[Mapbender-commits] r6270 - in trunk/mapbender: http/javascripts
	http/plugins lib
    svn_mapbender at osgeo.org
    Tue Jun 15 08:10:51 EDT 2010
Author: kmq
Date: 2010-06-15 12:10:51 +0000 (Tue, 15 Jun 2010)
New Revision: 6270
   trunk/mapbender/http/javascripts/geometry.js
   trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
   trunk/mapbender/lib/point.js
rework the georss display to show more than just points
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js	2010-06-15 09:46:58 UTC (rev 6269)
+++ trunk/mapbender/http/javascripts/geometry.js	2010-06-15 12:10:51 UTC (rev 6270)
@@ -874,6 +874,9 @@
 			text += ")";
+		else if(this.geomType == geomType.point){
+			text = this.get(0).toText();
 	return text;
@@ -1284,6 +1287,15 @@
 			break;
+		case geomType.point:
+			var point = this.get(0);
+			if(typeof(!point.z)) {
+				return "POINT(" +point.x + " " + point.y + ")";
+			else {
+				return "POINT Z (" + point.x + " " + point.y + " " + point.z + ")";
+			break;
 	return text;
Modified: trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
--- trunk/mapbender/http/plugins/mb_loadkmlgeorss.js	2010-06-15 09:46:58 UTC (rev 6269)
+++ trunk/mapbender/http/plugins/mb_loadkmlgeorss.js	2010-06-15 12:10:51 UTC (rev 6270)
@@ -75,6 +75,7 @@
 var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
 var that = this;
+that.feeds = [];
 $('<div id="'+ options.id +'_dialog"><label>GeoRSS <input type="radio" name="type" value="GeoRSS" checked="checked"/></label>'+
 	 '<label>KML<input type="radio" name="type" value="KML"></label><br />'+
@@ -114,76 +115,57 @@
 							var popup = null;
 							$("table", $dialog).remove();
 							var $table = $("<table><thead><tr><th class='labelName'>"+ translatedI18nObject.labelName  +"</th></tr></thead><tbody></tbody></table>");
 							if(data.features){
 								// we always transform _from_ 4326 geoRSS and KML use this as their default
 								var projSrc = new Proj4js.Proj('EPSG:4326');
 								var projDest = new Proj4js.Proj($map.epsg);
 								var markeroptions = {width: "19px", height: "34px"};
-								for(var i in data.features){
-									title = data.features[i].properties.title || data.features[i].properties.name || translatedI18nObject.labelUntitled;
-									$row = $("<tr><td>"+ title +"</td></tr>");
-									if(data.features[i].properties.iconurl){
-										markeroptions.img = {url: data.features[i].properties.iconurl, offset: {x:0,y:0}} ;
-									var x = data.features[i].geometry.coordinates[0];
-									var y = data.features[i].geometry.coordinates[1];
-									point = Proj4js.transform(projSrc, projDest,new Mapbender.Point(x,y));
-									marker = new Mapbender.Marker(point,$map, markeroptions);
-									markers.push(marker);
+								var g = null;
+								var map = $('#mapframe1').mapbender();
+								//title = feature.properties.title || feature.properties.name || translatedI18nObject.labelUntitled;
-									$row.click((function(feature, marker, markerIndex){
-										return function(){
-											var x = feature.geometry.coordinates[0];
-											var y = feature.geometry.coordinates[1];
-											var buffer = new Mapbender.Point(options.buffer,options.buffer);
-											var a = Proj4js.transform(projSrc,projDest,new Mapbender.Point(x,y));
-											a = a.minus(buffer);
+								var geomArray = new GeometryArray();
+								geomArray.importGeoJSON(data);
+								var h = new Highlight(['mapframe1'], "mapframe1_" + parseInt(Math.random()*100000,10),{
+									"position":"absolute",
+									"top": "0px",
+									"left": "0px",
+									"z-index": "80" },1);
+								for(var i =0; i < geomArray.count(); i++){
+									g = geomArray.get(i);
-											var b = Proj4js.transform(projSrc,projDest,new Mapbender.Point(x,y));
-											b = b.plus(buffer);
+									// per feature stuff
+									//g.e.setElement("Mapbender:icon", options.img.url); //? where to get, let the server do it ?
