[Mapbender-commits] r5641 - in trunk/mapbender/documents/api_js:
Data files files/http files/http/javascripts
files/http/plugins files/lib files/resources
files/resources/db files/resources/db/pgsql
files/resources/db/pgsql/UTF-8
files/resources/db/pgsql/UTF-8/update files/test
files/test/tools files/test/tools/env-js
files/test/tools/env-js/dist files/test/tools/env-js/dist/releases
files/test/tools/env-js/dist/releases/1-1-rc2
files/test/tools/env-js/src files/test/tools/env-js/src/css
files/test/tools/env-js/src/css/jss-0-4
files/test/tools/env-js/src/css/jss-0-4/js
svn_mapbender at osgeo.org
Wed Feb 24 11:19:38 EST 2010
Author: christoph
Date: 2010-02-24 11:19:38 -0500 (Wed, 24 Feb 2010)
New Revision: 5641
Added:
trunk/mapbender/documents/api_js/files/http/
trunk/mapbender/documents/api_js/files/http/javascripts/
trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html
trunk/mapbender/documents/api_js/files/http/javascripts/jq_jgrowl-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/jq_ui_effects-php.html
trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_ResultList-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_changeEPSG-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_coordsLookup-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_doubleclickZoom-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_firebug_lite-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_log-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_mousewheelZoom-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_pan-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-php.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_resize_mapsize-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_savewmc-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_scalebar-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_selArea-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_wfs_gazetteer_client-php.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomFull-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-js.html
trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomOut1-js.html
trunk/mapbender/documents/api_js/files/http/plugins/
trunk/mapbender/documents/api_js/files/http/plugins/jq_datatables-js.html
trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_accordion-js.html
trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_effects-js.html
trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_resizable-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_cookie-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_i18n-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_map-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_navigation-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_overview-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_print-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_resize-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_resultList_transferToDigitize-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_selectMapsize-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_tabs_vertical-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_twitter_signin-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeInterval-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeSliderYear-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomIn-js.html
trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomOut-js.html
trunk/mapbender/documents/api_js/files/http/plugins/ol-js.html
trunk/mapbender/documents/api_js/files/http/plugins/ol_keyboardDefaults-js.html
trunk/mapbender/documents/api_js/files/http/plugins/ol_layerSwitch-js.html
trunk/mapbender/documents/api_js/files/http/plugins/ol_mousePosition-js.html
trunk/mapbender/documents/api_js/files/http/plugins/ol_overview-js.html
trunk/mapbender/documents/api_js/files/http/plugins/ol_panZoomBar-js.html
trunk/mapbender/documents/api_js/files/http/plugins/ol_wms-php.html
trunk/mapbender/documents/api_js/files/lib/
trunk/mapbender/documents/api_js/files/lib/ajax-js.html
trunk/mapbender/documents/api_js/files/lib/basic-js.html
trunk/mapbender/documents/api_js/files/lib/button-js.html
trunk/mapbender/documents/api_js/files/lib/event-js.html
trunk/mapbender/documents/api_js/files/lib/exception-js.html
trunk/mapbender/documents/api_js/files/lib/extent-js.html
trunk/mapbender/documents/api_js/files/lib/list-js.html
trunk/mapbender/documents/api_js/files/lib/marker-js.html
trunk/mapbender/documents/api_js/files/lib/point-js.html
trunk/mapbender/documents/api_js/files/lib/resultGeometryListController-js.html
trunk/mapbender/documents/api_js/files/lib/resultGeometryListModel-js.html
trunk/mapbender/documents/api_js/files/resources/
trunk/mapbender/documents/api_js/files/resources/db/
trunk/mapbender/documents/api_js/files/resources/db/pgsql/
trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/
trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/
trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html
trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html
trunk/mapbender/documents/api_js/files/resources/db/sql_updates_monitoring-sql.html
trunk/mapbender/documents/api_js/files/test/
trunk/mapbender/documents/api_js/files/test/tools/
trunk/mapbender/documents/api_js/files/test/tools/env-js/
trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/
trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/
trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/
trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html
trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html
trunk/mapbender/documents/api_js/files/test/tools/env-js/src/
trunk/mapbender/documents/api_js/files/test/tools/env-js/src/css/
trunk/mapbender/documents/api_js/files/test/tools/env-js/src/css/jss-0-4/
trunk/mapbender/documents/api_js/files/test/tools/env-js/src/css/jss-0-4/js/
trunk/mapbender/documents/api_js/files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html
trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
trunk/mapbender/documents/api_js/Data/IndexInfo.nd
trunk/mapbender/documents/api_js/Data/SymbolTable.nd
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
(Binary files differ)
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
Modified: trunk/mapbender/documents/api_js/Data/SymbolTable.nd
Added: trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,39 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Mapbender</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Mapbender"></a>Mapbender</h1><div class=CBody><p>All Mapbender functionality is within this namespace</p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile id=MSelected>Mapbender</div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([1, 3], 8);// --></script></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/jq_jgrowl-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/jq_jgrowl-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/jq_jgrowl-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,49 @@
+<html><head><title>jq_jgrowl</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="jq_jgrowl"></a>jq_jgrowl</h1><div class=CBody><h4 class=CHeading>Description</h4><p>The container for the jQuery plugin jGrowl</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/jq_ui_effects.js</li><li>http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.*</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','jq_jgrowl',1,1,'',
+'','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_jgrowl.js',
+'../extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js','','',
+'http://stanlemon.net/projects/jgrowl.html');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+context, var_type) VALUES('<appId>', 'body', 'jq_jgrowl',
+'../extensions/jGrowl-1.2.4/jquery.jgrowl.css', '' ,'file/css');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/jq_jgrowl" class=LURL target=_top>http://www.mapbender.org/jq_jgrowl</a> <a href="http://stanlemon.net/projects/jgrowl.html" class=LURL target=_top>http://stanlemon.net/projects/jgrowl.html</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile id=MSelected>jq_jgrowl</div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/jq_jgrowl-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/jq_ui_effects-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/jq_ui_effects-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/jq_ui_effects-php.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,99 @@
+<html><head><title>jq_ui_effects</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="jq_ui_effects"></a>jq_ui_effects</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A collection of jQuery UI effects</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/jq_ui_effects.js</li><li>http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.*</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','jq_ui_effects',
+1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','',
+'jq_ui_effects.php',
+'../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js',
+context, var_type) VALUES('<appId>', 'body', 'jq_ui_effect_transfer',
+'.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ',
+'' ,'text/css');
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'blind', '0',
+'1 = effect active' ,'php_var');
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'bounce', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'clip', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'drop', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'explode', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'fold', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'highlight', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'pulsate', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'scale', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'shake', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'slide', '0',
+context, var_type) VALUES('<appId>', 'jq_ui_effects', 'transfer', '1',
+'1 = effect active' ,'php_var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/jq_ui_effects" class=LURL target=_top>http://www.mapbender.org/jq_ui_effects</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters (PHP)</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>blind</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>bounce</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>clip</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>drop</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>explode</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>fold</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>highlight</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>pulsate</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>scale</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>shake</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>slide</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr><tr><td class=CDLEntry>transfer</td><td class=CDLDescription>set to 1 to activate this effect, 0 to disable</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile id=MSelected>jq_ui_effects</div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/jq_ui_effects-php.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,45 @@
+<html><head><title>Map</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Map"></a>Map</h1><div class=CBody><h4 class=CHeading>Description</h4><p>This is the central module for displaying the composite map overlay.</p><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Mapframe" class=LURL target=_top>http://www.mapbender.org/Mapframe</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Map" >Map</a></td><td class=SDescription>This is the central module for displaying the composite map overlay.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Map.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Map.Map" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Map</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Map.setExtent" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">setExtent</a></td><td class=SDescription>set the extent of the wms</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Map.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Map.Map"></a>Map</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>frameName</td><td class=CDLDescription><b>[deprecated]</b> the name of the iframe, for backwards compatibility only, use “” for maps in DIVs</td></tr><tr><td class=CDLEntry>elementName</td><td class=CDLDescription>the ID of the DOM node</td></tr><tr><td class=CDLEntry>width</td><td class=CDLDescription>width of the map in pixel</td></tr><tr><td class=CDLEntry>height</td><td class=CDLDescription>height of the map in pixel</td></tr><tr><td class=CDLEntry>wms_index</td><td class=CDLDescription>restrict the WMS in the map to the WMS with this ID (useful for overview maps)</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Map.setExtent"></a>setExtent</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>set the extent of the wms</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>minx</td><td class=CDLDescription>x of south west</td></tr><tr><td class=CDLEntry>miny</td><td class=CDLDescription>y of south west</td></tr><tr><td class=CDLEntry>maxx</td><td class=CDLDescription>x of north east</td></tr><tr><td class=CDLEntry>maxy</td><td class=CDLDescription>y of north east</td></tr></table></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile id=MSelected>Map</div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_ResultList-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_ResultList-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_ResultList-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,54 @@
+<html><head><title>resultList</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="resultList"></a>resultList</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A result list for featureCollections</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_ResultList.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+VALUES('<gui_id>','resultList',2,1,'','Result List','div','','',NULL ,NULL
+,NULL ,NULL ,NULL
+,'','','div','mod_ResultList.js','../../lib/resultGeometryListController.js,
+../../lib/resultGeometryListModel.js','','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ResultList" class=LURL target=_top>http://www.mapbender.org/ResultList</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Karim" class=LURL target=_top>http://www.mapbender.org/User:Karim</a> Malhas</p><h4 class=CHeading>Parameters</h4><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#resultList" >resultList</a></td><td class=SDescription>A result list for featureCollections</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#resultList.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#resultList.addGlobalButton" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">addGlobalButton</a></td><td class=SDescription>Descriptions: adds a Button to the bottom of the resultList Parameters: buttondef: {Object} an object with five properties, “title”, “type” (either button or select) “classes” (the classes the button should have), “selectoptions” (an array in case the type is select), “callback”</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#resultList.addPopupButton" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">addPopupButton</a></td><td class=SDescription>Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list Parameters: buttondef: {Object} an object with two properties: “title” and “callback”, a function that gets the feature that corresponds to the popup as it’s argument</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#resultList.getSelected" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">getSelected</a></td><td class=SDescription>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="resultList.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="resultList.addGlobalButton"></a>addGlobalButton</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addGlobalButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Descriptions: adds a Button to the bottom of the resultList Parameters: buttondef: {Object} an object with five properties, “title”, “type” (either button or select) “classes” (the classes the button should have), “selectoptions” (an array in case the type is select), “callback”</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="resultList.addPopupButton"></a>addPopupButton</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addPopupButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list Parameters: buttondef: {Object} an object with two properties: “title” and “callback”, a function that gets the feature that corresponds to the popup as it’s argument</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="resultList.getSelected"></a>getSelected</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote><p>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile id=MSelected>resultList</div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addGlobalButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Descriptions: adds a Button to the bottom of the resultList Parameters: buttondef: {Object} an object with five properties, “title”, “type” (either button or select) “classes” (the classes the button should have), “selectoptions” (an array in case the type is select), “callback”</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addPopupButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list Parameters: buttondef: {Object} an object with two properties: “title” and “callback”, a function that gets the feature that corresponds to the popup as it’s argument</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_ResultList-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,59 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>AddWmsFromTree</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="AddWmsFromTree"></a>AddWmsFromTree</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Add a WMS from a container. The WMS are displayed in a customized tree (if one exists)</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_addWMSfromTree.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>',
+'addWMSfromTree',2,1,'Add a WMS from a container. The WMS are displayed in a customized tree (if one exists)',
+'Add WMS from tree','div','','',1,1,1,1,5,'overflow:scroll','','div',
+'../javascripts/mod_addWMSfromTree.js',
+'../extensions/jquery-ui-1.7.2.custom.min.js,../../lib/customTreeModel.js,../../lib/customTreeController.js',
+'mapframe1','mapframe1','');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('<app_id>', 'addWMSfromTree',
+'addwms_showWMS', '<max_number_of_layers>', '0 : do not make layer visible; n > 0 : make visible if #layers < n' ,'var');
+'applicationName', '<container_name>', 'Use the custom tree of this container' ,'var');
+var_value, context, var_type) VALUES ('<app_id>', 'body',
+'custom_tree_css', '../css/customTree.css', '' ,'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/AddWmsFromTree" class=LURL target=_top>http://www.mapbender.org/AddWmsFromTree</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>addwms_showWMS</td><td class=CDLDescription>Integer. 0 : do not make layer visible;</td></tr></table><ul><li>n > 0 : make visible if #layers < n</li></ul><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>applicationName</td><td class=CDLDescription>String. Use the custom tree of this container</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile id=MSelected>AddWmsFromTree</div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([1, 3], 8);// --></script></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_changeEPSG-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_changeEPSG-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_changeEPSG-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,51 @@
+<html><head><title>changeEPSG</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="changeEPSG"></a>changeEPSG</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Select a spatial reference system EPSG code. All maps are transformed to that system.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_changeEPSG.js</li><li>http/php/mod_changeEPSG_server.php</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>','changeEPSG',
+2,1,'change EPSG, Postgres required, overview is targed for full extent',
+'Change Projection','select','','',432,25,107,24,1,'',
+'<option value="">...</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>','select',
+'mod_changeEPSG.js','','overview','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ChangeEpsg" class=LURL target=_top>http://www.mapbender.org/ChangeEpsg</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile id=MSelected>changeEPSG</div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_changeEPSG-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_coordsLookup-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_coordsLookup-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_coordsLookup-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,54 @@
+<html><head><title>coordsLookup</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="coordsLookup"></a>coordsLookup</h1><div class=CBody><h4 class=CHeading>Description</h4><p>The user enters a coordinate tuple and selects the corresponding SRS from a select box. After submitting this form, Mapbender transforms the coordinate tuple to the current SRS and zooms to the location.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_coordsLookup.js</li><li>http/php/mod_coordsLookup_server.php</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','coordsLookup',
+10,1,'','Coordinate lookup','div','','',1000,0,NULL ,NULL ,NULL ,
+'z-index:9999;','','div','mod_coordsLookup.js','',
+'mapframe1','','');
+var_value, context, var_type) VALUES ('<app_id>', 'coordsLookup',
+'perimeters', '[50,200,1000,10000]', '' ,'var');
+var_value, context, var_type) VALUES('<app_id>', 'coordsLookup',
+'projections', '[''EPSG:31467'',''EPSG:31468'',''EPSG:31469'']', '' ,
+'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/coordsLookup" class=LURL target=_top>http://www.mapbender.org/coordsLookup</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>perimeters</td><td class=CDLDescription>Array of perimeters in m, like [50,200,1000,10000]</td></tr><tr><td class=CDLEntry>projections</td><td class=CDLDescription>Array of EPSG names, like [‘EPSG:31467’,’EPSG:31468’]</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile id=MSelected>coordsLookup</div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_coordsLookup-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_doubleclickZoom-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_doubleclickZoom-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_doubleclickZoom-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<html><head><title>doubleclickZoom</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="doubleclickZoom"></a>doubleclickZoom</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Adds behaviour to maps specified in the target field. Zoom in on left double click, zoom out on right double click. Deactivates the browser contextmenu!</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_doubleclickZoom.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+'doubleclickZoom',2,1,'adds doubleclick zoom to map module (target).
