[Mapbender-commits] r5489 - trunk/mapbender/http/classes
    svn_mapbender at osgeo.org
    Tue Feb  9 04:14:10 EST 2010
Author: armin11
Date: 2010-02-09 04:14:10 -0500 (Tue, 09 Feb 2010)
New Revision: 5489
Added:
   trunk/mapbender/http/classes/class_metadata_new.php
new class for metadata searching in the mapbender database (registry) merged from geoportal.rlp
Added: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_metadata_new.php	2010-02-09 09:14:10 UTC (rev 5489)
@@ -0,0 +1,1158 @@
+<?php
+#Script to call this class: http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php
+#Class for getting results out of the mapbender service registry
+#Resulttypes: WMS, WMS-Layer, (WFS), WFS-Featurtyps, WFS-Conf, WMC, GeoRSS-Feeds, ...
+#Possible filters: registrating organizations, time, bbox (fully inside, intersects, fully outside), ISO Topic Categories, INSPIRE themes, INSPIRE: keywords, classification of data/service ... - maybe relevant for the german broker not for one instance, quality and actuality (maybe spatial and temporal), bbox, deegree of conformity with ir, access and use constraints, responsible parties - maybe one is enough? We must have a look at the INSPIRE Metadata IR
+#Metadata we need to fullfil the demands of INSPIRE:
+#1. INSPIRE conformity classification for WMS/WFS/WCS
+#2. Temporal Extents at WMS/WMS-Layer/WFS/WFS-Featuretype levels - for datasets if demanded - til now there is no demand defined in the guidance-paper for metadata ir
+#3. Classified access and use contraints - which classes? - Check IR Data Sharing and IR Metadata
+#4.
+#Every ressource which should be send to INSPIRE can be filtered - but is not neccessary for a standardized approach
+#Another problem is the ranking of the different ressources. The ranking should be homogeneus.
+#Till now we rank the using of WMS Layers when Caps are requested and when s.o. load one layer into the geoportal.
+#The same things have to be done for the wfs-conf, wmc and georssfeeds
+#The searching for metadata should be parallel done. We need different classes for doing the search. They should be requested by one central class (class_metadata.php).
+#Classes for filtering after the results have been send to the portal:
+#1. ISO Topic Categories
+#2. INSPIRE Themes
+#3. Access and use classification
+#4. departments which provides the ressources - we need the new concept for the administration of this departments - store the addresses in the group table and give the relation - originating group in table mb_user_mb_group
+#Cause we have a authorization layer, we need the id of the requesting user which is defined in the session. If no session is set, it should be the anonymous user of the portal.
+#We need a parameter for internationalization - it should be send with the search request! Some of the Classes can be provided with different languages.
+#WMC and GeoRSS-Feeds have no or a to complex authorization info - maybe we need to test if wmc consists of info which is fully or only partually available to the anonymous user.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/class_administration.php");
+require_once(dirname(__FILE__)."/class_mb_exception.php");
+require_once(dirname(__FILE__)."/class_json.php");
+//definition for the things which are common to all kind of metadata ressources
+class searchMetadata {
+	var $userId;
+	var $searchId;
+	var $searchText;
+	var $registratingDepartments;
+	var $isoCategories;
+	var $inspireThemes;
+	var $customCategories;
+	var $timeBegin;
+	var $timeEnd;
+	var $regTimeBegin;
+	var $regTimeEnd;
+	var $maxResults;
+	var $searchBbox;
+	var $searchTypeBbox;
+	var $accessRestrictions;
+	var $languageCode;
+	var $searchStartTime;
+	var $searchView;
+	var $searchURL;
+	var $searchEPSG;
+	var $searchResources;
+	var $searchPages;
+	var $outputFormat;
+	var $resultTarget;
+	var $tempFolder;
+	var $orderBy;
+	function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories){
+		$this->userId = (integer)$userId;
+		$this->searchId = $searchId;
+		$this->searchText = $searchText;
+		$this->registratingDepartments = $registratingDepartments; //array with ids of the registrating groups in the mb database
+		$this->registratingDepartmentsArray = explode(",",$this->registratingDepartments);
+		$this->isoCategories = $isoCategories;
+		$this->inspireThemes = $inspireThemes;
+		$this->customCategories = $customCategories;
+		$this->timeBegin = $timeBegin;
+		$this->timeEnd = $timeEnd;
+		$this->regTimeBegin = $regTimeBegin;
+		$this->regTimeEnd = $regTimeEnd;
+		$this->maxResults = (integer)$maxResults;
+		$this->searchBbox = $searchBbox;
+		$this->searchTypeBbox = $searchTypeBbox;
+		$this->accessRestrictions = $accessRestrictions;
+		$this->languageCode = $languageCode;
+		$this->searchEPSG = $searchEPSG;
+		$this->searchResources = $searchResources;
+		$this->searchPages = $searchPages;
+		$this->outputFormat = $outputFormat;
+		$this->resultTarget = $resultTarget;
+		$this->searchURL = $searchURL;
+		$this->tempFolder = "/tmp"; //TODO define another path - maybe the one which is given in mapbender.conf
+		if ($this->outputFormat == 'json'){
+			$this->json = new Mapbender_JSON;
+		//set a time to find time consumers
+		$this->searchStartTime = $this->microtime_float();
+		//Defining of the different database categories
+		$this->resourceClassifications = array();
+		$this->resourceClassifications[0]['title'] = "ISO 19115"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
+		$this->resourceClassifications[0]['tablename'] = 'md_topic_category';
+		$this->resourceClassifications[0]['requestName'] = 'isoCategories';
+		$this->resourceClassifications[0]['id_wms'] = 'layer_id';
+		$this->resourceClassifications[0]['id_wfs'] = 'featuretype_id';
+		$this->resourceClassifications[0]['relation_wms'] = 'layer_md_topic_category';
+		$this->resourceClassifications[0]['relation_wfs'] = 'featuretype_md_topic_category';//TODO: define this in mapbender
+		$this->resourceClassifications[1]['title'] = "INSPIRE"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
+		$this->resourceClassifications[1]['tablename'] = 'inspire_category';
+		$this->resourceClassifications[1]['requestName'] = 'inspireThemes';
