[Mapbender-commits] r6595 -
trunk/mapbender/http/extensions/RaphaelJS
svn_mapbender at osgeo.org
Tue Jul 13 09:08:43 EDT 2010
Author: topi
Date: 2010-07-13 13:08:43 +0000 (Tue, 13 Jul 2010)
New Revision: 6595
Added:
trunk/mapbender/http/extensions/RaphaelJS/raphael-1.4.7.min.js
latest version
Added: trunk/mapbender/http/extensions/RaphaelJS/raphael-1.4.7.min.js
--- trunk/mapbender/http/extensions/RaphaelJS/raphael-1.4.7.min.js (rev 0)
+++ trunk/mapbender/http/extensions/RaphaelJS/raphael-1.4.7.min.js 2010-07-13 13:08:43 UTC (rev 6595)
@@ -0,0 +1,116 @@
+ * Raphael 1.4.7 - JavaScript Vector Library
+ * Copyright (c) 2010 Dmitry Baranovskiy (http://raphaeljs.com)
+ * Licensed under the MIT (http://www.opensource.org/licenses/mit-license.php) license.
+Raphael=function(){function l(){if(l.is(arguments[0],U)){for(var a=arguments[0],b=Ca[K](l,a.splice(0,3+l.is(a[0],P))),c=b.set(),d=0,f=a[o];d<f;d++){var e=a[d]||{};sb.test(e.type)&&c[F](b[e.type]().attr(e))}return c}return Ca[K](l,arguments)}l.version="1.4.7";var V=/[, ]+/,sb=/^(circle|rect|path|ellipse|text|image)$/,p="prototype",z="hasOwnProperty",C=document,aa=window,Qa={was:Object[p][z].call(aa,"Raphael"),is:aa.Raphael};function H(){}var x="appendChild",K="apply",M="concat",Da="createTouch"in C,
+A="",N=" ",D=String,G="split",Ra="click dblclick mousedown mousemove mouseout mouseover mouseup touchstart touchmove touchend orientationchange touchcancel gesturestart gesturechange gestureend"[G](N),Ea={mousedown:"touchstart",mousemove:"touchmove",mouseup:"touchend"},R="join",o="length",fa=String[p].toLowerCase,v=Math,Y=v.max,ba=v.min,P="number",ga="string",U="array",O="toString",ca="fill",tb=Object[p][O],E=v.pow,F="push",ja=/^(?=[\da-f]$)/,Sa=/^url\(['"]?([^\)]+?)['"]?\)$/i,ub=/^\s*((#[a-f\d]{6})|(#[a-f\d]{3})|rgba?\(\s*([\d\.]+\s*,\s*[\d\.]+\s*,\s*[\d\.]+(?:\s*,\s*[\d\.]+)?)\s*\)|rgba?\(\s*([\d\.]+%\s*,\s*[\d\.]+%\s*,\s*[\d\.]+%(?:\s*,\s*[\d\.]+%)?)\s*\)|hsb\(\s*([\d\.]+(?:deg|\xb0)?\s*,\s*[\d\.]+\s*,\s*[\d\.]+)\s*\)|hsb\(\s*([\d\.]+(?:deg|\xb0|%)\s*,\s*[\d\.]+%\s*,\s*[\d\.]+%)\s*\)|hsl\(\s*([\d\.]+(?:deg|\xb0)?\s*,\s*[\d\.]+\s*,\s*[\d\.]+)\s*\)|hsl\(\s*([\d\.]+(?:deg|\xb0|%)\s*,\s*[\d\.]+%\s*,\s*[\d\.]+%)\s*\))\s*$/i,
+Q=v.round,W="setAttribute",y=parseFloat,ha=parseInt,Fa=" progid:DXImageTransform.Microsoft",sa=String[p].toUpperCase,ta={blur:0,"clip-rect":"0 0 1e9 1e9",cursor:"default",cx:0,cy:0,fill:"#fff","fill-opacity":1,font:'10px "Arial"',"font-family":'"Arial"',"font-size":"10","font-style":"normal","font-weight":400,gradient:0,height:0,href:"http://raphaeljs.com/",opacity:1,path:"M0,0",r:0,rotation:0,rx:0,ry:0,scale:"1 1",src:"",stroke:"#000","stroke-dasharray":"","stroke-linecap":"butt","stroke-linejoin":"butt",
+"stroke-miterlimit":0,"stroke-opacity":1,"stroke-width":1,target:"_blank","text-anchor":"middle",title:"Raphael",translation:"0 0",width:0,x:0,y:0},Ga={along:"along",blur:P,"clip-rect":"csv",cx:P,cy:P,fill:"colour","fill-opacity":P,"font-size":P,height:P,opacity:P,path:"path",r:P,rotation:"csv",rx:P,ry:P,scale:"csv",stroke:"colour","stroke-opacity":P,"stroke-width":P,translation:"csv",width:P,x:P,y:P},I="replace";l.type=aa.SVGAngle||C.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#BasicStructure",
+"1.1")?"SVG":"VML";if(l.type=="VML"){var da=C.createElement("div");da.innerHTML='<v:shape adj="1"/>';da=da.firstChild;da.style.behavior="url(#default#VML)";if(!(da&&typeof da.adj=="object"))return l.type=null;da=null}l.svg=!(l.vml=l.type=="VML");H[p]=l[p];l._id=0;l._oid=0;l.fn={};l.is=function(a,b){b=fa.call(b);return b=="object"&&a===Object(a)||b=="undefined"&&typeof a==b||b=="null"&&a==null||b=="array"&&Array.isArray&&Array.isArray(a)||fa.call(tb.call(a).slice(8,-1))==b};l.setWindow=function(a){aa=
+a;C=aa.document};function ua(a){if(l.vml){var b=/^\s+|\s+$/g;ua=Z(function(d){var f;d=D(d)[I](b,A);try{var e=new aa.ActiveXObject("htmlfile");e.write("<body>");e.close();f=e.body}catch(g){f=aa.createPopup().document.body}e=f.createTextRange();try{f.style.color=d;var h=e.queryCommandValue("ForeColor");h=(h&255)<<16|h&65280|(h&16711680)>>>16;return"#"+("000000"+h[O](16)).slice(-6)}catch(i){return"none"}})}else{var c=C.createElement("i");c.title="Rapha\u00ebl Colour Picker";c.style.display="none";C.body[x](c);
+ua=Z(function(d){c.style.color=d;return C.defaultView.getComputedStyle(c,A).getPropertyValue("color")})}return ua(a)}function Ta(){return"hsb("+[this.h,this.s,this.b]+")"}function vb(){return"hsl("+[this.h,this.s,this.l]+")"}function wb(){return this.hex}l.hsb2rgb=function(a,b,c){if(l.is(a,"object")&&"h"in a&&"s"in a&&"b"in a){c=a.b;b=a.s;a=a.h}return l.hsl2rgb(a,b,c/2)};l.hsl2rgb=function(a,b,c){if(l.is(a,"object")&&"h"in a&&"s"in a&&"l"in a){c=a.l;b=a.s;a=a.h}if(a>1||b>1||c>1){a/=255;b/=255;c/=
+255}var d={},f=["r","g","b"],e;if(b){b=c<0.5?c*(1+b):c+b-c*b;c=2*c-b;for(var g=0,h=f.length;g<h;g++){e=a+1/3*-(g-1);e<0&&e++;e>1&&e--;d[f[g]]=e*6<1?c+(b-c)*6*e:e*2<1?b:e*3<2?c+(b-c)*(2/3-e)*6:c}}else d={r:c,g:c,b:c};d.r*=255;d.g*=255;d.b*=255;a=(~~d.r)[O](16);f=(~~d.g)[O](16);b=(~~d.b)[O](16);a=a[I](ja,"0");f=f[I](ja,"0");b=b[I](ja,"0");d.hex="#"+a+f+b;d.toString=wb;return d};l.rgb2hsb=function(a,b,c){if(b==null&&l.is(a,"object")&&"r"in a&&"g"in a&&"b"in a){c=a.b;b=a.g;a=a.r}if(b==null&&l.is(a,ga)){var d=
+l.getRGB(a);a=d.r;b=d.g;c=d.b}if(a>1||b>1||c>1){a/=255;b/=255;c/=255}var f=Y(a,b,c),e=ba(a,b,c);d=f;if(e==f)return{h:0,s:0,b:f,toString:Ta};else{var g=f-e;e=g/f;a=a==f?(b-c)/g:b==f?2+(c-a)/g:4+(a-b)/g;a/=6;a<0&&a++;a>1&&a--}return{h:a,s:e,b:d,toString:Ta}};l.rgb2hsl=function(a,b,c){if(b==null&&l.is(a,"object")&&"r"in a&&"g"in a&&"b"in a){c=a.b;b=a.g;a=a.r}if(b==null&&l.is(a,ga)){var d=l.getRGB(a);a=d.r;b=d.g;c=d.b}if(a>1||b>1||c>1){a/=255;b/=255;c/=255}var f=Y(a,b,c),e=ba(a,b,c);d=(f+e)/2;if(e==f)a=
+{h:0,s:0,l:d};else{var g=f-e;e=d<0.5?g/(f+e):g/(2-f-e);a=a==f?(b-c)/g:b==f?2+(c-a)/g:4+(a-b)/g;a/=6;a<0&&a++;a>1&&a--;a={h:a,s:e,l:d}}a.toString=vb;return a};var xb=/,?([achlmqrstvxz]),?/gi,ka=/\s*,\s*/,yb={hs:1,rg:1};l._path2string=function(){return this.join(",")[I](xb,"$1")};function Z(a,b,c){function d(){var f=Array[p].slice.call(arguments,0),e=f[R]("\u25ba"),g=d.cache=d.cache||{},h=d.count=d.count||[];if(g[z](e))return c?c(g[e]):g[e];h[o]>=1000&&delete g[h.shift()];h[F](e);g[e]=a[K](b,f);return c?