+Deactivates the browser contextmenu!!!','Doubleclick zoom','div',
+'','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div',
+'mod_doubleclickZoom.js','','mapframe1','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/DoubleclickZoom" class=LURL target=_top>http://www.mapbender.org/DoubleclickZoom</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile id=MSelected>doubleclickZoom</div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_doubleclickZoom-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_firebug_lite-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_firebug_lite-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_firebug_lite-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<html><head><title>firebug_lite</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="firebug_lite"></a>firebug_lite</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Simply includes the Firebug lite JavaScript and CSS</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_firebug_lite.js</li><li>http/extensions/firebug-lite/</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','firebug_lite',
+1,1,'Firebug Lite','Firebug Lite','','','',NULL ,NULL ,NULL ,NULL ,NULL ,
+'','','','mod_firebug_lite.js',
+'../extensions/firebug-lite/firebug-lite-compressed.js','','',
+'http://getfirebug.com/lite.html');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Firebug_Lite" class=LURL target=_top>http://www.mapbender.org/Firebug_Lite</a></p><h4 class=CHeading>Help</h4><p><a href="http://getfirebug.com/lite.html" class=LURL target=_top>http://getfirebug.com/lite.html</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>firebug_lite</div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_firebug_lite-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_log-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_log-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_log-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,48 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Log</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Log"></a>Log</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Logs the accesses to the guis in the database or a logfile The accesses will be written in the mapbender database on table mb_log or into mapbender/log/mb_access_$DATE.log. The log mode can be set via the element_var logtype (file or db).</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_log.js</li><li>http/php/mod_log.php</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
+e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
+e_target, e_requires, e_url) VALUES ('<gui_id>', 'log', 2, 1,
+'log requests', 'div', '', '', 0, 0, NULL, NULL, NULL, '', '', 'div',
+'mod_log.php', '', 'mapframe1', '', '');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+context, var_type) VALUES('<gui_id>', 'log', 'logtype', 'file',
+'http://www.mapbender.org/Log' ,'php_var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Log" class=LURL target=_top>http://www.mapbender.org/Log</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Melchior_Moos" class=LURL target=_top>http://www.mapbender.org/User:Melchior_Moos</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>logtype</td><td class=CDLDescription>{String} log mode, file | db</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile id=MSelected>Log</div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([1, 3], 8);// --></script></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_log-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_mousewheelZoom-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_mousewheelZoom-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_mousewheelZoom-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,50 @@
+<html><head><title>mousewheelZoom</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mousewheelZoom"></a>mousewheelZoom</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Zoom in/out with the mousewheel. Specify maps in target field.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_mousewheelZoom.js</li><li>http/extensions/jquery.mousewheel.min.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<gui_id>','mousewheelZoom',
+2,1,'adds mousewheel zoom to map module (target)','Mousewheel zoom',
+'div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div',
+'mod_mousewheelZoom.js','../extensions/jquery.mousewheel.min.js',
+context, var_type) VALUES('<gui_id>', 'mousewheelZoom', 'factor', '2',
+'The factor by which the map is zoomed on each mousewheel unit' ,'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/MousewheelZoom" class=LURL target=_top>http://www.mapbender.org/MousewheelZoom</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>factor</td><td class=CDLDescription><b>[optional]</b> {Float} The factor by which the map is zoomed on each mousewheel unit. Default is 2.</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile id=MSelected>mousewheelZoom</div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_mousewheelZoom-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,52 @@
+<html><head><title>overviewToggle</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="overviewToggle"></a>overviewToggle</h1><div class=CBody><h4 class=CHeading>Description</h4><p>shows and hides the overview module with a jQuery animation</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_overviewToggle.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>',
+'overviewToggle',5,1,'','','div','','class="ui-widget-header ui-corner-all"',
+-1,-1,NULL ,NULL ,NULL ,
+'display:none;height:24px;width:35px;vertical-align: middle;text-align:right',
+'<img style='position:absolute;top:0px;left:0px' src='../img/ovtoggle.png' /><span style='margin-left: auto; margin-right: 0;' class='ui-icon ui-icon-triangle-1-e'></span>',
+'div','../javascripts/mod_overviewToggle.js','','overview','','');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('<app_id>', 'body',
+'overviewToggle_css', '../css/dialog/jquery-ui-1.7.2.custom.css',
+'' ,'file/css');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/OverviewToggle" class=LURL target=_top>http://www.mapbender.org/OverviewToggle</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>overviewToggle</div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_pan-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_pan-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_pan-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title>selArea</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="selArea"></a>selArea</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Zoom by rectangle</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_selArea.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/SelArea1" class=LURL target=_top>http://www.mapbender.org/SelArea1</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_pan-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,49 @@
+<html><head><title>Reload</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Reload"></a>Reload</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A button that reloads the whole window.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_reload.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
+e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>', 'reload',
+2,1,'reload','img','../img/button_blink_red/reload_off.png', '',335,
+60,24,24,1,'','','','mod_reload.js','','mapframe1','',
+'http://www.mapbender.org/index.php/Reload');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/index.php/Reload" class=LURL target=_top>http://www.mapbender.org/index.php/Reload</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Vera_Schulze" class=LURL target=_top>http://www.mapbender.org/User:Vera_Schulze</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Reload" >Reload</a></td><td class=SDescription>A button that reloads the whole window.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Reload.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Reload.reload" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">reload</a></td><td class=SDescription>Reloads the window.</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Reload.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Reload.reload"></a>reload</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote><p>Reloads the window.</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile id=MSelected>Reload</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,45 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>repaint</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="repaint"></a>repaint</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Repaints a map. The maps must be specified comma-seperated under target.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_repaint.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<gui_id>','repaint',2,1,
+'refresh a map object','Repaint',
+'img','../img/button_blink_red/repaint_off.png','',360,60,24,24,1,'','',
+'','mod_repaint.js','','mapframe1','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Repaint" class=LURL target=_top>http://www.mapbender.org/Repaint</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([1, 3], 8);// --></script></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-php.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,45 @@
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_repaint-php.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_resize_mapsize-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_resize_mapsize-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_resize_mapsize-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,60 @@
+<html><head><title>ResizeMapsize</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ResizeMapsize"></a>ResizeMapsize</h1><div class=CBody><h4 class=CHeading>Description</h4><p>This modul dynamically resizes the mapframe in relation to the browsersize. Thanks to Antje Jacobs and Marko Samson.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_resizeMapsize.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
+e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
+e_target, e_requires, e_url) VALUES('<gui_id>','resizeMapsize',2,1,
+'resize_mapsize','img','../img/button_blink_red/resizemapsize_off.png',
+'onclick = "adjustDimension()" onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Kartenfenstergröße optimieren"',
+838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','',
+'mod_resize_mapsize.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+context, var_type) VALUES('<gui_id>', 'resizeMapsize', 'adjust_height',
+'-35', 'to adjust the height of the mapframe on the bottom of the window',
+'var');
+context, var_type) VALUES('gui1', 'resizeMapsize', 'adjust_width', '-45',
+'to adjust the width of the mapframe on the right side of the window',
+'var');
+context, var_type) VALUES('gui1', 'resizeMapsize', 'resize_option',
+'button', 'auto (autoresize on load), button (resize by button)' ,'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ResizeMapsize" class=LURL target=_top>http://www.mapbender.org/ResizeMapsize</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>adjust_height</td><td class=CDLDescription><b>[optional]</b> {Integer} adjust the maximum size of the mapframe. A positive number will enlarge the maximum mapframe size, an negative number will reduce the maximum mapframe size. Default: -90</td></tr><tr><td class=CDLEntry>adjust_width</td><td class=CDLDescription><b>[optional]</b> {Integer} adjust the maximum size of the mapframe. A positive number will enlarge the maximum mapframe size, an negative number will reduce the maximum mapframe size. Default: -45</td></tr><tr><td class=CDLEntry>resize_option</td><td class=CDLDescription><b>[optional]</b> {String} choose between automatic resizing on startup and resizing by clicking the button. The element var value ‘auto’ means automatic resizing, the value ‘button’ means resizing clicking the button. If element var resize_option doesn’t exist, automatic resizing will be set as standard configuration.</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>ResizeMapsize</div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_resize_mapsize-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,60 @@
+<html><head><title>Sandclock</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Sandclock"></a>Sandclock</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Displays an arbitrary sandclock image on a map</p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
+e_height, e_z_index, e_more_styles, e_content, e_closeTag, e_js_file,
+e_mb_mod, e_target, e_requires) VALUES ('<gui_id>', 'sandclock', '0002',
+'1', 'displays a sand clock while waiting for requests', 'div', '',
+'', '', '', '', '', '', '', '', 'div', 'mod_sandclock.php', '',
+'mapframe1', '');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('<gui_id>', 'sandclock',
+'mod_sandclock_image', '../img/sandclock.gif',
+'define a sandclock-image', 'var');
+var_value, context, var_type) VALUES('<gui_id>', 'sandclock',
+'blockElement', '0', '' ,'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Sandclock" class=LURL target=_top>http://www.mapbender.org/Sandclock</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>mod_sandclock_img</td><td class=CDLDescription><b>[optional]</b> the filename and path to the sandclock image</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Sandclock" >Sandclock</a></td><td class=SDescription>Displays an arbitrary sandclock image on a map</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Sandclock.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Sandclock.show" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">show</a></td><td class=SDescription>Displays the sandclock</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Sandclock.hide" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">hide</a></td><td class=SDescription>Hides the sandclock</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Sandclock.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Sandclock.show"></a>show</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>nodeId,</td></tr><tr><td></td><td class=PParameter nowrap>arg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Displays the sandclock</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Sandclock.hide"></a>hide</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Hides the sandclock</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile id=MSelected>Sandclock</div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>nodeId,</td></tr><tr><td></td><td class=PParameter nowrap>arg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_savewmc-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_savewmc-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_savewmc-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,54 @@
+<html><head><title>savewmc</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="savewmc"></a>savewmc</h1><div class=CBody><h4 class=CHeading>Description</h4><p>save workspace as WMC</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_savewmc.php</li><li>http/javascripts/mod_savewmc.js</li><li>http/php/mod_savewmc_server.php</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<gui_id>','savewmc',2,1,
+'save workspace as WMC','Save workspace as web map context document',
+'img','../img/button_blink_red/wmc_save_off.png','',870,60,24,24,1,'',
+'','','mod_savewmc.php','','mapframe1','mapframe1',
+'http://www.mapbender.org/index.php/SaveWMC');
+context, var_type) VALUES('<gui_id>', 'savewmc', 'overwrite', '1', '',
+'var');
+context, var_type) VALUES('<gui_id>', 'savewmc', 'saveInSession', '1',
+'' ,'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/index.php/SaveWMC" class=LURL target=_top>http://www.mapbender.org/index.php/SaveWMC</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>overwrite</td><td class=CDLDescription><b>[optional]</b> if set to 1, a WMC document is overwritten if a WMC with the given name already exists</td></tr><tr><td class=CDLEntry>saveInSession</td><td class=CDLDescription><b>[optional]</b> if set to 1, the state of the client is stored in the session after each map request in the target map</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile id=MSelected>savewmc</div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_savewmc-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_scalebar-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_scalebar-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_scalebar-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,44 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>scalebar</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="scalebar"></a>scalebar</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Displays scalebar in the map. The position currently is hard coded to the lower left corner of the map frame.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_scalebar.php</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>','scalebar',
+2,1,'scalebar','Scalebar','div','','',0,0,0,0,0,'','','div',
+'mod_scalebar.php','','mapframe1','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Scalebar" class=LURL target=_top>http://www.mapbender.org/Scalebar</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile id=MSelected>scalebar</div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([1, 3], 8);// --></script></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_scalebar-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_selArea-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_selArea-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_selArea-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title>selArea</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="selArea"></a>selArea</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Zoom by rectangle</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_selArea.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/SelArea1" class=LURL target=_top>http://www.mapbender.org/SelArea1</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_selArea-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_wfs_gazetteer_client-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_wfs_gazetteer_client-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_wfs_gazetteer_client-php.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,80 @@
