[Mapbender-commits] r5640 - in trunk/mapbender/documents/api_js: .
Data index javascript search
svn_mapbender at osgeo.org
Wed Feb 24 11:16:02 EST 2010
Author: christoph
Date: 2010-02-24 11:16:02 -0500 (Wed, 24 Feb 2010)
New Revision: 5640
Added:
trunk/mapbender/documents/api_js/Menu_Backup_3.txt
trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
trunk/mapbender/documents/api_js/Data/FileInfo.nd
trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd
trunk/mapbender/documents/api_js/Data/IndexInfo.nd
trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
trunk/mapbender/documents/api_js/Data/PreviousSettings.nd
trunk/mapbender/documents/api_js/Data/SymbolTable.nd
trunk/mapbender/documents/api_js/Menu.txt
trunk/mapbender/documents/api_js/index.html
trunk/mapbender/documents/api_js/index/Classes.html
trunk/mapbender/documents/api_js/index/DatabaseIndexes.html
trunk/mapbender/documents/api_js/index/DatabaseTables.html
trunk/mapbender/documents/api_js/index/DatabaseTriggers.html
trunk/mapbender/documents/api_js/index/DatabaseViews.html
trunk/mapbender/documents/api_js/index/Files.html
trunk/mapbender/documents/api_js/index/Functions.html
trunk/mapbender/documents/api_js/index/General.html
trunk/mapbender/documents/api_js/index/General2.html
trunk/mapbender/documents/api_js/index/Properties.html
trunk/mapbender/documents/api_js/index/Variables.html
trunk/mapbender/documents/api_js/javascript/searchdata.js
trunk/mapbender/documents/api_js/search/ClassesA.html
trunk/mapbender/documents/api_js/search/ClassesB.html
trunk/mapbender/documents/api_js/search/ClassesE.html
trunk/mapbender/documents/api_js/search/ClassesL.html
trunk/mapbender/documents/api_js/search/ClassesM.html
trunk/mapbender/documents/api_js/search/ClassesN.html
trunk/mapbender/documents/api_js/search/ClassesP.html
trunk/mapbender/documents/api_js/search/ClassesR.html
trunk/mapbender/documents/api_js/search/ClassesW.html
trunk/mapbender/documents/api_js/search/FilesR.html
trunk/mapbender/documents/api_js/search/FunctionsA.html
trunk/mapbender/documents/api_js/search/FunctionsC.html
trunk/mapbender/documents/api_js/search/FunctionsD.html
trunk/mapbender/documents/api_js/search/FunctionsE.html
trunk/mapbender/documents/api_js/search/FunctionsG.html
trunk/mapbender/documents/api_js/search/FunctionsM.html
trunk/mapbender/documents/api_js/search/FunctionsN.html
trunk/mapbender/documents/api_js/search/FunctionsP.html
trunk/mapbender/documents/api_js/search/FunctionsR.html
trunk/mapbender/documents/api_js/search/FunctionsS.html
trunk/mapbender/documents/api_js/search/FunctionsT.html
trunk/mapbender/documents/api_js/search/FunctionsU.html
trunk/mapbender/documents/api_js/search/FunctionsW.html
trunk/mapbender/documents/api_js/search/GeneralA.html
trunk/mapbender/documents/api_js/search/GeneralB.html
trunk/mapbender/documents/api_js/search/GeneralC.html
trunk/mapbender/documents/api_js/search/GeneralD.html
trunk/mapbender/documents/api_js/search/GeneralE.html
trunk/mapbender/documents/api_js/search/GeneralF.html
trunk/mapbender/documents/api_js/search/GeneralG.html
trunk/mapbender/documents/api_js/search/GeneralL.html
trunk/mapbender/documents/api_js/search/GeneralM.html
trunk/mapbender/documents/api_js/search/GeneralN.html
trunk/mapbender/documents/api_js/search/GeneralP.html
trunk/mapbender/documents/api_js/search/GeneralR.html
trunk/mapbender/documents/api_js/search/GeneralS.html
trunk/mapbender/documents/api_js/search/GeneralT.html
trunk/mapbender/documents/api_js/search/GeneralU.html
trunk/mapbender/documents/api_js/search/GeneralW.html
trunk/mapbender/documents/api_js/search/PropertiesE.html
trunk/mapbender/documents/api_js/search/PropertiesR.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
(Binary files differ)
Modified: trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
Modified: trunk/mapbender/documents/api_js/Data/FileInfo.nd
--- trunk/mapbender/documents/api_js/Data/FileInfo.nd 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/Data/FileInfo.nd 2010-02-24 16:16:02 UTC (rev 5640)
@@ -1,34 +1,907 @@
1.4
-JavaScript
-/home/cbaudson/workspace/trunk/lib/history.js 1257779030 0 /home/cbaudson/workspace/trunk/lib/history.js
-/home/cbaudson/workspace/trunk/lib/point.js 1263903572 1 Point
-/home/cbaudson/workspace/trunk/lib/class_Mapbender.php 1247654252 0 /home/cbaudson/workspace/trunk/lib/class_Mapbender.php
+PHP
+/home/cbaudson/workspace/trunk/sql/update_wfs_conf.sql 1246284046 0 /home/cbaudson/workspace/trunk/sql/update_wfs_conf.sql
+/home/cbaudson/workspace/trunk/http/php/mod_user_group.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_user_group.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql 1246284071 0 /home/cbaudson/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql
+/home/cbaudson/workspace/trunk/http/sld/classes/LabelPlacement.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/LabelPlacement.php
+/home/cbaudson/workspace/trunk/lib/resizableButton.js 1246284050 0 /home/cbaudson/workspace/trunk/lib/resizableButton.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_selectMapsize.js 1260530974 1 selectMapsize
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/call-load-test.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/call-load-test.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/__global__.js
+/home/cbaudson/workspace/trunk/http/php/mod_editGuiWmsMeta.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_editGuiWmsMeta.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_dynamicOverview.php 1258024545 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_dynamicOverview.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xmltoken.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xmltoken.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/document.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/document.js
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.2_to_2.4.3_pgsql_UTF-8.sql 1258538852 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.2_to_2.4.3_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Main.java 1267021291 0 /home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Main.java
+/home/cbaudson/workspace/trunk/http/sld/sld_function_getusersld.php 1246283960 0 /home/cbaudson/workspace/trunk/http/sld/sld_function_getusersld.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/console/console.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/console/console.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/iframe.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/iframe.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_print.js 1267021306 1 printPDF
+/home/cbaudson/workspace/trunk/test/tools/env-js/bin/prototype_1.6.0.3_tmpl.txt 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/bin/prototype_1.6.0.3_tmpl.txt
+/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js 1246612355 1 Reload
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/onload.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/onload.js
+/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql 1246284070 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_html.php 1246283960 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_html.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_owsproxy.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_owsproxy.php
+/home/cbaudson/workspace/trunk/http/plugins/jq_upload.php 1257345660 0 /home/cbaudson/workspace/trunk/http/plugins/jq_upload.php
+/home/cbaudson/workspace/trunk/http/classes/class_gml_multipoint.php 1253260684 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_multipoint.php
+/home/cbaudson/workspace/trunk/http/classes/class_gml_envelope.php 1246284044 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_envelope.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/readme.txt 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/readme.txt
+/home/cbaudson/workspace/trunk/http/classes/class_element.php 1261564131 0 /home/cbaudson/workspace/trunk/http/classes/class_element.php
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php
+/home/cbaudson/workspace/trunk/http/classes/class_checkInput.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_checkInput.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jquery.js 1267021297 1 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jquery.js
+/home/cbaudson/workspace/trunk/http/javascripts/popupballon.js 1253096390 0 /home/cbaudson/workspace/trunk/http/javascripts/popupballon.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.1.1.rc2.js 1267021305 1 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.1.1.rc2.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/test/xpath_script.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/test/xpath_script.js
+/home/cbaudson/workspace/trunk/http/php/mod_customTree_server.php 1259141716 0 /home/cbaudson/workspace/trunk/http/php/mod_customTree_server.php
+/home/cbaudson/workspace/trunk/http/php/mod_loadWFSCapabilities.php 1247129681 0 /home/cbaudson/workspace/trunk/http/php/mod_loadWFSCapabilities.php
+/home/cbaudson/workspace/trunk/tools/wms_extent/wms_geometry.sql 1246284046 0 /home/cbaudson/workspace/trunk/tools/wms_extent/wms_geometry.sql
+/home/cbaudson/workspace/trunk/http/classes/class_wfs.php 1248255824 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs.php
+/home/cbaudson/workspace/trunk/http/php/mod_gui_group.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gui_group.php
+/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilities.php 1260538916 0 /home/cbaudson/workspace/trunk/http/php/mod_loadCapabilities.php
+/home/cbaudson/workspace/trunk/http/classes/class_metadata.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_metadata.php
+/home/cbaudson/workspace/trunk/tools/mod_mailAbo.php 1249461424 0 /home/cbaudson/workspace/trunk/tools/mod_mailAbo.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleHint.php 1246460709 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_scaleHint.php
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_edit.php 1253875191 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_edit.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/doc/jquery-compatibility.txt 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/doc/jquery-compatibility.txt
+/home/cbaudson/workspace/trunk/Readme.txt 1246284075 0 /home/cbaudson/workspace/trunk/Readme.txt
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/uievent.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/uievent.js
+/home/cbaudson/workspace/trunk/http/classes/class_mb_exception.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_mb_exception.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/form.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/form.js
+/home/cbaudson/workspace/trunk/http/php/mod_editElements.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_editElements.php
+/home/cbaudson/workspace/trunk/http/plugins/jq_ui_resizable.js 1264753743 1 jq_ui_resizable
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.pretty.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.pretty.js
+/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2Image.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_weldMaps2Image.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_twitter_signin.js 1267021306 1 twitter_signin
+/home/cbaudson/workspace/trunk/http/php/mod_download.php 1260538915 0 /home/cbaudson/workspace/trunk/http/php/mod_download.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Global.java 1267021291 0 /home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Global.java
+/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsBetween.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsBetween.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/a.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/a.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/timer.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/timer.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jss.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jss.js
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_gazetteer_server.php 1263903612 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_gazetteer_server.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_back.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_back.php
+/home/cbaudson/workspace/trunk/http/sld/classes/GraphicStroke.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/GraphicStroke.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/elementmembers.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/elementmembers.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_wfs_gazetteer_client.php 1267026796 1 gazetteerWFS
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/body.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/body.js
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_client.php 1257421140 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_client.php
+/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php
+/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js 1267021307 1 Map
+/home/cbaudson/workspace/trunk/http/php/mod_loadCatalogToGUI.php 1261565743 0 /home/cbaudson/workspace/trunk/http/php/mod_loadCatalogToGUI.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_coords.php 1253875316 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_coords.php
+/home/cbaudson/workspace/trunk/http/php/mod_digitize_splitPolygon.php 1263296626 0 /home/cbaudson/workspace/trunk/http/php/mod_digitize_splitPolygon.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/html/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/html/boot.js
+/home/cbaudson/workspace/trunk/http/php/mod_simpleWMSpreferences.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_simpleWMSpreferences.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php
+/home/cbaudson/workspace/trunk/license/license.txt 1246284047 0 /home/cbaudson/workspace/trunk/license/license.txt
+/home/cbaudson/workspace/trunk/lib/database-mysqli.php 1253874627 0 /home/cbaudson/workspace/trunk/lib/database-mysqli.php
+/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsLike.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsLike.php
+/home/cbaudson/workspace/trunk/http/php/mod_renameGUI.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_renameGUI.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/xmlserializer.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/xmlserializer.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/label.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/label.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/window.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/window.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/event/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/event/boot.js
+/home/cbaudson/workspace/trunk/http/php/mod_loadwms.php 1253875191 0 /home/cbaudson/workspace/trunk/http/php/mod_loadwms.php
+/home/cbaudson/workspace/trunk/tools/mapbender_setup.php 1267021391 0 /home/cbaudson/workspace/trunk/tools/mapbender_setup.php
+/home/cbaudson/workspace/trunk/http/sld/sld_edit_filter.php 1246283960 0 /home/cbaudson/workspace/trunk/http/sld/sld_edit_filter.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.rhino.1.1.rc2.js 1267021305 1 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.rhino.1.1.rc2.js
+/home/cbaudson/workspace/trunk/lib/marker.js 1267027600 1 Mapbender.Marker
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/document.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/document.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_help.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_help.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromList.php 1255602947 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromList.php
+/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read_single_diff.php 1246284046 0 /home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read_single_diff.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/domparser.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/domparser.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/mouseevents.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/mouseevents.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeInterval.js 1262680107 1 wmsTimeInterval
+/home/cbaudson/workspace/trunk/http/javascripts/core.php 1263474573 1 Mapbender
+/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities.php 1248077682 0 /home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/window.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/window.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_forward.php 1247751995 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_forward.php
+/home/cbaudson/workspace/trunk/http/php/mod_saveWKT.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_saveWKT.php
+/home/cbaudson/workspace/trunk/http/sld/sld_filter_parse.php 1246283960 0 /home/cbaudson/workspace/trunk/http/sld/sld_filter_parse.php
+/home/cbaudson/workspace/trunk/http/javascripts/wfs_obj.js 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/wfs_obj.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_mapstraction.php 1263824745 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_mapstraction.php
+/home/cbaudson/workspace/trunk/http/php/mod_getStyles.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_getStyles.php
+/home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromXML.php 1256201565 0 /home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromXML.php
+/home/cbaudson/workspace/trunk/http/sld/classes/TextSymbolizer.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/TextSymbolizer.php
+/home/cbaudson/workspace/trunk/http/include/dyn_css.php 1246283960 0 /home/cbaudson/workspace/trunk/http/include/dyn_css.php
+/home/cbaudson/workspace/trunk/http/sld/classes/DbUtils.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/DbUtils.php
+/home/cbaudson/workspace/trunk/http/classes/class_gml_multipolygon.php 1253605799 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_multipolygon.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql 1246284075 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/__global__.js
+/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql 1246284071 0 /home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/php/mod_forgottenPassword.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_forgottenPassword.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/jqUnit.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/jqUnit.js
+/home/cbaudson/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql 1253874935 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/http/php/wms.php 1251966344 0 /home/cbaudson/workspace/trunk/http/php/wms.php
+/home/cbaudson/workspace/trunk/http/php/mod_WMSpreferences.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_WMSpreferences.php
+/home/cbaudson/workspace/trunk/http/php/mod_createCategory.php 1246283966 0 /home/cbaudson/workspace/trunk/http/php/mod_createCategory.php
+/home/cbaudson/workspace/trunk/http/classes/class_ows_factory.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_ows_factory.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql 1253874941 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/http/classes/class_gml_polygon.php 1253605811 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_polygon.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js 1267021307 1 overviewToggle
+/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql 1253874935 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_0.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_0.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js 1263477108 1 repaint
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt
+/home/cbaudson/workspace/trunk/http/plugins/ol_overview.js 1262789894 1 ol_overviewMap
+/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql 1246284069 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql
+/home/cbaudson/workspace/trunk/http/classes/class_rss.php 1253194681 0 /home/cbaudson/workspace/trunk/http/classes/class_rss.php
+/home/cbaudson/workspace/trunk/http/classes/class_kml_parser_ows.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_parser_ows.php
+/home/cbaudson/workspace/trunk/http/classes/class_point.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_point.php
+/home/cbaudson/workspace/trunk/http/sld/classes/Displacement.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Displacement.php
+/home/cbaudson/workspace/trunk/http/sld/sld_pick_color.php 1246283960 0 /home/cbaudson/workspace/trunk/http/sld/sld_pick_color.php
+/home/cbaudson/workspace/trunk/http/sld/classes/LineSymbolizer.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/LineSymbolizer.php
+/home/cbaudson/workspace/trunk/lib/saveButton.js 1246284055 0 /home/cbaudson/workspace/trunk/lib/saveButton.js
+/home/cbaudson/workspace/trunk/http/plugins/ol_mousePosition.js 1262789894 1 ol_mousePosition
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/html/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/html/spec.js
+/home/cbaudson/workspace/trunk/http/plugins/ol_panZoomBar.js 1262789894 1 ol_panZoomBar
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/param.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/param.js
+/home/cbaudson/workspace/trunk/http/php/mod_button_tooltips.php 1246283966 0 /home/cbaudson/workspace/trunk/http/php/mod_button_tooltips.php
+/home/cbaudson/workspace/trunk/http/classes/class_weldOverview2PNG.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_weldOverview2PNG.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_coordsLookup.js 1252674785 1 coordsLookup
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/sizzle.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/sizzle.js
+/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql 1246284071 0 /home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/sld/classes/Filter.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Filter.php
+/home/cbaudson/workspace/trunk/http/php/mb_validateSession.php 1263903311 0 /home/cbaudson/workspace/trunk/http/php/mb_validateSession.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql 1259847974 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql 1246284075 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/php/mod_group_filteredGui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_group_filteredGui.php
+/home/cbaudson/workspace/trunk/log/ReadMe.txt 1250169174 0 /home/cbaudson/workspace/trunk/log/ReadMe.txt
+/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMS.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_addWMS.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/xslt.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/xslt.js
+/home/cbaudson/workspace/trunk/lib/list.js 1263903580 1 List
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/navigator.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/window/navigator.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/timer/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/timer/boot.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql 1246284075 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql 1259847971 0 /home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
+/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql 1246284073 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/document.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/document.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/parser/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/parser/boot.js
+/home/cbaudson/workspace/trunk/http/php/mod_editUser.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_editUser.php
+/home/cbaudson/workspace/trunk/http/classes/class_georss_geometry.php 1258987433 0 /home/cbaudson/workspace/trunk/http/classes/class_georss_geometry.php
+/home/cbaudson/workspace/trunk/http/php/mod_showLoggedUser.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_showLoggedUser.php
+/home/cbaudson/workspace/trunk/http/classes/class_kml_polygon.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_polygon.php
+/home/cbaudson/workspace/trunk/lib/alignButton.js 1263903550 0 /home/cbaudson/workspace/trunk/lib/alignButton.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.backup.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.backup.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_cookie.js 1267021306 1 cookie
+/home/cbaudson/workspace/trunk/lib/core.js 1263903586 0 /home/cbaudson/workspace/trunk/lib/core.js
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql 1246284075 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/php/mod_coordsLookup_server.php 1251986996 0 /home/cbaudson/workspace/trunk/http/php/mod_coordsLookup_server.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomOut1.js 1255602947 1 ZoomOut1
+/home/cbaudson/workspace/trunk/http/sld/classes/DisplayOperationModule.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/DisplayOperationModule.php
+/home/cbaudson/workspace/trunk/test/http/classes/MbNoticeTest.php 1255606944 0 /home/cbaudson/workspace/trunk/test/http/classes/MbNoticeTest.php
+/home/cbaudson/workspace/trunk/http/php/mod_digitize_differencePolygon.php 1246283960 0 /home/cbaudson/workspace/trunk/http/php/mod_digitize_differencePolygon.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/vendor/prototype-1.6.0.3.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/vendor/prototype-1.6.0.3.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_3.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_3.js
+/home/cbaudson/workspace/trunk/http/plugins/jq_ui_datepicker.js 1264752979 0 /home/cbaudson/workspace/trunk/http/plugins/jq_ui_datepicker.js
+/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_User.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_User.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/__global__.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/__global__.js
+/home/cbaudson/workspace/trunk/http/print/mod_printPDF_pdf.php 1259847977 0 /home/cbaudson/workspace/trunk/http/print/mod_printPDF_pdf.php
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_1_factory.php 1246284044 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_1_1_factory.php
+/home/cbaudson/workspace/trunk/http/classes/class.pdf.php 1251986925 0 /home/cbaudson/workspace/trunk/http/classes/class.pdf.php
+/home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php 1262603806 0 /home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php
+/home/cbaudson/workspace/trunk/http/classes/class_administration.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_administration.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_saveWKT.js 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_saveWKT.js
+/home/cbaudson/workspace/trunk/lib/event.js 1267021316 1 Event
+/home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeSliderYear.js 1261043062 1 wmsTimeSliderYear
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/form.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/form.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_saveWmcKml.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_saveWmcKml.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.4_to_2.4.5_pgsql_UTF-8.sql 1258538852 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.4_to_2.4.5_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/php/mod_user_filteredGui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_user_filteredGui.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/window.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/window.js
+/home/cbaudson/workspace/trunk/http/plugins/jq_ui_slider.js 1264753022 0 /home/cbaudson/workspace/trunk/http/plugins/jq_ui_slider.js
+/home/cbaudson/workspace/trunk/http/print/classes/mbPdf.php 1263998515 0 /home/cbaudson/workspace/trunk/http/print/classes/mbPdf.php
+/home/cbaudson/workspace/trunk/http/include/preliminary_logo_splash.php 1261563955 0 /home/cbaudson/workspace/trunk/http/include/preliminary_logo_splash.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/settings.js 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/settings.js
+/home/cbaudson/workspace/trunk/http/javascripts/group.php 1249653424 0 /home/cbaudson/workspace/trunk/http/javascripts/group.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_ResultList.js 1267021307 1 resultList
+/home/cbaudson/workspace/trunk/http/javascripts/mod_dependentIframe.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_dependentIframe.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/fieldset.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/fieldset.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/nu.validator.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/nu.validator.js
+/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_filteredGui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredUser_filteredGui.php
+/home/cbaudson/workspace/trunk/http/plugins/ol_keyboardDefaults.js 1262789894 1 ol_keyboardDefaults
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/profile/profile.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/profile/profile.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/simplelog.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/simplelog.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/variables_0.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/variables_0.js
+/home/cbaudson/workspace/trunk/http/javascripts/popup.js 1257430427 0 /home/cbaudson/workspace/trunk/http/javascripts/popup.js
+/home/cbaudson/workspace/trunk/http/include/gui1_splash.php 1255602884 0 /home/cbaudson/workspace/trunk/http/include/gui1_splash.php
+/home/cbaudson/workspace/trunk/http/javascripts/jq_jgrowl.js 1261488139 1 jq_jgrowl
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/head.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/head.js
+/home/cbaudson/workspace/trunk/http/frames/index.php 1263903619 0 /home/cbaudson/workspace/trunk/http/frames/index.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/dom/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/dom/spec.js
+/home/cbaudson/workspace/trunk/sql/update_wfs_conf_element.sql 1246284046 0 /home/cbaudson/workspace/trunk/sql/update_wfs_conf_element.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/css/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/css/spec.js
+/home/cbaudson/workspace/trunk/tools/update.php 1261402205 0 /home/cbaudson/workspace/trunk/tools/update.php
+/home/cbaudson/workspace/trunk/http/php/mod_digitize_splitLine.php 1263296597 0 /home/cbaudson/workspace/trunk/http/php/mod_digitize_splitLine.php