+		$this->resourceClassifications[1]['id_wms'] = 'layer_id';
+		$this->resourceClassifications[1]['id_wfs'] = 'featuretype_id';
+		$this->resourceClassifications[1]['relation_wms'] = 'layer_inspire_category';
+		$this->resourceClassifications[1]['relation_wfs'] = 'featuretype_inspire_category';//TODO: define this in mapbender
+		$this->resourceClassifications[2]['title'] = "Custom"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
+		$this->resourceClassifications[2]['tablename'] = 'custom_category';
+		$this->resourceClassifications[2]['requestName'] = 'customCategories';
+		$this->resourceClassifications[2]['id_wms'] = 'layer_id';
+		$this->resourceClassifications[2]['id_wfs'] = 'featuretype_id';
+		$this->resourceClassifications[2]['relation_wms'] = 'layer_custom_category';
+		$this->resourceClassifications[2]['relation_wfs'] = 'featuretype_custom_category';//TODO: define this in mapbender
+		//Defining of the different result categories
+		$this->resourceCategories = array();
+		$this->resourceCategories[0]['name'] = 'WMS';
+		$this->resourceCategories[1]['name'] = 'WFS';
+		$this->resourceCategories[2]['name'] = 'WMC';
+		$this->resourceCategories[3]['name'] = 'GeoRSS';
+		switch($this->languageCode){
+        		case 'de':
+                	$this->resourceCategories[0]['name2show'] = 'Darstellungsdienste';
+			$this->resourceCategories[1]['name2show'] = 'Such- und Downloaddienste';
+			$this->resourceCategories[2]['name2show'] = 'Kartenzusammenstellungen';
+			$this->resourceCategories[3]['name2show'] = 'Geokodierte Newsfeeds';
+       			break;
+        		case 'en':
+               		$this->resourceCategories[0]['name2show'] = 'Viewingservices';
+			$this->resourceCategories[1]['name2show'] = 'Search- and Downloadservices';
+			$this->resourceCategories[2]['name2show'] = 'Combined Maps';
+			$this->resourceCategories[3]['name2show'] = 'Geocodet Newsfeeds';
+        		break;
+        		case 'fr':
+       			break;
+     			default:
+		//not needed til now - maybe usefull for georss output
+		if ($this->outputFormat == "xml") {
+			//Initialize XML documents
+			if (isset($this->searchResources) & strtolower($this->searchResources) === "wms") {
+				$this->wmsDoc = new DOMDocument('1.0');
+			if (isset($this->searchResources) & strtolower($this->searchResources) === "wfs") {
+				$this->wfsDoc = new DOMDocument('1.0');
+				$this->generateWFSMetadata($this->wfsDoc);
+			if (isset($this->searchResources) & strtolower($this->searchResources) === "wmc") {
+				$this->wmcDoc = new DOMDocument('1.0');
+			if (isset($this->searchResources) & strtolower($this->searchResources) === "georss") {
+				$this->georssDoc = new DOMDocument('1.0');
+		if ($this->outputFormat === "json") {
+				$this->searchView = 'search_wfs_view';
+				$this->orderBy = " ORDER BY wfs_id,featuretype_id,wfs_conf_id ";
+				$this->resourceClasses = NULL;
+				$this->searchView = 'wms_search_table_test';
+				$this->orderBy = " ORDER BY load_count DESC";
+				$this->resourceClasses = array(0,1,2);
+				$this->generateWMSMetadata($this->wmsDoc);
+	private function microtime_float() {
+    		list($usec, $sec) = explode(" ", microtime());
+    		return ((float)$usec + (float)$sec);
+	private function generateXMLHead($xmlDoc) {
+		$xmlDoc->encoding = CHARSET;
+		$result = $xmlDoc->createElement("result");
+		$xmlDoc->appendChild($result);
+		//Result Count
+		$overLimit = $xmlDoc->createElement("overLimit");
+		$result->appendChild($overLimit);
+		//$tr_text = $xmlDoc->createTextNode($this->isOverLimit);
+		$tr_text = $xmlDoc->createTextNode("really?");
+		$overLimit->appendChild($tr_text);
+		$rd = $xmlDoc->createElement("redirect");
+		$result->appendChild($rd);
+		$trd = $xmlDoc->createTextNode("not yet ready...");
+		$rd->appendChild($trd);
+	private function generateXMLFoot($xmlDoc){
+		$results = $xmlDoc->getElementsByTagName("result");
+		foreach ($results as $result) {
+			$result->appendChild($ready);
+	private function flipDiagonally($arr) {
+    		$out = array();
+    		foreach ($arr as $key => $subarr) {
+      			foreach ($subarr as $subkey => $subvalue) {
+        			$out[$subkey][$key] = $subvalue;
+   		return $out;
+	private function generateWFSMetadataJSON($res, $n) {
+		//initialize object
+		$this->wfsJSON = new stdClass;
+		$this->wfsJSON->wfs = (object) array(
+				'md' => (object) array(
+					'nresults' => $n,
+					'p' => $this->searchPages,
+					'rpp' => $this->maxResults
+				'srv' => array()
+		//read out records
+		$serverCount = 0;
+		$wfsMatrix = db_fetch_all($res);
+		//sort result for accessing the right services
+		$wfsMatrix = $this->flipDiagonally($wfsMatrix);
+		//TODO check if order by db or order by php is faster!
+		#array_multisort($wfsMatrix['wfs_id'], SORT_ASC,$wfsMatrix['featuretype_id'], SORT_ASC,$wfsMatrix['wfs_conf_id'], SORT_ASC); //have some problems - the database version is more stable
+		#print_r($wfsMatrix);
+		//read out first server entry - maybe this a little bit timeconsuming TODO
+		$j = 0; //count identical wfs_id => double featuretype
+		$l = 0; //index featuretype and or modul per wfs
+		$m = 0; //index modul per featuretype
+		for($i=0; $i<count($wfsMatrix);$i++){
+				$this->wfsJSON->wfs->srv[$i-$j]->id = $wfsMatrix[$i]['wfs_id'];
+				$this->wfsJSON->wfs->srv[$i-$j]->title = $wfsMatrix[$i]['wfs_title'];
+				$this->wfsJSON->wfs->srv[$i-$j]->abstract = $wfsMatrix[$i]['wfs_abstract'];
+				$this->wfsJSON->wfs->srv[$i-$j]->date = date("d.m.Y",$wfsMatrix[$i]['wfs_timestamp']);
+				$this->wfsJSON->wfs->srv[$i-$j]->respOrg = $wfsMatrix[$i]['mb_group_name'];
+				$this->wfsJSON->wfs->srv[$i-$j]->mdLink = $_SERVER['HOSTNAME']."/mapbender/x_geoportal/showWFSMetadata.php?id=".$wfsMatrix[$i]['wfs_id'];
+				$spatialSource = "";
+				$stateOrProvince = $wfsMatrix[$i]['administrativearea'];
+				if ($stateOrProvince == "NULL" || $stateOrProvince == "") {
+					$spatialSource = $wfsMatrix[$i]['country'];
+				} else {
+					$spatialSource = $wfsMatrix[$i]['administrativearea'];
+				$this->wfsJSON->wfs->srv[$i-$j]->iso3166 = $spatialSource;
+				$this->wfsJSON->wfs->srv[$i-$j]->tou = $wfsMatrix[$i]['termsofuse'];
+				//TODO check the field accessconstraints - which should be presented?
