[Mapbender-commits] r5639 - in trunk/mapbender/documents/api_js: . Data index javascript search
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Feb 24 11:13:31 EST 2010
Author: christoph
Date: 2010-02-24 11:13:30 -0500 (Wed, 24 Feb 2010)
New Revision: 5639
Added:
   trunk/mapbender/documents/api_js/Menu_Backup_2.txt
   trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
   trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
   trunk/mapbender/documents/api_js/Data/FileInfo.nd
   trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd
   trunk/mapbender/documents/api_js/Data/IndexInfo.nd
   trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
   trunk/mapbender/documents/api_js/Data/PreviousSettings.nd
   trunk/mapbender/documents/api_js/Data/SymbolTable.nd
   trunk/mapbender/documents/api_js/Menu.txt
   trunk/mapbender/documents/api_js/index.html
   trunk/mapbender/documents/api_js/index/Classes.html
   trunk/mapbender/documents/api_js/index/Files.html
   trunk/mapbender/documents/api_js/index/Functions.html
   trunk/mapbender/documents/api_js/index/General.html
   trunk/mapbender/documents/api_js/index/Properties.html
   trunk/mapbender/documents/api_js/javascript/searchdata.js
   trunk/mapbender/documents/api_js/search/ClassesA.html
   trunk/mapbender/documents/api_js/search/ClassesB.html
   trunk/mapbender/documents/api_js/search/ClassesE.html
   trunk/mapbender/documents/api_js/search/ClassesL.html
   trunk/mapbender/documents/api_js/search/ClassesM.html
   trunk/mapbender/documents/api_js/search/ClassesN.html
   trunk/mapbender/documents/api_js/search/ClassesP.html
   trunk/mapbender/documents/api_js/search/ClassesR.html
   trunk/mapbender/documents/api_js/search/ClassesW.html
   trunk/mapbender/documents/api_js/search/FilesR.html
   trunk/mapbender/documents/api_js/search/FunctionsA.html
   trunk/mapbender/documents/api_js/search/FunctionsC.html
   trunk/mapbender/documents/api_js/search/FunctionsD.html
   trunk/mapbender/documents/api_js/search/FunctionsE.html
   trunk/mapbender/documents/api_js/search/FunctionsG.html
   trunk/mapbender/documents/api_js/search/FunctionsM.html
   trunk/mapbender/documents/api_js/search/FunctionsN.html
   trunk/mapbender/documents/api_js/search/FunctionsP.html
   trunk/mapbender/documents/api_js/search/FunctionsR.html
   trunk/mapbender/documents/api_js/search/FunctionsS.html
   trunk/mapbender/documents/api_js/search/FunctionsT.html
   trunk/mapbender/documents/api_js/search/FunctionsU.html
   trunk/mapbender/documents/api_js/search/FunctionsW.html
   trunk/mapbender/documents/api_js/search/GeneralA.html
   trunk/mapbender/documents/api_js/search/GeneralB.html
   trunk/mapbender/documents/api_js/search/GeneralC.html
   trunk/mapbender/documents/api_js/search/GeneralD.html
   trunk/mapbender/documents/api_js/search/GeneralE.html
   trunk/mapbender/documents/api_js/search/GeneralF.html
   trunk/mapbender/documents/api_js/search/GeneralG.html
   trunk/mapbender/documents/api_js/search/GeneralL.html
   trunk/mapbender/documents/api_js/search/GeneralM.html
   trunk/mapbender/documents/api_js/search/GeneralN.html
   trunk/mapbender/documents/api_js/search/GeneralP.html
   trunk/mapbender/documents/api_js/search/GeneralR.html
   trunk/mapbender/documents/api_js/search/GeneralS.html
   trunk/mapbender/documents/api_js/search/GeneralT.html
   trunk/mapbender/documents/api_js/search/GeneralU.html
   trunk/mapbender/documents/api_js/search/GeneralW.html
   trunk/mapbender/documents/api_js/search/PropertiesE.html
   trunk/mapbender/documents/api_js/search/PropertiesR.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
(Binary files differ)
Modified: trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
Modified: trunk/mapbender/documents/api_js/Data/FileInfo.nd
--- trunk/mapbender/documents/api_js/Data/FileInfo.nd	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/Data/FileInfo.nd	2010-02-24 16:13:30 UTC (rev 5639)
@@ -1,907 +1,34 @@
 1.4
-PHP
-/home/cbaudson/workspace/trunk/sql/update_wfs_conf.sql	1246284046	0	/home/cbaudson/workspace/trunk/sql/update_wfs_conf.sql
-/home/cbaudson/workspace/trunk/http/php/mod_user_group.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_user_group.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql	1246284071	0	/home/cbaudson/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql
-/home/cbaudson/workspace/trunk/http/sld/classes/LabelPlacement.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/LabelPlacement.php
-/home/cbaudson/workspace/trunk/lib/resizableButton.js	1246284050	0	/home/cbaudson/workspace/trunk/lib/resizableButton.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_selectMapsize.js	1260530974	1	selectMapsize
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/call-load-test.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/call-load-test.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/__global__.js
-/home/cbaudson/workspace/trunk/http/php/mod_editGuiWmsMeta.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_editGuiWmsMeta.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_dynamicOverview.php	1258024545	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_dynamicOverview.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xmltoken.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xmltoken.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/document.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/document.js
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.2_to_2.4.3_pgsql_UTF-8.sql	1258538852	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.2_to_2.4.3_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Main.java	1267021291	0	/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Main.java
-/home/cbaudson/workspace/trunk/http/sld/sld_function_getusersld.php	1246283960	0	/home/cbaudson/workspace/trunk/http/sld/sld_function_getusersld.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/console/console.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/console/console.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/iframe.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/iframe.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_print.js	1267021306	1	printPDF
-/home/cbaudson/workspace/trunk/test/tools/env-js/bin/prototype_1.6.0.3_tmpl.txt	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/bin/prototype_1.6.0.3_tmpl.txt
-/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js	1246612355	1	Reload
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/onload.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/onload.js
-/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql	1246284070	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_html.php	1246283960	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_html.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_owsproxy.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_owsproxy.php
-/home/cbaudson/workspace/trunk/http/plugins/jq_upload.php	1257345660	0	/home/cbaudson/workspace/trunk/http/plugins/jq_upload.php
-/home/cbaudson/workspace/trunk/http/classes/class_gml_multipoint.php	1253260684	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_multipoint.php
-/home/cbaudson/workspace/trunk/http/classes/class_gml_envelope.php	1246284044	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_envelope.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/readme.txt	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/readme.txt
-/home/cbaudson/workspace/trunk/http/classes/class_element.php	1261564131	0	/home/cbaudson/workspace/trunk/http/classes/class_element.php
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php
-/home/cbaudson/workspace/trunk/http/classes/class_checkInput.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_checkInput.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jquery.js	1267021297	1	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jquery.js
-/home/cbaudson/workspace/trunk/http/javascripts/popupballon.js	1253096390	0	/home/cbaudson/workspace/trunk/http/javascripts/popupballon.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.1.1.rc2.js	1267021305	1	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.1.1.rc2.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/test/xpath_script.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/test/xpath_script.js
-/home/cbaudson/workspace/trunk/http/php/mod_customTree_server.php	1259141716	0	/home/cbaudson/workspace/trunk/http/php/mod_customTree_server.php
-/home/cbaudson/workspace/trunk/http/php/mod_loadWFSCapabilities.php	1247129681	0	/home/cbaudson/workspace/trunk/http/php/mod_loadWFSCapabilities.php
-/home/cbaudson/workspace/trunk/tools/wms_extent/wms_geometry.sql	1246284046	0	/home/cbaudson/workspace/trunk/tools/wms_extent/wms_geometry.sql
-/home/cbaudson/workspace/trunk/http/classes/class_wfs.php	1248255824	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs.php
-/home/cbaudson/workspace/trunk/http/php/mod_gui_group.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gui_group.php
-/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilities.php	1260538916	0	/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilities.php
-/home/cbaudson/workspace/trunk/http/classes/class_metadata.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_metadata.php
-/home/cbaudson/workspace/trunk/tools/mod_mailAbo.php	1249461424	0	/home/cbaudson/workspace/trunk/tools/mod_mailAbo.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleHint.php	1246460709	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleHint.php
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_edit.php	1253875191	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_edit.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/doc/jquery-compatibility.txt	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/doc/jquery-compatibility.txt
-/home/cbaudson/workspace/trunk/Readme.txt	1246284075	0	/home/cbaudson/workspace/trunk/Readme.txt
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/uievent.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/uievent.js
-/home/cbaudson/workspace/trunk/http/classes/class_mb_exception.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_mb_exception.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/form.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/form.js
-/home/cbaudson/workspace/trunk/http/php/mod_editElements.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_editElements.php
-/home/cbaudson/workspace/trunk/http/plugins/jq_ui_resizable.js	1264753743	1	jq_ui_resizable
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.pretty.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.pretty.js
-/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2Image.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2Image.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_twitter_signin.js	1267021306	1	twitter_signin
-/home/cbaudson/workspace/trunk/http/php/mod_download.php	1260538915	0	/home/cbaudson/workspace/trunk/http/php/mod_download.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Global.java	1267021291	0	/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Global.java
-/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsBetween.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsBetween.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/a.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/a.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/timer.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/timer.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jss.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jss.js
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_gazetteer_server.php	1263903612	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_gazetteer_server.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_back.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_back.php
-/home/cbaudson/workspace/trunk/http/sld/classes/GraphicStroke.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/GraphicStroke.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/elementmembers.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/elementmembers.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_wfs_gazetteer_client.php	1267026796	1	gazetteerWFS
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/body.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/body.js
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_client.php	1257421140	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_client.php
-/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php
-/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js	1267021307	1	Map
-/home/cbaudson/workspace/trunk/http/php/mod_loadCatalogToGUI.php	1261565743	0	/home/cbaudson/workspace/trunk/http/php/mod_loadCatalogToGUI.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_coords.php	1253875316	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_coords.php
-/home/cbaudson/workspace/trunk/http/php/mod_digitize_splitPolygon.php	1263296626	0	/home/cbaudson/workspace/trunk/http/php/mod_digitize_splitPolygon.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/html/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/html/boot.js
-/home/cbaudson/workspace/trunk/http/php/mod_simpleWMSpreferences.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_simpleWMSpreferences.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php
-/home/cbaudson/workspace/trunk/license/license.txt	1246284047	0	/home/cbaudson/workspace/trunk/license/license.txt
-/home/cbaudson/workspace/trunk/lib/database-mysqli.php	1253874627	0	/home/cbaudson/workspace/trunk/lib/database-mysqli.php
-/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsLike.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsLike.php
-/home/cbaudson/workspace/trunk/http/php/mod_renameGUI.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_renameGUI.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/xmlserializer.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/xmlserializer.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/label.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/label.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/window.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/window.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/event/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/event/boot.js
-/home/cbaudson/workspace/trunk/http/php/mod_loadwms.php	1253875191	0	/home/cbaudson/workspace/trunk/http/php/mod_loadwms.php
-/home/cbaudson/workspace/trunk/tools/mapbender_setup.php	1267021391	0	/home/cbaudson/workspace/trunk/tools/mapbender_setup.php
-/home/cbaudson/workspace/trunk/http/sld/sld_edit_filter.php	1246283960	0	/home/cbaudson/workspace/trunk/http/sld/sld_edit_filter.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.rhino.1.1.rc2.js	1267021305	1	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.rhino.1.1.rc2.js
-/home/cbaudson/workspace/trunk/lib/marker.js	1267027600	1	Mapbender.Marker
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/document.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/document.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_help.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_help.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromList.php	1255602947	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromList.php
-/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read_single_diff.php	1246284046	0	/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read_single_diff.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/domparser.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/domparser.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/mouseevents.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/mouseevents.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeInterval.js	1262680107	1	wmsTimeInterval
-/home/cbaudson/workspace/trunk/http/javascripts/core.php	1263474573	1	Mapbender
-/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities.php	1248077682	0	/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/window.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/window.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_forward.php	1247751995	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_forward.php
-/home/cbaudson/workspace/trunk/http/php/mod_saveWKT.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_saveWKT.php
-/home/cbaudson/workspace/trunk/http/sld/sld_filter_parse.php	1246283960	0	/home/cbaudson/workspace/trunk/http/sld/sld_filter_parse.php
-/home/cbaudson/workspace/trunk/http/javascripts/wfs_obj.js	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/wfs_obj.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_mapstraction.php	1263824745	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_mapstraction.php
-/home/cbaudson/workspace/trunk/http/php/mod_getStyles.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_getStyles.php
-/home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromXML.php	1256201565	0	/home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromXML.php
-/home/cbaudson/workspace/trunk/http/sld/classes/TextSymbolizer.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/TextSymbolizer.php
-/home/cbaudson/workspace/trunk/http/include/dyn_css.php	1246283960	0	/home/cbaudson/workspace/trunk/http/include/dyn_css.php
-/home/cbaudson/workspace/trunk/http/sld/classes/DbUtils.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/DbUtils.php
-/home/cbaudson/workspace/trunk/http/classes/class_gml_multipolygon.php	1253605799	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_multipolygon.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql	1246284075	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/__global__.js
-/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql	1246284071	0	/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/php/mod_forgottenPassword.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_forgottenPassword.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/jqUnit.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/jqUnit.js
-/home/cbaudson/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql	1253874935	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/http/php/wms.php	1251966344	0	/home/cbaudson/workspace/trunk/http/php/wms.php
-/home/cbaudson/workspace/trunk/http/php/mod_WMSpreferences.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_WMSpreferences.php
-/home/cbaudson/workspace/trunk/http/php/mod_createCategory.php	1246283966	0	/home/cbaudson/workspace/trunk/http/php/mod_createCategory.php
-/home/cbaudson/workspace/trunk/http/classes/class_ows_factory.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_ows_factory.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql	1253874941	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/http/classes/class_gml_polygon.php	1253605811	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_polygon.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js	1267021307	1	overviewToggle
-/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql	1253874935	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_0.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_0.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js	1263477108	1	repaint
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt
-/home/cbaudson/workspace/trunk/http/plugins/ol_overview.js	1262789894	1	ol_overviewMap
-/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql	1246284069	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql
-/home/cbaudson/workspace/trunk/http/classes/class_rss.php	1253194681	0	/home/cbaudson/workspace/trunk/http/classes/class_rss.php
-/home/cbaudson/workspace/trunk/http/classes/class_kml_parser_ows.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_parser_ows.php
-/home/cbaudson/workspace/trunk/http/classes/class_point.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_point.php
-/home/cbaudson/workspace/trunk/http/sld/classes/Displacement.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Displacement.php
-/home/cbaudson/workspace/trunk/http/sld/sld_pick_color.php	1246283960	0	/home/cbaudson/workspace/trunk/http/sld/sld_pick_color.php
-/home/cbaudson/workspace/trunk/http/sld/classes/LineSymbolizer.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/LineSymbolizer.php
-/home/cbaudson/workspace/trunk/lib/saveButton.js	1246284055	0	/home/cbaudson/workspace/trunk/lib/saveButton.js
-/home/cbaudson/workspace/trunk/http/plugins/ol_mousePosition.js	1262789894	1	ol_mousePosition
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/html/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/html/spec.js
-/home/cbaudson/workspace/trunk/http/plugins/ol_panZoomBar.js	1262789894	1	ol_panZoomBar
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/param.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/param.js
-/home/cbaudson/workspace/trunk/http/php/mod_button_tooltips.php	1246283966	0	/home/cbaudson/workspace/trunk/http/php/mod_button_tooltips.php
-/home/cbaudson/workspace/trunk/http/classes/class_weldOverview2PNG.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_weldOverview2PNG.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_coordsLookup.js	1252674785	1	coordsLookup
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/sizzle.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/sizzle.js
-/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql	1246284071	0	/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/sld/classes/Filter.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Filter.php
-/home/cbaudson/workspace/trunk/http/php/mb_validateSession.php	1263903311	0	/home/cbaudson/workspace/trunk/http/php/mb_validateSession.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	1259847974	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql	1246284075	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/php/mod_group_filteredGui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_group_filteredGui.php
-/home/cbaudson/workspace/trunk/log/ReadMe.txt	1250169174	0	/home/cbaudson/workspace/trunk/log/ReadMe.txt
-/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMS.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMS.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/xslt.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/xslt.js
-/home/cbaudson/workspace/trunk/lib/list.js	1263903580	1	List
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/navigator.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/navigator.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/timer/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/timer/boot.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql	1246284075	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	1259847971	0	/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
-/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql	1246284073	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/document.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/document.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/parser/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/parser/boot.js
-/home/cbaudson/workspace/trunk/http/php/mod_editUser.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_editUser.php
-/home/cbaudson/workspace/trunk/http/classes/class_georss_geometry.php	1258987433	0	/home/cbaudson/workspace/trunk/http/classes/class_georss_geometry.php
-/home/cbaudson/workspace/trunk/http/php/mod_showLoggedUser.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_showLoggedUser.php
-/home/cbaudson/workspace/trunk/http/classes/class_kml_polygon.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_polygon.php
-/home/cbaudson/workspace/trunk/lib/alignButton.js	1263903550	0	/home/cbaudson/workspace/trunk/lib/alignButton.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.backup.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.backup.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_cookie.js	1267021306	1	cookie
-/home/cbaudson/workspace/trunk/lib/core.js	1263903586	0	/home/cbaudson/workspace/trunk/lib/core.js
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql	1246284075	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/php/mod_coordsLookup_server.php	1251986996	0	/home/cbaudson/workspace/trunk/http/php/mod_coordsLookup_server.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomOut1.js	1255602947	1	ZoomOut1
-/home/cbaudson/workspace/trunk/http/sld/classes/DisplayOperationModule.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/DisplayOperationModule.php
-/home/cbaudson/workspace/trunk/test/http/classes/MbNoticeTest.php	1255606944	0	/home/cbaudson/workspace/trunk/test/http/classes/MbNoticeTest.php
-/home/cbaudson/workspace/trunk/http/php/mod_digitize_differencePolygon.php	1246283960	0	/home/cbaudson/workspace/trunk/http/php/mod_digitize_differencePolygon.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/vendor/prototype-1.6.0.3.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/vendor/prototype-1.6.0.3.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_3.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_3.js
-/home/cbaudson/workspace/trunk/http/plugins/jq_ui_datepicker.js	1264752979	0	/home/cbaudson/workspace/trunk/http/plugins/jq_ui_datepicker.js
-/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_User.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_User.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/__global__.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/__global__.js
-/home/cbaudson/workspace/trunk/http/print/mod_printPDF_pdf.php	1259847977	0	/home/cbaudson/workspace/trunk/http/print/mod_printPDF_pdf.php
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_1_factory.php	1246284044	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_1_factory.php
-/home/cbaudson/workspace/trunk/http/classes/class.pdf.php	1251986925	0	/home/cbaudson/workspace/trunk/http/classes/class.pdf.php
-/home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php	1262603806	0	/home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php
-/home/cbaudson/workspace/trunk/http/classes/class_administration.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_administration.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_saveWKT.js	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_saveWKT.js
-/home/cbaudson/workspace/trunk/lib/event.js	1267021316	1	Event
-/home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeSliderYear.js	1261043062	1	wmsTimeSliderYear
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/form.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/form.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_saveWmcKml.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_saveWmcKml.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.4_to_2.4.5_pgsql_UTF-8.sql	1258538852	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.4_to_2.4.5_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/php/mod_user_filteredGui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_user_filteredGui.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/window.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/window.js
-/home/cbaudson/workspace/trunk/http/plugins/jq_ui_slider.js	1264753022	0	/home/cbaudson/workspace/trunk/http/plugins/jq_ui_slider.js
-/home/cbaudson/workspace/trunk/http/print/classes/mbPdf.php	1263998515	0	/home/cbaudson/workspace/trunk/http/print/classes/mbPdf.php
-/home/cbaudson/workspace/trunk/http/include/preliminary_logo_splash.php	1261563955	0	/home/cbaudson/workspace/trunk/http/include/preliminary_logo_splash.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/settings.js	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/settings.js
-/home/cbaudson/workspace/trunk/http/javascripts/group.php	1249653424	0	/home/cbaudson/workspace/trunk/http/javascripts/group.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_ResultList.js	1267021307	1	resultList
-/home/cbaudson/workspace/trunk/http/javascripts/mod_dependentIframe.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_dependentIframe.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/fieldset.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/fieldset.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/nu.validator.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/nu.validator.js
-/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_filteredGui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_filteredGui.php
-/home/cbaudson/workspace/trunk/http/plugins/ol_keyboardDefaults.js	1262789894	1	ol_keyboardDefaults
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/profile/profile.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/profile/profile.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/simplelog.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/simplelog.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/variables_0.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/variables_0.js
-/home/cbaudson/workspace/trunk/http/javascripts/popup.js	1257430427	0	/home/cbaudson/workspace/trunk/http/javascripts/popup.js
-/home/cbaudson/workspace/trunk/http/include/gui1_splash.php	1255602884	0	/home/cbaudson/workspace/trunk/http/include/gui1_splash.php
-/home/cbaudson/workspace/trunk/http/javascripts/jq_jgrowl.js	1261488139	1	jq_jgrowl
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/head.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/head.js
-/home/cbaudson/workspace/trunk/http/frames/index.php	1263903619	0	/home/cbaudson/workspace/trunk/http/frames/index.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/dom/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/dom/spec.js
-/home/cbaudson/workspace/trunk/sql/update_wfs_conf_element.sql	1246284046	0	/home/cbaudson/workspace/trunk/sql/update_wfs_conf_element.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/css/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/css/spec.js
-/home/cbaudson/workspace/trunk/tools/update.php	1261402205	0	/home/cbaudson/workspace/trunk/tools/update.php
-/home/cbaudson/workspace/trunk/http/php/mod_digitize_splitLine.php	1263296597	0	/home/cbaudson/workspace/trunk/http/php/mod_digitize_splitLine.php
-/home/cbaudson/workspace/trunk/http/classes/class_gml_point.php	1253605804	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_point.php
-/home/cbaudson/workspace/trunk/http/classes/class_gml_2_factory.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_2_factory.php
-/home/cbaudson/workspace/trunk/resources/db/log_sequences.txt	1246373944	0	/home/cbaudson/workspace/trunk/resources/db/log_sequences.txt
