[Mapbender-commits] r5520 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Feb 19 08:34:30 EST 2010
Author: astrid_emde
Date: 2010-02-19 08:34:29 -0500 (Fri, 19 Feb 2010)
New Revision: 5520
trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList_ajax.php
translations for checkboxes and notice text
Modified: trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList_ajax.php
--- trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList_ajax.php 2010-02-19 11:11:49 UTC (rev 5519)
+++ trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList_ajax.php 2010-02-19 13:34:29 UTC (rev 5520)
@@ -1,7 +1,7 @@
<?php
# $Id$
# http://www.mapbender.org/index.php/mod_addWMSfromfilteredList.php
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
@@ -52,7 +52,7 @@
addwms_zoomToExtent = 0;
var guis = gui_list.split(',');
if(gui_list === '') {
guis = [];
@@ -68,35 +68,35 @@
var loadWmsAndZoomCallback = function (opt) {
if (typeof opt === "object" && opt.success) {
var wmsId = parseInt(opt.wmsId, 10);
var map = parent.getMapObjByName('<?php echo $e_target[1]; ?>');
var wms = map.wms[map.wms.length - 1];
if (wms === null) {
opt.msg = "Ein unbekannter Fehler ist aufgetreten.";
else {
// activate
if (typeof opt.visible === "number" && opt.visible === 1) {
- if (typeof addwms_showWMS === "number"
+ if (typeof addwms_showWMS === "number"
&& addwms_showWMS < wms.objLayer.length) {
if (addwms_showWMS > 0) {
try {
var msg = "Der hinzugeladene Kartendienst " +
"verfügt über mehr als " +
addwms_showWMS +
" Ebenen. Die Ebenen des Dienstes werden " +
"<b>nicht</b> aktiviert.";
parent.Mapbender.modules.dialogManager.openDialog({
content: msg,
modal: false,
effectShow: 'puff'
catch (e) {
new parent.Mb_warning(e.message + ". " + msg);
@@ -107,7 +107,7 @@
parent.handleSelectedWms(map.elementName, wmsId, "visible", 1)
if (typeof opt.zoomToExtent === "number" && opt.zoomToExtent === 1) {
// zoom to bbox
var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
@@ -120,7 +120,7 @@
if (bbox_minx === null || bbox_miny === null || bbox_maxx === null || bbox_maxy === null) {
continue;
map.calculateExtent(new parent.Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy));
map.setMapRequest();
break;
@@ -135,16 +135,16 @@
var loadWmsCallback = function (opt) {
var msg = typeof opt.msg === "string" ? opt.msg : "";
if (typeof opt !== "object" || !opt.success) {
else {
if (wms !== null) {
- msg = "Der folgende Dienst wurde zu 'Aktive Dienste' " +
+ msg = "Der folgende Dienst wurde zu 'Aktive Dienste' " +
"hinzugefügt:<br><br>";
msg += "<b>" + wms.wms_title + "</b>";
@@ -166,7 +166,7 @@
function mod_addWMSfromfilteredList(pointer_name, version, options){
pointer_name=pointer_name + parent.mb_getConjunctionCharacter(pointer_name);
if (version == '1.0.0'){
var cap = pointer_name + "REQUEST=capabilities&WMTVER=1.0.0";
@@ -179,12 +179,12 @@
else if (version == '1.1.1'){
var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1";
var load = cap;
if(load){
parent.mod_addWMS_load(load, options);
function mod_addWmsfromURL(){
var capabilities = document.getElementById('CapURL').value;
var zoomToExtent = document.getElementById('addwms-zoom').checked ? 1 : 0;
@@ -258,7 +258,7 @@
document.getElementById('resultString').innerHTML = text;
document.getElementById('titleLeft').innerHTML = titleLeft;
document.getElementById('titleRight').innerHTML = titleRight;
