[Mapbender-commits] r5490 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Feb 9 04:15:18 EST 2010
Author: armin11
Date: 2010-02-09 04:15:17 -0500 (Tue, 09 Feb 2010)
New Revision: 5490
Added:
trunk/mapbender/http/php/mod_callMetadata.php
trunk/mapbender/http/php/mod_metadataWrite.php
new files for the http metadata search service, merged from geoportal.rlp
Added: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php (rev 0)
+++ trunk/mapbender/http/php/mod_callMetadata.php 2010-02-09 09:15:17 UTC (rev 5490)
@@ -0,0 +1,701 @@
+<?php
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchText=sozial&outputFormat=json&resultTarget=web&searchResources=wfs
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchText=sozial+schwanger&outputFormat=json&resultTarget=web&searchResources=wfs®istratingDepartments=72
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchText=sozial&outputFormat=json&resultTarget=web&searchResources=wms&
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchText=niedersachsen&outputFormat=json&resultTarget=web&searchResources=wms&maxResults=50
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wal&searchText=wald&outputFormat=json&resultTarget=web&searchResources=wms&maxResults=10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=test&searchText=e,w&outputFormat=json®istratingDepartments=44,33,29,30,31,35,40,61,101,87&languageCode=en&resultTarget=web&searchResources=wms&maxResults=10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=45&searchText=e&outputFormat=json®istratingDepartments=44,33,29,30,31,35,40,61,101,87&languageCode=en&resultTarget=debug&searchResources=wms&maxResults=10&searchPages=1&isoCategories=10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=45&searchText=e&outputFormat=json®istratingDepartments=44,33,29,30,31,35,40,61,101,87&languageCode=en&resultTarget=debug&searchResources=wms&maxResults=20&searchPages=1&isoCategories=10,5
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=10&isoCategories=10,5®istratingDepartments=44,31
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=5®istratingDepartments=44,31&inspireThemes=11&isoCategories=5,10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=5®istratingDepartments=44,31&inspireThemes=11&isoCategories=5,10&searchBbox=7,48,9,51
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=99®istratingDepartments=44,31,52&inspireThemes=11&isoCategories=5,10&searchBbox=7,48,9,51®TimeBegin=2001-12-24®TimeEnd=2020-10-10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=99®istratingDepartments=44,31,52&inspireThemes=11&isoCategories=5,10&searchBbox=7,48,9,51®TimeBegin=2001-12-24®TimeEnd=2020-10-10
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_metadata_new.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+session_start();
+//initialize request parameters:
+$searchId = "dummysearch";
+$searchText = "e";
+#$registratingDepartments = "33,29,30,31,35,40,61,101,87,44";
+$registratingDepartments = NULL;
+#$isoCategories = "1,2,3";
+$isoCategories = NULL;
+$inspireThemes = NULL;
+$customCategories = NULL;
+$timeBegin = NULL;
+$timeEnd = NULL;
+$regTimeBegin = NULL;
+$regTimeEnd = NULL;
+$maxResults = 5;
+#$searchBbox = "-180.0,-90.0,180.0,90.0";
+$searchBbox = NULL;
+$searchTypeBbox = "intersects"; //outside / inside
+$accessRestrictions = "false";
+$languageCode = "de";
+$outputFormat = 'json';
+#$searchResources = "wms,wfs,wmc,georss";
+$searchResources = "wms";
+$searchPages = "1,1,1,1";
+$resultTarget = "debug";
+$searchEPSG = "EPSG:31466";
+$classJSON = new Mapbender_JSON;
+$tempFolder = "/tmp";
+//Read out request Parameter:
+if (isset($_REQUEST["searchId"]) & $_REQUEST["searchId"] != "") {
+ //gernerate md5 representation, cause the id is used as a filename later on! - no validation needed
+ $searchId = md5($_REQUEST["searchId"]);
