+    if (options.clearForm) callbacks.push(function() { $form.clearForm(); });
+    // perform a load on the target only if dataType is not provided
+    if (!options.dataType && options.target) {
+        var oldSuccess = options.success || function(){};
+        callbacks.push(function(data) {
+            $(options.target).html(data).each(oldSuccess, arguments);
+    else if (options.success)
+        callbacks.push(options.success);
+    options.success = function(data, status) {
+        for (var i=0, max=callbacks.length; i < max; i++)
+            callbacks[i].apply(options, [data, status, $form]);
+    // are there files to upload?
+    var files = $('input:file', this).fieldValue();
+    var found = false;
+    for (var j=0; j < files.length; j++)
+        if (files[j])
+            found = true;
+    // options.iframe allows user to force iframe mode
+   if (options.iframe || found) {
+       // hack to fix Safari hang (thanks to Tim Molendijk for this)
+       // see:  http://groups.google.com/group/jquery-dev/browse_thread/thread/36395b7ab510dd5d
+       if (options.closeKeepAlive)
+           $.get(options.closeKeepAlive, fileUpload);
+       else
+           fileUpload();
+   else
+       $.ajax(options);
+    // fire 'notify' event
+    this.trigger('form-submit-notify', [this, options]);
+    return this;
+    // private function for handling file uploads (hat tip to YAHOO!)
+    function fileUpload() {
+        var form = $form[0];
+        if ($(':input[name=submit]', form).length) {
+            alert('Error: Form elements must not be named "submit".');
+            return;
+        var opts = $.extend({}, $.ajaxSettings, options);
+		var s = jQuery.extend(true, {}, $.extend(true, {}, $.ajaxSettings), opts);
+        var id = 'jqFormIO' + (new Date().getTime());
+        var $io = $('<iframe id="' + id + '" name="' + id + '" src="about:blank" />');
+        var io = $io[0];
+        $io.css({ position: 'absolute', top: '-1000px', left: '-1000px' });
+        var xhr = { // mock object
+            aborted: 0,
+            responseText: null,
+            responseXML: null,
+            status: 0,
+            statusText: 'n/a',
+            getAllResponseHeaders: function() {},
+            getResponseHeader: function() {},
+            setRequestHeader: function() {},
+            abort: function() {
+                this.aborted = 1;
+                $io.attr('src','about:blank'); // abort op in progress
+        var g = opts.global;
+        // trigger ajax global events so that activity/block indicators work like normal
+        if (g && ! $.active++) $.event.trigger("ajaxStart");
+        if (g) $.event.trigger("ajaxSend", [xhr, opts]);
+		if (s.beforeSend && s.beforeSend(xhr, s) === false) {
+			s.global && jQuery.active--;
+			return;
+        if (xhr.aborted)
+            return;
+        var cbInvoked = 0;
+        var timedOut = 0;
+        // add submitting element to data if we know it
+        var sub = form.clk;
+        if (sub) {
+            var n = sub.name;
+            if (n && !sub.disabled) {
+                options.extraData = options.extraData || {};
+                options.extraData[n] = sub.value;
+                if (sub.type == "image") {
+                    options.extraData[name+'.x'] = form.clk_x;
+                    options.extraData[name+'.y'] = form.clk_y;
+        // take a breath so that pending repaints get some cpu time before the upload starts
+        setTimeout(function() {
+            // make sure form attrs are set
+            var t = $form.attr('target'), a = $form.attr('action');
+			// update form attrs in IE friendly way
+			form.setAttribute('target',id);
+			if (form.getAttribute('method') != 'POST')
+				form.setAttribute('method', 'POST');
+			if (form.getAttribute('action') != opts.url)
+				form.setAttribute('action', opts.url);
+            // ie borks in some cases when setting encoding
+            if (! options.skipEncodingOverride) {
+                $form.attr({
+                    encoding: 'multipart/form-data',
+                    enctype:  'multipart/form-data'
+            // support timout
+            if (opts.timeout)
+                setTimeout(function() { timedOut = true; cb(); }, opts.timeout);
+            // add "extra" data to form if provided in options
