[Mapbender-commits] r5803 - branches/2.6/http/javascripts
svn_mapbender at osgeo.org
Wed Mar 17 09:20:02 EDT 2010
Author: christoph
Date: 2010-03-17 09:20:00 -0400 (Wed, 17 Mar 2010)
New Revision: 5803
branches/2.6/http/javascripts/map_obj.js
branches/2.6/http/javascripts/mod_box1.js
faulty mouse position
Modified: branches/2.6/http/javascripts/map_obj.js
--- branches/2.6/http/javascripts/map_obj.js 2010-03-17 13:00:37 UTC (rev 5802)
+++ branches/2.6/http/javascripts/map_obj.js 2010-03-17 13:20:00 UTC (rev 5803)
@@ -1081,26 +1081,13 @@
this.getMousePos = function(e){
- if(ie){
- if(this.frameName){
- clickX = window.frames[fName].event.clientX;
- clickY = window.frames[fName].event.clientY;
- else{
- clickX = event.clientX;
- clickY = event.clientY;
+ var pt = this.getMousePosition(e);
+ // set the globals for backwards compatibility
+ if (pt !== null) {
+ clickX = pt.x;
+ clickY = pt.y;
- else{
- clickX = e.pageX;
- clickY = e.pageY;
- //remove divtag offset
- clickX -= parseInt(this.getDomElement().style.left, 10);
- clickY -= parseInt(this.getDomElement().style.top, 10);
- return new Point(clickX, clickY);
+ return pt;
eventAfterMapObjectConstruction.trigger();
Modified: branches/2.6/http/javascripts/mod_box1.js
--- branches/2.6/http/javascripts/mod_box1.js 2010-03-17 13:00:37 UTC (rev 5802)
+++ branches/2.6/http/javascripts/mod_box1.js 2010-03-17 13:20:00 UTC (rev 5803)
@@ -17,9 +17,12 @@
function mod_box_start(e){
mb_boxMapObj = getMapObjByName(mb_isBF);
mb_isActive = true;
- mb_boxMapObj.getMousePos(e);
- mb_start_x = clickX;
- mb_start_y = clickY;
+ var pt = mb_boxMapObj.getMousePosition(e);
+ if (pt === null) {
+ return false;
+ mb_start_x = pt.x;
+ mb_start_y = pt.y;
mb_end_x = mb_start_x+1;
mb_end_y = mb_start_y+1;
mb_offset_left = mb_start_x;
@@ -31,10 +34,14 @@
function mod_box_run(e){
if(mb_isActive){
+ return false;
var width = mb_boxMapObj.width;
var height = mb_boxMapObj.height;
+ var clickX = pt.x;
+ var clickY = pt.y;
if (((clickX>width) || (clickY>height) || (clickX<=0) ||(clickY<=0))){
isActive = false;
mod_box_stop(e);
More information about the Mapbender_commits