+if (isset($_REQUEST["searchText"]) & $_REQUEST["searchText"] != "") {
+ $test="(SELECT\s[\w\*\)\(\,\s]+\sFROM\s[\w]+)| (UPDATE\s[\w]+\sSET\s[\w\,\'\=]+)| (INSERT\sINTO\s[\d\w]+[\s\w\d\)\(\,]*\sVALUES\s\([\d\w\'\,\)]+)| (DELETE\sFROM\s[\d\w\'\=]+)";
+ //validate to csv integer list
+ $testMatch = $_REQUEST["searchText"];
+ $pattern = '/(\%27)|(\')|(\-\-)|(\")|(\%22)/';
+ if (preg_match($pattern,$testMatch)){
+ echo 'searchText: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $searchText = $testMatch;
+ $testMatch = NULL;
+if (isset($_REQUEST["registratingDepartments"]) & $_REQUEST["registratingDepartments"] != "") {
+ $testMatch = $_REQUEST["registratingDepartments"];
+ $pattern = '/^[\d,]*$/';
+ if (!preg_match($pattern,$testMatch)){
+ echo 'registratingDepartments: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $registratingDepartments = $testMatch;
+if (isset($_REQUEST["isoCategories"]) & $_REQUEST["isoCategories"] != "") {
+ $testMatch = $_REQUEST["isoCategories"];
+ echo 'isoCategories: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $isoCategories = $testMatch;
+if (isset($_REQUEST["inspireThemes"]) & $_REQUEST["inspireThemes"] != "") {
+ $testMatch = $_REQUEST["inspireThemes"];
+ echo 'inspireThemes: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $inspireThemes = $testMatch;
+if (isset($_REQUEST["customCategories"]) & $_REQUEST["customCategories"] != "") {
+ $testMatch = $_REQUEST["customCategories"];
+ echo 'customCategories: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $customCategories = $testMatch;
+if (isset($_REQUEST["timeBegin"]) & $_REQUEST["timeBegin"] != "") {
+ //validate to iso date format YYYY-MM-DD
+ $testMatch = $_REQUEST["timeBegin"];
+ $pattern = '/^(19|20)[0-9]{2}[-](0[1-9]|1[012])[-](0[1-9]|[12][0-9]|3[01])$/';
+ echo 'timeBegin: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $timeBegin = $testMatch;
+if (isset($_REQUEST["timeEnd"]) & $_REQUEST["timeEnd"] != "") {
+ $testMatch = $_REQUEST["timeEnd"];
+ $pattern = '/(19|20)[0-9]{2}[- /.](0[1-9]|1[012])[- /.](0[1-9]|[12][0-9]|3[01])/';
+ echo 'timeEnd: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $timeEnd = $testMatch;
+if (isset($_REQUEST["regTimeBegin"]) & $_REQUEST["regTimeBegin"] != "") {
+ $testMatch = $_REQUEST["regTimeBegin"];
+ echo 'regTimeBegin: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $regTimeBegin = $testMatch;
+if (isset($_REQUEST["regTimeEnd"]) & $_REQUEST["regTimeEnd"] != "") {
+ $testMatch = $_REQUEST["regTimeEnd"];
+ echo 'regTimeEnd: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $regTimeEnd = $testMatch;
+if (isset($_REQUEST["maxResults"]) & $_REQUEST["maxResults"] != "") {
+ //validate integer to 100 - not more
+ $testMatch = $_REQUEST["maxResults"];
+ //give max 99 entries - more will be to slow
+ $pattern = '/^([0-9]{0,1})([0-9]{1})$/';
+ echo 'maxResults: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $maxResults = $testMatch;
+if (isset($_REQUEST["searchBbox"]) & $_REQUEST["searchBbox"] != "") {
+ $testMatch = $_REQUEST["searchBbox"];
+ $pattern = '/^[-\d,]*$/';
+ echo 'searchBbox: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ if (count(explode(',',$testMatch)) != 4) {
+ echo 'searchBbox: <b>'.$testMatch.'</b> has a wrong amount of entries.<br/>';
+ die();
+ $searchBbox = $testMatch;
+if (isset($_REQUEST["searchTypeBbox"]) & $_REQUEST["searchTypeBbox"] != "") {
+ //validate to inside / outside - TODO implement other ones than intersects which is default
+ $testMatch = $_REQUEST["searchTypeBbox"];
+ if (!($testMatch == 'inside' or $testMatch == 'outside')){
+ echo 'searchTypeBbox: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ #$searchTypeBbox = $testMatch; //TODO activate this
+if (isset($_REQUEST["accessRestrictions"]) & $_REQUEST["accessRestrictions"] != "") {
+ //validate to ?