+            var extraInputs = [];
+            try {
+                if (options.extraData)
+                    for (var n in options.extraData)
+                        extraInputs.push(
+                            $('<input type="hidden" name="'+n+'" value="'+options.extraData[n]+'" />')
+                                .appendTo(form)[0]);
+                // add iframe to doc and submit the form
+                $io.appendTo('body');
+                io.attachEvent ? io.attachEvent('onload', cb) : io.addEventListener('load', cb, false);
+                form.submit();
+            finally {
+                // reset attrs and remove "extra" input elements
+				form.setAttribute('action',a);
+                t ? form.setAttribute('target', t) : $form.removeAttr('target');
+                $(extraInputs).remove();
+        }, 10);
+        var nullCheckFlag = 0;
+        function cb() {
+            if (cbInvoked++) return;
+            io.detachEvent ? io.detachEvent('onload', cb) : io.removeEventListener('load', cb, false);
+            var ok = true;
+            try {
+                if (timedOut) throw 'timeout';
+                // extract the server response from the iframe
+                var data, doc;
+                doc = io.contentWindow ? io.contentWindow.document : io.contentDocument ? io.contentDocument : io.document;
+                if ((doc.body == null || doc.body.innerHTML == '') && !nullCheckFlag) {
+                    // in some browsers (cough, Opera 9.2.x) the iframe DOM is not always traversable when
+                    // the onload callback fires, so we give them a 2nd chance
+                    nullCheckFlag = 1;
+                    cbInvoked--;
+                    setTimeout(cb, 100);
+                    return;
+                xhr.responseText = doc.body ? doc.body.innerHTML : null;
+                xhr.responseXML = doc.XMLDocument ? doc.XMLDocument : doc;
+                xhr.getResponseHeader = function(header){
+                    var headers = {'content-type': opts.dataType};
+                    return headers[header];
+                if (opts.dataType == 'json' || opts.dataType == 'script') {
+                    var ta = doc.getElementsByTagName('textarea')[0];
+                    xhr.responseText = ta ? ta.value : xhr.responseText;
+                else if (opts.dataType == 'xml' && !xhr.responseXML && xhr.responseText != null) {
+                    xhr.responseXML = toXml(xhr.responseText);
+                data = $.httpData(xhr, opts.dataType);
+            catch(e){
+                ok = false;
+                $.handleError(opts, xhr, 'error', e);
+            // ordering of these callbacks/triggers is odd, but that's how $.ajax does it
+            if (ok) {
+                opts.success(data, 'success');
+                if (g) $.event.trigger("ajaxSuccess", [xhr, opts]);
+            if (g) $.event.trigger("ajaxComplete", [xhr, opts]);
+            if (g && ! --$.active) $.event.trigger("ajaxStop");
+            if (opts.complete) opts.complete(xhr, ok ? 'success' : 'error');
+            // clean up
+                $io.remove();
+                xhr.responseXML = null;
+            }, 100);
+        function toXml(s, doc) {
+            if (window.ActiveXObject) {
+                doc = new ActiveXObject('Microsoft.XMLDOM');
+                doc.async = 'false';
+                doc.loadXML(s);
+            else
+                doc = (new DOMParser()).parseFromString(s, 'text/xml');
+            return (doc && doc.documentElement && doc.documentElement.tagName != 'parsererror') ? doc : null;
+ * ajaxForm() provides a mechanism for fully automating form submission.
+ * The advantages of using this method instead of ajaxSubmit() are:
+ * 1: This method will include coordinates for <input type="image" /> elements (if the element
+ *    is used to submit the form).
+ * 2. This method will include the submit element's name/value data (for the element that was
+ *    used to submit the form).
+ * 3. This method binds the submit() method to the form for you.
+ * The options argument for ajaxForm works exactly as it does for ajaxSubmit.  ajaxForm merely
+ * passes the options argument along after properly binding events for submit elements and
+ * the form itself.