+<html><head><title>gazetteerWFS</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="gazetteerWFS"></a>gazetteerWFS</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A WFS gazetteer for pre configured WFS configurations.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_wfs_gazetteer_client.php</li><li>http/php/mod_wfs_gazetteer_server.php</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','gazetteerWFS',
+2,1,'a gazetteer for user in the mapbender user map','Search','iframe',
+'../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview',
+'frameborder = "0"',10,600,300,150,4,
+'visibility:hidden; border: 1px solid #a19c8f;','','iframe','',
+'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/wz_jsgraphics.js',
+'mapframe1,overview','','http://www.mapbender.org/GazetteerWFS');
+var_value, context, var_type) VALUES('<appId>', 'gazetteerWFS',
+'maxHighlightedPoints', '500', 'max number of points to highlight',
+'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('<appId>', 'gazetteerWFS',
+'wfsConfIdString', '<value>', 'comma seperated list of WFS conf ids' ,
+'php_var');
+'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf',
+'location and name of the WFS configuration file for spatialRequest' ,
+'php_var');
+'initializeOnLoad', '0', 'start gazetteer onload' ,'var');
+'enableSearchWithoutParams', '0',
+'define that search can be started without any search params' ,
+'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/GazetteerWFS" class=LURL target=_top>http://www.mapbender.org/GazetteerWFS</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Verena_Diewald" class=LURL target=_top>http://www.mapbender.org/User:Verena_Diewald</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>maxHighlightedPoints</td><td class=CDLDescription>max number of points to highlight</td></tr><tr><td class=CDLEntry>wfsConfIdString</td><td class=CDLDescription>comma seperated list of WFS conf ids</td></tr><tr><td class=CDLEntry>wfs_spatial_request_conf_filename</td><td class=CDLDescription>location and name of the WFS configuration file for spatialRequest</td></tr><tr><td class=CDLEntry>initializeOnLoad</td><td class=CDLDescription>start gazetteer onload</td></tr><tr><td class=CDLEntry>enableSearchWithoutParams</td><td class=CDLDescription>define that search can be started without any search params</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#gazetteerWFS" >gazetteerWFS</a></td><td class=SDescription>A WFS gazetteer for pre configured WFS configurations.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#gazetteerWFS.Properties" >Properties</a></td><td class=SDescription></td></tr><tr class="SProperty SIndent2 SMarked"><td class=SEntry><a href="#gazetteerWFS.events.onWfsConfSelect" >events.<wbr>onWfsConfSelect</a></td><td class=SDescription>event is fired whenever a new WFS is selected</td></tr><tr class="SProperty SIndent2"><td class=SEntry><a href="#gazetteerWFS.events.onFormReset" >events.<wbr>onFormReset</a></td><td class=SDescription>event is fired whenever the form is resetted</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="gazetteerWFS.Properties"></a>Properties</h3></div></div>
+<div class="CProperty"><div class=CTopic><h3 class=CTitle><a name="gazetteerWFS.events.onWfsConfSelect"></a>events.<wbr>onWfsConfSelect</h3><div class=CBody><h4 class=CHeading>Description</h4><p>event is fired whenever a new WFS is selected</p></div></div></div>
+<div class="CProperty"><div class=CTopic><h3 class=CTitle><a name="gazetteerWFS.events.onFormReset"></a>events.<wbr>onFormReset</h3><div class=CBody><h4 class=CHeading>Description</h4><p>event is fired whenever the form is resetted</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile id=MSelected>gazetteerWFS</div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_wfs_gazetteer_client-php.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomFull-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomFull-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomFull-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<html><head><title>zoomFull</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="zoomFull"></a>zoomFull</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Click button to zoom to the full extent of the BoundingBox.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_zoomFull.php</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre> INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','zoomFull',2,1,
+ 'zoom to full extent button','Display complete map','img',
+ '../img/button_blink_red/zoomFull_off.png','',335,60,24,24,2,'','','',
+ 'mod_zoomFull.php','','mapframe1','',
+'http://www.mapbender.org/index.php/ZoomFull');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ZoomFull" class=LURL target=_top>http://www.mapbender.org/ZoomFull</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Verena_Diewald" class=LURL target=_top>http://www.mapbender.org/User:Verena_Diewald</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>zoomFull</div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomFull-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<html><head><title>ZoomIn1</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ZoomIn1"></a>ZoomIn1</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). Image size is not affected.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_zoomIn1.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
+e_comment, e_title, e_element, e_src, e_attributes, e_left,
+e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+VALUES('gui', 'zoomIn1', 2, 1, 'zoomIn button','Zoom in',
+'img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,
+'','','','mod_zoomIn1.js','','mapframe1','',
+'http://www.mapbender.org/index.php/ZoomIn');</pre></blockquote><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomIn1</div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomOut1-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomOut1-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomOut1-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>ZoomOut1</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ZoomOut1"></a>ZoomOut1</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). Image size is not affected.</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_zoomOut1.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','zoomOut1',
+2,1,'zoomOut button','Zoom out','img',
+'../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','',
+'mod_zoomOut1.js','','mapframe1','',
+'http://www.mapbender.org/index.php/ZoomOut');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ZoomOut" class=LURL target=_top>http://www.mapbender.org/ZoomOut</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomOut1</div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([1, 3], 8);// --></script></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomOut1-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/jq_datatables-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/jq_datatables-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/jq_datatables-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,52 @@
+<html><head><title>jq_datatables</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="jq_datatables"></a>jq_datatables</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Includes the jQuery plugin datatables, use like this</p><p>$(selector).datatables(options)</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/jq_datatables.js</li><li>http/extensions/dataTables-1.5/</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_datatables',1,1,
+'Includes the jQuery plugin datatables','','','','',NULL ,NULL ,NULL ,
+NULL ,NULL ,'','','','../plugins/jq_datatables.js',
+'../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','',
+'http://www.datatables.net/');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES('gui1', 'jq_datatables',
+'defaultCss',
+'../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,
+'file/css');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.datatables.net/" class=LURL target=_top>http://www.datatables.net/</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile id=MSelected>jq_datatables</div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+HideAllBut([2, 3], 8);// --></script></div><!--Menu-->
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/jq_datatables-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_accordion-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_accordion-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_accordion-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<html><head><title>jq_ui_accordion</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="jq_ui_accordion"></a>jq_ui_accordion</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Accordion from the jQuery UI framework</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/jq_ui_accordion.js</li><li>http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/ui.accordion.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>',
+'jq_ui_accordion',2,1,'Accordion from the jQuery UI framework','','',
+'','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','',
+'../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/ui.accordion.js',
+'','jq_ui','http://docs.jquery.com/UI/Accordion');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://jqueryui.com/demos/accordion" class=LURL target=_top>http://jqueryui.com/demos/accordion</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile id=MSelected>jq_ui_accordion</div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_accordion-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_effects-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_effects-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_effects-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,94 @@
+<html><head><title>jq_ui_effects</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="jq_ui_effects"></a>jq_ui_effects</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A collection of jQuery UI effects</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/jq_ui_effects.js</li><li>http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.*</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre> INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','jq_ui_effect',
+ 1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','',
+ 'jq_ui_effects.php',
+ '../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js',
+ INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'blind',
+ '0', '1 = effect active' ,'php_var');
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'bounce',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'clip',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'drop',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'explode',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'fold',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'highlight',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'pulsate',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'scale',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'shake',
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'slide',
+'0', '1 = effect active' ,'php_var');
+ var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'transfer',
+ '1', '1 = effect active' ,'php_var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://jqueryui.com/docs/effect/" class=LURL target=_top>http://jqueryui.com/docs/effect/</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile id=MSelected>jq_ui_effects</div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_effects-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_resizable-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_resizable-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_resizable-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,47 @@
+<html><head><title>jq_ui_resizable</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="jq_ui_resizable"></a>jq_ui_resizable</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Resizable from the jQuery UI framework</p><h4 class=CHeading>Files</h4><ul><li>plugins/jq_ui_resizable.js</li><li>extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>',
+'jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','',
+'../plugins/jq_ui_resizable.js',
+'../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js',
+'','jq_ui','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://jqueryui.com/demos/resizable/" class=LURL target=_top>http://jqueryui.com/demos/resizable/</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile id=MSelected>jq_ui_resizable</div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/jq_ui_resizable-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_cookie-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_cookie-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_cookie-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,44 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>cookie</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="cookie"></a>cookie</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Sets a cookie after each map request. The cookie contains the current settings of the map, similar to WMC.</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_cookie.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','cookie',20,1,
+'','','div','','',-1,-1,1,1,NULL ,'','','div','../plugins/mb_cookie.js',
+'','mapframe1','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Cookie" class=LURL target=_top>http://www.mapbender.org/Cookie</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile id=MSelected>cookie</div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_cookie-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_i18n-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_i18n-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_i18n-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<html><head><title>i18n</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="i18n"></a>i18n</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_i18n.js</li><li>http/plugins/mb_i18n_server.php</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('gui','i18n',1,1,
+'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.',
+'Internationalization','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','',
+'div','../plugins/mb_i18n.js','','','',
+'http://www.mapbender.org/Gettext');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Gettext" class=LURL target=_top>http://www.mapbender.org/Gettext</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile id=MSelected>i18n</div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+HideAllBut([2, 3], 8);// --></script></div><!--Menu-->
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_i18n-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_map-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_map-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_map-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,57 @@
+<html><head><title>mapframe1</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mapframe1"></a>mapframe1</h1><div class=CBody><h4 class=CHeading>Description</h4><p>The main map in Mapbender</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_map.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','mapframe1',
+1,1,'The main map in Mapbender','','div','','',220,105,625,400,2,
+'overflow:hidden;background-color:#ffffff','','div',
+'../plugins/mb_map.js',
+'../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php',
+'','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES('<appId>', 'mapframe1',
+'skipWmsIfSrsNotSupported', '0',
+'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility',
+'var');
+var_value, context, var_type) VALUES('<appId>', 'mapframe1', 'slippy',
+'0', 'Activates an animated, pseudo slippy map' ,'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Mapframe" class=LURL target=_top>http://www.mapbender.org/Mapframe</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>skipWmsIfSrsNotSupported</td><td class=CDLDescription>if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile id=MSelected>mapframe1</div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_map-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_navigation-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_navigation-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_navigation-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,45 @@
+<html><head><title>mb_navigation</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mb_navigation"></a>mb_navigation</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Adds navigation arrows on top of the map</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_navigation.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','mb_navigation',
+2,1,'Adds navigation arrows on top of the map','Navigation','div','','',
+NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_navigation.js',
+'','mapframe1','mapframe1','http://www.mapbender.org/Navigation');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Navigation" class=LURL target=_top>http://www.mapbender.org/Navigation</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile id=MSelected>mb_navigation</div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_navigation-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_overview-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_overview-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_overview-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,57 @@