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/function_declarations.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/function_declarations.js
-/home/cbaudson/workspace/trunk/http/classes/class_gml_2.php	1246284044	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_2.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql	1253874941	0	/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/php/mod_editWMS_Metadata.php	1252598016	0	/home/cbaudson/workspace/trunk/http/php/mod_editWMS_Metadata.php
-/home/cbaudson/workspace/trunk/http_auth/http/index.php	1251986234	0	/home/cbaudson/workspace/trunk/http_auth/http/index.php
-/home/cbaudson/workspace/trunk/http/html/mod_treefolder.php	1246283960	0	/home/cbaudson/workspace/trunk/http/html/mod_treefolder.php
-/home/cbaudson/workspace/trunk/http/include/template_splash.php	1255602885	0	/home/cbaudson/workspace/trunk/http/include/template_splash.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_6.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_6.js
-/home/cbaudson/workspace/trunk/http/php/mod_editFilteredGroup.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_editFilteredGroup.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/prototypecompat.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/prototypecompat.js
-/home/cbaudson/workspace/trunk/http/php/mod_editElementVars.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_editElementVars.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js	1261489065	1	mousewheelZoom
-/home/cbaudson/workspace/trunk/http/plugins/jq_ui_accordion.js	1264752984	1	jq_ui_accordion
-/home/cbaudson/workspace/trunk/http/print/classes/mbLegendDecorator.php	1267021310	0	/home/cbaudson/workspace/trunk/http/print/classes/mbLegendDecorator.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/timer.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/timer.js
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_result.php	1255948404	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_result.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_horizTabs.js	1246283985	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_horizTabs.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_setVendorspecific.js	1267021306	0	/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_setVendorspecific.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/element.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/element.js
-/home/cbaudson/workspace/trunk/http/include/dyn_js_object.php	1249379412	0	/home/cbaudson/workspace/trunk/http/include/dyn_js_object.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_transferToDigitize.js	1264752560	1	mb_resultList_transferToDigitize
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/dom.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/dom.js
-/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql	1246284073	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/script_error.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/script_error.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/properties.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/properties.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js
-/home/cbaudson/workspace/trunk/resources/db/log_update.txt	1246373945	0	/home/cbaudson/workspace/trunk/resources/db/log_update.txt
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/attr.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/attr.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/platform/rhino.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/platform/rhino.js
-/home/cbaudson/workspace/trunk/http/php/mod_category_filteredGUI.php	1246283960	0	/home/cbaudson/workspace/trunk/http/php/mod_category_filteredGUI.php
-/home/cbaudson/workspace/trunk/http/php/mod_callMetadata.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_callMetadata.php
-/home/cbaudson/workspace/trunk/http/php/mod_zoomCoords.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_zoomCoords.php
-/home/cbaudson/workspace/trunk/http/javascripts/ConfEditor.js	1255602947	0	/home/cbaudson/workspace/trunk/http/javascripts/ConfEditor.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/legend.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/legend.js
-/home/cbaudson/workspace/trunk/http/sld/classes/Halo.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Halo.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql	1253874941	0	/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/php/mod_showGuiName.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_showGuiName.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/namespace.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/namespace.js
-/home/cbaudson/workspace/trunk/http/sld/sld_parse.php	1246283960	0	/home/cbaudson/workspace/trunk/http/sld/sld_parse.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/processinginstruction.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/processinginstruction.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_legend.js	1257240138	0	/home/cbaudson/workspace/trunk/http/plugins/mb_legend.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_resize.js	1264753809	1	resize
-/home/cbaudson/workspace/trunk/http/print/print_functions.php	1246284035	0	/home/cbaudson/workspace/trunk/http/print/print_functions.php
-/home/cbaudson/workspace/trunk/core/globalSettings.php	1263995829	0	/home/cbaudson/workspace/trunk/core/globalSettings.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/css.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/css.js
-/home/cbaudson/workspace/trunk/http/php/mod_user_filteredGroup.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_user_filteredGroup.php
-/home/cbaudson/workspace/trunk/http/classes/class_gml_3.php	1246284044	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_3.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/blockquote-q.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/blockquote-q.js
-/home/cbaudson/workspace/trunk/http/frames/cleanurl.php	1246284046	0	/home/cbaudson/workspace/trunk/http/frames/cleanurl.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js	1246605598	1	Log
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/test.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/test.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/collection.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/collection.js
-/home/cbaudson/workspace/trunk/http/classes/class_georss.php	1253189338	0	/home/cbaudson/workspace/trunk/http/classes/class_georss.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/html.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/html.js
-/home/cbaudson/workspace/trunk/http/sld/classes/GraphicFill.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/GraphicFill.php
-/home/cbaudson/workspace/trunk/http/sld/classes/ElseFilter.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/ElseFilter.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/changelog.txt	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/changelog.txt
-/home/cbaudson/workspace/trunk/http/php/mod_gui_filteredGroup.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gui_filteredGroup.php
-/home/cbaudson/workspace/trunk/http/javascripts/ConfObject.js	1249653447	0	/home/cbaudson/workspace/trunk/http/javascripts/ConfObject.js
-/home/cbaudson/workspace/trunk/http/php/mod_group_filteredUser.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_group_filteredUser.php
-/home/cbaudson/workspace/trunk/owsproxy/http/index.php	1251896391	0	/home/cbaudson/workspace/trunk/owsproxy/http/index.php
-/home/cbaudson/workspace/trunk/http/php/mod_savewmc_server.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_savewmc_server.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/string_declarations.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/string_declarations.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.3.2-test.js	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.3.2-test.js
-/home/cbaudson/workspace/trunk/http/sld/classes/Font.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Font.php
-/home/cbaudson/workspace/trunk/http/classes/class_metadata_new.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_metadata_new.php
+JavaScript
+/home/cbaudson/workspace/trunk/lib/history.js	1257779030	0	/home/cbaudson/workspace/trunk/lib/history.js
+/home/cbaudson/workspace/trunk/lib/point.js	1263903572	1	Point
+/home/cbaudson/workspace/trunk/lib/class_Mapbender.php	1247654252	0	/home/cbaudson/workspace/trunk/lib/class_Mapbender.php
 /home/cbaudson/workspace/trunk/lib/printbox.js	1264003357	0	/home/cbaudson/workspace/trunk/lib/printbox.js
-/home/cbaudson/workspace/trunk/http/classes/class_universal_gml_factory.php	1262789163	0	/home/cbaudson/workspace/trunk/http/classes/class_universal_gml_factory.php
 /home/cbaudson/workspace/trunk/lib/ajax.js	1263903566	1	Ajax
-/home/cbaudson/workspace/trunk/http/sld/classes/UnaryLogicOp.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/UnaryLogicOp.php
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_1.php	1253605983	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_1.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/title.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/title.js
-/home/cbaudson/workspace/trunk/license/simplified_bsd.txt	1246284047	0	/home/cbaudson/workspace/trunk/license/simplified_bsd.txt
-/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_write.php	1249473920	0	/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_write.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/entity.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/entity.js
-/home/cbaudson/workspace/trunk/http/php/mod_editSelf.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_editSelf.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_history_back.js	1257780613	0	/home/cbaudson/workspace/trunk/http/plugins/mb_history_back.js
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql	1246284075	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/frame.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/frame.js
-/home/cbaudson/workspace/trunk/Install.txt	1263995835	0	/home/cbaudson/workspace/trunk/Install.txt
-/home/cbaudson/workspace/trunk/http/include/dyn_js.php	1246283960	0	/home/cbaudson/workspace/trunk/http/include/dyn_js.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/__global__.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php	1264003337	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/console/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/console/spec.js
-/home/cbaudson/workspace/trunk/http/frames/login.php	1256112146	0	/home/cbaudson/workspace/trunk/http/frames/login.php
-/home/cbaudson/workspace/trunk/http/sld/sld_main.php	1246283960	0	/home/cbaudson/workspace/trunk/http/sld/sld_main.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_setTimeout.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_setTimeout.php
-/home/cbaudson/workspace/trunk/http/php/mod_gazetteer_conf.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gazetteer_conf.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_displayWmc.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_displayWmc.php
-/home/cbaudson/workspace/trunk/http/php/mod_updateKmlInDb.php	1253705934	0	/home/cbaudson/workspace/trunk/http/php/mod_updateKmlInDb.php
-/home/cbaudson/workspace/trunk/lib/class_Mapbender_session.php	1267021316	0	/home/cbaudson/workspace/trunk/lib/class_Mapbender_session.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/map.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/map.js
-/home/cbaudson/workspace/trunk/test/tools/testframework.js	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/testframework.js
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_configuration.php	1259847969	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_configuration.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_digitize_tab.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_digitize_tab.php
-/home/cbaudson/workspace/trunk/http/php/mod_group_gui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_group_gui.php
-/home/cbaudson/workspace/trunk/http/javascripts/map.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/map.php
-/home/cbaudson/workspace/trunk/http/print/printPDF_download.php	1267021310	0	/home/cbaudson/workspace/trunk/http/print/printPDF_download.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/xhr.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/xhr.js
-/home/cbaudson/workspace/trunk/http/classes/class_wfsToDb.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_wfsToDb.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_i18n.js	1263395373	1	i18n
-/home/cbaudson/workspace/trunk/http/javascripts/mod_coords_div.php	1253875315	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_coords_div.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/option.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/option.js
-/home/cbaudson/workspace/trunk/http/php/output.txt	1249476135	0	/home/cbaudson/workspace/trunk/http/php/output.txt
-/home/cbaudson/workspace/trunk/http/javascripts/mod_perimeter.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_perimeter.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/script.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/script.js
-/home/cbaudson/workspace/trunk/http/classes/class_kml_placemark.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_placemark.php
-/home/cbaudson/workspace/trunk/http/sld/classes/LegendGraphic.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/LegendGraphic.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_loadKML.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_loadKML.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_group.js	1255602947	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_group.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/element.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/element.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/xmlhttprequest.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/xmlhttprequest.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_CSWFunctions.js	1261565985	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_CSWFunctions.js
-/home/cbaudson/workspace/trunk/http/javascripts/send_post.php	1246284046	0	/home/cbaudson/workspace/trunk/http/javascripts/send_post.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xmltoken_unittest.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xmltoken_unittest.js
-/home/cbaudson/workspace/trunk/http/classes/class_kml_linearring.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_linearring.php
-/home/cbaudson/workspace/trunk/http/classes/class_locale.php	1256902107	0	/home/cbaudson/workspace/trunk/http/classes/class_locale.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/input-elements.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/input-elements.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/div.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/div.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_zoomIn.js	1257239887	1	mb_zoomIn
-/home/cbaudson/workspace/trunk/http/javascripts/mod_displayObj.js	1247730584	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_displayObj.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_legend.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_legend.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_mapstraction.js	1263824738	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_mapstraction.js
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_server.php	1253705999	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_server.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/frame.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/frame.js
-/home/cbaudson/workspace/trunk/http/php/mod_customTree.php	1258120186	0	/home/cbaudson/workspace/trunk/http/php/mod_customTree.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql	1246284071	0	/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/php/mod_gazLayerObj_conf.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gazLayerObj_conf.php
-/home/cbaudson/workspace/trunk/http/classes/class_mb_log.php	1257521428	0	/home/cbaudson/workspace/trunk/http/classes/class_mb_log.php
-/home/cbaudson/workspace/trunk/http/classes/class_rss_item.php	1253192526	0	/home/cbaudson/workspace/trunk/http/classes/class_rss_item.php
-/home/cbaudson/workspace/trunk/http/javascripts/wfs.php	1263288120	0	/home/cbaudson/workspace/trunk/http/javascripts/wfs.php
-/home/cbaudson/workspace/trunk/http/plugins/jq_upload.js	1267021306	0	/home/cbaudson/workspace/trunk/http/plugins/jq_upload.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/canvas.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/canvas.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/events.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/events.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/timer/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/timer/__global__.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php
-/home/cbaudson/workspace/trunk/http/php/mb_listKMLs.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mb_listKMLs.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/prototype-test.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/prototype-test.js
-/home/cbaudson/workspace/trunk/http/php/mod_featuretypeMetadata.php	1246283960	0	/home/cbaudson/workspace/trunk/http/php/mod_featuretypeMetadata.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/__global__.js
-/home/cbaudson/workspace/trunk/http/php/mod_loadwmc_server.php	1258104820	0	/home/cbaudson/workspace/trunk/http/php/mod_loadwmc_server.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/__global__.js
-/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql	1246284073	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/http/php/mod_editApplication.php	1253875137	0	/home/cbaudson/workspace/trunk/http/php/mod_editApplication.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/window.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/window.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js	1251460890	1	AddWmsFromTree
-/home/cbaudson/workspace/trunk/http/php/mod_echoFileUpload.php	1260280340	0	/home/cbaudson/workspace/trunk/http/php/mod_echoFileUpload.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php	1257420068	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php
-/home/cbaudson/workspace/trunk/http/javascripts/gui.php	1249653444	0	/home/cbaudson/workspace/trunk/http/javascripts/gui.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql	1255606925	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/col-colgroup.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/col-colgroup.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/keyboardevents.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/keyboardevents.js
-/home/cbaudson/workspace/trunk/test/http/classes/GroupTest.php	1255606944	0	/home/cbaudson/workspace/trunk/test/http/classes/GroupTest.php
-/home/cbaudson/workspace/trunk/http/php/mod_log.php	1246636499	0	/home/cbaudson/workspace/trunk/http/php/mod_log.php
-/home/cbaudson/workspace/trunk/http/sld/classes/Mark.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Mark.php
-/home/cbaudson/workspace/trunk/http/html/mod_sync_treefolder.php	1246283960	0	/home/cbaudson/workspace/trunk/http/html/mod_sync_treefolder.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/link.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/link.js
-/home/cbaudson/workspace/trunk/http/php/mod_treefolder2_l10n.php	1257425334	0	/home/cbaudson/workspace/trunk/http/php/mod_treefolder2_l10n.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/mouseevent.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/mouseevent.js
-/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_User.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_User.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Proxy.java	1267021291	0	/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Proxy.java
-/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_PrintPreview.js	1260538909	0	/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_PrintPreview.js
-/home/cbaudson/workspace/trunk/http/sld/classes/CssParameter.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/CssParameter.php
-/home/cbaudson/workspace/trunk/http/sld/sld_config.php	1246283960	0	/home/cbaudson/workspace/trunk/http/sld/sld_config.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_overview.js	1263996078	1	Overview
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/namednodemap.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/namednodemap.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/env.qunit.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/env.qunit.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php	1247660161	1	repaint
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/xhr.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/xhr.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_map.js	1267021306	1	mapframe1
-/home/cbaudson/workspace/trunk/http/sld/classes/Fill.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Fill.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/cdatasection.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/cdatasection.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/qunit/qunit/qunit.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/qunit/qunit/qunit.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_poi.php	1256661476	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_poi.php
-/home/cbaudson/workspace/trunk/http/sld/classes/ColorMap.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/ColorMap.php
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_gazetteer_l10n.php	1257424605	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_gazetteer_l10n.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_2.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_2.js
-/home/cbaudson/workspace/trunk/http/classes/class_kml.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/licenses/GPL-LICENSE.txt	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/licenses/GPL-LICENSE.txt
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_0_factory.php	1246284044	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_0_factory.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/input.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/input.js
-/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilities_temp.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilities_temp.php
-/home/cbaudson/workspace/trunk/http/print/classes/mbTextDecorator.php	1267021310	0	/home/cbaudson/workspace/trunk/http/print/classes/mbTextDecorator.php
-/home/cbaudson/workspace/trunk/http/print/classes/factoryClasses.php	1263998514	0	/home/cbaudson/workspace/trunk/http/print/classes/factoryClasses.php
-/home/cbaudson/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php
-/home/cbaudson/workspace/trunk/http/php/mod_meetingPoint.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_meetingPoint.php
-/home/cbaudson/workspace/trunk/http/sld/classes/ColorMapEntry.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/ColorMapEntry.php
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_featuretype.php	1246284044	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_featuretype.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/html.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/html.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_navFrame.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_navFrame.php
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_server.php	1246283963	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_server.php
-/home/cbaudson/workspace/trunk/http/php/mod_loadCatalog.php	1261565744	0	/home/cbaudson/workspace/trunk/http/php/mod_loadCatalog.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_horizTab.php	1246283976	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_horizTab.php
-/home/cbaudson/workspace/trunk/http/classes/class_user.php	1258530375	0	/home/cbaudson/workspace/trunk/http/classes/class_user.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/unknown.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/unknown.js
-/home/cbaudson/workspace/trunk/http/html/mod_treefolder2_multiple.php	1246355465	0	/home/cbaudson/workspace/trunk/http/html/mod_treefolder2_multiple.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__setArray__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__setArray__.js
-/home/cbaudson/workspace/trunk/http/php/mod_treefolderAdmin.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_treefolderAdmin.php
-/home/cbaudson/workspace/trunk/test/http/classes/GeoRssFactoryTest.php	1255606944	0	/home/cbaudson/workspace/trunk/test/http/classes/GeoRssFactoryTest.php
-/home/cbaudson/workspace/trunk/http/php/mod_logout.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_logout.php
-/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_main.php	1249474917	0	/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_main.php
-/home/cbaudson/workspace/trunk/http/sld/classes/AnchorPoint.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/AnchorPoint.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.js	1255602946	1	ZoomIn1
-/home/cbaudson/workspace/trunk/http/javascripts/mod_dependentDiv.php	1264003344	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_dependentDiv.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_permanentHighlight.js	1258639767	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_permanentHighlight.js
-/home/cbaudson/workspace/trunk/http/print/mod_printPDF.php	1263995547	0	/home/cbaudson/workspace/trunk/http/print/mod_printPDF.php
-/home/cbaudson/workspace/trunk/http/classes/class_json.php	1263903604	0	/home/cbaudson/workspace/trunk/http/classes/class_json.php
-/home/cbaudson/workspace/trunk/http/classes/class_gml_3_factory.php	1263903601	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_3_factory.php
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_factory.php	1247648164	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_factory.php
-/home/cbaudson/workspace/trunk/http/php/mod_searchCatQueryBuilder_server.php	1261565743	0	/home/cbaudson/workspace/trunk/http/php/mod_searchCatQueryBuilder_server.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/comment.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/comment.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/window/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/window/boot.js
-/home/cbaudson/workspace/trunk/lib/database-mysql.php	1262704275	0	/home/cbaudson/workspace/trunk/lib/database-mysql.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_key.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_key.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/tr.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/tr.js
-/home/cbaudson/workspace/trunk/http/php/mod_editGroup.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_editGroup.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/p.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/p.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/domimplementation.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/domimplementation.js
-/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	1246284073	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql	1246284071	0	/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql
-/home/cbaudson/workspace/trunk/http/classes/class_gml_geometry.php	1263903605	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_geometry.php
-/home/cbaudson/workspace/trunk/http/php/mod_loadwms_temp.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_loadwms_temp.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/platform/rhino.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/platform/rhino.js
-/home/cbaudson/workspace/trunk/http/sld/classes/ExternalGraphic.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/ExternalGraphic.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/timer.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/timer.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js	1247750208	1	scalebar
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_deprecated.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_deprecated.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/parser.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/parser.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_user.js	1255602947	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_user.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/style.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/style.js
-/home/cbaudson/workspace/trunk/http/classes/class_SaveLegend.php	1258548780	0	/home/cbaudson/workspace/trunk/http/classes/class_SaveLegend.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_loadwmc.php	1257521749	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_loadwmc.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/eventexception.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/eventexception.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xpathdebug.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xpathdebug.js
-/home/cbaudson/workspace/trunk/lib/buttonNew.js	1246284053	0	/home/cbaudson/workspace/trunk/lib/buttonNew.js
-/home/cbaudson/workspace/trunk/tools/char_code.php	1246284046	0	/home/cbaudson/workspace/trunk/tools/char_code.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/styledeclaration.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/styledeclaration.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js	1261489062	1	doubleclickZoom
-/home/cbaudson/workspace/trunk/http/javascripts/wfsFilter.js	1246283980	0	/home/cbaudson/workspace/trunk/http/javascripts/wfsFilter.js
-/home/cbaudson/workspace/trunk/http/classes/class_rss_factory.php	1253194155	0	/home/cbaudson/workspace/trunk/http/classes/class_rss_factory.php
-/home/cbaudson/workspace/trunk/core/system.php	1262618528	0	/home/cbaudson/workspace/trunk/core/system.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_DetailPopup.js	1267021306	0	/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_DetailPopup.js
-/home/cbaudson/workspace/trunk/http/classes/class_log.php	1246636499	0	/home/cbaudson/workspace/trunk/http/classes/class_log.php
-/home/cbaudson/workspace/trunk/http/plugins/ol.js	1262789894	1	ol