+/home/cbaudson/workspace/trunk/http/classes/class_gml_point.php 1253605804 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_point.php
+/home/cbaudson/workspace/trunk/http/classes/class_gml_2_factory.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_2_factory.php
+/home/cbaudson/workspace/trunk/resources/db/log_sequences.txt 1246373944 0 /home/cbaudson/workspace/trunk/resources/db/log_sequences.txt
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/function_declarations.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/function_declarations.js
+/home/cbaudson/workspace/trunk/http/classes/class_gml_2.php 1246284044 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_2.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql 1253874941 0 /home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/php/mod_editWMS_Metadata.php 1252598016 0 /home/cbaudson/workspace/trunk/http/php/mod_editWMS_Metadata.php
+/home/cbaudson/workspace/trunk/http_auth/http/index.php 1251986234 0 /home/cbaudson/workspace/trunk/http_auth/http/index.php
+/home/cbaudson/workspace/trunk/http/html/mod_treefolder.php 1246283960 0 /home/cbaudson/workspace/trunk/http/html/mod_treefolder.php
+/home/cbaudson/workspace/trunk/http/include/template_splash.php 1255602885 0 /home/cbaudson/workspace/trunk/http/include/template_splash.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_6.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_6.js
+/home/cbaudson/workspace/trunk/http/php/mod_editFilteredGroup.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_editFilteredGroup.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/prototypecompat.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/prototypecompat.js
+/home/cbaudson/workspace/trunk/http/php/mod_editElementVars.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_editElementVars.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js 1261489065 1 mousewheelZoom
+/home/cbaudson/workspace/trunk/http/plugins/jq_ui_accordion.js 1264752984 1 jq_ui_accordion
+/home/cbaudson/workspace/trunk/http/print/classes/mbLegendDecorator.php 1267021310 0 /home/cbaudson/workspace/trunk/http/print/classes/mbLegendDecorator.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/timer.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/timer.js
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_result.php 1255948404 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_result.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_horizTabs.js 1246283985 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_horizTabs.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_setVendorspecific.js 1267021306 0 /home/cbaudson/workspace/trunk/http/plugins/mb_resultList_setVendorspecific.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/element.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/element.js
+/home/cbaudson/workspace/trunk/http/include/dyn_js_object.php 1249379412 0 /home/cbaudson/workspace/trunk/http/include/dyn_js_object.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_transferToDigitize.js 1264752560 1 mb_resultList_transferToDigitize
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/dom.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/dom.js
+/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql 1246284073 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/script_error.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/script_error.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/properties.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/properties.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js
+/home/cbaudson/workspace/trunk/resources/db/log_update.txt 1246373945 0 /home/cbaudson/workspace/trunk/resources/db/log_update.txt
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/attr.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/attr.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/platform/rhino.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/platform/rhino.js
+/home/cbaudson/workspace/trunk/http/php/mod_category_filteredGUI.php 1246283960 0 /home/cbaudson/workspace/trunk/http/php/mod_category_filteredGUI.php
+/home/cbaudson/workspace/trunk/http/php/mod_callMetadata.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_callMetadata.php
+/home/cbaudson/workspace/trunk/http/php/mod_zoomCoords.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_zoomCoords.php
+/home/cbaudson/workspace/trunk/http/javascripts/ConfEditor.js 1255602947 0 /home/cbaudson/workspace/trunk/http/javascripts/ConfEditor.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/legend.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/legend.js
+/home/cbaudson/workspace/trunk/http/sld/classes/Halo.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Halo.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql 1253874941 0 /home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/php/mod_showGuiName.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_showGuiName.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/namespace.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/namespace.js
+/home/cbaudson/workspace/trunk/http/sld/sld_parse.php 1246283960 0 /home/cbaudson/workspace/trunk/http/sld/sld_parse.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/processinginstruction.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/processinginstruction.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_legend.js 1257240138 0 /home/cbaudson/workspace/trunk/http/plugins/mb_legend.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_resize.js 1264753809 1 resize
+/home/cbaudson/workspace/trunk/http/print/print_functions.php 1246284035 0 /home/cbaudson/workspace/trunk/http/print/print_functions.php
+/home/cbaudson/workspace/trunk/core/globalSettings.php 1263995829 0 /home/cbaudson/workspace/trunk/core/globalSettings.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/css.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/css.js
+/home/cbaudson/workspace/trunk/http/php/mod_user_filteredGroup.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_user_filteredGroup.php
+/home/cbaudson/workspace/trunk/http/classes/class_gml_3.php 1246284044 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_3.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/blockquote-q.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/blockquote-q.js
+/home/cbaudson/workspace/trunk/http/frames/cleanurl.php 1246284046 0 /home/cbaudson/workspace/trunk/http/frames/cleanurl.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js 1246605598 1 Log
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/test.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/test.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/collection.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/collection.js
+/home/cbaudson/workspace/trunk/http/classes/class_georss.php 1253189338 0 /home/cbaudson/workspace/trunk/http/classes/class_georss.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/html.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/html.js
+/home/cbaudson/workspace/trunk/http/sld/classes/GraphicFill.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/GraphicFill.php
+/home/cbaudson/workspace/trunk/http/sld/classes/ElseFilter.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/ElseFilter.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/changelog.txt 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/changelog.txt
+/home/cbaudson/workspace/trunk/http/php/mod_gui_filteredGroup.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gui_filteredGroup.php
+/home/cbaudson/workspace/trunk/http/javascripts/ConfObject.js 1249653447 0 /home/cbaudson/workspace/trunk/http/javascripts/ConfObject.js
+/home/cbaudson/workspace/trunk/http/php/mod_group_filteredUser.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_group_filteredUser.php
+/home/cbaudson/workspace/trunk/owsproxy/http/index.php 1251896391 0 /home/cbaudson/workspace/trunk/owsproxy/http/index.php
+/home/cbaudson/workspace/trunk/http/php/mod_savewmc_server.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_savewmc_server.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/string_declarations.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/string_declarations.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.3.2-test.js 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.3.2-test.js
+/home/cbaudson/workspace/trunk/http/sld/classes/Font.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Font.php
+/home/cbaudson/workspace/trunk/http/classes/class_metadata_new.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_metadata_new.php
/home/cbaudson/workspace/trunk/lib/printbox.js 1264003357 0 /home/cbaudson/workspace/trunk/lib/printbox.js
+/home/cbaudson/workspace/trunk/http/classes/class_universal_gml_factory.php 1262789163 0 /home/cbaudson/workspace/trunk/http/classes/class_universal_gml_factory.php
/home/cbaudson/workspace/trunk/lib/ajax.js 1263903566 1 Ajax
+/home/cbaudson/workspace/trunk/http/sld/classes/UnaryLogicOp.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/UnaryLogicOp.php
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_1.php 1253605983 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_1_1.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/title.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/title.js
+/home/cbaudson/workspace/trunk/license/simplified_bsd.txt 1246284047 0 /home/cbaudson/workspace/trunk/license/simplified_bsd.txt
+/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_write.php 1249473920 0 /home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_write.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/entity.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/entity.js
+/home/cbaudson/workspace/trunk/http/php/mod_editSelf.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_editSelf.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_history_back.js 1257780613 0 /home/cbaudson/workspace/trunk/http/plugins/mb_history_back.js
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql 1246284075 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/frame.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/window/frame.js
+/home/cbaudson/workspace/trunk/Install.txt 1263995835 0 /home/cbaudson/workspace/trunk/Install.txt
+/home/cbaudson/workspace/trunk/http/include/dyn_js.php 1246283960 0 /home/cbaudson/workspace/trunk/http/include/dyn_js.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/window/__global__.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php 1264003337 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/console/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/console/spec.js
+/home/cbaudson/workspace/trunk/http/frames/login.php 1256112146 0 /home/cbaudson/workspace/trunk/http/frames/login.php
+/home/cbaudson/workspace/trunk/http/sld/sld_main.php 1246283960 0 /home/cbaudson/workspace/trunk/http/sld/sld_main.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_setTimeout.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_setTimeout.php
+/home/cbaudson/workspace/trunk/http/php/mod_gazetteer_conf.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gazetteer_conf.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_displayWmc.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_displayWmc.php
+/home/cbaudson/workspace/trunk/http/php/mod_updateKmlInDb.php 1253705934 0 /home/cbaudson/workspace/trunk/http/php/mod_updateKmlInDb.php
+/home/cbaudson/workspace/trunk/lib/class_Mapbender_session.php 1267021316 0 /home/cbaudson/workspace/trunk/lib/class_Mapbender_session.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/map.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/map.js
+/home/cbaudson/workspace/trunk/test/tools/testframework.js 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/testframework.js
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_configuration.php 1259847969 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_configuration.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_digitize_tab.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_digitize_tab.php
+/home/cbaudson/workspace/trunk/http/php/mod_group_gui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_group_gui.php
+/home/cbaudson/workspace/trunk/http/javascripts/map.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/map.php
+/home/cbaudson/workspace/trunk/http/print/printPDF_download.php 1267021310 0 /home/cbaudson/workspace/trunk/http/print/printPDF_download.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/xhr.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/xhr.js
+/home/cbaudson/workspace/trunk/http/classes/class_wfsToDb.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_wfsToDb.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_i18n.js 1263395373 1 i18n
+/home/cbaudson/workspace/trunk/http/javascripts/mod_coords_div.php 1253875315 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_coords_div.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/option.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/option.js
+/home/cbaudson/workspace/trunk/http/php/output.txt 1249476135 0 /home/cbaudson/workspace/trunk/http/php/output.txt
+/home/cbaudson/workspace/trunk/http/javascripts/mod_perimeter.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_perimeter.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/script.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/script.js
+/home/cbaudson/workspace/trunk/http/classes/class_kml_placemark.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_placemark.php
+/home/cbaudson/workspace/trunk/http/sld/classes/LegendGraphic.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/LegendGraphic.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_loadKML.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_loadKML.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_group.js 1255602947 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_group.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/element.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/element.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/xmlhttprequest.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/xmlhttprequest.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_CSWFunctions.js 1261565985 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_CSWFunctions.js
+/home/cbaudson/workspace/trunk/http/javascripts/send_post.php 1246284046 0 /home/cbaudson/workspace/trunk/http/javascripts/send_post.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xmltoken_unittest.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xmltoken_unittest.js
+/home/cbaudson/workspace/trunk/http/classes/class_kml_linearring.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_linearring.php
+/home/cbaudson/workspace/trunk/http/classes/class_locale.php 1256902107 0 /home/cbaudson/workspace/trunk/http/classes/class_locale.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/input-elements.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/input-elements.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/div.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/div.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_zoomIn.js 1257239887 1 mb_zoomIn
+/home/cbaudson/workspace/trunk/http/javascripts/mod_displayObj.js 1247730584 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_displayObj.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_legend.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_legend.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_mapstraction.js 1263824738 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_mapstraction.js
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_server.php 1253705999 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_server.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/frame.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/frame.js
+/home/cbaudson/workspace/trunk/http/php/mod_customTree.php 1258120186 0 /home/cbaudson/workspace/trunk/http/php/mod_customTree.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql 1246284071 0 /home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/php/mod_gazLayerObj_conf.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gazLayerObj_conf.php
+/home/cbaudson/workspace/trunk/http/classes/class_mb_log.php 1257521428 0 /home/cbaudson/workspace/trunk/http/classes/class_mb_log.php
+/home/cbaudson/workspace/trunk/http/classes/class_rss_item.php 1253192526 0 /home/cbaudson/workspace/trunk/http/classes/class_rss_item.php
+/home/cbaudson/workspace/trunk/http/javascripts/wfs.php 1263288120 0 /home/cbaudson/workspace/trunk/http/javascripts/wfs.php
+/home/cbaudson/workspace/trunk/http/plugins/jq_upload.js 1267021306 0 /home/cbaudson/workspace/trunk/http/plugins/jq_upload.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/canvas.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/canvas.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/events.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/events.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/timer/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/timer/__global__.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php
+/home/cbaudson/workspace/trunk/http/php/mb_listKMLs.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mb_listKMLs.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/prototype-test.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/prototype-test.js
+/home/cbaudson/workspace/trunk/http/php/mod_featuretypeMetadata.php 1246283960 0 /home/cbaudson/workspace/trunk/http/php/mod_featuretypeMetadata.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/__global__.js
+/home/cbaudson/workspace/trunk/http/php/mod_loadwmc_server.php 1258104820 0 /home/cbaudson/workspace/trunk/http/php/mod_loadwmc_server.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/__global__.js
+/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql 1246284073 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/http/php/mod_editApplication.php 1253875137 0 /home/cbaudson/workspace/trunk/http/php/mod_editApplication.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/window.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/window/window.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js 1251460890 1 AddWmsFromTree
+/home/cbaudson/workspace/trunk/http/php/mod_echoFileUpload.php 1260280340 0 /home/cbaudson/workspace/trunk/http/php/mod_echoFileUpload.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php 1257420068 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php
+/home/cbaudson/workspace/trunk/http/javascripts/gui.php 1249653444 0 /home/cbaudson/workspace/trunk/http/javascripts/gui.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql 1255606925 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/col-colgroup.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/col-colgroup.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/keyboardevents.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/keyboardevents.js
+/home/cbaudson/workspace/trunk/test/http/classes/GroupTest.php 1255606944 0 /home/cbaudson/workspace/trunk/test/http/classes/GroupTest.php
+/home/cbaudson/workspace/trunk/http/php/mod_log.php 1246636499 0 /home/cbaudson/workspace/trunk/http/php/mod_log.php
+/home/cbaudson/workspace/trunk/http/sld/classes/Mark.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Mark.php
+/home/cbaudson/workspace/trunk/http/html/mod_sync_treefolder.php 1246283960 0 /home/cbaudson/workspace/trunk/http/html/mod_sync_treefolder.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/link.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/link.js
+/home/cbaudson/workspace/trunk/http/php/mod_treefolder2_l10n.php 1257425334 0 /home/cbaudson/workspace/trunk/http/php/mod_treefolder2_l10n.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/mouseevent.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/mouseevent.js
+/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_User.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredGui_User.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Proxy.java 1267021291 0 /home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Proxy.java
+/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_PrintPreview.js 1260538909 0 /home/cbaudson/workspace/trunk/http/plugins/mb_resultList_PrintPreview.js
+/home/cbaudson/workspace/trunk/http/sld/classes/CssParameter.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/CssParameter.php
+/home/cbaudson/workspace/trunk/http/sld/sld_config.php 1246283960 0 /home/cbaudson/workspace/trunk/http/sld/sld_config.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_overview.js 1263996078 1 Overview
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/namednodemap.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/namednodemap.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/env.qunit.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/env.qunit.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php 1247660161 1 repaint
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/xhr.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/xhr.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_map.js 1267021306 1 mapframe1
+/home/cbaudson/workspace/trunk/http/sld/classes/Fill.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Fill.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/cdatasection.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/cdatasection.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/qunit/qunit/qunit.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/qunit/qunit/qunit.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_poi.php 1256661476 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_poi.php
+/home/cbaudson/workspace/trunk/http/sld/classes/ColorMap.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/ColorMap.php
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_gazetteer_l10n.php 1257424605 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_gazetteer_l10n.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_2.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_2.js
+/home/cbaudson/workspace/trunk/http/classes/class_kml.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/licenses/GPL-LICENSE.txt 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/licenses/GPL-LICENSE.txt
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_0_factory.php 1246284044 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_1_0_factory.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/input.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/input.js
+/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilities_temp.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_loadCapabilities_temp.php
+/home/cbaudson/workspace/trunk/http/print/classes/mbTextDecorator.php 1267021310 0 /home/cbaudson/workspace/trunk/http/print/classes/mbTextDecorator.php
+/home/cbaudson/workspace/trunk/http/print/classes/factoryClasses.php 1263998514 0 /home/cbaudson/workspace/trunk/http/print/classes/factoryClasses.php
+/home/cbaudson/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php
+/home/cbaudson/workspace/trunk/http/php/mod_meetingPoint.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_meetingPoint.php
+/home/cbaudson/workspace/trunk/http/sld/classes/ColorMapEntry.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/ColorMapEntry.php
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_featuretype.php 1246284044 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_featuretype.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/html.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/html.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_navFrame.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_navFrame.php
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_server.php 1246283963 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_server.php
+/home/cbaudson/workspace/trunk/http/php/mod_loadCatalog.php 1261565744 0 /home/cbaudson/workspace/trunk/http/php/mod_loadCatalog.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_horizTab.php 1246283976 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_horizTab.php
+/home/cbaudson/workspace/trunk/http/classes/class_user.php 1258530375 0 /home/cbaudson/workspace/trunk/http/classes/class_user.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/unknown.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/unknown.js
+/home/cbaudson/workspace/trunk/http/html/mod_treefolder2_multiple.php 1246355465 0 /home/cbaudson/workspace/trunk/http/html/mod_treefolder2_multiple.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__setArray__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__setArray__.js
+/home/cbaudson/workspace/trunk/http/php/mod_treefolderAdmin.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_treefolderAdmin.php
+/home/cbaudson/workspace/trunk/test/http/classes/GeoRssFactoryTest.php 1255606944 0 /home/cbaudson/workspace/trunk/test/http/classes/GeoRssFactoryTest.php
+/home/cbaudson/workspace/trunk/http/php/mod_logout.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_logout.php
+/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_main.php 1249474917 0 /home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_main.php
+/home/cbaudson/workspace/trunk/http/sld/classes/AnchorPoint.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/AnchorPoint.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.js 1255602946 1 ZoomIn1
+/home/cbaudson/workspace/trunk/http/javascripts/mod_dependentDiv.php 1264003344 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_dependentDiv.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_permanentHighlight.js 1258639767 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_permanentHighlight.js
+/home/cbaudson/workspace/trunk/http/print/mod_printPDF.php 1263995547 0 /home/cbaudson/workspace/trunk/http/print/mod_printPDF.php
+/home/cbaudson/workspace/trunk/http/classes/class_json.php 1263903604 0 /home/cbaudson/workspace/trunk/http/classes/class_json.php
+/home/cbaudson/workspace/trunk/http/classes/class_gml_3_factory.php 1263903601 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_3_factory.php
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_factory.php 1247648164 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_factory.php
+/home/cbaudson/workspace/trunk/http/php/mod_searchCatQueryBuilder_server.php 1261565743 0 /home/cbaudson/workspace/trunk/http/php/mod_searchCatQueryBuilder_server.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/comment.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/comment.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/window/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/window/boot.js
+/home/cbaudson/workspace/trunk/lib/database-mysql.php 1262704275 0 /home/cbaudson/workspace/trunk/lib/database-mysql.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_key.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_key.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/tr.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/tr.js
+/home/cbaudson/workspace/trunk/http/php/mod_editGroup.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_editGroup.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/p.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/p.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/domimplementation.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/domimplementation.js
+/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql 1246284073 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql 1246284071 0 /home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql
+/home/cbaudson/workspace/trunk/http/classes/class_gml_geometry.php 1263903605 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_geometry.php
+/home/cbaudson/workspace/trunk/http/php/mod_loadwms_temp.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_loadwms_temp.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/platform/rhino.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/platform/rhino.js
+/home/cbaudson/workspace/trunk/http/sld/classes/ExternalGraphic.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/ExternalGraphic.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/timer.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/timer.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js 1247750208 1 scalebar
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_deprecated.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_deprecated.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/parser.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/parser.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_user.js 1255602947 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_user.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/style.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/style.js
+/home/cbaudson/workspace/trunk/http/classes/class_SaveLegend.php 1258548780 0 /home/cbaudson/workspace/trunk/http/classes/class_SaveLegend.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_loadwmc.php 1257521749 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_loadwmc.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/eventexception.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/eventexception.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xpathdebug.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xpathdebug.js
+/home/cbaudson/workspace/trunk/lib/buttonNew.js 1246284053 0 /home/cbaudson/workspace/trunk/lib/buttonNew.js
+/home/cbaudson/workspace/trunk/tools/char_code.php 1246284046 0 /home/cbaudson/workspace/trunk/tools/char_code.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/styledeclaration.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/styledeclaration.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js 1261489062 1 doubleclickZoom
+/home/cbaudson/workspace/trunk/http/javascripts/wfsFilter.js 1246283980 0 /home/cbaudson/workspace/trunk/http/javascripts/wfsFilter.js
+/home/cbaudson/workspace/trunk/http/classes/class_rss_factory.php 1253194155 0 /home/cbaudson/workspace/trunk/http/classes/class_rss_factory.php
+/home/cbaudson/workspace/trunk/core/system.php 1262618528 0 /home/cbaudson/workspace/trunk/core/system.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_DetailPopup.js 1267021306 0 /home/cbaudson/workspace/trunk/http/plugins/mb_resultList_DetailPopup.js
+/home/cbaudson/workspace/trunk/http/classes/class_log.php 1246636499 0 /home/cbaudson/workspace/trunk/http/classes/class_log.php
+/home/cbaudson/workspace/trunk/http/plugins/ol.js 1262789894 1 ol
