[Mapbender-commits] r5565 - branches/2.6/http/php
svn_mapbender at osgeo.org
Sat Feb 20 09:51:32 EST 2010
Author: astrid_emde
Date: 2010-02-20 09:51:32 -0500 (Sat, 20 Feb 2010)
New Revision: 5565
branches/2.6/http/php/mod_gazetteerMetadata_search.php
error in SQl ;
Modified: branches/2.6/http/php/mod_gazetteerMetadata_search.php
--- branches/2.6/http/php/mod_gazetteerMetadata_search.php 2010-02-20 14:50:52 UTC (rev 5564)
+++ branches/2.6/http/php/mod_gazetteerMetadata_search.php 2010-02-20 14:51:32 UTC (rev 5565)
@@ -8,7 +8,17 @@
$user_id = $_SESSION["mb_user_id"];
$query = stripslashes($_REQUEST["search"]);
$srs = stripslashes($_REQUEST["srs"]);
+$searchColumnsWms = $_REQUEST["searchColumnsWms"];
+$searchColumnsLayer = $_REQUEST["searchColumnsLayer"];
+if ($searchColumnsWms && !preg_match("/^[a-zA-Z_\-, ]+$/", $searchColumnsWms)) {
+ echo "[]"; die;
+if ($searchColumnsLayer && !preg_match("/^[a-zA-Z_\-, ]+$/", $searchColumnsLayer)) {
+ echo "[]"; die;
if (!preg_match("/^[a-zA-Z_\- ]+$/", $query)) {
echo "[]"; die;
@@ -55,7 +65,22 @@
array_push($v, $mywms[$i]);
array_push($t, 'i');
- $sql_wms .= ") AND (wms_title ILIKE '%".$query."%' OR wms_abstract ILIKE '%".$query."%') ORDER BY wms_title";
+ $sql_wms .= ") AND (";
+ if($searchColumnsWms == "") {
+ $sql_wms .= "wms_title ILIKE '%".$query."%' OR wms_abstract ILIKE '%".$query."%'";
+ else{
+ $wmsColumnArray = split(",", $searchColumnsWms);
+ for($j = 0; $j < count($wmsColumnArray); $j++) {
+ if ($j > 0) {
+ $sql_wms .= " OR ";
+ $sql_wms .= trim($wmsColumnArray[$j]) . " ILIKE '%".$query."%'";
+ $sql_wms .= ") ORDER BY wms_title";
$res_wms = db_prep_query($sql_wms,$v,$t);
while ($row = db_fetch_array($res_wms)) {
@@ -95,14 +120,27 @@
- $sql_layer .= ") AND (" .
- "layer_title ILIKE '%".$query."%' OR " .
- "layer_name ILIKE '%".$query."%' OR " .
- "layer_abstract ILIKE '%".$query."%' OR " .
- "kw.keyword ILIKE '%".$query."%') ";
- $sql_layer .= "ORDER BY l.layer_title;";
+ $sql_layer .= ") AND (";
+ if($searchColumnsLayer == "") {
+ $sql_layer .= "layer_title ILIKE '%".$query."%' OR " .
+ "layer_name ILIKE '%".$query."%' OR " .
+ "layer_abstract ILIKE '%".$query."%' ";
+ else{
+ $layerColumnArray = split(",", $searchColumnsLayer);
+ for($k = 0; $k < count($layerColumnArray); $k++) {
+ if ($k > 0) {
+ $sql_layer .= " OR ";
+ $sql_layer .= trim($layerColumnArray[$k]) . " ILIKE '%".$query."%'";
+ $sql_layer .= " OR kw.keyword ILIKE '%".$query."%') ORDER BY l.layer_title;";
$res_layer = db_prep_query($sql_layer,$v,$t);
while ($row = db_fetch_array($res_layer)) {
array_push($obj, array(
'wms_getcapabilities' => $row['wms_getcapabilities'],
More information about the Mapbender_commits