+ #TODO implement me //$accessRestrictions = $_REQUEST["accessRestrictions"];
+if (isset($_REQUEST["languageCode"]) & $_REQUEST["languageCode"] != "") {
+ //validate to de, en, fr
+ $testMatch = $_REQUEST["languageCode"];
+ if (!($testMatch == 'de' or $testMatch == 'en' or $testMatch == 'fr')){
+ echo 'languageCode: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $languageCode = $testMatch;
+if (isset($_REQUEST["outputFormat"]) & $_REQUEST["outputFormat"] != "") {
+ $testMatch = $_REQUEST["outputFormat"];
+ if (!($testMatch == 'json' or $testMatch == 'georss')){
+ echo 'outputFormat: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $outputFormat = $testMatch;
+if (isset($_REQUEST["searchResources"]) & $_REQUEST["searchResources"] != "") {
+ //validate to wms,wfs,wmc,georss
+ $testMatch = $_REQUEST["searchResources"];
+ #$pattern = '/^(19|20)[0-9]{2}[-](0[1-9]|1[012])[-](0[1-9]|[12][0-9]|3[01])$/';
+ $countSR = count(explode(',',$testMatch));
+ if (!($countSR >= 1 && $countSR <= 4)){
+ echo 'searchResources: <b>'.$testMatch.'</b> count of requested resources out of sync.<br/>';
+ die();
+ } else {
+ $testArray = explode(',',$testMatch);
+ for($i=0; $i<count($testArray);$i++){
+ if (!($testArray[$i] == 'wms' or $testArray[$i] == 'wfs' or $testArray[$i] == 'wmc' or $testArray[$i] == 'georss')) {
+ echo 'searchResources: <b>'.$testMatch.'</b>at least one of them does not exists!<br/>';
+ die();
+ unset($i);
+ $searchResources = $testMatch;
+if (isset($_REQUEST["searchPages"]) & $_REQUEST["searchPages"] != "") {
+ //validate to csv integer list with dimension of searchResources list
+ $testMatch = $_REQUEST["searchPages"];
+ echo 'searchPages: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ if (count(explode(',',$testMatch)) != count(explode(',',$searchResources))) {
+ echo 'searchPages: <b>'.$testMatch.'</b> has a wrong amount of entries.<br/>';
+ die();
+ $searchPages = $testMatch;
+$searchPages = $_REQUEST["searchPages"];
+ #$searchPages = split(',',$searchPages);
+if (isset($_REQUEST["resultTarget"]) & $_REQUEST["resultTarget"] != "") {
+ //validate to web,debug,file
+ $testMatch = $_REQUEST["resultTarget"];
+ if (!($testMatch == 'web' or $testMatch == 'debug' or $testMatch == 'file')){
+ echo 'resultTarget: <b>'.$testMatch.'</b> is not valid.<br/>';
+ die();
+ $resultTarget = $testMatch;
+//validate request parameters
+if (!isset($_SESSION['mb_user_id'])) {
+ $userId = ANONYMOUS_USER;
+else
+ $userId = $_SESSION['mb_user_id'];
+#$searchResources = array('wms','wfs','wmc','georss');
+#$searchPages = array(1,1,1,1);
+//TODO: if class is called directly
+ #$registratingDepartments = explode(",",$registratingDepartments);
+ #$isoCategories = explode(",",$isoCategories);
+ #$inspireThemes = explode(",",$inspireThemes);
+ #$searchBbox = explode(",",$searchBbox);
+ $searchResources = explode(",",$searchResources);
+ $searchPages = explode(",",$searchPages);
+//read the whole query string:
+$searchURL = $_SERVER['QUERY_STRING'];
+if ($resultTarget == 'debug') {
+ echo "<br>DEBUG: searchURL: ".$searchURL."<br>";
+ #echo "<br>DEBUG: languageCode: ".$languageCode."<br>";
+//Generate search filter file. This file holds the defined search filter to allow the user to see how he searched
+//The user should become the possibility to drop the search filters by clicking in some buttons
+//list of options to display:
+//searchText (textfields) - dropping only if more than one text is given
+//registratingDepartments (list) - dropping allowed - maybe give a webservice for mb_group data
+//isoCategories - dropping allowed
+//inspireThemes - dropping allowed
+//customCategories - dropping allowed
+//bbox (show) - dropping allowed
+//regTimeBegin - dropping allowed
+//regTimeEnd -dropping allowed
+//the idea is, to rewrite the searchURL directly and then have another url for the special case!