+c(g[e]):g[e]}return d}l.getRGB=Z(function(a){if(!a||(a=D(a)).indexOf("-")+1)return{r:-1,g:-1,b:-1,hex:"none",error:1};if(a=="none")return{r:-1,g:-1,b:-1,hex:"none"};!(yb[z](a.substring(0,2))||a.charAt()=="#")&&(a=ua(a));var b,c,d,f,e;if(a=a.match(ub)){if(a[2]){d=ha(a[2].substring(5),16);c=ha(a[2].substring(3,5),16);b=ha(a[2].substring(1,3),16)}if(a[3]){d=ha((e=a[3].charAt(3))+e,16);c=ha((e=a[3].charAt(2))+e,16);b=ha((e=a[3].charAt(1))+e,16)}if(a[4]){a=a[4][G](ka);b=y(a[0]);c=y(a[1]);d=y(a[2]);f=y(a[3])}if(a[5]){a=
+a[5][G](ka);b=y(a[0])*2.55;c=y(a[1])*2.55;d=y(a[2])*2.55;f=y(a[3])}if(a[6]){a=a[6][G](ka);b=y(a[0]);c=y(a[1]);d=y(a[2]);(a[0].slice(-3)=="deg"||a[0].slice(-1)=="\u00b0")&&(b/=360);return l.hsb2rgb(b,c,d)}if(a[7]){a=a[7][G](ka);b=y(a[0])*2.55;c=y(a[1])*2.55;d=y(a[2])*2.55;(a[0].slice(-3)=="deg"||a[0].slice(-1)=="\u00b0")&&(b/=360*2.55);return l.hsb2rgb(b,c,d)}if(a[8]){a=a[8][G](ka);b=y(a[0]);c=y(a[1]);d=y(a[2]);(a[0].slice(-3)=="deg"||a[0].slice(-1)=="\u00b0")&&(b/=360);return l.hsl2rgb(b,c,d)}if(a[9]){a=
+a[9][G](ka);b=y(a[0])*2.55;c=y(a[1])*2.55;d=y(a[2])*2.55;(a[0].slice(-3)=="deg"||a[0].slice(-1)=="\u00b0")&&(b/=360*2.55);return l.hsl2rgb(b,c,d)}a={r:b,g:c,b:d};b=(~~b)[O](16);c=(~~c)[O](16);d=(~~d)[O](16);b=b[I](ja,"0");c=c[I](ja,"0");d=d[I](ja,"0");a.hex="#"+b+c+d;isFinite(y(f))&&(a.o=f);return a}return{r:-1,g:-1,b:-1,hex:"none",error:1}},l);l.getColor=function(a){a=this.getColor.start=this.getColor.start||{h:0,s:1,b:a||0.75};var b=this.hsb2rgb(a.h,a.s,a.b);a.h+=0.075;if(a.h>1){a.h=0;a.s-=0.2;
+a.s<=0&&(this.getColor.start={h:0,s:1,b:a.b})}return b.hex};l.getColor.reset=function(){delete this.start};var zb=/([achlmqstvz])[\s,]*((-?\d*\.?\d*(?:e[-+]?\d+)?\s*,?\s*)+)/ig,Ab=/(-?\d*\.?\d*(?:e[-+]?\d+)?)\s*,?\s*/ig;l.parsePathString=Z(function(a){if(!a)return null;var b={a:7,c:6,h:1,l:2,m:2,q:4,s:4,t:2,v:1,z:0},c=[];if(l.is(a,U)&&l.is(a[0],U))c=va(a);c[o]||D(a)[I](zb,function(d,f,e){var g=[];d=fa.call(f);e[I](Ab,function(h,i){i&&g[F](+i)});if(d=="m"&&g[o]>2){c[F]([f][M](g.splice(0,2)));d="l";
+f=f=="m"?"l":"L"}for(;g[o]>=b[d];){c[F]([f][M](g.splice(0,b[d])));if(!b[d])break}});c[O]=l._path2string;return c});l.findDotsAtSegment=function(a,b,c,d,f,e,g,h,i){var j=1-i,m=E(j,3)*a+E(j,2)*3*i*c+j*3*i*i*f+E(i,3)*g;j=E(j,3)*b+E(j,2)*3*i*d+j*3*i*i*e+E(i,3)*h;var n=a+2*i*(c-a)+i*i*(f-2*c+a),r=b+2*i*(d-b)+i*i*(e-2*d+b),q=c+2*i*(f-c)+i*i*(g-2*f+c),k=d+2*i*(e-d)+i*i*(h-2*e+d);a=(1-i)*a+i*c;b=(1-i)*b+i*d;f=(1-i)*f+i*g;e=(1-i)*e+i*h;h=90-v.atan((n-q)/(r-k))*180/v.PI;(n>q||r<k)&&(h+=180);return{x:m,y:j,
+m:{x:n,y:r},n:{x:q,y:k},start:{x:a,y:b},end:{x:f,y:e},alpha:h}};var xa=Z(function(a){if(!a)return{x:0,y:0,width:0,height:0};a=wa(a);for(var b=0,c=0,d=[],f=[],e,g=0,h=a[o];g<h;g++){e=a[g];if(e[0]=="M"){b=e[1];c=e[2];d[F](b);f[F](c)}else{b=Bb(b,c,e[1],e[2],e[3],e[4],e[5],e[6]);d=d[M](b.min.x,b.max.x);f=f[M](b.min.y,b.max.y);b=e[5];c=e[6]}}a=ba[K](0,d);e=ba[K](0,f);return{x:a,y:e,width:Y[K](0,d)-a,height:Y[K](0,f)-e}});function va(a){var b=[];if(!l.is(a,U)||!l.is(a&&a[0],U))a=l.parsePathString(a);for(var c=
+0,d=a[o];c<d;c++){b[c]=[];for(var f=0,e=a[c][o];f<e;f++)b[c][f]=a[c][f]}b[O]=l._path2string;return b}var Ha=Z(function(a){if(!l.is(a,U)||!l.is(a&&a[0],U))a=l.parsePathString(a);var b=[],c=0,d=0,f=0,e=0,g=0;if(a[0][0]=="M"){c=a[0][1];d=a[0][2];f=c;e=d;g++;b[F](["M",c,d])}g=g;for(var h=a[o];g<h;g++){var i=b[g]=[],j=a[g];if(j[0]!=fa.call(j[0])){i[0]=fa.call(j[0]);switch(i[0]){case "a":i[1]=j[1];i[2]=j[2];i[3]=j[3];i[4]=j[4];i[5]=j[5];i[6]=+(j[6]-c).toFixed(3);i[7]=+(j[7]-d).toFixed(3);break;case "v":i[1]=
++(j[1]-d).toFixed(3);break;case "m":f=j[1];e=j[2];default:for(var m=1,n=j[o];m<n;m++)i[m]=+(j[m]-(m%2?c:d)).toFixed(3)}}else{b[g]=[];if(j[0]=="m"){f=j[1]+c;e=j[2]+d}i=0;for(m=j[o];i<m;i++)b[g][i]=j[i]}j=b[g][o];switch(b[g][0]){case "z":c=f;d=e;break;case "h":c+=+b[g][j-1];break;case "v":d+=+b[g][j-1];break;default:c+=+b[g][j-2];d+=+b[g][j-1]}}b[O]=l._path2string;return b},0,va),oa=Z(function(a){if(!l.is(a,U)||!l.is(a&&a[0],U))a=l.parsePathString(a);var b=[],c=0,d=0,f=0,e=0,g=0;if(a[0][0]=="M"){c=
++a[0][1];d=+a[0][2];f=c;e=d;g++;b[0]=["M",c,d]}g=g;for(var h=a[o];g<h;g++){var i=b[g]=[],j=a[g];if(j[0]!=sa.call(j[0])){i[0]=sa.call(j[0]);switch(i[0]){case "A":i[1]=j[1];i[2]=j[2];i[3]=j[3];i[4]=j[4];i[5]=j[5];i[6]=+(j[6]+c);i[7]=+(j[7]+d);break;case "V":i[1]=+j[1]+d;break;case "H":i[1]=+j[1]+c;break;case "M":f=+j[1]+c;e=+j[2]+d;default:for(var m=1,n=j[o];m<n;m++)i[m]=+j[m]+(m%2?c:d)}}else{m=0;for(n=j[o];m<n;m++)b[g][m]=j[m]}switch(i[0]){case "Z":c=f;d=e;break;case "H":c=i[1];break;case "V":d=i[1];
+break;case "M":f=b[g][b[g][o]-2];e=b[g][b[g][o]-1];default:c=b[g][b[g][o]-2];d=b[g][b[g][o]-1]}}b[O]=l._path2string;return b},null,va);function ya(a,b,c,d){return[a,b,c,d,c,d]}function Ua(a,b,c,d,f,e){var g=1/3,h=2/3;return[g*a+h*c,g*b+h*d,g*f+h*c,g*e+h*d,f,e]}function Va(a,b,c,d,f,e,g,h,i,j){var m=v.PI,n=m*120/180,r=m/180*(+f||0),q=[],k,t=Z(function(J,ia,za){var Cb=J*v.cos(za)-ia*v.sin(za);J=J*v.sin(za)+ia*v.cos(za);return{x:Cb,y:J}});if(j){w=j[0];k=j[1];e=j[2];B=j[3]}else{k=t(a,b,-r);a=k.x;b=k.y;
+k=t(h,i,-r);h=k.x;i=k.y;v.cos(m/180*f);v.sin(m/180*f);k=(a-h)/2;w=(b-i)/2;B=k*k/(c*c)+w*w/(d*d);if(B>1){B=v.sqrt(B);c=B*c;d=B*d}B=c*c;var L=d*d;B=(e==g?-1:1)*v.sqrt(v.abs((B*L-B*w*w-L*k*k)/(B*w*w+L*k*k)));e=B*c*w/d+(a+h)/2;var B=B*-d*k/c+(b+i)/2,w=v.asin(((b-B)/d).toFixed(7));k=v.asin(((i-B)/d).toFixed(7));w=a<e?m-w:w;k=h<e?m-k:k;w<0&&(w=m*2+w);k<0&&(k=m*2+k);if(g&&w>k)w-=m*2;if(!g&&k>w)k-=m*2}m=k-w;if(v.abs(m)>n){q=k;m=h;L=i;k=w+n*(g&&k>w?1:-1);h=e+c*v.cos(k);i=B+d*v.sin(k);q=Va(h,i,c,d,f,0,g,m,
+L,[k,q,e,B])}m=k-w;f=v.cos(w);e=v.sin(w);g=v.cos(k);k=v.sin(k);m=v.tan(m/4);c=4/3*c*m;m=4/3*d*m;d=[a,b];a=[a+c*e,b-m*f];b=[h+c*k,i-m*g];h=[h,i];a[0]=2*d[0]-a[0];a[1]=2*d[1]-a[1];if(j)return[a,b,h][M](q);else{q=[a,b,h][M](q)[R]()[G](",");j=[];h=0;for(i=q[o];h<i;h++)j[h]=h%2?t(q[h-1],q[h],r).y:t(q[h],q[h+1],r).x;return j}}function la(a,b,c,d,f,e,g,h,i){var j=1-i;return{x:E(j,3)*a+E(j,2)*3*i*c+j*3*i*i*f+E(i,3)*g,y:E(j,3)*b+E(j,2)*3*i*d+j*3*i*i*e+E(i,3)*h}}var Bb=Z(function(a,b,c,d,f,e,g,h){var i=f-2*
+c+a-(g-2*f+c),j=2*(c-a)-2*(f-c),m=a-c,n=(-j+v.sqrt(j*j-4*i*m))/2/i;i=(-j-v.sqrt(j*j-4*i*m))/2/i;var r=[b,h],q=[a,g];v.abs(n)>1000000000000&&(n=0.5);v.abs(i)>1000000000000&&(i=0.5);if(n>0&&n<1){n=la(a,b,c,d,f,e,g,h,n);q[F](n.x);r[F](n.y)}if(i>0&&i<1){n=la(a,b,c,d,f,e,g,h,i);q[F](n.x);r[F](n.y)}i=e-2*d+b-(h-2*e+d);j=2*(d-b)-2*(e-d);m=b-d;n=(-j+v.sqrt(j*j-4*i*m))/2/i;i=(-j-v.sqrt(j*j-4*i*m))/2/i;v.abs(n)>1000000000000&&(n=0.5);v.abs(i)>1000000000000&&(i=0.5);if(n>0&&n<1){n=la(a,b,c,d,f,e,g,h,n);q[F](n.x);
+r[F](n.y)}if(i>0&&i<1){n=la(a,b,c,d,f,e,g,h,i);q[F](n.x);r[F](n.y)}return{min:{x:ba[K](0,q),y:ba[K](0,r)},max:{x:Y[K](0,q),y:Y[K](0,r)}}}),wa=Z(function(a,b){var c=oa(a),d=b&&oa(b);a={x:0,y:0,bx:0,by:0,X:0,Y:0,qx:null,qy:null};b={x:0,y:0,bx:0,by:0,X:0,Y:0,qx:null,qy:null};function f(q,k){var t;if(!q)return["C",k.x,k.y,k.x,k.y,k.x,k.y];!(q[0]in{T:1,Q:1})&&(k.qx=k.qy=null);switch(q[0]){case "M":k.X=q[1];k.Y=q[2];break;case "A":q=["C"][M](Va[K](0,[k.x,k.y][M](q.slice(1))));break;case "S":t=k.x+(k.x-