-/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js	1262789244	1	ResizeMapsize
-/home/cbaudson/workspace/trunk/http/php/mod_evalArea.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_evalArea.php
-/home/cbaudson/workspace/trunk/http/php/mb_validatePermission.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mb_validatePermission.php
-/home/cbaudson/workspace/trunk/http/print/classes/mbMapDecorator.php	1267021310	0	/home/cbaudson/workspace/trunk/http/print/classes/mbMapDecorator.php
-/home/cbaudson/workspace/trunk/http/php/mod_gui_filteredUser.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gui_filteredUser.php
-/home/cbaudson/workspace/trunk/http/classes/class_gml_feature.php	1264687497	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_feature.php
-/home/cbaudson/workspace/trunk/http/php/mod_exportGUI.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_exportGUI.php
-/home/cbaudson/workspace/trunk/http/sld/classes/PolygonSymbolizer.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/PolygonSymbolizer.php
-/home/cbaudson/workspace/trunk/http/classes/class_cswrecord.php	1261564131	0	/home/cbaudson/workspace/trunk/http/classes/class_cswrecord.php
-/home/cbaudson/workspace/trunk/http/sld/classes/ParameterValue.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/ParameterValue.php
-/home/cbaudson/workspace/trunk/http/sld/classes/BinaryLogicOp.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/BinaryLogicOp.php
-/home/cbaudson/workspace/trunk/http/php/mod_editFilteredUser.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_editFilteredUser.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/xhr/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/xhr/boot.js
-/home/cbaudson/workspace/trunk/http/php/kmldownload.php	1257413692	0	/home/cbaudson/workspace/trunk/http/php/kmldownload.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/timer/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/timer/spec.js
-/home/cbaudson/workspace/trunk/http/php/mod_changeEPSG_dynamic.php	1246460709	0	/home/cbaudson/workspace/trunk/http/php/mod_changeEPSG_dynamic.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.4.1-test.js	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.4.1-test.js
-/home/cbaudson/workspace/trunk/lib/extent.js	1263903576	1	Extent
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/documenttype.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/documenttype.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_export_image.php	1246460709	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_export_image.php
-/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2PNG.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2PNG.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/__global__.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/__global__.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php
-/home/cbaudson/workspace/trunk/http/javascripts/jsTree.js	1259141740	0	/home/cbaudson/workspace/trunk/http/javascripts/jsTree.js
-/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql	1246284070	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/document.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/document.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/mutationevent.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/mutationevent.js
-/home/cbaudson/workspace/trunk/http/classes/class_map.php	1263996069	0	/home/cbaudson/workspace/trunk/http/classes/class_map.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.js
-/home/cbaudson/workspace/trunk/lib/resultGeometryListModel.js	1263903563	1	ResultGeometryListModel
-/home/cbaudson/workspace/trunk/http/javascripts/mod_treeConf.js	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_treeConf.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/licenses/MIT-LICENSE.txt	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/licenses/MIT-LICENSE.txt
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/test.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/test.js
-/home/cbaudson/workspace/trunk/http/php/mod_map_messages.php	1255429345	0	/home/cbaudson/workspace/trunk/http/php/mod_map_messages.php
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf.php	1253875191	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf.php
-/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_Gui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_Gui.php
-/home/cbaudson/workspace/trunk/http/php/mb_getGUIs.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mb_getGUIs.php
-/home/cbaudson/workspace/trunk/test/http/classes/MbWarningTest.php	1255606944	0	/home/cbaudson/workspace/trunk/test/http/classes/MbWarningTest.php
-/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php
-/home/cbaudson/workspace/trunk/tools/url_code.php	1246284046	0	/home/cbaudson/workspace/trunk/tools/url_code.php
-/home/cbaudson/workspace/trunk/http/classes/class_kml_ows.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_ows.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_add_vendorspecific.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_add_vendorspecific.php
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_0.php	1246284039	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_0.php
-/home/cbaudson/workspace/trunk/tools/mapFiler.php	1246284046	0	/home/cbaudson/workspace/trunk/tools/mapFiler.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql	1267021391	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/area.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/area.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_twitter.php	1267021306	0	/home/cbaudson/workspace/trunk/http/plugins/mb_twitter.php
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php
-/home/cbaudson/workspace/trunk/http/php/mod_exportMapImage_server.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_exportMapImage_server.php
-/home/cbaudson/workspace/trunk/http/php/mod_loadwfs.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_loadwfs.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/htmlelement.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/htmlelement.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/parser/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/parser/spec.js
-/home/cbaudson/workspace/trunk/lib/class_Monitor.php	1249479917	0	/home/cbaudson/workspace/trunk/lib/class_Monitor.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/multi-window.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/multi-window.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_cardindex.js	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_cardindex.js
-/home/cbaudson/workspace/trunk/http/php/mod_wfsLayerObj_conf.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_wfsLayerObj_conf.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_tab.php	1257242696	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_tab.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/cookie.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/cookie.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfo.php	1264003360	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfo.php
-/home/cbaudson/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php	1251880844	0	/home/cbaudson/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/env.rhino.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/env.rhino.js
-/home/cbaudson/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php	1256112846	0	/home/cbaudson/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php
-/home/cbaudson/workspace/trunk/http/include/gui1_splash_jquery.php	1261565993	0	/home/cbaudson/workspace/trunk/http/include/gui1_splash_jquery.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_wps_client.js	1258538846	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_wps_client.js
-/home/cbaudson/workspace/trunk/http/php/mb_listGUIs.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mb_listGUIs.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_savewmc.js	1267021307	1	savewmc
-/home/cbaudson/workspace/trunk/http/php/createImageFromText.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/createImageFromText.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_admin.js	1249653442	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_admin.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/html/script.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/html/script.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php
-/home/cbaudson/workspace/trunk/http/php/mod_createUser.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_createUser.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_box1.js	1257759489	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_box1.js
-/home/cbaudson/workspace/trunk/http/classes/class_weldOverview2PNG_rotate.php	1263996069	0	/home/cbaudson/workspace/trunk/http/classes/class_weldOverview2PNG_rotate.php
-/home/cbaudson/workspace/trunk/http/php/mod_gazetteerSQL_server.php	1246283968	0	/home/cbaudson/workspace/trunk/http/php/mod_gazetteerSQL_server.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8.sql	1267021391	1	inspire_md_data
-/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php	1255602947	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/util.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/util.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/range.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/range.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_embedded_legend.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_embedded_legend.php
-/home/cbaudson/workspace/trunk/http/php/mod_editGuiWms.php	1252598015	0	/home/cbaudson/workspace/trunk/http/php/mod_editGuiWms.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/img.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/img.js
-/home/cbaudson/workspace/trunk/http/classes/class_gml_multiline.php	1253605792	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_multiline.php
-/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2PNG_rotate.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2PNG_rotate.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/expression.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/expression.js
-/home/cbaudson/workspace/trunk/http/php/mb_js_exception.php	1246283963	0	/home/cbaudson/workspace/trunk/http/php/mb_js_exception.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/dom.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/dom.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php	1256902561	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php
-/home/cbaudson/workspace/trunk/http/php/mod_updateWMS.php	1249480531	0	/home/cbaudson/workspace/trunk/http/php/mod_updateWMS.php
-/home/cbaudson/workspace/trunk/http/php/mod_loadCatalogCapabilities.php	1262789903	0	/home/cbaudson/workspace/trunk/http/php/mod_loadCatalogCapabilities.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/location.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/location.js
-/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_defineGetMapBbox.php	1248852611	0	/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_defineGetMapBbox.php
-/home/cbaudson/workspace/trunk/lib/class_Mapbender.php	1247654252	0	/home/cbaudson/workspace/trunk/lib/class_Mapbender.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/select.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/select.js
-/home/cbaudson/workspace/trunk/http/classes/class_georss_item.php	1253112961	0	/home/cbaudson/workspace/trunk/http/classes/class_georss_item.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/domexception.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/domexception.js
-/home/cbaudson/workspace/trunk/http/php/mod_user_gui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_user_gui.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_loadwmc.js	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_loadwmc.js
-/home/cbaudson/workspace/trunk/http/print/classes/mbOverviewDecorator.php	1263998515	0	/home/cbaudson/workspace/trunk/http/print/classes/mbOverviewDecorator.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleSel.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleSel.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/implementation.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/implementation.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_setBackground_all.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_setBackground_all.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/nodelist.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/nodelist.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/timer/timer.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/timer/timer.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_admin.php	1257421166	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_admin.php
-/home/cbaudson/workspace/trunk/http/sld/classes/Rule.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Rule.php
-/home/cbaudson/workspace/trunk/http/javascripts/map.js	1252502888	0	/home/cbaudson/workspace/trunk/http/javascripts/map.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/css/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/css/boot.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_1.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_1.js
-/home/cbaudson/workspace/trunk/test/http/classes/MapTest.php	1255606944	0	/home/cbaudson/workspace/trunk/test/http/classes/MapTest.php
-/home/cbaudson/workspace/trunk/http/php/mod_treefolderClient.php	1259847973	0	/home/cbaudson/workspace/trunk/http/php/mod_treefolderClient.php
-/home/cbaudson/workspace/trunk/http/html/mod_treefolder2.php	1246374828	0	/home/cbaudson/workspace/trunk/http/html/mod_treefolder2.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/dom.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/dom.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/documentevent.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/documentevent.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_adminNavigation.js	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_adminNavigation.js
 /home/cbaudson/workspace/trunk/lib/customTreeController.js	1259164236	0	/home/cbaudson/workspace/trunk/lib/customTreeController.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/scope.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/scope.js
-/home/cbaudson/workspace/trunk/http/php/mod_owsproxy_conf.php	1251896391	0	/home/cbaudson/workspace/trunk/http/php/mod_owsproxy_conf.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/debug.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/debug.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_twitter_update.js	1267021306	0	/home/cbaudson/workspace/trunk/http/plugins/mb_twitter_update.js
-/home/cbaudson/workspace/trunk/http/classes/class_weldLegend2PNG.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_weldLegend2PNG.php
-/home/cbaudson/workspace/trunk/http/php/mod_tab_messages.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_tab_messages.php
-/home/cbaudson/workspace/trunk/license/license_js.txt	1246284047	0	/home/cbaudson/workspace/trunk/license/license_js.txt
-/home/cbaudson/workspace/trunk/http/javascripts/mod_selectMapsize.php	1251987659	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_selectMapsize.php
-/home/cbaudson/workspace/trunk/http/javascripts/requestGeometryConstructor.js	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/requestGeometryConstructor.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/__global__.js
-/home/cbaudson/workspace/trunk/http/php/mod_printView1.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_printView1.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_4.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_4.js
-/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql	1246284075	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/dom.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/dom.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_selArea.js	1267021307	1	selArea
-/home/cbaudson/workspace/trunk/http/classes/class_wfs_conf.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_wfs_conf.php
-/home/cbaudson/workspace/trunk/http/sld/classes/Stroke.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Stroke.php
-/home/cbaudson/workspace/trunk/http/php/mod_gazetteerMetadata.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_gazetteerMetadata.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/console/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/console/__global__.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/external_script.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/external_script.js
-/home/cbaudson/workspace/trunk/http/javascripts/jq_ui_effects.php	1261486956	1	jq_ui_effects
-/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/HtmlParser.java	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/HtmlParser.java
-/home/cbaudson/workspace/trunk/test/http/classes/RssTest.php	1255606944	0	/home/cbaudson/workspace/trunk/test/http/classes/RssTest.php
-/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_interface.js	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_interface.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/__global__.js
-/home/cbaudson/workspace/trunk/http/php/mod_exportElement.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_exportElement.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/script.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/script.js
-/home/cbaudson/workspace/trunk/http/php/mod_digitize_mergePolygon.php	1253875191	0	/home/cbaudson/workspace/trunk/http/php/mod_digitize_mergePolygon.php
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/event/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/event/spec.js
-/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php
-/home/cbaudson/workspace/trunk/lib/backwards_compatibility_to_2.6.js	1263903553	0	/home/cbaudson/workspace/trunk/lib/backwards_compatibility_to_2.6.js
-/home/cbaudson/workspace/trunk/lib/ajax.php	1253706015	0	/home/cbaudson/workspace/trunk/lib/ajax.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js	1247659724	1	zoomFull
-/home/cbaudson/workspace/trunk/http/php/mod_deleteWMS.php	1256039728	0	/home/cbaudson/workspace/trunk/http/php/mod_deleteWMS.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/dom/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/dom/boot.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/platform/core.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/platform/core.js
-/home/cbaudson/workspace/trunk/http/classes/class_kml_point.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_point.php
-/home/cbaudson/workspace/trunk/http/php/mod_filteredWms_layer_topic.php	1246283968	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredWms_layer_topic.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/variable_declarations.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/variable_declarations.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php
-/home/cbaudson/workspace/trunk/http/php/mod_changeEPSG_server.php	1251469148	0	/home/cbaudson/workspace/trunk/http/php/mod_changeEPSG_server.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_2.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_2.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/HtmlParserModule.java	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/HtmlParserModule.java
-/home/cbaudson/workspace/trunk/tools/send_post_curl.php	1246284046	0	/home/cbaudson/workspace/trunk/tools/send_post_curl.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/textarea.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/textarea.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/implementation.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/implementation.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/parser.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/parser.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/event.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/event.js
-/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js	1261565712	1	/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_navigation.js	1263824798	1	mb_navigation
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/mysql_gettext.sql	1246284071	0	/home/cbaudson/workspace/trunk/resources/db/mysql/mysql_gettext.sql
-/home/cbaudson/workspace/trunk/resources/db/log_data.txt	1246373944	0	/home/cbaudson/workspace/trunk/resources/db/log_data.txt
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/console.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/console.js
-/home/cbaudson/workspace/trunk/lib/history.js	1257779030	0	/home/cbaudson/workspace/trunk/lib/history.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/notation.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/notation.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_home.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_home.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_setPOI2Scale.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_setPOI2Scale.php
-/home/cbaudson/workspace/trunk/http/classes/class_group.php	1255602724	0	/home/cbaudson/workspace/trunk/http/classes/class_group.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/tbody-thead-tfoot.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/tbody-thead-tfoot.js
-/home/cbaudson/workspace/trunk/http/classes/class_gml_line.php	1253605785	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_line.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql	1253874941	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/http/javascripts/mod_measure.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_measure.php
+/home/cbaudson/workspace/trunk/lib/resizableButton.js	1246284050	0	/home/cbaudson/workspace/trunk/lib/resizableButton.js
+/home/cbaudson/workspace/trunk/lib/resultGeometryListModel.js	1263903563	1	ResultGeometryListModel
+/home/cbaudson/workspace/trunk/lib/exception.js	1263903557	1	Exception
+/home/cbaudson/workspace/trunk/lib/database-mysql.php	1262704275	0	/home/cbaudson/workspace/trunk/lib/database-mysql.php
 /home/cbaudson/workspace/trunk/lib/class_Singleton.php	1246284057	0	/home/cbaudson/workspace/trunk/lib/class_Singleton.php
 /home/cbaudson/workspace/trunk/lib/div.js	1263903589	0	/home/cbaudson/workspace/trunk/lib/div.js
-/home/cbaudson/workspace/trunk/http/classes/class_wmcToXml.php	1255592147	0	/home/cbaudson/workspace/trunk/http/classes/class_wmcToXml.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_highlightPOI.php	1261493348	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_highlightPOI.php
-/home/cbaudson/workspace/trunk/http/php/mod_zoomCoords_en.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_zoomCoords_en.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/console.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/console.js
-/home/cbaudson/workspace/trunk/http/php/mod_gui_user.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gui_user.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/event.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/event.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_add_SLD.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_add_SLD.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/frameset.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/frameset.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_pan.js	1258644177	1	selArea
-/home/cbaudson/workspace/trunk/http/plugins/mb_i18n_server.php	1258554838	0	/home/cbaudson/workspace/trunk/http/plugins/mb_i18n_server.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/profile.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/profile.js
-/home/cbaudson/workspace/trunk/http/classes/class_gml_feature_collection.php	1246284035	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_feature_collection.php
-/home/cbaudson/workspace/trunk/http/php/mb_validateInput.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mb_validateInput.php
-/home/cbaudson/workspace/trunk/http/sld/classes/Graphic.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/Graphic.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_georss.php	1259154665	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_georss.php
-/home/cbaudson/workspace/trunk/http/php/mod_SelectKeyword.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_SelectKeyword.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_renderGML.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_renderGML.php
-/home/cbaudson/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php	1246283966	0	/home/cbaudson/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/__global__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/__global__.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.2.6-test.js	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.2.6-test.js
-/home/cbaudson/workspace/trunk/test/http/classes/UserTest.php	1255606944	0	/home/cbaudson/workspace/trunk/test/http/classes/UserTest.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_zoomOut.js	1257239892	1	mb_zoomOut
-/home/cbaudson/workspace/trunk/http/javascripts/mod_copyright.php	1263995844	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_copyright.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_print1.php	1246460709	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_print1.php
-/home/cbaudson/workspace/trunk/http/classes/class.ezpdf.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class.ezpdf.php
-/home/cbaudson/workspace/trunk/http/classes/class_keyword.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_keyword.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__trim__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__trim__.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/meta.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/meta.js
-/home/cbaudson/workspace/trunk/http/php/mod_deleteFilteredGUI.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_deleteFilteredGUI.php
 /home/cbaudson/workspace/trunk/lib/selectableButton.js	1267021316	0	/home/cbaudson/workspace/trunk/lib/selectableButton.js
-/home/cbaudson/workspace/trunk/sql/insert_wfs_conf_element.sql	1246284046	0	/home/cbaudson/workspace/trunk/sql/insert_wfs_conf_element.sql
-/home/cbaudson/workspace/trunk/http/classes/class_kml_geometry.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_geometry.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql	1246284075	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql
-/home/cbaudson/workspace/trunk/http/sld/classes/NamedLayer.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/NamedLayer.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SaveAsFile.js	1260538899	0	/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SaveAsFile.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/base.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/base.js
-/home/cbaudson/workspace/trunk/http/javascripts/usemap.js	1259154025	0	/home/cbaudson/workspace/trunk/http/javascripts/usemap.js
-/home/cbaudson/workspace/trunk/http/php/mod_usemap.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_usemap.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.3.1-test.js	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.3.1-test.js
-/home/cbaudson/workspace/trunk/http/classes/class_universal_wfs_factory.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/class_universal_wfs_factory.php
+/home/cbaudson/workspace/trunk/lib/ajax.php	1253706015	0	/home/cbaudson/workspace/trunk/lib/ajax.php
+/home/cbaudson/workspace/trunk/lib/backwards_compatibility_to_2.6.js	1263903553	0	/home/cbaudson/workspace/trunk/lib/backwards_compatibility_to_2.6.js
 /home/cbaudson/workspace/trunk/lib/database-pgsql.php	1253874628	0	/home/cbaudson/workspace/trunk/lib/database-pgsql.php
-/home/cbaudson/workspace/trunk/http/php/mod_wfs.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_wfs.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/stylesheet.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/stylesheet.js
+/home/cbaudson/workspace/trunk/lib/database-mysqli.php	1253874627	0	/home/cbaudson/workspace/trunk/lib/database-mysqli.php
 /home/cbaudson/workspace/trunk/lib/draggableButton.js	1267021316	0	/home/cbaudson/workspace/trunk/lib/draggableButton.js
-/home/cbaudson/workspace/trunk/http/php/mod_edit_metadata.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_edit_metadata.php
-/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsNull.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsNull.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/__global__.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/__global__.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/td-th.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/td-th.js
-/home/cbaudson/workspace/trunk/http/sld/classes/BinaryComparisonOp.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/BinaryComparisonOp.php
-/home/cbaudson/workspace/trunk/http/classes/class_stripRequest.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_stripRequest.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Window.java	1267021291	0	/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Window.java
-/home/cbaudson/workspace/trunk/http/sld/classes/AddOperationModule.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/AddOperationModule.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/frame/proxy.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/frame/proxy.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xslt_unittest.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xslt_unittest.js
-/home/cbaudson/workspace/trunk/http/img/button_blue/README.TXT	1246284021	0	/home/cbaudson/workspace/trunk/http/img/button_blue/README.TXT
-/home/cbaudson/workspace/trunk/lib/point.js	1263903572	1	Point
-/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_Group.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_Group.php
-/home/cbaudson/workspace/trunk/http/html/mod_treefolderPlain.php	1267021310	0	/home/cbaudson/workspace/trunk/http/html/mod_treefolderPlain.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql	1246284071	0	/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/node.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/node.js
-/home/cbaudson/workspace/trunk/http/classes/class_gml_factory.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_factory.php
-/home/cbaudson/workspace/trunk/http/php/mod_wmc2ol.php	1255603052	0	/home/cbaudson/workspace/trunk/http/php/mod_wmc2ol.php