+//we have to get the searchURL as a parameter for this wrapper cause the class_metadata should give filters for the found categories
+//use regular expressions to do this!
+//define internationalization
+//searchText
+//bbox
+//generate query json:
+//some objects like names of categories and other objects have to be pulled of the database. Maybe a webservice is the better way? But now there are no webservices - therefor: pull the names out of the database into arrays - only those who are requested:
+//function to get the information about the registrating departments (mb_groups) out of the mapbender database
+function get_registratingDepartmentsArray($departmentIds,$languageCode) {
+ $sql = "SELECT mb_group_id, mb_group_name FROM mb_group WHERE mb_group_id IN (";
+ $v = array();
+ $t = array();
+ $departmentsArray = array();
+ for($i=0; $i<count($departmentIds);$i++){
+ if($i > 0){$sql .= ",";}
+ $sql .= "$".strval($i+1);
+ array_push($v,$departmentIds[$i]);
+ array_push($t,"i");
+ $sql .= ")";
+ $res = db_prep_query($sql,$v,$t);
+ $countDepArray = 0;
+ while($row = db_fetch_array($res)){
+ $departmentsArray[$countDepArray]["id"] = $row["mb_group_id"];
+ $departmentsArray[$countDepArray]["name"] = $row["mb_group_name"];
+ $departmentsArray[$countDepArray]["showScript"] = "../php/mod_showRegistratingGroup.php?";
+ $countDepArray = $countDepArray + 1;
+ return $departmentsArray;
+//get the information about the requested isoCategories
+function get_isoCategoriesArray($isoCategoryIds,$languageCode) {
+ $sql = "SELECT md_topic_category_id, md_topic_category_code_".$languageCode;
+ #$e = new mb_exception("php/mod_callMetadata.php: language code: ".$languageCode);
+ $sql .= " FROM md_topic_category WHERE md_topic_category_id IN (";
+ $v = array();
+ $t = array();
+ $isoCategoryArray = array();
+ for($i=0; $i<count($isoCategoryIds);$i++){
+ array_push($v,$isoCategoryIds[$i]);
+ $sql .= ")";
+ #$e = new mb_exception("php/mod_callMetadata.php: sql for getting topic cats: ".$sql);
+ $countIsoArray = 0;
+ $isoCategoryArray[$countIsoArray]["id"] = $row["md_topic_category_id"];
+ $isoCategoryArray[$countIsoArray]["name"] = $row["md_topic_category_code_".$languageCode];
+ $countIsoArray = $countDepArray + 1;
+ return $isoCategoryArray;
+//get the information about the inspireThemes
+function get_inspireThemesArray($inspireThemesIds,$languageCode) {
+ $sql = "SELECT inspire_category_id, inspire_category_code_".$languageCode." FROM inspire_category WHERE inspire_category_id IN (";
+ $v = array();
+ $t = array();
+ $inspireCategoryArray = array();
+ for($i=0; $i<count($inspireThemesIds);$i++){
+ array_push($v,$inspireThemesIds[$i]);
+ $sql .= ")";
+ $e = new mb_exception("php/mod_callMetadata.php: sql for getting inspire cats: ".$sql);
+ $countInspireArray = 0;
+ $inspireCategoryArray[$countInspireArray]["id"] = $row["inspire_category_id"];
+ $inspireCategoryArray[$countInspireArray]["name"] = $row["inspire_category_code_".$languageCode];
+ $countInspireArray = $countInspireArray + 1;
+ return $inspireCategoryArray;
+function get_customCategoriesArray($customCategoriesIds,$languageCode) {
+ $sql = "SELECT custom_category_id, custom_category_code_".$languageCode." FROM custom_category WHERE custom_category_id IN (";
+ $v = array();
+ $t = array();
+ $customCategoryArray = array();
+ for($i=0; $i<count($customCategoriesIds);$i++){
+ array_push($v,$customCategoriesIds[$i]);
+ $sql .= ")";
+ $e = new mb_exception("php/mod_callMetadata.php: sql for getting custom cats: ".$sql);
+ $countCustomArray = 0;
+ $customCategoryArray[$countCustomArray]["id"] = $row["custom_category_id"];
+ $customCategoryArray[$countCustomArray]["name"] = $row["custom_category_code_".$languageCode];
+ $countCustomArray = $countCustomArray + 1;
+ return $customCategoryArray;
+//define where to become the information from - this is relavant for the information which must be pulled out of the database
+$classificationElements = array();
+$classificationElements[0]['name'] = 'searchText';
+$classificationElements[1]['name'] = 'registratingDepartments';
+$classificationElements[2]['name'] = 'isoCategories';
+$classificationElements[3]['name'] = 'inspireThemes';