removeChildNodes(document.getElementById('resultTableBody'));
@@ -269,7 +269,7 @@
var leftTableCellContent = document.createElement('strong');
var rightTableCellContent = document.createElement('em');
var tableRow = document.createElement('tr');
leftTableCellContent.innerHTML = leftText;
rightTableCellContent.innerHTML = rightText;
@@ -277,7 +277,7 @@
rightTableCell.appendChild(rightTableCellContent);
tableRow.appendChild(leftTableCell);
tableRow.appendChild(rightTableCell);
tableRow.onclick = function () {
eval(onClick);
@@ -316,9 +316,9 @@
if (typeof addwms_showWMS === "number" && addwms_showWMS > 0) {
document.getElementById("addwms-show").checked = "checked";
- if (typeof addwms_zoomToExtent === "number"
+ if (typeof addwms_zoomToExtent === "number"
&& addwms_zoomToExtent === 1) {
document.getElementById("addwms-zoom").checked = "checked";
@@ -330,8 +330,8 @@
// If only one is active load list imidiately
if(
- parseInt(option_dbgui) +
- parseInt(option_dbgroup) +
+ parseInt(option_dbgui) +
+ parseInt(option_dbgroup) +
parseInt(option_dball)
=== 1) {
if(option_dball === 1){
@@ -347,7 +347,7 @@
if(optionButton) {
optionButton.onclick();
containerButtons.parentNode.removeChild(containerButtons);
return;
@@ -364,7 +364,7 @@
optionButton = document.getElementById('button_dbGui');
optionButton.parentNode.removeChild(optionButton);
if(capabilitiesInput === 0) {
optionButton = document.getElementById('capabilitiesForm');
@@ -375,10 +375,10 @@
function displayGroups (groupArray) {
if (groupArray.length > 0) {
setTableHeader(selectGroupText, groupNameText, groupAbstractText);
for (var i = 0; i < groupArray.length; i++) {
var onClick = "getWMSByGroup('" + groupArray[i].id + "')";
- addTableRow(groupArray[i].name, groupArray[i].description, onClick);
+ addTableRow(groupArray[i].name, groupArray[i].description, onClick);
else {
@@ -389,19 +389,19 @@
function displayGUIs (guiArray) {
if (guiArray.length > 0) {
setTableHeader(selectGuiText, guiNameText, guiAbstractText);
for (var i = 0; i < guiArray.length; i++) {
var onClick = "getWMSByGUI('" + guiArray[i].id + "')";
if(guis.length>0){
for(var j=0; j < guis.length; j++){
if(guiArray[i].id==guis[j]){
- addTableRow(guiArray[i].name, guiArray[i].description, onClick);
+ addTableRow(guiArray[i].name, guiArray[i].description, onClick);
break;
else
else {
@@ -416,24 +416,24 @@
for (var i = 0; i < wmsArray.length; i++) {
if (global_source == "db" && typeof(guiId) !== "undefined" ) {
- var onClick = "parent.mod_addWMSById_ajax(" +
- "'" + guiId + "', '" + wmsArray[i].id + "', {" +
- "callback: function (opt) {" +
- "if (typeof opt === 'object' && opt.success) {" +
- "var wmsId = parseInt(opt.wmsId, 10);" +
- "var map = getMapObjByName('<?php echo $e_target[0]; ?>');" +
- "handleSelectedWms(map.elementName, wmsId, 'visible', 0);" +
- "handleSelectedWms(map.elementName, wmsId, 'querylayer', 0);" +
+ var onClick = "parent.mod_addWMSById_ajax(" +
+ "'" + guiId + "', '" + wmsArray[i].id + "', {" +
+ "callback: function (opt) {" +
+ "if (typeof opt === 'object' && opt.success) {" +
+ "var wmsId = parseInt(opt.wmsId, 10);" +
+ "var map = getMapObjByName('<?php echo $e_target[0]; ?>');" +
+ "handleSelectedWms(map.elementName, wmsId, 'visible', 0);" +
+ "handleSelectedWms(map.elementName, wmsId, 'querylayer', 0);" +
"loadWmsCallback(opt);}});";
else {