+/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js 1262789244 1 ResizeMapsize
+/home/cbaudson/workspace/trunk/http/php/mod_evalArea.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_evalArea.php
+/home/cbaudson/workspace/trunk/http/php/mb_validatePermission.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mb_validatePermission.php
+/home/cbaudson/workspace/trunk/http/print/classes/mbMapDecorator.php 1267021310 0 /home/cbaudson/workspace/trunk/http/print/classes/mbMapDecorator.php
+/home/cbaudson/workspace/trunk/http/php/mod_gui_filteredUser.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gui_filteredUser.php
+/home/cbaudson/workspace/trunk/http/classes/class_gml_feature.php 1264687497 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_feature.php
+/home/cbaudson/workspace/trunk/http/php/mod_exportGUI.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_exportGUI.php
+/home/cbaudson/workspace/trunk/http/sld/classes/PolygonSymbolizer.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/PolygonSymbolizer.php
+/home/cbaudson/workspace/trunk/http/classes/class_cswrecord.php 1261564131 0 /home/cbaudson/workspace/trunk/http/classes/class_cswrecord.php
+/home/cbaudson/workspace/trunk/http/sld/classes/ParameterValue.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/ParameterValue.php
+/home/cbaudson/workspace/trunk/http/sld/classes/BinaryLogicOp.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/BinaryLogicOp.php
+/home/cbaudson/workspace/trunk/http/php/mod_editFilteredUser.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_editFilteredUser.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/xhr/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/xhr/boot.js
+/home/cbaudson/workspace/trunk/http/php/kmldownload.php 1257413692 0 /home/cbaudson/workspace/trunk/http/php/kmldownload.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/timer/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/timer/spec.js
+/home/cbaudson/workspace/trunk/http/php/mod_changeEPSG_dynamic.php 1246460709 0 /home/cbaudson/workspace/trunk/http/php/mod_changeEPSG_dynamic.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.4.1-test.js 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.4.1-test.js
+/home/cbaudson/workspace/trunk/lib/extent.js 1263903576 1 Extent
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/documenttype.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/documenttype.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_export_image.php 1246460709 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_export_image.php
+/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2PNG.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_weldMaps2PNG.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/__global__.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/__global__.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php
+/home/cbaudson/workspace/trunk/http/javascripts/jsTree.js 1259141740 0 /home/cbaudson/workspace/trunk/http/javascripts/jsTree.js
+/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql 1246284070 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/document.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/document.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/mutationevent.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/mutationevent.js
+/home/cbaudson/workspace/trunk/http/classes/class_map.php 1263996069 0 /home/cbaudson/workspace/trunk/http/classes/class_map.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlparser.js
+/home/cbaudson/workspace/trunk/lib/resultGeometryListModel.js 1263903563 1 ResultGeometryListModel
+/home/cbaudson/workspace/trunk/http/javascripts/mod_treeConf.js 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_treeConf.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/licenses/MIT-LICENSE.txt 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/licenses/MIT-LICENSE.txt
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/test.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/test.js
+/home/cbaudson/workspace/trunk/http/php/mod_map_messages.php 1255429345 0 /home/cbaudson/workspace/trunk/http/php/mod_map_messages.php
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf.php 1253875191 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_conf.php
+/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_Gui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredUser_Gui.php
+/home/cbaudson/workspace/trunk/http/php/mb_getGUIs.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mb_getGUIs.php
+/home/cbaudson/workspace/trunk/test/http/classes/MbWarningTest.php 1255606944 0 /home/cbaudson/workspace/trunk/test/http/classes/MbWarningTest.php
+/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php
+/home/cbaudson/workspace/trunk/tools/url_code.php 1246284046 0 /home/cbaudson/workspace/trunk/tools/url_code.php
+/home/cbaudson/workspace/trunk/http/classes/class_kml_ows.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_ows.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_add_vendorspecific.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_add_vendorspecific.php
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_1_0.php 1246284039 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_1_0.php
+/home/cbaudson/workspace/trunk/tools/mapFiler.php 1246284046 0 /home/cbaudson/workspace/trunk/tools/mapFiler.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql 1267021391 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/area.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/area.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_twitter.php 1267021306 0 /home/cbaudson/workspace/trunk/http/plugins/mb_twitter.php
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php
+/home/cbaudson/workspace/trunk/http/php/mod_exportMapImage_server.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_exportMapImage_server.php
+/home/cbaudson/workspace/trunk/http/php/mod_loadwfs.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_loadwfs.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/htmlelement.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/htmlelement.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/parser/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/parser/spec.js
+/home/cbaudson/workspace/trunk/lib/class_Monitor.php 1249479917 0 /home/cbaudson/workspace/trunk/lib/class_Monitor.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/multi-window.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/multi-window.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_cardindex.js 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_cardindex.js
+/home/cbaudson/workspace/trunk/http/php/mod_wfsLayerObj_conf.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_wfsLayerObj_conf.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_tab.php 1257242696 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_tab.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/cookie.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/cookie.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfo.php 1264003360 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfo.php
+/home/cbaudson/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php 1251880844 0 /home/cbaudson/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/env.rhino.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/env.rhino.js
+/home/cbaudson/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php 1256112846 0 /home/cbaudson/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php
+/home/cbaudson/workspace/trunk/http/include/gui1_splash_jquery.php 1261565993 0 /home/cbaudson/workspace/trunk/http/include/gui1_splash_jquery.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_wps_client.js 1258538846 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_wps_client.js
+/home/cbaudson/workspace/trunk/http/php/mb_listGUIs.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mb_listGUIs.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_savewmc.js 1267021307 1 savewmc
+/home/cbaudson/workspace/trunk/http/php/createImageFromText.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/createImageFromText.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_admin.js 1249653442 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_admin.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/html/script.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/html/script.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php
+/home/cbaudson/workspace/trunk/http/php/mod_createUser.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_createUser.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_box1.js 1257759489 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_box1.js
+/home/cbaudson/workspace/trunk/http/classes/class_weldOverview2PNG_rotate.php 1263996069 0 /home/cbaudson/workspace/trunk/http/classes/class_weldOverview2PNG_rotate.php
+/home/cbaudson/workspace/trunk/http/php/mod_gazetteerSQL_server.php 1246283968 0 /home/cbaudson/workspace/trunk/http/php/mod_gazetteerSQL_server.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8.sql 1267021391 1 inspire_md_data
+/home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php 1255602947 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/util.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/util.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/range.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/range.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_embedded_legend.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_embedded_legend.php
+/home/cbaudson/workspace/trunk/http/php/mod_editGuiWms.php 1252598015 0 /home/cbaudson/workspace/trunk/http/php/mod_editGuiWms.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/img.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/img.js
+/home/cbaudson/workspace/trunk/http/classes/class_gml_multiline.php 1253605792 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_multiline.php
+/home/cbaudson/workspace/trunk/http/classes/class_weldMaps2PNG_rotate.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_weldMaps2PNG_rotate.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/expression.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/expression.js
+/home/cbaudson/workspace/trunk/http/php/mb_js_exception.php 1246283963 0 /home/cbaudson/workspace/trunk/http/php/mb_js_exception.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/dom.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/dom.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php 1256902561 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php
+/home/cbaudson/workspace/trunk/http/php/mod_updateWMS.php 1249480531 0 /home/cbaudson/workspace/trunk/http/php/mod_updateWMS.php
+/home/cbaudson/workspace/trunk/http/php/mod_loadCatalogCapabilities.php 1262789903 0 /home/cbaudson/workspace/trunk/http/php/mod_loadCatalogCapabilities.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/location.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/location.js
+/home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_defineGetMapBbox.php 1248852611 0 /home/cbaudson/workspace/trunk/tools/mod_monitorCapabilities_defineGetMapBbox.php
+/home/cbaudson/workspace/trunk/lib/class_Mapbender.php 1247654252 0 /home/cbaudson/workspace/trunk/lib/class_Mapbender.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/select.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/select.js
+/home/cbaudson/workspace/trunk/http/classes/class_georss_item.php 1253112961 0 /home/cbaudson/workspace/trunk/http/classes/class_georss_item.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/domexception.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/domexception.js
+/home/cbaudson/workspace/trunk/http/php/mod_user_gui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_user_gui.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_loadwmc.js 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_loadwmc.js
+/home/cbaudson/workspace/trunk/http/print/classes/mbOverviewDecorator.php 1263998515 0 /home/cbaudson/workspace/trunk/http/print/classes/mbOverviewDecorator.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleSel.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_scaleSel.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/implementation.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/implementation.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_setBackground_all.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_setBackground_all.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/nodelist.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/nodelist.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/timer/timer.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/timer/timer.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_admin.php 1257421166 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_admin.php
+/home/cbaudson/workspace/trunk/http/sld/classes/Rule.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Rule.php
+/home/cbaudson/workspace/trunk/http/javascripts/map.js 1252502888 0 /home/cbaudson/workspace/trunk/http/javascripts/map.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/css/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/css/boot.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_1.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/strings_1.js
+/home/cbaudson/workspace/trunk/test/http/classes/MapTest.php 1255606944 0 /home/cbaudson/workspace/trunk/test/http/classes/MapTest.php
+/home/cbaudson/workspace/trunk/http/php/mod_treefolderClient.php 1259847973 0 /home/cbaudson/workspace/trunk/http/php/mod_treefolderClient.php
+/home/cbaudson/workspace/trunk/http/html/mod_treefolder2.php 1246374828 0 /home/cbaudson/workspace/trunk/http/html/mod_treefolder2.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/dom.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/dom.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/documentevent.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/documentevent.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_adminNavigation.js 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_adminNavigation.js
/home/cbaudson/workspace/trunk/lib/customTreeController.js 1259164236 0 /home/cbaudson/workspace/trunk/lib/customTreeController.js
-/home/cbaudson/workspace/trunk/lib/resizableButton.js 1246284050 0 /home/cbaudson/workspace/trunk/lib/resizableButton.js
-/home/cbaudson/workspace/trunk/lib/resultGeometryListModel.js 1263903563 1 ResultGeometryListModel
-/home/cbaudson/workspace/trunk/lib/exception.js 1263903557 1 Exception
-/home/cbaudson/workspace/trunk/lib/database-mysql.php 1262704275 0 /home/cbaudson/workspace/trunk/lib/database-mysql.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/scope.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/scope.js
+/home/cbaudson/workspace/trunk/http/php/mod_owsproxy_conf.php 1251896391 0 /home/cbaudson/workspace/trunk/http/php/mod_owsproxy_conf.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/debug.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/debug.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_twitter_update.js 1267021306 0 /home/cbaudson/workspace/trunk/http/plugins/mb_twitter_update.js
+/home/cbaudson/workspace/trunk/http/classes/class_weldLegend2PNG.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_weldLegend2PNG.php
+/home/cbaudson/workspace/trunk/http/php/mod_tab_messages.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_tab_messages.php
+/home/cbaudson/workspace/trunk/license/license_js.txt 1246284047 0 /home/cbaudson/workspace/trunk/license/license_js.txt
+/home/cbaudson/workspace/trunk/http/javascripts/mod_selectMapsize.php 1251987659 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_selectMapsize.php
+/home/cbaudson/workspace/trunk/http/javascripts/requestGeometryConstructor.js 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/requestGeometryConstructor.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/__global__.js
+/home/cbaudson/workspace/trunk/http/php/mod_printView1.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_printView1.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_4.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_4.js
+/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql 1246284075 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/dom.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/dom.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_selArea.js 1267021307 1 selArea
+/home/cbaudson/workspace/trunk/http/classes/class_wfs_conf.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_wfs_conf.php
+/home/cbaudson/workspace/trunk/http/sld/classes/Stroke.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Stroke.php
+/home/cbaudson/workspace/trunk/http/php/mod_gazetteerMetadata.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_gazetteerMetadata.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/console/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/console/__global__.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/external_script.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/js/external_script.js
+/home/cbaudson/workspace/trunk/http/javascripts/jq_ui_effects.php 1261486956 1 jq_ui_effects
+/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/HtmlParser.java 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/HtmlParser.java
+/home/cbaudson/workspace/trunk/test/http/classes/RssTest.php 1255606944 0 /home/cbaudson/workspace/trunk/test/http/classes/RssTest.php
+/home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_interface.js 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs_conf_interface.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xhr/__global__.js
+/home/cbaudson/workspace/trunk/http/php/mod_exportElement.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_exportElement.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/script.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/script.js
+/home/cbaudson/workspace/trunk/http/php/mod_digitize_mergePolygon.php 1253875191 0 /home/cbaudson/workspace/trunk/http/php/mod_digitize_mergePolygon.php
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/event/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/event/spec.js
+/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php
+/home/cbaudson/workspace/trunk/lib/backwards_compatibility_to_2.6.js 1263903553 0 /home/cbaudson/workspace/trunk/lib/backwards_compatibility_to_2.6.js
+/home/cbaudson/workspace/trunk/lib/ajax.php 1253706015 0 /home/cbaudson/workspace/trunk/lib/ajax.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js 1247659724 1 zoomFull
+/home/cbaudson/workspace/trunk/http/php/mod_deleteWMS.php 1256039728 0 /home/cbaudson/workspace/trunk/http/php/mod_deleteWMS.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/dom/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/dom/boot.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/platform/core.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/platform/core.js
+/home/cbaudson/workspace/trunk/http/classes/class_kml_point.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_point.php
+/home/cbaudson/workspace/trunk/http/php/mod_filteredWms_layer_topic.php 1246283968 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredWms_layer_topic.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/variable_declarations.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/variable_declarations.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php
+/home/cbaudson/workspace/trunk/http/php/mod_changeEPSG_server.php 1251469148 0 /home/cbaudson/workspace/trunk/http/php/mod_changeEPSG_server.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_2.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_2.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/HtmlParserModule.java 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/HtmlParserModule.java
+/home/cbaudson/workspace/trunk/tools/send_post_curl.php 1246284046 0 /home/cbaudson/workspace/trunk/tools/send_post_curl.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/textarea.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/textarea.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/implementation.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/implementation.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/parser.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/parser.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/event.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/event.js
+/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js 1261565712 1 /home/cbaudson/workspace/trunk/lib/resultGeometryListController.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_navigation.js 1263824798 1 mb_navigation
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/mysql_gettext.sql 1246284071 0 /home/cbaudson/workspace/trunk/resources/db/mysql/mysql_gettext.sql
+/home/cbaudson/workspace/trunk/resources/db/log_data.txt 1246373944 0 /home/cbaudson/workspace/trunk/resources/db/log_data.txt
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/console.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/console.js
+/home/cbaudson/workspace/trunk/lib/history.js 1257779030 0 /home/cbaudson/workspace/trunk/lib/history.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/notation.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/notation.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_home.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_home.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_setPOI2Scale.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_setPOI2Scale.php
+/home/cbaudson/workspace/trunk/http/classes/class_group.php 1255602724 0 /home/cbaudson/workspace/trunk/http/classes/class_group.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/tbody-thead-tfoot.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/tbody-thead-tfoot.js
+/home/cbaudson/workspace/trunk/http/classes/class_gml_line.php 1253605785 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_line.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql 1253874941 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/http/javascripts/mod_measure.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_measure.php
/home/cbaudson/workspace/trunk/lib/class_Singleton.php 1246284057 0 /home/cbaudson/workspace/trunk/lib/class_Singleton.php
/home/cbaudson/workspace/trunk/lib/div.js 1263903589 0 /home/cbaudson/workspace/trunk/lib/div.js
+/home/cbaudson/workspace/trunk/http/classes/class_wmcToXml.php 1255592147 0 /home/cbaudson/workspace/trunk/http/classes/class_wmcToXml.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_highlightPOI.php 1261493348 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_highlightPOI.php
+/home/cbaudson/workspace/trunk/http/php/mod_zoomCoords_en.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_zoomCoords_en.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/console.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/console.js
+/home/cbaudson/workspace/trunk/http/php/mod_gui_user.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gui_user.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/event.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/event.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_add_SLD.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_add_SLD.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/frameset.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/frameset.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_pan.js 1258644177 1 selArea
+/home/cbaudson/workspace/trunk/http/plugins/mb_i18n_server.php 1258554838 0 /home/cbaudson/workspace/trunk/http/plugins/mb_i18n_server.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/profile.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/profile.js
+/home/cbaudson/workspace/trunk/http/classes/class_gml_feature_collection.php 1246284035 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_feature_collection.php
+/home/cbaudson/workspace/trunk/http/php/mb_validateInput.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mb_validateInput.php
+/home/cbaudson/workspace/trunk/http/sld/classes/Graphic.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/Graphic.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_georss.php 1259154665 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_georss.php
+/home/cbaudson/workspace/trunk/http/php/mod_SelectKeyword.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_SelectKeyword.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_renderGML.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_renderGML.php
+/home/cbaudson/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php 1246283966 0 /home/cbaudson/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/__global__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/__global__.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.2.6-test.js 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.2.6-test.js
+/home/cbaudson/workspace/trunk/test/http/classes/UserTest.php 1255606944 0 /home/cbaudson/workspace/trunk/test/http/classes/UserTest.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_zoomOut.js 1257239892 1 mb_zoomOut
+/home/cbaudson/workspace/trunk/http/javascripts/mod_copyright.php 1263995844 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_copyright.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_print1.php 1246460709 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_print1.php
+/home/cbaudson/workspace/trunk/http/classes/class.ezpdf.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class.ezpdf.php
+/home/cbaudson/workspace/trunk/http/classes/class_keyword.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_keyword.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__trim__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__trim__.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/meta.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/meta.js
+/home/cbaudson/workspace/trunk/http/php/mod_deleteFilteredGUI.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_deleteFilteredGUI.php
/home/cbaudson/workspace/trunk/lib/selectableButton.js 1267021316 0 /home/cbaudson/workspace/trunk/lib/selectableButton.js
-/home/cbaudson/workspace/trunk/lib/ajax.php 1253706015 0 /home/cbaudson/workspace/trunk/lib/ajax.php
-/home/cbaudson/workspace/trunk/lib/backwards_compatibility_to_2.6.js 1263903553 0 /home/cbaudson/workspace/trunk/lib/backwards_compatibility_to_2.6.js
+/home/cbaudson/workspace/trunk/sql/insert_wfs_conf_element.sql 1246284046 0 /home/cbaudson/workspace/trunk/sql/insert_wfs_conf_element.sql
+/home/cbaudson/workspace/trunk/http/classes/class_kml_geometry.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_geometry.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql 1246284075 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql
+/home/cbaudson/workspace/trunk/http/sld/classes/NamedLayer.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/NamedLayer.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SaveAsFile.js 1260538899 0 /home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SaveAsFile.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/base.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/base.js
+/home/cbaudson/workspace/trunk/http/javascripts/usemap.js 1259154025 0 /home/cbaudson/workspace/trunk/http/javascripts/usemap.js
+/home/cbaudson/workspace/trunk/http/php/mod_usemap.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_usemap.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.3.1-test.js 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/bin/jquery-1.3.1-test.js
+/home/cbaudson/workspace/trunk/http/classes/class_universal_wfs_factory.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/class_universal_wfs_factory.php
/home/cbaudson/workspace/trunk/lib/database-pgsql.php 1253874628 0 /home/cbaudson/workspace/trunk/lib/database-pgsql.php
-/home/cbaudson/workspace/trunk/lib/database-mysqli.php 1253874627 0 /home/cbaudson/workspace/trunk/lib/database-mysqli.php
+/home/cbaudson/workspace/trunk/http/php/mod_wfs.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_wfs.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/stylesheet.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/stylesheet.js
/home/cbaudson/workspace/trunk/lib/draggableButton.js 1267021316 0 /home/cbaudson/workspace/trunk/lib/draggableButton.js
-/home/cbaudson/workspace/trunk/lib/class_Monitor.php 1249479917 0 /home/cbaudson/workspace/trunk/lib/class_Monitor.php
-/home/cbaudson/workspace/trunk/lib/list.js 1263903580 1 List
-/home/cbaudson/workspace/trunk/lib/event.js 1267021316 1 Event
-/home/cbaudson/workspace/trunk/lib/saveButton.js 1246284055 0 /home/cbaudson/workspace/trunk/lib/saveButton.js
+/home/cbaudson/workspace/trunk/http/php/mod_edit_metadata.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_edit_metadata.php
+/home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsNull.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/PropertyIsNull.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/__global__.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/__global__.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/td-th.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/td-th.js
+/home/cbaudson/workspace/trunk/http/sld/classes/BinaryComparisonOp.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/BinaryComparisonOp.php
+/home/cbaudson/workspace/trunk/http/classes/class_stripRequest.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_stripRequest.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Window.java 1267021291 0 /home/cbaudson/workspace/trunk/test/tools/env-js/rhino/src/org/mozilla/javascript/tools/envjs/Window.java
+/home/cbaudson/workspace/trunk/http/sld/classes/AddOperationModule.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/AddOperationModule.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/frame/proxy.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/frame/proxy.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xslt_unittest.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xslt_unittest.js
+/home/cbaudson/workspace/trunk/http/img/button_blue/README.TXT 1246284021 0 /home/cbaudson/workspace/trunk/http/img/button_blue/README.TXT
+/home/cbaudson/workspace/trunk/lib/point.js 1263903572 1 Point
+/home/cbaudson/workspace/trunk/http/php/mod_filteredUser_Group.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredUser_Group.php
