[Mapbender-commits] r6640 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jul 26 09:56:48 EDT 2010
Author: christoph
Date: 2010-07-26 13:56:48 +0000 (Mon, 26 Jul 2010)
New Revision: 6640
   trunk/mapbender/http/javascripts/mod_measure.php
new mouse events
Modified: trunk/mapbender/http/javascripts/mod_measure.php
--- trunk/mapbender/http/javascripts/mod_measure.php	2010-07-26 11:25:32 UTC (rev 6639)
+++ trunk/mapbender/http/javascripts/mod_measure.php	2010-07-26 13:56:48 UTC (rev 6640)
@@ -20,16 +20,22 @@
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
 echo "var mod_measure_target = '".$e_target[0]."';";
 var mod_measure_color1 = "white";
 var mod_measure_color2 = "black";
 var mod_measure_font = "Arial, Helvetica, sans-serif";
-var mod_measure_fontsize = "9px";
-var mod_measure_basepoint = "#8a2be2";
-var mod_measure_linepoint = "#ff00ff";
+var mod_measure_fontsize = "10px";
+var mod_measure_basepoint = "#FF0000";
+var mod_measure_line = "#005395";
+var mod_measure_poly = "#c1d0e3";
+var mod_measure_line_opacity = "1";
+var mod_measure_poly_opacity = "0.2";
 var mod_measure_bg = "";
 var mod_measure_pgsql = true;
+var polygonIsSimple = true;
+var MeasureIsPolygon = false;
 var mod_measure_win = null;
 var mod_measure_elName = "measure";
@@ -43,6 +49,15 @@
 var mod_measure_Dist = new Array();
 var mod_measure_TotalDist = new Array();
+var mod_measure_WinContent_header = "<div style='font-family:verdana;font-size:12px;margin:5pt;'>";
+var mod_measure_WinContent_koord = "Koordinate:<br>";
+var mod_measure_WinContent_strecke = "<br>";
+var mod_measure_WinContent_flaeche = "<br>";
+var mod_measure_WinContent_clear = "<br><img src='../http_ms/img/button_ms/clear_off.png' onclick='javascript:mod_measure_clear();' onmouseover='this.src = this.src.replace(/_off/,\"_over\");' onmouseout='this.src = this.src.replace(/_over/,\"_off\");'  alt='Messung l&ouml;schen'  title='Messung l&ouml;schen'>";
+var mod_measure_WinContent_footer = "</div>";
+var MeasurePaper;
 // global variable
 window.eventAfterMeasure = new MapbenderEvent();
@@ -50,9 +65,15 @@
 var mod_measure_img_off = new Image(); mod_measure_img_off.src = "<?php  echo $e_src;  ?>";
 var mod_measure_img_over = new Image(); mod_measure_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+function mod_measure_update(){
+   MeasureWin.setHtml(mod_measure_WinContent_header+mod_measure_WinContent_koord+mod_measure_WinContent_strecke+mod_measure_WinContent_flaeche+mod_measure_WinContent_clear+mod_measure_WinContent_footer);
 function init_mod_measure(ind){
+  local_ind=ind;
 	mod_measure_mapObj = getMapObjByName(mod_measure_target);
 	//ensure we have the div elements in Mapframe
 	var map_el = mod_measure_mapObj.getDomElement()
@@ -98,44 +119,69 @@
 		drawDashedLine();
 	mb_registerPanSubElement(mod_measure_target+"_measuring");
+	MeasurePaper = Raphael(el, mod_measure_width, mod_measure_height);
 function mod_measure_go(){
 	var el = mod_measure_mapObj.getDomElement();
-	el.onmousedown = mod_measure_start;
-	el.onmousemove = mod_measure_run;
-	el.onmouseover = function () {
+	if (el) {
+		$(el).bind("mousedown", mod_measure_start)
+			.bind("mousemove", mod_measure_run);
 		el.style.cursor = 'crosshair';
-	el.onmouseout = function () {
-		el.style.cursor = 'auto';
 	var measureSub = eventAfterMeasure.trigger({}, "CAT");
-	writeTag("",mod_measure_target+"_measure_sub",measureSub);
+	MeasureWin = new mb_popup({
+			title:"Messung",frameName:"",