+$classificationElements[4]['name'] = 'customCategories';
+$classificationElements[5]['name'] = 'searchBbox';
+$classificationElements[6]['name'] = 'regTimeBegin';
+$classificationElements[7]['name'] = 'regTimeEnd';
+$classificationElements[0]['source'] = '';
+$classificationElements[1]['source'] = 'database';
+$classificationElements[2]['source'] = 'database';
+$classificationElements[3]['source'] = 'database';
+$classificationElements[4]['source'] = 'database';
+$classificationElements[5]['source'] = '';
+$classificationElements[6]['source'] = '';
+$classificationElements[7]['source'] = '';
+$classificationElements[0]['list'] = true;
+$classificationElements[1]['list'] = true;
+$classificationElements[2]['list'] = true;
+$classificationElements[3]['list'] = true;
+$classificationElements[4]['list'] = true;
+$classificationElements[5]['list'] = false;
+$classificationElements[6]['list'] = false;
+$classificationElements[7]['list'] = false;
+switch($languageCode){
+ case 'de':
+ $classificationElements[0]['name2show'] = 'Suchbegriff(e):';
+ $classificationElements[1]['name2show'] = 'Anbietende Stelle(n):';
+ $classificationElements[3]['name2show'] = 'INSPIRE Themen:';
+ $classificationElements[2]['name2show'] = 'ISO Kategorien:';
+ $classificationElements[4]['name2show'] = 'RP Kategorien:';
+ $classificationElements[5]['name2show'] = 'Räumliche Einschränkung:';
+ $classificationElements[6]['name2show'] = 'Registrierung/Aktualisierung von:';
+ $classificationElements[7]['name2show'] = 'Registrierung/Aktualisierung bis:';
+ break;
+ case 'en':
+ $classificationElements[0]['name2show'] = 'Search Term(s):';
+ $classificationElements[1]['name2show'] = 'Department(s):';
+ $classificationElements[3]['name2show'] = 'INSPIRE Themes:';
+ $classificationElements[2]['name2show'] = 'ISO Topic Categories:';
+ $classificationElements[4]['name2show'] = 'RP Categories:';
+ $classificationElements[5]['name2show'] = 'Spatial Filter:';
+ $classificationElements[6]['name2show'] = 'Registration/Update from:';
+ $classificationElements[7]['name2show'] = 'Registration/Update till:';
+ break;
+ case 'fr':
+ break;
+ default:
+$queryJSON = new stdClass;
+$queryJSON->searchFilter = (object) array();
+//generate search filter file - if more categories are defined give
+#echo "<br> number of filter elements: ".count($classificationElements)."<br>";
+for($i=0; $i < count($classificationElements); $i++){
+ if (isset(${$classificationElements[$i]['name']}) & ${$classificationElements[$i]['name']} !='' & ${$classificationElements[$i]['name']} != NULL) {
+ //pull register information out of database in arrays
+ if ($classificationElements[$i]['source'] == 'database') {
+ $funcName = "get_".$classificationElements[$i]['name']."Array";
+ ${$classificationElements[$i]['name']."Array"} = $funcName(explode(',',${$classificationElements[$i]['name']}),$languageCode);
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->title = $classificationElements[$i]['name2show'];
+ //check if the filter has subfilters - if not delete the whole filter from query
+ if ($classificationElements[$i]['list'] == false) { //the object has no subsets - like bbox or time filters
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->delLink = delTotalFromQuery($classificationElements[$i]['name'],$searchURL);
+ } else {
+ //TODO delete all entries of this main category (not for searchText)
+ if ($classificationElements[$i]['name'] != 'searchText') {
+ } else {
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->delLink = NULL;
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->item = array();
+ $queryArray = explode(',',${$classificationElements[$i]['name']});
+ //loop for the subcategories
+ for($j=0; $j < count($queryArray); $j++){
+ $identArray = ${$classificationElements[$i]['name']."Array"};
+ $identArray = flipDiagonally($identArray);
+ //find searched id in information from database
+ $key = array_search($queryArray[$j], $identArray['id']);
+ if ($key === false) {
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->title = "no information found in database";
+ } else {
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->title = ${$classificationElements[$i]['name']."Array"}[$key]['name'];