+(k.bx||k.x));k=k.y+(k.y-(k.by||k.y));q=["C",t,k][M](q.slice(1));break;case "T":k.qx=k.x+(k.x-(k.qx||k.x));k.qy=k.y+(k.y-(k.qy||k.y));q=["C"][M](Ua(k.x,k.y,k.qx,k.qy,q[1],q[2]));break;case "Q":k.qx=q[1];k.qy=q[2];q=["C"][M](Ua(k.x,k.y,q[1],q[2],q[3],q[4]));break;case "L":q=["C"][M](ya(k.x,k.y,q[1],q[2]));break;case "H":q=["C"][M](ya(k.x,k.y,q[1],k.y));break;case "V":q=["C"][M](ya(k.x,k.y,k.x,q[1]));break;case "Z":q=["C"][M](ya(k.x,k.y,k.X,k.Y));break}return q}function e(q,k){if(q[k][o]>7){q[k].shift();
+for(var t=q[k];t[o];)q.splice(k++,0,["C"][M](t.splice(0,6)));q.splice(k,1);i=Y(c[o],d&&d[o]||0)}}function g(q,k,t,L,B){if(q&&k&&q[B][0]=="M"&&k[B][0]!="M"){k.splice(B,0,["M",L.x,L.y]);t.bx=0;t.by=0;t.x=q[B][1];t.y=q[B][2];i=Y(c[o],d&&d[o]||0)}}for(var h=0,i=Y(c[o],d&&d[o]||0);h<i;h++){c[h]=f(c[h],a);e(c,h);d&&(d[h]=f(d[h],b));d&&e(d,h);g(c,d,a,b,h);g(d,c,b,a,h);var j=c[h],m=d&&d[h],n=j[o],r=d&&m[o];a.x=j[n-2];a.y=j[n-1];a.bx=y(j[n-4])||a.x;a.by=y(j[n-3])||a.y;b.bx=d&&(y(m[r-4])||b.x);b.by=d&&(y(m[r-
+3])||b.y);b.x=d&&m[r-2];b.y=d&&m[r-1]}return d?[c,d]:c},null,va),Wa=Z(function(a){for(var b=[],c=0,d=a[o];c<d;c++){var f={},e=a[c].match(/^([^:]*):?([\d\.]*)/);f.color=l.getRGB(e[1]);if(f.color.error)return null;f.color=f.color.hex;e[2]&&(f.offset=e[2]+"%");b[F](f)}c=1;for(d=b[o]-1;c<d;c++)if(!b[c].offset){a=y(b[c-1].offset||0);e=0;for(f=c+1;f<d;f++)if(b[f].offset){e=b[f].offset;break}if(!e){e=100;f=d}e=y(e);for(e=(e-a)/(f-c+1);c<f;c++){a+=e;b[c].offset=a+"%"}}return b});function Xa(a,b,c,d){if(l.is(a,
+ga)||l.is(a,"object")){a=l.is(a,ga)?C.getElementById(a):a;if(a.tagName)return b==null?{container:a,width:a.style.pixelWidth||a.offsetWidth,height:a.style.pixelHeight||a.offsetHeight}:{container:a,width:b,height:c}}else return{container:1,x:a,y:b,width:c,height:d}}function Ia(a,b){var c=this;for(var d in b)if(b[z](d)&&!(d in a))switch(typeof b[d]){case "function":(function(f){a[d]=a===c?f:function(){return f[K](c,arguments)}})(b[d]);break;case "object":a[d]=a[d]||{};Ia.call(this,a[d],b[d]);break;default:a[d]=
+b[d];break}}function ma(a,b){a==b.top&&(b.top=a.prev);a==b.bottom&&(b.bottom=a.next);a.next&&(a.next.prev=a.prev);a.prev&&(a.prev.next=a.next)}function Ya(a,b){if(b.top!==a){ma(a,b);a.next=null;a.prev=b.top;b.top.next=a;b.top=a}}function Za(a,b){if(b.bottom!==a){ma(a,b);a.next=b.bottom;a.prev=null;b.bottom.prev=a;b.bottom=a}}function $a(a,b,c){ma(a,c);b==c.top&&(c.top=a);b.next&&(b.next.prev=a);a.next=b.next;a.prev=b;b.next=a}function ab(a,b,c){ma(a,c);b==c.bottom&&(c.bottom=a);b.prev&&(b.prev.next=
+a);a.prev=b.prev;b.prev=a;a.next=b}function bb(a){return function(){throw new Error("Rapha\u00ebl: you are calling to method \u201c"+a+"\u201d of removed object");}}var cb=/^r(?:\(([^,]+?)\s*,\s*([^\)]+?)\))?/;l.pathToRelative=Ha;if(l.svg){H[p].svgns="http://www.w3.org/2000/svg";H[p].xlink="http://www.w3.org/1999/xlink";Q=function(a){return+a+(~~a===a)*0.5};var u=function(a,b){if(b)for(var c in b)b[z](c)&&a[W](c,D(b[c]));else{a=C.createElementNS(H[p].svgns,a);a.style.webkitTapHighlightColor="rgba(0,0,0,0)";
+return a}};l[O]=function(){return"Your browser supports SVG.\nYou are running Rapha\u00ebl "+this.version};var db=function(a,b){var c=u("path");b.canvas&&b.canvas[x](c);b=new s(c,b);b.type="path";ea(b,{fill:"none",stroke:"#000",path:a});return b},pa=function(a,b,c){var d="linear",f=0.5,e=0.5,g=a.style;b=D(b)[I](cb,function(m,n,r){d="radial";if(n&&r){f=y(n);e=y(r);m=(e>0.5)*2-1;E(f-0.5,2)+E(e-0.5,2)>0.25&&(e=v.sqrt(0.25-E(f-0.5,2))*m+0.5)&&e!=0.5&&(e=e.toFixed(5)-1.0E-5*m)}return A});b=b[G](/\s*\-\s*/);
+if(d=="linear"){var h=b.shift();h=-y(h);if(isNaN(h))return null;h=[0,0,v.cos(h*v.PI/180),v.sin(h*v.PI/180)];var i=1/(Y(v.abs(h[2]),v.abs(h[3]))||1);h[2]*=i;h[3]*=i;if(h[2]<0){h[0]=-h[2];h[2]=0}if(h[3]<0){h[1]=-h[3];h[3]=0}}b=Wa(b);if(!b)return null;i=a.getAttribute(ca);(i=i.match(/^url\(#(.*)\)$/))&&c.defs.removeChild(C.getElementById(i[1]));i=u(d+"Gradient");i.id="r"+(l._id++)[O](36);u(i,d=="radial"?{fx:f,fy:e}:{x1:h[0],y1:h[1],x2:h[2],y2:h[3]});c.defs[x](i);c=0;for(h=b[o];c<h;c++){var j=u("stop");
+u(j,{offset:b[c].offset?b[c].offset:!c?"0%":"100%","stop-color":b[c].color||"#fff"});i[x](j)}u(a,{fill:"url(#"+i.id+")",opacity:1,"fill-opacity":1});g.fill=A;g.opacity=1;return g.fillOpacity=1},Ja=function(a){var b=a.getBBox();u(a.pattern,{patternTransform:l.format("translate({0},{1})",b.x,b.y)})},ea=function(a,b){var c={"":[0],none:[0],"-":[3,1],".":[1,1],"-.":[3,1,1,1],"-..":[3,1,1,1,1,1],". ":[1,3],"- ":[4,3],"--":[8,3],"- .":[4,3,1,3],"--.":[8,3,1,3],"--..":[8,3,1,3,1,3]},d=a.node,f=a.attrs,e=
+a.rotate();function g(k,t){if(t=c[fa.call(t)]){var L=k.attrs["stroke-width"]||"1";k={round:L,square:L,butt:0}[k.attrs["stroke-linecap"]||b["stroke-linecap"]]||0;for(var B=[],w=t[o];w--;)B[w]=t[w]*L+(w%2?1:-1)*k;u(d,{"stroke-dasharray":B[R](",")})}}b[z]("rotation")&&(e=b.rotation);var h=D(e)[G](V);if(h.length-1){h[1]=+h[1];h[2]=+h[2]}else h=null;y(e)&&a.rotate(0,true);for(var i in b)if(b[z](i))if(ta[z](i)){var j=b[i];f[i]=j;switch(i){case "blur":a.blur(j);break;case "rotation":a.rotate(j,true);break;
+case "href":case "title":case "target":var m=d.parentNode;if(fa.call(m.tagName)!="a"){var n=u("a");m.insertBefore(n,d);n[x](d);m=n}m.setAttributeNS(a.paper.xlink,i,j);break;case "cursor":d.style.cursor=j;break;case "clip-rect":m=D(j)[G](V);if(m[o]==4){a.clip&&a.clip.parentNode.parentNode.removeChild(a.clip.parentNode);var r=u("clipPath");n=u("rect");r.id="r"+(l._id++)[O](36);u(n,{x:m[0],y:m[1],width:m[2],height:m[3]});r[x](n);a.paper.defs[x](r);u(d,{"clip-path":"url(#"+r.id+")"});a.clip=n}if(!j){(j=
+C.getElementById(d.getAttribute("clip-path")[I](/(^url\(#|\)$)/g,A)))&&j.parentNode.removeChild(j);u(d,{"clip-path":A});delete a.clip}break;case "path":if(a.type=="path")u(d,{d:j?(f.path=oa(j)):"M0,0"});break;case "width":d[W](i,j);if(f.fx){i="x";j=f.x}else break;case "x":if(f.fx)j=-f.x-(f.width||0);case "rx":if(i=="rx"&&a.type=="rect")break;case "cx":h&&(i=="x"||i=="cx")&&(h[1]+=j-f[i]);d[W](i,j);a.pattern&&Ja(a);break;case "height":d[W](i,j);if(f.fy){i="y";j=f.y}else break;case "y":if(f.fy)j=-f.y-
+(f.height||0);case "ry":if(i=="ry"&&a.type=="rect")break;case "cy":h&&(i=="y"||i=="cy")&&(h[2]+=j-f[i]);d[W](i,j);a.pattern&&Ja(a);break;case "r":a.type=="rect"?u(d,{rx:j,ry:j}):d[W](i,j);break;case "src":a.type=="image"&&d.setAttributeNS(a.paper.xlink,"href",j);break;case "stroke-width":d.style.strokeWidth=j;d[W](i,j);f["stroke-dasharray"]&&g(a,f["stroke-dasharray"]);break;case "stroke-dasharray":g(a,j);break;case "translation":j=D(j)[G](V);j[0]=+j[0]||0;j[1]=+j[1]||0;if(h){h[1]+=j[0];h[2]+=j[1]}Aa.call(a,
+j[0],j[1]);break;case "scale":j=D(j)[G](V);a.scale(+j[0]||1,+j[1]||+j[0]||1,isNaN(y(j[2]))?null:+j[2],isNaN(y(j[3]))?null:+j[3]);break;case ca:if(m=D(j).match(Sa)){r=u("pattern");var q=u("image");r.id="r"+(l._id++)[O](36);u(r,{x:0,y:0,patternUnits:"userSpaceOnUse",height:1,width:1});u(q,{x:0,y:0});q.setAttributeNS(a.paper.xlink,"href",m[1]);r[x](q);j=C.createElement("img");j.style.cssText="position:absolute;left:-9999em;top-9999em";j.onload=function(){u(r,{width:this.offsetWidth,height:this.offsetHeight});
+u(q,{width:this.offsetWidth,height:this.offsetHeight});C.body.removeChild(this);a.paper.safari()};C.body[x](j);j.src=m[1];a.paper.defs[x](r);d.style.fill="url(#"+r.id+")";u(d,{fill:"url(#"+r.id+")"});a.pattern=r;a.pattern&&Ja(a);break}m=l.getRGB(j);if(m.error){if(({circle:1,ellipse:1}[z](a.type)||D(j).charAt()!="r")&&pa(d,j,a.paper)){f.gradient=j;f.fill="none";break}}else{delete b.gradient;delete f.gradient;!l.is(f.opacity,"undefined")&&l.is(b.opacity,"undefined")&&u(d,{opacity:f.opacity});!l.is(f["fill-opacity"],