+/home/cbaudson/workspace/trunk/http/html/mod_treefolderPlain.php 1267021310 0 /home/cbaudson/workspace/trunk/http/html/mod_treefolderPlain.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql 1246284071 0 /home/cbaudson/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/node.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/node.js
+/home/cbaudson/workspace/trunk/http/classes/class_gml_factory.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_factory.php
+/home/cbaudson/workspace/trunk/http/php/mod_wmc2ol.php 1255603052 0 /home/cbaudson/workspace/trunk/http/php/mod_wmc2ol.php
+/home/cbaudson/workspace/trunk/http/classes/class_mb_notice.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_mb_notice.php
+/home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_Gui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredGroup_Gui.php
+/home/cbaudson/workspace/trunk/http/php/mod_gazetteer_edit.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gazetteer_edit.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_setBBOX1.php 1253875660 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_setBBOX1.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/html.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/html.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/env.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/env.js
+/home/cbaudson/workspace/trunk/http/php/mod_edit_element_vars.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_edit_element_vars.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/screen.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/window/screen.js
+/home/cbaudson/workspace/trunk/http/php/mod_export_image.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_export_image.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/prototypes.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/prototypes.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/del-ins.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/del-ins.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/outro.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/common/outro.js
+/home/cbaudson/workspace/trunk/http/classes/class_universal_rss_factory.php 1253192303 0 /home/cbaudson/workspace/trunk/http/classes/class_universal_rss_factory.php
+/home/cbaudson/workspace/trunk/http/print/classes/mbMeasureDecorator.php 1263998514 0 /home/cbaudson/workspace/trunk/http/print/classes/mbMeasureDecorator.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_gui.js 1255602947 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_gui.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/event.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/event.js
+/home/cbaudson/workspace/trunk/http/classes/class_bbox.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_bbox.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_tab.js 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_tab.js
+/home/cbaudson/workspace/trunk/http/javascripts/wms.js 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/wms.js
+/home/cbaudson/workspace/trunk/http/plugins/jq_ui_dialog.js 1264752970 0 /home/cbaudson/workspace/trunk/http/plugins/jq_ui_dialog.js
+/home/cbaudson/workspace/trunk/http/php/mod_loadCapabilitiesList.php 1255956391 0 /home/cbaudson/workspace/trunk/http/php/mod_loadCapabilitiesList.php
+/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read.php 1249480442 0 /home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/fixtures/external_script.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/fixtures/external_script.js
+/home/cbaudson/workspace/trunk/http/sld/classes/FeatureTypeStyle.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/FeatureTypeStyle.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_firebug_lite.js 1261129655 1 firebug_lite
+/home/cbaudson/workspace/trunk/http/javascripts/mod_setBackground.php 1255602947 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_setBackground.php
+/home/cbaudson/workspace/trunk/http/sld/classes/PointPlacement.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/PointPlacement.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/timer.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/timer.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/console.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/console.js
+/home/cbaudson/workspace/trunk/http/sld/classes/PointSymbolizer.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/PointSymbolizer.php
+/home/cbaudson/workspace/trunk/http/php/mod_digitize_messages.php 1263300768 0 /home/cbaudson/workspace/trunk/http/php/mod_digitize_messages.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/rule.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/css/rule.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlelement.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmlelement.js
+/home/cbaudson/workspace/trunk/http/php/mod_gazLayerObj_edit.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gazLayerObj_edit.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql 1259847975 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/text.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/text.js
+/home/cbaudson/workspace/trunk/http/javascripts/geometry.js 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/geometry.js
+/home/cbaudson/workspace/trunk/http/classes/class_connector.php 1267026796 0 /home/cbaudson/workspace/trunk/http/classes/class_connector.php
+/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_filteredUser.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredGui_filteredUser.php
+/home/cbaudson/workspace/trunk/http/php/nestedSets.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/nestedSets.php
+/home/cbaudson/workspace/trunk/license/bitstream-COPYRIGHT.TXT 1246284047 0 /home/cbaudson/workspace/trunk/license/bitstream-COPYRIGHT.TXT
+/home/cbaudson/workspace/trunk/http/index.php 1246284046 0 /home/cbaudson/workspace/trunk/http/index.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/optgroup.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/optgroup.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_dragMapSize.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_dragMapSize.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql 1258548846 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/aspect.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/aspect.js
+/home/cbaudson/workspace/trunk/sql/insert_wfs_conf.sql 1246284046 0 /home/cbaudson/workspace/trunk/sql/insert_wfs_conf.sql
+/home/cbaudson/workspace/trunk/http/plugins/jq_ui_effects.php 1264752560 0 /home/cbaudson/workspace/trunk/http/plugins/jq_ui_effects.php
+/home/cbaudson/workspace/trunk/http/classes/class_layer_monitor.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_layer_monitor.php
+/home/cbaudson/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_tabs_vertical.js 1264752560 1 tabs_vertical
+/home/cbaudson/workspace/trunk/http/classes/class_kml_line.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_line.php
+/home/cbaudson/workspace/trunk/http/javascripts/user.php 1249653429 0 /home/cbaudson/workspace/trunk/http/javascripts/user.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/xhr.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/xhr.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xpath_unittest.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/xpath_unittest.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/xhr/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/xhr/spec.js
+/home/cbaudson/workspace/trunk/http/plugins/mb_history_forward.js 1257780619 0 /home/cbaudson/workspace/trunk/http/plugins/mb_history_forward.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/iframe.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/iframe.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/window/spec.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/window/spec.js
+/home/cbaudson/workspace/trunk/core/i18n.php 1263396699 0 /home/cbaudson/workspace/trunk/core/i18n.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/profile.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/rhino/profile.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php 1256039578 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php
+/home/cbaudson/workspace/trunk/license/gpl_short.txt 1246284047 0 /home/cbaudson/workspace/trunk/license/gpl_short.txt
+/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql 1246284070 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/BrowserTreeBuilder.java 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/htmlparser/BrowserTreeBuilder.java
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/window.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/window.js
+/home/cbaudson/workspace/trunk/http/sld/classes/RasterSymbolizer.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/RasterSymbolizer.php
+/home/cbaudson/workspace/trunk/http/php/mod_gui_owner.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_gui_owner.php
+/home/cbaudson/workspace/trunk/http/php/mod_echo.php 1260538913 0 /home/cbaudson/workspace/trunk/http/php/mod_echo.php
+/home/cbaudson/workspace/trunk/lib/customTreeModel.js 1263903547 0 /home/cbaudson/workspace/trunk/lib/customTreeModel.js
+/home/cbaudson/workspace/trunk/http/plugins/ol_layerSwitch.js 1261559928 1 ol_layerSwitch
+/home/cbaudson/workspace/trunk/http/classes/class_ows.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/class_ows.php
+/home/cbaudson/workspace/trunk/http/classes/class_csw.php 1261564131 0 /home/cbaudson/workspace/trunk/http/classes/class_csw.php
+/home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read_single.php 1248852610 0 /home/cbaudson/workspace/trunk/http/php/mod_monitorCapabilities_read_single.php
+/home/cbaudson/workspace/trunk/test/http/classes/GeoRssTest.php 1255606944 0 /home/cbaudson/workspace/trunk/test/http/classes/GeoRssTest.php
+/home/cbaudson/workspace/trunk/http/print/classes/mbParagraphDecorator.php 1263998515 0 /home/cbaudson/workspace/trunk/http/print/classes/mbParagraphDecorator.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_searchCSW_form.php 1261565985 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_searchCSW_form.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_toggleModule.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_toggleModule.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/characterdata.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/characterdata.js
+/home/cbaudson/workspace/trunk/http/php/mod_abo_show.php 1249464694 0 /home/cbaudson/workspace/trunk/http/php/mod_abo_show.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_scaleText.php 1246460709 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_scaleText.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_1.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_1.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php
+/home/cbaudson/workspace/trunk/http/classes/class_RPCEndpoint.php 1249653363 0 /home/cbaudson/workspace/trunk/http/classes/class_RPCEndpoint.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/openlayers_application.sql 1246284071 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/openlayers_application.sql
+/home/cbaudson/workspace/trunk/http/php/mod_deleteGUI.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_deleteGUI.php
+/home/cbaudson/workspace/trunk/http/php/mod_displayKML.php 1246283966 0 /home/cbaudson/workspace/trunk/http/php/mod_displayKML.php
+/home/cbaudson/workspace/trunk/http/php/mod_metadataWrite.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_metadataWrite.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_initWmc.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_initWmc.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/factory.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/factory.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/qunit.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/qunit.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_fisheye.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_fisheye.php
+/home/cbaudson/workspace/trunk/http/php/mod_wmc_publish.php 1258120121 0 /home/cbaudson/workspace/trunk/http/php/mod_wmc_publish.php
+/home/cbaudson/workspace/trunk/http/sld/classes/UserStyle.php 1246283956 0 /home/cbaudson/workspace/trunk/http/sld/classes/UserStyle.php
+/home/cbaudson/workspace/trunk/http/php/mod_newGui.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_newGui.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_usemap.php 1246374828 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_usemap.php
+/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/table.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/table.js
+/home/cbaudson/workspace/trunk/http/tmp/ReadMe.txt 1267021285 0 /home/cbaudson/workspace/trunk/http/tmp/ReadMe.txt
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/htmlevents.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/htmlevents.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_center1.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_center1.php
+/home/cbaudson/workspace/trunk/http/classes/class_wmc.php 1258622176 0 /home/cbaudson/workspace/trunk/http/classes/class_wmc.php
+/home/cbaudson/workspace/trunk/http/php/mod_changePassword.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_changePassword.php
+/home/cbaudson/workspace/trunk/http/plugins/ol_wms.php 1262789894 1 <Application element name>
+/home/cbaudson/workspace/trunk/http/print/classes/mbTemplatePdf.php 1267021310 0 /home/cbaudson/workspace/trunk/http/print/classes/mbTemplatePdf.php
+/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql 1246284070 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/result.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xpath/result.js
+/home/cbaudson/workspace/trunk/http/classes/class_gml.php 1246284039 0 /home/cbaudson/workspace/trunk/http/classes/class_gml.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/button.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/button.js
+/home/cbaudson/workspace/trunk/license/gpl.txt 1246284047 0 /home/cbaudson/workspace/trunk/license/gpl.txt
+/home/cbaudson/workspace/trunk/http/test/test_rss_load.php 1253193891 0 /home/cbaudson/workspace/trunk/http/test/test_rss_load.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/html/object.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/html/object.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_savewmc.php 1258557168 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_savewmc.php
+/home/cbaudson/workspace/trunk/http/php/mod_wps.php 1263903487 0 /home/cbaudson/workspace/trunk/http/php/mod_wps.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/intro.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/common/intro.js
+/home/cbaudson/workspace/trunk/http/php/geoRSSToGeoJSON.php 1258643797 0 /home/cbaudson/workspace/trunk/http/php/geoRSSToGeoJSON.php
+/home/cbaudson/workspace/trunk/http/classes/class_gui.php 1267021310 0 /home/cbaudson/workspace/trunk/http/classes/class_gui.php
+/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SelectAll.js 1261565683 0 /home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SelectAll.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_5.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_5.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/eventtarget.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/eventtarget.js
+/home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql 1251461870 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql
/home/cbaudson/workspace/trunk/lib/button.js 1263903592 1 Button
-/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js 1261565712 1 /home/cbaudson/workspace/trunk/lib/resultGeometryListController.js
-/home/cbaudson/workspace/trunk/lib/customTreeModel.js 1263903547 0 /home/cbaudson/workspace/trunk/lib/customTreeModel.js
-/home/cbaudson/workspace/trunk/lib/alignButton.js 1263903550 0 /home/cbaudson/workspace/trunk/lib/alignButton.js
-/home/cbaudson/workspace/trunk/lib/extent.js 1263903576 1 Extent
-/home/cbaudson/workspace/trunk/lib/marker.js 1267027600 1 Mapbender.Marker
-/home/cbaudson/workspace/trunk/lib/class_Mapbender_session.php 1267021316 0 /home/cbaudson/workspace/trunk/lib/class_Mapbender_session.php
-/home/cbaudson/workspace/trunk/lib/buttonNew.js 1246284053 0 /home/cbaudson/workspace/trunk/lib/buttonNew.js
-/home/cbaudson/workspace/trunk/lib/core.js 1263903586 0 /home/cbaudson/workspace/trunk/lib/core.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/parser.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/unit/parser.js
+/home/cbaudson/workspace/trunk/test/tools/qunit.js 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/qunit.js
+/home/cbaudson/workspace/trunk/tools/send_post.php 1246284046 0 /home/cbaudson/workspace/trunk/tools/send_post.php
/home/cbaudson/workspace/trunk/lib/basic.js 1263995832 1 mapbender
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/simple.txt 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/fixtures/simple.txt
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmldocument.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/htmldocument.js
+/home/cbaudson/workspace/trunk/http/plugins/jq_ui_effects.js 1264753004 1 jq_ui_effects
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/mail.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/mail.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomCoords.php 1264003367 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_zoomCoords.php
+/home/cbaudson/workspace/trunk/resources/db/log_schema.txt 1246373938 0 /home/cbaudson/workspace/trunk/resources/db/log_schema.txt
+/home/cbaudson/workspace/trunk/Changes.txt 1267021391 0 /home/cbaudson/workspace/trunk/Changes.txt
+/home/cbaudson/workspace/trunk/lib/exception.js 1263903557 1 Exception
+/home/cbaudson/workspace/trunk/http/php/mod_editApplication_server.php 1253705870 0 /home/cbaudson/workspace/trunk/http/php/mod_editApplication_server.php
+/home/cbaudson/workspace/trunk/http/classes/class_georss_factory.php 1253192205 0 /home/cbaudson/workspace/trunk/http/classes/class_georss_factory.php
+/home/cbaudson/workspace/trunk/http/php/mod_gazetteerMetadata_search.php 1267021307 0 /home/cbaudson/workspace/trunk/http/php/mod_gazetteerMetadata_search.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql 1251461877 0 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/dom.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/core/dom.js
+/home/cbaudson/workspace/trunk/http/php/mod_orphanWMS.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_orphanWMS.php
+/home/cbaudson/workspace/trunk/http/print/classes/mbImageDecorator.php 1263998514 0 /home/cbaudson/workspace/trunk/http/print/classes/mbImageDecorator.php
+/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 1267021391 1 /home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/event/keyboardevent.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/event/keyboardevent.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/johnson/placeholder.txt 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/platform/johnson/placeholder.txt
+/home/cbaudson/workspace/trunk/http/javascripts/mod_searchCSW_ajax.php 1267021307 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_searchCSW_ajax.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/test/xslt_script.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/test/xslt_script.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/documentfragment.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/documentfragment.js
+/home/cbaudson/workspace/trunk/http/javascripts/mod_AdminTabs.js 1255602947 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_AdminTabs.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/README.Refactor.txt 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/README.Refactor.txt
+/home/cbaudson/workspace/trunk/resources/db/sql_updates_monitoring.sql 1248965379 1 /home/cbaudson/workspace/trunk/resources/db/sql_updates_monitoring.sql
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/console/boot.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/console/boot.js
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/qunit.js 1267021287 0 /home/cbaudson/workspace/trunk/test/tools/env-js/test/specs/qunit.js
+/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql 1259847968 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
+/home/cbaudson/workspace/trunk/http/classes/class_gml2.php 1259154633 0 /home/cbaudson/workspace/trunk/http/classes/class_gml2.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_saveLayerPreview.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_saveLayerPreview.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_state.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_state.php
+/home/cbaudson/workspace/trunk/http/print/classes/mbTemplatePdfDecorator.php 1263998515 0 /home/cbaudson/workspace/trunk/http/print/classes/mbTemplatePdfDecorator.php
+/home/cbaudson/workspace/trunk/http/classes/class_mb_warning.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_mb_warning.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/parser.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/parser.js
+/home/cbaudson/workspace/trunk/http/php/mod_filteredGui_group.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredGui_group.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/window/history.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/window/history.js
+/home/cbaudson/workspace/trunk/http/plugins/jq_datatables.js 1257348781 1 jq_datatables
+/home/cbaudson/workspace/trunk/http/javascripts/mod_tooltip.php 1253875633 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_tooltip.php
+/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php
+/home/cbaudson/workspace/trunk/http/sld/sld_function_handler.php 1246283960 0 /home/cbaudson/workspace/trunk/http/sld/sld_function_handler.php
+/home/cbaudson/workspace/trunk/http/include/dyn_php.php 1246283960 0 /home/cbaudson/workspace/trunk/http/include/dyn_php.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js 1259593231 1 Sandclock
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/processor.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/processor.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/dist/event.js 1267021305 0 /home/cbaudson/workspace/trunk/test/tools/env-js/dist/event.js
+/home/cbaudson/workspace/trunk/license/Liberation-License.txt 1246284047 0 /home/cbaudson/workspace/trunk/license/Liberation-License.txt
+/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js 1267021307 1 changeEPSG
+/home/cbaudson/workspace/trunk/http/javascripts/initWms.php 1246283973 0 /home/cbaudson/workspace/trunk/http/javascripts/initWms.php
+/home/cbaudson/workspace/trunk/http/php/mod_group_user.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_group_user.php
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/entityreference.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/dom/entityreference.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/dom_unittest.js 1267021297 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/xslt/ajaxslt-0.8.1/dom_unittest.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_0.js 1267021298 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/parser/functions_0.js
+/home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__extend__.js 1267021296 0 /home/cbaudson/workspace/trunk/test/tools/env-js/src/common/__extend__.js
+/home/cbaudson/workspace/trunk/http/php/mod_deleteWFS.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_deleteWFS.php
+/home/cbaudson/workspace/trunk/http/classes/class_kml_multigeometry.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_kml_multigeometry.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_exportMapImage.php 1246283992 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_exportMapImage.php
+/home/cbaudson/workspace/trunk/http/classes/class_wms.php 1256902136 0 /home/cbaudson/workspace/trunk/http/classes/class_wms.php
+/home/cbaudson/workspace/trunk/http/php/mod_filteredWms_topic.php 1246283969 0 /home/cbaudson/workspace/trunk/http/php/mod_filteredWms_topic.php
+/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js 1251460918 0 /home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js
+/home/cbaudson/workspace/trunk/http/php/mod_layerMetadata.php 1257413721 0 /home/cbaudson/workspace/trunk/http/php/mod_layerMetadata.php
+/home/cbaudson/workspace/trunk/http/print/printFactory.php 1264003334 0 /home/cbaudson/workspace/trunk/http/print/printFactory.php
+/home/cbaudson/workspace/trunk/license/licence_reference.txt 1246284047 0 /home/cbaudson/workspace/trunk/license/licence_reference.txt
+/home/cbaudson/workspace/trunk/test/tools/env-js/bin/prototype-1.6.0.3-test.js 1267021306 0 /home/cbaudson/workspace/trunk/test/tools/env-js/bin/prototype-1.6.0.3-test.js
Modified: trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd
(Binary files differ)
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
Modified: trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
Modified: trunk/mapbender/documents/api_js/Data/PreviousSettings.nd
Modified: trunk/mapbender/documents/api_js/Data/SymbolTable.nd
Modified: trunk/mapbender/documents/api_js/Menu.txt
--- trunk/mapbender/documents/api_js/Menu.txt 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/Menu.txt 2010-02-24 16:16:02 UTC (rev 5640)
@@ -46,18 +46,99 @@
-File: Ajax (ajax.js)
-File: Button (button.js)
-File: Event (event.js)
-File: Exception (exception.js)
-File: Extent (extent.js)
-File: List (list.js)
-File: mapbender (basic.js)
-File: Mapbender.Marker (marker.js)
-File: Point (point.js)
-File: resultGeometryListController.js (resultGeometryListController.js)
-File: ResultGeometryListModel (resultGeometryListModel.js)
+Group: Http {
+ Group: Javascripts {
+ File: AddWmsFromTree (http/javascripts/mod_addWMSfromTree.js)
+ File: changeEPSG (http/javascripts/mod_changeEPSG.js)
+ File: coordsLookup (http/javascripts/mod_coordsLookup.js)
+ File: doubleclickZoom (http/javascripts/mod_doubleclickZoom.js)
+ File: firebug_lite (http/javascripts/mod_firebug_lite.js)
+ File: gazetteerWFS (http/javascripts/mod_wfs_gazetteer_client.php)
+ File: jq_jgrowl (http/javascripts/jq_jgrowl.js)
+ File: jq_ui_effects (http/javascripts/jq_ui_effects.php)
+ File: Log (http/javascripts/mod_log.js)
+ File: Map (http/javascripts/map_obj.js)
+ File: Mapbender (http/javascripts/core.php)
+ File: mousewheelZoom (http/javascripts/mod_mousewheelZoom.js)
+ File: overviewToggle (http/javascripts/mod_overviewToggle.js)
+ File: Reload (http/javascripts/mod_reload.js)
+ File: repaint (http/javascripts/mod_repaint.js)
+ File: repaint (http/javascripts/mod_repaint.php)
+ File: ResizeMapsize (http/javascripts/mod_resize_mapsize.js)
+ File: resultList (http/javascripts/mod_ResultList.js)
+ File: Sandclock (http/javascripts/mod_sandclock.js)
+ File: savewmc (http/javascripts/mod_savewmc.js)
+ File: scalebar (http/javascripts/mod_scalebar.js)
+ File: selArea (http/javascripts/mod_selArea.js)
+ File: selArea (http/javascripts/mod_pan.js)
+ File: zoomFull (http/javascripts/mod_zoomFull.js)
+ File: ZoomIn1 (http/javascripts/mod_zoomIn1.js)
+ File: ZoomOut1 (http/javascripts/mod_zoomOut1.js)
+ } # Group: Javascripts
+ Group: Plugins {
+ File: <Application element name> (http/plugins/ol_wms.php)
+ File: cookie (http/plugins/mb_cookie.js)
+ File: i18n (http/plugins/mb_i18n.js)
+ File: jq_datatables (http/plugins/jq_datatables.js)
+ File: jq_ui_accordion (http/plugins/jq_ui_accordion.js)
+ File: jq_ui_effects (http/plugins/jq_ui_effects.js)
+ File: jq_ui_resizable (http/plugins/jq_ui_resizable.js)
+ File: mapframe1 (http/plugins/mb_map.js)
+ File: mb_navigation (http/plugins/mb_navigation.js)
+ File: mb_resultList_transferToDigitize (http/plugins/mb_resultList_transferToDigitize.js)
+ File: mb_zoomIn (http/plugins/mb_zoomIn.js)
+ File: mb_zoomOut (http/plugins/mb_zoomOut.js)
+ File: ol (http/plugins/ol.js)
+ File: ol_keyboardDefaults (http/plugins/ol_keyboardDefaults.js)
+ File: ol_layerSwitch (http/plugins/ol_layerSwitch.js)
+ File: ol_mousePosition (http/plugins/ol_mousePosition.js)
+ File: ol_overviewMap (http/plugins/ol_overview.js)
+ File: ol_panZoomBar (http/plugins/ol_panZoomBar.js)
+ File: Overview (http/plugins/mb_overview.js)
+ File: printPDF (http/plugins/mb_print.js)
+ File: resize (http/plugins/mb_resize.js)
+ File: selectMapsize (http/plugins/mb_selectMapsize.js)
+ File: tabs_vertical (http/plugins/mb_tabs_vertical.js)
+ File: twitter_signin (http/plugins/mb_twitter_signin.js)
+ File: wmsTimeInterval (http/plugins/mb_wmsTimeInterval.js)
+ File: wmsTimeSliderYear (http/plugins/mb_wmsTimeSliderYear.js)
+ } # Group: Plugins
+ } # Group: Http
+Group: Lib {
+ File: Ajax (lib/ajax.js)
+ File: Button (lib/button.js)
+ File: Event (lib/event.js)
+ File: Exception (lib/exception.js)
+ File: Extent (lib/extent.js)
+ File: List (lib/list.js)
+ File: mapbender (lib/basic.js)
+ File: Mapbender.Marker (lib/marker.js)
+ File: Point (lib/point.js)
+ File: resultGeometryListController.js (lib/resultGeometryListController.js)
+ File: ResultGeometryListModel (lib/resultGeometryListModel.js)
+ } # Group: Lib
+Group: Resources {
+ File: inspire_md_data (resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8.sql)
+ File: pgsql/.../update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql (resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql)
+ File: sql_updates_monitoring.sql (resources/db/sql_updates_monitoring.sql)
+ } # Group: Resources
+Group: Test {
+ File: dist/.../1.1.rc2/env.1.1.rc2.js (test/tools/env-js/dist/releases/1.1.rc2/env.1.1.rc2.js)
+ File: dist/.../1.1.rc2/env.rhino.1.1.rc2.js (test/tools/env-js/dist/releases/1.1.rc2/env.rhino.1.1.rc2.js)
+ File: src/.../js/jquery.js (test/tools/env-js/src/css/jss-0-4/js/jquery.js)
+ } # Group: Test
Group: Index {
Index: Everything
@@ -65,5 +146,10 @@
Function Index: Functions
Property Index: Properties
File Index: Files
+ Database Index Index: Database Indexes
+ Database Table Index: Database Tables
+ Database Trigger Index: Database Triggers
+ Database View Index: Database Views
+ Variable Index: Variables
} # Group: Index
Added: trunk/mapbender/documents/api_js/Menu_Backup_3.txt
--- trunk/mapbender/documents/api_js/Menu_Backup_3.txt (rev 0)
+++ trunk/mapbender/documents/api_js/Menu_Backup_3.txt 2010-02-24 16:16:02 UTC (rev 5640)
@@ -0,0 +1,69 @@
+Format: 1.4
+# You can add a title and sub-title to your menu like this:
+# Title: [project name]
+# SubTitle: [subtitle]
+# You can add a footer to your documentation like this:
+# Footer: [text]
+# If you want to add a copyright notice, this would be the place to do it.