-/home/cbaudson/workspace/trunk/http/classes/class_mb_notice.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_mb_notice.php
-/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_Gui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_Gui.php
-/home/cbaudson/workspace/trunk/http/php/mod_gazetteer_edit.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gazetteer_edit.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_setBBOX1.php	1253875660	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_setBBOX1.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/html.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/html.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/env.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/env.js
-/home/cbaudson/workspace/trunk/http/php/mod_edit_element_vars.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_edit_element_vars.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/screen.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/screen.js
-/home/cbaudson/workspace/trunk/http/php/mod_export_image.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_export_image.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/prototypes.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/prototypes.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/del-ins.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/del-ins.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/outro.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/outro.js
-/home/cbaudson/workspace/trunk/http/classes/class_universal_rss_factory.php	1253192303	0	/home/cbaudson/workspace/trunk/http/classes/class_universal_rss_factory.php
-/home/cbaudson/workspace/trunk/http/print/classes/mbMeasureDecorator.php	1263998514	0	/home/cbaudson/workspace/trunk/http/print/classes/mbMeasureDecorator.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_gui.js	1255602947	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_gui.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/event.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/event.js
-/home/cbaudson/workspace/trunk/http/classes/class_bbox.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_bbox.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_tab.js	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_tab.js
-/home/cbaudson/workspace/trunk/http/javascripts/wms.js	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/wms.js
-/home/cbaudson/workspace/trunk/http/plugins/jq_ui_dialog.js	1264752970	0	/home/cbaudson/workspace/trunk/http/plugins/jq_ui_dialog.js
-/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilitiesList.php	1255956391	0	/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilitiesList.php
-/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read.php	1249480442	0	/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/fixtures/external_script.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/fixtures/external_script.js
-/home/cbaudson/workspace/trunk/http/sld/classes/FeatureTypeStyle.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/FeatureTypeStyle.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_firebug_lite.js	1261129655	1	firebug_lite
-/home/cbaudson/workspace/trunk/http/javascripts/mod_setBackground.php	1255602947	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_setBackground.php
-/home/cbaudson/workspace/trunk/http/sld/classes/PointPlacement.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/PointPlacement.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/timer.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/timer.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/console.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/console.js
-/home/cbaudson/workspace/trunk/http/sld/classes/PointSymbolizer.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/PointSymbolizer.php
-/home/cbaudson/workspace/trunk/http/php/mod_digitize_messages.php	1263300768	0	/home/cbaudson/workspace/trunk/http/php/mod_digitize_messages.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/rule.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/rule.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlelement.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlelement.js
-/home/cbaudson/workspace/trunk/http/php/mod_gazLayerObj_edit.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gazLayerObj_edit.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql	1259847975	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/text.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/text.js
-/home/cbaudson/workspace/trunk/http/javascripts/geometry.js	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/geometry.js
-/home/cbaudson/workspace/trunk/http/classes/class_connector.php	1267026796	0	/home/cbaudson/workspace/trunk/http/classes/class_connector.php
-/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_filteredUser.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_filteredUser.php
-/home/cbaudson/workspace/trunk/http/php/nestedSets.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/nestedSets.php
-/home/cbaudson/workspace/trunk/license/bitstream-COPYRIGHT.TXT	1246284047	0	/home/cbaudson/workspace/trunk/license/bitstream-COPYRIGHT.TXT
-/home/cbaudson/workspace/trunk/http/index.php	1246284046	0	/home/cbaudson/workspace/trunk/http/index.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/optgroup.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/optgroup.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_dragMapSize.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_dragMapSize.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql	1258548846	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/aspect.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/aspect.js
-/home/cbaudson/workspace/trunk/sql/insert_wfs_conf.sql	1246284046	0	/home/cbaudson/workspace/trunk/sql/insert_wfs_conf.sql
-/home/cbaudson/workspace/trunk/http/plugins/jq_ui_effects.php	1264752560	0	jq_ui_effects
-/home/cbaudson/workspace/trunk/http/classes/class_layer_monitor.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_layer_monitor.php
-/home/cbaudson/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_tabs_vertical.js	1264752560	1	tabs_vertical
-/home/cbaudson/workspace/trunk/http/classes/class_kml_line.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_line.php
-/home/cbaudson/workspace/trunk/http/javascripts/user.php	1249653429	0	/home/cbaudson/workspace/trunk/http/javascripts/user.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/xhr.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/xhr.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xpath_unittest.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xpath_unittest.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/xhr/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/xhr/spec.js
-/home/cbaudson/workspace/trunk/http/plugins/mb_history_forward.js	1257780619	0	/home/cbaudson/workspace/trunk/http/plugins/mb_history_forward.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/iframe.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/iframe.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/window/spec.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/window/spec.js
-/home/cbaudson/workspace/trunk/core/i18n.php	1263396699	0	/home/cbaudson/workspace/trunk/core/i18n.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/profile.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/profile.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php	1256039578	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php
-/home/cbaudson/workspace/trunk/license/gpl_short.txt	1246284047	0	/home/cbaudson/workspace/trunk/license/gpl_short.txt
-/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql	1246284070	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/BrowserTreeBuilder.java	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/BrowserTreeBuilder.java
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/window.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/window.js
-/home/cbaudson/workspace/trunk/http/sld/classes/RasterSymbolizer.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/RasterSymbolizer.php
-/home/cbaudson/workspace/trunk/http/php/mod_gui_owner.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_gui_owner.php
-/home/cbaudson/workspace/trunk/http/php/mod_echo.php	1260538913	0	/home/cbaudson/workspace/trunk/http/php/mod_echo.php
-/home/cbaudson/workspace/trunk/lib/customTreeModel.js	1263903547	0	/home/cbaudson/workspace/trunk/lib/customTreeModel.js
-/home/cbaudson/workspace/trunk/http/plugins/ol_layerSwitch.js	1261559928	1	ol_layerSwitch
-/home/cbaudson/workspace/trunk/http/classes/class_ows.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/class_ows.php
-/home/cbaudson/workspace/trunk/http/classes/class_csw.php	1261564131	0	/home/cbaudson/workspace/trunk/http/classes/class_csw.php
-/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read_single.php	1248852610	0	/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read_single.php
-/home/cbaudson/workspace/trunk/test/http/classes/GeoRssTest.php	1255606944	0	/home/cbaudson/workspace/trunk/test/http/classes/GeoRssTest.php
-/home/cbaudson/workspace/trunk/http/print/classes/mbParagraphDecorator.php	1263998515	0	/home/cbaudson/workspace/trunk/http/print/classes/mbParagraphDecorator.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_searchCSW_form.php	1261565985	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_searchCSW_form.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_toggleModule.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_toggleModule.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/characterdata.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/characterdata.js
-/home/cbaudson/workspace/trunk/http/php/mod_abo_show.php	1249464694	0	/home/cbaudson/workspace/trunk/http/php/mod_abo_show.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleText.php	1246460709	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleText.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_1.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_1.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php
-/home/cbaudson/workspace/trunk/http/classes/class_RPCEndpoint.php	1249653363	0	/home/cbaudson/workspace/trunk/http/classes/class_RPCEndpoint.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/openlayers_application.sql	1246284071	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/openlayers_application.sql
-/home/cbaudson/workspace/trunk/http/php/mod_deleteGUI.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_deleteGUI.php
-/home/cbaudson/workspace/trunk/http/php/mod_displayKML.php	1246283966	0	/home/cbaudson/workspace/trunk/http/php/mod_displayKML.php
-/home/cbaudson/workspace/trunk/http/php/mod_metadataWrite.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_metadataWrite.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_initWmc.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_initWmc.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/factory.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/factory.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/qunit.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/qunit.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_fisheye.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_fisheye.php
-/home/cbaudson/workspace/trunk/http/php/mod_wmc_publish.php	1258120121	0	/home/cbaudson/workspace/trunk/http/php/mod_wmc_publish.php
-/home/cbaudson/workspace/trunk/http/sld/classes/UserStyle.php	1246283956	0	/home/cbaudson/workspace/trunk/http/sld/classes/UserStyle.php
-/home/cbaudson/workspace/trunk/http/php/mod_newGui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_newGui.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_usemap.php	1246374828	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_usemap.php
-/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/table.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/table.js
-/home/cbaudson/workspace/trunk/http/tmp/ReadMe.txt	1267021285	0	/home/cbaudson/workspace/trunk/http/tmp/ReadMe.txt
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/htmlevents.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/htmlevents.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_center1.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_center1.php
-/home/cbaudson/workspace/trunk/http/classes/class_wmc.php	1258622176	0	/home/cbaudson/workspace/trunk/http/classes/class_wmc.php
-/home/cbaudson/workspace/trunk/http/php/mod_changePassword.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_changePassword.php
-/home/cbaudson/workspace/trunk/http/plugins/ol_wms.php	1262789894	1	<Application element name>
-/home/cbaudson/workspace/trunk/http/print/classes/mbTemplatePdf.php	1267021310	0	/home/cbaudson/workspace/trunk/http/print/classes/mbTemplatePdf.php
-/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql	1246284070	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/result.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/result.js
-/home/cbaudson/workspace/trunk/http/classes/class_gml.php	1246284039	0	/home/cbaudson/workspace/trunk/http/classes/class_gml.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/button.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/button.js
-/home/cbaudson/workspace/trunk/license/gpl.txt	1246284047	0	/home/cbaudson/workspace/trunk/license/gpl.txt
-/home/cbaudson/workspace/trunk/http/test/test_rss_load.php	1253193891	0	/home/cbaudson/workspace/trunk/http/test/test_rss_load.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/object.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/object.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_savewmc.php	1258557168	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_savewmc.php
-/home/cbaudson/workspace/trunk/http/php/mod_wps.php	1263903487	0	/home/cbaudson/workspace/trunk/http/php/mod_wps.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/intro.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/intro.js
-/home/cbaudson/workspace/trunk/http/php/geoRSSToGeoJSON.php	1258643797	0	/home/cbaudson/workspace/trunk/http/php/geoRSSToGeoJSON.php
-/home/cbaudson/workspace/trunk/http/classes/class_gui.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_gui.php
-/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SelectAll.js	1261565683	0	/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SelectAll.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_5.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_5.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/eventtarget.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/eventtarget.js
-/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql	1251461870	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql
+/home/cbaudson/workspace/trunk/lib/class_Monitor.php	1249479917	0	/home/cbaudson/workspace/trunk/lib/class_Monitor.php
+/home/cbaudson/workspace/trunk/lib/list.js	1263903580	1	List
+/home/cbaudson/workspace/trunk/lib/event.js	1267021316	1	Event
+/home/cbaudson/workspace/trunk/lib/saveButton.js	1246284055	0	/home/cbaudson/workspace/trunk/lib/saveButton.js
 /home/cbaudson/workspace/trunk/lib/button.js	1263903592	1	Button
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/parser.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/parser.js
-/home/cbaudson/workspace/trunk/test/tools/qunit.js	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/qunit.js
-/home/cbaudson/workspace/trunk/tools/send_post.php	1246284046	0	/home/cbaudson/workspace/trunk/tools/send_post.php
+/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js	1261565712	1	/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js
+/home/cbaudson/workspace/trunk/lib/customTreeModel.js	1263903547	0	/home/cbaudson/workspace/trunk/lib/customTreeModel.js
+/home/cbaudson/workspace/trunk/lib/alignButton.js	1263903550	0	/home/cbaudson/workspace/trunk/lib/alignButton.js
+/home/cbaudson/workspace/trunk/lib/extent.js	1263903576	1	Extent
+/home/cbaudson/workspace/trunk/lib/marker.js	1267027600	1	Mapbender.Marker
+/home/cbaudson/workspace/trunk/lib/class_Mapbender_session.php	1267021316	0	/home/cbaudson/workspace/trunk/lib/class_Mapbender_session.php
+/home/cbaudson/workspace/trunk/lib/buttonNew.js	1246284053	0	/home/cbaudson/workspace/trunk/lib/buttonNew.js
+/home/cbaudson/workspace/trunk/lib/core.js	1263903586	0	/home/cbaudson/workspace/trunk/lib/core.js
 /home/cbaudson/workspace/trunk/lib/basic.js	1263995832	1	mapbender
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/simple.txt	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/simple.txt
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmldocument.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmldocument.js
-/home/cbaudson/workspace/trunk/http/plugins/jq_ui_effects.js	1264753004	1	jq_ui_effects
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/mail.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/mail.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomCoords.php	1264003367	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomCoords.php
-/home/cbaudson/workspace/trunk/resources/db/log_schema.txt	1246373938	0	/home/cbaudson/workspace/trunk/resources/db/log_schema.txt
-/home/cbaudson/workspace/trunk/Changes.txt	1267021391	0	/home/cbaudson/workspace/trunk/Changes.txt
-/home/cbaudson/workspace/trunk/lib/exception.js	1263903557	1	Exception
-/home/cbaudson/workspace/trunk/http/php/mod_editApplication_server.php	1253705870	0	/home/cbaudson/workspace/trunk/http/php/mod_editApplication_server.php
-/home/cbaudson/workspace/trunk/http/classes/class_georss_factory.php	1253192205	0	/home/cbaudson/workspace/trunk/http/classes/class_georss_factory.php
-/home/cbaudson/workspace/trunk/http/php/mod_gazetteerMetadata_search.php	1267021307	0	/home/cbaudson/workspace/trunk/http/php/mod_gazetteerMetadata_search.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql	1251461877	0	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/dom.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/dom.js
-/home/cbaudson/workspace/trunk/http/php/mod_orphanWMS.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_orphanWMS.php
-/home/cbaudson/workspace/trunk/http/print/classes/mbImageDecorator.php	1263998514	0	/home/cbaudson/workspace/trunk/http/print/classes/mbImageDecorator.php
-/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	1267021391	1	/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/keyboardevent.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/keyboardevent.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/johnson/placeholder.txt	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/johnson/placeholder.txt
-/home/cbaudson/workspace/trunk/http/javascripts/mod_searchCSW_ajax.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_searchCSW_ajax.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/test/xslt_script.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/test/xslt_script.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/documentfragment.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/documentfragment.js
-/home/cbaudson/workspace/trunk/http/javascripts/mod_AdminTabs.js	1255602947	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_AdminTabs.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/README.Refactor.txt	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/README.Refactor.txt
-/home/cbaudson/workspace/trunk/resources/db/sql_updates_monitoring.sql	1248965379	1	/home/cbaudson/workspace/trunk/resources/db/sql_updates_monitoring.sql
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/console/boot.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/console/boot.js
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/qunit.js	1267021287	0	/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/qunit.js
-/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	1259847968	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
-/home/cbaudson/workspace/trunk/http/classes/class_gml2.php	1259154633	0	/home/cbaudson/workspace/trunk/http/classes/class_gml2.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_saveLayerPreview.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_saveLayerPreview.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_state.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_state.php
-/home/cbaudson/workspace/trunk/http/print/classes/mbTemplatePdfDecorator.php	1263998515	0	/home/cbaudson/workspace/trunk/http/print/classes/mbTemplatePdfDecorator.php
-/home/cbaudson/workspace/trunk/http/classes/class_mb_warning.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_mb_warning.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/parser.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/parser.js
-/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_group.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_group.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/history.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/history.js
-/home/cbaudson/workspace/trunk/http/plugins/jq_datatables.js	1257348781	1	jq_datatables
-/home/cbaudson/workspace/trunk/http/javascripts/mod_tooltip.php	1253875633	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_tooltip.php
-/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php
-/home/cbaudson/workspace/trunk/http/sld/sld_function_handler.php	1246283960	0	/home/cbaudson/workspace/trunk/http/sld/sld_function_handler.php
-/home/cbaudson/workspace/trunk/http/include/dyn_php.php	1246283960	0	/home/cbaudson/workspace/trunk/http/include/dyn_php.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js	1259593231	1	Sandclock
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/processor.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/processor.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/dist/event.js	1267021305	0	/home/cbaudson/workspace/trunk/test/tools/env-js/dist/event.js
-/home/cbaudson/workspace/trunk/license/Liberation-License.txt	1246284047	0	/home/cbaudson/workspace/trunk/license/Liberation-License.txt
-/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js	1267021307	1	changeEPSG
-/home/cbaudson/workspace/trunk/http/javascripts/initWms.php	1246283973	0	/home/cbaudson/workspace/trunk/http/javascripts/initWms.php
-/home/cbaudson/workspace/trunk/http/php/mod_group_user.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_group_user.php
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/entityreference.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/entityreference.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/dom_unittest.js	1267021297	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/dom_unittest.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_0.js	1267021298	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_0.js
-/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__extend__.js	1267021296	0	/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__extend__.js
-/home/cbaudson/workspace/trunk/http/php/mod_deleteWFS.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_deleteWFS.php
-/home/cbaudson/workspace/trunk/http/classes/class_kml_multigeometry.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_kml_multigeometry.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_exportMapImage.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_exportMapImage.php
-/home/cbaudson/workspace/trunk/http/classes/class_wms.php	1256902136	0	/home/cbaudson/workspace/trunk/http/classes/class_wms.php
-/home/cbaudson/workspace/trunk/http/php/mod_filteredWms_topic.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_filteredWms_topic.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js	1251460918	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js
-/home/cbaudson/workspace/trunk/http/php/mod_layerMetadata.php	1257413721	0	/home/cbaudson/workspace/trunk/http/php/mod_layerMetadata.php
-/home/cbaudson/workspace/trunk/http/print/printFactory.php	1264003334	0	/home/cbaudson/workspace/trunk/http/print/printFactory.php
-/home/cbaudson/workspace/trunk/license/licence_reference.txt	1246284047	0	/home/cbaudson/workspace/trunk/license/licence_reference.txt
-/home/cbaudson/workspace/trunk/test/tools/env-js/bin/prototype-1.6.0.3-test.js	1267021306	0	/home/cbaudson/workspace/trunk/test/tools/env-js/bin/prototype-1.6.0.3-test.js
Modified: trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd
(Binary files differ)
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
Modified: trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
Modified: trunk/mapbender/documents/api_js/Data/PreviousSettings.nd
Modified: trunk/mapbender/documents/api_js/Data/SymbolTable.nd
Modified: trunk/mapbender/documents/api_js/Menu.txt
--- trunk/mapbender/documents/api_js/Menu.txt	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/Menu.txt	2010-02-24 16:13:30 UTC (rev 5639)
@@ -46,110 +46,24 @@
-Group: Http  {
+File: Ajax  (ajax.js)
+File: Button  (button.js)
+File: Event  (event.js)
+File: Exception  (exception.js)
+File: Extent  (extent.js)
+File: List  (list.js)
+File: mapbender  (basic.js)
+File: Mapbender.Marker  (marker.js)
+File: Point  (point.js)
+File: resultGeometryListController.js  (resultGeometryListController.js)
+File: ResultGeometryListModel  (resultGeometryListModel.js)
-   Group: Javascripts  {
-      File: AddWmsFromTree  (http/javascripts/mod_addWMSfromTree.js)
-      File: changeEPSG  (http/javascripts/mod_changeEPSG.js)
-      File: coordsLookup  (http/javascripts/mod_coordsLookup.js)
-      File: doubleclickZoom  (http/javascripts/mod_doubleclickZoom.js)
-      File: firebug_lite  (http/javascripts/mod_firebug_lite.js)
-      File: gazetteerWFS  (http/javascripts/mod_wfs_gazetteer_client.php)
-      File: jq_jgrowl  (http/javascripts/jq_jgrowl.js)
-      File: jq_ui_effects  (http/javascripts/jq_ui_effects.php)
-      File: Log  (http/javascripts/mod_log.js)
-      File: Map  (http/javascripts/map_obj.js)
-      File: Mapbender  (http/javascripts/core.php)
-      File: mousewheelZoom  (http/javascripts/mod_mousewheelZoom.js)
-      File: overviewToggle  (http/javascripts/mod_overviewToggle.js)
-      File: Reload  (http/javascripts/mod_reload.js)
-      File: repaint  (http/javascripts/mod_repaint.js)
-      File: repaint  (http/javascripts/mod_repaint.php)
-      File: ResizeMapsize  (http/javascripts/mod_resize_mapsize.js)
-      File: resultList  (http/javascripts/mod_ResultList.js)
-      File: Sandclock  (http/javascripts/mod_sandclock.js)
-      File: savewmc  (http/javascripts/mod_savewmc.js)
-      File: scalebar  (http/javascripts/mod_scalebar.js)
-      File: selArea  (http/javascripts/mod_selArea.js)
-      File: selArea  (http/javascripts/mod_pan.js)
-      File: zoomFull  (http/javascripts/mod_zoomFull.js)
-      File: ZoomIn1  (http/javascripts/mod_zoomIn1.js)
-      File: ZoomOut1  (http/javascripts/mod_zoomOut1.js)
-      }  # Group: Javascripts
-   Group: Plugins  {
-      File: <Application element name>  (http/plugins/ol_wms.php)
-      File: cookie  (http/plugins/mb_cookie.js)
-      File: i18n  (http/plugins/mb_i18n.js)
-      File: jq_datatables  (http/plugins/jq_datatables.js)
-      File: jq_ui_accordion  (http/plugins/jq_ui_accordion.js)
-      File: jq_ui_effects  (http/plugins/jq_ui_effects.js)
-      File: jq_ui_resizable  (http/plugins/jq_ui_resizable.js)
-      File: mapframe1  (http/plugins/mb_map.js)
-      File: mb_navigation  (http/plugins/mb_navigation.js)
-      File: mb_resultList_transferToDigitize  (http/plugins/mb_resultList_transferToDigitize.js)
-      File: mb_zoomIn  (http/plugins/mb_zoomIn.js)
-      File: mb_zoomOut  (http/plugins/mb_zoomOut.js)
-      File: ol  (http/plugins/ol.js)
-      File: ol_keyboardDefaults  (http/plugins/ol_keyboardDefaults.js)
-      File: ol_layerSwitch  (http/plugins/ol_layerSwitch.js)
-      File: ol_mousePosition  (http/plugins/ol_mousePosition.js)
-      File: ol_overviewMap  (http/plugins/ol_overview.js)
-      File: ol_panZoomBar  (http/plugins/ol_panZoomBar.js)
-      File: Overview  (http/plugins/mb_overview.js)
-      File: printPDF  (http/plugins/mb_print.js)
-      File: resize  (http/plugins/mb_resize.js)
-      File: selectMapsize  (http/plugins/mb_selectMapsize.js)
-      File: tabs_vertical  (http/plugins/mb_tabs_vertical.js)
-      File: twitter_signin  (http/plugins/mb_twitter_signin.js)
-      File: wmsTimeInterval  (http/plugins/mb_wmsTimeInterval.js)
-      File: wmsTimeSliderYear  (http/plugins/mb_wmsTimeSliderYear.js)
-      }  # Group: Plugins
-   }  # Group: Http
-Group: Lib  {
-   File: Ajax  (lib/ajax.js)
-   File: Button  (lib/button.js)
-   File: Event  (lib/event.js)
-   File: Exception  (lib/exception.js)
-   File: Extent  (lib/extent.js)
-   File: List  (lib/list.js)
-   File: mapbender  (lib/basic.js)
-   File: Mapbender.Marker  (lib/marker.js)
-   File: Point  (lib/point.js)
-   File: resultGeometryListController.js  (lib/resultGeometryListController.js)
-   File: ResultGeometryListModel  (lib/resultGeometryListModel.js)
-   }  # Group: Lib
-Group: Resources  {
-   File: inspire_md_data  (resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8.sql)
-   File: pgsql/.../update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql  (resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql)
-   File: sql_updates_monitoring.sql  (resources/db/sql_updates_monitoring.sql)
-   }  # Group: Resources
-Group: Test  {
-   File: dist/.../1.1.rc2/env.1.1.rc2.js  (test/tools/env-js/dist/releases/1.1.rc2/env.1.1.rc2.js)
-   File: dist/.../1.1.rc2/env.rhino.1.1.rc2.js  (test/tools/env-js/dist/releases/1.1.rc2/env.rhino.1.1.rc2.js)
-   File: src/.../js/jquery.js  (test/tools/env-js/src/css/jss-0-4/js/jquery.js)
-   }  # Group: Test
 Group: Index  {
    Index: Everything
    Class Index: Classes
    Function Index: Functions
    Property Index: Properties
-   Database Index Index: Database Indexes
-   Database Table Index: Database Tables
-   Database Trigger Index: Database Triggers
-   Database View Index: Database Views
    File Index: Files
-   Variable Index: Variables
    }  # Group: Index
Added: trunk/mapbender/documents/api_js/Menu_Backup_2.txt
--- trunk/mapbender/documents/api_js/Menu_Backup_2.txt	                        (rev 0)
+++ trunk/mapbender/documents/api_js/Menu_Backup_2.txt	2010-02-24 16:13:30 UTC (rev 5639)
@@ -0,0 +1,155 @@
+Format: 1.4
+# You can add a title and sub-title to your menu like this:
+# Title: [project name]
+# SubTitle: [subtitle]
+# You can add a footer to your documentation like this:
+# Footer: [text]
+# If you want to add a copyright notice, this would be the place to do it.