+"undefined")&&l.is(b["fill-opacity"],"undefined")&&u(d,{"fill-opacity":f["fill-opacity"]})}m[z]("o")&&u(d,{"fill-opacity":m.o>1?m.o/100:m.o});case "stroke":m=l.getRGB(j);d[W](i,m.hex);i=="stroke"&&m[z]("o")&&u(d,{"stroke-opacity":m.o>1?m.o/100:m.o});break;case "gradient":(({circle:1,ellipse:1})[z](a.type)||D(j).charAt()!="r")&&pa(d,j,a.paper);break;case "opacity":case "fill-opacity":if(f.gradient){if(m=C.getElementById(d.getAttribute(ca)[I](/^url\(#|\)$/g,A))){m=m.getElementsByTagName("stop");m[m[o]-
+1][W]("stop-opacity",j)}break}default:i=="font-size"&&(j=ha(j,10)+"px");m=i[I](/(\-.)/g,function(k){return sa.call(k.substring(1))});d.style[m]=j;d[W](i,j);break}}Db(a,b);if(h)a.rotate(h.join(N));else y(e)&&a.rotate(e,true)},eb=1.2,Db=function(a,b){if(!(a.type!="text"||!(b[z]("text")||b[z]("font")||b[z]("font-size")||b[z]("x")||b[z]("y")))){var c=a.attrs,d=a.node,f=d.firstChild?ha(C.defaultView.getComputedStyle(d.firstChild,A).getPropertyValue("font-size"),10):10;if(b[z]("text")){for(c.text=b.text;d.firstChild;)d.removeChild(d.firstChild);
+b=D(b.text)[G]("\n");for(var e=0,g=b[o];e<g;e++)if(b[e]){var h=u("tspan");e&&u(h,{dy:f*eb,x:c.x});h[x](C.createTextNode(b[e]));d[x](h)}}else{b=d.getElementsByTagName("tspan");e=0;for(g=b[o];e<g;e++)e&&u(b[e],{dy:f*eb,x:c.x})}u(d,{y:c.y});a=a.getBBox();(a=c.y-(a.y+a.height/2))&&isFinite(a)&&u(d,{y:c.y+a})}},s=function(a,b){this[0]=a;this.id=l._oid++;this.node=a;a.raphael=this;this.paper=b;this.attrs=this.attrs||{};this.transformations=[];this._={tx:0,ty:0,rt:{deg:0,cx:0,cy:0},sx:1,sy:1};!b.bottom&&
+(b.bottom=this);(this.prev=b.top)&&(b.top.next=this);b.top=this;this.next=null};s[p].rotate=function(a,b,c){if(this.removed)return this;if(a==null){if(this._.rt.cx)return[this._.rt.deg,this._.rt.cx,this._.rt.cy][R](N);return this._.rt.deg}var d=this.getBBox();a=D(a)[G](V);if(a[o]-1){b=y(a[1]);c=y(a[2])}a=y(a[0]);if(b!=null)this._.rt.deg=a;else this._.rt.deg+=a;c==null&&(b=null);this._.rt.cx=b;this._.rt.cy=c;b=b==null?d.x+d.width/2:b;c=c==null?d.y+d.height/2:c;if(this._.rt.deg){this.transformations[0]=
+l.format("rotate({0} {1} {2})",this._.rt.deg,b,c);this.clip&&u(this.clip,{transform:l.format("rotate({0} {1} {2})",-this._.rt.deg,b,c)})}else{this.transformations[0]=A;this.clip&&u(this.clip,{transform:A})}u(this.node,{transform:this.transformations[R](N)});return this};s[p].hide=function(){!this.removed&&(this.node.style.display="none");return this};s[p].show=function(){!this.removed&&(this.node.style.display="");return this};s[p].remove=function(){if(!this.removed){ma(this,this.paper);this.node.parentNode.removeChild(this.node);
+for(var a in this)delete this[a];this.removed=true}};s[p].getBBox=function(){if(this.removed)return this;if(this.type=="path")return xa(this.attrs.path);if(this.node.style.display=="none"){this.show();var a=true}var b={};try{b=this.node.getBBox()}catch(c){}finally{b=b||{}}if(this.type=="text"){b={x:b.x,y:Infinity,width:0,height:0};for(var d=0,f=this.node.getNumberOfChars();d<f;d++){var e=this.node.getExtentOfChar(d);e.y<b.y&&(b.y=e.y);e.y+e.height-b.y>b.height&&(b.height=e.y+e.height-b.y);e.x+e.width-
+b.x>b.width&&(b.width=e.x+e.width-b.x)}}a&&this.hide();return b};s[p].attr=function(a,b){if(this.removed)return this;if(a==null){a={};for(var c in this.attrs)if(this.attrs[z](c))a[c]=this.attrs[c];this._.rt.deg&&(a.rotation=this.rotate());(this._.sx!=1||this._.sy!=1)&&(a.scale=this.scale());a.gradient&&a.fill=="none"&&(a.fill=a.gradient)&&delete a.gradient;return a}if(b==null&&l.is(a,ga)){if(a=="translation")return Aa.call(this);if(a=="rotation")return this.rotate();if(a=="scale")return this.scale();
+if(a==ca&&this.attrs.fill=="none"&&this.attrs.gradient)return this.attrs.gradient;return this.attrs[a]}if(b==null&&l.is(a,U)){b={};c=0;for(var d=a.length;c<d;c++)b[a[c]]=this.attr(a[c]);return b}if(b!=null){c={};c[a]=b;ea(this,c)}else a!=null&&l.is(a,"object")&&ea(this,a);return this};s[p].toFront=function(){if(this.removed)return this;this.node.parentNode[x](this.node);var a=this.paper;a.top!=this&&Ya(this,a);return this};s[p].toBack=function(){if(this.removed)return this;if(this.node.parentNode.firstChild!=
+this.node){this.node.parentNode.insertBefore(this.node,this.node.parentNode.firstChild);Za(this,this.paper)}return this};s[p].insertAfter=function(a){if(this.removed)return this;var b=a.node||a[a.length].node;b.nextSibling?b.parentNode.insertBefore(this.node,b.nextSibling):b.parentNode[x](this.node);$a(this,a,this.paper);return this};s[p].insertBefore=function(a){if(this.removed)return this;var b=a.node||a[0].node;b.parentNode.insertBefore(this.node,b);ab(this,a,this.paper);return this};s[p].blur=
+function(a){var b=this;if(+a!==0){var c=u("filter"),d=u("feGaussianBlur");b.attrs.blur=a;c.id="r"+(l._id++)[O](36);u(d,{stdDeviation:+a||1.5});c.appendChild(d);b.paper.defs.appendChild(c);b._blur=c;u(b.node,{filter:"url(#"+c.id+")"})}else{if(b._blur){b._blur.parentNode.removeChild(b._blur);delete b._blur;delete b.attrs.blur}b.node.removeAttribute("filter")}};var fb=function(a,b,c,d){var f=u("circle");a.canvas&&a.canvas[x](f);a=new s(f,a);a.attrs={cx:b,cy:c,r:d,fill:"none",stroke:"#000"};a.type="circle";
+u(f,a.attrs);return a},gb=function(a,b,c,d,f,e){var g=u("rect");a.canvas&&a.canvas[x](g);a=new s(g,a);a.attrs={x:b,y:c,width:d,height:f,r:e||0,rx:e||0,ry:e||0,fill:"none",stroke:"#000"};a.type="rect";u(g,a.attrs);return a},hb=function(a,b,c,d,f){var e=u("ellipse");a.canvas&&a.canvas[x](e);a=new s(e,a);a.attrs={cx:b,cy:c,rx:d,ry:f,fill:"none",stroke:"#000"};a.type="ellipse";u(e,a.attrs);return a},ib=function(a,b,c,d,f,e){var g=u("image");u(g,{x:c,y:d,width:f,height:e,preserveAspectRatio:"none"});g.setAttributeNS(a.xlink,
+"href",b);a.canvas&&a.canvas[x](g);a=new s(g,a);a.attrs={x:c,y:d,width:f,height:e,src:b};a.type="image";return a},jb=function(a,b,c,d){var f=u("text");u(f,{x:b,y:c,"text-anchor":"middle"});a.canvas&&a.canvas[x](f);a=new s(f,a);a.attrs={x:b,y:c,"text-anchor":"middle",text:d,font:ta.font,stroke:"none",fill:"#000"};a.type="text";ea(a,a.attrs);return a},kb=function(a,b){this.width=a||this.width;this.height=b||this.height;this.canvas[W]("width",this.width);this.canvas[W]("height",this.height);return this},
+Ca=function(){var a=Xa[K](0,arguments),b=a&&a.container,c=a.x,d=a.y,f=a.width;a=a.height;if(!b)throw new Error("SVG container not found.");var e=u("svg");c=c||0;d=d||0;f=f||512;a=a||342;u(e,{xmlns:"http://www.w3.org/2000/svg",version:1.1,width:f,height:a});if(b==1){e.style.cssText="position:absolute;left:"+c+"px;top:"+d+"px";C.body[x](e)}else b.firstChild?b.insertBefore(e,b.firstChild):b[x](e);b=new H;b.width=f;b.height=a;b.canvas=e;Ia.call(b,b,l.fn);b.clear();return b};H[p].clear=function(){for(var a=
+this.canvas;a.firstChild;)a.removeChild(a.firstChild);this.bottom=this.top=null;(this.desc=u("desc"))[x](C.createTextNode("Created with Rapha\u00ebl"));a[x](this.desc);a[x](this.defs=u("defs"))};H[p].remove=function(){this.canvas.parentNode&&this.canvas.parentNode.removeChild(this.canvas);for(var a in this)this[a]=bb(a)}}if(l.vml){var lb={M:"m",L:"l",C:"c",Z:"x",m:"t",l:"r",c:"v",z:"x"},Eb=/([clmz]),?([^clmz]*)/gi,Fb=/-?[^,\s-]+/g,qa=1000+N+1000,na=10,ra={path:1,rect:1},Gb=function(a){var b=/[ahqstv]/ig,