+				$this->wfsJSON->wfs->srv[$i-$j]->status = NULL; //$wfsMatrix[$i][''];
+				$this->wfsJSON->wfs->srv[$i-$j]->avail = NULL; //$wfsMatrix[$i][''];
+				$this->wfsJSON->wfs->srv[$i-$j]->logged = NULL; //$wfsMatrix[$i][''];
+				$this->wfsJSON->wfs->srv[$i-$j]->price = NULL; //$wfsMatrix[$i][''];
+				$this->wfsJSON->wfs->srv[$i-$j]->nwaccess = NULL; //$wfsMatrix[$i][''];
+				$this->wfsJSON->wfs->srv[$i-$j]->bbox = array(-180.0,-90.0,180.0,90.0); //$wfsMatrix[$i][''];
+				//if featuretype hasn't been created - do it
+				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype)) {
+					$this->wfsJSON->wfs->srv[$i-$j]->ftype = array();
+				//fill in featuretype infos
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->id = $wfsMatrix[$i]['featuretype_id'];
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->title = $wfsMatrix[$i]['featuretype_title'];
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->abstract = $wfsMatrix[$i]['featuretype_abstract'];
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->mdLink = $_SERVER['HOST']."/mapbender/x_geoportal/showWFeatureTypeMetadata.php?id=".$wfsMatrix[$i]['featuretype_id'];
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->geomtype = $wfsMatrix[$i]['element_type'];
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->bbox = array(-180.0,-90.0,180.0,90.0);//TODO: $wfsMatrix[$i]['bbox'];
+				//fill in categories
+				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat)) {
+					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat = array();
+				if (isset($wfsMatrix[$i]['iso_categories'])) {
+				//if (isset($wfsMatrix[$i]['inspire_category'])) {
+					//TODO write the categories as JSON into Database!
+					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->type = 'INSPIRE Kategorie';
+ 					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->value = 'Umwelt';
+					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->symbol = 'umwelt.png';
+				if (isset($wfsMatrix[$i]['custom_categories'])) {
+				//if modul hasn't been created - do it
+				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul)) {
+					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul = array();
+				//fill in modul infos
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->id = $wfsMatrix[$i]['wfs_conf_id'];
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->title = $wfsMatrix[$i]['wfs_conf_description'];
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->abstract = $wfsMatrix[$i]['wfs_conf_abstract'];
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->type = $wfsMatrix[$i]['modultype'];
+				$equalEPSG = $wfsMatrix[$i]['featuretype_srs'];
+                       		$isEqual = "true";
+				//control if EPSG is supported by Client
+		        	if ($equalEPSG == $this->searchEPSG){
+					$isEqual = "false";
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->srsProblem = $isEqual;
+				//generate Link to show metadata
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->mdLink = $_SERVER['HOST']."/mapbender/x_geoportal/showWFSConfMetadata.php?id=".$wfsMatrix[$i]['wfs_conf_id'];
+				$perText = $this->getPermissionValueForWFS($wfsMatrix[$i]['wfs_id'], $wfsMatrix[$i]['wfs_conf_id']);
+				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->permission = $perText;
+				if ($wfsMatrix[$i]['wfs_id'] == $wfsMatrix[$i+1]['wfs_id']){
+					$j++; //next record is the same service
+					$l++;
+				else
+					$l = 0;
+				if ($wfsMatrix[$i]['featuretype_id'] == $wfsMatrix[$i+1]['featuretype_id']){
+					$m++;
+				else
+					$m = 0;
+	private function generateWMSMetadataJSON($res, $n) {
+		$this->wmsJSON = new stdClass;
+		$this->wmsJSON->wms = (object) array(
+					'nresults' => $n,
+				'srv' => array()
+		$serverCount = 0;
+		$wmsMatrix = db_fetch_all($res);
+		$layerIdArray = array();
+		//read out array with unique wms_ids in wmsMatrix
+		$wmsIdArray = array();
+		//initialize root layer id;
+		$rootLayerId = -1;
+		$j = 0;
+		#$countWmsMatrix = count($wmsMatrix);
+		#echo $countWmsMatrix;
+		if ($n != 0) {
+		for($i=0; $i<count($wmsMatrix);$i++){
+			$layerID = $wmsMatrix[$i]['layer_id'];
+			#echo "<br>LayerID: ".$layerID."<br>";
+			$wmsID = $wmsMatrix[$i]['wms_id'];
+			if (!in_array($layerID, $layerIdArray) or !in_array($rootLayerId, $layerIdArray)) {
+				//Select all layers of with this wms_id into new array per WMS - the grouping should be done by wms!