+<html><head><title>Overview</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Overview"></a>Overview</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Use the overview map to navigate the main map window. You can select a new rectangle in the overview map, the details will be displayed in the main map window. Recenter the main map window section by just clicking a new position in the overview map (the scale will not change).</p><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_overview.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','overview',
+2,1,'OverviewFrame','Overview','div','','',15,25,150,150,2,
+'overflow:hidden;',
+'<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>',
+'div','../plugins/mb_overview.js','mod_box1.js','mapframe1','mapframe1',
+'http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('<app_id>', 'overview',
+'overview_wms', '0', 'wms that shows up as overview' ,'var');
+'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,
+'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Overview" class=LURL target=_top>http://www.mapbender.org/Overview</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>overview_wms</td><td class=CDLDescription>wms that shows up as overview</td></tr><tr><td class=CDLEntry>skipWmsIfSrsNotSupported</td><td class=CDLDescription><b>[optional]</b> if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile id=MSelected>Overview</div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_overview-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_print-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_print-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_print-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,77 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>printPDF</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="printPDF"></a>printPDF</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Mapbender print PDF with PDF templates module.</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_print.js</li><li>http/print/classes</li><li>http/print/printFactory.php</li><li>http/print/printPDF_download.php</li><li>lib/printbox.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','printPDF',
+2,1,'pdf print','Print','div','','',1,1,2,2,5,'',
+'<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>',
+'div','../plugins/mb_print.js',
+'../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../extensions/jquery.form.min.js',
+'mapframe1','','http://www.mapbender.org/index.php/Print');
+var_value, context, var_type) VALUES('<appId>', 'printPDF',
+'mbPrintConfig', '{"Standard": "mapbender_template.json"}', '' ,'var');
+var_value, context, var_type) VALUES('<appId>', 'body',
+'print_css', '../css/print_div.css', '' ,'file/css');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/PrintPDF_with_template" class=LURL target=_top>http://www.mapbender.org/PrintPDF_with_template</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Michael_Schulz" class=LURL target=_top>http://www.mapbender.org/User:Michael_Schulz</a> <a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>mbPrintConfig</td><td class=CDLDescription><b>[optional]</b> object with name and filename of template, like { “Standard”: “a_template.json”, “Different”: “another_template.json” }</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#printPDF" >printPDF</a></td><td class=SDescription>Mapbender print PDF with PDF templates module.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#printPDF.Properties" >Properties</a></td><td class=SDescription></td></tr><tr class="SProperty SIndent2 SMarked"><td class=SEntry><a href="#printPDF.actualConfig" >actualConfig</a></td><td class=SDescription>object, holds the actual configuration after loading the json file</td></tr><tr class="SProperty SIndent2"><td class=SEntry><a href="#printPDF.printBox" >printBox</a></td><td class=SDescription>the movable printframe</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#printPDF.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#printPDF.createPrintBox" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">createPrintBox</a></td><td class=SDescription>creates a printBox in the current view, calculates the scale (tbd. </td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#printPDF.getPDFMapSize" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">getPDFMapSize</a></td><td class=SDescription>checks the actual config for the size w/h values.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#printPDF.destroyPrintBox" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">destroyPrintBox</a></td><td class=SDescription>removes an existing printBox.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#printPDF.mod_printPDF_init" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')">mod_printPDF_init</a></td><td class=SDescription>initializes the print modules, generates template chooser and loads first configuration.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#printPDF.loadConfig" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')">loadConfig</a></td><td class=SDescription>GETs the config, build corresponding form, remove an existing printBox</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#printPDF.hookForm" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')">hookForm</a></td><td class=SDescription>utility method to connect the form plugin to the print form.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#printPDF.showResult" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')">showResult</a></td><td class=SDescription>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="printPDF.Properties"></a>Properties</h3></div></div>
+<div class="CProperty"><div class=CTopic><h3 class=CTitle><a name="printPDF.actualConfig"></a>actualConfig</h3><div class=CBody><p>object, holds the actual configuration after loading the json file</p></div></div></div>
+<div class="CProperty"><div class=CTopic><h3 class=CTitle><a name="printPDF.printBox"></a>printBox</h3><div class=CBody><p>the movable printframe</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="printPDF.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="printPDF.createPrintBox"></a>createPrintBox</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.createPrintBox = function ()</td></tr></table></blockquote><p>creates a printBox in the current view, calculates the scale (tbd. if not set from the config) so that the printbox fits in the mapframe. Width and height are taken from the configuration.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="printPDF.getPDFMapSize"></a>getPDFMapSize</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>checks the actual config for the size w/h values.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>key</td><td class=CDLDescription>string, the key which value to retrieve (currently width or height)</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="printPDF.destroyPrintBox"></a>destroyPrintBox</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var destroyPrintBox = function ()</td></tr></table></blockquote><p>removes an existing printBox.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="printPDF.mod_printPDF_init"></a>mod_printPDF_init</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote><p>initializes the print modules, generates template chooser and loads first configuration.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="printPDF.loadConfig"></a>loadConfig</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>GETs the config, build corresponding form, remove an existing printBox</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="printPDF.hookForm"></a>hookForm</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote><p>utility method to connect the form plugin to the print form.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="printPDF.showResult"></a>showResult</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var showResult = function (</td><td class=PParameter nowrap>res,</td></tr><tr><td></td><td class=PParameter nowrap>text</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile id=MSelected>printPDF</div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.createPrintBox = function ()</td></tr></table></blockquote>creates a printBox in the current view, calculates the scale (tbd. </div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var destroyPrintBox = function ()</td></tr></table></blockquote>removes an existing printBox.</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var showResult = function (</td><td class=PParameter nowrap>res,</td></tr><tr><td></td><td class=PParameter nowrap>text</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</div></div><!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_print-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_resize-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_resize-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_resize-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,47 @@
+<html><head><title>resize</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="resize"></a>resize</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Adds a resizable plugin to the module in target, for example mapframe1</p><h4 class=CHeading>Files</h4><ul><li>plugins/mb_resize.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+'jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','',
+'','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','',
+'../plugins/jq_ui_resizable.js',
+'../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js',
+'','jq_ui','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://jqueryui.com/demos/resizable/" class=LURL target=_top>http://jqueryui.com/demos/resizable/</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile id=MSelected>resize</div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+HideAllBut([2, 3], 8);// --></script></div><!--Menu-->
+<!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_resize-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_resultList_transferToDigitize-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_resultList_transferToDigitize-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_resultList_transferToDigitize-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title>mb_resultList_transferToDigitize</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mb_resultList_transferToDigitize"></a>mb_resultList_transferToDigitize</h1><div class=CBody><h4 class=CHeading>Description</h4><p><A description></p><h4 class=CHeading>Files</h4><ul><li><path and filename, like http/javascripts/mod_zoomIn1.php></li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/" class=LURL target=_top>http://www.mapbender.org/</a><wiki site name></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:" class=LURL target=_top>http://www.mapbender.org/User:</a><user></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry><normal element var name></td><td class=CDLDescription><type and description></td></tr><tr><td class=CDLEntry><optional element var name></td><td class=CDLDescription><b>[optional]</b> <type and description></td></tr><tr><td class=CDLEntry><deprecated element var name></td><td class=CDLDescription><b>[deprecated]</b> <type and description></td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile id=MSelected>mb_resultList_transferToDigitize</div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_resultList_transferToDigitize-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_selectMapsize-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_selectMapsize-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_selectMapsize-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,45 @@
+<html><head><title>selectMapsize</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="selectMapsize"></a>selectMapsize</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Select the map size from a pre defined settings, like large or small</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_selectMapsize.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','selectMapsize',
+2,1,'change the size of the map with a selectbox','','select','','',
+750,10,100,20,5,'','<option value="800,800">gross</option><option value="600,600">mittel</option><option value="500,500">klein</option>',
+'select','../plugins/mb_selectMapsize.js','','mapframe1','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/SelectMapsize" class=LURL target=_top>http://www.mapbender.org/SelectMapsize</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile id=MSelected>selectMapsize</div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_selectMapsize-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_tabs_vertical-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_tabs_vertical-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_tabs_vertical-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,50 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>tabs_vertical</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="tabs_vertical"></a>tabs_vertical</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An accordion decorator, replaces the deprecated element “tabs”</p><p>Enter the elements to be put in the accordion in its target field (comma-separated list of element ids).</p><p>Avoid styles in elements within the accordion.</p><p>The overview won’t work in the accordion, as it cannot be positioned absolutely.</p><p>The width of this module determines the accordion width, but the height of the individual elements determines the height.</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_accordion.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>',
+'tabs_vertical',2,1,
+'An accordion decorator, replaces the deprecated element tabs',
+'','div','','',10,130,300,NULL ,2,'','','div',
+'../plugins/jq_ui_accordion.js','','','jq_ui_accordion','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES('<appId>', 'tabs_vertical',
+'active', '2', 'which tab to open on startup [1..n]' ,'var');</pre></blockquote><h4 class=CHeading>Help</h4><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile id=MSelected>tabs_vertical</div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_tabs_vertical-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_twitter_signin-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_twitter_signin-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_twitter_signin-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,54 @@
+<html><head><title>twitter_signin</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="twitter_signin"></a>twitter_signin</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Authenticate with Twitter</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_twitter_signin.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','twitter_signin',
+1,1,'Authenticate with Twitter','Authenticate with Twitter','img',
+'../img/twitter_signin.png','',900,10,NULL ,NULL ,NULL ,'','','',
+'../plugins/mb_twitter_signin.js','','','','');
+var_value, context, var_type) VALUES('<appId>', 'twitter_signin',
+'consumerKey', '<your key>', '' ,'php_var');
+'consumerSecret', '<your secret>',
+'' ,'php_var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Twitter_signin" class=LURL target=_top>http://www.mapbender.org/Twitter_signin</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>consumerKey</td><td class=CDLDescription>your consumer key from Twitter (PHP var)</td></tr><tr><td class=CDLEntry>consumerSecret</td><td class=CDLDescription>your consumer secret from Twitter (PHP var)</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile id=MSelected>twitter_signin</div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+<!--START_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_twitter_signin-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeInterval-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeInterval-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeInterval-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,49 @@
+<html><head><title>wmsTimeInterval</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="wmsTimeInterval"></a>wmsTimeInterval</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Find an interval with two datepickers and attach it to getMap requests of WMS in your application</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_wmsTimeInterval.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title,
+e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index,
+e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,
+e_url) VALUES('<gui_id>','wmsTimeInterval',1,1,'select an interval for WMS-T',
+'','div','','',700,40,NULL ,NULL ,2,'','','div',
+'../plugins/mb_wmsTimeInterval.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+context, var_type) VALUES('<gui_id>', 'wmsTimeInterval', 'wms', '<wmsId>',
+'An array in JSON notation, containing the IDs of the WMS that the time parameter is passed to' ,
+'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/wmsTimeInterval" class=LURL target=_top>http://www.mapbender.org/wmsTimeInterval</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>wms</td><td class=CDLDescription>a single numerical WMS id (like 407), or an array of numerical WMS in JSON notation (like [407,912])</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile id=MSelected>wmsTimeInterval</div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+HideAllBut([2, 3], 8);// --></script></div><!--Menu-->
+<!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeInterval-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeSliderYear-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeSliderYear-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeSliderYear-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,79 @@
+<html><head><title>wmsTimeSliderYear</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="wmsTimeSliderYear"></a>wmsTimeSliderYear</h1><div class=CBody><h4 class=CHeading>Description</h4><p>sets the TIME parameter for all activated WMS (years only)</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_wmsTimeSliderYear.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+'wmsTimeSliderYear',5,1,'sets the TIME parameter for all activated WMS (years only)',