+c=oa;D(a).match(b)&&(c=wa);b=/[clmz]/g;if(c==oa&&!D(a).match(b))return a=D(a)[I](Eb,function(i,j,m){var n=[],r=fa.call(j)=="m",q=lb[j];m[I](Fb,function(k){if(r&&n[o]==2){q+=n+lb[j=="m"?"l":"L"];n=[]}n[F](Q(k*na))});return q+n});b=c(a);var d;a=[];for(var f=0,e=b[o];f<e;f++){c=b[f];d=fa.call(b[f][0]);d=="z"&&(d="x");for(var g=1,h=c[o];g<h;g++)d+=Q(c[g]*na)+(g!=h-1?",":A);a[F](d)}return a[R](N)};l[O]=function(){return"Your browser doesn\u2019t support SVG. Falling down to VML.\nYou are running Rapha\u00ebl "+
+this.version};db=function(a,b){var c=S("group");c.style.cssText="position:absolute;left:0;top:0;width:"+b.width+"px;height:"+b.height+"px";c.coordsize=b.coordsize;c.coordorigin=b.coordorigin;var d=S("shape"),f=d.style;f.width=b.width+"px";f.height=b.height+"px";d.coordsize=qa;d.coordorigin=b.coordorigin;c[x](d);d=new s(d,c,b);f={fill:"none",stroke:"#000"};a&&(f.path=a);d.isAbsolute=true;d.type="path";d.path=[];d.Path=A;ea(d,f);b.canvas[x](c);return d};ea=function(a,b){a.attrs=a.attrs||{};var c=a.node,
+d=a.attrs,f=c.style,e;e=(b.x!=d.x||b.y!=d.y||b.width!=d.width||b.height!=d.height||b.r!=d.r)&&a.type=="rect";var g=a;for(var h in b)if(b[z](h))d[h]=b[h];if(e){d.path=mb(d.x,d.y,d.width,d.height,d.r);a.X=d.x;a.Y=d.y;a.W=d.width;a.H=d.height}b.href&&(c.href=b.href);b.title&&(c.title=b.title);b.target&&(c.target=b.target);b.cursor&&(f.cursor=b.cursor);"blur"in b&&a.blur(b.blur);if(b.path&&a.type=="path"||e)c.path=Gb(d.path);b.rotation!=null&&a.rotate(b.rotation,true);if(b.translation){e=D(b.translation)[G](V);
+Aa.call(a,e[0],e[1]);if(a._.rt.cx!=null){a._.rt.cx+=+e[0];a._.rt.cy+=+e[1];a.setBox(a.attrs,e[0],e[1])}}if(b.scale){e=D(b.scale)[G](V);a.scale(+e[0]||1,+e[1]||+e[0]||1,+e[2]||null,+e[3]||null)}if("clip-rect"in b){e=D(b["clip-rect"])[G](V);if(e[o]==4){e[2]=+e[2]+ +e[0];e[3]=+e[3]+ +e[1];h=c.clipRect||C.createElement("div");var i=h.style,j=c.parentNode;i.clip=l.format("rect({1}px {2}px {3}px {0}px)",e);if(!c.clipRect){i.position="absolute";i.top=0;i.left=0;i.width=a.paper.width+"px";i.height=a.paper.height+
+"px";j.parentNode.insertBefore(h,j);h[x](j);c.clipRect=h}}if(!b["clip-rect"])c.clipRect&&(c.clipRect.style.clip=A)}if(a.type=="image"&&b.src)c.src=b.src;if(a.type=="image"&&b.opacity){c.filterOpacity=Fa+".Alpha(opacity="+b.opacity*100+")";f.filter=(c.filterMatrix||A)+(c.filterOpacity||A)}b.font&&(f.font=b.font);b["font-family"]&&(f.fontFamily='"'+b["font-family"][G](",")[0][I](/^['"]+|['"]+$/g,A)+'"');b["font-size"]&&(f.fontSize=b["font-size"]);b["font-weight"]&&(f.fontWeight=b["font-weight"]);b["font-style"]&&
+(f.fontStyle=b["font-style"]);if(b.opacity!=null||b["stroke-width"]!=null||b.fill!=null||b.stroke!=null||b["stroke-width"]!=null||b["stroke-opacity"]!=null||b["fill-opacity"]!=null||b["stroke-dasharray"]!=null||b["stroke-miterlimit"]!=null||b["stroke-linejoin"]!=null||b["stroke-linecap"]!=null){c=a.shape||c;f=c.getElementsByTagName(ca)&&c.getElementsByTagName(ca)[0];e=false;!f&&(e=f=S(ca));if("fill-opacity"in b||"opacity"in b){a=((+d["fill-opacity"]+1||2)-1)*((+d.opacity+1||2)-1)*((+l.getRGB(b.fill).o+
+1||2)-1);a<0&&(a=0);a>1&&(a=1);f.opacity=a}b.fill&&(f.on=true);if(f.on==null||b.fill=="none")f.on=false;if(f.on&&b.fill)if(a=b.fill.match(Sa)){f.src=a[1];f.type="tile"}else{f.color=l.getRGB(b.fill).hex;f.src=A;f.type="solid";if(l.getRGB(b.fill).error&&(g.type in{circle:1,ellipse:1}||D(b.fill).charAt()!="r")&&pa(g,b.fill)){d.fill="none";d.gradient=b.fill}}e&&c[x](f);f=c.getElementsByTagName("stroke")&&c.getElementsByTagName("stroke")[0];e=false;!f&&(e=f=S("stroke"));if(b.stroke&&b.stroke!="none"||
+b["stroke-width"]||b["stroke-opacity"]!=null||b["stroke-dasharray"]||b["stroke-miterlimit"]||b["stroke-linejoin"]||b["stroke-linecap"])f.on=true;(b.stroke=="none"||f.on==null||b.stroke==0||b["stroke-width"]==0)&&(f.on=false);a=l.getRGB(b.stroke);f.on&&b.stroke&&(f.color=a.hex);a=((+d["stroke-opacity"]+1||2)-1)*((+d.opacity+1||2)-1)*((+a.o+1||2)-1);h=(y(b["stroke-width"])||1)*0.75;a<0&&(a=0);a>1&&(a=1);b["stroke-width"]==null&&(h=d["stroke-width"]);b["stroke-width"]&&(f.weight=h);h&&h<1&&(a*=h)&&(f.weight=
+1);f.opacity=a;b["stroke-linejoin"]&&(f.joinstyle=b["stroke-linejoin"]||"miter");f.miterlimit=b["stroke-miterlimit"]||8;b["stroke-linecap"]&&(f.endcap=b["stroke-linecap"]=="butt"?"flat":b["stroke-linecap"]=="square"?"square":"round");if(b["stroke-dasharray"]){a={"-":"shortdash",".":"shortdot","-.":"shortdashdot","-..":"shortdashdotdot",". ":"dot","- ":"dash","--":"longdash","- .":"dashdot","--.":"longdashdot","--..":"longdashdotdot"};f.dashstyle=a[z](b["stroke-dasharray"])?a[b["stroke-dasharray"]]:
+A}e&&c[x](f)}if(g.type=="text"){f=g.paper.span.style;d.font&&(f.font=d.font);d["font-family"]&&(f.fontFamily=d["font-family"]);d["font-size"]&&(f.fontSize=d["font-size"]);d["font-weight"]&&(f.fontWeight=d["font-weight"]);d["font-style"]&&(f.fontStyle=d["font-style"]);g.node.string&&(g.paper.span.innerHTML=D(g.node.string)[I](/</g,"<")[I](/&/g,"&")[I](/\n/g,"<br>"));g.W=d.w=g.paper.span.offsetWidth;g.H=d.h=g.paper.span.offsetHeight;g.X=d.x;g.Y=d.y+Q(g.H/2);switch(d["text-anchor"]){case "start":g.node.style["v-text-align"]=
+"left";g.bbx=Q(g.W/2);break;case "end":g.node.style["v-text-align"]="right";g.bbx=-Q(g.W/2);break;default:g.node.style["v-text-align"]="center";break}}};pa=function(a,b){a.attrs=a.attrs||{};var c="linear",d=".5 .5";a.attrs.gradient=b;b=D(b)[I](cb,function(i,j,m){c="radial";if(j&&m){j=y(j);m=y(m);E(j-0.5,2)+E(m-0.5,2)>0.25&&(m=v.sqrt(0.25-E(j-0.5,2))*((m>0.5)*2-1)+0.5);d=j+N+m}return A});b=b[G](/\s*\-\s*/);if(c=="linear"){var f=b.shift();f=-y(f);if(isNaN(f))return null}var e=Wa(b);if(!e)return null;
+a=a.shape||a.node;b=a.getElementsByTagName(ca)[0]||S(ca);!b.parentNode&&a.appendChild(b);if(e[o]){b.on=true;b.method="none";b.color=e[0].color;b.color2=e[e[o]-1].color;a=[];for(var g=0,h=e[o];g<h;g++)e[g].offset&&a[F](e[g].offset+N+e[g].color);b.colors&&(b.colors.value=a[o]?a[R]():"0% "+b.color);if(c=="radial"){b.type="gradientradial";b.focus="100%";b.focussize=d;b.focusposition=d}else{b.type="gradient";b.angle=(270-f)%360}}return 1};s=function(a,b,c){this[0]=a;this.id=l._oid++;this.node=a;a.raphael=
+this;this.Y=this.X=0;this.attrs={};this.Group=b;this.paper=c;this._={tx:0,ty:0,rt:{deg:0},sx:1,sy:1};!c.bottom&&(c.bottom=this);(this.prev=c.top)&&(c.top.next=this);c.top=this;this.next=null};s[p].rotate=function(a,b,c){if(this.removed)return this;if(a==null){if(this._.rt.cx)return[this._.rt.deg,this._.rt.cx,this._.rt.cy][R](N);return this._.rt.deg}a=D(a)[G](V);if(a[o]-1){b=y(a[1]);c=y(a[2])}a=y(a[0]);if(b!=null)this._.rt.deg=a;else this._.rt.deg+=a;c==null&&(b=null);this._.rt.cx=b;this._.rt.cy=c;
+this.setBox(this.attrs,b,c);this.Group.style.rotation=this._.rt.deg;return this};s[p].setBox=function(a,b,c){if(this.removed)return this;var d=this.Group.style,f=this.shape&&this.shape.style||this.node.style;a=a||{};for(var e in a)if(a[z](e))this.attrs[e]=a[e];b=b||this._.rt.cx;c=c||this._.rt.cy;var g=this.attrs,h;switch(this.type){case "circle":a=g.cx-g.r;e=g.cy-g.r;h=g=g.r*2;break;case "ellipse":a=g.cx-g.rx;e=g.cy-g.ry;h=g.rx*2;g=g.ry*2;break;case "image":a=+g.x;e=+g.y;h=g.width||0;g=g.height||