+				$subLayers = $this->filter_by_value($wmsMatrix, 'wms_id', $wmsID);
+				#echo "<br>Sublayers: <br>";
+				#print_r($subLayers);
+				//Sort array by load_count - problem: maybe there are some groups between where count is to low (they have no load count because you cannot load them by name)? - Therefor we need some ideas - or pull them out of the database and show them greyed out. Another way will be to define a new group (or wms with the same id) for those layers which are more than one integer away from their parents
+				$subLayersFlip = $this->flipDiagonally($subLayers);
+				#var_dump($subLayers['layer_pos']);
+				#$subLayers = $this->flipDiagonally($subLayers);
+				//go backwards through the layerTree to get the layer with the highest position without gaps in between
+				#var_dump($subLayers['layer_id']);
+				#echo "<br>";
+				$index = array_search($layerID, $subLayersFlip['layer_id']);
+				#echo "<br>found layer_id= ".$layerID." at index: ".$index." in sublayerstable<br>";
+				$rootIndex = $this->getLayerParent($subLayersFlip, $index);
+				$rootLayerPos = $subLayers[$rootIndex]['layer_pos'];
+				$rootLayerId = $subLayers[$rootIndex]['layer_id'];
+				#echo "<br>LayerId:<br>";
+				#echo "<br>".$layerID."<br>";
+				#echo "<br>rootLayerPos:<br>";
+				#echo "<br>".$rootLayerPos."<br>";
+				#echo "<br>rootLayerId:<br>";
+				#echo "<br>".$rootLayerId."<br>";
+				//push root layer id in array
+				array_push($layerIdArray, $rootLayerId);
+				#echo "<br>root Layer ID: ".$rootLayerId."<br>";
+				#array_multisort($subLayers['layer_pos'], SORT_ASC);
+				#print_r("<br>rootIndex: ".$rootIndex."<br>");
+				//Create object for wms service level
+				$this->wmsJSON->wms->srv[$i-$j]->id = $subLayers[$rootIndex]['wms_id'];
+				$this->wmsJSON->wms->srv[$i-$j]->title = $subLayers[$rootIndex]['wms_title'];
+				$this->wmsJSON->wms->srv[$i-$j]->abstract = $subLayers[$rootIndex]['wms_abstract'];
+				$this->wmsJSON->wms->srv[$i-$j]->date = date("d.m.Y",$subLayers[$rootIndex]['wms_timestamp']);
+				$this->wmsJSON->wms->srv[$i-$j]->respOrg = $subLayers[$rootIndex]['mb_group_name'];
+				$this->wmsJSON->wms->srv[$i-$j]->loadCount = $subLayers[$rootIndex]['load_count'];
+				$this->wmsJSON->wms->srv[$i-$j]->mdLink = $_SERVER['HOSTNAME']."/mapbender/x_geoportal/mod_layerMetadata.php?id=".$rootLayerId;
+				$stateOrProvince = $wmsMatrix[$i]['administrativearea'];
+					$spatialSource = $wmsMatrix[$i]['country'];
+				} else {
+					$spatialSource = $wmsMatrix[$i]['administrativearea'];
+				$this->wmsJSON->wms->srv[$i-$j]->iso3166 = $spatialSource;
+				$this->wmsJSON->wms->srv[$i-$j]->tou = $subLayers[$rootIndex]['termsofuse'];
+				$this->wmsJSON->wms->srv[$i-$j]->status = $subLayers[$rootIndex]['status']; //$wmsMatrix[$i][''];
+				$this->wmsJSON->wms->srv[$i-$j]->avail = $subLayers[$rootIndex]['availability']; //$wmsMatrix[$i][''];
+				$this->wmsJSON->wms->srv[$i-$j]->logged = NULL; //$wmsMatrix[$i][''];
+				$this->wmsJSON->wms->srv[$i-$j]->price = NULL; //$wmsMatrix[$i][''];
+				$this->wmsJSON->wms->srv[$i-$j]->nwaccess = NULL; //$wmsMatrix[$i][''];
+				$this->wmsJSON->wms->srv[$i-$j]->bbox = $subLayers[$rootIndex]['bbox']; //$wmsMatrix[$i][''];
+				//Call recursively the child elements, give and pull $layerIdArray to push the done elements in the array to avoid double results
+				//generate the layer-entry for the so called root layer
+				$this->wmsJSON->wms->srv[$i-$j]->layer = array();
+				$this->wmsJSON->wms->srv[$i-$j]->layer[0]->id = $subLayers[$rootIndex]['layer_id'];
+				$this->wmsJSON->wms->srv[$i-$j]->layer[0]->title = $subLayers[$rootIndex]['layer_title'];
+				$this->wmsJSON->wms->srv[$i-$j]->layer[0]->abstract = $subLayers[$rootIndex]['layer_abstract'];
+				if ($subLayers[$rootIndex]['layer_name'] == ''){
+					$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 0;
+				else {
+					$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 1;
+				#if ($subLayers[$rootIndex]['layer_name'] == ''){
+				#	$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 0;
+				#else {
+				#	$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 1;
+				$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadCount = $subLayers[$rootIndex]['load_count'];
+				#$servObject->layer[$countsublayer]->mdLink = $_SERVER['HOST']."/mapbender/x_geoportal/showWFeatureTypeMetadata.php?id=".$wfsMatrix[$i]['featuretype_id'];
+				#$servObject->layer[$countsublayer]->geomtype = $wfsMatrix[$i]['element_type'];
+				$this->wmsJSON->wms->srv[$i-$j]->layer[0]->bbox = $subLayers[$rootIndex]['bbox'];
+				$this->wmsJSON->wms->srv[$i-$j]->layer[0]->permission = $this->getPermissionValueForLayer($subLayers[$rootIndex]['wms_id'], $subLayers[$rootIndex]['layer_id']);
+				$layerIdArray = $this->writeWMSChilds($layerIdArray, $rootLayerPos, $subLayers, $i, $j, $this->wmsJSON->wms->srv[$i-$j]->layer[0]);
+				//generate php object - if root layer was found - > layer_parent='' give hint to visualize folder symbol.
+	private function generateWMSMetadata($xmlDoc) {
+		$starttime = $this->microtime_float();
+		list($sql, $v, $t, $n) = $this->generateSearchSQL();
+		//call database search in limits
+		$res = db_prep_query($sql, $v, $t);
+			//generate json
+			$this->generateWMSMetadataJSON($res,$n);
+			$this->wmsJSON = $this->json->encode($this->wmsJSON);
+			if ($this->resultTarget == 'file') {
+				if($wmsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
+					fwrite($wmsFileHandle,$this->wfsJSON);
+					fclose($wmsFileHandle);
+			if ($this->resultTarget == 'web' or $this->resultTarget == 'debug') {
+				echo $this->wmsJSON;
+		$usedTime = $this->microtime_float() - $starttime;
+		$e = new mb_exception("Time to generate WMS-Metadata: ".$usedTime);
+		$e = new mb_exception("Wrote the MD_WMS-File");
+	private function generateWFSMetadata($xmlDoc) {
+			//generate json
+			$this->generateWFSMetadataJSON($res, $n);
+			$this->wfsJSON = $this->json->encode($this->wfsJSON);
+				if($wfsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
+					fwrite($wfsFileHandle,$this->wfsJSON);
+					fclose($wfsFileHandle);
+			if ($this->resultTarget == 'web'or $this->resultTarget == 'debug') {
+				echo $this->wfsJSON;
+		if ($this->outputFormat == 'xml'){
+			//generate xml
+			$this->generateXMLHead($xmlDoc);
+			$this->generateXMLFoot($xmlDoc);
+			$this->generateWFSResultXML($xmlDoc,$res);
+				if($wfsFileHandleXML = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".xml","w")){
+					fwrite($wfsFileHandleXML,$xmlDoc->saveXML());
+					fclose($wfsFileHandleXML);
+			if ($this->resultTarget == 'web') {
+				header("Content-type: application/xhtml+xml; charset=UTF-8");
+				echo $xmlDoc->saveXML();
+		$e = new mb_exception("Time to generate WFS-Metadata: ".$usedTime);
+		$e = new mb_exception("Wrote the MD_WFS-File");
+	private function replaceChars_all($text){
+		$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü",  "ß");
+		$repWith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
+		$replaced = str_replace($search, $repWith, $text);
+		return $replaced;
+	private function generateSearchSQL() {
+		//elements needed to exist in mb wfs view or table:
+		//1. textfield - all texts - searchText
+		//2. responsible organisations - given id
+		//3. bbox - is not explicit given in the wfs metadata? Since WFS 1.1.0 a latlonbbox is present
+		//4. isoTopicCategory - is not been saved til now
+		//5. ...