+									//g.e.setElement("Mapbender:iconOffsetX", options.img.offset.x);
+									//g.e.setElement("Mapbender:iconOffsetY", options.img.offset.y);
+									//g.e.setElement("Mapbender:iconZIndex", options.img.offset.y);
-											$map.calculateExtent( new Mapbender.Extent(a,b));
-											$map.setMapRequest();
-											var offset = $('#'+options.target).offset();
-											var mapPoint = $map.convertRealToPixel(Proj4js.transform(projSrc,projDest, new Mapbender.Point(x,y)));
-											marker.remove();
-											point = Proj4js.transform(projSrc, projDest, new Mapbender.Point(x,y));
-											var markeroptions = {width: "19px", height: "34px", img:{url: "../img/marker/orange.png", offset: new Point(-10,-34)}};
-											var highlightmarker = new Mapbender.Marker(point,$map, markeroptions);
-											$('<div style="max-height:20em; max-width:20em">'+ feature.properties.description + "</div>").dialog({
-												title: feature.properties.title || feature.properties.name || translatedI18nObject.labelUntitled,
-												position: [mapPoint.x+offset.left+20, mapPoint.y + offset.top+20 ],
-												autoOpen: true,
-												buttons : {"Close" :function(){
-													$(this).dialog("close");
-												close: function(){
-													highlightmarker.remove();
-													var markeroptions = {width: "19px", height: "34px"};
-													if(feature.properties.iconurl){
-														markeroptions.img = {url: feature.properties.iconurl, offset: {x:0,y:0}} ;
-									})(data.features[i], marker));
-									$row.css("cursor","pointer");
-									$("tbody",$table).append($row);
+									h.add(g);
+								h.paint();
+								map.events.afterMapRequest.register(function () {
+									h.paint();
+								var index = that.feeds.push({
+									url: url,
+									geomArray: geomArray,
+									highlight: h,
+								index--; //push returns the length
 							var $tableDialog = $("<div></div>").dialog({
 								width: "450",
 								height: "500",
 								position: options.position,
 								beforeclose: function(){
+									h.clean();
 									for(var i in markers){
 										markers[i].remove();
@@ -217,7 +199,6 @@
 Mapbender.events.localize.register(function(){
 	Mapbender.modules.i18n.queue(options.id, originalI18nObject, function(translatedI18nObject){
-		alert('need to localize here');
 		$('.labelLoadError').text(translatedI18nObject.labelLoadError);
 		$('.labelUrlBox').text(translatedI18nObject.labelUrlBox);
@@ -227,4 +208,42 @@
 	$(that).click(function(){
 		$('#'+options.id+'_dialog').dialog('open');
+	$('#mapframe1').click(function(e){
+		var pos = map.getMousePosition(e);
+		var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
+		var feed = null;
+		var requestGeometries = [];
+		for (var i in that.feeds){
+			feed = that.feeds[i] ;
+			for(var j = 0; j < feed.geomArray.count(); j++){
+				g = feed.geomArray.get(j);
+				requestGeometries.push(g.toText());
+			var req = new Mapbender.Ajax.Request({
+			url: "../php/intersection.php",
+			method: "intersect",
+			parameters: {
+				clickPoint:	clickPoint.toText(),
+				geometries: requestGeometries
+			callback: function(result, success, message){
+				if(!success){
+					return;
+				// this is basically an onclick handler, !intersects means
+				// the click didn't happen on the polygon
+				if(!result.geometries){
+					return;
+				for(var i in geometries){
+					//TODO: add the popup handler
+			req.send();
Modified: trunk/mapbender/lib/point.js
--- trunk/mapbender/lib/point.js	2010-06-15 09:46:58 UTC (rev 6269)
+++ trunk/mapbender/lib/point.js	2010-06-15 12:10:51 UTC (rev 6270)
@@ -131,3 +131,12 @@
 		return "[" + this.x + ", " + this.y + ", " + this.z + "]";
+Mapbender.Point.prototype.toText = function(){
+	if (typeof(this.z == "undefined")) {
+		return "POINT(" + this.x + " " + this.y + ")";
+	else {
+		return "POINT Z (" + this.x + " " + this.y + " " + this.z + ")";
More information about the Mapbender_commits
