[Mapbender-commits] r5476 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Feb 1 06:35:02 EST 2010
Author: christoph
Date: 2010-02-01 06:35:01 -0500 (Mon, 01 Feb 2010)
New Revision: 5476
   trunk/mapbender/http/classes/class_wfs_conf.php
Modified: trunk/mapbender/http/classes/class_wfs_conf.php
--- trunk/mapbender/http/classes/class_wfs_conf.php	2010-02-01 11:30:48 UTC (rev 5475)
+++ trunk/mapbender/http/classes/class_wfs_conf.php	2010-02-01 11:35:01 UTC (rev 5476)
@@ -1,384 +1,385 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_wfs_conf.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/../classes/class_user.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-class WfsConf {
-	var $confArray = array();
-	 * Gets the configuration from the database
-	function __construct () {
-	function __toString () {
-		$json = new Mapbender_JSON();
-		return $json->encode($this->confArray);
-	 * Loads WFS conf data from the database
-	 * @return Object WFS conf data.
-	 * @param $idOrIdArray Object May be an integer or an array of integers representing WFS conf IDs.
-	public function load ($idOrIdArray) {
-		// Check parameter and set idArray
-		if (isset($idOrIdArray)){
-			// parameter is a number
-			if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
-				$idOrIdArray = array(intval($idOrIdArray));
-			// parameter is an array of numbers
-			if (is_array($idOrIdArray)) {
-				$idArray = array();
-				for ($i=0; $i < count($idOrIdArray); $i++) {
-					if (!is_numeric($idOrIdArray[$i])) {
-						$e = new mb_exception("Wfs_conf: constructor: wrong parameter: ".$idOrIdArray[$i]." is not a number.");
-						return array();
-					array_push($idArray, intval($idOrIdArray[$i]));
-				// If a user ID is given, remove the ones the user has no access to
-				if (Mapbender::session()->get("mb_user_id")) {
-					$user = new User(Mapbender::session()->get("mb_user_id"));
-					$idArray = array_intersect($idArray, $user->getWfsConfByPermission());
-				return $this->getWfsConfFromDb($idArray);
-			// parameter is invalid
-			else {
-				$e = new mb_exception("Wfs_conf: constructor: parameter must be number or an array of numbers.");
-				return array();
-		else {
-			$e = new mb_exception("Wfs_conf: constructor: parameter is not valid");
-			return null;
-	// --------------------------- private -----------------------------------
-	 * Gets the database content for a number of WFS configurations given by their IDs.
-	 * @return Array
-	 * @param $idArray Array an array of integer values representing WFS conf IDs.
-	private static function getWfsConfFromDbByArray ($idArray) {
-		$rowArray = array();
-        foreach ($idArray as $id) {
-        		$sql = "SELECT * FROM wfs_conf ";
-                $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
-                $sql .= "WHERE wfs_conf.wfs_conf_id = $1 LIMIT 1";
-                $v = array($id);
-                $t = array("i");
-                $res = db_prep_query($sql, $v, $t);
-                $row = db_fetch_array($res);
-                array_push($rowArray, $row);
-        return $rowArray;
-	public static function getGeomColumnNameByConfId ($confId) {
-		$elArray = self::getWfsConfElementFromDb($confId);
-		foreach ($elArray as $element) {
-			if ($element["f_geom"] == "1") {
-				return $element["element_name"];
-		return null;
-	 * Gets the database content of a WFS conf element given by a WFS conf ID.
-	 * @return Array
-	 * @param $id Integer the WFS conf ID.
-	private static function getWfsConfElementFromDb ($id) {
-		$sql = "SELECT * FROM wfs_conf_element ";
-		$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-		$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-		#filtered on client side
-		#$sql .= "AND wfs_conf_element.f_search = 1 ";
-		$sql .= "ORDER BY wfs_conf_element.f_pos";
-		$v = array($id);
-		$t = array('i');
-		$elementArray = array();
-		while ($row = db_fetch_array($res)) {
-			$currentElement = array("element_name" => $row["element_name"],
-									"element_type" => $row["element_type"],
-									"f_search" => $row["f_search"],
-									"f_style_id" => $row["f_style_id"],
-									"f_toupper" => $row["f_toupper"],
-									"f_label" => $row["f_label"],
-									"f_label_id" => $row["f_label_id"],
-									"f_geom" => $row["f_geom"],
-									"f_show" => $row["f_show"],
-									"f_mandatory" => $row["f_mandatory"],
-									"f_respos" => $row["f_respos"],
-									"f_min_input" => $row["f_min_input"],
-									"f_form_element_html" => $row["f_form_element_html"],
-									"f_auth_varname" => $row["f_auth_varname"],
-									"f_detailpos" => $row["f_detailpos"],
-									"f_operator" => $row["f_operator"],
-									"f_show_detail" => $row["f_show_detail"]
-			array_push($elementArray, $currentElement);
-		return $elementArray;
-	 * Gets the database content of a WFS feature type given by a WFS ID and a featuretype ID.
