[Mapbender-commits] r6271 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 15 09:15:02 EDT 2010
Author: verenadiewald
Date: 2010-06-15 13:15:02 +0000 (Tue, 15 Jun 2010)
New Revision: 6271
   trunk/mapbender/http/classes/class_bbox.php
   trunk/mapbender/http/classes/class_gml.php
   trunk/mapbender/http/classes/class_gml_factory.php
   trunk/mapbender/http/classes/class_gml_feature.php
   trunk/mapbender/http/classes/class_gml_feature_collection.php
   trunk/mapbender/http/classes/class_gml_geometry.php
   trunk/mapbender/http/classes/class_gml_line.php
   trunk/mapbender/http/classes/class_gml_point.php
   trunk/mapbender/http/classes/class_point.php
added new functionality for getting bbox of a featureCollection
Modified: trunk/mapbender/http/classes/class_bbox.php
--- trunk/mapbender/http/classes/class_bbox.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_bbox.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -55,7 +55,7 @@
 			$max = $param1; // is a Mapbender_point
 			$epsg = $param2; // is an EPSG code like "EPSG:4326"
-			if ($min->isWestOf($max) && $min->isSouthOf($max)) {
+			if (($min->isWestOf($max) && $min->isSouthOf($max)) || $min->equals($max)) {
 				if ($min->epsg == $max->epsg && $min->epsg == $epsg) {
 					$this->min = $min;
 					$this->max = $max;
@@ -167,5 +167,9 @@
 	function __toString() {
 		return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
+	function toJson() {
+		return (string) "[" . $this->min->x . ",". $this->min->y . "," . $this->max->x . "," . $this->max->y . "]";
Modified: trunk/mapbender/http/classes/class_gml.php
--- trunk/mapbender/http/classes/class_gml.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_gml.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -46,6 +46,20 @@
 		$myGmlObj = $gmlFactory->createFromGeoJson($geoJson);
 		return $myGmlObj->toGml();
+	public function getBbox () {
+		if (is_null($this->featureCollection)) {
+			return null;
+		return $this->featureCollection->getBbox();
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_gml_factory.php
--- trunk/mapbender/http/classes/class_gml_factory.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_gml_factory.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -277,6 +277,6 @@
 			$e = new mb_exception($e);
 			return null;
Modified: trunk/mapbender/http/classes/class_gml_feature.php
--- trunk/mapbender/http/classes/class_gml_feature.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_gml_feature.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -73,6 +73,13 @@
 		return $str;
+		if (is_null($this->geometry) || $this->geometry === false) {
+			return null;
+		return $this->geometry->getBbox();
Modified: trunk/mapbender/http/classes/class_gml_feature_collection.php
--- trunk/mapbender/http/classes/class_gml_feature_collection.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_gml_feature_collection.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -20,6 +20,7 @@
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 require_once(dirname(__FILE__)."/../classes/class_json.php");
 require_once(dirname(__FILE__)."/../classes/class_gml_feature.php");
+require_once(dirname(__FILE__)."/../classes/class_bbox.php");
 class FeatureCollection {
@@ -51,5 +52,26 @@
 		$str .= "]}";
 		return $str;
+		if (!is_array($this->featureArray) || count($this->featureArray) === 0) {
+			return null;
+		$bBoxArray = array();
+		for ($i = 0; $i < count($this->featureArray);$i++) {
+			$currentBbox = $this->featureArray[$i]->getBbox();
+			if(!is_null($currentBbox)) {
+				$bBoxArray[] = $currentBbox;
+		return Mapbender_bbox::union($bBoxArray);
Modified: trunk/mapbender/http/classes/class_gml_geometry.php
--- trunk/mapbender/http/classes/class_gml_geometry.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_gml_geometry.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -30,6 +30,8 @@
 	abstract public function toGeoJSON ();
+	//abstract public function getBbox ();
 	public $srs;
 	public $latLonSrs = array(
Modified: trunk/mapbender/http/classes/class_gml_line.php
--- trunk/mapbender/http/classes/class_gml_line.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_gml_line.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -20,6 +20,7 @@
 require_once(dirname(__FILE__)."/../classes/class_gml_geometry.php");
 class GMLLine extends GmlGeometry {
@@ -91,5 +92,18 @@
 		return $str;
+		$bboxArray = array();
+		for ($i = 0; $i < count($pointArray); $i++) {
+			$p = new Mapbender_point(
+				$this->pointArray[$i]["x"],
+				$this->pointArray[$i]["y"],
+				$this->srs
+			$bboxArray[]= new Mapbender_bbox($p, $p, $this->srs);
+		return Mapbender_bbox::union($bboxArray);
Modified: trunk/mapbender/http/classes/class_gml_point.php
--- trunk/mapbender/http/classes/class_gml_point.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_gml_point.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -20,6 +20,7 @@
 class GMLPoint extends GmlGeometry {
@@ -69,5 +70,14 @@
 		return $str;
+			$this->point["x"],
+			$this->point["y"],
+			$this->srs
+		return new Mapbender_bbox($p, $p, $this->srs);
Modified: trunk/mapbender/http/classes/class_point.php
--- trunk/mapbender/http/classes/class_point.php	2010-06-15 12:10:51 UTC (rev 6270)
+++ trunk/mapbender/http/classes/class_point.php	2010-06-15 13:15:02 UTC (rev 6271)
@@ -105,6 +105,16 @@
+	function equals($point) {
+		if ($this->x === $point->x &&
+			$this->y === $point->y &&
+			$this->z === $point->z &&
+			$this->epsg === $point->epsg
+			return true;
 	function isWestOf($point) {
 		if ($this->x < $point->x) {
 			return true;
More information about the Mapbender_commits mailing list