+$.fn.ajaxForm = function(options) {
+    return this.ajaxFormUnbind().bind('submit.form-plugin',function() {
+        $(this).ajaxSubmit(options);
+        return false;
+    }).each(function() {
+        // store options in hash
+        $(":submit,input:image", this).bind('click.form-plugin',function(e) {
+            var form = this.form;
+            form.clk = this;
+            if (this.type == 'image') {
+                if (e.offsetX != undefined) {
+                    form.clk_x = e.offsetX;
+                    form.clk_y = e.offsetY;
+                } else if (typeof $.fn.offset == 'function') { // try to use dimensions plugin
+                    var offset = $(this).offset();
+                    form.clk_x = e.pageX - offset.left;
+                    form.clk_y = e.pageY - offset.top;
+                } else {
+                    form.clk_x = e.pageX - this.offsetLeft;
+                    form.clk_y = e.pageY - this.offsetTop;
+            // clear form vars
+            setTimeout(function() { form.clk = form.clk_x = form.clk_y = null; }, 10);
+// ajaxFormUnbind unbinds the event handlers that were bound by ajaxForm
+$.fn.ajaxFormUnbind = function() {
+    this.unbind('submit.form-plugin');
+    return this.each(function() {
+        $(":submit,input:image", this).unbind('click.form-plugin');
+ * formToArray() gathers form element data into an array of objects that can
+ * be passed to any of the following ajax functions: $.get, $.post, or load.
+ * Each object in the array has both a 'name' and 'value' property.  An example of
+ * an array for a simple login form might be:
+ * [ { name: 'username', value: 'jresig' }, { name: 'password', value: 'secret' } ]
+ * It is this array that is passed to pre-submit callback functions provided to the
+ * ajaxSubmit() and ajaxForm() methods.
+$.fn.formToArray = function(semantic) {
+    var a = [];
+    if (this.length == 0) return a;
+    var form = this[0];
+    var els = semantic ? form.getElementsByTagName('*') : form.elements;
+    if (!els) return a;
+    for(var i=0, max=els.length; i < max; i++) {
+        var el = els[i];
+        var n = el.name;
+        if (!n) continue;
+        if (semantic && form.clk && el.type == "image") {
+            // handle image inputs on the fly when semantic == true
+            if(!el.disabled && form.clk == el)
+                a.push({name: n+'.x', value: form.clk_x}, {name: n+'.y', value: form.clk_y});
+            continue;
+        var v = $.fieldValue(el, true);
+        if (v && v.constructor == Array) {
+            for(var j=0, jmax=v.length; j < jmax; j++)
+                a.push({name: n, value: v[j]});
+        else if (v !== null && typeof v != 'undefined')
+            a.push({name: n, value: v});
+    if (!semantic && form.clk) {
+        // input type=='image' are not found in elements array! handle them here
+        var inputs = form.getElementsByTagName("input");
+        for(var i=0, max=inputs.length; i < max; i++) {
+            var input = inputs[i];
+            var n = input.name;
+            if(n && !input.disabled && input.type == "image" && form.clk == input)
+    return a;
+ * Serializes form data into a 'submittable' string. This method will return a string
+ * in the format: name1=value1&name2=value2
+$.fn.formSerialize = function(semantic) {
+    //hand off to jQuery.param for proper encoding
+    return $.param(this.formToArray(semantic));
+ * Serializes all field elements in the jQuery object into a query string.
+ * This method will return a string in the format: name1=value1&name2=value2
+$.fn.fieldSerialize = function(successful) {
+    var a = [];
+    this.each(function() {
+        var n = this.name;
+        if (!n) return;
+        var v = $.fieldValue(this, successful);
+            for (var i=0,max=v.length; i < max; i++)
+                a.push({name: n, value: v[i]});
+            a.push({name: this.name, value: v});
+    return $.param(a);
+ * Returns the value(s) of the element in the matched set.  For example, consider the following form:
+ *  <form><fieldset>
+ *      <input name="A" type="text" />
+ *      <input name="B" type="checkbox" value="B1" />
+ *      <input name="B" type="checkbox" value="B2"/>
+ *      <input name="C" type="radio" value="C1" />
+ *      <input name="C" type="radio" value="C2" />
+ *  </fieldset></form>
+ *  var v = $(':text').fieldValue();
+ *  // if no values are entered into the text inputs
+ *  v == ['','']
+ *  // if values entered into the text inputs are 'foo' and 'bar'
+ *  v == ['foo','bar']
+ *  var v = $(':checkbox').fieldValue();
+ *  // if neither checkbox is checked
+ *  v === undefined
+ *  // if both checkboxes are checked
+ *  v == ['B1', 'B2']
+ *  var v = $(':radio').fieldValue();
+ *  // if neither radio is checked
+ *  v === undefined
+ *  // if first radio is checked
+ *  v == ['C1']
+ * The successful argument controls whether or not the field element must be 'successful'
+ * (per http://www.w3.org/TR/html4/interact/forms.html#successful-controls).
