[Mapbender-commits] r5477 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon Feb 1 07:21:38 EST 2010
Author: astrid_emde
Date: 2010-02-01 07:21:36 -0500 (Mon, 01 Feb 2010)
New Revision: 5477
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
UI classes treeGDE --> a.fkey_gui_id
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-02-01 11:35:01 UTC (rev 5476)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-02-01 12:21:36 UTC (rev 5477)
@@ -1110,7 +1110,7 @@
-- set UI classes for treeGDE
UPDATE gui_element SET e_more_styles = 'visibility:hidden;overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
WHERE e_id = 'treeGDE' AND fkey_gui_id IN
-(SELECT fkey_gui_id FROM gui_element AS a, gui_element AS b WHERE a.e_id = 'tabs' AND b.e_id = 'treeGDE' AND a.fkey_gui_id = b.fkey_gui_id);
+(SELECT a.fkey_gui_id FROM gui_element AS a, gui_element AS b WHERE a.e_id = 'tabs' AND b.e_id = 'treeGDE' AND a.fkey_gui_id = b.fkey_gui_id);
-- remove expanding treeGDE in gui1
UPDATE gui_element SET e_more_styles = 'overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
More information about the Mapbender_commits