+# You can add a timestamp to your documentation like one of these:
+# Timestamp: Generated on month day, year
+# Timestamp: Updated mm/dd/yyyy
+# Timestamp: Last updated mon day
+#   m     - One or two digit month.  January is "1"
+#   mm    - Always two digit month.  January is "01"
+#   mon   - Short month word.  January is "Jan"
+#   month - Long month word.  January is "January"
+#   d     - One or two digit day.  1 is "1"
+#   dd    - Always two digit day.  1 is "01"
+#   day   - Day with letter extension.  1 is "1st"
+#   yy    - Two digit year.  2006 is "06"
+#   yyyy  - Four digit year.  2006 is "2006"
+#   year  - Four digit year.  2006 is "2006"
+# Cut and paste the lines below to change the order in which your files
+# appear on the menu.  Don't worry about adding or removing files, Natural
+# Docs will take care of that.
+# You can further organize the menu by grouping the entries.  Add a
+# "Group: [name] {" line to start a group, and add a "}" to end it.
+# You can add text and web links to the menu by adding "Text: [text]" and
+# "Link: [name] ([URL])" lines, respectively.
+# The formatting and comments are auto-generated, so don't worry about
+# neatness when editing the file.  Natural Docs will clean it up the next
+# time it is run.  When working with groups, just deal with the braces and
+# forget about the indentation and comments.
+Group: Http  {
+   Group: Javascripts  {
+      File: AddWmsFromTree  (http/javascripts/mod_addWMSfromTree.js)
+      File: changeEPSG  (http/javascripts/mod_changeEPSG.js)
+      File: coordsLookup  (http/javascripts/mod_coordsLookup.js)
+      File: doubleclickZoom  (http/javascripts/mod_doubleclickZoom.js)
+      File: firebug_lite  (http/javascripts/mod_firebug_lite.js)
+      File: gazetteerWFS  (http/javascripts/mod_wfs_gazetteer_client.php)
+      File: jq_jgrowl  (http/javascripts/jq_jgrowl.js)
+      File: jq_ui_effects  (http/javascripts/jq_ui_effects.php)
+      File: Log  (http/javascripts/mod_log.js)
+      File: Map  (http/javascripts/map_obj.js)
+      File: Mapbender  (http/javascripts/core.php)
+      File: mousewheelZoom  (http/javascripts/mod_mousewheelZoom.js)
+      File: overviewToggle  (http/javascripts/mod_overviewToggle.js)
+      File: Reload  (http/javascripts/mod_reload.js)
+      File: repaint  (http/javascripts/mod_repaint.js)
+      File: repaint  (http/javascripts/mod_repaint.php)
+      File: ResizeMapsize  (http/javascripts/mod_resize_mapsize.js)
+      File: resultList  (http/javascripts/mod_ResultList.js)
+      File: Sandclock  (http/javascripts/mod_sandclock.js)
+      File: savewmc  (http/javascripts/mod_savewmc.js)
+      File: scalebar  (http/javascripts/mod_scalebar.js)
+      File: selArea  (http/javascripts/mod_selArea.js)
+      File: selArea  (http/javascripts/mod_pan.js)
+      File: zoomFull  (http/javascripts/mod_zoomFull.js)
+      File: ZoomIn1  (http/javascripts/mod_zoomIn1.js)
+      File: ZoomOut1  (http/javascripts/mod_zoomOut1.js)
+      }  # Group: Javascripts
+   Group: Plugins  {
+      File: <Application element name>  (http/plugins/ol_wms.php)
+      File: cookie  (http/plugins/mb_cookie.js)
+      File: i18n  (http/plugins/mb_i18n.js)
+      File: jq_datatables  (http/plugins/jq_datatables.js)
+      File: jq_ui_accordion  (http/plugins/jq_ui_accordion.js)
+      File: jq_ui_effects  (http/plugins/jq_ui_effects.js)
+      File: jq_ui_resizable  (http/plugins/jq_ui_resizable.js)
+      File: mapframe1  (http/plugins/mb_map.js)
+      File: mb_navigation  (http/plugins/mb_navigation.js)
+      File: mb_resultList_transferToDigitize  (http/plugins/mb_resultList_transferToDigitize.js)
+      File: mb_zoomIn  (http/plugins/mb_zoomIn.js)
+      File: mb_zoomOut  (http/plugins/mb_zoomOut.js)
+      File: ol  (http/plugins/ol.js)
+      File: ol_keyboardDefaults  (http/plugins/ol_keyboardDefaults.js)
+      File: ol_layerSwitch  (http/plugins/ol_layerSwitch.js)
+      File: ol_mousePosition  (http/plugins/ol_mousePosition.js)
+      File: ol_overviewMap  (http/plugins/ol_overview.js)
+      File: ol_panZoomBar  (http/plugins/ol_panZoomBar.js)
+      File: Overview  (http/plugins/mb_overview.js)
+      File: printPDF  (http/plugins/mb_print.js)
+      File: resize  (http/plugins/mb_resize.js)
+      File: selectMapsize  (http/plugins/mb_selectMapsize.js)
+      File: tabs_vertical  (http/plugins/mb_tabs_vertical.js)
+      File: twitter_signin  (http/plugins/mb_twitter_signin.js)
+      File: wmsTimeInterval  (http/plugins/mb_wmsTimeInterval.js)
+      File: wmsTimeSliderYear  (http/plugins/mb_wmsTimeSliderYear.js)
+      }  # Group: Plugins
+   }  # Group: Http
+Group: Lib  {
+   File: Ajax  (lib/ajax.js)
+   File: Button  (lib/button.js)
+   File: Event  (lib/event.js)
+   File: Exception  (lib/exception.js)
+   File: Extent  (lib/extent.js)
+   File: List  (lib/list.js)
+   File: mapbender  (lib/basic.js)
+   File: Mapbender.Marker  (lib/marker.js)
+   File: Point  (lib/point.js)
+   File: resultGeometryListController.js  (lib/resultGeometryListController.js)
+   File: ResultGeometryListModel  (lib/resultGeometryListModel.js)
+   }  # Group: Lib
+Group: Resources  {
+   File: inspire_md_data  (resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8.sql)
+   File: pgsql/.../update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql  (resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql)
+   File: sql_updates_monitoring.sql  (resources/db/sql_updates_monitoring.sql)
+   }  # Group: Resources
+Group: Test  {
+   File: dist/.../1.1.rc2/env.1.1.rc2.js  (test/tools/env-js/dist/releases/1.1.rc2/env.1.1.rc2.js)
+   File: dist/.../1.1.rc2/env.rhino.1.1.rc2.js  (test/tools/env-js/dist/releases/1.1.rc2/env.rhino.1.1.rc2.js)
+   File: src/.../js/jquery.js  (test/tools/env-js/src/css/jss-0-4/js/jquery.js)
+   }  # Group: Test
+Group: Index  {
+   Index: Everything
+   Class Index: Classes
+   Function Index: Functions
+   Property Index: Properties
+   Database Index Index: Database Indexes
+   Database Table Index: Database Tables
+   Database Trigger Index: Database Triggers
+   Database View Index: Database Views
+   File Index: Files
+   Variable Index: Variables
+   }  # Group: Index
Modified: trunk/mapbender/documents/api_js/index/Classes.html
--- trunk/mapbender/documents/api_js/index/Classes.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/index/Classes.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,96 +11,51 @@
-<div id=Index><div class=IPageTitle>Class Index</div><div class=INavigationBar><a href="#Symbols">$#!</a> &middot; 0-9 &middot; <a href="#A">A</a> &middot; <a href="#B">B</a> &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; <a href="#G">G</a> &middot; H &middot; <a href="#I">I</a> &middot; <a href="#J">J</a> &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; <a href="#O">O</a> &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; U &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="Symbols"></a>$#!</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_wms-php.html#Application_element_name" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>&lt;Application element name&gt;</a></td></tr><tr><td class=IHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>AddWmsFromTree</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/button-js.html#Button" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_changeEPSG-js.html#changeEPSG" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>changeEPSG</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_cookie-js.html#cookie" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>cookie</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_coordsLookup-js.html#coordsLookup" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>coordsLookup</a></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_doubleclickZoom-js.html#doubleclickZoom" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>doubleclickZoom</a></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Exception" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Exception</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Extent</a></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>firebug_lite</a></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>gazetteerWFS</a></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_i18n-js.html#i18n" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>i18n</a></td></tr><tr><td class=IHeading><a name="J"></a>J</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_datatables-js.html#jq_datatables" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>jq_datatables</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/jq_jgrowl-js.html#jq_jgrowl" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>jq_jgrowl</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_ui_accordion-js.html#jq_ui_accordion" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>jq_ui_accordion</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>jq_ui_effects</span><div class=ISubIndex><a href="../files/http/javascripts/jq_ui_effects-php.html#jq_ui_effects" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=IFile>http/<wbr>javascripts/<wbr>jq_ui_effects.php</a><a href="../files/http/plugins/jq_ui_effects-js.html#jq_ui_effects" id=link19 onMouseOver="ShowTip(event, 'tt18', 'link19')" onMouseOut="HideTip('tt18')" class=IFile>http/<wbr>plugins/<wbr>jq_ui_effects.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_ui_resizable-js.html#jq_ui_resizable" id=link20 onMouseOver="ShowTip(event, 'tt19', 'link20')" onMouseOut="HideTip('tt19')" class=ISymbol>jq_ui_resizable</a></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/list-js.html#List" id=link21 onMouseOver="ShowTip(event, 'tt20', 'link21')" onMouseOut="HideTip('tt20')" class=ISymbol>List</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" id=link22 onMouseOver="ShowTip(event, 'tt21', 'link22')" onMouseOut="HideTip('tt21')" class=ISymbol>Log</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" id=link23 onMouseOver="ShowTip(event, 'tt22', 'link23')" onMouseOut="HideTip('tt22')" class=ISymbol>Map</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender" id=link24 onMouseOver="ShowTip(event, 'tt23', 'link24')" onMouseOut="HideTip('tt23')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link25 onMouseOver="ShowTip(event, 'tt24', 'link25')" onMouseOut="HideTip('tt24')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker" id=link26 onMouseOver="ShowTip(event, 'tt25', 'link26')" onMouseOut="HideTip('tt25')" class=ISymbol>Mapbender.<wbr>Marker</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" id=link27 onMouseOver="ShowTip(event, 'tt26', 'link27')" onMouseOut="HideTip('tt26')" class=ISymbol>mapframe1</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" id=link28 onMouseOver="ShowTip(event, 'tt27', 'link28')" onMouseOut="HideTip('tt27')" class=ISymbol>mb_navigation</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" id=link29 onMouseOver="ShowTip(event, 'tt28', 'link29')" onMouseOut="HideTip('tt28')" class=ISymbol>mb_resultList_transferToDigitize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" id=link30 onMouseOver="ShowTip(event, 'tt29', 'link30')" onMouseOut="HideTip('tt29')" class=ISymbol>mb_zoomIn</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" id=link31 onMouseOver="ShowTip(event, 'tt30', 'link31')" onMouseOut="HideTip('tt30')" class=ISymbol>mb_zoomOut</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" id=link32 onMouseOver="ShowTip(event, 'tt31', 'link32')" onMouseOut="HideTip('tt31')" class=ISymbol>mousewheelZoom</a></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Notice" id=link33 onMouseOver="ShowTip(event, 'tt32', 'link33')" onMouseOut="HideTip('tt32')" class=ISymbol>Notice</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Notification" id=link34 onMouseOver="ShowTip(event, 'tt33', 'link34')" onMouseOut="HideTip('tt33')" class=ISymbol>Notification</a></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol-js.html#ol" id=link35 onMouseOver="ShowTip(event, 'tt34', 'link35')" onMouseOut="HideTip('tt34')" class=ISymbol>ol</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_keyboardDefaults-js.html#ol_keyboardDefaults" id=link36 onMouseOver="ShowTip(event, 'tt35', 'link36')" onMouseOut="HideTip('tt35')" class=ISymbol>ol_keyboardDefaults</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_layerSwitch-js.html#ol_layerSwitch" id=link37 onMouseOver="ShowTip(event, 'tt36', 'link37')" onMouseOut="HideTip('tt36')" class=ISymbol>ol_layerSwitch</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_mousePosition-js.html#ol_mousePosition" id=link38 onMouseOver="ShowTip(event, 'tt37', 'link38')" onMouseOut="HideTip('tt37')" class=ISymbol>ol_mousePosition</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_overview-js.html#ol_overviewMap" id=link39 onMouseOver="ShowTip(event, 'tt38', 'link39')" onMouseOut="HideTip('tt38')" class=ISymbol>ol_overviewMap</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_panZoomBar-js.html#ol_panZoomBar" id=link40 onMouseOver="ShowTip(event, 'tt39', 'link40')" onMouseOut="HideTip('tt39')" class=ISymbol>ol_panZoomBar</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_overview-js.html#Overview" id=link41 onMouseOver="ShowTip(event, 'tt40', 'link41')" onMouseOut="HideTip('tt40')" class=ISymbol>Overview</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_overviewToggle-js.html#overviewToggle" id=link42 onMouseOver="ShowTip(event, 'tt41', 'link42')" onMouseOut="HideTip('tt41')" class=ISymbol>overviewToggle</a></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/point-js.html#Point" id=link43 onMouseOver="ShowTip(event, 'tt42', 'link43')" onMouseOut="HideTip('tt42')" class=ISymbol>Point</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF" id=link44 onMouseOver="ShowTip(event, 'tt43', 'link44')" onMouseOut="HideTip('tt43')" class=ISymbol>printPDF</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" id=link45 onMouseOver="ShowTip(event, 'tt44', 'link45')" onMouseOut="HideTip('tt44')" class=ISymbol>Reload</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>repaint</span><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" id=link46 onMouseOver="ShowTip(event, 'tt45', 'link46')" onMouseOut="HideTip('tt45')" class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" id=link47 onMouseOver="ShowTip(event, 'tt45', 'link47')" onMouseOut="HideTip('tt45')" class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Request" id=link48 onMouseOver="ShowTip(event, 'tt46', 'link48')" onMouseOut="HideTip('tt46')" class=ISymbol>Request</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" id=link49 onMouseOver="ShowTip(event, 'tt47', 'link49')" onMouseOut="HideTip('tt47')" class=ISymbol>resize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" id=link50 onMouseOver="ShowTip(event, 'tt48', 'link50')" onMouseOut="HideTip('tt48')" class=ISymbol>ResizeMapsize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" id=link51 onMouseOver="ShowTip(event, 'tt49', 'link51')" onMouseOut="HideTip('tt49')" class=ISymbol>ResultGeometryListModel</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" id=link52 onMouseOver="ShowTip(event, 'tt50', 'link52')" onMouseOut="HideTip('tt50')" class=ISymbol>resultList</a></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock" id=link53 onMouseOver="ShowTip(event, 'tt51', 'link53')" onMouseOut="HideTip('tt51')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_savewmc-js.html#savewmc" id=link54 onMouseOver="ShowTip(event, 'tt52', 'link54')" onMouseOut="HideTip('tt52')" class=ISymbol>savewmc</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_scalebar-js.html#scalebar" id=link55 onMouseOver="ShowTip(event, 'tt53', 'link55')" onMouseOut="HideTip('tt53')" class=ISymbol>scalebar</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>selArea</span><div class=ISubIndex><a href="../files/http/javascripts/mod_pan-js.html#selArea" id=link56 onMouseOver="ShowTip(event, 'tt54', 'link56')" onMouseOut="HideTip('tt54')" class=IFile>http/<wbr>javascripts/<wbr>mod_pan.js</a><a href="../files/http/javascripts/mod_selArea-js.html#selArea" id=link57 onMouseOver="ShowTip(event, 'tt54', 'link57')" onMouseOut="HideTip('tt54')" class=IFile>http/<wbr>javascripts/<wbr>mod_selArea.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_selectMapsize-js.html#selectMapsize" id=link58 onMouseOver="ShowTip(event, 'tt55', 'link58')" onMouseOut="HideTip('tt55')" class=ISymbol>selectMapsize</a></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_tabs_vertical-js.html#tabs_vertical" id=link59 onMouseOver="ShowTip(event, 'tt56', 'link59')" onMouseOut="HideTip('tt56')" class=ISymbol>tabs_vertical</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_twitter_signin-js.html#twitter_signin" id=link60 onMouseOver="ShowTip(event, 'tt57', 'link60')" onMouseOut="HideTip('tt57')" class=ISymbol>twitter_signin</a></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Warning" id=link61 onMouseOver="ShowTip(event, 'tt58', 'link61')" onMouseOut="HideTip('tt58')" class=ISymbol>Warning</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_wmsTimeInterval-js.html#wmsTimeInterval" id=link62 onMouseOver="ShowTip(event, 'tt59', 'link62')" onMouseOut="HideTip('tt59')" class=ISymbol>wmsTimeInterval</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html#wmsTimeSliderYear" id=link63 onMouseOver="ShowTip(event, 'tt60', 'link63')" onMouseOut="HideTip('tt60')" class=ISymbol>wmsTimeSliderYear</a></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomFull-js.html#zoomFull" id=link64 onMouseOver="ShowTip(event, 'tt61', 'link64')" onMouseOut="HideTip('tt61')" class=ISymbol>zoomFull</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-js.html#ZoomIn1" id=link65 onMouseOver="ShowTip(event, 'tt62', 'link65')" onMouseOut="HideTip('tt62')" class=ISymbol>ZoomIn1</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomOut1-js.html#ZoomOut1" id=link66 onMouseOver="ShowTip(event, 'tt63', 'link66')" onMouseOut="HideTip('tt63')" class=ISymbol>ZoomOut1</a></td></tr></table>
+<div id=Index><div class=IPageTitle>Class Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; <a href="#B">B</a> &middot; C &middot; D &middot; <a href="#E">E</a> &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; T &middot; U &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Ajax" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/button-js.html#Button" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/event-js.html#Event" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/exception-js.html#Exception" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>Exception</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/extent-js.html#Extent" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>Extent</a></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/list-js.html#List" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>List</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/basic-js.html#mapbender" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>Mapbender.<wbr>Marker</a></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/exception-js.html#Notice" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>Notice</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Notification" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Notification</a></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/point-js.html#Point" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Point</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Request" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>Request</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>ResultGeometryListModel</a></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/exception-js.html#Warning" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>Warning</a></td></tr></table>
 <!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CClass>A description</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CClass>An AJAX wrapper for client server interaction via JSON RPC</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt2"><div class=CClass>Add a WMS from a container. </div></div><div class=CToolTip id="tt3"><div class=CClass>An AJAX wrapper for client server interaction via JSON RPC</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt2"><div class=CClass>Adds a clickable button to Mapbender</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt4"><div class=CClass>Adds a clickable button to Mapbender</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt3"><div class=CClass>An event. </div></div><div class=CToolTip id="tt4"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt5"><div class=CClass>An extent is also known as a bounding box.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt5"><div class=CClass>Select a spatial reference system EPSG code. </div></div><div class=CToolTip id="tt6"><div class=CClass>Sets a cookie after each map request. </div></div><div class=CToolTip id="tt7"><div class=CClass>The user enters a coordinate tuple and selects the corresponding SRS from a select box. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt6"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt8"><div class=CClass>Adds behaviour to maps specified in the target field. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt7"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt8"><div class=CClass>A very basic marker class. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt9"><div class=CClass>An event. </div></div><div class=CToolTip id="tt10"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt11"><div class=CClass>An extent is also known as a bounding box.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt9"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt10"><div class=CClass>An AJAX notification (it doesn&rsquo;t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt12"><div class=CClass>Simply includes the Firebug lite JavaScript and CSS</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CClass>A class representing a two- (or three-) dimensional point.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt13"><div class=CClass>A WFS gazetteer for pre configured WFS configurations.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt12"><div class=CClass>An AJAX request (it expects a reply from the server)</div></div><div class=CToolTip id="tt13"><div class=CClass>A feature collection of a result geometry list.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt14"><div class=CClass>Internationalization module, collects data from all elements and sends them to the server in a single POST request. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt14"><div class=CClass>Logs an warning in the log file, in a console window or as an alert</div></div><!--END_ND_TOOLTIPS-->
-<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt15"><div class=CClass>Includes the jQuery plugin datatables, use like this</div></div><div class=CToolTip id="tt16"><div class=CClass>The container for the jQuery plugin jGrowl</div></div><div class=CToolTip id="tt17"><div class=CClass>Accordion from the jQuery UI framework</div></div><div class=CToolTip id="tt18"><div class=CClass>A collection of jQuery UI effects</div></div><div class=CToolTip id="tt19"><div class=CClass>Resizable from the jQuery UI framework</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt20"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><div class=CToolTip id="tt21"><div class=CClass>Logs the accesses to the guis in the database or a logfile The accesses will be written in the mapbender database on table mb_log or into mapbender/log/mb_access_$DATE.log. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt22"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt23"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt24"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt25"><div class=CClass>A very basic marker class. </div></div><div class=CToolTip id="tt26"><div class=CClass>The main map in Mapbender</div></div><div class=CToolTip id="tt27"><div class=CClass>Adds navigation arrows on top of the map</div></div><div class=CToolTip id="tt28"><div class=CClass>A description</div></div><div class=CToolTip id="tt29"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt30"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><div class=CToolTip id="tt31"><div class=CClass>Zoom in/out with the mousewheel. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt32"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt33"><div class=CClass>An AJAX notification (it doesn&rsquo;t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt34"><div class=CClass>An OpenLayers Map, configured with WMS from Mapbender application settings</div></div><div class=CToolTip id="tt35"><div class=CClass>An OpenLayers KeyboardDefaults</div></div><div class=CToolTip id="tt36"><div class=CClass>An OpenLayers Layer Switch</div></div><div class=CToolTip id="tt37"><div class=CClass>An OpenLayers MousePosition</div></div><div class=CToolTip id="tt38"><div class=CClass>An OpenLayers Layer Switch</div></div><div class=CToolTip id="tt39"><div class=CClass>An OpenLayers panZoomBar</div></div><div class=CToolTip id="tt40"><div class=CClass>Use the overview map to navigate the main map window. </div></div><div class=CToolTip id="tt41"><div class=CClass>shows and hides the overview module with a jQuery animation</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt42"><div class=CClass>A class representing a two- (or three-) dimensional point.</div></div><div class=CToolTip id="tt43"><div class=CClass>Mapbender print PDF with PDF templates module.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt44"><div class=CClass>A button that reloads the whole window.</div></div><div class=CToolTip id="tt45"><div class=CClass>Repaints a map. </div></div><div class=CToolTip id="tt46"><div class=CClass>An AJAX request (it expects a reply from the server)</div></div><div class=CToolTip id="tt47"><div class=CClass>Adds a resizable plugin to the module in target, for example mapframe1</div></div><div class=CToolTip id="tt48"><div class=CClass>This modul dynamically resizes the mapframe in relation to the browsersize. </div></div><div class=CToolTip id="tt49"><div class=CClass>A feature collection of a result geometry list.</div></div><div class=CToolTip id="tt50"><div class=CClass>A result list for featureCollections</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt51"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt52"><div class=CClass>save workspace as WMC</div></div><div class=CToolTip id="tt53"><div class=CClass>Displays scalebar in the map. </div></div><div class=CToolTip id="tt54"><div class=CClass>Zoom by rectangle</div></div><div class=CToolTip id="tt55"><div class=CClass>Select the map size from a pre defined settings, like large or small</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt56"><div class=CClass>An accordion decorator, replaces the deprecated element &ldquo;tabs&rdquo;</div></div><div class=CToolTip id="tt57"><div class=CClass>Authenticate with Twitter</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt58"><div class=CClass>Logs an warning in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt59"><div class=CClass>Find an interval with two datepickers and attach it to getMap requests of WMS in your application</div></div><div class=CToolTip id="tt60"><div class=CClass>sets the TIME parameter for all activated WMS (years only)</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt61"><div class=CClass>Click button to zoom to the full extent of the BoundingBox.</div></div><div class=CToolTip id="tt62"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt63"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><!--END_ND_TOOLTIPS-->
 </div><!--Index-->
 <div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html">&lt;Application element name&gt;</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div></div></div></div><script type="text/javascript"><!--
 var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
-HideAllBut([7, 6, 5], 8);// --></script></div><!--Menu-->
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option></select></div></div><!--Menu-->
 <div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
Modified: trunk/mapbender/documents/api_js/index/Files.html
--- trunk/mapbender/documents/api_js/index/Files.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/index/Files.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,36 +11,19 @@
-<div id=Index><div class=IPageTitle>File Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; D &middot; <a href="#E">E</a> &middot; F &middot; G &middot; H &middot; I &middot; <a href="#J">J</a> &middot; K &middot; L &middot; M &middot; N &middot; O &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; T &middot; <a href="#U">U</a> &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#env.1.1.rc2.js"  class=ISymbol>env.<wbr>1.1.<wbr>rc2.js</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#env.rhino.1.1.rc2.js"  class=ISymbol>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></td></tr><tr><td class=IHeading><a name="J"></a>J</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#jquery.js"  class=ISymbol>jquery.js</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js"  class=ISymbol>resultGeometryListController.js</a></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/sql_updates_monitoring-sql.html#sql_updates_monitoring.sql"  class=ISymbol>sql_updates_monitoring.sql</a></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql"  class=ISymbol>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></td></tr></table>
+<div id=Index><div class=IPageTitle>File Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; D &middot; E &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; L &middot; M &middot; N &middot; O &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListController-js.html#resultGeometryListController.js"  class=ISymbol>resultGeometryListController.js</a></td></tr></table>
-<!--END_ND_TOOLTIPS-->
 </div><!--Index-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html">&lt;Application element name&gt;</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Files</div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Files</div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index/Functions.html
--- trunk/mapbender/documents/api_js/index/Functions.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/index/Functions.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,80 +11,67 @@