+		//parse searchText into different array elements to allow an AND search
+		$searchStringArray = $this->generateSearchStringArray();
+		$v = array();
+		$t = array();
+		$sql = "SELECT * from ".$this->searchView." where ";
+		#$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." where ";
+		$whereStr = "";
+		$whereCondArray = array();
+		$isTextSearch = "false";
+		$e = new mb_exception("Number of used searchstrings: ".count($searchStringArray));
+		//textsearch
+		if ($this->searchText != NULL) {
+			for($i=0; $i < count($searchStringArray); $i++){
+				$isTextSearch = "true";
+				if($i>0) {
+					$whereStr .= " AND ";
+				$whereStr .= "searchtext LIKE $".($i+1);
+				//output for debugging
+				$e = new mb_notice("Part of string".$i.": ".$searchStringArray[$i]);
+				$e = new mb_notice("converted: ".$this->replaceChars_all($searchStringArray[$i]));
+				$va = "%".trim(strtoupper($this->replaceChars_all($searchStringArray[$i])))."%";
+				$e = new mb_notice($this->searchResources." Searchtext in SQL: ".$va);
+				array_push($v,$va);
+				array_push($t,"s");
+/* This is only for the later postgis versions. The within and disjoint is to slow, cause there is no usage of the geometrical index in the old versions!
+		//spatial search filter - ist should be the first filter in the where clause, cause it is
+		if (strtolower($this->searchResources) === "wms" & $this->searchBbox != NULL) {
+			#$spatialFilter = "(the_geom ";
+			#echo "<br> spatial operator: ".$this->searchTypeBbox."<br>";
+			if ($this->searchTypeBbox == 'outside') {
+				$spatialFilter = ' disjoint(';
+			} elseif ($this->searchTypeBbox == 'inside') {
+				$spatialFilter = ' within(';
+			} else {
+				$spatialFilter = ' intersects(';
+			//define spatial filter
+			if(count(explode(',',$this->searchBbox)) == 4){   //if searchBbox has 4 entries
+				$spatialFilterCoords = explode(',',$this->searchBbox);//read out searchBbox
+				//definition of the spatial filter
+				$spatialFilter .= 'GeomFromText(\'POLYGON(('.$spatialFilterCoords[0];//minx
+				$spatialFilter .= ' '.$spatialFilterCoords[1].',';//miny
+				$spatialFilter .= $spatialFilterCoords[0];//minx
+				$spatialFilter .= ' '.$spatialFilterCoords[3].',';//maxy
+				$spatialFilter .= $spatialFilterCoords[2];//maxx
+				$spatialFilter .= ' '.$spatialFilterCoords[1].'))\',4326)';//miny
+				$spatialFilter .= ",the_geom)";
+				array_push($whereCondArray, $spatialFilter);
+			#array_push($whereCondArray, $spatialFilter);
+			#if ($this->searchTypeBbox == 'outside') {
+			#	$spatialFilter = ' disjoint(';
+			#} elseif ($this->searchTypeBbox == 'inside') {
+			#	$spatialFilter = ' within(';
+			#} else {
+			#	$spatialFilter = ' intersects(';
+			$spatialFilter = ' the_geom && ';
+				#$spatialFilter .= ",the_geom)";
+		//search filter for md_topic_categories
+		if (strtolower($this->searchResources) === "wms" & $this->isoCategories != NULL) {
+			$isoArray = explode(',',$this->isoCategories);
+			$topicCond = "(";
+			for($i=0; $i < count($isoArray); $i++){
+				if ($i == 0) {
+					$topicCond .= "(md_topic_cats LIKE '%{".$isoArray[$i]."}%') ";
+				} else {
+					$topicCond .= "OR (md_topic_cats LIKE '%{".$isoArray[$i]."}%') ";
+			$topicCond .= ")";
+			array_push($whereCondArray, $topicCond);
+		//search filter for inspire_categories
+		if (strtolower($this->searchResources) === "wms" & $this->inspireThemes != NULL) {
+			$inspireArray = explode(',',$this->inspireThemes);
+			$inspireCond = "(";
+			for($i=0; $i < count($inspireArray); $i++){
+				if ($i == 0) {
+					$inspireCond .= "(md_inspire_cats LIKE '%{".$inspireArray[$i]."}%') ";
+				} else {
+					$inspireCond .= "OR (md_inspire_cats LIKE '%{".$inspireArray[$i]."}%') ";
+			$inspireCond .= ")";
+			array_push($whereCondArray, $inspireCond);
+		//search filter for custom_categories
+		if (strtolower($this->searchResources) === "wms" & $this->customCategories != NULL) {
+			$customArray = explode(',',$this->customCategories);
+			$customCond = "(";
+			for($i=0; $i < count($customArray); $i++){
+				if ($i == 0) {
+					$customCond .= "(md_custom_cats LIKE '%{".$customArray[$i]."}%') ";
+				} else {
+					$customCond .= "OR (md_custom_cats LIKE '%{".$customArray[$i]."}%') ";
+			$customCond .= ")";
+			array_push($whereCondArray, $customCond);
+		//date condition
+		//if begin and end are set
+		//echo "<br> regTimeBegin: ".$this-> regTimeBegin." regTimeEnd: ".$this-> regTimeEnd."<br>";
+		if ($this->regTimeBegin != NULL && $this->regTimeEnd != NULL){
+			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) BETWEEN '".$this->regTimeBegin."' AND '".$this->regTimeEnd."')";
+			array_push($whereCondArray, $time);
+			//only begin is set
+		if ($this->regTimeBegin != NULL && $this->regTimeEnd == NULL){
+			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) > '".$this->regTimeBegin."')";
+		if ($this->regTimeBegin == NULL && $this->regTimeEnd != NULL){
+			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) < '".$this->regTimeEnd."')";
+		//department condition
+		//TODO: generate filter for new sql check if at least some department is requested
+		//generate array
+		//$this->registratingDepartments = explode(',',$this->registratingDepartments);
+		#if(count($this->registratingDepartments) > 0 & $this->registratingDepartments){
+		if($this->registratingDepartments != NULL){
+			$dep = " department IN (".$this->registratingDepartments.") ";
+			array_push($whereCondArray, $dep);
+		// Creating the WHERE clause, based on a array
+		if(count($whereCondArray) > 0){
+			$txt_whereCond = "";
+			for ($index = 0; $index < sizeof($whereCondArray); $index++) {
+				$array_element = $whereCondArray[$index];
+				if($isTextSearch == "true") {
+					$txt_whereCond .= " AND ".$array_element;
+				} else {
+					if($index>0){
+					} else {
+						$txt_whereCond .= " ".$array_element;
+			$whereStr .= $txt_whereCond;
+		//Add WHERE condition to search