+			left:265,top:75,width:250,height:120,
+			html: mod_measure_WinContent_header+"Fahren Sie mit der Maus &uuml;ber die Karte, um die Koordinaten anzuzeigen.<br> Klicken Sie, um eine Messung zu starten"+ mod_measure_WinContent_footer,
+			closeCallback:function(){mod_measure_disable();}
+  MeasureWin.show();
 function mod_measure_disable(){
-	el.onmousedown = null;
-	el.onmousemove = null;
-	el.onmouseover = null;
-	el.onmouseout = null;
+	if (el) {
+		$(el).unbind("mousedown", mod_measure_start)
+			.unbind("mousemove", mod_measure_run);
+		el.style.cursor = 'auto';
 	writeTag("",mod_measure_target+"_measure_display","");
-	writeTag("",mod_measure_target+"_measure_sub","");
+	MeasureWin.destroy();
+	mod_measure_delete();
+	parent.mb_disableThisButton('measure');
 function mod_measure_timeout(){
-	var el = mod_measure_mapObj.getDomElement();
-	el.ondblclick = null;
+	var el = mod_measure_mapObj.getDomElement();
+	if (el) {
 function mod_measure_disableTimeout(){
+	if (el) {
 function mod_measure_start(e){
-	mod_measure_mapObj.getMousePos(e);
+	var pos = mod_measure_mapObj.getMousePosition(e);
-	var realWorldPos = makeClickPos2RealWorldPos(mod_measure_target,clickX,clickY);
+	var realWorldPos = makeClickPos2RealWorldPos(mod_measure_target, pos.x, pos.y);
 	if(mod_measure_epsg=="EPSG:4326"){
 		mod_measure_RX[mod_measure_RX.length] = realWorldPos[0];
 		mod_measure_RY[mod_measure_RY.length] = realWorldPos[1];
@@ -168,8 +214,28 @@
 		mod_measure_Dist[mod_measure_Dist.length] = 0;
 		mod_measure_TotalDist[mod_measure_TotalDist.length] = 0;
+	if (polygonIsSimple){checkpolygon()};
+	var closedist_x = Math.abs(mod_measure_RX[0] - mod_measure_RX[mod_measure_RX.length-1]);
+	var closedist_y = Math.abs(mod_measure_RY[0] - mod_measure_RY[mod_measure_RY.length-1]);
+  var	closedist = Math.round(Math.sqrt(Math.pow(closedist_x,2) + Math.pow(closedist_y,2))*100)/100;
+	if (closedist > mod_measure_TotalDist[mod_measure_TotalDist.length-1]/2 ) {MeasureIsPolygon = false} else {MeasureIsPolygon = true}
 	drawDashedLine();
+	if(mod_measure_RX.length == 1){
+     mod_measure_WinContent_strecke="Punkt: "+mod_measure_RX[0]+" "+mod_measure_RY[0]+"<br>";
+  } else {
+	   mod_measure_WinContent_strecke="Strecke: "+Math.round(mod_measure_TotalDist[mod_measure_TotalDist.length-1]*10)/10+" m<br>";
+	tmp_area = mod_measure_calc_area();
+  if (tmp_area != '' && polygonIsSimple && MeasureIsPolygon){
+      mod_measure_WinContent_flaeche="Fl&auml;che: "+mod_measure_calc_area()+"<br>";
+  } else {
+      mod_measure_WinContent_flaeche="<br>";
+  mod_measure_update();
 function drawDashedLine(){
 	//check if epsg has changed
 	mod_measure_width = mod_measure_mapObj.width;
@@ -178,51 +244,28 @@
 		mod_measure_epsg = mod_measure_mapObj.epsg;
-	var str_mPoints = "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mod_measure_width+"' height='0'></div>";
-	str_mPoints += "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='0' height='"+mod_measure_height+"'></div>";
-	for(var i=0; i<mod_measure_RX.length; i++){
-		var pos = makeRealWorld2mapPos(mod_measure_target,mod_measure_RX[i],mod_measure_RY[i]);
-		str_mPoints += "<div style='font-size:1px;position:absolute;top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;width:4px;height:4px;background-color:"+mod_measure_basepoint+"'></div>";
-		if(i>0){
-			str_mPoints += "<div  style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color1+";";
