[Mapbender-commits] r6661 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Jul 30 05:35:08 EDT 2010
Author: christoph
Date: 2010-07-30 09:35:08 +0000 (Fri, 30 Jul 2010)
New Revision: 6661
trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php
use jQuery mouse events, not DOM
Modified: trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php
--- trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php 2010-07-30 09:34:33 UTC (rev 6660)
+++ trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php 2010-07-30 09:35:08 UTC (rev 6661)
@@ -21,6 +21,7 @@
include '../include/dyn_js.php';
//defaults for element vars
if(typeof(featureInfoLayerPopup)==='undefined')
var featureInfoLayerPopup = 'false';
if(typeof(featureInfoPopupHeight)==='undefined')
@@ -55,12 +56,19 @@
mod_featureInfoTunnel_map = getMapObjByName(mod_featureInfoTunnel_target);
function mod_featureInfoTunnel_click(){
- mod_featureInfoTunnel_map.getDomElement().onclick = mod_featureInfoTunnel_event;
+ var domNode = mod_featureInfoTunnel_map.getDomElement();
+ if (domNode) {
+ $(domNode).bind("click", mod_featureInfoTunnel_event);
mod_featureInfoTunnel_map.getDomElement().style.cursor = "help";
function mod_featureInfoTunnel_disable(){
- mod_featureInfoTunnel_map.getDomElement().onclick = null;
+ if (domNode) {
+ $(domNode).unbind("click", mod_featureInfoTunnel_event);
mod_featureInfoTunnel_map.getDomElement().style.cursor = "default";
@@ -82,7 +90,7 @@
map_el.appendChild($div.get(0));
- var point = mod_featureInfoTunnel_map.getMousePos(e);
+ var point = mod_featureInfoTunnel_map.getMousePosition(e);
var path = '../extensions/ext_featureInfoTunnel.php';
//TODO that code should go to featureInfo Redirect module
@@ -101,7 +109,7 @@
for(var i=0;i<urls.length;i++){
(function () {
var currentMapObjWidth = point.x;
- var currentMapObjHeight = point.y;
+ var currentMapObjHeight = point.y;
$("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").html("<img src='../img/indicator_wheel.gif'/>");
$("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").css({
position: "absolute",
@@ -114,6 +122,7 @@
var currentRequest = urls[i];
var cnt = i;
$(".fiResultFrame").remove();
mb_ajax_post(path, {'url':currentRequest},function(js_code,status){
if(js_code){
if(featureInfoLayerPopup == 'true') {
More information about the Mapbender_commits
