[Mapbender-commits] r5843 - trunk/mapbender/resources/db/pgsql
    svn_mapbender at osgeo.org
    Fri Mar 26 11:08:29 EDT 2010
Author: astrid_emde
Date: 2010-03-26 11:08:27 -0400 (Fri, 26 Mar 2010)
New Revision: 5843
Added:
   trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.7.sql
new update sequences added for new tables
Added: trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.7.sql
--- trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.7.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.7.sql	2010-03-26 15:08:27 UTC (rev 5843)
@@ -0,0 +1,63 @@
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_treegde', 'id'), (Select max(id) from gui_treegde), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('layer', 'layer_id'), (Select max(layer_id) from layer), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_group', 'mb_group_id'), (Select max(mb_group_id) from mb_group), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_log', 'id'), (Select max(id) from mb_log), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_user', 'mb_user_id'), (Select max(mb_user_id) from mb_user), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs', 'wfs_id'), (Select max(wfs_id) from wfs), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf', 'wfs_conf_id'), (Select max(wfs_conf_id) from wfs_conf), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf_element', 'wfs_conf_element_id'), (Select max(wfs_conf_element_id) from wfs_conf_element), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_element', 'element_id'), (Select max(element_id) from wfs_element), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_featuretype', 'featuretype_id'), (Select max(featuretype_id) from wfs_featuretype), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wms', 'wms_id'), (Select max(wms_id) from wms), true);
+-- new sequences from Mapbender version 2.4.1
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('keyword', 'keyword_id'), (Select max(keyword_id) from keyword), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('md_topic_category', 'md_topic_category_id'), (Select max(md_topic_category_id) from md_topic_category), true);
+-- new sequences from Mapbender version 2.5
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('translations', 'trs_id'), (Select max(trs_id) from translations), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_kml', 'kml_id'), (Select max(kml_id) from gui_kml), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('sld_user_layer', 'sld_user_layer_id'), (Select max(sld_user_layer_id) from sld_user_layer), true);
+-- new sequences from Mapbender version 2.7
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_category', 'category_id'), (Select max(category_id) from gui_category), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('cat', 'cat_id'), (Select max(cat_id) from cat), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('inspire_md_data', 'data_id'), (Select max(data_id) from inspire_md_data), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('conformity', 'conformity_id'), (Select max(conformity_id) from conformity), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('spec_classification', 'spec_class_id'), (Select max(spec_class_id) from spec_classification), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('spec', 'spec_id'), (Select max(spec_id) from spec), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('conformity_relation', 'relation_id'), (Select max(relation_id) from conformity_relation), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('custom_category', 'custom_category_id'), (Select max(custom_category_id) from custom_category), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('inspire_category', 'inspire_category_id'), (Select max(inspire_category_id) from inspire_category), true);
Property changes on: trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.7.sql
___________________________________________________________________
Added: svn:executable
More information about the Mapbender_commits