+# You can add a timestamp to your documentation like one of these:
+# Timestamp: Generated on month day, year
+# Timestamp: Updated mm/dd/yyyy
+# Timestamp: Last updated mon day
+# m - One or two digit month. January is "1"
+# mm - Always two digit month. January is "01"
+# mon - Short month word. January is "Jan"
+# month - Long month word. January is "January"
+# d - One or two digit day. 1 is "1"
+# dd - Always two digit day. 1 is "01"
+# day - Day with letter extension. 1 is "1st"
+# yy - Two digit year. 2006 is "06"
+# yyyy - Four digit year. 2006 is "2006"
+# year - Four digit year. 2006 is "2006"
+# Cut and paste the lines below to change the order in which your files
+# appear on the menu. Don't worry about adding or removing files, Natural
+# Docs will take care of that.
+# You can further organize the menu by grouping the entries. Add a
+# "Group: [name] {" line to start a group, and add a "}" to end it.
+# You can add text and web links to the menu by adding "Text: [text]" and
+# "Link: [name] ([URL])" lines, respectively.
+# The formatting and comments are auto-generated, so don't worry about
+# neatness when editing the file. Natural Docs will clean it up the next
+# time it is run. When working with groups, just deal with the braces and
+# forget about the indentation and comments.
+File: Ajax (ajax.js)
+File: Button (button.js)
+File: Event (event.js)
+File: Exception (exception.js)
+File: Extent (extent.js)
+File: List (list.js)
+File: mapbender (basic.js)
+File: Mapbender.Marker (marker.js)
+File: Point (point.js)
+File: resultGeometryListController.js (resultGeometryListController.js)
+File: ResultGeometryListModel (resultGeometryListModel.js)
+Group: Index {
+ Index: Everything
+ Class Index: Classes
+ Function Index: Functions
+ Property Index: Properties
+ File Index: Files
+ } # Group: Index
Modified: trunk/mapbender/documents/api_js/index/Classes.html
--- trunk/mapbender/documents/api_js/index/Classes.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/Classes.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,51 +11,96 @@
-<div id=Index><div class=IPageTitle>Class Index</div><div class=INavigationBar>$#! · 0-9 · <a href="#A">A</a> · <a href="#B">B</a> · C · D · <a href="#E">E</a> · F · G · H · I · J · K · <a href="#L">L</a> · <a href="#M">M</a> · <a href="#N">N</a> · O · <a href="#P">P</a> · Q · <a href="#R">R</a> · S · T · U · V · <a href="#W">W</a> · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Ajax" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/button-js.html#Button" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/event-js.html#Event" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/exception-js.html#Exception" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>Exception</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/extent-js.html#Extent" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>Extent</a></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/list-js.html#List" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>List</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/basic-js.html#mapbender" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>Mapbender.<wbr>Marker</a></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/exception-js.html#Notice" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>Notice</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Notification" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Notification</a></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/point-js.html#Point" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Point</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Request" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>Request</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>ResultGeometryListModel</a></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/exception-js.html#Warning" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>Warning</a></td></tr></table>
+<div id=Index><div class=IPageTitle>Class Index</div><div class=INavigationBar><a href="#Symbols">$#!</a> · 0-9 · <a href="#A">A</a> · <a href="#B">B</a> · <a href="#C">C</a> · <a href="#D">D</a> · <a href="#E">E</a> · <a href="#F">F</a> · <a href="#G">G</a> · H · <a href="#I">I</a> · <a href="#J">J</a> · K · <a href="#L">L</a> · <a href="#M">M</a> · <a href="#N">N</a> · <a href="#O">O</a> · <a href="#P">P</a> · Q · <a href="#R">R</a> · <a href="#S">S</a> · <a href="#T">T</a> · U · V · <a href="#W">W</a> · X · Y · <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="Symbols"></a>$#!</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/ol_wms-php.html#Application_element_name" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol><Application element name></a></td></tr><tr><td class=IHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>AddWmsFromTree</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/button-js.html#Button" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_changeEPSG-js.html#changeEPSG" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>changeEPSG</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_cookie-js.html#cookie" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>cookie</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_coordsLookup-js.html#coordsLookup" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>coordsLookup</a></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_doubleclickZoom-js.html#doubleclickZoom" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>doubleclickZoom</a></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/exception-js.html#Exception" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Exception</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/extent-js.html#Extent" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Extent</a></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>firebug_lite</a></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>gazetteerWFS</a></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_i18n-js.html#i18n" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>i18n</a></td></tr><tr><td class=IHeading><a name="J"></a>J</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/jq_datatables-js.html#jq_datatables" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>jq_datatables</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/jq_jgrowl-js.html#jq_jgrowl" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>jq_jgrowl</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/jq_ui_accordion-js.html#jq_ui_accordion" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>jq_ui_accordion</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>jq_ui_effects</span><div class=ISubIndex><a href="../files/http/javascripts/jq_ui_effects-php.html#jq_ui_effects" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=IFile>http/<wbr>javascripts/<wbr>jq_ui_effects.php</a><a href="../files/http/plugins/jq_ui_effects-js.html#jq_ui_effects" id=link19 onMouseOver="ShowTip(event, 'tt18', 'link19')" onMouseOut="HideTip('tt18')" class=IFile>http/<wbr>plugins/<wbr>jq_ui_effects.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/jq_ui_resizable-js.html#jq_ui_resizable" id=link20 onMouseOver="ShowTip(event, 'tt19', 'link20')" onMouseOut="HideTip('tt19')" class=ISymbol>jq_ui_resizable</a></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/list-js.html#List" id=link21 onMouseOver="ShowTip(event, 'tt20', 'link21')" onMouseOut="HideTip('tt20')" class=ISymbol>List</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" id=link22 onMouseOver="ShowTip(event, 'tt21', 'link22')" onMouseOut="HideTip('tt21')" class=ISymbol>Log</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" id=link23 onMouseOver="ShowTip(event, 'tt22', 'link23')" onMouseOut="HideTip('tt22')" class=ISymbol>Map</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender" id=link24 onMouseOver="ShowTip(event, 'tt23', 'link24')" onMouseOut="HideTip('tt23')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link25 onMouseOver="ShowTip(event, 'tt24', 'link25')" onMouseOut="HideTip('tt24')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker" id=link26 onMouseOver="ShowTip(event, 'tt25', 'link26')" onMouseOut="HideTip('tt25')" class=ISymbol>Mapbender.<wbr>Marker</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" id=link27 onMouseOver="ShowTip(event, 'tt26', 'link27')" onMouseOut="HideTip('tt26')" class=ISymbol>mapframe1</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" id=link28 onMouseOver="ShowTip(event, 'tt27', 'link28')" onMouseOut="HideTip('tt27')" class=ISymbol>mb_navigation</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" id=link29 onMouseOver="ShowTip(event, 'tt28', 'link29')" onMouseOut="HideTip('tt28')" class=ISymbol>mb_resultList_transferToDigitize</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" id=link30 onMouseOver="ShowTip(event, 'tt29', 'link30')" onMouseOut="HideTip('tt29')" class=ISymbol>mb_zoomIn</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" id=link31 onMouseOver="ShowTip(event, 'tt30', 'link31')" onMouseOut="HideTip('tt30')" class=ISymbol>mb_zoomOut</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" id=link32 onMouseOver="ShowTip(event, 'tt31', 'link32')" onMouseOut="HideTip('tt31')" class=ISymbol>mousewheelZoom</a></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/exception-js.html#Notice" id=link33 onMouseOver="ShowTip(event, 'tt32', 'link33')" onMouseOut="HideTip('tt32')" class=ISymbol>Notice</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/ajax-js.html#Notification" id=link34 onMouseOver="ShowTip(event, 'tt33', 'link34')" onMouseOut="HideTip('tt33')" class=ISymbol>Notification</a></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/ol-js.html#ol" id=link35 onMouseOver="ShowTip(event, 'tt34', 'link35')" onMouseOut="HideTip('tt34')" class=ISymbol>ol</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/ol_keyboardDefaults-js.html#ol_keyboardDefaults" id=link36 onMouseOver="ShowTip(event, 'tt35', 'link36')" onMouseOut="HideTip('tt35')" class=ISymbol>ol_keyboardDefaults</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/ol_layerSwitch-js.html#ol_layerSwitch" id=link37 onMouseOver="ShowTip(event, 'tt36', 'link37')" onMouseOut="HideTip('tt36')" class=ISymbol>ol_layerSwitch</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/ol_mousePosition-js.html#ol_mousePosition" id=link38 onMouseOver="ShowTip(event, 'tt37', 'link38')" onMouseOut="HideTip('tt37')" class=ISymbol>ol_mousePosition</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/ol_overview-js.html#ol_overviewMap" id=link39 onMouseOver="ShowTip(event, 'tt38', 'link39')" onMouseOut="HideTip('tt38')" class=ISymbol>ol_overviewMap</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/ol_panZoomBar-js.html#ol_panZoomBar" id=link40 onMouseOver="ShowTip(event, 'tt39', 'link40')" onMouseOut="HideTip('tt39')" class=ISymbol>ol_panZoomBar</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_overview-js.html#Overview" id=link41 onMouseOver="ShowTip(event, 'tt40', 'link41')" onMouseOut="HideTip('tt40')" class=ISymbol>Overview</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_overviewToggle-js.html#overviewToggle" id=link42 onMouseOver="ShowTip(event, 'tt41', 'link42')" onMouseOut="HideTip('tt41')" class=ISymbol>overviewToggle</a></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/point-js.html#Point" id=link43 onMouseOver="ShowTip(event, 'tt42', 'link43')" onMouseOut="HideTip('tt42')" class=ISymbol>Point</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF" id=link44 onMouseOver="ShowTip(event, 'tt43', 'link44')" onMouseOut="HideTip('tt43')" class=ISymbol>printPDF</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" id=link45 onMouseOver="ShowTip(event, 'tt44', 'link45')" onMouseOut="HideTip('tt44')" class=ISymbol>Reload</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>repaint</span><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" id=link46 onMouseOver="ShowTip(event, 'tt45', 'link46')" onMouseOut="HideTip('tt45')" class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" id=link47 onMouseOver="ShowTip(event, 'tt45', 'link47')" onMouseOut="HideTip('tt45')" class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/ajax-js.html#Request" id=link48 onMouseOver="ShowTip(event, 'tt46', 'link48')" onMouseOut="HideTip('tt46')" class=ISymbol>Request</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" id=link49 onMouseOver="ShowTip(event, 'tt47', 'link49')" onMouseOut="HideTip('tt47')" class=ISymbol>resize</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" id=link50 onMouseOver="ShowTip(event, 'tt48', 'link50')" onMouseOut="HideTip('tt48')" class=ISymbol>ResizeMapsize</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" id=link51 onMouseOver="ShowTip(event, 'tt49', 'link51')" onMouseOut="HideTip('tt49')" class=ISymbol>ResultGeometryListModel</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" id=link52 onMouseOver="ShowTip(event, 'tt50', 'link52')" onMouseOut="HideTip('tt50')" class=ISymbol>resultList</a></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock" id=link53 onMouseOver="ShowTip(event, 'tt51', 'link53')" onMouseOut="HideTip('tt51')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_savewmc-js.html#savewmc" id=link54 onMouseOver="ShowTip(event, 'tt52', 'link54')" onMouseOut="HideTip('tt52')" class=ISymbol>savewmc</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_scalebar-js.html#scalebar" id=link55 onMouseOver="ShowTip(event, 'tt53', 'link55')" onMouseOut="HideTip('tt53')" class=ISymbol>scalebar</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>selArea</span><div class=ISubIndex><a href="../files/http/javascripts/mod_pan-js.html#selArea" id=link56 onMouseOver="ShowTip(event, 'tt54', 'link56')" onMouseOut="HideTip('tt54')" class=IFile>http/<wbr>javascripts/<wbr>mod_pan.js</a><a href="../files/http/javascripts/mod_selArea-js.html#selArea" id=link57 onMouseOver="ShowTip(event, 'tt54', 'link57')" onMouseOut="HideTip('tt54')" class=IFile>http/<wbr>javascripts/<wbr>mod_selArea.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_selectMapsize-js.html#selectMapsize" id=link58 onMouseOver="ShowTip(event, 'tt55', 'link58')" onMouseOut="HideTip('tt55')" class=ISymbol>selectMapsize</a></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_tabs_vertical-js.html#tabs_vertical" id=link59 onMouseOver="ShowTip(event, 'tt56', 'link59')" onMouseOut="HideTip('tt56')" class=ISymbol>tabs_vertical</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_twitter_signin-js.html#twitter_signin" id=link60 onMouseOver="ShowTip(event, 'tt57', 'link60')" onMouseOut="HideTip('tt57')" class=ISymbol>twitter_signin</a></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/exception-js.html#Warning" id=link61 onMouseOver="ShowTip(event, 'tt58', 'link61')" onMouseOut="HideTip('tt58')" class=ISymbol>Warning</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_wmsTimeInterval-js.html#wmsTimeInterval" id=link62 onMouseOver="ShowTip(event, 'tt59', 'link62')" onMouseOut="HideTip('tt59')" class=ISymbol>wmsTimeInterval</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html#wmsTimeSliderYear" id=link63 onMouseOver="ShowTip(event, 'tt60', 'link63')" onMouseOut="HideTip('tt60')" class=ISymbol>wmsTimeSliderYear</a></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_zoomFull-js.html#zoomFull" id=link64 onMouseOver="ShowTip(event, 'tt61', 'link64')" onMouseOut="HideTip('tt61')" class=ISymbol>zoomFull</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-js.html#ZoomIn1" id=link65 onMouseOver="ShowTip(event, 'tt62', 'link65')" onMouseOut="HideTip('tt62')" class=ISymbol>ZoomIn1</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_zoomOut1-js.html#ZoomOut1" id=link66 onMouseOver="ShowTip(event, 'tt63', 'link66')" onMouseOut="HideTip('tt63')" class=ISymbol>ZoomOut1</a></td></tr></table>
<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CClass>An AJAX wrapper for client server interaction via JSON RPC</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CClass>A description</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt2"><div class=CClass>Adds a clickable button to Mapbender</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt2"><div class=CClass>Add a WMS from a container. </div></div><div class=CToolTip id="tt3"><div class=CClass>An AJAX wrapper for client server interaction via JSON RPC</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt3"><div class=CClass>An event. </div></div><div class=CToolTip id="tt4"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt5"><div class=CClass>An extent is also known as a bounding box.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt4"><div class=CClass>Adds a clickable button to Mapbender</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt6"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt5"><div class=CClass>Select a spatial reference system EPSG code. </div></div><div class=CToolTip id="tt6"><div class=CClass>Sets a cookie after each map request. </div></div><div class=CToolTip id="tt7"><div class=CClass>The user enters a coordinate tuple and selects the corresponding SRS from a select box. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt7"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt8"><div class=CClass>A very basic marker class. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CClass>Adds behaviour to maps specified in the target field. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt9"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt10"><div class=CClass>An AJAX notification (it doesn’t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt9"><div class=CClass>An event. </div></div><div class=CToolTip id="tt10"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt11"><div class=CClass>An extent is also known as a bounding box.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt11"><div class=CClass>A class representing a two- (or three-) dimensional point.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt12"><div class=CClass>Simply includes the Firebug lite JavaScript and CSS</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt12"><div class=CClass>An AJAX request (it expects a reply from the server)</div></div><div class=CToolTip id="tt13"><div class=CClass>A feature collection of a result geometry list.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt13"><div class=CClass>A WFS gazetteer for pre configured WFS configurations.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt14"><div class=CClass>Logs an warning in the log file, in a console window or as an alert</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt14"><div class=CClass>Internationalization module, collects data from all elements and sends them to the server in a single POST request. </div></div><!--END_ND_TOOLTIPS-->
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt15"><div class=CClass>Includes the jQuery plugin datatables, use like this</div></div><div class=CToolTip id="tt16"><div class=CClass>The container for the jQuery plugin jGrowl</div></div><div class=CToolTip id="tt17"><div class=CClass>Accordion from the jQuery UI framework</div></div><div class=CToolTip id="tt18"><div class=CClass>A collection of jQuery UI effects</div></div><div class=CToolTip id="tt19"><div class=CClass>Resizable from the jQuery UI framework</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt20"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><div class=CToolTip id="tt21"><div class=CClass>Logs the accesses to the guis in the database or a logfile The accesses will be written in the mapbender database on table mb_log or into mapbender/log/mb_access_$DATE.log. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt22"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt23"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt24"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt25"><div class=CClass>A very basic marker class. </div></div><div class=CToolTip id="tt26"><div class=CClass>The main map in Mapbender</div></div><div class=CToolTip id="tt27"><div class=CClass>Adds navigation arrows on top of the map</div></div><div class=CToolTip id="tt28"><div class=CClass>A description</div></div><div class=CToolTip id="tt29"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt30"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><div class=CToolTip id="tt31"><div class=CClass>Zoom in/out with the mousewheel. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt32"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt33"><div class=CClass>An AJAX notification (it doesn’t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt34"><div class=CClass>An OpenLayers Map, configured with WMS from Mapbender application settings</div></div><div class=CToolTip id="tt35"><div class=CClass>An OpenLayers KeyboardDefaults</div></div><div class=CToolTip id="tt36"><div class=CClass>An OpenLayers Layer Switch</div></div><div class=CToolTip id="tt37"><div class=CClass>An OpenLayers MousePosition</div></div><div class=CToolTip id="tt38"><div class=CClass>An OpenLayers Layer Switch</div></div><div class=CToolTip id="tt39"><div class=CClass>An OpenLayers panZoomBar</div></div><div class=CToolTip id="tt40"><div class=CClass>Use the overview map to navigate the main map window. </div></div><div class=CToolTip id="tt41"><div class=CClass>shows and hides the overview module with a jQuery animation</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt42"><div class=CClass>A class representing a two- (or three-) dimensional point.</div></div><div class=CToolTip id="tt43"><div class=CClass>Mapbender print PDF with PDF templates module.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt44"><div class=CClass>A button that reloads the whole window.</div></div><div class=CToolTip id="tt45"><div class=CClass>Repaints a map. </div></div><div class=CToolTip id="tt46"><div class=CClass>An AJAX request (it expects a reply from the server)</div></div><div class=CToolTip id="tt47"><div class=CClass>Adds a resizable plugin to the module in target, for example mapframe1</div></div><div class=CToolTip id="tt48"><div class=CClass>This modul dynamically resizes the mapframe in relation to the browsersize. </div></div><div class=CToolTip id="tt49"><div class=CClass>A feature collection of a result geometry list.</div></div><div class=CToolTip id="tt50"><div class=CClass>A result list for featureCollections</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt51"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt52"><div class=CClass>save workspace as WMC</div></div><div class=CToolTip id="tt53"><div class=CClass>Displays scalebar in the map. </div></div><div class=CToolTip id="tt54"><div class=CClass>Zoom by rectangle</div></div><div class=CToolTip id="tt55"><div class=CClass>Select the map size from a pre defined settings, like large or small</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt56"><div class=CClass>An accordion decorator, replaces the deprecated element “tabs”</div></div><div class=CToolTip id="tt57"><div class=CClass>Authenticate with Twitter</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt58"><div class=CClass>Logs an warning in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt59"><div class=CClass>Find an interval with two datepickers and attach it to getMap requests of WMS in your application</div></div><div class=CToolTip id="tt60"><div class=CClass>sets the TIME parameter for all activated WMS (years only)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt61"><div class=CClass>Click button to zoom to the full extent of the BoundingBox.</div></div><div class=CToolTip id="tt62"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt63"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><!--END_ND_TOOLTIPS-->
</div><!--Index-->
<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option></select></div></div><!--Menu-->
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([7, 6, 5], 8);// --></script></div><!--Menu-->
<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
Modified: trunk/mapbender/documents/api_js/index/DatabaseIndexes.html
--- trunk/mapbender/documents/api_js/index/DatabaseIndexes.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/DatabaseIndexes.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -21,7 +21,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Database Indexes</div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Database Indexes</div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index/DatabaseTables.html
--- trunk/mapbender/documents/api_js/index/DatabaseTables.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/DatabaseTables.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -37,7 +37,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Database Tables</div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Database Tables</div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index/DatabaseTriggers.html
--- trunk/mapbender/documents/api_js/index/DatabaseTriggers.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/DatabaseTriggers.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -21,7 +21,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Database Triggers</div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Database Triggers</div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
HideAllBut([7, 6, 5], 8);// --></script></div><!--Menu-->
Modified: trunk/mapbender/documents/api_js/index/DatabaseViews.html
--- trunk/mapbender/documents/api_js/index/DatabaseViews.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/DatabaseViews.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -25,7 +25,7 @@
<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Database Views</div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Database Views</div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index/Files.html
--- trunk/mapbender/documents/api_js/index/Files.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/Files.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,19 +11,36 @@
-<div id=Index><div class=IPageTitle>File Index</div><div class=INavigationBar>$#! · 0-9 · A · B · C · D · E · F · G · H · I · J · K · L · M · N · O · P · Q · <a href="#R">R</a> · S · T · U · V · W · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListController-js.html#resultGeometryListController.js" class=ISymbol>resultGeometryListController.js</a></td></tr></table>
+<div id=Index><div class=IPageTitle>File Index</div><div class=INavigationBar>$#! · 0-9 · A · B · C · D · <a href="#E">E</a> · F · G · H · I · <a href="#J">J</a> · K · L · M · N · O · P · Q · <a href="#R">R</a> · <a href="#S">S</a> · T · <a href="#U">U</a> · V · W · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#env.1.1.rc2.js" class=ISymbol>env.<wbr>1.1.<wbr>rc2.js</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#env.rhino.1.1.rc2.js" class=ISymbol>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></td></tr><tr><td class=IHeading><a name="J"></a>J</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#jquery.js" class=ISymbol>jquery.js</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js" class=ISymbol>resultGeometryListController.js</a></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/sql_updates_monitoring-sql.html#sql_updates_monitoring.sql" class=ISymbol>sql_updates_monitoring.sql</a></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql" class=ISymbol>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></td></tr></table>
<!--START_ND_TOOLTIPS-->
<!--END_ND_TOOLTIPS-->
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
</div><!--Index-->
-<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Files</div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Files</div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option></select></div></div><!--Menu-->
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([7, 6, 5], 8);// --></script></div><!--Menu-->
<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
Modified: trunk/mapbender/documents/api_js/index/Functions.html
--- trunk/mapbender/documents/api_js/index/Functions.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/Functions.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,67 +11,80 @@
-<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! · 0-9 · <a href="#A">A</a> · B · <a href="#C">C</a> · <a href="#D">D</a> · <a href="#E">E</a> · F · <a href="#G">G</a> · H · I · J · K · L · <a href="#M">M</a> · <a href="#N">N</a> · O · <a href="#P">P</a> · Q · <a href="#R">R</a> · <a href="#S">S</a> · <a href="#T">T</a> · <a href="#U">U</a> · V · <a href="#W">W</a> · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeatureCollection" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListController-js.html#addFeatureCollection_callback" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/basic-js.html#mapbender.cloneObject" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/basic-js.html#mapbender.cookiesEnables" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/exception-js.html#Exception.Exception" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Exception</a>, <span class=IParent>Exception</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/extent-js.html#Extent.Extent" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Extent</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/basic-js.html#mapbender.getConjunctionChar" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.Mapbender.Marker" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/exception-js.html#Notice.Notice" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>Notice</a>, <span class=IParent>Notice</span></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/point-js.html#Point.Point" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>Point</a>, <span class=IParent>Point</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.remove" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/ajax-js.html#Notification.Mapbender.Ajax.Request" class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/ajax-js.html#Request.Mapbender.Ajax.Request" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Request.send" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/extent-js.html#Extent.set" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/extent-js.html#Extent.toString" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/exception-js.html#Warning.Warning" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>Warning</a>, <span class=IParent>Warning</span></td></tr></table>
