[Mapbender-commits] r3705 - trunk/mapbender/http/classes
    svn_mapbender at osgeo.org
    Fri Mar 13 09:34:54 EDT 2009
Author: christoph
Date: 2009-03-13 09:34:53 -0400 (Fri, 13 Mar 2009)
New Revision: 3705
   trunk/mapbender/http/classes/class_map.php
   trunk/mapbender/http/classes/class_wmc.php
http://trac.osgeo.org/mapbender/ticket/392
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php	2009-03-13 13:11:10 UTC (rev 3704)
+++ trunk/mapbender/http/classes/class_map.php	2009-03-13 13:34:53 UTC (rev 3705)
@@ -9,7 +9,7 @@
 	private $width;
 	private $height;
 	private $frameName;
-	private $elementName = "maps";
+	private $elementName;
 	private $extent;
 	private $zoomFullExtentArray = array();
 	private $isOverview = false;
@@ -260,7 +260,8 @@
 		$this->width = $jsMapObject->width;
 		$this->height = $jsMapObject->height;
-		$this->frameName = $jsMapObject->frameName;
+		// there are no more map frames in Mapbender 2.6
+		$this->frameName = $jsMapObject->elementName;
 		$this->extent = $bbox;
 		if (isset($jsMapObject->isOverview) && $jsMapObject->isOverview == "1") {
@@ -400,9 +401,10 @@
 		if ($wmsIndex === null) {
 			$wmsIndex = "null";
-		$registerMapString = "mb_registerMapObj('" .
-			$this->frameName . "', " .
-			"'maps', " .
+		// syntax has changed in 2.6! Map is no longer a frame
+		$registerMapString = "mb_registerMapObj('', " .
+			"'" . $this->frameName . "', " .
 			$wmsIndex . ", " .
 			$this->width . ", " .
 			$this->height . ");";
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2009-03-13 13:11:10 UTC (rev 3704)
+++ trunk/mapbender/http/classes/class_wmc.php	2009-03-13 13:34:53 UTC (rev 3705)
@@ -502,7 +502,7 @@
 			$tagLowerCase = administration::sepNameSpace($element[tag]);
 			$type = $element[type];
 			$attributes = $element[attributes];
-			$value = mb_utf8_decode(html_entity_decode($element[value])); // TODO: not sure if utf decoding is necessary
+			$value = mb_utf8_decode(html_entity_decode($element[value]));
 			if ($tag == "VIEWCONTEXT" && $type == "open") {
 				$this->wmc_id = $attributes["id"];
@@ -915,6 +915,11 @@
 			$currentMapIsOverview = true;
+		if (is_null($currentMap)) {
+			$e = new mb_exception('class_wmc.php: setLayerData: $currentMap is null. Aborting.');
+			return null;
 		$wmsArray = $currentMap->getWmsArray();
More information about the Mapbender_commits