+		$sql .= $whereStr;
+		//TODO ORDER BY in SQL - not necessary for counting things:
+		$sql .= $this->orderBy;
+		//Calculate Paging for OFFSET and LIMIT values:
+		$offset = ((integer)$this->maxResults) * ((integer)$this->searchPages -1);
+		$limit = (integer)$this->maxResults;
+		//defining range for paging
+		$sql .= " LIMIT ".$limit." OFFSET ".$offset."";
+		//Print out search SQL term
+		$e = new mb_exception("class_metadata.php: Search => SQL-Request of ".$this->searchResources." service metadata: ".$sql."");
+		//parameter: searchId -> can be used global, searchResources -> is only one type per instance!!-> global,which categories -> can be defined global! $whereStr
+		$n = $this->writeCategories($whereStr, $v, $t);
+		//write counts to filesystem to avoid to many database connections
+		//only write them, if searchId is given - problem: searches with same searchId's maybe get wrong information
+		return array($sql, $v, $t, $n);
+	private function writeCategories($whereStr, $v, $t) {
+		//generate count sql
+		//generate count of all entries
+		$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." where ";
+		$sqlN .= $whereStr;
+		//Get total number of results
+		$count = db_prep_query($sqlN, $v, $t);
+		$n = db_fetch_all($count);
+		#echo "<br>N: ".var_dump($n)."<br>";
+		$n = $n[0]['count'];
+		$e = new mb_notice("class_metadata.php: Search => SQL-Request of ".$this->searchResources." service metadata N: ".$sqlN." Number of found objects: ".$n);
+		if ($this->searchId != 'dummysearch') { //searchId is not the default id! - it has been explicitly defined
+			//check if cat file already exists:
+			//filename to search for:
+			$filename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_cat.json";
+			if (!file_exists($filename) or $this->resultTarget == 'debug') { //TODO at the moment the cat file will be overwritten - change this in production system
+				//open category file for wfs results
+				$this->catJSON = new stdClass;
+				$this->catJSON->searchMD = (object) array(
+					'searchId' => $this->searchId,
+					'n' => $n
+				//generate the list of category counts
+				$sqlCat = array();
+				//check if categories are defined for the resource
+				if ($this->resourceClasses != NULL) {
+					$this->catJSON->searchMD->category = array();
+					for ($i = 0; $i < count($this->resourceClasses); $i++) {
+						//TODO: not to set the classification?
+						$this->catJSON->searchMD->category[$i]->title = $this->resourceClassifications[$i]['title'];
+						$sqlCat[$i] = "SELECT ".$this->resourceClassifications[$i]['tablename'];
+						$sqlCat[$i] .= ".".$this->resourceClassifications[$i]['tablename']."_id, ";
+						$sqlCat[$i] .= " ".$this->resourceClassifications[$i]['tablename'].".";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_code_";
+						$sqlCat[$i] .= $this->languageCode.", COUNT(*) FROM ".$this->searchView;
+						//first join for connection table
+						$sqlCat[$i] .= " INNER JOIN ".$this->resourceClassifications[$i]['relation_'.$this->searchResources];
+						$sqlCat[$i] .= " ON (";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['relation_'.$this->searchResources].".fkey_";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['id_'.$this->searchResources]."=".$this->searchView;
+						$sqlCat[$i] .= ".".$this->resourceClassifications[$i]['id_'.$this->searchResources];
+						$sqlCat[$i] .= ") INNER JOIN ";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']." ON (";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename'].".";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id=";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id)";
+						$sqlCat[$i] .= " WHERE ".$whereStr."  GROUP BY ";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id,";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_code_".$this->languageCode." ORDER BY ";
+						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id";
+						$sqlCategory = $sqlCat[$i];
+						//call sql for count of category
+						$res = db_prep_query($sqlCategory, $v, $t);
+						$categoryCounts = db_fetch_all($res);
+						//if none found: $categoryCounts=false
+						#echo "<br>count sub categories :".$categoryCounts."<br>";
+						if ($categoryCounts) {
+						//write results in json object
+						if (count($categoryCounts) > 0) {
+							#echo "<br>count main categories".count($categoryCounts)."<br>";
+							#echo "<br>vardump main categories".var_dump($categoryCounts)."<br>";
+							$this->catJSON->searchMD->category[$i]->subcat = array();
+							for ($j = 0; $j < count($categoryCounts); $j++) {
+								$this->catJSON->searchMD->category[$i]->subcat[$j]->id = $categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"];
+								$this->catJSON->searchMD->category[$i]->subcat[$j]->title = $categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_code_".$this->languageCode];
+								$this->catJSON->searchMD->category[$i]->subcat[$j]->count = $categoryCounts[$j]['count'];
+								//delete requestParam for this category and for id - cause a new search is started from searchURL
+								$filteredSearchString = $this->delTotalFromQuery('searchId',$this->searchURL);
+								$filteredSearchString = $this->delTotalFromQuery($this->resourceClassifications[$i]['requestName'],$filteredSearchString);
+								//set filter for this categoryid
+								$filteredSearchString .= "&".$this->resourceClassifications[$i]['requestName']."=".$categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"];
+								$this->catJSON->searchMD->category[$i]->subcat[$j]->filterLink = $filteredSearchString;
+						} else {
+							#$this->catJSON->searchMD->category[$i]->subcat = array();
+						$e = new mb_notice("class_metadata: countsql: ".$sqlCat[$i]);
+				$this->catJSON = $this->json->encode($this->catJSON);
+				//write categories files only when file is requested and the searchid was not used before!