-<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; <a href="#G">G</a> &middot; <a href="#H">H</a> &middot; I &middot; J &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Exception.Exception" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>Exception</a>, <span class=IParent>Exception</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.Extent" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>Extent</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_epsg(integer)"  class=ISymbol>f_collect_epsg(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext(integer,integer)"  class=ISymbol>f_collect_searchtext(integer,integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext_wfs(integer,integer)"  class=ISymbol>f_collect_searchtext_wfs(integer,integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfs_tou(integer)"  class=ISymbol>f_getwfs_tou(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfsmodultype(integer)"  class=ISymbol>f_getwfsmodultype(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwms_tou(integer)"  class=ISymbol>f_getwms_tou(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_layer_load_count(integer)"  class=ISymbol>f_layer_load_count(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.hide" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.hookForm" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>hookForm</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>Map</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.Mapbender.Marker" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>mb_monitor_after</span>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after"  class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after"  class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Notice.Notice" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>Notice</a>, <span class=IParent>Notice</span></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/point-js.html#Point.Point" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>Point</a>, <span class=IParent>Point</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.remove" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request"  class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>SAXDriver</span><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#SAXDriver" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#SAXDriver" id=link34 onMouseOver="ShowTip(event, 'tt33', 'link34')" onMouseOut="HideTip('tt33')" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Request.send" id=link35 onMouseOver="ShowTip(event, 'tt34', 'link35')" onMouseOut="HideTip('tt34')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.set" id=link36 onMouseOver="ShowTip(event, 'tt35', 'link36')" onMouseOut="HideTip('tt35')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link37 onMouseOver="ShowTip(event, 'tt36', 'link37')" onMouseOut="HideTip('tt36')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link38 onMouseOver="ShowTip(event, 'tt37', 'link38')" onMouseOut="HideTip('tt37')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" id=link39 onMouseOver="ShowTip(event, 'tt38', 'link39')" onMouseOut="HideTip('tt38')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" id=link40 onMouseOver="ShowTip(event, 'tt39', 'link40')" onMouseOut="HideTip('tt39')" class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>this is the constructor to the XMLP Object</span><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" id=link41 onMouseOver="ShowTip(event, 'tt40', 'link41')" onMouseOut="HideTip('tt40')" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" id=link42 onMouseOver="ShowTip(event, 'tt40', 'link42')" onMouseOut="HideTip('tt40')" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" id=link43 onMouseOver="ShowTip(event, 'tt41', 'link43')" onMouseOut="HideTip('tt41')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link44 onMouseOver="ShowTip(event, 'tt42', 'link44')" onMouseOut="HideTip('tt42')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Warning.Warning" id=link45 onMouseOver="ShowTip(event, 'tt43', 'link45')" onMouseOut="HideTip('tt43')" class=ISymbol>Warning</a>, <span class=IParent>Warning</span></td></tr></table>
+<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; F &middot; <a href="#G">G</a> &middot; H &middot; I &middot; J &middot; K &middot; L &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeatureCollection" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListController-js.html#addFeatureCollection_callback" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/basic-js.html#mapbender.cloneObject" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/basic-js.html#mapbender.cookiesEnables" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/exception-js.html#Exception.Exception" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Exception</a>, <span class=IParent>Exception</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/extent-js.html#Extent.Extent" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Extent</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/basic-js.html#mapbender.getConjunctionChar" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.Mapbender.Marker" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/exception-js.html#Notice.Notice" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>Notice</a>, <span class=IParent>Notice</span></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/point-js.html#Point.Point" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>Point</a>, <span class=IParent>Point</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.remove" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/ajax-js.html#Notification.Mapbender.Ajax.Request"  class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/ajax-js.html#Request.Mapbender.Ajax.Request" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Request.send" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/extent-js.html#Extent.set" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/extent-js.html#Extent.toString" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/exception-js.html#Warning.Warning" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>Warning</a>, <span class=IParent>Warning</span></td></tr></table>
 <!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addGlobalButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Descriptions: adds a Button to the bottom of the resultList Parameters: buttondef: {Object} an object with five properties, &ldquo;title&rdquo;, &ldquo;type&rdquo; (either button or select)  &ldquo;classes&rdquo; (the classes the button should have), &ldquo;selectoptions&rdquo; (an array in case the type is select), &ldquo;callback&rdquo;</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addPopupButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list Parameters: buttondef: {Object} an object with two properties: &ldquo;title&rdquo; and  &ldquo;callback&rdquo;, a function that gets the  feature that corresponds to the popup as it&rsquo;s argument</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt9"><div class=CFunction>Checks whether cookies are enabled in the browser</div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.createPrintBox = function ()</td></tr></table></blockquote>creates a printBox in the current view, calculates the scale (tbd. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt7"><div class=CFunction>Checks whether cookies are enabled in the browser</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var destroyPrintBox = function ()</td></tr></table></blockquote>removes an existing printBox.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt24"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt24"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt30"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt31"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt32"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt33"><div class=CFunction>Author:   Scott Severtson Description: SAXDriver is an object that basically wraps an XMLP instance, and provides an event-based interface for parsing. </div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt36"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>nodeId,</td></tr><tr><td></td><td class=PParameter nowrap>arg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var showResult = function (</td><td class=PParameter nowrap>res,</td></tr><tr><td></td><td class=PParameter nowrap>text</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt40"><div class=CFunction>Author:   Scott Severtson Description:XMLP is a pull-based parser. </div></div><div class=CToolTip id="tt41"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt42"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt43"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
 </div><!--Index-->
 <div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html">&lt;Application element name&gt;</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div></div></div></div><script type="text/javascript"><!--
 var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
-HideAllBut([7, 6, 5], 8);// --></script></div><!--Menu-->
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option></select></div></div><!--Menu-->
 <div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
Modified: trunk/mapbender/documents/api_js/index/General.html
--- trunk/mapbender/documents/api_js/index/General.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/index/General.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,72 +11,79 @@
-<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar><a href="#Symbols">$#!</a> &middot; 0-9 &middot; <a href="#A">A</a> &middot; <a href="#B">B</a> &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; <a href="#G">G</a> &middot; <a href="#H">H</a> &middot; <a href="#I">I</a> &middot; <a href="#J">J</a> &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; <a href="General2.html#O">O</a> &middot; <a href="General2.html#P">P</a> &middot; Q &middot; <a href="General2.html#R">R</a> &middot; <a href="General2.html#S">S</a> &middot; <a href="General2.html#T">T</a> &middot; <a href="General2.html#U">U</a> &middot; <a href="General2.html#V">V</a> &middot; <a href="General2.html#W">W</a> &middot; X &middot; Y &middot; <a href="General2.html#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="Symbols"></a>$#!</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(#id)"  class=ISymbol>$(&ldquo;#id&rdquo;)</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(*)"  class=ISymbol>$(*)</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>$(array)</span><div class=ISubIndex><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(array)"  class=IParent>Global</a><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(html).$(array)"  class=IParent>$(html)</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(arraylike)" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>$(arraylike)</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(expr)"  class=ISymbol>$(expr)</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(function)" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>$(function)</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_wms-php.html#Application_element_name" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>&lt;Application element name&gt;</a></td></tr><tr><td class=IHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.actualConfig" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>actualConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>AddWmsFromTree</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/button-js.html#Button" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_changeEPSG-js.html#changeEPSG" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>changeEPSG</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#conformity"  class=ISymbol>conformity</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#conformity_relation"  class=ISymbol>conformity_relation</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_cookie-js.html#cookie" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>cookie</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_coordsLookup-js.html#coordsLookup" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>coordsLookup</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#custom_category"  class=ISymbol>custom_category</a></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Database Indexes</span><div class=ISubIndex><span class=IParent>Global</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#Database_Indexes"  class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#Database_Indexes"  class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows.Database_Indexes"  class=IParent>mb_user_abo_ows</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Database Triggers</span>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.Database_Triggers"  class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.Database_Triggers"  class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_doubleclickZoom-js.html#doubleclickZoom" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>doubleclickZoom</a></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#env.1.1.rc2.js"  class=ISymbol>env.<wbr>1.1.<wbr>rc2.js</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#env.rhino.1.1.rc2.js"  class=ISymbol>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events"  class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Exception</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Exception" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Exception" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=IParent>Exception</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Extent</span><div class=ISubIndex><a href="../files/lib/extent-js.html#Extent" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=IParent>Global</a><a href="../files/lib/extent-js.html#Extent.Extent" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=IParent>Extent</a></div></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_epsg(integer)"  class=ISymbol>f_collect_epsg(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext(integer,integer)"  class=ISymbol>f_collect_searchtext(integer,integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext_wfs(integer,integer)"  class=ISymbol>f_collect_searchtext_wfs(integer,integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfs_tou(integer)"  class=ISymbol>f_getwfs_tou(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfsmodultype(integer)"  class=ISymbol>f_getwfsmodultype(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwms_tou(integer)"  class=ISymbol>f_getwms_tou(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_layer_load_count(integer)"  class=ISymbol>f_layer_load_count(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>firebug_lite</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><span class=IParent>Global</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#Functions"  class=IFile>lib/<wbr>resultGeometryListController.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#Functions"  class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#Functions"  class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div><a href="../files/lib/exception-js.html#Exception.Functions"  class=IParent>Exception</a><a href="../files/lib/extent-js.html#Extent.Functions"  class=IParent>Extent</a><a href="../files/http/javascripts/map_obj-js.html#Map.Functions"  class=IParent>Map</a><a href="../files/lib/basic-js.html#mapbender.Functions"  class=IParent>mapbender</a><a href="../files/lib/marker-js.html#Mapbender.Marker.Functions"  class=IParent>Mapbender.<wbr>Marker</a><span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.Functions"  class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.Functions"  class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div><a href="../files/lib/exception-js.html#Notice.Functions"  class=IParent>Notice</a><a href="../files/lib/ajax-js.html#Notification.Functions"  class=IParent>Notification</a><a href="../files/lib/point-js.html#Point.Functions"  class=IParent>Point</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Functions"  class=IParent>printPDF</a><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.Functions"  class=IParent>registrating_groups</a><a href="../files/http/javascripts/mod_reload-js.html#Reload.Functions"  class=IParent>Reload</a><a href="../files/lib/ajax-js.html#Request.Functions"  class=IParent>Request</a><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.Functions"  class=IParent>resultList</a><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.Functions"  class=IParent>Sandclock</a><a href="../files/lib/exception-js.html#Warning.Functions"  class=IParent>Warning</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties"  class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=ISymbol>gazetteerWFS</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.hide" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.hookForm" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>hookForm</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_i18n-js.html#i18n" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>i18n</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/sql_updates_monitoring-sql.html#idx_mb_monitor_status"  class=ISymbol>idx_mb_monitor_status</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>idx_mb_monitor_upload_id</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#idx_mb_monitor_upload_id"  class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#idx_mb_monitor_upload_id"  class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows.idx_wms_id"  class=ISymbol>idx_wms_id</a>, <span class=IParent>mb_user_abo_ows</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#inspire_category"  class=ISymbol>inspire_category</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#inspire_md_data"  class=ISymbol>inspire_md_data</a></td></tr><tr><td class=IHeading><a name="J"></a>J</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_datatables-js.html#jq_datatables" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>jq_datatables</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/jq_jgrowl-js.html#jq_jgrowl" id=link41 onMouseOver="ShowTip(event, 'tt41', 'link41')" onMouseOut="HideTip('tt41')" class=ISymbol>jq_jgrowl</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_ui_accordion-js.html#jq_ui_accordion" id=link42 onMouseOver="ShowTip(event, 'tt42', 'link42')" onMouseOut="HideTip('tt42')" class=ISymbol>jq_ui_accordion</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>jq_ui_effects</span><div class=ISubIndex><a href="../files/http/javascripts/jq_ui_effects-php.html#jq_ui_effects" id=link43 onMouseOver="ShowTip(event, 'tt43', 'link43')" onMouseOut="HideTip('tt43')" class=IFile>http/<wbr>javascripts/<wbr>jq_ui_effects.php</a><a href="../files/http/plugins/jq_ui_effects-js.html#jq_ui_effects" id=link44 onMouseOver="ShowTip(event, 'tt43', 'link44')" onMouseOut="HideTip('tt43')" class=IFile>http/<wbr>plugins/<wbr>jq_ui_effects.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_ui_resizable-js.html#jq_ui_resizable" id=link45 onMouseOver="ShowTip(event, 'tt44', 'link45')" onMouseOut="HideTip('tt44')" class=ISymbol>jq_ui_resizable</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#jquery.js"  class=ISymbol>jquery.js</a></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#layer_custom_category"  class=ISymbol>layer_custom_category</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#layer_inspire_category"  class=ISymbol>layer_inspire_category</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/list-js.html#List" id=link46 onMouseOver="ShowTip(event, 'tt45', 'link46')" onMouseOut="HideTip('tt45')" class=ISymbol>List</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" id=link47 onMouseOver="ShowTip(event, 'tt46', 'link47')" onMouseOut="HideTip('tt46')" class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" id=link48 onMouseOver="ShowTip(event, 'tt47', 'link48')" onMouseOut="HideTip('tt47')" class=ISymbol>Log</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Map</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" id=link49 onMouseOver="ShowTip(event, 'tt48', 'link49')" onMouseOut="HideTip('tt48')" class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link50 onMouseOver="ShowTip(event, 'tt49', 'link50')" onMouseOut="HideTip('tt49')" class=IParent>Map</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender" id=link51 onMouseOver="ShowTip(event, 'tt50', 'link51')" onMouseOut="HideTip('tt50')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link52 onMouseOver="ShowTip(event, 'tt51', 'link52')" onMouseOut="HideTip('tt51')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker" id=link53 onMouseOver="ShowTip(event, 'tt52', 'link53')" onMouseOut="HideTip('tt52')" class=ISymbol>Mapbender.<wbr>Marker</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" id=link54 onMouseOver="ShowTip(event, 'tt53', 'link54')" onMouseOut="HideTip('tt53')" class=ISymbol>mapframe1</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.Mapbender.Marker" id=link55 onMouseOver="ShowTip(event, 'tt54', 'link55')" onMouseOut="HideTip('tt54')" class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>mb_monitor_after</span>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after"  class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after"  class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>mb_monitor_after on mb_monitor</span>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after_on_mb_monitor"  class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after_on_mb_monitor"  class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" id=link56 onMouseOver="ShowTip(event, 'tt55', 'link56')" onMouseOut="HideTip('tt55')" class=ISymbol>mb_navigation</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" id=link57 onMouseOver="ShowTip(event, 'tt56', 'link57')" onMouseOut="HideTip('tt56')" class=ISymbol>mb_resultList_transferToDigitize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows"  class=ISymbol>mb_user_abo_ows</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability"  class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability"  class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" id=link58 onMouseOver="ShowTip(event, 'tt57', 'link58')" onMouseOut="HideTip('tt57')" class=ISymbol>mb_zoomIn</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" id=link59 onMouseOver="ShowTip(event, 'tt58', 'link59')" onMouseOut="HideTip('tt58')" class=ISymbol>mb_zoomOut</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" id=link60 onMouseOver="ShowTip(event, 'tt59', 'link60')" onMouseOut="HideTip('tt59')" class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" id=link61 onMouseOver="ShowTip(event, 'tt60', 'link61')" onMouseOut="HideTip('tt60')" class=ISymbol>mousewheelZoom</a></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Notice</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Notice" id=link62 onMouseOver="ShowTip(event, 'tt61', 'link62')" onMouseOut="HideTip('tt61')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Notice.Notice" id=link63 onMouseOver="ShowTip(event, 'tt62', 'link63')" onMouseOut="HideTip('tt62')" class=IParent>Notice</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Notification" id=link64 onMouseOver="ShowTip(event, 'tt63', 'link64')" onMouseOut="HideTip('tt63')" class=ISymbol>Notification</a></td></tr></table>
+<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; <a href="#B">B</a> &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; <a href="#G">G</a> &middot; H &middot; I &middot; J &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeatureCollection" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListController-js.html#addFeatureCollection_callback" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Ajax" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/button-js.html#Button" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/basic-js.html#mapbender.cloneObject" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/basic-js.html#mapbender.cookiesEnables" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/event-js.html#Event" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.events"  class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Exception</span><div class=ISubIndex><a href="../files/exception-js.html#Exception" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=IParent>Global</a><a href="../files/exception-js.html#Exception.Exception" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=IParent>Exception</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Extent</span><div class=ISubIndex><a href="../files/extent-js.html#Extent" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=IParent>Global</a><a href="../files/extent-js.html#Extent.Extent" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=IParent>Extent</a></div></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#Functions"  class=IParent>Global</a><a href="../files/exception-js.html#Exception.Functions"  class=IParent>Exception</a><a href="../files/extent-js.html#Extent.Functions"  class=IParent>Extent</a><a href="../files/basic-js.html#mapbender.Functions"  class=IParent>mapbender</a><a href="../files/marker-js.html#Mapbender.Marker.Functions"  class=IParent>Mapbender.<wbr>Marker</a><a href="../files/exception-js.html#Notice.Functions"  class=IParent>Notice</a><a href="../files/ajax-js.html#Notification.Functions"  class=IParent>Notification</a><a href="../files/point-js.html#Point.Functions"  class=IParent>Point</a><a href="../files/ajax-js.html#Request.Functions"  class=IParent>Request</a><a href="../files/exception-js.html#Warning.Functions"  class=IParent>Warning</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties"  class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/basic-js.html#mapbender.getConjunctionChar" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/list-js.html#List" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>List</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/basic-js.html#mapbender" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>Mapbender.<wbr>Marker</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.Mapbender.Marker" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Notice</span><div class=ISubIndex><a href="../files/exception-js.html#Notice" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=IParent>Global</a><a href="../files/exception-js.html#Notice.Notice" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=IParent>Notice</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Notification" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>Notification</a></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Point</span><div class=ISubIndex><a href="../files/point-js.html#Point" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=IParent>Global</a><a href="../files/point-js.html#Point.Point" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=IParent>Point</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Ajax.Properties"  class=ISymbol>Properties</a>, <span class=IParent>Ajax</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.remove" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/ajax-js.html#Request" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=IParent>Global</a><a href="../files/ajax-js.html#Notification.Mapbender.Ajax.Request"  class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/ajax-js.html#Request.Mapbender.Ajax.Request" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Ajax.requestCount" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListController-js.html#resultGeometryListController.js"  class=ISymbol>resultGeometryListController.js</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>ResultGeometryListModel</span><div class=ISubIndex><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Request.send" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/extent-js.html#Extent.set" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/extent-js.html#Extent.toString" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Warning</span><div class=ISubIndex><a href="../files/exception-js.html#Warning" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=IParent>Global</a><a href="../files/exception-js.html#Warning.Warning" id=link41 onMouseOver="ShowTip(event, 'tt41', 'link41')" onMouseOut="HideTip('tt41')" class=IParent>Warning</a></div></td></tr></table>