+'','div','','',500,700,500,10,NULL ,'','','div',
+'../plugins/mb_wmsTimeSliderYear.js','','mapframe1','jq_ui_slider','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','jq_ui_slider',
+5,1,'slider from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,
+NULL ,NULL ,'','','','',
+'../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.slider.js',
+'','jq_ui','');
+e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','jq_ui',1,1,
+'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','',
+'','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js',
+context, var_type) VALUES('<appId>', 'jq_ui', 'css',
+'../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css',
+'' ,'file/css');
+context, var_type) VALUES('<appId>', 'wmsTimeSliderYear',
+'yearDefault', '2007', 'default slider setting' ,'var');
+context, var_type) VALUES('<appId>', 'wmsTimeSliderYear', 'yearMax',
+'2007', 'upper end of the time interval' ,'var');
+context, var_type) VALUES('<appId>', 'wmsTimeSliderYear', 'yearMin',
+'1995', 'lower end of the time interval' ,'var');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/wmsTimeSliderYear" class=LURL target=_top>http://www.mapbender.org/wmsTimeSliderYear</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>yearMin</td><td class=CDLDescription>lower end of the time interval</td></tr><tr><td class=CDLEntry>yearMax</td><td class=CDLDescription>lower end of the time interval</td></tr><tr><td class=CDLEntry>yearDefault</td><td class=CDLDescription><b>[optional]</b> default slider setting (if not set yearMax is used)</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile id=MSelected>wmsTimeSliderYear</div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_wmsTimeSliderYear-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomIn-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomIn-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomIn-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<html><head><title>mb_zoomIn</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mb_zoomIn"></a>mb_zoomIn</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). Image size is not affected.</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_zoomIn.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
+e_comment, e_title, e_element, e_src, e_attributes, e_left,
+e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+VALUES('<app_id>', 'mb_zoomIn', 2, 1, 'zoomIn button','Zoom in',
+'img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,
+'','','','../plugins/mb_zoomIn.js','','mapstraction','',
+'');</pre></blockquote><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile id=MSelected>mb_zoomIn</div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomIn-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomOut-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomOut-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomOut-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,46 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>mb_zoomOut</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mb_zoomOut"></a>mb_zoomOut</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). Image size is not affected.</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/mb_zoomOut.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','mb_zoomOut',
+2,1,'zoomOut button','Zoom out','img',
+'../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','',
+'../plugins/mb_zoomOut.js','','mapstraction','',
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile id=MSelected>mb_zoomOut</div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/mb_zoomOut-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/ol-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/ol-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/ol-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title>ol</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ol"></a>ol</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An OpenLayers Map, configured with WMS from Mapbender application settings</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/ol.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ol" class=LURL target=_top>http://www.mapbender.org/ol</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile id=MSelected>ol</div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+<!--START_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/ol-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/ol_keyboardDefaults-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/ol_keyboardDefaults-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/ol_keyboardDefaults-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title>ol_keyboardDefaults</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ol_keyboardDefaults"></a>ol_keyboardDefaults</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An OpenLayers KeyboardDefaults</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/ol_keyboardDefaults.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ol_keyboardDefaults" class=LURL target=_top>http://www.mapbender.org/ol_keyboardDefaults</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile id=MSelected>ol_keyboardDefaults</div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+HideAllBut([2, 3], 8);// --></script></div><!--Menu-->
+<!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/ol_keyboardDefaults-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/ol_layerSwitch-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/ol_layerSwitch-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/ol_layerSwitch-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title>ol_layerSwitch</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ol_layerSwitch"></a>ol_layerSwitch</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An OpenLayers Layer Switch</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/ol_layerSwitch.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ol_layerSwitch" class=LURL target=_top>http://www.mapbender.org/ol_layerSwitch</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile id=MSelected>ol_layerSwitch</div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/ol_layerSwitch-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/ol_mousePosition-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/ol_mousePosition-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/ol_mousePosition-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title>ol_mousePosition</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ol_mousePosition"></a>ol_mousePosition</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An OpenLayers MousePosition</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/ol_mousePosition.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ol_mousePosition" class=LURL target=_top>http://www.mapbender.org/ol_mousePosition</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile id=MSelected>ol_mousePosition</div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/ol_mousePosition-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/ol_overview-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/ol_overview-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/ol_overview-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title>ol_overviewMap</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ol_overviewMap"></a>ol_overviewMap</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An OpenLayers Layer Switch</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/ol_overview.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ol_overviewMap" class=LURL target=_top>http://www.mapbender.org/ol_overviewMap</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile id=MSelected>ol_overviewMap</div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/ol_overview-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/ol_panZoomBar-js.html
--- trunk/mapbender/documents/api_js/files/http/plugins/ol_panZoomBar-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/ol_panZoomBar-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>ol_panZoomBar</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ol_panZoomBar"></a>ol_panZoomBar</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An OpenLayers panZoomBar</p><h4 class=CHeading>Files</h4><ul><li>http/plugins/ol_panZoomBar.js</li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/ol_panZoomBar" class=LURL target=_top>http://www.mapbender.org/ol_panZoomBar</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile id=MSelected>ol_panZoomBar</div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/ol_panZoomBar-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/http/plugins/ol_wms-php.html
--- trunk/mapbender/documents/api_js/files/http/plugins/ol_wms-php.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/http/plugins/ol_wms-php.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,41 @@
+<html><head><title><Application element name></title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Application_element_name"></a><Application element name></h1><div class=CBody><h4 class=CHeading>Description</h4><p><A description></p><h4 class=CHeading>Files</h4><ul><li><path and filename, like http/javascripts/mod_zoomIn1.php></li></ul><h4 class=CHeading>SQL</h4><blockquote><pre><SQL for element>
+<SQL for element var></pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/" class=LURL target=_top>http://www.mapbender.org/</a><wiki site name></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:" class=LURL target=_top>http://www.mapbender.org/User:</a><user></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry><normal element var name></td><td class=CDLDescription><type and description></td></tr><tr><td class=CDLEntry><optional element var name></td><td class=CDLDescription><b>[optional]</b> <type and description></td></tr><tr><td class=CDLEntry><deprecated element var name></td><td class=CDLDescription><b>[deprecated]</b> <type and description></td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile id=MSelected><Application element name></div></div><div class=MEntry><div class=MFile><a href="mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+<!--START_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/http/plugins/ol_wms-php.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/ajax-js.html
--- trunk/mapbender/documents/api_js/files/lib/ajax-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/ajax-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,57 @@
+<html><head><title>Ajax</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Ajax"></a>Ajax</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An AJAX wrapper for client server interaction via JSON RPC</p><h4 class=CHeading>Files</h4><ul><li>lib/ajax.js</li></ul><h4 class=CHeading>Help</h4><p><none></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Ajax" >Ajax</a></td><td class=SDescription>An AJAX wrapper for client server interaction via JSON RPC</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Ajax.Properties" >Properties</a></td><td class=SDescription></td></tr><tr class="SProperty SIndent2 SMarked"><td class=SEntry><a href="#Ajax.requestCount" >requestCount</a></td><td class=SDescription>counts the number of requests that have been made</td></tr><tr class="SClass"><td class=SEntry><a href="#Notification" >Notification</a></td><td class=SDescription>An AJAX notification (it doesn’t expect a reply from the server)</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Notification.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Notification.Mapbender.Ajax.Request" >Mapbender.<wbr>Ajax.<wbr>Request</a></td><td class=SDescription></td></tr><tr class="SClass"><td class=SEntry><a href="#Request" >Request</a></td><td class=SDescription>An AJAX request (it expects a reply from the server)</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Request.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Request.Mapbender.Ajax.Request" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Mapbender.<wbr>Ajax.<wbr>Request</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Request.send" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">send</a></td><td class=SDescription>Sends the request to the server side</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Ajax.Properties"></a>Properties</h3></div></div>
+<div class="CProperty"><div class=CTopic><h3 class=CTitle><a name="Ajax.requestCount"></a>requestCount</h3><div class=CBody><h4 class=CHeading>Description</h4><p>counts the number of requests that have been made</p></div></div></div>
+<div class="CClass"><div class=CTopic><h2 class=CTitle><a name="Notification"></a>Notification</h2><div class=CBody><h4 class=CHeading>Description</h4><p>An AJAX notification (it doesn’t expect a reply from the server)</p><h4 class=CHeading>Files</h4><ul><li>lib/ajax.js</li></ul><h4 class=CHeading>Help</h4><p><none> Maintainer: <a href="http://www.mapbender.org/Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#Notification.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#Notification.Mapbender.Ajax.Request" >Mapbender.<wbr>Ajax.<wbr>Request</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Notification.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Notification.Mapbender.Ajax.Request"></a>Mapbender.<wbr>Ajax.<wbr>Request</h3><div class=CBody><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>options.url</td><td class=CDLDescription>(String) The URL or the server side script</td></tr><tr><td class=CDLEntry>options.type</td><td class=CDLDescription><b>[optional]</b> (String) “POST” (default) or “GET”</td></tr><tr><td class=CDLEntry>options.log</td><td class=CDLDescription><b>[optional]</b> (Boolean) logs the request as Mapbender.Notice (default: false)</td></tr><tr><td class=CDLEntry>options.method</td><td class=CDLDescription><b>[optional]</b> (String) The name of the method that is called on the server side (default: “”)</td></tr><tr><td class=CDLEntry>options.parameters</td><td class=CDLDescription><b>[optional]</b> (Object) arguments being passed to the method given above</td></tr><tr><td class=CDLEntry><deprecated variable name></td><td class=CDLDescription><b>[deprecated]</b> <type and description></td></tr></table></div></div></div>
+<div class="CClass"><div class=CTopic><h2 class=CTitle><a name="Request"></a>Request</h2><div class=CBody><h4 class=CHeading>Description</h4><p>An AJAX request (it expects a reply from the server)</p><h4 class=CHeading>Files</h4><ul><li>lib/ajax.js</li></ul><h4 class=CHeading>Help</h4><p><none></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#Request.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#Request.Mapbender.Ajax.Request" id=link3 onMouseOver="ShowTip(event, 'tt1', 'link3')" onMouseOut="HideTip('tt1')">Mapbender.<wbr>Ajax.<wbr>Request</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#Request.send" id=link4 onMouseOver="ShowTip(event, 'tt2', 'link4')" onMouseOut="HideTip('tt2')">send</a></td><td class=SDescription>Sends the request to the server side</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Request.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Request.Mapbender.Ajax.Request"></a>Mapbender.<wbr>Ajax.<wbr>Request</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>options.url</td><td class=CDLDescription>(String) The URL to the server side script</td></tr><tr><td class=CDLEntry>options.type</td><td class=CDLDescription><b>[optional]</b> (String) “POST” (default) or “GET”</td></tr><tr><td class=CDLEntry>options.log</td><td class=CDLDescription><b>[optional]</b> (Boolean) logs the request as Mapbender.Notice (default: false)</td></tr><tr><td class=CDLEntry>options.method</td><td class=CDLDescription><b>[optional]</b> (String) The name of the method that is called on the server side (default: “”)</td></tr><tr><td class=CDLEntry>options.parameters</td><td class=CDLDescription><b>[optional]</b> (Object) arguments being passed to the method given above</td></tr><tr><td class=CDLEntry>options.callback</td><td class=CDLDescription>(Function) Will be called after the request is finished</td></tr><tr><td class=CDLEntry>options.scope</td><td class=CDLDescription><b>[optional]</b> (Object) the callback will be executed within the scope of this object</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Request.send"></a>send</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Sends the request to the server side</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile id=MSelected>Ajax</div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../search");
+HideAllBut([4, 5, 3, 6], 8);// --></script></div><!--Menu-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/ajax-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/basic-js.html
--- trunk/mapbender/documents/api_js/files/lib/basic-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/basic-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,47 @@