-	 * @return Array
-	 * @param $wfsId Integer the WFS ID.
-	 * @param $featuretypeId Integer the WFS featuretype ID.
-	private static function getWfsFeatureTypeFromDb($wfsId, $featuretypeId) {
-		$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
-		$v = array($wfsId, $featuretypeId);
-		$t = array("i", "i");
-		$currentRow = array();
-		if($row = db_fetch_array($res)){
-			$currentRow["featuretype_name"] = $row["featuretype_name"];
-			$currentRow["featuretype_srs"] = $row["featuretype_srs"];
-		return $currentRow;
-	 * get WFS conf data from database
-	private function getWfsConfFromDB ($idArray) {
-		// if a user has access to some WFS confs...
-		if (count($idArray) > 0) {
-			// get WFS conf data from DB
-			$rowArray = self::getWfsConfFromDbByArray($idArray);
-			for ($i=0; $i < count($rowArray); $i++) {
-				// WFS conf data
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_wfs_conf.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+class WfsConf {
+	var $confArray = array();
+	 * Gets the configuration from the database
+	function __construct () {
+	function __toString () {
+		$json = new Mapbender_JSON();
+		return $json->encode($this->confArray);
+	 * Loads WFS conf data from the database
+	 * @return Object WFS conf data.
+	 * @param $idOrIdArray Object May be an integer or an array of integers representing WFS conf IDs.
+	public function load ($idOrIdArray) {
+		// Check parameter and set idArray
+		if (isset($idOrIdArray)){
+			// parameter is a number
+			if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
+				$idOrIdArray = array(intval($idOrIdArray));
+			// parameter is an array of numbers
+			if (is_array($idOrIdArray)) {
+				$idArray = array();
+				for ($i=0; $i < count($idOrIdArray); $i++) {
+					if (!is_numeric($idOrIdArray[$i])) {
+						$e = new mb_exception("Wfs_conf: constructor: wrong parameter: ".$idOrIdArray[$i]." is not a number.");
+						return array();
+					array_push($idArray, intval($idOrIdArray[$i]));
+				// If a user ID is given, remove the ones the user has no access to
+				if (Mapbender::session()->get("mb_user_id")) {
+					$user = new User(Mapbender::session()->get("mb_user_id"));
+					$idArray = array_intersect($idArray, $user->getWfsConfByPermission());
+				return $this->getWfsConfFromDb($idArray);
+			// parameter is invalid
+			else {
+				$e = new mb_exception("Wfs_conf: constructor: parameter must be number or an array of numbers.");
+				return array();
+		else {
+			$e = new mb_exception("Wfs_conf: constructor: parameter is not valid");
+			return null;
+	// --------------------------- private -----------------------------------
+	 * Gets the database content for a number of WFS configurations given by their IDs.
+	 * @return Array
+	 * @param $idArray Array an array of integer values representing WFS conf IDs.
+	private static function getWfsConfFromDbByArray ($idArray) {
+		$rowArray = array();
+        foreach ($idArray as $id) {
+        		$sql = "SELECT * FROM wfs_conf ";
+                $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+                $sql .= "WHERE wfs_conf.wfs_conf_id = $1 LIMIT 1";
+                $v = array($id);
+                $t = array("i");
+                $res = db_prep_query($sql, $v, $t);
+                $row = db_fetch_array($res);
+                array_push($rowArray, $row);
+        return $rowArray;
+	public static function getGeomColumnNameByConfId ($confId) {
+		$elArray = self::getWfsConfElementFromDb($confId);
+		foreach ($elArray as $element) {
+			if ($element["f_geom"] == "1") {
+				return $element["element_name"];
+		return null;
+	 * Gets the database content of a WFS conf element given by a WFS conf ID.
+	 * @return Array
+	 * @param $id Integer the WFS conf ID.