 <!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CVariable>Watch for when an array-like object is passed as the selector</div></div><div class=CToolTip id="tt2"><div class=CVariable>Shortcut for document ready</div></div><div class=CToolTip id="tt3"><div class=CClass>A description</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><div class=CToolTip id="tt6"><div class=CClass>An AJAX wrapper for client server interaction via JSON RPC</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt4"><div class=CProperty>object, holds the actual configuration after loading the json file</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addGlobalButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Descriptions: adds a Button to the bottom of the resultList Parameters: buttondef: {Object} an object with five properties, &ldquo;title&rdquo;, &ldquo;type&rdquo; (either button or select)  &ldquo;classes&rdquo; (the classes the button should have), &ldquo;selectoptions&rdquo; (an array in case the type is select), &ldquo;callback&rdquo;</div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addPopupButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list Parameters: buttondef: {Object} an object with two properties: &ldquo;title&rdquo; and  &ldquo;callback&rdquo;, a function that gets the  feature that corresponds to the popup as it&rsquo;s argument</div></div><div class=CToolTip id="tt12"><div class=CClass>Add a WMS from a container. </div></div><div class=CToolTip id="tt13"><div class=CClass>An AJAX wrapper for client server interaction via JSON RPC</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt7"><div class=CClass>Adds a clickable button to Mapbender</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt14"><div class=CClass>Adds a clickable button to Mapbender</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt9"><div class=CFunction>Checks whether cookies are enabled in the browser</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt15"><div class=CClass>Select a spatial reference system EPSG code. </div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt17"><div class=CClass>Sets a cookie after each map request. </div></div><div class=CToolTip id="tt18"><div class=CFunction>Checks whether cookies are enabled in the browser</div></div><div class=CToolTip id="tt19"><div class=CClass>The user enters a coordinate tuple and selects the corresponding SRS from a select box. </div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.createPrintBox = function ()</td></tr></table></blockquote>creates a printBox in the current view, calculates the scale (tbd. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var destroyPrintBox = function ()</td></tr></table></blockquote>removes an existing printBox.</div></div><div class=CToolTip id="tt24"><div class=CClass>Adds behaviour to maps specified in the target field. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt12"><div class=CClass>An event. </div></div><div class=CToolTip id="tt13"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CClass>An extent is also known as a bounding box.</div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt25"><div class=CClass>An event. </div></div><div class=CToolTip id="tt26"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt28"><div class=CClass>An extent is also known as a bounding box.</div></div><div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt30"><div class=CClass>Simply includes the Firebug lite JavaScript and CSS</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt31"><div class=CClass>A WFS gazetteer for pre configured WFS configurations.</div></div><div class=CToolTip id="tt32"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt33"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt36"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt20"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt21"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt22"><div class=CClass>A very basic marker class. </div></div><div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt39"><div class=CClass>Internationalization module, collects data from all elements and sends them to the server in a single POST request. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt24"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt26"><div class=CClass>An AJAX notification (it doesn&rsquo;t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt40"><div class=CClass>Includes the jQuery plugin datatables, use like this</div></div><div class=CToolTip id="tt41"><div class=CClass>The container for the jQuery plugin jGrowl</div></div><div class=CToolTip id="tt42"><div class=CClass>Accordion from the jQuery UI framework</div></div><div class=CToolTip id="tt43"><div class=CClass>A collection of jQuery UI effects</div></div><div class=CToolTip id="tt44"><div class=CClass>Resizable from the jQuery UI framework</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt27"><div class=CClass>A class representing a two- (or three-) dimensional point.</div></div><div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt45"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><div class=CToolTip id="tt46"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><div class=CToolTip id="tt47"><div class=CClass>Logs the accesses to the guis in the database or a logfile The accesses will be written in the mapbender database on table mb_log or into mapbender/log/mb_access_$DATE.log. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt30"><div class=CClass>An AJAX request (it expects a reply from the server)</div></div><div class=CToolTip id="tt31"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt32"><div class=CProperty>counts the number of requests that have been made</div></div><div class=CToolTip id="tt33"><div class=CClass>A feature collection of a result geometry list.</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt48"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt49"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt50"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt51"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt52"><div class=CClass>A very basic marker class. </div></div><div class=CToolTip id="tt53"><div class=CClass>The main map in Mapbender</div></div><div class=CToolTip id="tt54"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt55"><div class=CClass>Adds navigation arrows on top of the map</div></div><div class=CToolTip id="tt56"><div class=CClass>A description</div></div><div class=CToolTip id="tt57"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt58"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><div class=CToolTip id="tt59"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><div class=CToolTip id="tt60"><div class=CClass>Zoom in/out with the mousewheel. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt36"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt61"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt62"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt63"><div class=CClass>An AJAX notification (it doesn&rsquo;t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><!--END_ND_TOOLTIPS-->
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt40"><div class=CClass>Logs an warning in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt41"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
 </div><!--Index-->
 <div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html">&lt;Application element name&gt;</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div></div></div></div><script type="text/javascript"><!--
 var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
-HideAllBut([7, 6, 5], 8);// --></script></div><!--Menu-->
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option></select></div></div><!--Menu-->
 <div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
Modified: trunk/mapbender/documents/api_js/index/Properties.html
--- trunk/mapbender/documents/api_js/index/Properties.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/index/Properties.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,36 +11,23 @@
-<div id=Index><div class=IPageTitle>Property Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; C &middot; D &middot; <a href="#E">E</a> &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; L &middot; M &middot; N &middot; <a href="#O">O</a> &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.actualConfig" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>actualConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events"  class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.events.onFormReset" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>onFormReset</a>, <span class=IParent>gazetteerWFS.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.events.onWfsConfSelect" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>onWfsConfSelect</a>, <span class=IParent>gazetteerWFS.<wbr>events</span></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.printBox" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>printBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></td></tr></table>
+<div id=Index><div class=IPageTitle>Property Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; D &middot; <a href="#E">E</a> &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; L &middot; M &middot; N &middot; O &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.events"  class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/ajax-js.html#Ajax.requestCount" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></td></tr></table>
-<div class=CToolTip id="tt1"><div class=CProperty>object, holds the actual configuration after loading the json file</div></div><!--END_ND_TOOLTIPS-->
-<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt2"><div class=CProperty>event is fired whenever the form is resetted</div></div><div class=CToolTip id="tt3"><div class=CProperty>event is fired whenever a new WFS is selected</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CProperty>counts the number of requests that have been made</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt4"><div class=CProperty>the movable printframe</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt5"><div class=CProperty>counts the number of requests that have been made</div></div><!--END_ND_TOOLTIPS-->
 </div><!--Index-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html">&lt;Application element name&gt;</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Properties</div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Properties</div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index.html
--- trunk/mapbender/documents/api_js/index.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/index.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -1 +1 @@
-<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/http/javascripts/mod_addWMSfromTree-js.html"></head></html>
\ No newline at end of file
+<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/ajax-js.html"></head></html>
Modified: trunk/mapbender/documents/api_js/javascript/searchdata.js
--- trunk/mapbender/documents/api_js/javascript/searchdata.js	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/javascript/searchdata.js	2010-02-24 16:13:30 UTC (rev 5639)
@@ -29,36 +29,6 @@
       "Y": false,
       "Z": true
-   "Variables": {
-      "Symbols": true,
-      "Numbers": false,
-      "A": false,
-      "B": false,
-      "C": false,
-      "D": false,
-      "E": false,
-      "F": false,
-      "G": false,
-      "H": false,
-      "I": false,
-      "J": false,
-      "K": false,
-      "L": false,
-      "M": false,
-      "N": false,
-      "O": false,
-      "P": false,
-      "Q": false,
-      "R": false,
-      "S": false,
-      "T": false,
-      "U": false,
-      "V": false,
-      "W": false,
-      "X": false,
-      "Y": false,
-      "Z": false
    "Functions": {
       "Symbols": false,
       "Numbers": false,
@@ -67,13 +37,13 @@
       "C": true,
       "D": true,
       "E": true,
-      "F": true,
+      "F": false,
       "G": true,
-      "H": true,
+      "H": false,
       "I": false,
       "J": false,
       "K": false,
-      "L": true,
+      "L": false,
       "M": true,
       "N": true,
       "O": false,
@@ -96,36 +66,6 @@
       "B": false,
       "C": false,
       "D": false,
-      "E": true,
-      "F": false,
-      "G": false,
-      "H": false,
-      "I": false,
-      "J": true,
-      "K": false,
-      "L": false,
-      "M": false,
-      "N": false,
-      "O": false,
-      "P": false,
-      "Q": false,
-      "R": true,
-      "S": true,
-      "T": false,
-      "U": true,
-      "V": false,
-      "W": false,
-      "X": false,
-      "Y": false,
-      "Z": false
-   "DatabaseViews": {
-      "Symbols": false,
-      "Numbers": false,
-      "A": false,
-      "B": false,
-      "C": false,
-      "D": false,
       "E": false,
       "F": false,
       "G": false,
@@ -140,36 +80,6 @@
       "P": false,
       "Q": false,
       "R": true,
-      "S": true,
-      "T": false,
-      "U": false,
-      "V": false,
-      "W": false,
-      "X": false,
-      "Y": false,
-      "Z": false
-   "DatabaseIndexes": {
-      "Symbols": false,
-      "Numbers": false,
-      "A": false,
-      "B": false,
-      "C": false,
-      "D": false,
-      "E": false,
-      "F": false,
-      "G": false,
-      "H": false,
-      "I": true,
-      "J": false,
-      "K": false,
-      "L": false,
-      "M": false,
-      "N": false,
-      "O": false,
-      "P": false,
-      "Q": false,
-      "R": false,
       "S": false,
       "T": false,
       "U": false,
@@ -179,92 +89,32 @@
       "Y": false,
       "Z": false
-   "DatabaseTables": {
+   "Classes": {
       "Symbols": false,
       "Numbers": false,
-      "A": false,
-      "B": false,
-      "C": true,
-      "D": false,
-      "E": false,
-      "F": false,
-      "G": false,
-      "H": false,
-      "I": true,
-      "J": false,
-      "K": false,
-      "L": true,
-      "M": true,
-      "N": false,
-      "O": false,
-      "P": false,
-      "Q": false,
-      "R": false,
-      "S": false,
-      "T": false,
-      "U": false,
-      "V": false,
-      "W": true,
-      "X": false,
-      "Y": false,
-      "Z": false
-   "Classes": {
-      "Symbols": true,
-      "Numbers": false,
       "A": true,
       "B": true,
-      "C": true,
-      "D": true,
-      "E": true,
-      "F": true,
-      "G": true,
-      "H": false,
-      "I": true,
-      "J": true,
-      "K": false,
-      "L": true,
-      "M": true,
-      "N": true,
-      "O": true,
-      "P": true,
-      "Q": false,
-      "R": true,
-      "S": true,
-      "T": true,
-      "U": false,
-      "V": false,
-      "W": true,
-      "X": false,
-      "Y": false,
-      "Z": true
-   "DatabaseTriggers": {
-      "Symbols": false,
-      "Numbers": false,
-      "A": false,
-      "B": false,
       "C": false,
       "D": false,
-      "E": false,
+      "E": true,
       "F": false,
       "G": false,
       "H": false,
       "I": false,
       "J": false,
       "K": false,
-      "L": false,
+      "L": true,
       "M": true,
-      "N": false,
+      "N": true,
       "O": false,
-      "P": false,
+      "P": true,
       "Q": false,
-      "R": false,
+      "R": true,
       "S": false,
       "T": false,
       "U": false,
       "V": false,
-      "W": false,
+      "W": true,
       "X": false,
       "Y": false,
       "Z": false
@@ -272,7 +122,7 @@
    "Properties": {
       "Symbols": false,
       "Numbers": false,
-      "A": true,
+      "A": false,
       "B": false,
       "C": false,
       "D": false,
@@ -286,8 +136,8 @@
       "L": false,
       "M": false,
       "N": false,
-      "O": true,
-      "P": true,
+      "O": false,
+      "P": false,
       "Q": false,
       "R": true,
       "S": false,
Modified: trunk/mapbender/documents/api_js/search/ClassesA.html
--- trunk/mapbender/documents/api_js/search/ClassesA.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesA.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_AddWmsFromTree><div class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" target=_parent class=ISymbol>AddWmsFromTree</a></div></div><div class=SRResult id=SR_Ajax><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax" target=_parent class=ISymbol>Ajax</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Ajax><div class=IEntry><a href="../files/ajax-js.html#Ajax" target=_parent class=ISymbol>Ajax</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
 document.getElementById("Loading").style.display="none";
 document.getElementById("NoMatches").style.display="none";
 var searchResults = new SearchResults("searchResults", "HTML");
Modified: trunk/mapbender/documents/api_js/search/ClassesB.html
--- trunk/mapbender/documents/api_js/search/ClassesB.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesB.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Button><div class=IEntry><a href="../files/lib/button-js.html#Button" target=_parent class=ISymbol>Button</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Button><div class=IEntry><a href="../files/button-js.html#Button" target=_parent class=ISymbol>Button</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesE.html
--- trunk/mapbender/documents/api_js/search/ClassesE.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesE.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/lib/exception-js.html#Exception" target=_parent class=ISymbol>Exception</a></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/lib/extent-js.html#Extent" target=_parent class=ISymbol>Extent</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/exception-js.html#Exception" target=_parent class=ISymbol>Exception</a></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/extent-js.html#Extent" target=_parent class=ISymbol>Extent</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesL.html
--- trunk/mapbender/documents/api_js/search/ClassesL.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesL.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_List><div class=IEntry><a href="../files/lib/list-js.html#List" target=_parent class=ISymbol>List</a></div></div><div class=SRResult id=SR_Log><div class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" target=_parent class=ISymbol>Log</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_List><div class=IEntry><a href="../files/list-js.html#List" target=_parent class=ISymbol>List</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesM.html
--- trunk/mapbender/documents/api_js/search/ClassesM.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesM.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=ISymbol>Map</a></div></div><div class=SRResult id=SR_mapbender><div class=IEntry><a href="../files/lib/basic-js.html#mapbender" target=_parent class=ISymbol>mapbender</a></div></div><div class=SRResult id=SR2_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div><div class=SRResult id=SR_Mapbender_perMarker><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker" target=_parent class=ISymbol>Mapbender.<wbr>Marker</a></div></div><div class=SRResult id=SR_mapframe1><div class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" target=_parent class=ISymbol>mapframe1</a></div></div><div class=SRResult id=SR_mb_undnavigation><div class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" target=_parent class=ISymbol>mb_navigation</a></div></div><div class=SRResult id=SR_mb_undresultList_undtransferToDigitize><div class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" target=_parent class=ISymbol>mb_resultList_transferToDigitize</a></div></div><div class=SRResult id=SR_mb_undzoomIn><div class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" target=_parent class=ISymbol>mb_zoomIn</a></div></div><div class=SRResult id=SR_mb_undzoomOut><div class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" target=_parent class=ISymbol>mb_zoomOut</a></div></div><div class=SRResult id=SR_mousewheelZoom><div class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" target=_parent class=ISymbol>mousewheelZoom</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mapbender><div class=IEntry><a href="../files/basic-js.html#mapbender" target=_parent class=ISymbol>mapbender</a></div></div><div class=SRResult id=SR_Mapbender_perMarker><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker" target=_parent class=ISymbol>Mapbender.<wbr>Marker</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesN.html
--- trunk/mapbender/documents/api_js/search/ClassesN.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesN.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="../files/lib/exception-js.html#Notice" target=_parent class=ISymbol>Notice</a></div></div><div class=SRResult id=SR_Notification><div class=IEntry><a href="../files/lib/ajax-js.html#Notification" target=_parent class=ISymbol>Notification</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="../files/exception-js.html#Notice" target=_parent class=ISymbol>Notice</a></div></div><div class=SRResult id=SR_Notification><div class=IEntry><a href="../files/ajax-js.html#Notification" target=_parent class=ISymbol>Notification</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesP.html
--- trunk/mapbender/documents/api_js/search/ClassesP.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesP.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="../files/lib/point-js.html#Point" target=_parent class=ISymbol>Point</a></div></div><div class=SRResult id=SR_printPDF><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF" target=_parent class=ISymbol>printPDF</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="../files/point-js.html#Point" target=_parent class=ISymbol>Point</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesR.html
--- trunk/mapbender/documents/api_js/search/ClassesR.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesR.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_repaint><div class=IEntry><a href="javascript:searchResults.Toggle('SR_repaint')" class=ISymbol>repaint</a><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="../files/lib/ajax-js.html#Request" target=_parent class=ISymbol>Request</a></div></div><div class=SRResult id=SR_resize><div class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" target=_parent class=ISymbol>resize</a></div></div><div class=SRResult id=SR_ResizeMapsize><div class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" target=_parent class=ISymbol>ResizeMapsize</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a></div></div><div class=SRResult id=SR_resultList><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" target=_parent class=ISymbol>resultList</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Request><div class=IEntry><a href="../files/ajax-js.html#Request" target=_parent class=ISymbol>Request</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesW.html
--- trunk/mapbender/documents/api_js/search/ClassesW.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/ClassesW.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="../files/lib/exception-js.html#Warning" target=_parent class=ISymbol>Warning</a></div></div><div class=SRResult id=SR_wmsTimeInterval><div class=IEntry><a href="../files/http/plugins/mb_wmsTimeInterval-js.html#wmsTimeInterval" target=_parent class=ISymbol>wmsTimeInterval</a></div></div><div class=SRResult id=SR_wmsTimeSliderYear><div class=IEntry><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html#wmsTimeSliderYear" target=_parent class=ISymbol>wmsTimeSliderYear</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="../files/exception-js.html#Warning" target=_parent class=ISymbol>Warning</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FilesR.html
--- trunk/mapbender/documents/api_js/search/FilesR.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FilesR.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsA.html
--- trunk/mapbender/documents/api_js/search/FunctionsA.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsA.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_addFeature><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeature')" class=ISymbol>addFeature</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeatureCollection')" class=ISymbol>addFeatureCollection</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection_undcallback><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" target=_parent class=ISymbol>addFeatureCollection_callback</a></div></div><div class=SRResult id=SR_addGlobalButton><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" target=_parent class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></div></div><div class=SRResult id=SR_addPopupButton><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" target=_parent class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_addFeature><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeature')" class=ISymbol>addFeature</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeature" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeatureCollection')" class=ISymbol>addFeatureCollection</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeatureCollection" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection_undcallback><div class=IEntry><a href="../files/resultGeometryListController-js.html#addFeatureCollection_callback" target=_parent class=ISymbol>addFeatureCollection_callback</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsC.html
--- trunk/mapbender/documents/api_js/search/FunctionsC.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsC.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_cloneObject><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" target=_parent class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_cookiesEnables><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" target=_parent class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_createPrintBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" target=_parent class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_cloneObject><div class=IEntry><a href="../files/basic-js.html#mapbender.cloneObject" target=_parent class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_cookiesEnables><div class=IEntry><a href="../files/basic-js.html#mapbender.cookiesEnables" target=_parent class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsD.html
--- trunk/mapbender/documents/api_js/search/FunctionsD.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsD.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deleteFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" target=_parent class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_deleteFeatureCollection><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" target=_parent class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_destroyPrintBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" target=_parent class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deleteFeature><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" target=_parent class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_deleteFeatureCollection><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" target=_parent class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsE.html
--- trunk/mapbender/documents/api_js/search/FunctionsE.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsE.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/lib/exception-js.html#Exception.Exception" target=_parent class=ISymbol>Exception</a>, <span class=IParent>Exception</span></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/lib/extent-js.html#Extent.Extent" target=_parent class=ISymbol>Extent</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/exception-js.html#Exception.Exception" target=_parent class=ISymbol>Exception</a>, <span class=IParent>Exception</span></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/extent-js.html#Extent.Extent" target=_parent class=ISymbol>Extent</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsG.html
--- trunk/mapbender/documents/api_js/search/FunctionsG.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsG.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_getConjunctionChar><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" target=_parent class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_getFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" target=_parent class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getFeatureProperty><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" target=_parent class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getPDFMapSize><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" target=_parent class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_getSelected><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" target=_parent class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_getConjunctionChar><div class=IEntry><a href="../files/basic-js.html#mapbender.getConjunctionChar" target=_parent class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_getFeature><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" target=_parent class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getFeatureProperty><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" target=_parent class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsM.html
--- trunk/mapbender/documents/api_js/search/FunctionsM.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsM.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=ISymbol>Map</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_Marker><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.Mapbender.Marker" target=_parent class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></div></div><div class=SRResult id=SR_mb_undmonitor_undafter><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mb_undmonitor_undafter')" class=ISymbol>mb_monitor_after</a>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_mod_undprintPDF_undinit><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" target=_parent class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Marker><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.Mapbender.Marker" target=_parent class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsN.html
--- trunk/mapbender/documents/api_js/search/FunctionsN.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsN.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="../files/lib/exception-js.html#Notice.Notice" target=_parent class=ISymbol>Notice</a>, <span class=IParent>Notice</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="../files/exception-js.html#Notice.Notice" target=_parent class=ISymbol>Notice</a>, <span class=IParent>Notice</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsP.html
--- trunk/mapbender/documents/api_js/search/FunctionsP.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsP.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="../files/lib/point-js.html#Point.Point" target=_parent class=ISymbol>Point</a>, <span class=IParent>Point</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="../files/point-js.html#Point.Point" target=_parent class=ISymbol>Point</a>, <span class=IParent>Point</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsR.html
--- trunk/mapbender/documents/api_js/search/FunctionsR.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsR.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsS.html
--- trunk/mapbender/documents/api_js/search/FunctionsS.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsS.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_SAXDriver><div class=IEntry><a href="javascript:searchResults.Toggle('SR_SAXDriver')" class=ISymbol>SAXDriver</a><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#SAXDriver" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#SAXDriver" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div></div><div class=SRResult id=SR_send><div class=IEntry><a href="../files/lib/ajax-js.html#Request.send" target=_parent class=ISymbol>send</a>, <span class=IParent>Request</span></div></div><div class=SRResult id=SR_set><div class=IEntry><a href="../files/lib/extent-js.html#Extent.set" target=_parent class=ISymbol>set</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_setFeatureProperty><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" target=_parent class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div><div class=SRResult id=SR_showResult><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" target=_parent class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_send><div class=IEntry><a href="../files/ajax-js.html#Request.send" target=_parent class=ISymbol>send</a>, <span class=IParent>Request</span></div></div><div class=SRResult id=SR_set><div class=IEntry><a href="../files/extent-js.html#Extent.set" target=_parent class=ISymbol>set</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_setFeatureProperty><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" target=_parent class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsT.html
--- trunk/mapbender/documents/api_js/search/FunctionsT.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsT.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_this_spcis_spcthe_spcconstructor_spcto_spcthe_spcXMLP_spcObject><div class=IEntry><a href="javascript:searchResults.Toggle('SR_this_spcis_spcthe_spcconstructor_spcto_spcthe_spcXMLP_spcObject')" class=ISymbol>this is the constructor to the XMLP Object</a><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div></div><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsU.html