-			if(mod_measure_bg != ""){
-				str_mPoints += "background-color:"+mod_measure_bg+";";
-			str_mPoints += "position:absolute;top:"+(pos[1] + 3)+"px;left:"+(pos[0]+3)+"px;z-index:20'>"+mod_measure_TotalDist[i]+"</div>";
-			str_mPoints += "<div  style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color2+";position:absolute;top:"+(pos[1] + 4)+"px;left:"+(pos[0]+4)+"px;z-index:21'>"+mod_measure_TotalDist[i]+"</div>";
-	if(mod_measure_RX.length>1){
-		for(var k=1; k<mod_measure_RX.length; k++){
+	MeasurePaper.clear();
+	if(mod_measure_RX.length>0){
+	 var str_path;
+		for(var k=0; k<mod_measure_RX.length; k++){
 			var pos0 = makeRealWorld2mapPos(mod_measure_target,mod_measure_RX[k], mod_measure_RY[k]);
-			var pos1 = makeRealWorld2mapPos(mod_measure_target,mod_measure_RX[k-1], mod_measure_RY[k-1]);
-			str_mPoints += evaluateDashes(pos1[0],pos1[1],pos0[0],pos0[1],k);
+			if (k == 0){str_path += 'M'} else {str_path += 'L'};
+      str_path += pos0[0]+' '+pos0[1];
+      var circle = MeasurePaper.circle(pos0[0],pos0[1],3);
+      if (k==0){circle.attr({fill: mod_measure_basepoint, stroke: "none", opacity: mod_measure_line_opacity})}else{circle.attr({fill:  mod_measure_line, stroke: "none", opacity: mod_measure_line_opacity})};
-	writeTag("",mod_measure_target+"_measuring",str_mPoints);
+  if (mod_measure_RX.length >2 && polygonIsSimple && MeasureIsPolygon) {
+	   poly = MeasurePaper.path(str_path + 'Z');
+	   poly.attr({fill:  mod_measure_poly, opacity:  mod_measure_poly_opacity});
+	   //poly.toFront();
+	var line = MeasurePaper.path(str_path);
+	line.attr({stroke:  mod_measure_line, "stroke-width": 2, opacity: mod_measure_line_opacity});
+	line.toFront();
-function evaluateDashes(x1,y1,x2,y2,count){
-	var str_dashedLine = "";
-	var s = 10;
-	var d = Math.sqrt(Math.pow((y1-y2),2) + Math.pow((x1-x2),2)) ;
-	var n = Math.round(d/s);
-	var s_x =  (x2 - x1)/n;
-	var s_y =  (y2 - y1)/n;
-	for(var i=1; i<n; i++){
-		var x = Math.round(x1 + i * s_x)-2;
-		var y = Math.round(y1 + i * s_y)-2;
-		if(x >= 0 && x <= mod_measure_width && y >= 0 && y <= mod_measure_height){
-			str_dashedLine += "<div style='font-size:1px;position:absolute;top:"+y+"px;left:"+x+"px;width:4px;height:4px;background-color:"+mod_measure_linepoint+"'></div>";
-	str_dashedLine += "<div style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color1+";";
-		str_dashedLine += "background-color:"+mod_measure_bg+";";
-	str_dashedLine += "position:absolute;top:"+(Math.round(y1 + (y2-y1)/2 +3))+"px;left:"+(Math.round(x1 + (x2-x1)/2 +3))+"px'>"+mod_measure_Dist[count]+"</div>";
-	str_dashedLine += "<div style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color2+";position:absolute;top:"+(Math.round(y1 + (y2-y1)/2 + 4))+"px;left:"+(Math.round(x1 + (x2-x1)/2+4))+"px'>"+mod_measure_Dist[count]+"</div>";
-	return str_dashedLine;
 function mod_measure_run(e){
 	var pos = makeClickPos2RealWorldPos(mod_measure_target,clickX,clickY);
@@ -240,135 +283,75 @@
 		var dist_y = Math.abs(mod_measure_RY[mod_measure_RY.length-1] - pos[1]);
 		dist=Math.sqrt(dist_x*dist_x+dist_y*dist_y);
-	if(isNaN(dist) == false && clickX > 0 && clickX < mod_measure_width && clickY > 0 && clickY < mod_measure_height){
+	if(isNaN(dist) == false && pos.x > 0 && pos.x < mod_measure_width && pos.y > 0 && pos.y < mod_measure_height){
 		var str_display = "<span style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color2+";'>"+(Math.round(dist*100)/100)+" m</span>";