+ * The default value of the successful argument is true.  If this value is false the value(s)
+ * for each element is returned.
+ * Note: This method *always* returns an array.  If no valid value can be determined the
+ *       array will be empty, otherwise it will contain one or more values.
+$.fn.fieldValue = function(successful) {
+    for (var val=[], i=0, max=this.length; i < max; i++) {
+        var el = this[i];
+        var v = $.fieldValue(el, successful);
+        if (v === null || typeof v == 'undefined' || (v.constructor == Array && !v.length))
+            continue;
+        v.constructor == Array ? $.merge(val, v) : val.push(v);
+    return val;
+ * Returns the value of the field element.
+$.fieldValue = function(el, successful) {
+    var n = el.name, t = el.type, tag = el.tagName.toLowerCase();
+    if (typeof successful == 'undefined') successful = true;
+    if (successful && (!n || el.disabled || t == 'reset' || t == 'button' ||
+        (t == 'checkbox' || t == 'radio') && !el.checked ||
+        (t == 'submit' || t == 'image') && el.form && el.form.clk != el ||
+        tag == 'select' && el.selectedIndex == -1))
+            return null;
+    if (tag == 'select') {
+        var index = el.selectedIndex;
+        if (index < 0) return null;
+        var a = [], ops = el.options;
+        var one = (t == 'select-one');
+        var max = (one ? index+1 : ops.length);
+        for(var i=(one ? index : 0); i < max; i++) {
+            var op = ops[i];
+            if (op.selected) {
+				var v = op.value;
+				if (!v) // extra pain for IE...
+                	v = (op.attributes && op.attributes['value'] && !(op.attributes['value'].specified)) ? op.text : op.value;
+                if (one) return v;
+                a.push(v);
+        return a;
+    return el.value;
+ * Clears the form data.  Takes the following actions on the form's input fields:
+ *  - input text fields will have their 'value' property set to the empty string
+ *  - select elements will have their 'selectedIndex' property set to -1
+ *  - checkbox and radio inputs will have their 'checked' property set to false
+ *  - inputs of type submit, button, reset, and hidden will *not* be effected
+ *  - button elements will *not* be effected
+$.fn.clearForm = function() {
+        $('input,select,textarea', this).clearFields();
+ * Clears the selected form elements.
+$.fn.clearFields = $.fn.clearInputs = function() {
+        var t = this.type, tag = this.tagName.toLowerCase();
+        if (t == 'text' || t == 'password' || tag == 'textarea')
+            this.value = '';
+        else if (t == 'checkbox' || t == 'radio')
+            this.checked = false;
+        else if (tag == 'select')
+            this.selectedIndex = -1;
+ * Resets the form data.  Causes all form elements to be reset to their original value.
+$.fn.resetForm = function() {
+        // guard against an input with the name of 'reset'
+        // note that IE reports the reset function as an 'object'
+        if (typeof this.reset == 'function' || (typeof this.reset == 'object' && !this.reset.nodeType))
+            this.reset();
+ * Enables or disables any matching elements.
+$.fn.enable = function(b) {
+    if (b == undefined) b = true;
+        this.disabled = !b
+ * Checks/unchecks any matching checkboxes or radio buttons and
+ * selects/deselects and matching option elements.
+$.fn.selected = function(select) {
+    if (select == undefined) select = true;
+        var t = this.type;
+        if (t == 'checkbox' || t == 'radio')
+            this.checked = select;
+        else if (this.tagName.toLowerCase() == 'option') {
+            var $sel = $(this).parent('select');
+            if (select && $sel[0] && $sel[0].type == 'select-one') {
+                // deselect all other options
+                $sel.find('option').selected(false);
+            this.selected = select;
+// helper fn for console logging
+// set $.fn.ajaxSubmit.debug to true to enable debug logging
+function log() {
+    if ($.fn.ajaxSubmit.debug && window.console && window.console.log)
+        window.console.log('[jquery.form] ' + Array.prototype.join.call(arguments,''));
+})(jQuery);
More information about the Mapbender_commits