--- trunk/mapbender/documents/api_js/search/FunctionsU.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsU.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_updateFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" target=_parent class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_updateFeature><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" target=_parent class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsW.html
--- trunk/mapbender/documents/api_js/search/FunctionsW.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/FunctionsW.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="../files/lib/exception-js.html#Warning.Warning" target=_parent class=ISymbol>Warning</a>, <span class=IParent>Warning</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="../files/exception-js.html#Warning.Warning" target=_parent class=ISymbol>Warning</a>, <span class=IParent>Warning</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralA.html
--- trunk/mapbender/documents/api_js/search/GeneralA.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralA.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_actualConfig><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.actualConfig" target=_parent class=ISymbol>actualConfig</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_addFeature><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeature')" class=ISymbol>addFeature</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeatureCollection')" class=ISymbol>addFeatureCollection</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection_undcallback><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" target=_parent class=ISymbol>addFeatureCollection_callback</a></div></div><div class=SRResult id=SR_addGlobalButton><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" target=_parent class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></div></div><div class=SRResult id=SR_addPopupButton><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" target=_parent class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></div></div><div class=SRResult id=SR_AddWmsFromTree><div class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" target=_parent class=ISymbol>AddWmsFromTree</a></div></div><div class=SRResult id=SR_Ajax><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax" target=_parent class=ISymbol>Ajax</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_addFeature><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeature')" class=ISymbol>addFeature</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeature" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeatureCollection')" class=ISymbol>addFeatureCollection</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeatureCollection" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection_undcallback><div class=IEntry><a href="../files/resultGeometryListController-js.html#addFeatureCollection_callback" target=_parent class=ISymbol>addFeatureCollection_callback</a></div></div><div class=SRResult id=SR_Ajax><div class=IEntry><a href="../files/ajax-js.html#Ajax" target=_parent class=ISymbol>Ajax</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralB.html
--- trunk/mapbender/documents/api_js/search/GeneralB.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralB.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
Modified: trunk/mapbender/documents/api_js/search/GeneralC.html
--- trunk/mapbender/documents/api_js/search/GeneralC.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralC.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_changeEPSG><div class=IEntry><a href="../files/http/javascripts/mod_changeEPSG-js.html#changeEPSG" target=_parent class=ISymbol>changeEPSG</a></div></div><div class=SRResult id=SR_cloneObject><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" target=_parent class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_conformity><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#conformity" target=_parent class=ISymbol>conformity</a></div></div><div class=SRResult id=SR_conformity_undrelation><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#conformity_relation" target=_parent class=ISymbol>conformity_relation</a></div></div><div class=SRResult id=SR_cookie><div class=IEntry><a href="../files/http/plugins/mb_cookie-js.html#cookie" target=_parent class=ISymbol>cookie</a></div></div><div class=SRResult id=SR_cookiesEnables><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" target=_parent class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_coordsLookup><div class=IEntry><a href="../files/http/javascripts/mod_coordsLookup-js.html#coordsLookup" target=_parent class=ISymbol>coordsLookup</a></div></div><div class=SRResult id=SR_createPrintBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" target=_parent class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_custom_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#custom_category" target=_parent class=ISymbol>custom_category</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralD.html
--- trunk/mapbender/documents/api_js/search/GeneralD.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralD.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Database_spcIndexes><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Database_spcIndexes')" class=ISymbol>Database Indexes</a><div class=ISubIndex><span class=IParent>Global</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#Database_Indexes" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#Database_Indexes" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows.Database_Indexes" target=_parent class=IParent>mb_user_abo_ows</a></div></div></div><div class=SRResult id=SR_Database_spcTriggers><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Database_spcTriggers')" class=ISymbol>Database Triggers</a>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.Database_Triggers" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.Database_Triggers" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_deleteFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" target=_parent class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_deleteFeatureCollection><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" target=_parent class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_destroyPrintBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" target=_parent class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_doubleclickZoom><div class=IEntry><a href="../files/http/javascripts/mod_doubleclickZoom-js.html#doubleclickZoom" target=_parent class=ISymbol>doubleclickZoom</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralE.html
--- trunk/mapbender/documents/api_js/search/GeneralE.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralE.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_env_per1_per1_perrc2_perjs><div class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#env.1.1.rc2.js" target=_parent class=ISymbol>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=SRResult id=SR_env_perrhino_per1_per1_perrc2_perjs><div class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#env.rhino.1.1.rc2.js" target=_parent class=ISymbol>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_events><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Exception')" class=ISymbol>Exception</a><div class=ISubIndex><a href="../files/lib/exception-js.html#Exception" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Exception" target=_parent class=IParent>Exception</a></div></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Extent')" class=ISymbol>Extent</a><div class=ISubIndex><a href="../files/lib/extent-js.html#Extent" target=_parent class=IParent>Global</a><a href="../files/lib/extent-js.html#Extent.Extent" target=_parent class=IParent>Extent</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_events><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Exception')" class=ISymbol>Exception</a><div class=ISubIndex><a href="../files/exception-js.html#Exception" target=_parent class=IParent>Global</a><a href="../files/exception-js.html#Exception.Exception" target=_parent class=IParent>Exception</a></div></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Extent')" class=ISymbol>Extent</a><div class=ISubIndex><a href="../files/extent-js.html#Extent" target=_parent class=IParent>Global</a><a href="../files/extent-js.html#Extent.Extent" target=_parent class=IParent>Extent</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralF.html
--- trunk/mapbender/documents/api_js/search/GeneralF.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralF.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_f_undcollect_undepsg_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_epsg(integer)" target=_parent class=ISymbol>f_collect_epsg(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undcollect_undsearchtext_lpainteger_cominteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext(integer,integer)" target=_parent class=ISymbol>f_collect_searchtext(integer,integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undcollect_undsearchtext_undwfs_lpainteger_cominteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext_wfs(integer,integer)" target=_parent class=ISymbol>f_collect_searchtext_wfs(integer,integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undgetwfs_undtou_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfs_tou(integer)" target=_parent class=ISymbol>f_getwfs_tou(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undgetwfsmodultype_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfsmodultype(integer)" target=_parent class=ISymbol>f_getwfsmodultype(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undgetwms_undtou_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwms_tou(integer)" target=_parent class=ISymbol>f_getwms_tou(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undlayer_undload_undcount_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_layer_load_count(integer)" target=_parent class=ISymbol>f_layer_load_count(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_firebug_undlite><div class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" target=_parent class=ISymbol>firebug_lite</a></div></div><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><span class=IParent>Global</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#Functions" target=_parent class=IFile>lib/<wbr>resultGeometryListController.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#Functions" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#Functions" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div><a href="../files/lib/exception-js.html#Exception.Functions" target=_parent class=IParent>Exception</a><a href="../files/lib/extent-js.html#Extent.Functions" target=_parent class=IParent>Extent</a><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" target=_parent class=IParent>Map</a><a href="../files/lib/basic-js.html#mapbender.Functions" target=_parent class=IParent>mapbender</a><a href="../files/lib/marker-js.html#Mapbender.Marker.Functions" target=_parent class=IParent>Mapbender.<wbr>Marker</a><span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.Functions" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.Functions" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div><a href="../files/lib/exception-js.html#Notice.Functions" target=_parent class=IParent>Notice</a><a href="../files/lib/ajax-js.html#Notification.Functions" target=_parent class=IParent>Notification</a><a href="../files/lib/point-js.html#Point.Functions" target=_parent class=IParent>Point</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Functions" target=_parent class=IParent>printPDF</a><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.Functions" target=_parent class=IParent>registrating_groups</a><a href="../files/http/javascripts/mod_reload-js.html#Reload.Functions" target=_parent class=IParent>Reload</a><a href="../files/lib/ajax-js.html#Request.Functions" target=_parent class=IParent>Request</a><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.Functions" target=_parent class=IParent>resultList</a><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.Functions" target=_parent class=IParent>Sandclock</a><a href="../files/lib/exception-js.html#Warning.Functions" target=_parent class=IParent>Warning</a></div></div></div><div class=SRResult id=SR_Functions_spcand_spcProperties><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties" target=_parent class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#Functions" target=_parent class=IParent>Global</a><a href="../files/exception-js.html#Exception.Functions" target=_parent class=IParent>Exception</a><a href="../files/extent-js.html#Extent.Functions" target=_parent class=IParent>Extent</a><a href="../files/basic-js.html#mapbender.Functions" target=_parent class=IParent>mapbender</a><a href="../files/marker-js.html#Mapbender.Marker.Functions" target=_parent class=IParent>Mapbender.<wbr>Marker</a><a href="../files/exception-js.html#Notice.Functions" target=_parent class=IParent>Notice</a><a href="../files/ajax-js.html#Notification.Functions" target=_parent class=IParent>Notification</a><a href="../files/point-js.html#Point.Functions" target=_parent class=IParent>Point</a><a href="../files/ajax-js.html#Request.Functions" target=_parent class=IParent>Request</a><a href="../files/exception-js.html#Warning.Functions" target=_parent class=IParent>Warning</a></div></div></div><div class=SRResult id=SR_Functions_spcand_spcProperties><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties" target=_parent class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
 document.getElementById("Loading").style.display="none";
 document.getElementById("NoMatches").style.display="none";
 var searchResults = new SearchResults("searchResults", "HTML");
Modified: trunk/mapbender/documents/api_js/search/GeneralG.html
--- trunk/mapbender/documents/api_js/search/GeneralG.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralG.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_gazetteerWFS><div class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS" target=_parent class=ISymbol>gazetteerWFS</a></div></div><div class=SRResult id=SR_getConjunctionChar><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" target=_parent class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_getFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" target=_parent class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getFeatureProperty><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" target=_parent class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getPDFMapSize><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" target=_parent class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_getSelected><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" target=_parent class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralL.html
--- trunk/mapbender/documents/api_js/search/GeneralL.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralL.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_layer_undcustom_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#layer_custom_category" target=_parent class=ISymbol>layer_custom_category</a></div></div><div class=SRResult id=SR_layer_undinspire_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#layer_inspire_category" target=_parent class=ISymbol>layer_inspire_category</a></div></div><div class=SRResult id=SR_List><div class=IEntry><a href="../files/lib/list-js.html#List" target=_parent class=ISymbol>List</a></div></div><div class=SRResult id=SR_loadConfig><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" target=_parent class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_Log><div class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" target=_parent class=ISymbol>Log</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_List><div class=IEntry><a href="../files/list-js.html#List" target=_parent class=ISymbol>List</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralM.html
--- trunk/mapbender/documents/api_js/search/GeneralM.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralM.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Map')" class=ISymbol>Map</a><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=IParent>Map</a></div></div></div><div class=SRResult id=SR_mapbender><div class=IEntry><a href="../files/lib/basic-js.html#mapbender" target=_parent class=ISymbol>mapbender</a></div></div><div class=SRResult id=SR2_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div><div class=SRResult id=SR_Mapbender_perMarker><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker" target=_parent class=ISymbol>Mapbender.<wbr>Marker</a></div></div><div class=SRResult id=SR_mapframe1><div class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" target=_parent class=ISymbol>mapframe1</a></div></div><div class=SRResult id=SR_Marker><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.Mapbender.Marker" target=_parent class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></div></div><div class=SRResult id=SR_mb_undmonitor_undafter><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mb_undmonitor_undafter')" class=ISymbol>mb_monitor_after</a>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_mb_undmonitor_undafter_spcon_spcmb_undmonitor><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mb_undmonitor_undafter_spcon_spcmb_undmonitor')" class=ISymbol>mb_monitor_after on mb_monitor</a>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after_on_mb_monitor" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after_on_mb_monitor" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_mb_undnavigation><div class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" target=_parent class=ISymbol>mb_navigation</a></div></div><div class=SRResult id=SR_mb_undresultList_undtransferToDigitize><div class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" target=_parent class=ISymbol>mb_resultList_transferToDigitize</a></div></div><div class=SRResult id=SR_mb_unduser_undabo_undows><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows" target=_parent class=ISymbol>mb_user_abo_ows</a></div></div><div class=SRResult id=SR_mb_undwms_undavailability><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mb_undwms_undavailability')" class=ISymbol>mb_wms_availability</a><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_mb_undzoomIn><div class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" target=_parent class=ISymbol>mb_zoomIn</a></div></div><div class=SRResult id=SR_mb_undzoomOut><div class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" target=_parent class=ISymbol>mb_zoomOut</a></div></div><div class=SRResult id=SR_mod_undprintPDF_undinit><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" target=_parent class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_mousewheelZoom><div class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" target=_parent class=ISymbol>mousewheelZoom</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mapbender><div class=IEntry><a href="../files/basic-js.html#mapbender" target=_parent class=ISymbol>mapbender</a></div></div><div class=SRResult id=SR_Mapbender_perMarker><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker" target=_parent class=ISymbol>Mapbender.<wbr>Marker</a></div></div><div class=SRResult id=SR_Marker><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.Mapbender.Marker" target=_parent class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralN.html
--- trunk/mapbender/documents/api_js/search/GeneralN.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralN.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Notice')" class=ISymbol>Notice</a><div class=ISubIndex><a href="../files/lib/exception-js.html#Notice" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Notice.Notice" target=_parent class=IParent>Notice</a></div></div></div><div class=SRResult id=SR_Notification><div class=IEntry><a href="../files/lib/ajax-js.html#Notification" target=_parent class=ISymbol>Notification</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Notice')" class=ISymbol>Notice</a><div class=ISubIndex><a href="../files/exception-js.html#Notice" target=_parent class=IParent>Global</a><a href="../files/exception-js.html#Notice.Notice" target=_parent class=IParent>Notice</a></div></div></div><div class=SRResult id=SR_Notification><div class=IEntry><a href="../files/ajax-js.html#Notification" target=_parent class=ISymbol>Notification</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralP.html
--- trunk/mapbender/documents/api_js/search/GeneralP.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralP.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Point')" class=ISymbol>Point</a><div class=ISubIndex><a href="../files/lib/point-js.html#Point" target=_parent class=IParent>Global</a><a href="../files/lib/point-js.html#Point.Point" target=_parent class=IParent>Point</a></div></div></div><div class=SRResult id=SR_printBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.printBox" target=_parent class=ISymbol>printBox</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_printPDF><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF" target=_parent class=ISymbol>printPDF</a></div></div><div class=SRResult id=SR_Properties><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Properties')" class=ISymbol>Properties</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Ajax.Properties" target=_parent class=IParent>Ajax</a><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.Properties" target=_parent class=IParent>gazetteerWFS</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Properties" target=_parent class=IParent>printPDF</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Point')" class=ISymbol>Point</a><div class=ISubIndex><a href="../files/point-js.html#Point" target=_parent class=IParent>Global</a><a href="../files/point-js.html#Point.Point" target=_parent class=IParent>Point</a></div></div></div><div class=SRResult id=SR_Properties><div class=IEntry><a href="../files/ajax-js.html#Ajax.Properties" target=_parent class=ISymbol>Properties</a>, <span class=IParent>Ajax</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralR.html
--- trunk/mapbender/documents/api_js/search/GeneralR.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralR.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_registrating_undgroups><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups" target=_parent class=ISymbol>registrating_groups</a></div></div><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR2_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></div></div><div class=SRResult id=SR_repaint><div class=IEntry><a href="javascript:searchResults.Toggle('SR_repaint')" class=ISymbol>repaint</a><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Request" target=_parent class=IParent>Global</a><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div><div class=SRResult id=SR_resize><div class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" target=_parent class=ISymbol>resize</a></div></div><div class=SRResult id=SR_ResizeMapsize><div class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" target=_parent class=ISymbol>ResizeMapsize</a></div></div><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="javascript:searchResults.Toggle('SR_ResultGeometryListModel')" class=ISymbol>ResultGeometryListModel</a><div class=ISubIndex><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_resultList><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" target=_parent class=ISymbol>resultList</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/ajax-js.html#Request" target=_parent class=IParent>Global</a><a href="../files/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="javascript:searchResults.Toggle('SR_ResultGeometryListModel')" class=ISymbol>ResultGeometryListModel</a><div class=ISubIndex><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralS.html
--- trunk/mapbender/documents/api_js/search/GeneralS.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralS.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Sandclock><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock" target=_parent class=ISymbol>Sandclock</a></div></div><div class=SRResult id=SR_savewmc><div class=IEntry><a href="../files/http/javascripts/mod_savewmc-js.html#savewmc" target=_parent class=ISymbol>savewmc</a></div></div><div class=SRResult id=SR_SAXDriver><div class=IEntry><a href="javascript:searchResults.Toggle('SR_SAXDriver')" class=ISymbol>SAXDriver</a><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#SAXDriver" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#SAXDriver" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div></div><div class=SRResult id=SR_scalebar><div class=IEntry><a href="../files/http/javascripts/mod_scalebar-js.html#scalebar" target=_parent class=ISymbol>scalebar</a></div></div><div class=SRResult id=SR_search_undwfs_undview><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#search_wfs_view" target=_parent class=ISymbol>search_wfs_view</a></div></div><div class=SRResult id=SR_search_undwms_undview><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#search_wms_view" target=_parent class=ISymbol>search_wms_view</a></div></div><div class=SRResult id=SR_selArea><div class=IEntry><a href="javascript:searchResults.Toggle('SR_selArea')" class=ISymbol>selArea</a><div class=ISubIndex><a href="../files/http/javascripts/mod_pan-js.html#selArea" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_pan.js</a><a href="../files/http/javascripts/mod_selArea-js.html#selArea" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_selArea.js</a></div></div></div><div class=SRResult id=SR_selectMapsize><div class=IEntry><a href="../files/http/plugins/mb_selectMapsize-js.html#selectMapsize" target=_parent class=ISymbol>selectMapsize</a></div></div><div class=SRResult id=SR_send><div class=IEntry><a href="../files/lib/ajax-js.html#Request.send" target=_parent class=ISymbol>send</a>, <span class=IParent>Request</span></div></div><div class=SRResult id=SR_set><div class=IEntry><a href="../files/lib/extent-js.html#Extent.set" target=_parent class=ISymbol>set</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_setFeatureProperty><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" target=_parent class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div><div class=SRResult id=SR_showResult><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" target=_parent class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_sql_undupdates_undmonitoring_persql><div class=IEntry><a href="../files/resources/db/sql_updates_monitoring-sql.html#sql_updates_monitoring.sql" target=_parent class=ISymbol>sql_updates_monitoring.sql</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralT.html
--- trunk/mapbender/documents/api_js/search/GeneralT.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralT.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_tabs_undvertical><div class=IEntry><a href="../files/http/plugins/mb_tabs_vertical-js.html#tabs_vertical" target=_parent class=ISymbol>tabs_vertical</a></div></div><div class=SRResult id=SR_this_spcis_spcthe_spcconstructor_spcto_spcthe_spcXMLP_spcObject><div class=IEntry><a href="javascript:searchResults.Toggle('SR_this_spcis_spcthe_spcconstructor_spcto_spcthe_spcXMLP_spcObject')" class=ISymbol>this is the constructor to the XMLP Object</a><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div></div><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_twitter_undsignin><div class=IEntry><a href="../files/http/plugins/mb_twitter_signin-js.html#twitter_signin" target=_parent class=ISymbol>twitter_signin</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralU.html
--- trunk/mapbender/documents/api_js/search/GeneralU.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralU.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_update_und2_per6_per1_undto_und2_per7rc1_undpgsql_undUTF_min8_persql><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql" target=_parent class=ISymbol>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=SRResult id=SR_updateFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" target=_parent class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralW.html
--- trunk/mapbender/documents/api_js/search/GeneralW.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/GeneralW.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Warning')" class=ISymbol>Warning</a><div class=ISubIndex><a href="../files/lib/exception-js.html#Warning" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Warning.Warning" target=_parent class=IParent>Warning</a></div></div></div><div class=SRResult id=SR_wfs_undfeaturetype_undcustom_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#wfs_featuretype_custom_category" target=_parent class=ISymbol>wfs_featuretype_custom_category</a></div></div><div class=SRResult id=SR_wfs_undfeaturetype_undinspire_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#wfs_featuretype_inspire_category" target=_parent class=ISymbol>wfs_featuretype_inspire_category</a></div></div><div class=SRResult id=SR_wfs_undfeaturetype_undmd_undtopic_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#wfs_featuretype_md_topic_category" target=_parent class=ISymbol>wfs_featuretype_md_topic_category</a></div></div><div class=SRResult id=SR_wmsTimeInterval><div class=IEntry><a href="../files/http/plugins/mb_wmsTimeInterval-js.html#wmsTimeInterval" target=_parent class=ISymbol>wmsTimeInterval</a></div></div><div class=SRResult id=SR_wmsTimeSliderYear><div class=IEntry><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html#wmsTimeSliderYear" target=_parent class=ISymbol>wmsTimeSliderYear</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Warning')" class=ISymbol>Warning</a><div class=ISubIndex><a href="../files/exception-js.html#Warning" target=_parent class=IParent>Global</a><a href="../files/exception-js.html#Warning.Warning" target=_parent class=IParent>Warning</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/PropertiesE.html
--- trunk/mapbender/documents/api_js/search/PropertiesE.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/PropertiesE.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_events><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_events><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/PropertiesR.html
--- trunk/mapbender/documents/api_js/search/PropertiesR.html	2010-02-24 16:11:28 UTC (rev 5638)
+++ trunk/mapbender/documents/api_js/search/PropertiesR.html	2010-02-24 16:13:30 UTC (rev 5639)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
More information about the Mapbender_commits mailing list