+<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! · 0-9 · <a href="#A">A</a> · B · <a href="#C">C</a> · <a href="#D">D</a> · <a href="#E">E</a> · <a href="#F">F</a> · <a href="#G">G</a> · <a href="#H">H</a> · I · J · K · <a href="#L">L</a> · <a href="#M">M</a> · <a href="#N">N</a> · O · <a href="#P">P</a> · Q · <a href="#R">R</a> · <a href="#S">S</a> · <a href="#T">T</a> · <a href="#U">U</a> · V · <a href="#W">W</a> · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/exception-js.html#Exception.Exception" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>Exception</a>, <span class=IParent>Exception</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.Extent" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>Extent</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_epsg(integer)" class=ISymbol>f_collect_epsg(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext(integer,integer)" class=ISymbol>f_collect_searchtext(integer,integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext_wfs(integer,integer)" class=ISymbol>f_collect_searchtext_wfs(integer,integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfs_tou(integer)" class=ISymbol>f_getwfs_tou(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfsmodultype(integer)" class=ISymbol>f_getwfsmodultype(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwms_tou(integer)" class=ISymbol>f_getwms_tou(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_layer_load_count(integer)" class=ISymbol>f_layer_load_count(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.hide" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.hookForm" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>hookForm</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>Map</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.Mapbender.Marker" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>mb_monitor_after</span>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after" class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after" class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/exception-js.html#Notice.Notice" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>Notice</a>, <span class=IParent>Notice</span></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/point-js.html#Point.Point" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>Point</a>, <span class=IParent>Point</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.remove" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>SAXDriver</span><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#SAXDriver" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#SAXDriver" id=link34 onMouseOver="ShowTip(event, 'tt33', 'link34')" onMouseOut="HideTip('tt33')" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/ajax-js.html#Request.send" id=link35 onMouseOver="ShowTip(event, 'tt34', 'link35')" onMouseOut="HideTip('tt34')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.set" id=link36 onMouseOver="ShowTip(event, 'tt35', 'link36')" onMouseOut="HideTip('tt35')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link37 onMouseOver="ShowTip(event, 'tt36', 'link37')" onMouseOut="HideTip('tt36')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link38 onMouseOver="ShowTip(event, 'tt37', 'link38')" onMouseOut="HideTip('tt37')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" id=link39 onMouseOver="ShowTip(event, 'tt38', 'link39')" onMouseOut="HideTip('tt38')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" id=link40 onMouseOver="ShowTip(event, 'tt39', 'link40')" onMouseOut="HideTip('tt39')" class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>this is the constructor to the XMLP Object</span><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" id=link41 onMouseOver="ShowTip(event, 'tt40', 'link41')" onMouseOut="HideTip('tt40')" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" id=link42 onMouseOver="ShowTip(event, 'tt40', 'link42')" onMouseOut="HideTip('tt40')" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" id=link43 onMouseOver="ShowTip(event, 'tt41', 'link43')" onMouseOut="HideTip('tt41')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link44 onMouseOver="ShowTip(event, 'tt42', 'link44')" onMouseOut="HideTip('tt42')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/exception-js.html#Warning.Warning" id=link45 onMouseOver="ShowTip(event, 'tt43', 'link45')" onMouseOut="HideTip('tt43')" class=ISymbol>Warning</a>, <span class=IParent>Warning</span></td></tr></table>
-<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addGlobalButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Descriptions: adds a Button to the bottom of the resultList Parameters: buttondef: {Object} an object with five properties, “title”, “type” (either button or select) “classes” (the classes the button should have), “selectoptions” (an array in case the type is select), “callback”</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addPopupButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list Parameters: buttondef: {Object} an object with two properties: “title” and “callback”, a function that gets the feature that corresponds to the popup as it’s argument</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt7"><div class=CFunction>Checks whether cookies are enabled in the browser</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt9"><div class=CFunction>Checks whether cookies are enabled in the browser</div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.createPrintBox = function ()</td></tr></table></blockquote>creates a printBox in the current view, calculates the scale (tbd. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var destroyPrintBox = function ()</td></tr></table></blockquote>removes an existing printBox.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt24"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><!--END_ND_TOOLTIPS-->
<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt24"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt30"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt31"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt32"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt33"><div class=CFunction>Author: Scott Severtson Description: SAXDriver is an object that basically wraps an XMLP instance, and provides an event-based interface for parsing. </div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt36"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>nodeId,</td></tr><tr><td></td><td class=PParameter nowrap>arg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var showResult = function (</td><td class=PParameter nowrap>res,</td></tr><tr><td></td><td class=PParameter nowrap>text</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</div></div><!--END_ND_TOOLTIPS-->
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt40"><div class=CFunction>Author: Scott Severtson Description:XMLP is a pull-based parser. </div></div><div class=CToolTip id="tt41"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt42"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt43"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
</div><!--Index-->
<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option></select></div></div><!--Menu-->
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([7, 6, 5], 8);// --></script></div><!--Menu-->
<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
Modified: trunk/mapbender/documents/api_js/index/General.html
--- trunk/mapbender/documents/api_js/index/General.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/General.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,79 +11,72 @@
-<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar>$#! · 0-9 · <a href="#A">A</a> · <a href="#B">B</a> · <a href="#C">C</a> · <a href="#D">D</a> · <a href="#E">E</a> · <a href="#F">F</a> · <a href="#G">G</a> · H · I · J · K · <a href="#L">L</a> · <a href="#M">M</a> · <a href="#N">N</a> · O · <a href="#P">P</a> · Q · <a href="#R">R</a> · <a href="#S">S</a> · <a href="#T">T</a> · <a href="#U">U</a> · V · <a href="#W">W</a> · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeatureCollection" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListController-js.html#addFeatureCollection_callback" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Ajax" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/button-js.html#Button" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/basic-js.html#mapbender.cloneObject" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/basic-js.html#mapbender.cookiesEnables" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/event-js.html#Event" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.events" class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>Exception</span><div class=ISubIndex><a href="../files/exception-js.html#Exception" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=IParent>Global</a><a href="../files/exception-js.html#Exception.Exception" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=IParent>Exception</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Extent</span><div class=ISubIndex><a href="../files/extent-js.html#Extent" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=IParent>Global</a><a href="../files/extent-js.html#Extent.Extent" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=IParent>Extent</a></div></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#Functions" class=IParent>Global</a><a href="../files/exception-js.html#Exception.Functions" class=IParent>Exception</a><a href="../files/extent-js.html#Extent.Functions" class=IParent>Extent</a><a href="../files/basic-js.html#mapbender.Functions" class=IParent>mapbender</a><a href="../files/marker-js.html#Mapbender.Marker.Functions" class=IParent>Mapbender.<wbr>Marker</a><a href="../files/exception-js.html#Notice.Functions" class=IParent>Notice</a><a href="../files/ajax-js.html#Notification.Functions" class=IParent>Notification</a><a href="../files/point-js.html#Point.Functions" class=IParent>Point</a><a href="../files/ajax-js.html#Request.Functions" class=IParent>Request</a><a href="../files/exception-js.html#Warning.Functions" class=IParent>Warning</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties" class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/basic-js.html#mapbender.getConjunctionChar" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/list-js.html#List" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>List</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/basic-js.html#mapbender" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>Mapbender.<wbr>Marker</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.Mapbender.Marker" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Notice</span><div class=ISubIndex><a href="../files/exception-js.html#Notice" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=IParent>Global</a><a href="../files/exception-js.html#Notice.Notice" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=IParent>Notice</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Notification" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>Notification</a></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Point</span><div class=ISubIndex><a href="../files/point-js.html#Point" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=IParent>Global</a><a href="../files/point-js.html#Point.Point" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=IParent>Point</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Ajax.Properties" class=ISymbol>Properties</a>, <span class=IParent>Ajax</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.remove" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/ajax-js.html#Request" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=IParent>Global</a><a href="../files/ajax-js.html#Notification.Mapbender.Ajax.Request" class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/ajax-js.html#Request.Mapbender.Ajax.Request" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Ajax.requestCount" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListController-js.html#resultGeometryListController.js" class=ISymbol>resultGeometryListController.js</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><span class=ISymbol>ResultGeometryListModel</span><div class=ISubIndex><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Request.send" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/extent-js.html#Extent.set" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/extent-js.html#Extent.toString" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><span class=ISymbol>Warning</span><div class=ISubIndex><a href="../files/exception-js.html#Warning" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=IParent>Global</a><a href="../files/exception-js.html#Warning.Warning" id=link41 onMouseOver="ShowTip(event, 'tt41', 'link41')" onMouseOut="HideTip('tt41')" class=IParent>Warning</a></div></td></tr></table>
+<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar><a href="#Symbols">$#!</a> · 0-9 · <a href="#A">A</a> · <a href="#B">B</a> · <a href="#C">C</a> · <a href="#D">D</a> · <a href="#E">E</a> · <a href="#F">F</a> · <a href="#G">G</a> · <a href="#H">H</a> · <a href="#I">I</a> · <a href="#J">J</a> · K · <a href="#L">L</a> · <a href="#M">M</a> · <a href="#N">N</a> · <a href="General2.html#O">O</a> · <a href="General2.html#P">P</a> · Q · <a href="General2.html#R">R</a> · <a href="General2.html#S">S</a> · <a href="General2.html#T">T</a> · <a href="General2.html#U">U</a> · <a href="General2.html#V">V</a> · <a href="General2.html#W">W</a> · X · Y · <a href="General2.html#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="Symbols"></a>$#!</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(#id)" class=ISymbol>$(“#id”)</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(*)" class=ISymbol>$(*)</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>$(array)</span><div class=ISubIndex><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(array)" class=IParent>Global</a><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(html).$(array)" class=IParent>$(html)</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(arraylike)" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>$(arraylike)</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(expr)" class=ISymbol>$(expr)</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#$(function)" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>$(function)</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/ol_wms-php.html#Application_element_name" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol><Application element name></a></td></tr><tr><td class=IHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.actualConfig" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>actualConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>AddWmsFromTree</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/button-js.html#Button" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_changeEPSG-js.html#changeEPSG" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>changeEPSG</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#conformity" class=ISymbol>conformity</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#conformity_relation" class=ISymbol>conformity_relation</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_cookie-js.html#cookie" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>cookie</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_coordsLookup-js.html#coordsLookup" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>coordsLookup</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#custom_category" class=ISymbol>custom_category</a></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Database Indexes</span><div class=ISubIndex><span class=IParent>Global</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#Database_Indexes" class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#Database_Indexes" class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows.Database_Indexes" class=IParent>mb_user_abo_ows</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>Database Triggers</span>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.Database_Triggers" class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.Database_Triggers" class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_doubleclickZoom-js.html#doubleclickZoom" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>doubleclickZoom</a></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#env.1.1.rc2.js" class=ISymbol>env.<wbr>1.1.<wbr>rc2.js</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#env.rhino.1.1.rc2.js" class=ISymbol>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events" class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>Exception</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Exception" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Exception" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=IParent>Exception</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Extent</span><div class=ISubIndex><a href="../files/lib/extent-js.html#Extent" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=IParent>Global</a><a href="../files/lib/extent-js.html#Extent.Extent" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=IParent>Extent</a></div></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_epsg(integer)" class=ISymbol>f_collect_epsg(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext(integer,integer)" class=ISymbol>f_collect_searchtext(integer,integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext_wfs(integer,integer)" class=ISymbol>f_collect_searchtext_wfs(integer,integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfs_tou(integer)" class=ISymbol>f_getwfs_tou(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfsmodultype(integer)" class=ISymbol>f_getwfsmodultype(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwms_tou(integer)" class=ISymbol>f_getwms_tou(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_layer_load_count(integer)" class=ISymbol>f_layer_load_count(integer)</a>, <span class=IParent>registrating_groups</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>firebug_lite</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><span class=IParent>Global</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#Functions" class=IFile>lib/<wbr>resultGeometryListController.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#Functions" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#Functions" class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div><a href="../files/lib/exception-js.html#Exception.Functions" class=IParent>Exception</a><a href="../files/lib/extent-js.html#Extent.Functions" class=IParent>Extent</a><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" class=IParent>Map</a><a href="../files/lib/basic-js.html#mapbender.Functions" class=IParent>mapbender</a><a href="../files/lib/marker-js.html#Mapbender.Marker.Functions" class=IParent>Mapbender.<wbr>Marker</a><span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.Functions" class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.Functions" class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div><a href="../files/lib/exception-js.html#Notice.Functions" class=IParent>Notice</a><a href="../files/lib/ajax-js.html#Notification.Functions" class=IParent>Notification</a><a href="../files/lib/point-js.html#Point.Functions" class=IParent>Point</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Functions" class=IParent>printPDF</a><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.Functions" class=IParent>registrating_groups</a><a href="../files/http/javascripts/mod_reload-js.html#Reload.Functions" class=IParent>Reload</a><a href="../files/lib/ajax-js.html#Request.Functions" class=IParent>Request</a><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.Functions" class=IParent>resultList</a><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.Functions" class=IParent>Sandclock</a><a href="../files/lib/exception-js.html#Warning.Functions" class=IParent>Warning</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties" class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=ISymbol>gazetteerWFS</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.hide" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.hookForm" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>hookForm</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_i18n-js.html#i18n" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>i18n</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/sql_updates_monitoring-sql.html#idx_mb_monitor_status" class=ISymbol>idx_mb_monitor_status</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>idx_mb_monitor_upload_id</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#idx_mb_monitor_upload_id" class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#idx_mb_monitor_upload_id" class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows.idx_wms_id" class=ISymbol>idx_wms_id</a>, <span class=IParent>mb_user_abo_ows</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#inspire_category" class=ISymbol>inspire_category</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#inspire_md_data" class=ISymbol>inspire_md_data</a></td></tr><tr><td class=IHeading><a name="J"></a>J</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/jq_datatables-js.html#jq_datatables" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>jq_datatables</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/jq_jgrowl-js.html#jq_jgrowl" id=link41 onMouseOver="ShowTip(event, 'tt41', 'link41')" onMouseOut="HideTip('tt41')" class=ISymbol>jq_jgrowl</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/jq_ui_accordion-js.html#jq_ui_accordion" id=link42 onMouseOver="ShowTip(event, 'tt42', 'link42')" onMouseOut="HideTip('tt42')" class=ISymbol>jq_ui_accordion</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>jq_ui_effects</span><div class=ISubIndex><a href="../files/http/javascripts/jq_ui_effects-php.html#jq_ui_effects" id=link43 onMouseOver="ShowTip(event, 'tt43', 'link43')" onMouseOut="HideTip('tt43')" class=IFile>http/<wbr>javascripts/<wbr>jq_ui_effects.php</a><a href="../files/http/plugins/jq_ui_effects-js.html#jq_ui_effects" id=link44 onMouseOver="ShowTip(event, 'tt43', 'link44')" onMouseOut="HideTip('tt43')" class=IFile>http/<wbr>plugins/<wbr>jq_ui_effects.js</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/jq_ui_resizable-js.html#jq_ui_resizable" id=link45 onMouseOver="ShowTip(event, 'tt44', 'link45')" onMouseOut="HideTip('tt44')" class=ISymbol>jq_ui_resizable</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html#jquery.js" class=ISymbol>jquery.js</a></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#layer_custom_category" class=ISymbol>layer_custom_category</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#layer_inspire_category" class=ISymbol>layer_inspire_category</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/list-js.html#List" id=link46 onMouseOver="ShowTip(event, 'tt45', 'link46')" onMouseOut="HideTip('tt45')" class=ISymbol>List</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" id=link47 onMouseOver="ShowTip(event, 'tt46', 'link47')" onMouseOut="HideTip('tt46')" class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" id=link48 onMouseOver="ShowTip(event, 'tt47', 'link48')" onMouseOut="HideTip('tt47')" class=ISymbol>Log</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Map</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" id=link49 onMouseOver="ShowTip(event, 'tt48', 'link49')" onMouseOut="HideTip('tt48')" class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link50 onMouseOver="ShowTip(event, 'tt49', 'link50')" onMouseOut="HideTip('tt49')" class=IParent>Map</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender" id=link51 onMouseOver="ShowTip(event, 'tt50', 'link51')" onMouseOut="HideTip('tt50')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link52 onMouseOver="ShowTip(event, 'tt51', 'link52')" onMouseOut="HideTip('tt51')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker" id=link53 onMouseOver="ShowTip(event, 'tt52', 'link53')" onMouseOut="HideTip('tt52')" class=ISymbol>Mapbender.<wbr>Marker</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" id=link54 onMouseOver="ShowTip(event, 'tt53', 'link54')" onMouseOut="HideTip('tt53')" class=ISymbol>mapframe1</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.Mapbender.Marker" id=link55 onMouseOver="ShowTip(event, 'tt54', 'link55')" onMouseOut="HideTip('tt54')" class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>mb_monitor_after</span>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after" class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after" class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>mb_monitor_after on mb_monitor</span>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after_on_mb_monitor" class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after_on_mb_monitor" class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" id=link56 onMouseOver="ShowTip(event, 'tt55', 'link56')" onMouseOut="HideTip('tt55')" class=ISymbol>mb_navigation</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" id=link57 onMouseOver="ShowTip(event, 'tt56', 'link57')" onMouseOut="HideTip('tt56')" class=ISymbol>mb_resultList_transferToDigitize</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows" class=ISymbol>mb_user_abo_ows</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><span class=ISymbol>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability" class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability" class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" id=link58 onMouseOver="ShowTip(event, 'tt57', 'link58')" onMouseOut="HideTip('tt57')" class=ISymbol>mb_zoomIn</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" id=link59 onMouseOver="ShowTip(event, 'tt58', 'link59')" onMouseOut="HideTip('tt58')" class=ISymbol>mb_zoomOut</a></td></tr><tr><td class=ISymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" id=link60 onMouseOver="ShowTip(event, 'tt59', 'link60')" onMouseOut="HideTip('tt59')" class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" id=link61 onMouseOver="ShowTip(event, 'tt60', 'link61')" onMouseOut="HideTip('tt60')" class=ISymbol>mousewheelZoom</a></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><span class=ISymbol>Notice</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Notice" id=link62 onMouseOver="ShowTip(event, 'tt61', 'link62')" onMouseOut="HideTip('tt61')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Notice.Notice" id=link63 onMouseOver="ShowTip(event, 'tt62', 'link63')" onMouseOut="HideTip('tt62')" class=IParent>Notice</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/lib/ajax-js.html#Notification" id=link64 onMouseOver="ShowTip(event, 'tt63', 'link64')" onMouseOut="HideTip('tt63')" class=ISymbol>Notification</a></td></tr></table>
<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><div class=CToolTip id="tt6"><div class=CClass>An AJAX wrapper for client server interaction via JSON RPC</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CVariable>Watch for when an array-like object is passed as the selector</div></div><div class=CToolTip id="tt2"><div class=CVariable>Shortcut for document ready</div></div><div class=CToolTip id="tt3"><div class=CClass>A description</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt7"><div class=CClass>Adds a clickable button to Mapbender</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt4"><div class=CProperty>object, holds the actual configuration after loading the json file</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addGlobalButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Descriptions: adds a Button to the bottom of the resultList Parameters: buttondef: {Object} an object with five properties, “title”, “type” (either button or select) “classes” (the classes the button should have), “selectoptions” (an array in case the type is select), “callback”</div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addPopupButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list Parameters: buttondef: {Object} an object with two properties: “title” and “callback”, a function that gets the feature that corresponds to the popup as it’s argument</div></div><div class=CToolTip id="tt12"><div class=CClass>Add a WMS from a container. </div></div><div class=CToolTip id="tt13"><div class=CClass>An AJAX wrapper for client server interaction via JSON RPC</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt9"><div class=CFunction>Checks whether cookies are enabled in the browser</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt14"><div class=CClass>Adds a clickable button to Mapbender</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt15"><div class=CClass>Select a spatial reference system EPSG code. </div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt17"><div class=CClass>Sets a cookie after each map request. </div></div><div class=CToolTip id="tt18"><div class=CFunction>Checks whether cookies are enabled in the browser</div></div><div class=CToolTip id="tt19"><div class=CClass>The user enters a coordinate tuple and selects the corresponding SRS from a select box. </div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.createPrintBox = function ()</td></tr></table></blockquote>creates a printBox in the current view, calculates the scale (tbd. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt12"><div class=CClass>An event. </div></div><div class=CToolTip id="tt13"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CClass>An extent is also known as a bounding box.</div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var destroyPrintBox = function ()</td></tr></table></blockquote>removes an existing printBox.</div></div><div class=CToolTip id="tt24"><div class=CClass>Adds behaviour to maps specified in the target field. </div></div><!--END_ND_TOOLTIPS-->