+	private static function getWfsConfElementFromDb ($id) {
+		$sql = "SELECT * FROM wfs_conf_element ";
+		$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+		$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+		#filtered on client side
+		#$sql .= "AND wfs_conf_element.f_search = 1 ";
+		$sql .= "ORDER BY wfs_conf_element.f_pos";
+		$v = array($id);
+		$t = array('i');
+		$elementArray = array();
+		while ($row = db_fetch_array($res)) {
+			$currentElement = array("element_name" => $row["element_name"],
+									"element_type" => $row["element_type"],
+									"f_search" => $row["f_search"],
+									"f_style_id" => $row["f_style_id"],
+									"f_toupper" => $row["f_toupper"],
+									"f_label" => $row["f_label"],
+									"f_label_id" => $row["f_label_id"],
+									"f_geom" => $row["f_geom"],
+									"f_show" => $row["f_show"],
+									"f_mandatory" => $row["f_mandatory"],
+									"f_respos" => $row["f_respos"],
+									"f_min_input" => $row["f_min_input"],
+									"f_form_element_html" => $row["f_form_element_html"],
+									"f_auth_varname" => $row["f_auth_varname"],
+									"f_detailpos" => $row["f_detailpos"],
+									"f_operator" => $row["f_operator"],
+									"f_show_detail" => $row["f_show_detail"]
+			array_push($elementArray, $currentElement);
+		return $elementArray;
+	 * Gets the database content of a WFS feature type given by a WFS ID and a featuretype ID.
+	 * @return Array
+	 * @param $wfsId Integer the WFS ID.
+	 * @param $featuretypeId Integer the WFS featuretype ID.
+	private static function getWfsFeatureTypeFromDb($wfsId, $featuretypeId) {
+		$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
+		$v = array($wfsId, $featuretypeId);
+		$t = array("i", "i");
+		$currentRow = array();
+		if($row = db_fetch_array($res)){
+			$currentRow["featuretype_name"] = $row["featuretype_name"];
+			$currentRow["featuretype_srs"] = $row["featuretype_srs"];
+		return $currentRow;
+	 * get WFS conf data from database
+	private function getWfsConfFromDB ($idArray) {
+		// if a user has access to some WFS confs...
+		if (count($idArray) > 0) {
+			// get WFS conf data from DB
+			$rowArray = self::getWfsConfFromDbByArray($idArray);
+			for ($i=0; $i < count($rowArray); $i++) {
+				// WFS conf data
 				$currentRow = array("g_label" => $rowArray[$i]["g_label"],
-									"wfs_conf_abstract" => $rowArray[$i]["wfs_conf_abstract"],
-			                        "g_label_id" => $rowArray[$i]["g_label_id"],
-									"g_style" => $rowArray[$i]["g_style"],
-									"g_button" => $rowArray[$i]["g_button"],
-									"g_button_id" => $rowArray[$i]["g_button_id"],
-									"g_buffer" => $rowArray[$i]["g_buffer"],
-									"g_res_style" => $rowArray[$i]["g_res_style"],
-									"g_use_wzgraphics" => $rowArray[$i]["g_use_wzgraphics"],
-									"wfs_id" => $rowArray[$i]["fkey_wfs_id"],
-									"featuretype_id" => $rowArray[$i]["fkey_featuretype_id"],
-									"wfs_getfeature" => $rowArray[$i]["wfs_getfeature"],
-									"wfs_describefeaturetype" => $rowArray[$i]["wfs_describefeaturetype"],
-									"wfs_transaction" => $rowArray[$i]["wfs_transaction"],
-									"element" => $elementArray
-				// get WFS conf element data of current WFS conf
-				$id = $rowArray[$i]["wfs_conf_id"];
-				$currentRow["element"] = self::getWfsConfElementFromDb($id);
-				// get WFS featuretype data of current WFS conf
-				$wfsId = $rowArray[$i]["fkey_wfs_id"];
-				$featuretypeId = $rowArray[$i]["fkey_featuretype_id"];
-				$currentRow = array_merge($currentRow , self::getWfsFeatureTypeFromDb($wfsId, $featuretypeId));
-				$this->confArray[$id] = $currentRow;
-			return $this->confArray;
-		else {
-			$e = new mb_warning("class_wfs_conf.php: getWfsConfFromDB: You don't have access to any WFS confs. Check EDIT WFS.");
-			return array();
- * @deprecated
