[Mapbender-commits] r3726 - trunk/mapbender/conf
svn_mapbender at osgeo.org
Sat Mar 14 11:34:39 EDT 2009
Author: astrid_emde
Date: 2009-03-14 11:34:39 -0400 (Sat, 14 Mar 2009)
New Revision: 3726
trunk/mapbender/conf/wfs_additional_spatial_search.conf
changes for i18n - translations for spatial buttons, messages
Modified: trunk/mapbender/conf/wfs_additional_spatial_search.conf
--- trunk/mapbender/conf/wfs_additional_spatial_search.conf 2009-03-14 15:15:03 UTC (rev 3725)
+++ trunk/mapbender/conf/wfs_additional_spatial_search.conf 2009-03-14 15:34:39 UTC (rev 3726)
@@ -7,17 +7,17 @@
* [@param {string} filteroption type of filter for search (values: "intersects" or "within"), used for buttons buttonRectangle and buttonPolygon
-var buttonRectangle = {"status":1,"img":"select_rectangle_off.png","title":"select by rectangle","filteroption":"intersects"};
-var buttonPolygon = {"status":1,"img":"select_polygon_off.png","title":"select by polygon","filteroption":"intersects"};
-var buttonPoint = {"status":1, "img":"select_point_off.png","title":"select by point"};
-var buttonExtent = {"status":1,"img":"select_extent_off.png","title":"select by extent"};
+var buttonRectangle = {"status":1,"img":"select_rectangle_off.png","title":"<?php echo _mb("select by rectangle");?>","filteroption":"intersects"};
+var buttonPolygon = {"status":1,"img":"select_polygon_off.png","title":"<?php echo _mb("select by polygon");?>","filteroption":"intersects"};
+var buttonPoint = {"status":1, "img":"select_point_off.png","title":"<?php echo _mb("select by point");?>"};
+var buttonExtent = {"status":1,"img":"select_extent_off.png","title":"<?php echo _mb("select by extent");?>"};
var mb_wfs_tolerance = 8;
-var spatialRequestIsSetMessage = "Spatial filter is set.";
-var clearFilterButtonLabel = "New";
+var spatialRequestIsSetMessage = '<?php echo _mb("Spatial filter is set.");?>';
+var clearFilterButtonLabel = '<?php echo _mb("New");?>';
-var noResultMsg = "No result";
+var noResultMsg = '<?php _mb("No result");?>';
var buttonWfs_imgdir = "../img/button_gray/";
var buttonWfs_zIndex = 10;
@@ -28,13 +28,13 @@
var wfsResultModulePath = "php/";
var wfsResultModuleFilename = "mod_wfs_result.php";
-var searchPopupTitle = "Search results";
+var searchPopupTitle = '<?php echo _mb("Search results");?>';
var searchPopupWidth = 400;
var searchPopupHeight =250;
var searchPopupX = 750;
var searchPopupY = 80;
-var detailPopupTitle = "Details";
+var detailPopupTitle = '<?php echo _mb("Details");?>';
var detailPopupWidth = 400;
var detailPopupHeight = 200;
var detailPopupX = 750;
More information about the Mapbender_commits