+<html><head><title>mapbender</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mapbender"></a>mapbender</h1><div class=CBody><h4 class=CHeading>Description</h4><p>This jQuery plugin grants access to the Mapbender API from a DOM element. You can supply various arguments to achieve different things:</p><p>Passing no arguments will return the API object of the Mapbender element associated with the DOM element, usage</p><p>var api = $(“#myelement”).mapbender();</p><p>Passing an object serves as a setter: the object is the new API object associated with the DOM element, usage</p><p>$(“#myelement”).mapbender(new CustomApiObject());</p><p>Passing a string serves as an attribute getter. It returns the value of any public attribute of the API object, usage</p><p>$(“#myelement”).mapbender(“aSpecificAttribute”)</p><p>Passing a function executes the function in the scope of the API object. This is a shortcut to fetching the API object first, and then calling its method. By this, you don’t need to check whether the API object exists, if none exists, the function is simply not executed. Usage</p><p>$(“#myelement”).mapbender(function () { // this refers to the API object!! console.log(this.options); });</p><h4 class=CHeading>Files</h4><ul><li>lib/basic.js</li></ul><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#mapbender" >mapbender</a></td><td class=SDescription>This jQuery plugin grants access to the Mapbender API from a DOM element. </td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#mapbender.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#mapbender.cookiesEnables" >cookiesEnables</a></td><td class=SDescription>Checks whether cookies are enabled in the browser</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#mapbender.cloneObject" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">cloneObject</a></td><td class=SDescription>Clone an object recursively. </td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#mapbender.getConjunctionChar" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">getConjunctionChar</a></td><td class=SDescription>returns the character necessary to append to a string in order to attach more GET parameters</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="mapbender.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="mapbender.cookiesEnables"></a>cookiesEnables</h3><div class=CBody><h4 class=CHeading>Description</h4><p>Checks whether cookies are enabled in the browser</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="mapbender.cloneObject"></a>cloneObject</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Clone an object recursively. Make sure the object is not circular!</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>p</td><td class=CDLDescription>an object</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="mapbender.getConjunctionChar"></a>getConjunctionChar</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>returns the character necessary to append to a string in order to attach more GET parameters</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>url</td><td class=CDLDescription>the online resource</td></tr></table></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile id=MSelected>mapbender</div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.cloneObject = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>c</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Clone an object recursively. </div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/basic-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/button-js.html
--- trunk/mapbender/documents/api_js/files/lib/button-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/button-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,39 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Button</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Button"></a>Button</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Adds a clickable button to Mapbender</p><h4 class=CHeading>Files</h4><ul><li>lib/button.js</li></ul><h4 class=CHeading>Help</h4><p><none></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>options.over</td><td class=CDLDescription>URL to img representing the “over” status</td></tr><tr><td class=CDLEntry>options.on</td><td class=CDLDescription>URL to img representing the “on” status</td></tr><tr><td class=CDLEntry>options.off</td><td class=CDLDescription>URL to img representing the “off” status (default)</td></tr><tr><td class=CDLEntry>options.go</td><td class=CDLDescription>a function to be executed once the button is pressed</td></tr><tr><td class=CDLEntry>options.stop</td><td class=CDLDescription>a function to be executed once the button is disabled</td></tr><tr><td class=CDLEntry>options.off</td><td class=CDLDescription>URL to img representing the “off” status (default)</td></tr><tr><td class=CDLEntry>options.name</td><td class=CDLDescription>the ID of the corresponding DOM element</td></tr></table><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile id=MSelected>Button</div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/button-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/event-js.html
--- trunk/mapbender/documents/api_js/files/lib/event-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/event-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,48 @@
+<html><head><title>Event</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Event"></a>Event</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An event. What happens, when the event occurs, depends on which functions have been registered with the event.</p><h4 class=CHeading>usage</h4><blockquote><pre>// create a new Event
+var eventAfterMapRequest = new MapbenderEvent();
+// register a function with that event
+eventAfterMapRequest.register(function () {
+// trigger the event
+eventAfterMapRequest.trigger();</pre></blockquote></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile id=MSelected>Event</div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+<!--START_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/lib/event-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/exception-js.html
--- trunk/mapbender/documents/api_js/files/lib/exception-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/exception-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,55 @@
+<html><head><title>Exception</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Exception"></a>Exception</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Logs an exception in the log file, in a console window or as an alert</p><h4 class=CHeading>Files</h4><ul><li>lib/exception.js</li></ul><h4 class=CHeading>Help</h4><p><none></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Exception" >Exception</a></td><td class=SDescription>Logs an exception in the log file, in a console window or as an alert</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Exception.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Exception.Exception" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Exception</a></td><td class=SDescription></td></tr><tr class="SClass"><td class=SEntry><a href="#Warning" >Warning</a></td><td class=SDescription>Logs an warning in the log file, in a console window or as an alert</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Warning.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Warning.Warning" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">Warning</a></td><td class=SDescription></td></tr><tr class="SClass"><td class=SEntry><a href="#Notice" >Notice</a></td><td class=SDescription>Logs a notice in the log file, in a console window or as an alert</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Notice.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Notice.Notice" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">Notice</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Exception.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Exception.Exception"></a>Exception</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>message</td><td class=CDLDescription>A message that is being logged</td></tr></table></div></div></div>
+<div class="CClass"><div class=CTopic><h2 class=CTitle><a name="Warning"></a>Warning</h2><div class=CBody><h4 class=CHeading>Description</h4><p>Logs an warning in the log file, in a console window or as an alert</p><h4 class=CHeading>Files</h4><ul><li>lib/exception.js</li></ul><h4 class=CHeading>Help</h4><p><none></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#Warning.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#Warning.Warning" id=link4 onMouseOver="ShowTip(event, 'tt2', 'link4')" onMouseOut="HideTip('tt2')">Warning</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Warning.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Warning.Warning"></a>Warning</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>message</td><td class=CDLDescription>A message that is being logged</td></tr></table></div></div></div>
+<div class="CClass"><div class=CTopic><h2 class=CTitle><a name="Notice"></a>Notice</h2><div class=CBody><h4 class=CHeading>Description</h4><p>Logs a notice in the log file, in a console window or as an alert</p><h4 class=CHeading>Files</h4><ul><li>lib/exception.js</li></ul><h4 class=CHeading>Help</h4><p><none></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#Notice.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#Notice.Notice" id=link5 onMouseOver="ShowTip(event, 'tt3', 'link5')" onMouseOut="HideTip('tt3')">Notice</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Notice.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Notice.Notice"></a>Notice</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>message</td><td class=CDLDescription>A message that is being logged</td></tr></table></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile id=MSelected>Exception</div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../search");
+HideAllBut([4, 5, 3, 6], 8);// --></script></div><!--Menu-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/exception-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/extent-js.html
--- trunk/mapbender/documents/api_js/files/lib/extent-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/extent-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,47 @@
+<html><head><title>Extent</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Extent"></a>Extent</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An extent is also known as a bounding box.</p><h4 class=CHeading>Files</h4><ul><li>lib/extent.js</li></ul><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Extent" >Extent</a></td><td class=SDescription>An extent is also known as a bounding box.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Extent.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Extent.Extent" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Extent</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Extent.set" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">set</a></td><td class=SDescription>Allows to set the center (one param) or the extent (two params)</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Extent.toString" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">toString</a></td><td class=SDescription>Returns a comma-separated list of all four coordinates</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Extent.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Extent.Extent"></a>Extent</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters (coordinates)</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>minx</td><td class=CDLDescription>{Float} x-coordinate of south western point</td></tr><tr><td class=CDLEntry>miny</td><td class=CDLDescription>{Float} y-coordinate of south western point</td></tr><tr><td class=CDLEntry>maxx</td><td class=CDLDescription>{Float} x-coordinate of north eastern point</td></tr><tr><td class=CDLEntry>maxy</td><td class=CDLDescription>{Float} y-coordinate of north eastern point</td></tr></table><h4 class=CHeading>or parameters (points)</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>sw</td><td class=CDLDescription>{Point} south western point</td></tr><tr><td class=CDLEntry>ne</td><td class=CDLDescription>{Point} north eastern point</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Extent.set"></a>set</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Allows to set the center (one param) or the extent (two params)</p><p>Parameters (center) center - {Point} center of bounding box</p><p>Parameters (center) sw - {Point} south western point of bounding box ne - {Point} north eastern point of bounding box</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Extent.toString"></a>toString</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Returns a comma-separated list of all four coordinates</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile id=MSelected>Extent</div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/extent-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/list-js.html
--- trunk/mapbender/documents/api_js/files/lib/list-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/list-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,39 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>List</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="List"></a>List</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A List object is an array of arbitrary objects with additional methods.</p><h4 class=CHeading>Files</h4><ul><li>lib/list.js</li></ul><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile id=MSelected>List</div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/list-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/marker-js.html
--- trunk/mapbender/documents/api_js/files/lib/marker-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/marker-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,45 @@
+<html><head><title>Mapbender.Marker</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Mapbender.Marker"></a>Mapbender.<wbr>Marker</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A very basic marker class. Put a (custom) marker at a given location</p><h4 class=CHeading>Files</h4><ul><li>lib/marker.js</li></ul><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Mapbender.Marker" >Mapbender.<wbr>Marker</a></td><td class=SDescription>A very basic marker class. </td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Mapbender.Marker.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Mapbender.Marker.Mapbender.Marker" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Mapbender.<wbr>Marker</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Mapbender.Marker.remove" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">remove</a></td><td class=SDescription>Remove the marker from the map.</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Mapbender.Marker.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Mapbender.Marker.Mapbender.Marker"></a>Mapbender.<wbr>Marker</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>p</td><td class=CDLDescription>a <Mapbender.Point> to specify the location</td></tr><tr><td class=CDLEntry>map</td><td class=CDLDescription>a <Mapbender.Map> on which the point is rendered</td></tr><tr><td class=CDLEntry>options.img.url</td><td class=CDLDescription><b>[optional]</b> a link to a custom marker image</td></tr><tr><td class=CDLEntry>options.img.offset</td><td class=CDLDescription><b>[optional]</b> a <Mapbender.Point> specifying the offset, default is (0,0). Usually these values are below zero because the image has to be translated to top and left</td></tr><tr><td class=CDLEntry>options.img.width</td><td class=CDLDescription><b>[optional]</b> use this to resize the marker image width (height must also be specified)</td></tr><tr><td class=CDLEntry>options.img.height</td><td class=CDLDescription><b>[optional]</b> use this to resize the marker image height (width must also be specified)</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Mapbender.Marker.remove"></a>remove</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Remove the marker from the map.</p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile id=MSelected>Mapbender.<wbr>Marker</div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/lib/marker-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/point-js.html
--- trunk/mapbender/documents/api_js/files/lib/point-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/point-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,43 @@
+<html><head><title>Point</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Point"></a>Point</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A class representing a two- (or three-) dimensional point.</p><h4 class=CHeading>Files</h4><ul><li>lib/point.js</li></ul><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Point" >Point</a></td><td class=SDescription>A class representing a two- (or three-) dimensional point.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Point.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Point.Point" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Point</a></td><td class=SDescription>just pass a Point in order to clone it.</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Point.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Point.Point"></a>Point</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>just pass a Point in order to clone it.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>x</td><td class=CDLDescription>the x coordinate</td></tr><tr><td class=CDLEntry>y</td><td class=CDLDescription>the y coordinate</td></tr><tr><td class=CDLEntry>z</td><td class=CDLDescription><b>[optional]</b> the z coordinate</td></tr></table></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile id=MSelected>Point</div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/point-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/resultGeometryListController-js.html
--- trunk/mapbender/documents/api_js/files/lib/resultGeometryListController-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/resultGeometryListController-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,47 @@
+<html><head><title>/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CFile"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="resultGeometryListController.js"></a>resultGeometryListController.js</h1><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#resultGeometryListController.js" >resultGeometryListController.js</a></td><td class=SDescription></td></tr><tr class="SGroup"><td class=SEntry><a href="#Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">addFeature</a></td><td class=SDescription>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#addFeatureCollection" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">addFeatureCollection</a></td><td class=SDescription>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#addFeatureCollection_callback" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">addFeatureCollection_callback</a></td><td class=SDescription>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="addFeature"></a>addFeature</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="addFeatureCollection"></a>addFeatureCollection</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="addFeatureCollection_callback"></a>addFeatureCollection_callback</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile id=MSelected>resultGeometryListController.js</div></div><div class=MEntry><div class=MFile><a href="resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../search");