-class wfs_conf{
-	var $wfs_id;
-	var $wfs_name;
-	var $wfs_title;
-	var $wfs_abstract;
-	var $wfs_getcapabilities;
-	var $wfs_describefeaturetype;
-	var $wfs_getfeature;
-	var $features;
-	var $elements;
-	var $namespaces;
-	function getallwfs($userid){
-		$this->wfs_id = array();
-		$this->wfs_name = array();
-		$this->wfs_title = array();
-		$this->wfs_abstract = array();
-		global $DBSERVER,$DB,$OWNER,$PW;
-		$con = db_connect($DBSERVER,$OWNER,$PW);
-		db_select_db($DB,$con);
-		if($userid){
-		 	$sql = "SELECT * FROM wfs WHERE wfs_owner = $1";
-			$v = array($userid);
-			$t = array('i');
-			$res = db_prep_query($sql,$v,$t);
-		else{
-		 	$sql = "SELECT * FROM wfs";
-			$res = db_query($sql);
-		$cnt = 0;
-		while ($row = db_fetch_array($res)){
-			$this->wfs_version[$cnt] = $row["wfs_version"];
-			$this->wfs_id[$cnt] = $row["wfs_id"];
-			$this->wfs_name[$cnt] = $row["wfs_name"];
-			$this->wfs_title[$cnt] = $row["wfs_title"];
-			$this->wfs_abstract[$cnt] = $row["wfs_abstract"];
-			$this->wfs_getcapabilities[$cnt] = $row["wfs_getcapabilities"];
-			$this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
-			$this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
-			$cnt++;
-	function getfeatures($wfsid){
-		$this->features = new features($wfsid);
-	function getelements($feature){
-		$this->elements = new elements($feature);
-	function getnamespaces($feature){
-		$this->namespaces = new namespaces($feature);
-class features extends wfs_conf{
-	var $featuretype_id;
-	var $featuretype_name;
-	var $featuretype_title;
-	var $featuretype_srs;
-	function features($id){
-		$featuretype_id = array();
-		$featuretype_name = array();
-		$featuretype_title = array();
-		$featuretype_srs = array();
-		$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1";
-		$v = array($id);
-		$t = array("i");
-		$cnt = 0;
-			$this->featuretype_id[$cnt] = $row["featuretype_id"];
-			$this->featuretype_name[$cnt] = $row["featuretype_name"];
-			$this->featuretype_title[$cnt] = $row["featuretype_title"];
-			$this->featuretype_srs[$cnt] = $row["featuretype_srs"];
-			$cnt++;
-class elements extends wfs_conf{
-	var $element_id;
-	var $element_name;
-	var $element_type;
-	function elements($fid){
-		$element_id = array();
-		$element_name = array();
-		$element_type = array();
-		$sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = $1";
-		$v = array($fid);
-		$t = array("s");
-		$cnt = 0;
-			$this->element_id[$cnt] = $row["element_id"];
-			$this->element_name[$cnt] = $row["element_name"];
-			$this->element_type[$cnt] = $row["element_type"];
-			$cnt++;
-class namespaces extends wfs_conf{
-	var $namespace_name;
-	var $namespace_location;
-	function namespaces($fid){
-		$namespace_name = array();
-		$namespace_location = array();
-		$sql = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = $1";
-		$v = array($fid);
-		$t = array("s");
-		$cnt = 0;
-			$this->namespace_name[$cnt] = $row["namespace"];
-			$this->namespace_location[$cnt] = $row["namespace_location"];
-			$cnt++;
+									"wfs_conf_abstract" => $rowArray[$i]["wfs_conf_abstract"],
+			                        "g_label_id" => $rowArray[$i]["g_label_id"],
+									"g_style" => $rowArray[$i]["g_style"],
+									"g_button" => $rowArray[$i]["g_button"],
+									"g_button_id" => $rowArray[$i]["g_button_id"],
+									"g_buffer" => $rowArray[$i]["g_buffer"],
+									"g_res_style" => $rowArray[$i]["g_res_style"],
+									"g_use_wzgraphics" => $rowArray[$i]["g_use_wzgraphics"],
+									"wfs_id" => $rowArray[$i]["fkey_wfs_id"],
+									"featuretype_id" => $rowArray[$i]["fkey_featuretype_id"],
+									"wfs_getfeature" => $rowArray[$i]["wfs_getfeature"],
+									"wfs_describefeaturetype" => $rowArray[$i]["wfs_describefeaturetype"],
+									"wfs_transaction" => $rowArray[$i]["wfs_transaction"],
