[Mapbender-commits] r5828 - branches/2.6/http/classes
svn_mapbender at osgeo.org
Tue Mar 23 09:01:06 EDT 2010
Author: christoph
Date: 2010-03-23 09:01:05 -0400 (Tue, 23 Mar 2010)
New Revision: 5828
branches/2.6/http/classes/class_gml2.php
branches/2.6/http/classes/class_gml_2_factory.php
branches/2.6/http/classes/class_gml_factory.php
branches/2.6/http/classes/class_gml_geometry.php
branches/2.6/http/classes/class_locale.php
branches/2.6/http/classes/class_stripRequest.php
branches/2.6/http/classes/class_weldMaps2PNG.php
branches/2.6/http/classes/class_wfsToDb.php
branches/2.6/http/classes/class_wmc.php
branches/2.6/http/classes/class_wmcToXml.php
minor merges from trunk
Modified: branches/2.6/http/classes/class_gml2.php
--- branches/2.6/http/classes/class_gml2.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_gml2.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -537,6 +537,7 @@
case "gml:Envelope" :
$this->geometry = new GMLEnvelope();
$this->geometry->parseEnvelope($geomNode);
+ break;
default:
$this->properties[$columnName] = $value;
break;
Modified: branches/2.6/http/classes/class_gml_2_factory.php
--- branches/2.6/http/classes/class_gml_2_factory.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_gml_2_factory.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -92,7 +92,7 @@
list($x,$y,$z) = explode(',',$pointCoords);
$gmlPolygon->addPoint($x, $y);
$cnt++;
Modified: branches/2.6/http/classes/class_gml_factory.php
--- branches/2.6/http/classes/class_gml_factory.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_gml_factory.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -48,7 +48,7 @@
// check if valid feature collection
if (strtoupper($jsonObj->type) != "FEATURECOLLECTION" || !is_array($jsonObj->features)) {
- $e = new mb_exception("Not a valid GeoJSON Feature Collection.");
+ $e = new mb_exception("Not a valid GeoJSON Feature Collection: " . $geoJson);
return null;
Modified: branches/2.6/http/classes/class_gml_geometry.php
--- branches/2.6/http/classes/class_gml_geometry.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_gml_geometry.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -33,7 +33,8 @@
public $srs;
public $latLonSrs = array(
- "urn:x-ogc:def:crs:EPSG:4326"
+ "urn:x-ogc:def:crs:EPSG:4326",
+ "urn:x-ogc:def:crs:EPSG:31467"
\ No newline at end of file
Modified: branches/2.6/http/classes/class_locale.php
--- branches/2.6/http/classes/class_locale.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_locale.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -150,16 +150,16 @@
* @returns true if the language is supported; otherwise false
function isKnownLanguage($languageId) {
- if ($this->knownLanguages == null) {
- $this->setKnownLanguages();
- if (array_key_exists($languageId, $this->knownLanguages)) {
- return true;
- else {
- $e = new Mb_notice("language " . $languageId . " not supported.");
- return false;
+ if ($this->knownLanguages == null) {
+ $this->setKnownLanguages();
+ if (array_key_exists($languageId, $this->knownLanguages)) {
+ return true;
+ else {
+ $e = new Mb_notice("language " . $languageId . " not supported.");
+ return false;
Modified: branches/2.6/http/classes/class_stripRequest.php
--- branches/2.6/http/classes/class_stripRequest.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_stripRequest.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -142,7 +142,7 @@
$this->encodeGET();
return $this->url;
- function encodeGET(){
+ function encodeGET($encode = true){
$a = explode("?",$this->url);
$patterns = explode("&", $a[1]);
$a[0].= "?";
@@ -153,7 +153,11 @@
$a[0] .= $tmp[0]."=";
for($ii=0; $ii<count($val); $ii++){
if($ii>0){$a[0].=",";}
+ if($encode){
$a[0].= urlencode($val[$ii]);
+ }else{
+ $a[0].= $val[$ii];
if ($i < (count($patterns)-1)) {
$a[0] .= "&";
Modified: branches/2.6/http/classes/class_weldMaps2PNG.php
--- branches/2.6/http/classes/class_weldMaps2PNG.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_weldMaps2PNG.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -29,7 +29,7 @@
class weldMaps2PNG{
- function weldMaps2PNG($urls,$filename){
+ function weldMaps2PNG($urls,$filename, $encode = true){
if(!$urls || $urls == ""){
$e = new mb_exception("weldMaps2PNG: no maprequests delivered");
@@ -46,7 +46,7 @@
$obj = new stripRequest($url[$i]);
$url[$i] = $obj->setPNG();
- $url[$i] = $obj->encodeGET();
+ $url[$i] = $obj->encodeGET($encode);
$img = $this->loadpng($url[$i]);
if($img != false){
imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
Modified: branches/2.6/http/classes/class_wfsToDb.php
--- branches/2.6/http/classes/class_wfsToDb.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_wfsToDb.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -328,7 +328,7 @@
$sqlInsertConfElement .= "f_mandatory, f_auth_varname, f_show_detail, f_operator,";
$sqlInsertConfElement .= "f_detailpos, f_min_input) VALUES";
- $sqlInsertConfElement .= "($1, $2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18)";
+ $sqlInsertConfElement .= "($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18)";
$v = array($wfsConfId, $aWfsFeatureTypeElement->id,0,0,0,0,'',0,0,0,'',0,0,'',0,'',0,0);
$t = array("i", "i","i", "i","i", "i","s","i","i","i","s","i","i","s","i","s","i","i");
Modified: branches/2.6/http/classes/class_wmc.php
--- branches/2.6/http/classes/class_wmc.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_wmc.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -272,7 +272,7 @@
* @param $id String the WMC id
public static function getDocument ($id) {
- $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 AND fkey_user_id = $2 ";
+ $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 AND fkey_user_id = $2";
$v = array($id, $_SESSION["mb_user_id"]);
$t = array('s', 'i');
$res = db_prep_query($sql,$v,$t);
Modified: branches/2.6/http/classes/class_wmcToXml.php
--- branches/2.6/http/classes/class_wmcToXml.php 2010-03-22 17:49:17 UTC (rev 5827)
+++ branches/2.6/http/classes/class_wmcToXml.php 2010-03-23 13:01:05 UTC (rev 5828)
@@ -438,7 +438,11 @@
+ if ($currentLayer->gui_layer_wfs_featuretype !== "") {
+ $layerExtensionData["wfsFeatureType"] = $currentLayer->gui_layer_wfs_featuretype;
if ($currentOverviewLayer != null) {
$layerExtensionData["overviewData"] = array("overviewHidden" => ($currentOverviewLayer->gui_layer_visible ? 0 : 1));
More information about the Mapbender_commits