+ } else {
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->title = $queryArray[$j];
+ //generate links to disable filters on a simple way
+ if ($classificationElements[$i]['name'] === 'searchText' & count(explode(',',${$classificationElements[$i]['name']})) === 1) {
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->delLink = NULL;
+ } else {
+ $newSearchLink = delFromQuery($classificationElements[$i]['name'], $searchURL,$queryArray[$j],$queryArray,${$classificationElements[$i]['name']});
+ $newSearchLink = delTotalFromQuery('searchId',$newSearchLink);
+ $queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->delLink = $newSearchLink;
+//write out json to file or web
+$queryFilter = $classJSON->encode($queryJSON);
+ echo "<br>DEBUG: filter: ".$queryFilter."<br>";
+ #echo "<br>DEBUG: searchTypeBbox: ".$searchTypeBbox."<br>";
+if ($resultTarget == 'file') {
+ $filename = $tempFolder."/".$searchId."_filter.json";
+ if($catFileHandle = fopen($filename, "w")){
+ fwrite($catFileHandle,$queryFilter);
+ fclose($catFileHandle);
+ $e = new mb_notice("php/callMetdata.php: new filter_file created!");
+ } else {
+ $e = new mb_notice("php/callMetdata.php: cannot create filter_file!");
+//function to transpose a matrix - sometimes needed to do an array search
+function flipDiagonally($arr) {
+ $out = array();
+ foreach ($arr as $key => $subarr) {
+ foreach ($subarr as $subkey => $subvalue) {
+ $out[$subkey][$key] = $subvalue;
+ return $out;
+//function to delete one of the comma separated values from one get request
+function delFromQuery($paramName,$queryString,$string,$queryArray,$queryList) {
+ //check if if count searchArray = 1
+ if (count($queryArray) == 1){
+ //remove request parameter from url by regexpr or replace
+ $str2search = $paramName."=".$queryList;
+ $str2exchange = "";
+ $queryStringNew = str_replace($str2search, $str2exchange, $queryString);
+ $queryStringNew = str_replace("&&", "&", $queryStringNew);
+ } else {
+ //there are more than one filter - reduce the filter
+ $objectList = "";
+ for($i=0; $i < count($queryArray); $i++){
+ if ($queryArray[$i] != $string){
+ $objectList .= $queryArray[$i].",";
+ //remove last comma
+ $objectList = rtrim($objectList, ",");
+ $str2exchange = $paramName."=".$objectList;
+ return $queryStringNew;
+//function to remove one complete get param out of the query
+function delTotalFromQuery($paramName,$queryString) {
+ $queryString = "&".$queryString;
+ $queryStringNew = preg_replace('/\b'.$paramName.'\=[^&]+&?/',"",$queryString);
+ $queryStringNew = ltrim($queryStringNew,'&');
+ $queryStringNew = rtrim($queryStringNew,'&');
+//call class_metadata - in case of file for all requested resources, in case of web only for one resource - cause there are different result files
+ for($i=0; $i<count($searchResources);$i++){
+ $str = "nohup php5 /data/mapbender/http/php/mod_metadataWrite.php ";
+ $str .= "'".$userId."' ";
+ $str .= "'".$searchId."' ";
+ $str .= "'".$searchText."' ";
+ $str .= "'".$registratingDepartments."' ";
+ $str .= "'".$isoCategories."' ";
+ $str .= "'".$inspireThemes."' ";
+ $str .= "'".$timeBegin."' ";
+ $str .= "'".$timeEnd."' ";
+ $str .= "'".$regTimeBegin."' ";
+ $str .= "'".$regTimeEnd."' ";
+ $str .= "'".$maxResults."' ";
+ $str .= "'".$searchBbox."' ";
+ $str .= "'".$searchTypeBbox."' ";
+ $str .= "'".$accessRestrictions."' ";
+ $str .= "'".$languageCode."' ";
+ $str .= "'".$searchEPSG."' ";
+ $str .= "'".$searchResources[$i]."' ";
+ $str .= "'".$searchPages[$i]."' ";
+ $str .= "'".$outputFormat."' ";
+ $str .= "'".$resultTarget."' ";
+ $str .= "'".$searchURL."' ";
+ $str .= "'".$customCategories."' ";
+ $str .= " & ";
+ $e = new mb_exception($str);
+ exec($str);
+if ($resultTarget == 'web' or $resultTarget == 'debug') {
+ if (count($searchResources) == 1) {
+ $metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories);
+ #if ($outputFormat == 'xml') {
+ # header("Content-type: application/xhtml+xml; charset=UTF-8");
+ #echo "class initiated<br>";
+ else {
+ echo "Result for web can only requested for one type of resource (wms, wfs, wmc, georss)!";
+How does the webservice look like?