- var onClick = "mod_addWMSfromfilteredList(\"" +
- wmsArray[i].getCapabilitiesUrl + "\",\"" +
- wmsArray[i].version+"\", {" +
- "zoomToExtent: 0, " +
- "visible: 0, " +
- "callback: loadWmsCallback" +
+ var onClick = "mod_addWMSfromfilteredList(\"" +
+ wmsArray[i].getCapabilitiesUrl + "\",\"" +
+ wmsArray[i].version+"\", {" +
+ "zoomToExtent: 0, " +
+ "visible: 0, " +
+ "callback: loadWmsCallback" +
addTableRow(wmsArray[i].title, wmsArray[i].abstract, onClick);
@@ -464,23 +464,23 @@
<body onLoad="setButtons();setDefaults();">
<h1><?php echo _mb("Add WMS"); ?></h1>
<p><?php echo _mb("Enter a Capabilities-URL of a WMS or select one or more WMS from list."); ?></p>
-<p><em><?php echo _mb("Hint: Possibly you need to zoom in for showing layers from external map service. The operator of the external service is responsible for the display ranges. PortalU does not have a stake in this behaviour."); ?></em></p>
+<p><em><?php echo _mb("Notice: Be aware of the scale hints. Possibly you need to zoom in to display the added service."); ?></em></p>
<form id="capabilitiesForm" name="addURLForm" method="post" action="">
<fieldset id="container_capabilities">
<legend>Capabilities</legend>
<p>
- <label for="CapURL"><?php echo _mb("Capabilities-URL"); ?>:</label>
- <input type="text" id="CapURL" name="CapURL" />
+ <label for="CapURL"><?php echo _mb("Capabilities-URL"); ?>:</label>
+ <input type="text" id="CapURL" name="CapURL" />
<input type="button" id="addCapURL" name="addCapURL" value="<?php echo _mb("Add WMS"); ?>" onclick="mod_addWmsfromURL();" /><br />
</p>
<p style="padding:0 0 4px 0;">
<input style="margin-left: 12em;" type="checkbox" id="addwms-show" />
- <label style='display:inline;float:none;cursor:pointer' for="addwms-show">Ebenen des Kartendienstes aktivieren</label>
+ <label style='display:inline;float:none;cursor:pointer' for="addwms-show"><?php echo _mb("activate layers"); ?></label>
</p>
<input style="margin-left: 12em;" type="checkbox" id="addwms-zoom" />
- <label style='display:inline;float:none;cursor:pointer' for="addwms-zoom">Auf Ebenenausdehnung des Kartendienstes heranzoomen</label>
+ <label style='display:inline;float:none;cursor:pointer' for="addwms-zoom"><?php echo _mb("zoom to extent"); ?></label>
</p>
</fieldset>
</form>
@@ -490,15 +490,15 @@
<legend>WMS list(s)</legend>
<p>
<input type="button" name="button_dbAll" id="button_dbAll" value="<?php echo _mb("List all WMS"); ?>" onclick="setSource('db');getWMSByGUI(gui_list)">
- <input type="button" name="button_dbGroup" id="button_dbGroup" value="<?php echo _mb("List WMS by Group"); ?>" onclick="setSource('db');getGroups()">
- <input type="button" name="button_dbGui" id="button_dbGui" value="<?php echo _mb("List WMS by Application"); ?>" onclick="setSource('db');getGUIs()">
+ <input type="button" name="button_dbGroup" id="button_dbGroup" value="<?php echo _mb("List WMS by Group"); ?>" onclick="setSource('db');getGroups()">
+ <input type="button" name="button_dbGui" id="button_dbGui" value="<?php echo _mb("List WMS by Application"); ?>" onclick="setSource('db');getGUIs()">
</p>
</fieldset>
</form>
<p id="progressIndicator" name="progressIndicator">
<img src="../img/indicator_wheel.gif" />
- <?php echo _mb("Loading"); ?> ...
+ <?php echo _mb("Loading"); ?> ...
</p>
<h2 id="resultString" name="resultString"></h2>
More information about the Mapbender_commits
