[Mapbender-commits] r3690 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Thu Mar 12 13:48:42 EDT 2009
Author: astrid_emde
Date: 2009-03-12 13:48:41 -0400 (Thu, 12 Mar 2009)
New Revision: 3690
trunk/mapbender/resources/db/update/update_2.6.sql
Update URL to Mapbender help
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql 2009-03-12 17:20:11 UTC (rev 3689)
+++ trunk/mapbender/resources/db/update/update_2.6.sql 2009-03-12 17:48:41 UTC (rev 3690)
@@ -464,4 +464,32 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_timeDelay', '1000', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'wfs_conf_filename', 'wfs_default.conf', '', 'php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_width', '270', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_height', '200', '', 'var');
\ No newline at end of file
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_height', '200', '', 'var');
+-- Update URL to Mapbender help
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/AddWMS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'addWMS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Back' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'back';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Copyright' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'copyright';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DragMapSize' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dragMapSize';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DependentDiv' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dependentDiv';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfo' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfo1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoRedirect' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'FeatureInfoRedirect';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoTunnel' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfoTunnel';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Forward' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'forward';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/GazetteerWFS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'gazetteerWFS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Logout' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'logout';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Mapframe' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'mapframe1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Metadata' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'metadata';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/NavFrame' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'navFrame';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Overview' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'overview';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Pan' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'pan1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Print' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'printPDF';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SaveWMC' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'savewmc';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SelArea1' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'selArea1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SetBackground' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'setBackground';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ShowCoords_div' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'showCoords_div';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/TreeGde' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'treeGDE';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/WMS_preferences' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'WMS_preferences';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomFull' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomFull';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomIn' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomIn1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomOut' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomOut1';
More information about the Mapbender_commits
