[Mapbender-commits] r5827 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon Mar 22 13:49:18 EDT 2010
Author: christoph
Date: 2010-03-22 13:49:17 -0400 (Mon, 22 Mar 2010)
New Revision: 5827
Added:
trunk/mapbender/http/plugins/mb_digitize_geometry.js
Added: trunk/mapbender/http/plugins/mb_digitize_geometry.js
--- trunk/mapbender/http/plugins/mb_digitize_geometry.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_digitize_geometry.js 2010-03-22 17:49:17 UTC (rev 5827)
@@ -0,0 +1,81 @@
+var $digitize = $(this);
+var DigitizeApi = function () {
+ var that = this;
+ var geom;
+ var settings = {
+ geometryType: "point"
+ settings = $.extend({}, settings, options);
+ this.events = {
+ finished: new Mapbender.Event(),
+ added: new Mapbender.Event(),
+ mousemove: new Mapbender.Event()
+ var mousemove = function (e) {
+ that.events.mousemove.trigger(e);
+ var setPoint = function (e) {
+ var map = $(this).mapbender();
+ var pt = map.getMousePosition(e);
+ var coord = map.convertPixelToReal(pt);
+ geom.get(-1).setEpsg(map.getSrs());
+ // add snapping!
+ geom.get(-1).addPoint(coord);
+ that.events.added.trigger({
+ point: coord
+ if (settings.geometryType === Mapbender.geometryType.point) {
+ return button.stop();
+ var button = new Mapbender.Button({
+ domElement: $digitize.get(0),
+ over: options.src.replace(/_off/, "_over"),
+ on: options.src.replace(/_off/, "_on"),
+ off: options.src,
+ name: options.id,
+ go: function () {
+ geom = new MultiGeometry(settings.geometryType);
+ geom.addGeometry();
+ options.$target.bind("click", setPoint);
+ options.$target.bind("mousemove", mousemove);
+ stop: function () {
+ if (geom !== undefined) {
+ if (!geom.get(-1).close()) {
+ new Mapbender.Exception("Geometry could not be created.");
+ else {
+ var json = geom.toString();
+ that.events.finished.trigger({
+ feature: json
+ geom = undefined;
+ options.$target.unbind("click", setPoint);
+ options.$target.unbind("mousemove", mousemove);
+$digitize.mapbender(new DigitizeApi());
+$digitize.mapbender().events.finished.register(function (obj) {
+ console.log(obj.feature);
+$digitize.mapbender().events.mousemove.register(function (obj) {
+ console.log(obj);
+$digitize.mapbender().events.added.register(function (obj) {
+ console.log(obj.point);
More information about the Mapbender_commits