+HideAllBut([4, 5, 3, 6], 8);// --></script></div><!--Menu-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/resultGeometryListController-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/lib/resultGeometryListModel-js.html
--- trunk/mapbender/documents/api_js/files/lib/resultGeometryListModel-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/lib/resultGeometryListModel-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,61 @@
+<html><head><title>ResultGeometryListModel</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ResultGeometryListModel"></a>ResultGeometryListModel</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A feature collection of a result geometry list.</p><h4 class=CHeading>Files</h4><ul><li>lib/resultGeometryListModel.js</li></ul><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#ResultGeometryListModel" >ResultGeometryListModel</a></td><td class=SDescription>A feature collection of a result geometry list.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#ResultGeometryListModel.Functions_and_Properties" >Functions and Properties</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#ResultGeometryListModel.ResultGeometryListModel" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">ResultGeometryListModel</a></td><td class=SDescription></td></tr><tr class="SProperty SIndent2"><td class=SEntry><a href="#ResultGeometryListModel.events" >events</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#ResultGeometryListModel.addFeatureCollection" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">addFeatureCollection</a></td><td class=SDescription>Add a feature collection to the geometry array</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#ResultGeometryListModel.addFeature" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">addFeature</a></td><td class=SDescription>Add a feature to the geometry array</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#ResultGeometryListModel.deleteFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')">deleteFeatureCollection</a></td><td class=SDescription>Delete the feature collection (= clear)</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#ResultGeometryListModel.deleteFeature" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')">deleteFeature</a></td><td class=SDescription>Delete a feature from the geometry array</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#ResultGeometryListModel.updateFeature" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')">updateFeature</a></td><td class=SDescription>Replace a feature in the geometry array</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#ResultGeometryListModel.setFeatureProperty" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')">setFeatureProperty</a></td><td class=SDescription>Set a property of a feature in the geometry array</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#ResultGeometryListModel.getFeatureProperty" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')">getFeatureProperty</a></td><td class=SDescription>Get a property of a feature in the geometry array</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#ResultGeometryListModel.getFeature" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')">getFeature</a></td><td class=SDescription>Get a feature in the geometry array</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.Functions_and_Properties"></a>Functions and Properties</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.ResultGeometryListModel"></a>ResultGeometryListModel</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div></div>
+<div class="CProperty"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.events"></a>events</h3><div class=CBody><h4 class=CHeading>Description</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>added</td><td class=CDLDescription>the event is fired after features are added</td></tr><tr><td class=CDLEntry>deleted</td><td class=CDLDescription>the event is fired after features have been deleted</td></tr><tr><td class=CDLEntry>updated</td><td class=CDLDescription>the event is fired after features have been updated</td></tr><tr><td class=CDLEntry>cleared</td><td class=CDLDescription>the event is fired after all features have been deleted</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.addFeatureCollection"></a>addFeatureCollection</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Add a feature collection to the geometry array</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>geoJSON</td><td class=CDLDescription>a feature collection as GeoJSON string</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.addFeature"></a>addFeature</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Add a feature to the geometry array</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>geoJSON</td><td class=CDLDescription>a feature as GeoJSON string</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.deleteFeatureCollection"></a>deleteFeatureCollection</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Delete the feature collection (= clear)</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.deleteFeature"></a>deleteFeature</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Delete a feature from the geometry array</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>index</td><td class=CDLDescription>an index of the geometry array</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.updateFeature"></a>updateFeature</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Replace a feature in the geometry array</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>index</td><td class=CDLDescription>index of the feature that is replaced</td></tr><tr><td class=CDLEntry>geoJSON</td><td class=CDLDescription>a feature as GeoJSON string</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.setFeatureProperty"></a>setFeatureProperty</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Set a property of a feature in the geometry array</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>index</td><td class=CDLDescription>index of the feature</td></tr><tr><td class=CDLEntry>pName</td><td class=CDLDescription>property name</td></tr><tr><td class=CDLEntry>pValue</td><td class=CDLDescription>new property value</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.getFeatureProperty"></a>getFeatureProperty</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Get a property of a feature in the geometry array</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>index</td><td class=CDLDescription>index of the feature</td></tr><tr><td class=CDLEntry>pName</td><td class=CDLDescription>property name</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="ResultGeometryListModel.getFeature"></a>getFeature</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Get a feature in the geometry array</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>index</td><td class=CDLDescription>index of the feature</td></tr></table></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile id=MSelected>ResultGeometryListModel</div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deleteFeatureCollection = function ()</td></tr></table></blockquote>Delete the feature collection (= clear)</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.deleteFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Delete a feature from the geometry array</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
Property changes on: trunk/mapbender/documents/api_js/files/lib/resultGeometryListModel-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html
--- trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,83 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>inspire_md_data</title><link rel="stylesheet" type="text/css" href="../../../../../../styles/main.css"><script language=JavaScript src="../../../../../../javascript/main.js"></script><script language=JavaScript src="../../../../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CDatabaseTable"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="inspire_md_data"></a>inspire_md_data</h1><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#inspire_md_data" >inspire_md_data</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#conformity" >conformity</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#conformity" >conformity</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#conformity_relation" >conformity_relation</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#custom_category" >custom_category</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#layer_custom_category" >layer_custom_category</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#wfs_featuretype_custom_category" >wfs_featuretype_custom_category</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#inspire_category" >inspire_category</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#inspire_category" >inspire_category</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#layer_inspire_category" >layer_inspire_category</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#wfs_featuretype_inspire_category" >wfs_featuretype_inspire_category</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#wfs_featuretype_md_topic_category" >wfs_featuretype_md_topic_category</a></td><td class=SDescription></td></tr><tr class="SDatabaseView"><td class=SEntry><a href="#registrating_groups" >registrating_groups</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#registrating_groups.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#registrating_groups.f_getwfs_tou(integer)" >f_getwfs_tou(integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#registrating_groups.f_getwms_tou(integer)" >f_getwms_tou(integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#registrating_groups.f_collect_epsg(integer)" >f_collect_epsg(integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#registrating_groups.f_layer_load_count(integer)" >f_layer_load_count(integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#registrating_groups.f_collect_searchtext(integer,integer)" >f_collect_searchtext(integer, integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#registrating_groups.f_collect_searchtext_wfs(integer,integer)" >f_collect_searchtext_wfs(integer, integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#registrating_groups.f_getwfsmodultype(integer)" >f_getwfsmodultype(integer)</a></td><td class=SDescription></td></tr><tr class="SDatabaseView"><td class=SEntry><a href="#search_wms_view" >search_wms_view</a></td><td class=SDescription></td></tr><tr class="SDatabaseView"><td class=SEntry><a href="#search_wfs_view" >search_wfs_view</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="conformity"></a>conformity</h2><div class=CBody></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="conformity_relation"></a>conformity_relation</h2><div class=CBody></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="custom_category"></a>custom_category</h2><div class=CBody></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="layer_custom_category"></a>layer_custom_category</h2><div class=CBody></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="wfs_featuretype_custom_category"></a>wfs_featuretype_custom_category</h2><div class=CBody></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="inspire_category"></a>inspire_category</h2><div class=CBody></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="layer_inspire_category"></a>layer_inspire_category</h2><div class=CBody></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="wfs_featuretype_inspire_category"></a>wfs_featuretype_inspire_category</h2><div class=CBody></div></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="wfs_featuretype_md_topic_category"></a>wfs_featuretype_md_topic_category</h2><div class=CBody></div></div></div>
+<div class="CDatabaseView"><div class=CTopic><h2 class=CTitle><a name="registrating_groups"></a>registrating_groups</h2><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#registrating_groups.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#registrating_groups.f_getwfs_tou(integer)" >f_getwfs_tou(integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#registrating_groups.f_getwms_tou(integer)" >f_getwms_tou(integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#registrating_groups.f_collect_epsg(integer)" >f_collect_epsg(integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#registrating_groups.f_layer_load_count(integer)" >f_layer_load_count(integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#registrating_groups.f_collect_searchtext(integer,integer)" >f_collect_searchtext(integer, integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#registrating_groups.f_collect_searchtext_wfs(integer,integer)" >f_collect_searchtext_wfs(integer, integer)</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#registrating_groups.f_getwfsmodultype(integer)" >f_getwfsmodultype(integer)</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="registrating_groups.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="registrating_groups.f_getwfs_tou(integer)"></a>f_getwfs_tou(integer)</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="registrating_groups.f_getwms_tou(integer)"></a>f_getwms_tou(integer)</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="registrating_groups.f_collect_epsg(integer)"></a>f_collect_epsg(integer)</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="registrating_groups.f_layer_load_count(integer)"></a>f_layer_load_count(integer)</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="registrating_groups.f_collect_searchtext(integer,integer)"></a>f_collect_searchtext(integer, integer)</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="registrating_groups.f_collect_searchtext_wfs(integer,integer)"></a>f_collect_searchtext_wfs(integer, integer)</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="registrating_groups.f_getwfsmodultype(integer)"></a>f_getwfsmodultype(integer)</h3></div></div>
+<div class="CDatabaseView"><div class=CTopic><h2 class=CTitle><a name="search_wms_view"></a>search_wms_view</h2><div class=CBody></div></div></div>
+<div class="CDatabaseView"><div class=CTopic><h2 class=CTitle><a name="search_wfs_view"></a>search_wfs_view</h2><div class=CBody></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../../../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile id=MSelected>inspire_md_data</div></div><div class=MEntry><div class=MFile><a href="update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../../sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../../../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+HideAllBut([5, 6, 4, 3], 8);// --></script></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html
--- trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,59 @@
+<html><head><title>/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql</title><link rel="stylesheet" type="text/css" href="../../../../../../styles/main.css"><script language=JavaScript src="../../../../../../javascript/main.js"></script><script language=JavaScript src="../../../../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CFile"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql"></a>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</h1><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql" >update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></td><td class=SDescription></td></tr><tr class="SGroup"><td class=SEntry><a href="#Database_Indexes" >Database Indexes</a></td><td class=SDescription></td></tr><tr class="SDatabaseIndex SIndent1 SMarked"><td class=SEntry><a href="#idx_mb_monitor_upload_id" >idx_mb_monitor_upload_id</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#mb_wms_availability" >mb_wms_availability</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#mb_wms_availability.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#mb_wms_availability.mb_monitor_after" >mb_monitor_after()</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#mb_wms_availability.Database_Triggers" >Database Triggers</a></td><td class=SDescription></td></tr><tr class="SDatabaseTrigger SIndent2 SMarked"><td class=SEntry><a href="#mb_wms_availability.mb_monitor_after_on_mb_monitor" >mb_monitor_after on mb_monitor</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#mb_user_abo_ows" >mb_user_abo_ows</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#mb_user_abo_ows.Database_Indexes" >Database Indexes</a></td><td class=SDescription></td></tr><tr class="SDatabaseIndex SIndent2 SMarked"><td class=SEntry><a href="#mb_user_abo_ows.idx_wms_id" >idx_wms_id</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Database_Indexes"></a>Database Indexes</h3></div></div>
+<div class="CDatabaseIndex"><div class=CTopic><h3 class=CTitle><a name="idx_mb_monitor_upload_id"></a>idx_mb_monitor_upload_id</h3></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="mb_wms_availability"></a>mb_wms_availability</h2><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#mb_wms_availability.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#mb_wms_availability.mb_monitor_after" >mb_monitor_after()</a></td><td class=SDescription></td></tr><tr class="SGroup"><td class=SEntry><a href="#mb_wms_availability.Database_Triggers" >Database Triggers</a></td><td class=SDescription></td></tr><tr class="SDatabaseTrigger SIndent1 SMarked"><td class=SEntry><a href="#mb_wms_availability.mb_monitor_after_on_mb_monitor" >mb_monitor_after on mb_monitor</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="mb_wms_availability.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="mb_wms_availability.mb_monitor_after"></a>mb_monitor_after()</h3></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="mb_wms_availability.Database_Triggers"></a>Database Triggers</h3></div></div>
