[Mapbender-commits] r3689 - trunk/mapbender/http/javascripts
    svn_mapbender at osgeo.org
    Thu Mar 12 13:20:11 EDT 2009
Author: verenadiewald
Date: 2009-03-12 13:20:11 -0400 (Thu, 12 Mar 2009)
New Revision: 3689
   trunk/mapbender/http/javascripts/mod_tooltip.php
improved workflow
Modified: trunk/mapbender/http/javascripts/mod_tooltip.php
--- trunk/mapbender/http/javascripts/mod_tooltip.php	2009-03-12 17:11:45 UTC (rev 3688)
+++ trunk/mapbender/http/javascripts/mod_tooltip.php	2009-03-12 17:20:11 UTC (rev 3689)
@@ -69,29 +69,38 @@
 //buttonWfs_toDigitize_on ="0";
 function mod_tooltipInit(){
-var tooltip_map = getMapObjByName(tooltipTarget);
-var ind = getMapObjIndexByName(tooltipTarget);
-var myMapObj = mb_mapObj[ind];
+	var tooltip_map = getMapObjByName(tooltipTarget);
+	var ind = getMapObjIndexByName(tooltipTarget);
+	var myMapObj = mb_mapObj[ind];
-var map_el = myMapObj.getDomElement();
+	var map_el = myMapObj.getDomElement();
 	$(map_el.ownerDocument).mousemove(function(event){
-		var point = tooltip_map.getMousePos(event);
+		point = tooltip_map.getMousePosition(event);
 		//mb_getMousePos(event,myMapObj.getMousePosition(event));
-		mod_tooltip_run();
+		mod_tooltip_run(point);
 	}).mouseout(function(){mouseMoves=0;});
 eventInit.register(mod_tooltipInit);
-function mod_tooltip_run(){
+function mod_tooltip_run(point){
 	mouseMoves++;
-	setTimeout("if(mouseMoves=="+mouseMoves+"&&clickX=="+clickX+"&&clickY=="+clickY+")fireRequests();",tooltip_timeDelay);
+	var currentMouseMoves = mouseMoves;
+	setTimeout(function () {
+			if(point !== null && mouseMoves == currentMouseMoves) {
+				fireRequests(point);
+		,tooltip_timeDelay
-function fireRequests(){
+function fireRequests(point){
-	point = new Point(clickX,clickY);
 	var point_geom = new Geometry(geomType.point);
 	point_geom.addPoint(mapToReal(tooltipTarget,point));
 	visibleRequest = 0;
@@ -135,8 +144,9 @@
 	for(var k=0;k < no_result_text.length;k++){
 		if(js_code.indexOf(no_result_text[k])!==-1){
-			if(!isFirstResult())
+			if(!isFirstResult()) {
 				displayResultDoc("");
 			return;
@@ -175,8 +185,9 @@
 function displayResultDoc(html){
 	//test if we have a fixed destination and create popup otherwise
-	if(tooltip_destinationFrame=="")
+	if(tooltip_destinationFrame=="") {
 		return showBalloonFrame(html);
 	//put the frame there
 	$("#"+tooltip_destinationFrame).each(function(){
@@ -185,7 +196,7 @@
 	        oDoc = oDoc.document;
 		if(isFirstResult())
-	  		oDoc.open();
+			oDoc.open();
 		oDoc.write(html);
 		if(isLastResult())
 			oDoc.close();
@@ -195,7 +206,8 @@
 function showBalloonFrame(html){
 	if(isFirstResult()){
-		//claculate Position
+		//calculate Position
 		x=point.x+parseInt(document.getElementById(tooltipTarget).style.left);
 		y=point.y+parseInt(document.getElementById(tooltipTarget).style.top);
@@ -216,6 +228,7 @@
 	//finally display popup
 	tooltipWin.show();
+	visibleRequest++;
 function getWfsRequests(target, geom, checkscale, filteroption){
More information about the Mapbender_commits