+First request: Do search for all classes.
+Next request: Search only in the requested class and the numbered page.
+search.php?q=test&classes=wms,wfs,wmc,georss&pages=1,1,1,1&iso=1,2,3&inspire=1,2,3,4&department=1,2,3,4&bbox=123,123,123,123
+simple other request:
+search.php?q=test&classes=wms&pages=2&iso=1,2,3&inspire=1,2,3,4&department=1,2,3,4&beginDate=2009-10-10&endDate=2010-11-12&searchId=12hjxa31231
+There is a possibility to exchange some classes by other information - the id will be used to update the search result files - but this can only update the class infos. The pagenumber should be updated in the metadata file
+//Name of searchMetadata file
+//searchid_classes.json
+//Name of searchCategories file
+//Name of searchResult files
+//searchid_wms_1.json
+//searchid_wfs_1.json
+//searchid_wmc_1.json - doesn't exists till now
+//searchid_georss_1.json - doesn't exists till now
+//categories files - will only be generated when the search is started and resultType = 'file'. if the categories files already exists it will not be updated! - Here we can spare a reasonable amount of calculating power. Another approach is to generate a md5 hash of an ordered searchURL. With this we can cache the requests!
+//searchid_wms_cat.json
+//searchid_wfs_cat.json
+//searchid_wmc_cat.json - doesn't exists till now
+//searchid_georss_cat.json - doesn't exists till now
+//searchid_filter.json
\ No newline at end of file
Added: trunk/mapbender/http/php/mod_metadataWrite.php
--- trunk/mapbender/http/php/mod_metadataWrite.php (rev 0)
+++ trunk/mapbender/http/php/mod_metadataWrite.php 2010-02-09 09:15:17 UTC (rev 5490)
@@ -0,0 +1,26 @@
+<?php
+$userId = $_SERVER["argv"][1];
+$searchId = $_SERVER["argv"][2];
+$searchText = $_SERVER["argv"][3];
+$registratingDepartments = $_SERVER["argv"][4];
+$isoCategories = $_SERVER["argv"][5];
+$inspireThemes = $_SERVER["argv"][6];
+$timeBegin = $_SERVER["argv"][7];
+$timeEnd = $_SERVER["argv"][8];
+$regTimeBegin = $_SERVER["argv"][9];
+$regTimeEnd = $_SERVER["argv"][10];
+$maxResults = $_SERVER["argv"][11];
+$searchBbox = $_SERVER["argv"][12];
+$searchTypeBbox = $_SERVER["argv"][13];
+$accessRestrictions = $_SERVER["argv"][14];
+$languageCode = $_SERVER["argv"][15];
+$searchEPSG = $_SERVER["argv"][16];
+$searchResources = $_SERVER["argv"][17];
+$searchPages = $_SERVER["argv"][18];
+$outputFormat = $_SERVER["argv"][19];
+$resultTarget = $_SERVER["argv"][20];
+$searchURL = $_SERVER["argv"][21];
+$customCategories = $_SERVER["argv"][22];
+$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL,$customCategories);
More information about the Mapbender_commits