 		writeTag("", mod_measure_target+"_measure_display",str_display);
-		mb_arrangeElement("",mod_measure_target+"_measure_display",clickX +2, clickY - 10);
+		mb_arrangeElement("",mod_measure_target+"_measure_display",pos.x +2, pos.y - 10);
 	else{
+	mod_measure_WinContent_koord="Koordinate: "+Math.round(pos[0])+ " "+Math.round(pos[1])+"<br>";
-function mod_measure_close(){
-	if(mod_measure_RX.length < 3 || (mod_measure_RX[mod_measure_RX.length-1] == mod_measure_RX[0] && mod_measure_RY[mod_measure_RY.length-1] == mod_measure_RY[0])){return;}
-	mod_measure_RX[mod_measure_RX.length] = mod_measure_RX[0];
-	mod_measure_RY[mod_measure_RY.length] = mod_measure_RY[0];
-	if(mod_measure_RX.length > 1){
-		var dist;
-		if(mod_measure_epsg=="EPSG:4326"){
-			//convert coordinates to radian
-			var lon_from=(mod_measure_RX[mod_measure_RX.length-2]*Math.PI)/180;
-			var lat_from=(mod_measure_RY[mod_measure_RY.length-2]*Math.PI)/180;
-			var lon_to=(mod_measure_RX[mod_measure_RX.length-1]*Math.PI)/180;
-			var lat_to=(mod_measure_RY[mod_measure_RY.length-1]*Math.PI)/180;
-			dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
-			dist=Math.round(dist*100)/100;
-		else{
-			var dist_x = Math.abs(mod_measure_RX[mod_measure_RX.length-2] - mod_measure_RX[mod_measure_RX.length-1]);
-			var dist_y = Math.abs(mod_measure_RY[mod_measure_RY.length-2] - mod_measure_RY[mod_measure_RY.length-1]);
-			dist = Math.round(Math.sqrt(Math.pow(dist_x,2) + Math.pow(dist_y,2))*100)/100;
-		mod_measure_Dist[mod_measure_Dist.length] = dist;
-		var totalDist = mod_measure_TotalDist[mod_measure_TotalDist.length-1] + dist;
-		mod_measure_TotalDist[mod_measure_TotalDist.length] = Math.round(totalDist * 100)/100;
-	else{
-		mod_measure_Dist[mod_measure_Dist.length] = 0;
-		mod_measure_TotalDist[mod_measure_TotalDist.length] = 0;
-	drawDashedLine();
 function mod_measure_delete(){
+	mod_measure_clear();
+function mod_measure_clear(){
 	mod_measure_RX = new Array();
 	mod_measure_RY = new Array();
 	writeTag("",mod_measure_target+"_measuring","");
+	mod_measure_WinContent_strecke = "<br>";
+	mod_measure_WinContent_flaeche = "<br>";
+	polygonIsSimple = true;
-var mod_closePolygon_img = new Image();
-mod_closePolygon_img.src = "../img/button_gray/closePolygon_off.gif";
-mod_closePolygon_img.title = '<?php echo _mb("Close polygon");?>';
-eventAfterMeasure.register(function(){
-	return mod_closePolygon();
-function mod_closePolygon(){
-	var str =  "<div style='position:absolute;top:25px' onmouseup='mod_closePolygon_go()' ";
-	str += "onmouseover='mod_measure_timeout()' onmouseout='mod_measure_disableTimeout()'><img src='"+mod_closePolygon_img.src+"' style='cursor:pointer' title='"+mod_closePolygon_img.title+"'></div>";
-	return str;
+function mod_measure_calc_area(){
+  if(mod_measure_RX.length < 3 || (mod_measure_RX[mod_measure_RX.length-1] == mod_measure_RX[0] && mod_measure_RY[mod_measure_RY.length-1] == mod_measure_RY[0])){return "";}
+	var area = 0;
+	for (var i=1;i<mod_measure_RX.length;i++)  {
+      area +=  (Number(mod_measure_RY[i-1])+Number(mod_measure_RY[i]))*(Number(mod_measure_RX[i-1])-Number(mod_measure_RX[i]))/2;
+  area += (mod_measure_RY[mod_measure_RX.length-1]+mod_measure_RY[0])*(mod_measure_RX[mod_measure_RX.length-1]-mod_measure_RX[0])/2;
+  area= Math.abs(area);
+  if (area > 10000000){
+    area /= 1000000; return Math.round(area*10)/10+" km&sup2;";
+  } else if (area > 100000){