-<!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt25"><div class=CClass>An event. </div></div><div class=CToolTip id="tt26"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt28"><div class=CClass>An extent is also known as a bounding box.</div></div><div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt30"><div class=CClass>Simply includes the Firebug lite JavaScript and CSS</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt20"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt31"><div class=CClass>A WFS gazetteer for pre configured WFS configurations.</div></div><div class=CToolTip id="tt32"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt33"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt36"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt21"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt22"><div class=CClass>A very basic marker class. </div></div><div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt24"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt26"><div class=CClass>An AJAX notification (it doesn’t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt39"><div class=CClass>Internationalization module, collects data from all elements and sends them to the server in a single POST request. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt27"><div class=CClass>A class representing a two- (or three-) dimensional point.</div></div><div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt40"><div class=CClass>Includes the jQuery plugin datatables, use like this</div></div><div class=CToolTip id="tt41"><div class=CClass>The container for the jQuery plugin jGrowl</div></div><div class=CToolTip id="tt42"><div class=CClass>Accordion from the jQuery UI framework</div></div><div class=CToolTip id="tt43"><div class=CClass>A collection of jQuery UI effects</div></div><div class=CToolTip id="tt44"><div class=CClass>Resizable from the jQuery UI framework</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt30"><div class=CClass>An AJAX request (it expects a reply from the server)</div></div><div class=CToolTip id="tt31"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt32"><div class=CProperty>counts the number of requests that have been made</div></div><div class=CToolTip id="tt33"><div class=CClass>A feature collection of a result geometry list.</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt45"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><div class=CToolTip id="tt46"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><div class=CToolTip id="tt47"><div class=CClass>Logs the accesses to the guis in the database or a logfile The accesses will be written in the mapbender database on table mb_log or into mapbender/log/mb_access_$DATE.log. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt36"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt48"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt49"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt50"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt51"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt52"><div class=CClass>A very basic marker class. </div></div><div class=CToolTip id="tt53"><div class=CClass>The main map in Mapbender</div></div><div class=CToolTip id="tt54"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt55"><div class=CClass>Adds navigation arrows on top of the map</div></div><div class=CToolTip id="tt56"><div class=CClass>A description</div></div><div class=CToolTip id="tt57"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt58"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><div class=CToolTip id="tt59"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><div class=CToolTip id="tt60"><div class=CClass>Zoom in/out with the mousewheel. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt61"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt62"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt63"><div class=CClass>An AJAX notification (it doesn’t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
-<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt40"><div class=CClass>Logs an warning in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt41"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
</div><!--Index-->
<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option></select></div></div><!--Menu-->
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([7, 6, 5], 8);// --></script></div><!--Menu-->
<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
Modified: trunk/mapbender/documents/api_js/index/General2.html
--- trunk/mapbender/documents/api_js/index/General2.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/General2.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -53,7 +53,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index/Properties.html
--- trunk/mapbender/documents/api_js/index/Properties.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/Properties.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,23 +11,36 @@
-<div id=Index><div class=IPageTitle>Property Index</div><div class=INavigationBar>$#! · 0-9 · A · B · C · D · <a href="#E">E</a> · F · G · H · I · J · K · L · M · N · O · P · Q · <a href="#R">R</a> · S · T · U · V · W · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.events" class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/ajax-js.html#Ajax.requestCount" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></td></tr></table>
+<div id=Index><div class=IPageTitle>Property Index</div><div class=INavigationBar>$#! · 0-9 · <a href="#A">A</a> · B · C · D · <a href="#E">E</a> · F · G · H · I · J · K · L · M · N · <a href="#O">O</a> · <a href="#P">P</a> · Q · <a href="#R">R</a> · S · T · U · V · W · X · Y · Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.actualConfig" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>actualConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events" class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.events.onFormReset" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>onFormReset</a>, <span class=IParent>gazetteerWFS.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix> </td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.events.onWfsConfSelect" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>onWfsConfSelect</a>, <span class=IParent>gazetteerWFS.<wbr>events</span></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.printBox" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>printBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix> </td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CProperty>object, holds the actual configuration after loading the json file</div></div><!--END_ND_TOOLTIPS-->
+<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CProperty>counts the number of requests that have been made</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt2"><div class=CProperty>event is fired whenever the form is resetted</div></div><div class=CToolTip id="tt3"><div class=CProperty>event is fired whenever a new WFS is selected</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt4"><div class=CProperty>the movable printframe</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt5"><div class=CProperty>counts the number of requests that have been made</div></div><!--END_ND_TOOLTIPS-->
</div><!--Index-->
-<div id=Menu><div class=MEntry><div class=MFile><a href="../files/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Properties</div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Properties</div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index/Variables.html
--- trunk/mapbender/documents/api_js/index/Variables.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index/Variables.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -21,7 +21,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Variables</div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../files/lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../files/resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Variables</div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index.html
--- trunk/mapbender/documents/api_js/index.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/index.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -1 +1 @@
-<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/ajax-js.html"></head></html>
\ No newline at end of file
+<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/http/javascripts/mod_addWMSfromTree-js.html"></head></html>
Modified: trunk/mapbender/documents/api_js/javascript/searchdata.js
--- trunk/mapbender/documents/api_js/javascript/searchdata.js 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/javascript/searchdata.js 2010-02-24 16:16:02 UTC (rev 5640)
@@ -29,6 +29,36 @@
"Y": false,
"Z": true
+ "Variables": {
+ "Symbols": true,
+ "Numbers": false,
+ "A": false,
+ "B": false,
+ "C": false,
+ "D": false,
+ "E": false,
+ "F": false,
+ "G": false,
+ "H": false,
+ "I": false,
+ "J": false,
+ "K": false,
+ "L": false,
+ "M": false,
+ "N": false,
+ "O": false,
+ "P": false,
+ "Q": false,
+ "R": false,
+ "S": false,
+ "T": false,
+ "U": false,
+ "V": false,
+ "W": false,
+ "X": false,
+ "Y": false,
+ "Z": false
"Functions": {
"Symbols": false,
"Numbers": false,
@@ -37,13 +67,13 @@
"C": true,
"D": true,
"E": true,
- "F": false,
+ "F": true,
"G": true,
- "H": false,
+ "H": true,
"I": false,
"J": false,
"K": false,
- "L": false,
+ "L": true,
"M": true,
"N": true,
"O": false,
@@ -66,6 +96,36 @@
"B": false,
"C": false,
"D": false,
+ "E": true,
+ "F": false,
+ "G": false,
+ "H": false,
+ "I": false,
+ "J": true,
+ "K": false,
+ "L": false,
+ "M": false,
+ "N": false,
+ "O": false,
+ "P": false,
+ "Q": false,
+ "R": true,
+ "S": true,
+ "T": false,
+ "U": true,
+ "V": false,
+ "W": false,
+ "X": false,
+ "Y": false,
+ "Z": false
+ "DatabaseViews": {
+ "Symbols": false,
+ "Numbers": false,
+ "A": false,
+ "B": false,
+ "C": false,
+ "D": false,
"E": false,
"F": false,
"G": false,
@@ -80,6 +140,36 @@
"P": false,
"Q": false,
"R": true,
+ "S": true,
+ "T": false,
+ "U": false,
+ "V": false,
+ "W": false,
+ "X": false,
+ "Y": false,
+ "Z": false
+ "DatabaseIndexes": {
+ "Symbols": false,
+ "Numbers": false,
+ "A": false,
+ "B": false,
+ "C": false,
+ "D": false,
+ "E": false,
+ "F": false,
+ "G": false,
+ "H": false,
+ "I": true,
+ "J": false,
+ "K": false,
+ "L": false,
+ "M": false,
+ "N": false,
+ "O": false,
+ "P": false,
+ "Q": false,
+ "R": false,
"S": false,
"T": false,
"U": false,
@@ -89,32 +179,92 @@
"Y": false,
"Z": false
- "Classes": {
+ "DatabaseTables": {
"Symbols": false,
"Numbers": false,
+ "A": false,
+ "B": false,
+ "C": true,
+ "D": false,
+ "E": false,
+ "F": false,
+ "G": false,
+ "H": false,
+ "I": true,
+ "J": false,
+ "K": false,
+ "L": true,
+ "M": true,
+ "N": false,
+ "O": false,
+ "P": false,
+ "Q": false,
+ "R": false,
+ "S": false,
+ "T": false,
+ "U": false,
+ "V": false,
+ "W": true,
+ "X": false,
+ "Y": false,
+ "Z": false
+ "Classes": {
+ "Symbols": true,
+ "Numbers": false,
"A": true,
"B": true,
+ "C": true,
+ "D": true,
+ "E": true,
+ "F": true,
+ "G": true,
+ "H": false,
+ "I": true,
+ "J": true,
+ "K": false,
+ "L": true,
+ "M": true,
+ "N": true,
+ "O": true,
+ "P": true,
+ "Q": false,
+ "R": true,
+ "S": true,
+ "T": true,
+ "U": false,
+ "V": false,
+ "W": true,
+ "X": false,
+ "Y": false,
+ "Z": true
+ "DatabaseTriggers": {
+ "Symbols": false,
+ "Numbers": false,
+ "A": false,
+ "B": false,
"C": false,
"D": false,
- "E": true,
+ "E": false,
"F": false,
"G": false,
"H": false,
"I": false,
"J": false,
"K": false,
- "L": true,
+ "L": false,
"M": true,
- "N": true,
+ "N": false,
"O": false,
- "P": true,
+ "P": false,
"Q": false,
- "R": true,
+ "R": false,
"S": false,
"T": false,
"U": false,
"V": false,
- "W": true,
+ "W": false,
"X": false,
"Y": false,
"Z": false
@@ -122,7 +272,7 @@
"Properties": {
"Symbols": false,
"Numbers": false,
- "A": false,
+ "A": true,
"B": false,
"C": false,
"D": false,
@@ -136,8 +286,8 @@
"L": false,
"M": false,
"N": false,
- "O": false,
- "P": false,
+ "O": true,
+ "P": true,
"Q": false,
"R": true,
"S": false,
Modified: trunk/mapbender/documents/api_js/search/ClassesA.html
--- trunk/mapbender/documents/api_js/search/ClassesA.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesA.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Ajax><div class=IEntry><a href="../files/ajax-js.html#Ajax" target=_parent class=ISymbol>Ajax</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_AddWmsFromTree><div class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" target=_parent class=ISymbol>AddWmsFromTree</a></div></div><div class=SRResult id=SR_Ajax><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax" target=_parent class=ISymbol>Ajax</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
document.getElementById("Loading").style.display="none";
document.getElementById("NoMatches").style.display="none";
var searchResults = new SearchResults("searchResults", "HTML");
Modified: trunk/mapbender/documents/api_js/search/ClassesB.html
--- trunk/mapbender/documents/api_js/search/ClassesB.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesB.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Button><div class=IEntry><a href="../files/button-js.html#Button" target=_parent class=ISymbol>Button</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Button><div class=IEntry><a href="../files/lib/button-js.html#Button" target=_parent class=ISymbol>Button</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesE.html
--- trunk/mapbender/documents/api_js/search/ClassesE.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesE.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/exception-js.html#Exception" target=_parent class=ISymbol>Exception</a></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/extent-js.html#Extent" target=_parent class=ISymbol>Extent</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/lib/exception-js.html#Exception" target=_parent class=ISymbol>Exception</a></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/lib/extent-js.html#Extent" target=_parent class=ISymbol>Extent</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesL.html
--- trunk/mapbender/documents/api_js/search/ClassesL.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesL.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_List><div class=IEntry><a href="../files/list-js.html#List" target=_parent class=ISymbol>List</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_List><div class=IEntry><a href="../files/lib/list-js.html#List" target=_parent class=ISymbol>List</a></div></div><div class=SRResult id=SR_Log><div class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" target=_parent class=ISymbol>Log</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesM.html
--- trunk/mapbender/documents/api_js/search/ClassesM.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesM.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mapbender><div class=IEntry><a href="../files/basic-js.html#mapbender" target=_parent class=ISymbol>mapbender</a></div></div><div class=SRResult id=SR_Mapbender_perMarker><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker" target=_parent class=ISymbol>Mapbender.<wbr>Marker</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=ISymbol>Map</a></div></div><div class=SRResult id=SR_mapbender><div class=IEntry><a href="../files/lib/basic-js.html#mapbender" target=_parent class=ISymbol>mapbender</a></div></div><div class=SRResult id=SR2_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div><div class=SRResult id=SR_Mapbender_perMarker><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker" target=_parent class=ISymbol>Mapbender.<wbr>Marker</a></div></div><div class=SRResult id=SR_mapframe1><div class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" target=_parent class=ISymbol>mapframe1</a></div></div><div class=SRResult id=SR_mb_undnavigation><div class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" target=_parent class=ISymbol>mb_navigation</a></div></div><div class=SRResult id=SR_mb_undresultList_undtransferToDigitize><div class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" target=_parent class=ISymbol>mb_resultList_transferToDigitize</a></div></div><div class=SRResult id=SR_mb_undzoomIn><div class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" target=_parent class=ISymbol>mb_zoomIn</a></div></div><div class=SRResult id=SR_mb_undzoomOut><div class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" target=_parent class=ISymbol>mb_zoomOut</a></div></div><div class=SRResult id=SR_mousewheelZoom><div class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" target=_parent class=ISymbol>mousewheelZoom</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesN.html
--- trunk/mapbender/documents/api_js/search/ClassesN.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesN.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="../files/exception-js.html#Notice" target=_parent class=ISymbol>Notice</a></div></div><div class=SRResult id=SR_Notification><div class=IEntry><a href="../files/ajax-js.html#Notification" target=_parent class=ISymbol>Notification</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="../files/lib/exception-js.html#Notice" target=_parent class=ISymbol>Notice</a></div></div><div class=SRResult id=SR_Notification><div class=IEntry><a href="../files/lib/ajax-js.html#Notification" target=_parent class=ISymbol>Notification</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesP.html
--- trunk/mapbender/documents/api_js/search/ClassesP.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesP.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="../files/point-js.html#Point" target=_parent class=ISymbol>Point</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="../files/lib/point-js.html#Point" target=_parent class=ISymbol>Point</a></div></div><div class=SRResult id=SR_printPDF><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF" target=_parent class=ISymbol>printPDF</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesR.html
--- trunk/mapbender/documents/api_js/search/ClassesR.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesR.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Request><div class=IEntry><a href="../files/ajax-js.html#Request" target=_parent class=ISymbol>Request</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_repaint><div class=IEntry><a href="javascript:searchResults.Toggle('SR_repaint')" class=ISymbol>repaint</a><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="../files/lib/ajax-js.html#Request" target=_parent class=ISymbol>Request</a></div></div><div class=SRResult id=SR_resize><div class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" target=_parent class=ISymbol>resize</a></div></div><div class=SRResult id=SR_ResizeMapsize><div class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" target=_parent class=ISymbol>ResizeMapsize</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a></div></div><div class=SRResult id=SR_resultList><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" target=_parent class=ISymbol>resultList</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/ClassesW.html
--- trunk/mapbender/documents/api_js/search/ClassesW.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/ClassesW.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="../files/exception-js.html#Warning" target=_parent class=ISymbol>Warning</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="../files/lib/exception-js.html#Warning" target=_parent class=ISymbol>Warning</a></div></div><div class=SRResult id=SR_wmsTimeInterval><div class=IEntry><a href="../files/http/plugins/mb_wmsTimeInterval-js.html#wmsTimeInterval" target=_parent class=ISymbol>wmsTimeInterval</a></div></div><div class=SRResult id=SR_wmsTimeSliderYear><div class=IEntry><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html#wmsTimeSliderYear" target=_parent class=ISymbol>wmsTimeSliderYear</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FilesR.html
--- trunk/mapbender/documents/api_js/search/FilesR.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FilesR.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsA.html
--- trunk/mapbender/documents/api_js/search/FunctionsA.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsA.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_addFeature><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeature')" class=ISymbol>addFeature</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeature" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeatureCollection')" class=ISymbol>addFeatureCollection</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeatureCollection" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection_undcallback><div class=IEntry><a href="../files/resultGeometryListController-js.html#addFeatureCollection_callback" target=_parent class=ISymbol>addFeatureCollection_callback</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_addFeature><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeature')" class=ISymbol>addFeature</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeatureCollection')" class=ISymbol>addFeatureCollection</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection_undcallback><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" target=_parent class=ISymbol>addFeatureCollection_callback</a></div></div><div class=SRResult id=SR_addGlobalButton><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" target=_parent class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></div></div><div class=SRResult id=SR_addPopupButton><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" target=_parent class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsC.html
--- trunk/mapbender/documents/api_js/search/FunctionsC.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsC.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_cloneObject><div class=IEntry><a href="../files/basic-js.html#mapbender.cloneObject" target=_parent class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_cookiesEnables><div class=IEntry><a href="../files/basic-js.html#mapbender.cookiesEnables" target=_parent class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_cloneObject><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" target=_parent class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_cookiesEnables><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" target=_parent class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_createPrintBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" target=_parent class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsD.html
--- trunk/mapbender/documents/api_js/search/FunctionsD.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsD.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deleteFeature><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" target=_parent class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_deleteFeatureCollection><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" target=_parent class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deleteFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" target=_parent class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_deleteFeatureCollection><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" target=_parent class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_destroyPrintBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" target=_parent class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsE.html
--- trunk/mapbender/documents/api_js/search/FunctionsE.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsE.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/exception-js.html#Exception.Exception" target=_parent class=ISymbol>Exception</a>, <span class=IParent>Exception</span></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/extent-js.html#Extent.Extent" target=_parent class=ISymbol>Extent</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/lib/exception-js.html#Exception.Exception" target=_parent class=ISymbol>Exception</a>, <span class=IParent>Exception</span></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/lib/extent-js.html#Extent.Extent" target=_parent class=ISymbol>Extent</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsG.html
--- trunk/mapbender/documents/api_js/search/FunctionsG.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsG.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_getConjunctionChar><div class=IEntry><a href="../files/basic-js.html#mapbender.getConjunctionChar" target=_parent class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_getFeature><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" target=_parent class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getFeatureProperty><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" target=_parent class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_getConjunctionChar><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" target=_parent class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_getFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" target=_parent class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getFeatureProperty><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" target=_parent class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getPDFMapSize><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" target=_parent class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_getSelected><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" target=_parent class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsM.html
--- trunk/mapbender/documents/api_js/search/FunctionsM.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsM.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Marker><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.Mapbender.Marker" target=_parent class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=ISymbol>Map</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_Marker><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.Mapbender.Marker" target=_parent class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></div></div><div class=SRResult id=SR_mb_undmonitor_undafter><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mb_undmonitor_undafter')" class=ISymbol>mb_monitor_after</a>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_mod_undprintPDF_undinit><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" target=_parent class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsN.html
--- trunk/mapbender/documents/api_js/search/FunctionsN.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsN.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="../files/exception-js.html#Notice.Notice" target=_parent class=ISymbol>Notice</a>, <span class=IParent>Notice</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="../files/lib/exception-js.html#Notice.Notice" target=_parent class=ISymbol>Notice</a>, <span class=IParent>Notice</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsP.html
--- trunk/mapbender/documents/api_js/search/FunctionsP.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsP.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="../files/point-js.html#Point.Point" target=_parent class=ISymbol>Point</a>, <span class=IParent>Point</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="../files/lib/point-js.html#Point.Point" target=_parent class=ISymbol>Point</a>, <span class=IParent>Point</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsR.html
--- trunk/mapbender/documents/api_js/search/FunctionsR.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsR.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsS.html
--- trunk/mapbender/documents/api_js/search/FunctionsS.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsS.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_send><div class=IEntry><a href="../files/ajax-js.html#Request.send" target=_parent class=ISymbol>send</a>, <span class=IParent>Request</span></div></div><div class=SRResult id=SR_set><div class=IEntry><a href="../files/extent-js.html#Extent.set" target=_parent class=ISymbol>set</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_setFeatureProperty><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" target=_parent class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_SAXDriver><div class=IEntry><a href="javascript:searchResults.Toggle('SR_SAXDriver')" class=ISymbol>SAXDriver</a><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#SAXDriver" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#SAXDriver" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div></div><div class=SRResult id=SR_send><div class=IEntry><a href="../files/lib/ajax-js.html#Request.send" target=_parent class=ISymbol>send</a>, <span class=IParent>Request</span></div></div><div class=SRResult id=SR_set><div class=IEntry><a href="../files/lib/extent-js.html#Extent.set" target=_parent class=ISymbol>set</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_setFeatureProperty><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" target=_parent class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div><div class=SRResult id=SR_showResult><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" target=_parent class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsT.html
--- trunk/mapbender/documents/api_js/search/FunctionsT.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsT.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_this_spcis_spcthe_spcconstructor_spcto_spcthe_spcXMLP_spcObject><div class=IEntry><a href="javascript:searchResults.Toggle('SR_this_spcis_spcthe_spcconstructor_spcto_spcthe_spcXMLP_spcObject')" class=ISymbol>this is the constructor to the XMLP Object</a><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div></div><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsU.html
--- trunk/mapbender/documents/api_js/search/FunctionsU.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsU.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_updateFeature><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" target=_parent class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_updateFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" target=_parent class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsW.html
--- trunk/mapbender/documents/api_js/search/FunctionsW.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/FunctionsW.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="../files/exception-js.html#Warning.Warning" target=_parent class=ISymbol>Warning</a>, <span class=IParent>Warning</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="../files/lib/exception-js.html#Warning.Warning" target=_parent class=ISymbol>Warning</a>, <span class=IParent>Warning</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralA.html
