[Mapbender-commits] r6662 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Jul 30 05:36:04 EDT 2010
Author: christoph
Date: 2010-07-30 09:36:03 +0000 (Fri, 30 Jul 2010)
New Revision: 6662
trunk/mapbender/http/javascripts/mod_resize_mapsize.js
using jQuery getWidth and getHeight
bugfix in rebuild: problem with scrollbars
Modified: trunk/mapbender/http/javascripts/mod_resize_mapsize.js
--- trunk/mapbender/http/javascripts/mod_resize_mapsize.js 2010-07-30 09:35:08 UTC (rev 6661)
+++ trunk/mapbender/http/javascripts/mod_resize_mapsize.js 2010-07-30 09:36:03 UTC (rev 6662)
@@ -67,12 +67,12 @@
var resize_option = options.resize_option;
-if (!options.adjust_width) {
+if (typeof options.adjust_width == "undefined") {
options.adjust_width = -45;
var adjust_width = options.adjust_width;
-if (!options.adjust_height) {
+if (typeof options.adjust_height === "undefined") {
options.adjust_height = -90;
var adjust_height = options.adjust_height;
@@ -88,23 +88,12 @@
var width_temp, height_temp;
function frameWidth(){
- if (window.innerWidth) {
- return window.innerWidth;
- else if (document.body && document.body.offsetWidth) {
- return document.body.offsetWidth;
- return 0;
+ return $(window).width();
function frameHeight(){
- if (window.innerHeight) {
- return window.innerHeight;
- else if (document.body && document.body.offsetHeight) {
- return document.body.offsetHeight;
- return 0;
+ return $(window).height();
function adjustDimension(skipMapRequest) {
@@ -128,26 +117,29 @@
function rebuild() {
- if (width_temp != frameWidth() || height_temp != frameHeight()) {
- window.setTimeout(function () {
- adjustDimension()
- }, 500);
+ setTimeout(function () {
+ // has to be called twice: the first request does a resize,
+ // which will remove potential scrollbars.
+ // After the scrollbars are removed, the window width and height
+ // have changed, so another functiona call is necessary to fill
+ // this space
+ adjustDimension(true);
+ //adjustDimension();
+ adjustDimension(false);
+ }, 300);
+ }, 100);
function control(skipMapRequest){
- adjustDimension(skipMapRequest);
- if (!window.width_temp && window.innerWidth) {
- window.onresize = rebuild;
- width_temp = frameWidth();
- height_temp = frameHeight();
+ adjustDimension(skipMapRequest);
+ if (!width_temp && frameWidth()) {
+ $(window).bind("resize", rebuild);
+ width_temp = frameWidth();
+ height_temp = frameHeight();
- if (!window.width_temp && document.body && document.body.offsetWidth) {
if (resize_option == 'auto'){
More information about the Mapbender_commits