+    area /= 10000; return Math.round(area*10)/10+" ha";
+  } else {
+    return Math.round(area*10)/10+" m&sup2;";
-function mod_closePolygon_go(){
-	mod_measure_close();
-var mod_rubber_img = new Image();
-mod_rubber_img.src = "../img/button_gray/rubber_off.gif";
-mod_rubber_img.title = '<?php echo _mb("Rubber");?>';
-eventAfterMeasure.register(function () {
-	return mod_rubber();
-function mod_rubber(){
-   var str =  "<div onmouseup='mod_rubber_go()' onmouseover='mod_measure_timeout()' onmouseout='mod_measure_go()'><img src='"+mod_rubber_img.src+"' style='cursor:pointer' title='"+mod_rubber_img.title+"'></div>";
-   return str;
+function checkpolygon(){
+  for (var i=1;i<mod_measure_RX.length-2;i++)  {
+    if (line_intersect(mod_measure_RX[i-1],mod_measure_RY[i-1],mod_measure_RX[i],mod_measure_RY[i],mod_measure_RX[mod_measure_RX.length-2],mod_measure_RY[mod_measure_RX.length-2],mod_measure_RX[mod_measure_RX.length-1],mod_measure_RY[mod_measure_RX.length-1] ) ) {polygonIsSimple = false}
-function mod_rubber_go(){
-   mod_measure_delete();
-var mod_getArea_img = new Image();
-mod_getArea_img.src = "../img/button_gray/getArea_off.gif";
-mod_getArea_img.title = '<?php echo _mb("Get area");?>';
-	return mod_getArea();
-function mod_getArea(){
-	var str =  "<div id='getAreaButton' style='position:absolute;top:50px' onmouseup='mod_getArea_go()' ";
-	str += "onmouseover='mod_measure_timeout()' onmouseout='mod_measure_disableTimeout()'><img src='"+mod_getArea_img.src+"' style='cursor:pointer' title='"+mod_getArea_img.title+"'></div>";
-	return str;
-function mod_getArea_go(){
-	if(mod_measure_RX[mod_measure_RX.length -1] == mod_measure_RX[0] && mod_measure_RY[mod_measure_RY.length -1] == mod_measure_RY[0]){
-		var ind = getMapObjIndexByName(mod_measure_target);
-		var url = "../php/mod_evalArea.php?x=";
-		for(var i=0; i<mod_measure_RX.length;i++){
-			if(i>0){ url += ",";}
-			url += mod_measure_RX[i];
-		url += "&y=";
-		for(var i=0; i<mod_measure_RY.length;i++){
-			url += mod_measure_RY[i];
-		var srs = mb_mapObj[ind].epsg.split(":");
-		url += "&srs="+ escape(srs[1]);
-		url += "&length=" + mod_measure_TotalDist[mod_measure_TotalDist.length-1];
-		url += "&distance="  + mod_measure_TotalDist[mod_measure_TotalDist.length-2];
-		if(!mod_measure_win || mod_measure_win == null || mod_measure_win.closed == true){
-			mod_measure_win = window.open(url,"mod_measure_win","width=200,height=150,resizable=yes");
-		else{
-			mod_measure_win.document.location.href = url;
-		mod_measure_win.focus();
-	else{
-			mod_measure_win = window.open("","mod_measure_win","width=200,height=150,resizable=yes");
-			mod_measure_win.document.open("text/html");
-			mod_measure_win.document.write("<span style = 'font-family : Arial, Helvetica, sans-serif;font-size : 12px;font-weight : bold;';>Strecke: " +mod_measure_TotalDist[mod_measure_TotalDist.length-1]+" m</span>");
-			mod_measure_win.document.close();
-		else{
+function line_intersect ( a1, a2, b1, b2, c1, c2, d1, d2 ) {
+  var s;
+  var t;
+  //alert (a1+' '+a2+' '+b1+' '+b2+' '+c1+' '+c2+' '+d1+' '+d2);
+  var N = (b1-a1)*(d2-c2)-(b2-a2)*(d1-c1);
+  if (N == 0) {
+    // Strecken sind parallel
+    return false;
+  } else {
+    s = ((c1-a1)*(d2-c2)-(c2-a2)*(d1-c1)) / N;
+    t = (a1-c1 + s*(b1-a1)) / (d1-c1);
+    if (s <= 1 && s>=0 && t <= 1 && t>=0){return true;}else {return false;};
\ No newline at end of file
More information about the Mapbender_commits mailing list