--- trunk/mapbender/documents/api_js/search/GeneralA.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralA.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_addFeature><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeature')" class=ISymbol>addFeature</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeature" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeatureCollection')" class=ISymbol>addFeatureCollection</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#addFeatureCollection" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection_undcallback><div class=IEntry><a href="../files/resultGeometryListController-js.html#addFeatureCollection_callback" target=_parent class=ISymbol>addFeatureCollection_callback</a></div></div><div class=SRResult id=SR_Ajax><div class=IEntry><a href="../files/ajax-js.html#Ajax" target=_parent class=ISymbol>Ajax</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_actualConfig><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.actualConfig" target=_parent class=ISymbol>actualConfig</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_addFeature><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeature')" class=ISymbol>addFeature</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection><div class=IEntry><a href="javascript:searchResults.Toggle('SR_addFeatureCollection')" class=ISymbol>addFeatureCollection</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_addFeatureCollection_undcallback><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" target=_parent class=ISymbol>addFeatureCollection_callback</a></div></div><div class=SRResult id=SR_addGlobalButton><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" target=_parent class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></div></div><div class=SRResult id=SR_addPopupButton><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" target=_parent class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></div></div><div class=SRResult id=SR_AddWmsFromTree><div class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" target=_parent class=ISymbol>AddWmsFromTree</a></div></div><div class=SRResult id=SR_Ajax><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax" target=_parent class=ISymbol>Ajax</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralB.html
--- trunk/mapbender/documents/api_js/search/GeneralB.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralB.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
Modified: trunk/mapbender/documents/api_js/search/GeneralC.html
--- trunk/mapbender/documents/api_js/search/GeneralC.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralC.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_changeEPSG><div class=IEntry><a href="../files/http/javascripts/mod_changeEPSG-js.html#changeEPSG" target=_parent class=ISymbol>changeEPSG</a></div></div><div class=SRResult id=SR_cloneObject><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" target=_parent class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_conformity><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#conformity" target=_parent class=ISymbol>conformity</a></div></div><div class=SRResult id=SR_conformity_undrelation><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#conformity_relation" target=_parent class=ISymbol>conformity_relation</a></div></div><div class=SRResult id=SR_cookie><div class=IEntry><a href="../files/http/plugins/mb_cookie-js.html#cookie" target=_parent class=ISymbol>cookie</a></div></div><div class=SRResult id=SR_cookiesEnables><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" target=_parent class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_coordsLookup><div class=IEntry><a href="../files/http/javascripts/mod_coordsLookup-js.html#coordsLookup" target=_parent class=ISymbol>coordsLookup</a></div></div><div class=SRResult id=SR_createPrintBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" target=_parent class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_custom_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#custom_category" target=_parent class=ISymbol>custom_category</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralD.html
--- trunk/mapbender/documents/api_js/search/GeneralD.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralD.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Database_spcIndexes><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Database_spcIndexes')" class=ISymbol>Database Indexes</a><div class=ISubIndex><span class=IParent>Global</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#Database_Indexes" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#Database_Indexes" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows.Database_Indexes" target=_parent class=IParent>mb_user_abo_ows</a></div></div></div><div class=SRResult id=SR_Database_spcTriggers><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Database_spcTriggers')" class=ISymbol>Database Triggers</a>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.Database_Triggers" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.Database_Triggers" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_deleteFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" target=_parent class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_deleteFeatureCollection><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" target=_parent class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_destroyPrintBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" target=_parent class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_doubleclickZoom><div class=IEntry><a href="../files/http/javascripts/mod_doubleclickZoom-js.html#doubleclickZoom" target=_parent class=ISymbol>doubleclickZoom</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralE.html
--- trunk/mapbender/documents/api_js/search/GeneralE.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralE.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_events><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Exception')" class=ISymbol>Exception</a><div class=ISubIndex><a href="../files/exception-js.html#Exception" target=_parent class=IParent>Global</a><a href="../files/exception-js.html#Exception.Exception" target=_parent class=IParent>Exception</a></div></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Extent')" class=ISymbol>Extent</a><div class=ISubIndex><a href="../files/extent-js.html#Extent" target=_parent class=IParent>Global</a><a href="../files/extent-js.html#Extent.Extent" target=_parent class=IParent>Extent</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_env_per1_per1_perrc2_perjs><div class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#env.1.1.rc2.js" target=_parent class=ISymbol>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=SRResult id=SR_env_perrhino_per1_per1_perrc2_perjs><div class=IEntry><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#env.rhino.1.1.rc2.js" target=_parent class=ISymbol>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_events><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Exception')" class=ISymbol>Exception</a><div class=ISubIndex><a href="../files/lib/exception-js.html#Exception" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Exception" target=_parent class=IParent>Exception</a></div></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Extent')" class=ISymbol>Extent</a><div class=ISubIndex><a href="../files/lib/extent-js.html#Extent" target=_parent class=IParent>Global</a><a href="../files/lib/extent-js.html#Extent.Extent" target=_parent class=IParent>Extent</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralF.html
--- trunk/mapbender/documents/api_js/search/GeneralF.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralF.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><a href="../files/resultGeometryListController-js.html#Functions" target=_parent class=IParent>Global</a><a href="../files/exception-js.html#Exception.Functions" target=_parent class=IParent>Exception</a><a href="../files/extent-js.html#Extent.Functions" target=_parent class=IParent>Extent</a><a href="../files/basic-js.html#mapbender.Functions" target=_parent class=IParent>mapbender</a><a href="../files/marker-js.html#Mapbender.Marker.Functions" target=_parent class=IParent>Mapbender.<wbr>Marker</a><a href="../files/exception-js.html#Notice.Functions" target=_parent class=IParent>Notice</a><a href="../files/ajax-js.html#Notification.Functions" target=_parent class=IParent>Notification</a><a href="../files/point-js.html#Point.Functions" target=_parent class=IParent>Point</a><a href="../files/ajax-js.html#Request.Functions" target=_parent class=IParent>Request</a><a href="../files/exception-js.html#Warning.Functions" target=_parent class=IParent>Warning</a></div></div></div><div class=SRResult id=SR_Functions_spcand_spcProperties><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties" target=_parent class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_f_undcollect_undepsg_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_epsg(integer)" target=_parent class=ISymbol>f_collect_epsg(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undcollect_undsearchtext_lpainteger_cominteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext(integer,integer)" target=_parent class=ISymbol>f_collect_searchtext(integer,integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undcollect_undsearchtext_undwfs_lpainteger_cominteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_collect_searchtext_wfs(integer,integer)" target=_parent class=ISymbol>f_collect_searchtext_wfs(integer,integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undgetwfs_undtou_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfs_tou(integer)" target=_parent class=ISymbol>f_getwfs_tou(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undgetwfsmodultype_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwfsmodultype(integer)" target=_parent class=ISymbol>f_getwfsmodultype(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undgetwms_undtou_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_getwms_tou(integer)" target=_parent class=ISymbol>f_getwms_tou(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_f_undlayer_undload_undcount_lpainteger_rpa><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.f_layer_load_count(integer)" target=_parent class=ISymbol>f_layer_load_count(integer)</a>, <span class=IParent>registrating_groups</span></div></div><div class=SRResult id=SR_firebug_undlite><div class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" target=_parent class=ISymbol>firebug_lite</a></div></div><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><span class=IParent>Global</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#Functions" target=_parent class=IFile>lib/<wbr>resultGeometryListController.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#Functions" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#Functions" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div><a href="../files/lib/exception-js.html#Exception.Functions" target=_parent class=IParent>Exception</a><a href="../files/lib/extent-js.html#Extent.Functions" target=_parent class=IParent>Extent</a><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" target=_parent class=IParent>Map</a><a href="../files/lib/basic-js.html#mapbender.Functions" target=_parent class=IParent>mapbender</a><a href="../files/lib/marker-js.html#Mapbender.Marker.Functions" target=_parent class=IParent>Mapbender.<wbr>Marker</a><span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.Functions" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.Functions" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div><a href="../files/lib/exception-js.html#Notice.Functions" target=_parent class=IParent>Notice</a><a href="../files/lib/ajax-js.html#Notification.Functions" target=_parent class=IParent>Notification</a><a href="../files/lib/point-js.html#Point.Functions" target=_parent class=IParent>Point</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Functions" target=_parent class=IParent>printPDF</a><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups.Functions" target=_parent class=IParent>registrating_groups</a><a href="../files/http/javascripts/mod_reload-js.html#Reload.Functions" target=_parent class=IParent>Reload</a><a href="../files/lib/ajax-js.html#Request.Functions" target=_parent class=IParent>Request</a><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.Functions" target=_parent class=IParent>resultList</a><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.Functions" target=_parent class=IParent>Sandclock</a><a href="../files/lib/exception-js.html#Warning.Functions" target=_parent class=IParent>Warning</a></div></div></div><div class=SRResult id=SR_Functions_spcand_spcProperties><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties" target=_parent class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
document.getElementById("Loading").style.display="none";
document.getElementById("NoMatches").style.display="none";
var searchResults = new SearchResults("searchResults", "HTML");
Modified: trunk/mapbender/documents/api_js/search/GeneralG.html
--- trunk/mapbender/documents/api_js/search/GeneralG.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralG.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_gazetteerWFS><div class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS" target=_parent class=ISymbol>gazetteerWFS</a></div></div><div class=SRResult id=SR_getConjunctionChar><div class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" target=_parent class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></div></div><div class=SRResult id=SR_getFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" target=_parent class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getFeatureProperty><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" target=_parent class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_getPDFMapSize><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" target=_parent class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_getSelected><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" target=_parent class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralL.html
--- trunk/mapbender/documents/api_js/search/GeneralL.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralL.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_List><div class=IEntry><a href="../files/list-js.html#List" target=_parent class=ISymbol>List</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_layer_undcustom_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#layer_custom_category" target=_parent class=ISymbol>layer_custom_category</a></div></div><div class=SRResult id=SR_layer_undinspire_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#layer_inspire_category" target=_parent class=ISymbol>layer_inspire_category</a></div></div><div class=SRResult id=SR_List><div class=IEntry><a href="../files/lib/list-js.html#List" target=_parent class=ISymbol>List</a></div></div><div class=SRResult id=SR_loadConfig><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" target=_parent class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_Log><div class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" target=_parent class=ISymbol>Log</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralM.html
--- trunk/mapbender/documents/api_js/search/GeneralM.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralM.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mapbender><div class=IEntry><a href="../files/basic-js.html#mapbender" target=_parent class=ISymbol>mapbender</a></div></div><div class=SRResult id=SR_Mapbender_perMarker><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker" target=_parent class=ISymbol>Mapbender.<wbr>Marker</a></div></div><div class=SRResult id=SR_Marker><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.Mapbender.Marker" target=_parent class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Map')" class=ISymbol>Map</a><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=IParent>Map</a></div></div></div><div class=SRResult id=SR_mapbender><div class=IEntry><a href="../files/lib/basic-js.html#mapbender" target=_parent class=ISymbol>mapbender</a></div></div><div class=SRResult id=SR2_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div><div class=SRResult id=SR_Mapbender_perMarker><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker" target=_parent class=ISymbol>Mapbender.<wbr>Marker</a></div></div><div class=SRResult id=SR_mapframe1><div class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" target=_parent class=ISymbol>mapframe1</a></div></div><div class=SRResult id=SR_Marker><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.Mapbender.Marker" target=_parent class=ISymbol>Marker</a>, <span class=IParent>Mapbender.<wbr>Marker.<wbr>Mapbender</span></div></div><div class=SRResult id=SR_mb_undmonitor_undafter><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mb_undmonitor_undafter')" class=ISymbol>mb_monitor_after</a>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_mb_undmonitor_undafter_spcon_spcmb_undmonitor><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mb_undmonitor_undafter_spcon_spcmb_undmonitor')" class=ISymbol>mb_monitor_after on mb_monitor</a>, <span class=IParent>mb_wms_availability</span><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability.mb_monitor_after_on_mb_monitor" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability.mb_monitor_after_on_mb_monitor" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_mb_undnavigation><div class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" target=_parent class=ISymbol>mb_navigation</a></div></div><div class=SRResult id=SR_mb_undresultList_undtransferToDigitize><div class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" target=_parent class=ISymbol>mb_resultList_transferToDigitize</a></div></div><div class=SRResult id=SR_mb_unduser_undabo_undows><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_user_abo_ows" target=_parent class=ISymbol>mb_user_abo_ows</a></div></div><div class=SRResult id=SR_mb_undwms_undavailability><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mb_undwms_undavailability')" class=ISymbol>mb_wms_availability</a><div class=ISubIndex><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#mb_wms_availability" target=_parent class=IFile>resources/<wbr>db/<wbr>pgsql/<wbr>UTF-8/<wbr>update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a><a href="../files/resources/db/sql_updates_monitoring-sql.html#mb_wms_availability" target=_parent class=IFile>resources/<wbr>db/<wbr>sql_updates_monitoring.sql</a></div></div></div><div class=SRResult id=SR_mb_undzoomIn><div class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" target=_parent class=ISymbol>mb_zoomIn</a></div></div><div class=SRResult id=SR_mb_undzoomOut><div class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" target=_parent class=ISymbol>mb_zoomOut</a></div></div><div class=SRResult id=SR_mod_undprintPDF_undinit><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" target=_parent class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_mousewheelZoom><div class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" target=_parent class=ISymbol>mousewheelZoom</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralN.html
--- trunk/mapbender/documents/api_js/search/GeneralN.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralN.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Notice')" class=ISymbol>Notice</a><div class=ISubIndex><a href="../files/exception-js.html#Notice" target=_parent class=IParent>Global</a><a href="../files/exception-js.html#Notice.Notice" target=_parent class=IParent>Notice</a></div></div></div><div class=SRResult id=SR_Notification><div class=IEntry><a href="../files/ajax-js.html#Notification" target=_parent class=ISymbol>Notification</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Notice><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Notice')" class=ISymbol>Notice</a><div class=ISubIndex><a href="../files/lib/exception-js.html#Notice" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Notice.Notice" target=_parent class=IParent>Notice</a></div></div></div><div class=SRResult id=SR_Notification><div class=IEntry><a href="../files/lib/ajax-js.html#Notification" target=_parent class=ISymbol>Notification</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralP.html
--- trunk/mapbender/documents/api_js/search/GeneralP.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralP.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Point')" class=ISymbol>Point</a><div class=ISubIndex><a href="../files/point-js.html#Point" target=_parent class=IParent>Global</a><a href="../files/point-js.html#Point.Point" target=_parent class=IParent>Point</a></div></div></div><div class=SRResult id=SR_Properties><div class=IEntry><a href="../files/ajax-js.html#Ajax.Properties" target=_parent class=ISymbol>Properties</a>, <span class=IParent>Ajax</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Point><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Point')" class=ISymbol>Point</a><div class=ISubIndex><a href="../files/lib/point-js.html#Point" target=_parent class=IParent>Global</a><a href="../files/lib/point-js.html#Point.Point" target=_parent class=IParent>Point</a></div></div></div><div class=SRResult id=SR_printBox><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.printBox" target=_parent class=ISymbol>printBox</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_printPDF><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF" target=_parent class=ISymbol>printPDF</a></div></div><div class=SRResult id=SR_Properties><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Properties')" class=ISymbol>Properties</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Ajax.Properties" target=_parent class=IParent>Ajax</a><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.Properties" target=_parent class=IParent>gazetteerWFS</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Properties" target=_parent class=IParent>printPDF</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralR.html
--- trunk/mapbender/documents/api_js/search/GeneralR.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralR.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/marker-js.html#Mapbender.Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/ajax-js.html#Request" target=_parent class=IParent>Global</a><a href="../files/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="javascript:searchResults.Toggle('SR_ResultGeometryListModel')" class=ISymbol>ResultGeometryListModel</a><div class=ISubIndex><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=IParent>Global</a><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_registrating_undgroups><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#registrating_groups" target=_parent class=ISymbol>registrating_groups</a></div></div><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR2_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/lib/marker-js.html#Mapbender.Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Mapbender.<wbr>Marker</span></div></div><div class=SRResult id=SR_repaint><div class=IEntry><a href="javascript:searchResults.Toggle('SR_repaint')" class=ISymbol>repaint</a><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Request" target=_parent class=IParent>Global</a><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div><div class=SRResult id=SR_resize><div class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" target=_parent class=ISymbol>resize</a></div></div><div class=SRResult id=SR_ResizeMapsize><div class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" target=_parent class=ISymbol>ResizeMapsize</a></div></div><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="javascript:searchResults.Toggle('SR_ResultGeometryListModel')" class=ISymbol>ResultGeometryListModel</a><div class=ISubIndex><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_resultList><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" target=_parent class=ISymbol>resultList</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralS.html
--- trunk/mapbender/documents/api_js/search/GeneralS.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralS.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Sandclock><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock" target=_parent class=ISymbol>Sandclock</a></div></div><div class=SRResult id=SR_savewmc><div class=IEntry><a href="../files/http/javascripts/mod_savewmc-js.html#savewmc" target=_parent class=ISymbol>savewmc</a></div></div><div class=SRResult id=SR_SAXDriver><div class=IEntry><a href="javascript:searchResults.Toggle('SR_SAXDriver')" class=ISymbol>SAXDriver</a><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#SAXDriver" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#SAXDriver" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div></div><div class=SRResult id=SR_scalebar><div class=IEntry><a href="../files/http/javascripts/mod_scalebar-js.html#scalebar" target=_parent class=ISymbol>scalebar</a></div></div><div class=SRResult id=SR_search_undwfs_undview><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#search_wfs_view" target=_parent class=ISymbol>search_wfs_view</a></div></div><div class=SRResult id=SR_search_undwms_undview><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#search_wms_view" target=_parent class=ISymbol>search_wms_view</a></div></div><div class=SRResult id=SR_selArea><div class=IEntry><a href="javascript:searchResults.Toggle('SR_selArea')" class=ISymbol>selArea</a><div class=ISubIndex><a href="../files/http/javascripts/mod_pan-js.html#selArea" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_pan.js</a><a href="../files/http/javascripts/mod_selArea-js.html#selArea" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_selArea.js</a></div></div></div><div class=SRResult id=SR_selectMapsize><div class=IEntry><a href="../files/http/plugins/mb_selectMapsize-js.html#selectMapsize" target=_parent class=ISymbol>selectMapsize</a></div></div><div class=SRResult id=SR_send><div class=IEntry><a href="../files/lib/ajax-js.html#Request.send" target=_parent class=ISymbol>send</a>, <span class=IParent>Request</span></div></div><div class=SRResult id=SR_set><div class=IEntry><a href="../files/lib/extent-js.html#Extent.set" target=_parent class=ISymbol>set</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_setFeatureProperty><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" target=_parent class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div><div class=SRResult id=SR_showResult><div class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" target=_parent class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></div></div><div class=SRResult id=SR_sql_undupdates_undmonitoring_persql><div class=IEntry><a href="../files/resources/db/sql_updates_monitoring-sql.html#sql_updates_monitoring.sql" target=_parent class=ISymbol>sql_updates_monitoring.sql</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralT.html
--- trunk/mapbender/documents/api_js/search/GeneralT.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralT.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_tabs_undvertical><div class=IEntry><a href="../files/http/plugins/mb_tabs_vertical-js.html#tabs_vertical" target=_parent class=ISymbol>tabs_vertical</a></div></div><div class=SRResult id=SR_this_spcis_spcthe_spcconstructor_spcto_spcthe_spcXMLP_spcObject><div class=IEntry><a href="javascript:searchResults.Toggle('SR_this_spcis_spcthe_spcconstructor_spcto_spcthe_spcXMLP_spcObject')" class=ISymbol>this is the constructor to the XMLP Object</a><div class=ISubIndex><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a><a href="../files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html#this_is_the_constructor_to_the_XMLP_Object" target=_parent class=IFile>test/<wbr>tools/<wbr>env-js/<wbr>dist/<wbr>releases/<wbr>1.1.<wbr>rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div></div><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_twitter_undsignin><div class=IEntry><a href="../files/http/plugins/mb_twitter_signin-js.html#twitter_signin" target=_parent class=ISymbol>twitter_signin</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralU.html
--- trunk/mapbender/documents/api_js/search/GeneralU.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralU.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_update_und2_per6_per1_undto_und2_per7rc1_undpgsql_undUTF_min8_persql><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html#update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql" target=_parent class=ISymbol>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=SRResult id=SR_updateFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" target=_parent class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralW.html
--- trunk/mapbender/documents/api_js/search/GeneralW.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/GeneralW.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Warning')" class=ISymbol>Warning</a><div class=ISubIndex><a href="../files/exception-js.html#Warning" target=_parent class=IParent>Global</a><a href="../files/exception-js.html#Warning.Warning" target=_parent class=IParent>Warning</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Warning><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Warning')" class=ISymbol>Warning</a><div class=ISubIndex><a href="../files/lib/exception-js.html#Warning" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Warning.Warning" target=_parent class=IParent>Warning</a></div></div></div><div class=SRResult id=SR_wfs_undfeaturetype_undcustom_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#wfs_featuretype_custom_category" target=_parent class=ISymbol>wfs_featuretype_custom_category</a></div></div><div class=SRResult id=SR_wfs_undfeaturetype_undinspire_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#wfs_featuretype_inspire_category" target=_parent class=ISymbol>wfs_featuretype_inspire_category</a></div></div><div class=SRResult id=SR_wfs_undfeaturetype_undmd_undtopic_undcategory><div class=IEntry><a href="../files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html#wfs_featuretype_md_topic_category" target=_parent class=ISymbol>wfs_featuretype_md_topic_category</a></div></div><div class=SRResult id=SR_wmsTimeInterval><div class=IEntry><a href="../files/http/plugins/mb_wmsTimeInterval-js.html#wmsTimeInterval" target=_parent class=ISymbol>wmsTimeInterval</a></div></div><div class=SRResult id=SR_wmsTimeSliderYear><div class=IEntry><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html#wmsTimeSliderYear" target=_parent class=ISymbol>wmsTimeSliderYear</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/PropertiesE.html
--- trunk/mapbender/documents/api_js/search/PropertiesE.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/PropertiesE.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_events><div class=IEntry><a href="../files/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_events><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/PropertiesR.html
--- trunk/mapbender/documents/api_js/search/PropertiesR.html 2010-02-24 16:13:30 UTC (rev 5639)
+++ trunk/mapbender/documents/api_js/search/PropertiesR.html 2010-02-24 16:16:02 UTC (rev 5640)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
More information about the Mapbender_commits
