[Mapbender-commits] r5804 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Mar 17 09:20:57 EDT 2010
Author: christoph
Date: 2010-03-17 09:20:56 -0400 (Wed, 17 Mar 2010)
New Revision: 5804
   trunk/mapbender/http/javascripts/map_obj.js
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2010-03-17 13:20:00 UTC (rev 5803)
+++ trunk/mapbender/http/javascripts/map_obj.js	2010-03-17 13:20:56 UTC (rev 5804)
@@ -1474,28 +1474,16 @@
         return true;
-    this.getMousePos = function(e){
-        if (ie) {
-            if (this.frameName) {
-                clickX = window.frames[fName].event.clientX;
-                clickY = window.frames[fName].event.clientY;
-            else {
-                clickX = event.clientX;
-                clickY = event.clientY;
-        else {
-            clickX = e.pageX;
-            clickY = e.pageY;
-        //remove divtag offset
-        clickX -= parseInt(this.getDomElement().style.left, 10);
-        clickY -= parseInt(this.getDomElement().style.top, 10);
-        return new Point(clickX, clickY);
+	/* DEPRECATED! */
+	this.getMousePos = function(e){
+		var pt = this.getMousePosition(e);
+		// set the globals for backwards compatibility
+		if (pt !== null) {
+			clickX = pt.x;
+			clickY = pt.y;
+		return pt;
     var that = this;
More information about the Mapbender_commits mailing list
