[Mapbender-commits] r5844 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Fri Mar 26 11:19:03 EDT 2010
Author: astrid_emde
Date: 2010-03-26 11:19:02 -0400 (Fri, 26 Mar 2010)
New Revision: 5844
trunk/mapbender/resources/db/install.bat
trunk/mapbender/resources/db/install.sh
trunk/mapbender/resources/db/update.bat
trunk/mapbender/resources/db/update.sh
added pgsql_serial_set_sequences_2.7.sql to keep the sequences up-to-date
Modified: trunk/mapbender/resources/db/install.bat
--- trunk/mapbender/resources/db/install.bat 2010-03-26 15:08:27 UTC (rev 5843)
+++ trunk/mapbender/resources/db/install.bat 2010-03-26 15:19:02 UTC (rev 5844)
@@ -133,6 +133,8 @@
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6_to_2.6.1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
echo update to 2.7
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo update sequences
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_sequences.txt 2>> err_sequences.txt
:POFILES
rem install mapbender.conf
Modified: trunk/mapbender/resources/db/install.sh
--- trunk/mapbender/resources/db/install.sh 2010-03-26 15:08:27 UTC (rev 5843)
+++ trunk/mapbender/resources/db/install.sh 2010-03-26 15:19:02 UTC (rev 5844)
@@ -1,4 +1,4 @@
-#!/bin/bash
+#/bin/bash
# create database for mapbender
@@ -144,6 +144,8 @@
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
echo "update to 2.7"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.1_to_2.7rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+ echo "update sequences"
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.7.sql $DBNAME >> log_sequences.txt 2>> err_squences.txt
Modified: trunk/mapbender/resources/db/update.bat
--- trunk/mapbender/resources/db/update.bat 2010-03-26 15:08:27 UTC (rev 5843)
+++ trunk/mapbender/resources/db/update.bat 2010-03-26 15:19:02 UTC (rev 5844)
@@ -106,7 +106,8 @@
echo update to 2.7
+echo update to 2.7
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
goto END:
:PGNOTFOUND
Modified: trunk/mapbender/resources/db/update.sh
--- trunk/mapbender/resources/db/update.sh 2010-03-26 15:08:27 UTC (rev 5843)
+++ trunk/mapbender/resources/db/update.sh 2010-03-26 15:19:02 UTC (rev 5844)
@@ -97,7 +97,8 @@
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.7.sql $DBNAME >> log_update.txt 2>> err_update.txt
#magic starts here
More information about the Mapbender_commits