+0;break;case "text":this.textpath.v=["m",Q(g.x),", ",Q(g.y-2),"l",Q(g.x)+1,", ",Q(g.y-2)][R](A);a=g.x-Q(this.W/2);e=g.y-this.H/2;h=this.W;g=this.H;break;case "rect":case "path":if(this.attrs.path){g=xa(this.attrs.path);a=g.x;e=g.y;h=g.width;g=g.height}else{e=a=0;h=this.paper.width;g=this.paper.height}break;default:e=a=0;h=this.paper.width;g=this.paper.height;break}b=b==null?a+h/2:b;c=c==null?e+g/2:c;b=b-this.paper.width/2;c=c-this.paper.height/2;var i;d.left!=(i=b+"px")&&(d.left=i);d.top!=(i=c+"px")&&
+(d.top=i);this.X=ra[z](this.type)?-b:a;this.Y=ra[z](this.type)?-c:e;this.W=h;this.H=g;if(ra[z](this.type)){f.left!=(i=-b*na+"px")&&(f.left=i);f.top!=(i=-c*na+"px")&&(f.top=i)}else if(this.type=="text"){f.left!=(i=-b+"px")&&(f.left=i);f.top!=(i=-c+"px")&&(f.top=i)}else{d.width!=(i=this.paper.width+"px")&&(d.width=i);d.height!=(i=this.paper.height+"px")&&(d.height=i);f.left!=(i=a-b+"px")&&(f.left=i);f.top!=(i=e-c+"px")&&(f.top=i);f.width!=(i=h+"px")&&(f.width=i);f.height!=(i=g+"px")&&(f.height=i)}};
+s[p].hide=function(){!this.removed&&(this.Group.style.display="none");return this};s[p].show=function(){!this.removed&&(this.Group.style.display="block");return this};s[p].getBBox=function(){if(this.removed)return this;if(ra[z](this.type))return xa(this.attrs.path);return{x:this.X+(this.bbx||0),y:this.Y,width:this.W,height:this.H}};s[p].remove=function(){if(!this.removed){ma(this,this.paper);this.node.parentNode.removeChild(this.node);this.Group.parentNode.removeChild(this.Group);this.shape&&this.shape.parentNode.removeChild(this.shape);
+for(var a in this)delete this[a];this.removed=true}};s[p].attr=function(a,b){if(this.removed)return this;if(a==null){a={};for(var c in this.attrs)if(this.attrs[z](c))a[c]=this.attrs[c];this._.rt.deg&&(a.rotation=this.rotate());(this._.sx!=1||this._.sy!=1)&&(a.scale=this.scale());a.gradient&&a.fill=="none"&&(a.fill=a.gradient)&&delete a.gradient;return a}if(b==null&&l.is(a,ga)){if(a=="translation")return Aa.call(this);if(a=="rotation")return this.rotate();if(a=="scale")return this.scale();if(a==ca&&
+this.attrs.fill=="none"&&this.attrs.gradient)return this.attrs.gradient;return this.attrs[a]}if(this.attrs&&b==null&&l.is(a,U)){var d={};c=0;for(b=a[o];c<b;c++)d[a[c]]=this.attr(a[c]);return d}if(b!=null){d={};d[a]=b}b==null&&l.is(a,"object")&&(d=a);if(d){if(d.text&&this.type=="text")this.node.string=d.text;ea(this,d);if(d.gradient&&({circle:1,ellipse:1}[z](this.type)||D(d.gradient).charAt()!="r"))pa(this,d.gradient);(!ra[z](this.type)||this._.rt.deg)&&this.setBox(this.attrs)}return this};s[p].toFront=
+function(){!this.removed&&this.Group.parentNode[x](this.Group);this.paper.top!=this&&Ya(this,this.paper);return this};s[p].toBack=function(){if(this.removed)return this;if(this.Group.parentNode.firstChild!=this.Group){this.Group.parentNode.insertBefore(this.Group,this.Group.parentNode.firstChild);Za(this,this.paper)}return this};s[p].insertAfter=function(a){if(this.removed)return this;if(a.constructor==X)a=a[a.length];a.Group.nextSibling?a.Group.parentNode.insertBefore(this.Group,a.Group.nextSibling):
+a.Group.parentNode[x](this.Group);$a(this,a,this.paper);return this};s[p].insertBefore=function(a){if(this.removed)return this;if(a.constructor==X)a=a[0];a.Group.parentNode.insertBefore(this.Group,a.Group);ab(this,a,this.paper);return this};var Hb=/ progid:\S+Blur\([^\)]+\)/g;s[p].blur=function(a){var b=this.node.runtimeStyle,c=b.filter;c=c.replace(Hb,A);if(+a!==0){this.attrs.blur=a;b.filter=c+N+Fa+".Blur(pixelradius="+(+a||1.5)+")";b.margin=l.format("-{0}px 0 0 -{0}px",Q(+a||1.5))}else{b.filter=
+c;b.margin=0;delete this.attrs.blur}};fb=function(a,b,c,d){var f=S("group"),e=S("oval");f.style.cssText="position:absolute;left:0;top:0;width:"+a.width+"px;height:"+a.height+"px";f.coordsize=qa;f.coordorigin=a.coordorigin;f[x](e);e=new s(e,f,a);e.type="circle";ea(e,{stroke:"#000",fill:"none"});e.attrs.cx=b;e.attrs.cy=c;e.attrs.r=d;e.setBox({x:b-d,y:c-d,width:d*2,height:d*2});a.canvas[x](f);return e};function mb(a,b,c,d,f){return f?l.format("M{0},{1}l{2},0a{3},{3},0,0,1,{3},{3}l0,{5}a{3},{3},0,0,1,{4},{3}l{6},0a{3},{3},0,0,1,{4},{4}l0,{7}a{3},{3},0,0,1,{3},{4}z",
+a+f,b,c-f*2,f,-f,d-f*2,f*2-c,f*2-d):l.format("M{0},{1}l{2},0,0,{3},{4},0z",a,b,c,d,-c)}gb=function(a,b,c,d,f,e){var g=mb(b,c,d,f,e);a=a.path(g);var h=a.attrs;a.X=h.x=b;a.Y=h.y=c;a.W=h.width=d;a.H=h.height=f;h.r=e;h.path=g;a.type="rect";return a};hb=function(a,b,c,d,f){var e=S("group"),g=S("oval");e.style.cssText="position:absolute;left:0;top:0;width:"+a.width+"px;height:"+a.height+"px";e.coordsize=qa;e.coordorigin=a.coordorigin;e[x](g);g=new s(g,e,a);g.type="ellipse";ea(g,{stroke:"#000"});g.attrs.cx=
+b;g.attrs.cy=c;g.attrs.rx=d;g.attrs.ry=f;g.setBox({x:b-d,y:c-f,width:d*2,height:f*2});a.canvas[x](e);return g};ib=function(a,b,c,d,f,e){var g=S("group"),h=S("image");g.style.cssText="position:absolute;left:0;top:0;width:"+a.width+"px;height:"+a.height+"px";g.coordsize=qa;g.coordorigin=a.coordorigin;h.src=b;g[x](h);h=new s(h,g,a);h.type="image";h.attrs.src=b;h.attrs.x=c;h.attrs.y=d;h.attrs.w=f;h.attrs.h=e;h.setBox({x:c,y:d,width:f,height:e});a.canvas[x](g);return h};jb=function(a,b,c,d){var f=S("group"),
+e=S("shape"),g=e.style,h=S("path"),i=S("textpath");f.style.cssText="position:absolute;left:0;top:0;width:"+a.width+"px;height:"+a.height+"px";f.coordsize=qa;f.coordorigin=a.coordorigin;h.v=l.format("m{0},{1}l{2},{1}",Q(b*10),Q(c*10),Q(b*10)+1);h.textpathok=true;g.width=a.width;g.height=a.height;i.string=D(d);i.on=true;e[x](i);e[x](h);f[x](e);g=new s(i,f,a);g.shape=e;g.textpath=h;g.type="text";g.attrs.text=d;g.attrs.x=b;g.attrs.y=c;g.attrs.w=1;g.attrs.h=1;ea(g,{font:ta.font,stroke:"none",fill:"#000"});
+g.setBox();a.canvas[x](f);return g};kb=function(a,b){var c=this.canvas.style;a==+a&&(a+="px");b==+b&&(b+="px");c.width=a;c.height=b;c.clip="rect(0 "+a+" "+b+" 0)";return this};var S;C.createStyleSheet().addRule(".rvml","behavior:url(#default#VML)");try{!C.namespaces.rvml&&C.namespaces.add("rvml","urn:schemas-microsoft-com:vml");S=function(a){return C.createElement("<rvml:"+a+' class="rvml">')}}catch(Pb){S=function(a){return C.createElement("<"+a+' xmlns="urn:schemas-microsoft.com:vml" class="rvml">')}}Ca=
+function(){var a=Xa[K](0,arguments),b=a.container,c=a.height,d=a.width,f=a.x;a=a.y;if(!b)throw new Error("VML container not found.");var e=new H,g=e.canvas=C.createElement("div"),h=g.style;f=f||0;a=a||0;d=d||512;c=c||342;d==+d&&(d+="px");c==+c&&(c+="px");e.width=1000;e.height=1000;e.coordsize=na*1000+N+na*1000;e.coordorigin="0 0";e.span=C.createElement("span");e.span.style.cssText="position:absolute;left:-9999em;top:-9999em;padding:0;margin:0;line-height:1;display:inline;";g[x](e.span);h.cssText=
+l.format("width:{0};height:{1};display:inline-block;position:relative;clip:rect(0 {0} {1} 0);overflow:hidden",d,c);if(b==1){C.body[x](g);h.left=f+"px";h.top=a+"px";h.position="absolute"}else b.firstChild?b.insertBefore(g,b.firstChild):b[x](g);Ia.call(e,e,l.fn);return e};H[p].clear=function(){this.canvas.innerHTML=A;this.span=C.createElement("span");this.span.style.cssText="position:absolute;left:-9999em;top:-9999em;padding:0;margin:0;line-height:1;display:inline;";this.canvas[x](this.span);this.bottom=
