[Mapbender-commits] r6594 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Tue Jul 13 07:53:15 EDT 2010
Author: christoph
Date: 2010-07-13 11:53:15 +0000 (Tue, 13 Jul 2010)
New Revision: 6594
trunk/mapbender/http/classes/class_user.php
refactoring, code conventions
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php 2010-07-13 11:46:37 UTC (rev 6593)
+++ trunk/mapbender/http/classes/class_user.php 2010-07-13 11:53:15 UTC (rev 6594)
@@ -150,35 +150,34 @@
public function create() {
- if($this->name == ""){ $e = new Exception("Can' t create user without name");}
+ if ($this->name === "") {
+ $e = new Exception("Can' t create user without name");
- $sql_user_create = "INSERT INTO mb_user (mb_user_name) VALUES ('". $this->name ."');";
+ $sql_user_create = "INSERT INTO mb_user (mb_user_name) VALUES ('" .
+ $this->name ."');";
$v = array($this->name);
$t = array("s");
db_begin();
$insert_result = db_query($sql_user_create);
- if($insert_result == false)
+ if($insert_result == false) {
db_rollback();
throw new Exception("Could not insert new user");
$id = db_insertid($insert_result,'mb_user','mb_user_id');
- if($id != 0)
+ if ($id != 0) {
$this->id = $id;
$commit_result = $this->commit();
- if($commit_result == false)
+ if($commit_result == false) {
try {
db_rollback();
- catch(Exception $E)
+ catch(Exception $E) {
throw new Exception("Could not set inital values of new user");
@@ -192,8 +191,7 @@
public function change($changes) {
//FIXME: validate input
- if($changes->owner)
+ if($changes->owner) {
$owner = User::byName($changes->owner);
$this->name = $changes->name ? $changes->name : $this->name;
@@ -325,8 +323,8 @@
$v = array($this->id);
$t = array("i");
$res_user = db_prep_query($sql_user,$v,$t);
- if($row = db_fetch_array($res_user)){
+ if ($row = db_fetch_array($res_user)) {
$this->name = $row['mb_user_name'];
$this->owner = $row['mb_user_owner'];
$this->description = $row['mb_user_description'];
@@ -358,6 +356,7 @@
else {
throw new Exception("no such User");
+ return false;
return true;
@@ -381,6 +380,7 @@
else {
throw new Exception("Database error validating user ticket.");
+ return false;
return true;
@@ -399,6 +399,7 @@
if (!$update_result) {
throw new Exception("Database error updating user password");
+ return false;
return true;
More information about the Mapbender_commits
