[Mapbender-commits] r3647 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Mon Mar 9 04:14:38 EDT 2009
Author: verenadiewald
Date: 2009-03-09 04:14:38 -0400 (Mon, 09 Mar 2009)
New Revision: 3647
trunk/mapbender/resources/db/update/update_2.6.sql
featureInfo popup for gui2, not for gui_digitize
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql 2009-03-08 18:22:05 UTC (rev 3646)
+++ trunk/mapbender/resources/db/update/update_2.6.sql 2009-03-09 08:14:38 UTC (rev 3647)
@@ -386,11 +386,11 @@
--INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');--INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
--INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
More information about the Mapbender_commits