+					if($catFileHandle = fopen($filename, "w")){
+						fwrite($catFileHandle,$this->catJSON);
+						fclose($catFileHandle);
+						$e = new mb_notice("class_metadata: new ".$this->searchResources."_class_file created!");
+					} else {
+						$e = new mb_notice("class_metadata: cannot create ".$this->searchResources."_cat_file!");
+				if ($this->resultTarget == 'debug') {
+					echo "<br>DEBUG: show categories: <br>".$this->catJSON."<br><br>";
+			} else {
+				$e = new mb_exception("class_metadata: ".$this->searchResources."_class_file: ".$filename." already exists - no new one is generated!");
+		} else {
+				echo "<br>DEBUG: Standard ID dummysearch was invoked - classifications won't be counted!<br>";
+			$e = new mb_exception("class_metadata: standard dummysearch was invoked - classifications won't be counted!");
+		return $n;
+	private function generateWFSResultXML($wfsDoc, $res) {
+		$c = $this->wfsDoc->createElement("category");
+		$results = $this->wfsDoc->getElementsByTagName("result");
+			$result->appendChild($c);
+			$c->setAttribute('name', "WFS");
+			$c->setAttribute('count', "0");
+		$i = 0;
+		while($row = db_fetch_array($res)){
+			$m = $this->wfsDoc->createElement('member');
+			$m->setAttribute('wfs_id', $row['wfs_id']);
+			$m->setAttribute('layer_pos', "");
+			$c->appendChild($m);	 // member categorie 1 (first member)
+			// epsg - TODO adopt
+			$epsg = $this->wfsDoc->createElement('epsg');
+			$m->appendChild($epsg);
+			$equalEPSG = $row['featuretype_srs'];
+                       	$isequal = "false";
+		        if ($equalEPSG == $this->search_epsg){
+				$isequal = "true";
+		       	//Insert end
+			$epsg_text = $this->wfsDoc->createTextNode($isequal);
+			$epsg->appendChild($epsg_text);
+			// country codes
+			$state = $this->wfsDoc->createElement('federalstate');
+			$m->appendChild($state);
+			$stateorprovince = $row['administrativearea'];
+			if ($stateorprovince == "NULL" || $stateorprovince == "") {
+				$spatialSource = $row['country'];
+			} else {
+				$spatialSource = $row['administrativearea'];
+			$countr_code_text = $this->wfsDoc->createTextNode($spatialSource);
+			$state->appendChild($countr_code_text);
+			//type
+			$type = $this->wfsDoc->createElement('type');
+			$m->appendChild($type);
+			$ttype = $this->wfsDoc->createTextNode("wfs");
+			$type->appendChild($ttype);
+                        //wfs_id
+			$wfsid = $this->wfsDoc->createElement('wfs_id');
+			$m->appendChild($wfsid);
+			$twfsid = $this->wfsDoc->createTextNode($row['wfs_id']);
+			$wfsid->appendChild($twfsid);
+			//id
+			$id = $this->wfsDoc->createElement('featuretype_id');
+			$m->appendChild($id);
+			$tid = $this->wfsDoc->createTextNode($row['featuretype_id']);
+			$id->appendChild($tid);
+			//title
+			$title = $this->wfsDoc->createElement('featuretype_title');
+			$m->appendChild($title);
+			$ttitle = $this->wfsDoc->createTextNode($row['featuretype_title']);
+			$title->appendChild($ttitle);
+			//abstract
+			$abst = $this->wfsDoc->createElement('featuretype_abstract');
+			$m->appendChild($abst);
+			$tabst = $this->wfsDoc->createTextNode($row['featuretype_abstract']);
+			$abst->appendChild($tabst);
+			// accesscontraints
+			$ac = $this->wfsDoc->createElement('accessconstraints');
+			$m->appendChild($ac);
+//			$myac = $this->getAccessConstraints($this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['accessconstraints'], $this->cat[$i]['member'][$ii]['layer_id']);
+			$myac = $this->wfsDoc->createTextNode($row['accessconstraints']);
+			$ac->appendChild($myac);
+			// termsofuse
+			$ter = $this->wfsDoc->createElement('termsofuse');
+			$m->appendChild($ter);
+			$myter =  $this->wfsDoc->createTextNode($row['termsofuse']);
+			$ter->appendChild($myter);
+			//date
+			$date = $this->wfsDoc->createElement('date');
+			$m->appendChild($date);
+			$tdate = $this->wfsDoc->createTextNode(date("d.m.Y",$row['wfs_timestamp']));
+			$date->appendChild($tdate);
+			// Geomtype
+			$geo = $this->wfsDoc->createElement('geomtype');
+			$m->appendChild($geo);
+			//$geo_text = $this->getGeoType($row['wfs_id'], $row['featuretype_id']);
+			$geo_text = $this->wfsDoc->createTextNode($row['element_type']);
+			//$ge =  $this->wfsDoc->createTextNode($geo_text);
+			$geo->appendChild($geo_text);
+			//department
+			$dm = $this->wfsDoc->createElement('department');
+			$m->appendChild($dm);
+			$tdm = $this->wfsDoc->createTextNode($row['mb_group_name']);
+			$dm->appendChild($tdm);
+			//permission  		 Leseberechtigung des Benutzers(true), sonst Email zur Beantragung(email)
+			$per = $this->wfsDoc->createElement('permission');
+			$m->appendChild($per);
+			$per_text = $this->getPermissionValueForWFS($row['wfs_id'], $row['wfs_conf_id']);
+			$pe =  $this->wfsDoc->createTextNode($per_text);
+			$per->appendChild($pe);
+			//wfs_conf_id
+			$conf_id = $this->wfsDoc->createElement('wfs_conf_id');
+			$m->appendChild($conf_id);
+			$c_id = $this->wfsDoc->createTextNode($row['wfs_conf_id']);
+			$conf_id->appendChild($c_id);
+			//wfs_conf_title
+			$conf_title = $this->wfsDoc->createElement('wfs_conf_title');
+			$m->appendChild($conf_title);
+			$conf_title_text = $this->wfsDoc->createTextNode($row['wfs_conf_abstract']);
+			$conf_title->appendChild($conf_title_text);
+			//wfs_conf_abstract
+			$conf_abstract = $this->wfsDoc->createElement('wfs_conf_abstract');
+			$m->appendChild($conf_abstract);
+			$c_abstract = $this->wfsDoc->createTextNode($row['wfs_conf_description']);
+			$conf_abstract->appendChild($c_abstract);
+			//wfs_conf_modul
+			$conf_modul = $this->wfsDoc->createElement('wfs_conf_modul');
+			$m->appendChild($conf_modul);
+			$c_modul = $this->wfsDoc->createTextNode($row['modultype']);
+			$conf_modul->appendChild($c_modul);
+			$i++;
+		$c->setAttribute('count', $i);
+	private function getPermissionValueForWFS($wfs_id, $wfs_conf_id){
+		//TODO: Set Email of owner into view for ressource - so it don't have to be searched?