+<div class="CDatabaseTrigger"><div class=CTopic><h3 class=CTitle><a name="mb_wms_availability.mb_monitor_after_on_mb_monitor"></a>mb_monitor_after on mb_monitor</h3></div></div>
+<div class="CDatabaseTable"><div class=CTopic><h2 class=CTitle><a name="mb_user_abo_ows"></a>mb_user_abo_ows</h2><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#mb_user_abo_ows.Database_Indexes" >Database Indexes</a></td><td class=SDescription></td></tr><tr class="SDatabaseIndex SIndent1 SMarked"><td class=SEntry><a href="#mb_user_abo_ows.idx_wms_id" >idx_wms_id</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="mb_user_abo_ows.Database_Indexes"></a>Database Indexes</h3></div></div>
+<div class="CDatabaseIndex"><div class=CTopic><h3 class=CTitle><a name="mb_user_abo_ows.idx_wms_id"></a>idx_wms_id</h3></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../../../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile id=MSelected>pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</div></div><div class=MEntry><div class=MFile><a href="../../../sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../../../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/resources/db/sql_updates_monitoring-sql.html
--- trunk/mapbender/documents/api_js/files/resources/db/sql_updates_monitoring-sql.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/resources/db/sql_updates_monitoring-sql.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,55 @@
+<html><head><title>/home/cbaudson/workspace/trunk/resources/db/sql_updates_monitoring.sql</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CFile"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="sql_updates_monitoring.sql"></a>sql_updates_monitoring.sql</h1><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#sql_updates_monitoring.sql" >sql_updates_monitoring.sql</a></td><td class=SDescription></td></tr><tr class="SGroup"><td class=SEntry><a href="#Database_Indexes" >Database Indexes</a></td><td class=SDescription></td></tr><tr class="SDatabaseIndex SIndent1 SMarked"><td class=SEntry><a href="#idx_mb_monitor_status" >idx_mb_monitor_status</a></td><td class=SDescription></td></tr><tr class="SDatabaseIndex SIndent1"><td class=SEntry><a href="#idx_mb_monitor_upload_id" >idx_mb_monitor_upload_id</a></td><td class=SDescription></td></tr><tr class="SDatabaseTable"><td class=SEntry><a href="#mb_wms_availability" >mb_wms_availability</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#mb_wms_availability.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#mb_wms_availability.mb_monitor_after" >mb_monitor_after()</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#mb_wms_availability.Database_Triggers" >Database Triggers</a></td><td class=SDescription></td></tr><tr class="SDatabaseTrigger SIndent2 SMarked"><td class=SEntry><a href="#mb_wms_availability.mb_monitor_after_on_mb_monitor" >mb_monitor_after on mb_monitor</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CDatabaseIndex"><div class=CTopic><h3 class=CTitle><a name="idx_mb_monitor_status"></a>idx_mb_monitor_status</h3></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile id=MSelected>sql_updates_monitoring.sql</div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../test/tools/env-js/src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
Property changes on: trunk/mapbender/documents/api_js/files/resources/db/sql_updates_monitoring-sql.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html
--- trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,45 @@
+<html><head><title>/home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.1.1.rc2.js</title><link rel="stylesheet" type="text/css" href="../../../../../../../styles/main.css"><script language=JavaScript src="../../../../../../../javascript/main.js"></script><script language=JavaScript src="../../../../../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CFile"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="env.1.1.rc2.js"></a>env.<wbr>1.1.<wbr>rc2.js</h1><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#env.1.1.rc2.js" >env.<wbr>1.1.<wbr>rc2.js</a></td><td class=SDescription></td></tr><tr class="SGroup"><td class=SEntry><a href="#Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#this_is_the_constructor_to_the_XMLP_Object" >this is the constructor to the XMLP Object</a></td><td class=SDescription>Author: Scott Severtson Description:XMLP is a pull-based parser. </td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#SAXDriver" >SAXDriver</a></td><td class=SDescription>Author: Scott Severtson Description: SAXDriver is an object that basically wraps an XMLP instance, and provides an event-based interface for parsing. </td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="this_is_the_constructor_to_the_XMLP_Object"></a>this is the constructor to the XMLP Object</h3><div class=CBody><p>Author: Scott Severtson Description:XMLP is a pull-based parser. The calling application passes in a XML string to the constructor, then repeatedly calls .next() to parse the next segment. .next() returns a flag indicating what type of segment was found, and stores data temporarily in couple member variables (name, content, array of attributes), which can be accessed by several .get____() methods.</p><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>Basically, XMLP is the lowest common denominator parser</td><td class=CDLDescription>an very simple API which other wrappers can be built against.</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SAXDriver"></a>SAXDriver</h3><div class=CBody><p>Author: Scott Severtson Description: SAXDriver is an object that basically wraps an XMLP instance, and provides an event-based interface for parsing. This is the object users interact with when coding with XML for <SCRIPT></p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../../../../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../../../../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile id=MSelected>dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</div></div><div class=MEntry><div class=MFile><a href="env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../../../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../../../../../search");
+HideAllBut([6, 7, 5], 8);// --></script></div><!--Menu-->
Property changes on: trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-1-1-rc2-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html
--- trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,45 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>/home/cbaudson/workspace/trunk/test/tools/env-js/dist/releases/1.1.rc2/env.rhino.1.1.rc2.js</title><link rel="stylesheet" type="text/css" href="../../../../../../../styles/main.css"><script language=JavaScript src="../../../../../../../javascript/main.js"></script><script language=JavaScript src="../../../../../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!-- Generated by Natural Docs, version 1.4 -->
+<!-- http://www.naturaldocs.org -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CFile"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="env.rhino.1.1.rc2.js"></a>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</h1><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#env.rhino.1.1.rc2.js" >env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></td><td class=SDescription></td></tr><tr class="SGroup"><td class=SEntry><a href="#Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#this_is_the_constructor_to_the_XMLP_Object" >this is the constructor to the XMLP Object</a></td><td class=SDescription>Author: Scott Severtson Description:XMLP is a pull-based parser. </td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#SAXDriver" >SAXDriver</a></td><td class=SDescription>Author: Scott Severtson Description: SAXDriver is an object that basically wraps an XMLP instance, and provides an event-based interface for parsing. </td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../../../../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../../../../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile id=MSelected>dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</div></div><div class=MEntry><div class=MFile><a href="../../../src/css/jss-0-4/js/jquery-js.html">src/.../js/<wbr>jquery.js</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../../../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Property changes on: trunk/mapbender/documents/api_js/files/test/tools/env-js/dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html
+ text/html
Added: trunk/mapbender/documents/api_js/files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html
--- trunk/mapbender/documents/api_js/files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html (rev 0)
+++ trunk/mapbender/documents/api_js/files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html 2010-02-24 16:19:38 UTC (rev 5641)
@@ -0,0 +1,55 @@
+<html><head><title>/home/cbaudson/workspace/trunk/test/tools/env-js/src/css/jss-0-4/js/jquery.js</title><link rel="stylesheet" type="text/css" href="../../../../../../../../styles/main.css"><script language=JavaScript src="../../../../../../../../javascript/main.js"></script><script language=JavaScript src="../../../../../../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CFile"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="jquery.js"></a>jquery.js</h1><div class=CBody><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#jquery.js" >jquery.js</a></td><td class=SDescription></td></tr><tr class="SGroup"><td class=SEntry><a href="#Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent1 SMarked"><td class=SEntry><a href="#$(html).$(array)" >$(html) -> $(array)</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent1"><td class=SEntry><a href="#$(#id)" >$(“#id”)</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent1 SMarked"><td class=SEntry><a href="#$(expr)" >$(expr)</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent1"><td class=SEntry><a href="#$(function)" >$(function)</a></td><td class=SDescription>Shortcut for document ready</td></tr><tr class="SVariable SIndent1 SMarked"><td class=SEntry><a href="#$(array)" >$(array)</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent1"><td class=SEntry><a href="#$(arraylike)" >$(arraylike)</a></td><td class=SDescription>Watch for when an array-like object is passed as the selector</td></tr><tr class="SVariable SIndent1 SMarked"><td class=SEntry><a href="#$(*)" >$(*)</a></td><td class=SDescription></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Variables"></a>Variables</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="$(html).$(array)"></a>$(html) -> $(array)</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="$(#id)"></a>$(“#id”)</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="$(expr)"></a>$(expr)</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="$(function)"></a>$(function)</h3><div class=CBody><p>Shortcut for document ready</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="$(array)"></a>$(array)</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="$(arraylike)"></a>$(arraylike)</h3><div class=CBody><p>Watch for when an array-like object is passed as the selector</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="$(*)"></a>$(*)</h3></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Http</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Javascripts</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_firebug_lite-js.html">firebug_lite</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_wfs_gazetteer_client-php.html">gazetteerWFS</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/jq_jgrowl-js.html">jq_jgrowl</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/jq_ui_effects-php.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_ResultList-js.html">resultList</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/javascripts/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Plugins</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/ol_wms-php.html"><Application element name></a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_cookie-js.html">cookie</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_i18n-js.html">i18n</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/jq_datatables-js.html">jq_datatables</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/jq_ui_accordion-js.html">jq_ui_accordion</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/jq_ui_effects-js.html">jq_ui_effects</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/jq_ui_resizable-js.html">jq_ui_resizable</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_map-js.html">mapframe1</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_navigation-js.html">mb_navigation</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_resultList_transferToDigitize-js.html">mb_resultList_transferToDigitize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_zoomIn-js.html">mb_zoomIn</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_zoomOut-js.html">mb_zoomOut</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/ol-js.html">ol</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/ol_keyboardDefaults-js.html">ol_keyboardDefaults</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/ol_layerSwitch-js.html">ol_layerSwitch</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/ol_mousePosition-js.html">ol_mousePosition</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/ol_overview-js.html">ol_overviewMap</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/ol_panZoomBar-js.html">ol_panZoomBar</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_print-js.html">printPDF</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_resize-js.html">resize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_selectMapsize-js.html">selectMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_tabs_vertical-js.html">tabs_vertical</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_twitter_signin-js.html">twitter_signin</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_wmsTimeInterval-js.html">wmsTimeInterval</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../http/plugins/mb_wmsTimeSliderYear-js.html">wmsTimeSliderYear</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent4')">Lib</a><div class=MGroupContent id=MGroupContent4><div class=MEntry><div class=MFile><a href="../../../../../../../lib/ajax-js.html">Ajax</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/button-js.html">Button</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/exception-js.html">Exception</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/extent-js.html">Extent</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/list-js.html">List</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/basic-js.html">mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/marker-js.html">Mapbender.<wbr>Marker</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/point-js.html">Point</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/resultGeometryListController-js.html">resultGeometryListController.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../lib/resultGeometryListModel-js.html">ResultGeometryListModel</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent5')">Resources</a><div class=MGroupContent id=MGroupContent5><div class=MEntry><div class=MFile><a href="../../../../../../../resources/db/pgsql/UTF-8/update/metadata_pgsql_UTF-8-sql.html">inspire_md_data</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../resources/db/pgsql/UTF-8/update/update_2-6-1_to_2-7rc1_pgsql_UTF-8-sql.html">pgsql/.../update/<wbr>update_2.<wbr>6.1_to_2.<wbr>7rc1_pgsql_UTF-8.sql</a></div></div><div class=MEntry><div class=MFile><a href="../../../../../../../resources/db/sql_updates_monitoring-sql.html">sql_updates_monitoring.sql</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent6')">Test</a><div class=MGroupContent id=MGroupContent6><div class=MEntry><div class=MFile><a href="../../../../dist/releases/1-1-rc2/env-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile><a href="../../../../dist/releases/1-1-rc2/env-rhino-1-1-rc2-js.html">dist/.../1.<wbr>1.rc2/<wbr>env.<wbr>rhino.<wbr>1.1.<wbr>rc2.js</a></div></div><div class=MEntry><div class=MFile id=MSelected>src/.../js/<wbr>jquery.js</div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent7')">Index</a><div class=MGroupContent id=MGroupContent7><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/Properties.html">Properties</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/Files.html">Files</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/DatabaseIndexes.html">Database Indexes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/DatabaseTables.html">Database Tables</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/DatabaseTriggers.html">Database Triggers</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/DatabaseViews.html">Database Views</a></div></div><div class=MEntry><div class=MIndex><a href="../../../../../../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../../../../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="DatabaseIndexes">Database Indexes</option><option value="DatabaseTables">Database Tables</option><option value="DatabaseTriggers">Database Triggers</option><option value="DatabaseViews">Database Views</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Properties">Properties</option><option value="Variables">Variables</option></select></div><script language=JavaScript><!--
+<!--START_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/files/test/tools/env-js/src/css/jss-0-4/js/jquery-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
More information about the Mapbender_commits