+this.top=null};H[p].remove=function(){this.canvas.parentNode.removeChild(this.canvas);for(var a in this)this[a]=bb(a);return true}}H[p].safari=navigator.vendor=="Apple Computer, Inc."&&(navigator.userAgent.match(/Version\/(.*?)\s/)[1]<4||aa.navigator.platform.slice(0,2)=="iP")?function(){var a=this.rect(-99,-99,this.width+99,this.height+99).attr({stroke:"none"});aa.setTimeout(function(){a.remove()})}:function(){};function Ib(){this.returnValue=false}function Jb(){return this.originalEvent.preventDefault()}
+function Kb(){this.cancelBubble=true}function Lb(){return this.originalEvent.stopPropagation()}var Mb=function(){if(C.addEventListener)return function(a,b,c,d){var f=Da&&Ea[b]?Ea[b]:b;function e(g){if(Da&&Ea[z](b))for(var h=0,i=g.targetTouches&&g.targetTouches.length;h<i;h++)if(g.targetTouches[h].target==a){i=g;g=g.targetTouches[h];g.originalEvent=i;g.preventDefault=Jb;g.stopPropagation=Lb;break}return c.call(d,g)}a.addEventListener(f,e,false);return function(){a.removeEventListener(f,e,false);return true}};
+else if(C.attachEvent)return function(a,b,c,d){function f(g){g=g||aa.event;g.preventDefault=g.preventDefault||Ib;g.stopPropagation=g.stopPropagation||Kb;return c.call(d,g)}a.attachEvent("on"+b,f);function e(){a.detachEvent("on"+b,f);return true}return e}}(),$=[];function Ka(a){for(var b=a.clientX,c=a.clientY,d,f=$.length;f--;){d=$[f];if(Da)for(var e=a.touches.length,g;e--;){g=a.touches[e];if(g.identifier==d.el._drag.id){b=g.clientX;c=g.clientY;(a.originalEvent?a.originalEvent:a).preventDefault();
+break}}else a.preventDefault();d.move&&d.move.call(d.el,b-d.el._drag.x,c-d.el._drag.y,b,c)}}function La(){l.unmousemove(Ka).unmouseup(La);for(var a=$.length,b;a--;){b=$[a];b.el._drag={};b.end&&b.end.call(b.el)}$=[]}for(da=Ra[o];da--;)(function(a){l[a]=s[p][a]=function(b){if(l.is(b,"function")){this.events=this.events||[];this.events.push({name:a,f:b,unbind:Mb(this.shape||this.node||C,a,b,this)})}return this};l["un"+a]=s[p]["un"+a]=function(b){for(var c=this.events,d=c[o];d--;)if(c[d].name==a&&c[d].f==
+b){c[d].unbind();c.splice(d,1);!c.length&&delete this.events;return this}return this}})(Ra[da]);s[p].hover=function(a,b){return this.mouseover(a).mouseout(b)};s[p].unhover=function(a,b){return this.unmouseover(a).unmouseout(b)};s[p].drag=function(a,b,c){this._drag={};this.mousedown(function(d){(d.originalEvent||d).preventDefault();this._drag.x=d.clientX;this._drag.y=d.clientY;this._drag.id=d.identifier;b&&b.call(this,d.clientX,d.clientY);!$.length&&l.mousemove(Ka).mouseup(La);$.push({el:this,move:a,
+end:c})});return this};s[p].undrag=function(a,b,c){for(b=$.length;b--;){$[b].el==this&&$[b].move==a&&$[b].end==c&&$.splice(b,1);!$.length&&l.unmousemove(Ka).unmouseup(La)}};H[p].circle=function(a,b,c){return fb(this,a||0,b||0,c||0)};H[p].rect=function(a,b,c,d,f){return gb(this,a||0,b||0,c||0,d||0,f||0)};H[p].ellipse=function(a,b,c,d){return hb(this,a||0,b||0,c||0,d||0)};H[p].path=function(a){a&&!l.is(a,ga)&&!l.is(a[0],U)&&(a+=A);return db(l.format[K](l,arguments),this)};H[p].image=function(a,b,c,
+d,f){return ib(this,a||"about:blank",b||0,c||0,d||0,f||0)};H[p].text=function(a,b,c){return jb(this,a||0,b||0,c||A)};H[p].set=function(a){arguments[o]>1&&(a=Array[p].splice.call(arguments,0,arguments[o]));return new X(a)};H[p].setSize=kb;H[p].top=H[p].bottom=null;H[p].raphael=l;function nb(){return this.x+N+this.y}s[p].resetScale=function(){if(this.removed)return this;this._.sx=1;this._.sy=1;this.attrs.scale="1 1"};s[p].scale=function(a,b,c,d){if(this.removed)return this;if(a==null&&b==null)return{x:this._.sx,
+y:this._.sy,toString:nb};b=b||a;!+b&&(b=a);var f,e,g=this.attrs;if(a!=0){var h=this.getBBox(),i=h.x+h.width/2,j=h.y+h.height/2;f=a/this._.sx;e=b/this._.sy;c=+c||c==0?c:i;d=+d||d==0?d:j;h=~~(a/v.abs(a));var m=~~(b/v.abs(b)),n=this.node.style,r=c+(i-c)*f;j=d+(j-d)*e;switch(this.type){case "rect":case "image":var q=g.width*h*f,k=g.height*m*e;this.attr({height:k,r:g.r*ba(h*f,m*e),width:q,x:r-q/2,y:j-k/2});break;case "circle":case "ellipse":this.attr({rx:g.rx*h*f,ry:g.ry*m*e,r:g.r*ba(h*f,m*e),cx:r,cy:j});
+break;case "text":this.attr({x:r,y:j});break;case "path":i=Ha(g.path);for(var t=true,L=0,B=i[o];L<B;L++){var w=i[L],J=sa.call(w[0]);if(!(J=="M"&&t)){t=false;if(J=="A"){w[i[L][o]-2]*=f;w[i[L][o]-1]*=e;w[1]*=h*f;w[2]*=m*e;w[5]=+!(h+m?!+w[5]:+w[5])}else if(J=="H"){J=1;for(var ia=w[o];J<ia;J++)w[J]*=f}else if(J=="V"){J=1;for(ia=w[o];J<ia;J++)w[J]*=e}else{J=1;for(ia=w[o];J<ia;J++)w[J]*=J%2?f:e}}}e=xa(i);f=r-e.x-e.width/2;e=j-e.y-e.height/2;i[0][1]+=f;i[0][2]+=e;this.attr({path:i});break}if(this.type in
+{text:1,image:1}&&(h!=1||m!=1))if(this.transformations){this.transformations[2]="scale("[M](h,",",m,")");this.node[W]("transform",this.transformations[R](N));f=h==-1?-g.x-(q||0):g.x;e=m==-1?-g.y-(k||0):g.y;this.attr({x:f,y:e});g.fx=h-1;g.fy=m-1}else{this.node.filterMatrix=Fa+".Matrix(M11="[M](h,", M12=0, M21=0, M22=",m,", Dx=0, Dy=0, sizingmethod='auto expand', filtertype='bilinear')");n.filter=(this.node.filterMatrix||A)+(this.node.filterOpacity||A)}else if(this.transformations){this.transformations[2]=
+A;this.node[W]("transform",this.transformations[R](N));g.fx=0;g.fy=0}else{this.node.filterMatrix=A;n.filter=(this.node.filterMatrix||A)+(this.node.filterOpacity||A)}g.scale=[a,b,c,d][R](N);this._.sx=a;this._.sy=b}return this};s[p].clone=function(){if(this.removed)return null;var a=this.attr();delete a.scale;delete a.translation;return this.paper[this.type]().attr(a)};var ob=Z(function(a,b,c,d,f,e,g,h,i){for(var j=0,m,n=0;n<1.01;n+=0.01){var r=la(a,b,c,d,f,e,g,h,n);n&&(j+=E(E(m.x-r.x,2)+E(m.y-r.y,
+2),0.5));if(j>=i)return r;m=r}});function Ma(a,b){return function(c,d,f){c=wa(c);for(var e,g,h,i,j="",m={},n=0,r=0,q=c.length;r<q;r++){h=c[r];if(h[0]=="M"){e=+h[1];g=+h[2]}else{i=Nb(e,g,h[1],h[2],h[3],h[4],h[5],h[6]);if(n+i>d){if(b&&!m.start){e=ob(e,g,h[1],h[2],h[3],h[4],h[5],h[6],d-n);j+=["C",e.start.x,e.start.y,e.m.x,e.m.y,e.x,e.y];if(f)return j;m.start=j;j=["M",e.x,e.y+"C",e.n.x,e.n.y,e.end.x,e.end.y,h[5],h[6]][R]();n+=i;e=+h[5];g=+h[6];continue}if(!a&&!b){e=ob(e,g,h[1],h[2],h[3],h[4],h[5],h[6],
+d-n);return{x:e.x,y:e.y,alpha:e.alpha}}}n+=i;e=+h[5];g=+h[6]}j+=h}m.end=j;e=a?n:b?m:l.findDotsAtSegment(e,g,h[1],h[2],h[3],h[4],h[5],h[6],1);e.alpha&&(e={x:e.x,y:e.y,alpha:e.alpha});return e}}var Nb=Z(function(a,b,c,d,f,e,g,h){for(var i={x:0,y:0},j=0,m=0;m<1.01;m+=0.01){var n=la(a,b,c,d,f,e,g,h,m);m&&(j+=E(E(i.x-n.x,2)+E(i.y-n.y,2),0.5));i=n}return j}),pb=Ma(1),Ba=Ma(),Na=Ma(0,1);s[p].getTotalLength=function(){if(this.type=="path"){if(this.node.getTotalLength)return this.node.getTotalLength();return pb(this.attrs.path)}};
+s[p].getPointAtLength=function(a){if(this.type=="path"){if(this.node.getPointAtLength)return this.node.getPointAtLength(a);return Ba(this.attrs.path,a)}};s[p].getSubpath=function(a,b){if(this.type=="path"){if(v.abs(this.getTotalLength()-b)<1.0E-6)return Na(this.attrs.path,a).end;b=Na(this.attrs.path,b,1);return a?Na(b,a).end:b}};l.easing_formulas={linear:function(a){return a},"<":function(a){return E(a,3)},">":function(a){return E(a-1,3)+1},"<>":function(a){a*=2;if(a<1)return E(a,3)/2;a-=2;return(E(a,
+3)+2)/2},backIn:function(a){var b=1.70158;return a*a*((b+1)*a-b)},backOut:function(a){a-=1;var b=1.70158;return a*a*((b+1)*a+b)+1},elastic:function(a){if(a==0||a==1)return a;var b=0.3,c=b/4;return E(2,-10*a)*v.sin((a-c)*2*v.PI/b)+1},bounce:function(a){var b=7.5625,c=2.75;if(a<1/c)a=b*a*a;else if(a<2/c){a-=1.5/c;a=b*a*a+0.75}else if(a<2.5/c){a-=2.25/c;a=b*a*a+0.9375}else{a-=2.625/c;a=b*a*a+0.984375}return a}};var T={length:0};function qb(){var a=+new Date;for(var b in T)if(b!="length"&&T[z](b)){var c=