+									"wfs_conf_id" => $rowArray[$i]["wfs_conf_id"],
+									"element" => $elementArray
+				// get WFS conf element data of current WFS conf
+				$id = $rowArray[$i]["wfs_conf_id"];
+				$currentRow["element"] = self::getWfsConfElementFromDb($id);
+				// get WFS featuretype data of current WFS conf
+				$wfsId = $rowArray[$i]["fkey_wfs_id"];
+				$featuretypeId = $rowArray[$i]["fkey_featuretype_id"];
+				$currentRow = array_merge($currentRow , self::getWfsFeatureTypeFromDb($wfsId, $featuretypeId));
+				$this->confArray[$id] = $currentRow;
+			return $this->confArray;
+		else {
+			$e = new mb_warning("class_wfs_conf.php: getWfsConfFromDB: You don't have access to any WFS confs. Check EDIT WFS.");
+			return array();
+ * @deprecated
+class wfs_conf{
+	var $wfs_id;
+	var $wfs_name;
+	var $wfs_title;
+	var $wfs_abstract;
+	var $wfs_getcapabilities;
+	var $wfs_describefeaturetype;
+	var $wfs_getfeature;
+	var $features;
+	var $elements;
+	var $namespaces;
+	function getallwfs($userid){
+		$this->wfs_id = array();
+		$this->wfs_name = array();
+		$this->wfs_title = array();
+		$this->wfs_abstract = array();
+		global $DBSERVER,$DB,$OWNER,$PW;
+		$con = db_connect($DBSERVER,$OWNER,$PW);
+		db_select_db($DB,$con);
+		if($userid){
+		 	$sql = "SELECT * FROM wfs WHERE wfs_owner = $1";
+			$v = array($userid);
+			$t = array('i');
+			$res = db_prep_query($sql,$v,$t);
+		else{
+		 	$sql = "SELECT * FROM wfs";
+			$res = db_query($sql);
+		$cnt = 0;
+		while ($row = db_fetch_array($res)){
+			$this->wfs_version[$cnt] = $row["wfs_version"];
+			$this->wfs_id[$cnt] = $row["wfs_id"];
+			$this->wfs_name[$cnt] = $row["wfs_name"];
+			$this->wfs_title[$cnt] = $row["wfs_title"];
+			$this->wfs_abstract[$cnt] = $row["wfs_abstract"];
+			$this->wfs_getcapabilities[$cnt] = $row["wfs_getcapabilities"];
+			$this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
+			$this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
+			$cnt++;
+	function getfeatures($wfsid){
+		$this->features = new features($wfsid);
+	function getelements($feature){
+		$this->elements = new elements($feature);
+	function getnamespaces($feature){
+		$this->namespaces = new namespaces($feature);
+class features extends wfs_conf{
+	var $featuretype_id;
+	var $featuretype_name;
+	var $featuretype_title;
+	var $featuretype_srs;
+	function features($id){
+		$featuretype_id = array();
+		$featuretype_name = array();
+		$featuretype_title = array();
+		$featuretype_srs = array();
+		$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1";
+		$v = array($id);
+		$t = array("i");
+		$cnt = 0;
+			$this->featuretype_id[$cnt] = $row["featuretype_id"];
+			$this->featuretype_name[$cnt] = $row["featuretype_name"];
+			$this->featuretype_title[$cnt] = $row["featuretype_title"];
+			$this->featuretype_srs[$cnt] = $row["featuretype_srs"];
+			$cnt++;
+class elements extends wfs_conf{
+	var $element_id;
+	var $element_name;
+	var $element_type;
+	function elements($fid){
+		$element_id = array();
+		$element_name = array();
+		$element_type = array();
+		$sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = $1";
+		$v = array($fid);
+		$t = array("s");
+		$cnt = 0;
+			$this->element_id[$cnt] = $row["element_id"];
+			$this->element_name[$cnt] = $row["element_name"];
+			$this->element_type[$cnt] = $row["element_type"];
+			$cnt++;
+class namespaces extends wfs_conf{
+	var $namespace_name;
+	var $namespace_location;
+	function namespaces($fid){
+		$namespace_name = array();
+		$namespace_location = array();
+		$sql = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = $1";
+		$v = array($fid);
+		$t = array("s");
+		$cnt = 0;
+			$this->namespace_name[$cnt] = $row["namespace"];
+			$this->namespace_location[$cnt] = $row["namespace_location"];
+			$cnt++;
More information about the Mapbender_commits mailing list