+		$return_permission = "";
+		//get permission
+		$admin = new administration();
+		$myWFSconfs = $admin->getWfsConfByPermission($this->userId);
+		$this->myWFSConfs = $myWFSconfs;
+		for ($index = 0; $index < sizeof($this->myWFSConfs); $index++) {
+			$array_element = $this->myWFSConfs[$index];
+		if (in_array($wfs_conf_id, $this->myWFSConfs)){
+			$return_permission = "true";
+		} else {
+			$sql = "SELECT wfs.wfs_id, mb_user.mb_user_email as email FROM wfs, mb_user where wfs.wfs_owner=mb_user.mb_user_id "."and wfs.wfs_id=$1";
+			$v = array($wfs_id);
+			$t = array('i');
+			// get email
+			$mail = "";
+				$mail = $row['email'];
+				$return_permission = $mail;
+		return $return_permission;
+	private function getPermissionValueForLayer($wms_id, $layer_id){
+		$return_permission="";
+		$permission = $admin->getLayerPermission($wms_id, $layer_id, $this->userId);
+		if ($permission){
+		} else {
+			$sql = "SELECT wms.wms_id, mb_user.mb_user_email as email FROM wms, mb_user WHERE wms.wms_owner=mb_user.mb_user_id";
+			$sql .= " AND wms.wms_id=$1";
+			$v = array($wms_id);
+			$t = array('i');
+			// get email
+			$mail="";
+	private function generateSearchStringArray() {
+		//'wfs test array' -> ('wfs' 'test' 'array')
+		$asstr = array();
+		if ($this->searchText != "false"){
+			$asstr = split(",",$this->searchText);
+		return $asstr;
+	//out of php doc - test if it is faster than normal array_search
+	private function fast_in_array($elem, $array) {
+   		$top = sizeof($array) -1;
+   		$bot = 0;
+		while($top >= $bot) {
+			$p = floor(($top + $bot) / 2);
+			if ($array[$p] < $elem) $bot = $p + 1;
+			elseif ($array[$p] > $elem) $top = $p - 1;
+			else return TRUE;
+    	return FALSE;
+	* filtering an array
+	private function filter_by_value ($array, $index, $value){
+        	if(is_array($array) && count($array)>0) {
+            		foreach(array_keys($array) as $key){
+                		$temp[$key] = $array[$key][$index];
+                		if ($temp[$key] == $value){
+                    			$newarray[$key] = $array[$key];
+      	return $newarray;
+	//function to get the parent of the given layer by crawling the layertree upwards
+	private function getLayerParent ($layerArray, $index){
+		//only layers of one service should be in $layerArray
+		#$parentExists = false;
+		#var_dump($layerArray);
+		$layerIDKey = $layerArray['layer_id'][$index];
+		#echo ("layerIDKey= ".$layerIDKey."<br>");
+		$layerParentPos = $layerArray['layer_parent'][$index];
+		if ($layerParentPos == '') {
+			//root layer directly found
+			return $index;
+		#echo ("layerParentPos= ".$layerParentPos."<br>");
+		//Initialize index of layer parent - first it references the layer itself
+		$layerParentIndex = $index;
+		for ($i=0; $i<count($layerArray);$i++) {
+			#echo("<br>i= ".$i."<br>");
+			#echo("<br>layerParentPos= ".$layerParentPos."<br>");
+			$layerParentIndexNew = array_search($layerParentPos, $layerArray['layer_pos']);
+			#echo("<br>layerParentIndexNew= ".$layerParentIndexNew."<br>");
+			if ($layerParentIndexNew != false) {
+				//one parent has been found
+				$layerParentIndex = $layerParentIndexNew;
+				$layerParentPos = $layerArray['layer_parent'][$layerParentIndex];
+					return $layerParentIndex;
+				#$layerParentIndex = array_search($layerParentPos, $layerArray['layer_pos']);
+			} else {
+				#$layerParentIndex = $index; //no parent has been found
+	//function to write the child elements to the resulting wms object -> object is given by reference
+	private function writeWMSChilds($layerIdArray, $rootLayerPos, $subLayers, $i, $j, &$servObject) {
+		#echo "test";
+		#echo "<br>subLayers:<br>";
+		#var_dump($subLayers);
+		#echo "<br>";
+		$childLayers = $this->filter_by_value($subLayers, 'layer_parent', $rootLayerPos); //TODO anpassen
+		#echo "<br<childLayers:<br>";
+		#var_dump($childLayers);
+		#echo "test";
+		#print_r($childLayers);
+		$countsublayer = 0;
+		//if child exists create a array for these
+		if (count($childLayers) != 0) {
+			$servObject->layer = array();
+		foreach ($childLayers as $child){
+			#echo "<br>countsublayer: ".$countsublayer."<br>";
+			#echo "<br>Child id: ".$child['layer_id']."<br>";
+			#echo "<br>Child pos: ".$child['layer_pos']."<br>";
+			$servObject->layer[$countsublayer]->id = $child['layer_id'];
+			$servObject->layer[$countsublayer]->title = $child['layer_title'];
+			$servObject->layer[$countsublayer]->abstract = $child['layer_abstract'];
+			if ($child['layer_name'] == ''){
+				$servObject->layer[$countsublayer]->loadable = 0;
+			} else {
+				$servObject->layer[$countsublayer]->loadable = 1;
+			$servObject->layer[$countsublayer]->loadCount = $child['load_count'];
+			$servObject->layer[$countsublayer]->bbox = $child['bbox'];
+			$servObject->layer[$countsublayer]->permission = $this->getPermissionValueForLayer($child['wms_id'], $$child['layer_id']);
+			//call this function itself
+			$layerIdArray = $this->writeWMSChilds($layerIdArray, $child['layer_pos'], $subLayers, $i, $j, $servObject->layer[$countsublayer]);//TODO create a timeout condition !
+			array_push($layerIdArray, $child['layer_id']); //child have been identified and recursively written
+			#var_dump($layerIdArray);#
+			#echo "<br>";
+			$countsublayer ++;
+		return $layerIdArray;
+	private function delTotalFromQuery($paramName,$queryString) {
+		$queryString = "&".$queryString;
+		#echo "<br>queryString: ".$queryString."<br>";
+		$queryStringNew = preg_replace('/\b'.$paramName.'\=[^&]+&?/',"",$queryString);
+		$queryStringNew = ltrim($queryStringNew,'&');
+		$queryStringNew = rtrim($queryStringNew,'&');
+		return $queryStringNew;
\ No newline at end of file
More information about the Mapbender_commits
