[Mapbender-commits] r3725 - trunk/mapbender/http/html
svn_mapbender at osgeo.org
Sat Mar 14 11:15:03 EDT 2009
Author: astrid_emde
Date: 2009-03-14 11:15:03 -0400 (Sat, 14 Mar 2009)
New Revision: 3725
trunk/mapbender/http/html/mod_treefolderPlain.php
changes for i18n - translation of the context menu
Modified: trunk/mapbender/http/html/mod_treefolderPlain.php
--- trunk/mapbender/http/html/mod_treefolderPlain.php 2009-03-14 15:13:20 UTC (rev 3724)
+++ trunk/mapbender/http/html/mod_treefolderPlain.php 2009-03-14 15:15:03 UTC (rev 3725)
@@ -141,15 +141,15 @@
//menu elements
-var menu_move_up = ['menu_move_up', ['Move up ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
-var menu_move_down = ['menu_move_down', ['Move down ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
-var menu_delete = ['menu_delete', ['Remove ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];remove_wms(ids[0],ids[1],ids[2]);',,'delete_wms.png']];
-var menu_opacity_up = ['menu_opacity_up', ['Opacity up ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
-var menu_opacity_down = ['menu_opacity_down', ['Opacity down ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
-var menu_metalink = ['menu_metalink', ['Information ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[ids[0]].wms[ids[1]].objLayer[ids[2]].layer_uid);',,'info.png']];
-var menu_zoom = ['menu_zoom', ['Zoom ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];zoomToLayer(ids[0],ids[1],ids[2]);',,'zoom.png']];
-var menu_hide = ['menu_hide', ['Hide menu ', 'javascript:hideMenu()',,'hide.png']];
-//var menu_wms_switch = ['menu_zoom', ['Zoom ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+var menu_move_up = ['menu_move_up', ['<?php echo _mb("Move up");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
+var menu_move_down = ['menu_move_down', ['<?php echo _mb("Move down");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
+var menu_delete = ['menu_delete', ['<?php echo _mb("Remove");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];remove_wms(ids[0],ids[1],ids[2]);',,'delete_wms.png']];
+var menu_opacity_up = ['menu_opacity_up', ['<?php echo _mb("Opacity up");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
+var menu_opacity_down = ['menu_opacity_down', ['<?php echo _mb("Opacity down");?> ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
+var menu_metalink = ['menu_metalink', ['<?php echo _mb("Information");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[ids[0]].wms[ids[1]].objLayer[ids[2]].layer_uid);',,'info.png']];
+var menu_zoom = ['menu_zoom', ['<?php echo _mb("Zoom");?> ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];zoomToLayer(ids[0],ids[1],ids[2]);',,'zoom.png']];
+var menu_hide = ['menu_hide', ['<?php echo _mb("Hide menu");?> ', 'javascript:hideMenu()',,'hide.png']];
+//var menu_wms_switch = ['menu_zoom', ['<?php echo _mb("Zoom");?> ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
//var menu_layer_switch = ['menu_zoom', ['Zjjj ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
//var menu_info_switch = ['menu_zoom', ['Zmn ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
@@ -653,7 +653,7 @@
if(temp.gui_layer_queryable!='1')
controls.push('disabled ');
controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
- controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1);\" />");
+ controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1);\" />");
if(wmsbuttons == 'true'&&metadatalink == 'true'){
controls.push('<a href="javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');"><img src="'+imagedir+'/info.png" /></a>');
More information about the Mapbender_commits
