[Mapbender-commits] r6639 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Mon Jul 26 07:25:32 EDT 2010
Author: kmq
Date: 2010-07-26 11:25:32 +0000 (Mon, 26 Jul 2010)
New Revision: 6639
trunk/mapbender/lib/mb.ui.displayFeatures.js
clickhandler for georss honors all feeds
Modified: trunk/mapbender/lib/mb.ui.displayFeatures.js
--- trunk/mapbender/lib/mb.ui.displayFeatures.js 2010-07-26 10:26:03 UTC (rev 6638)
+++ trunk/mapbender/lib/mb.ui.displayFeatures.js 2010-07-26 11:25:32 UTC (rev 6639)
@@ -35,9 +35,8 @@
_feeds: {},
_popup : null,
- _init: function(){
+ _create: function(){
var that = this, o = this.options;
- this._popup = $('<div></div>').dialog({autoOpen : false, height: 500, width: 500});
this.element.click( function(e){
var map = that.element.mapbender();
var pos = map.getMousePosition(e);
@@ -50,6 +49,8 @@
// after that's finished the results are merged and displayed in a box
var pointGeometries = {};
var g,h,nodes = null;
+ $("*",that._popup).remove();
+ var $tabs = $("<ul></ul>");
for (var i in that._feeds){
feed = that._feeds[i] ;
requestGeometries = [];
@@ -68,7 +69,6 @@
// theywill be merged with the ones coming from the
// server
pointGeometries[j] = true;
- // console.log(nodes[0]);
}else{
@@ -94,12 +94,9 @@
- $("*",that._popup).remove();
- var $tabs = $("<ul></ul>");
// this iterates over an object where the keys are _not_ the incremential
- // basically a sparse array. therefore I cannot be used to count the entries in the object
+ // basically a sparse array. therefore It cannot be used to count the entries in the object
// this is why j is used
- var j = 0;
for(i in result.geometries){
var g = geomArray.get(i);
title = g.e.getElementValueByName("title");
@@ -119,33 +116,34 @@
description = g.e.getElementValueByName("description");
$tabs.append('<li><a href="#rsspopup_'+ i +'">'+ title + '</a></li>');
that._popup.append('<div id="rsspopup_'+ i +'"><h1>'+ title +'</h1><p>'+ description +'</p></h1>');
- j++;
+ if($tabs.children().size() > 1){
+ var $tabcontainer = $("<div><div>");
+ $tabcontainer.append($tabs);
+ $tabcontainer.append($('div',that._popup));
+ that._popup.append($tabcontainer);
+ $tabcontainer.tabs();
+ that._popup.dialog('open');
- if(j > 1){
- var $tabcontainer = $("<div><div>");
- $tabcontainer.append($tabs);
- $tabcontainer.append($('div',that._popup));
- that._popup.append($tabcontainer);
- $tabcontainer.tabs();
- that._popup.dialog('open');
- )(feed.geomArray, pointGeometries)
+ };})(feed.geomArray, pointGeometries)
req.send();
+ _init: function(){
+ var that = this, o = this.options;
+ this._popup = $('<div></div>').dialog({autoOpen : false, height: 500, width: 500});
if(o.url){
that._load(o.url);
- _create: function(){
_load : function(url){
@@ -164,7 +162,7 @@
loadError(data.errorMessage);
return;
- that._display(data);
+ that._display(data,url);
error: function(XMLHttpRequest, textStatus, errorThrown){
loadError("could not load "+o.url);
@@ -173,7 +171,7 @@
- _display : function(geoJSON){
+ _display : function(geoJSON,url){
var $map = $(that.element).mapbender();
More information about the Mapbender_commits