+T[b];if(c.stop||c.el.removed){delete T[b];T[o]--}else{var d=a-c.start,f=c.ms,e=c.easing,g=c.from,h=c.diff,i=c.to,j=c.t,m=c.prev||0,n=c.el,r=c.callback,q={},k;if(d<f){r=l.easing_formulas[e]?l.easing_formulas[e](d/f):d/f;for(var t in g)if(g[z](t)){switch(Ga[t]){case "along":k=r*f*h[t];i.back&&(k=i.len-k);e=Ba(i[t],k);n.translate(h.sx-h.x||0,h.sy-h.y||0);h.x=e.x;h.y=e.y;n.translate(e.x-h.sx,e.y-h.sy);i.rot&&n.rotate(h.r+e.alpha,e.x,e.y);break;case P:k=+g[t]+r*f*h[t];break;case "colour":k="rgb("+[Oa(Q(g[t].r+
+r*f*h[t].r)),Oa(Q(g[t].g+r*f*h[t].g)),Oa(Q(g[t].b+r*f*h[t].b))][R](",")+")";break;case "path":k=[];e=0;for(var L=g[t][o];e<L;e++){k[e]=[g[t][e][0]];for(var B=1,w=g[t][e][o];B<w;B++)k[e][B]=+g[t][e][B]+r*f*h[t][e][B];k[e]=k[e][R](N)}k=k[R](N);break;case "csv":switch(t){case "translation":k=h[t][0]*(d-m);e=h[t][1]*(d-m);j.x+=k;j.y+=e;k=k+N+e;break;case "rotation":k=+g[t][0]+r*f*h[t][0];g[t][1]&&(k+=","+g[t][1]+","+g[t][2]);break;case "scale":k=[+g[t][0]+r*f*h[t][0],+g[t][1]+r*f*h[t][1],2 in i[t]?i[t][2]:
+A,3 in i[t]?i[t][3]:A][R](N);break;case "clip-rect":k=[];for(e=4;e--;)k[e]=+g[t][e]+r*f*h[t][e];break}break}q[t]=k}n.attr(q);n._run&&n._run.call(n)}else{if(i.along){e=Ba(i.along,i.len*!i.back);n.translate(h.sx-(h.x||0)+e.x-h.sx,h.sy-(h.y||0)+e.y-h.sy);i.rot&&n.rotate(h.r+e.alpha,e.x,e.y)}(j.x||j.y)&&n.translate(-j.x,-j.y);i.scale&&(i.scale+=A);n.attr(i);delete T[b];T[o]--;n.in_animation=null;l.is(r,"function")&&r.call(n)}c.prev=d}}l.svg&&n&&n.paper&&n.paper.safari();T[o]&&aa.setTimeout(qb)}function Oa(a){return Y(ba(a,
+255),0)}function Aa(a,b){if(a==null)return{x:this._.tx,y:this._.ty,toString:nb};this._.tx+=+a;this._.ty+=+b;switch(this.type){case "circle":case "ellipse":this.attr({cx:+a+this.attrs.cx,cy:+b+this.attrs.cy});break;case "rect":case "image":case "text":this.attr({x:+a+this.attrs.x,y:+b+this.attrs.y});break;case "path":var c=Ha(this.attrs.path);c[0][1]+=+a;c[0][2]+=+b;this.attr({path:c});break}return this}s[p].animateWith=function(a,b,c,d,f){T[a.id]&&(b.start=T[a.id].start);return this.animate(b,c,d,
+f)};s[p].animateAlong=rb();s[p].animateAlongBack=rb(1);function rb(a){return function(b,c,d,f){var e={back:a};l.is(d,"function")?(f=d):(e.rot=d);b&&b.constructor==s&&(b=b.attrs.path);b&&(e.along=b);return this.animate(e,c,f)}}s[p].onAnimation=function(a){this._run=a||0;return this};s[p].animate=function(a,b,c,d){if(l.is(c,"function")||!c)d=c||null;var f={},e={},g={};for(var h in a)if(a[z](h))if(Ga[z](h)){f[h]=this.attr(h);f[h]==null&&(f[h]=ta[h]);e[h]=a[h];switch(Ga[h]){case "along":var i=pb(a[h]),
+j=Ba(a[h],i*!!a.back),m=this.getBBox();g[h]=i/b;g.tx=m.x;g.ty=m.y;g.sx=j.x;g.sy=j.y;e.rot=a.rot;e.back=a.back;e.len=i;a.rot&&(g.r=y(this.rotate())||0);break;case P:g[h]=(e[h]-f[h])/b;break;case "colour":f[h]=l.getRGB(f[h]);i=l.getRGB(e[h]);g[h]={r:(i.r-f[h].r)/b,g:(i.g-f[h].g)/b,b:(i.b-f[h].b)/b};break;case "path":i=wa(f[h],e[h]);f[h]=i[0];j=i[1];g[h]=[];i=0;for(m=f[h][o];i<m;i++){g[h][i]=[0];for(var n=1,r=f[h][i][o];n<r;n++)g[h][i][n]=(j[i][n]-f[h][i][n])/b}break;case "csv":j=D(a[h])[G](V);i=D(f[h])[G](V);
+switch(h){case "translation":f[h]=[0,0];g[h]=[j[0]/b,j[1]/b];break;case "rotation":f[h]=i[1]==j[1]&&i[2]==j[2]?i:[0,j[1],j[2]];g[h]=[(j[0]-f[h][0])/b,0,0];break;case "scale":a[h]=j;f[h]=D(f[h])[G](V);g[h]=[(j[0]-f[h][0])/b,(j[1]-f[h][1])/b,0,0];break;case "clip-rect":f[h]=D(f[h])[G](V);g[h]=[];for(i=4;i--;)g[h][i]=(j[i]-f[h][i])/b;break}e[h]=j}}this.stop();this.in_animation=1;T[this.id]={start:a.start||+new Date,ms:b,easing:c,from:f,diff:g,to:e,el:this,callback:d,t:{x:0,y:0}};++T[o]==1&&qb();return this};
+s[p].stop=function(){T[this.id]&&T[o]--;delete T[this.id];return this};s[p].translate=function(a,b){return this.attr({translation:a+" "+b})};s[p][O]=function(){return"Rapha\u00ebl\u2019s object"};l.ae=T;function X(a){this.items=[];this[o]=0;this.type="set";if(a)for(var b=0,c=a[o];b<c;b++)if(a[b]&&(a[b].constructor==s||a[b].constructor==X)){this[this.items[o]]=this.items[this.items[o]]=a[b];this[o]++}}X[p][F]=function(){for(var a,b,c=0,d=arguments[o];c<d;c++)if((a=arguments[c])&&(a.constructor==s||
+a.constructor==X)){b=this.items[o];this[b]=this.items[b]=a;this[o]++}return this};X[p].pop=function(){delete this[this[o]--];return this.items.pop()};for(var Pa in s[p])if(s[p][z](Pa))X[p][Pa]=function(a){return function(){for(var b=0,c=this.items[o];b<c;b++)this.items[b][a][K](this.items[b],arguments);return this}}(Pa);X[p].attr=function(a,b){if(a&&l.is(a,U)&&l.is(a[0],"object")){b=0;for(var c=a[o];b<c;b++)this.items[b].attr(a[b])}else{c=0;for(var d=this.items[o];c<d;c++)this.items[c].attr(a,b)}return this};
+X[p].animate=function(a,b,c,d){(l.is(c,"function")||!c)&&(d=c||null);var f=this.items[o],e=f,g,h=this,i;d&&(i=function(){!--f&&d.call(h)});c=l.is(c,ga)?c:i;for(g=this.items[--e].animate(a,b,c,i);e--;)this.items[e].animateWith(g,a,b,c,i);return this};X[p].insertAfter=function(a){for(var b=this.items[o];b--;)this.items[b].insertAfter(a);return this};X[p].getBBox=function(){for(var a=[],b=[],c=[],d=[],f=this.items[o];f--;){var e=this.items[f].getBBox();a[F](e.x);b[F](e.y);c[F](e.x+e.width);d[F](e.y+
+e.height)}a=ba[K](0,a);b=ba[K](0,b);return{x:a,y:b,width:Y[K](0,c)-a,height:Y[K](0,d)-b}};X[p].clone=function(a){a=new X;for(var b=0,c=this.items[o];b<c;b++)a[F](this.items[b].clone());return a};l.registerFont=function(a){if(!a.face)return a;this.fonts=this.fonts||{};var b={w:a.w,face:{},glyphs:{}},c=a.face["font-family"];for(var d in a.face)if(a.face[z](d))b.face[d]=a.face[d];if(this.fonts[c])this.fonts[c][F](b);else this.fonts[c]=[b];if(!a.svg){b.face["units-per-em"]=ha(a.face["units-per-em"],10);
+for(var f in a.glyphs)if(a.glyphs[z](f)){c=a.glyphs[f];b.glyphs[f]={w:c.w,k:{},d:c.d&&"M"+c.d[I](/[mlcxtrv]/g,function(g){return{l:"L",c:"C",x:"z",t:"m",r:"l",v:"c"}[g]||"M"})+"z"};if(c.k)for(var e in c.k)if(c[z](e))b.glyphs[f].k[e]=c.k[e]}}return a};H[p].getFont=function(a,b,c,d){d=d||"normal";c=c||"normal";b=+b||{normal:400,bold:700,lighter:300,bolder:800}[b]||400;if(l.fonts){var f=l.fonts[a];if(!f){a=new RegExp("(^|\\s)"+a[I](/[^\w\d\s+!~.:_-]/g,A)+"(\\s|$)","i");for(var e in l.fonts)if(l.fonts[z](e))if(a.test(e)){f=
+l.fonts[e];break}}var g;if(f){e=0;for(a=f[o];e<a;e++){g=f[e];if(g.face["font-weight"]==b&&(g.face["font-style"]==c||!g.face["font-style"])&&g.face["font-stretch"]==d)break}}return g}};H[p].print=function(a,b,c,d,f,e){e=e||"middle";var g=this.set(),h=D(c)[G](A),i=0;l.is(d,c)&&(d=this.getFont(d));if(d){c=(f||16)/d.face["units-per-em"];var j=d.face.bbox.split(V);f=+j[0];e=+j[1]+(e=="baseline"?j[3]-j[1]+ +d.face.descent:(j[3]-j[1])/2);j=0;for(var m=h[o];j<m;j++){var n=j&&d.glyphs[h[j-1]]||{},r=d.glyphs[h[j]];
+i+=j?(n.w||d.w)+(n.k&&n.k[h[j]]||0):0;r&&r.d&&g[F](this.path(r.d).attr({fill:"#000",stroke:"none",translation:[i,0]}))}g.scale(c,c,f,e).translate(a-f,b-e)}return g};var Ob=/\{(\d+)\}/g;l.format=function(a,b){var c=l.is(b,U)?[0][M](b):arguments;a&&l.is(a,ga)&&c[o]-1&&(a=a[I](Ob,function(d,f){return c[++f]==null?A:c[f]}));return a||A};l.ninja=function(){Qa.was?(Raphael=Qa.is):delete Raphael;return l};l.el=s[p];return l}();
More information about the Mapbender_commits
