[Mapbender-commits] r6178 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 11 11:55:40 EDT 2010
Author: christoph
Date: 2010-05-11 11:55:35 -0400 (Tue, 11 May 2010)
New Revision: 6178
   trunk/mapbender/http/plugins/mb_metadata_edit.js
   trunk/mapbender/http/plugins/mb_metadata_edit.php
   trunk/mapbender/http/plugins/mb_metadata_layer.js
   trunk/mapbender/http/plugins/mb_metadata_layer.php
   trunk/mapbender/http/plugins/mb_metadata_server.php
   trunk/mapbender/http/plugins/mb_metadata_submit.js
   trunk/mapbender/lib/basic.js
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_edit.js	2010-05-11 14:44:56 UTC (rev 6177)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.js	2010-05-11 15:55:35 UTC (rev 6178)
@@ -25,36 +25,42 @@
 var MetadataEditApi = function (o) {
 	var that = this;
 	var validator;
+	var formReady = false;
 	var wmsId;
 	this.events = {
 		showOriginalMetadata : new Mapbender.Event(),
 		submit: new Mapbender.Event()
+	this.valid = function () {
+		if (validator && validator.numberOfInvalids() > 0) {
+			$metadataForm.valid();
+			return false;
+		return true;
 	this.serialize = function (callback) {
-		var data = $metadataForm.easyform("serialize");
+		$metadataForm.submit();
+		var data = null;
+		if (this.valid()) {
+			data = {
+				wms: $metadataForm.easyform("serialize")
 		if ($.isFunction(callback)) {
-			callback({
-				wms: data
+			callback(data);
-		return data;
+		return data !== null ? data.wms : data;
-	this.valid = function () {
-		if (validator && validator.numberOfInvalids() > 0) {
-			$metadataForm.valid();
-	var formReady = false;
 	// second optional parameter formData
 	var fillForm = function (obj) {
 		if (arguments.length >= 2) {
 			$metadataForm.easyform("reset");
 			$metadataForm.easyform("fill", arguments[1]);
+			that.valid();
 			return;
@@ -71,6 +77,7 @@
 				$metadataForm.easyform("fill", obj);
+				that.valid();
 		req.send();
@@ -89,7 +96,12 @@
+	var validate = function () {
+		return false;
 	this.init = function (obj) {
 		wmsId = obj;
 		var formData = arguments.length >= 2 ? arguments[1] : undefined;
@@ -114,6 +126,8 @@
 		fillForm(obj);
+	$metadataForm.bind("submit", validate);
 	Mapbender.events.localize.register(function () {
 		that.valid();
 		var formData = $metadataForm.easyform("serialize");
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.php
--- trunk/mapbender/http/plugins/mb_metadata_edit.php	2010-05-11 14:44:56 UTC (rev 6177)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.php	2010-05-11 15:55:35 UTC (rev 6178)
@@ -1,8 +1,7 @@
 <?php
 	require_once dirname(__FILE__) . "/../../core/globalSettings.php";
-<fieldset class="ui-widget">
+<fieldset>
 	<input name="wms_id" id="wms_id" type="hidden"/>
 	<legend>Service Level Metadata: <img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Help text");?>'}" src="../img/questionmark.png"></img></legend>
@@ -58,7 +57,7 @@
 	</p>
 </fieldset>
 <fieldset>
-	<legend>WMS Provider Section (OWS):</legend>
+	<legend>WMS Provider Section (OWS)</legend>
 	<p>
 		<label for="contactperson">Contact Individual Name (OWS):</label>
     	<input name="contactperson" id="contactperson"/>
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js	2010-05-11 14:44:56 UTC (rev 6177)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js	2010-05-11 15:55:35 UTC (rev 6178)
@@ -26,84 +26,67 @@
 	var that = this;
 	var validator;
+	var wmsId;
+	var layerId;
+	this.events = {
+		initialized: new Mapbender.Event(),
+		submit: new Mapbender.Event()
+			return false;
+		return true;
+		var data = null;
+			data = {
+				layer: $metadataForm.easyform("serialize")
-			callback({
-				layer: data
+			callback(data);
-		return data;
+		return data !== null ? data.layer : data;
-	this.events = {
-		initialized: new Mapbender.Event(),
-		submit: new Mapbender.Event()
 	this.fillForm = function (obj) {
-		// layer data
-		$metadataForm.easyform("reset");
-		$metadataForm.easyform("fill", obj);
-		return;
-		// layer keywords
-		var req = new Mapbender.Ajax.Request({
-			url: "../plugins/mb_metadata_server.php",
-			method: "getLayerKeywords",
-			parameters: {
-				"id": obj.layer_id
-			callback: function(o, r, m) {
-				if (!r) {
-					return;
-				for (var i in o) {
-					var $node = $("#" + i).val("");
-					if ($node.size() > 0) {
-						for (var j = 0; j < o[i].length; j++) {
-							$node.val($node.val() !== "" ? $node.val() + ", " + o[i][j][1] : o[i][j][1]);
-		req.send();
+		layerId = obj.layer_id;
-		// layer categories
+		// get metadata from server
-			method: "getLayerCategories",
+			method: "getLayerMetadata",
 			parameters: {
+				"id": layerId
-				if (!r) {
+			callback: function (obj, result, message) {
+				if (!result) {
 					return;
-					var $node = $("#" + i);
-						$node.find("option").removeAttr("selected");
-							$node.find("option[value="+ o[i][j] +"]").attr("selected", "selected");
+				$metadataForm.easyform("reset");
+				$metadataForm.easyform("fill", obj);
+				that.valid();
-		req.send();
+		req.send();
+		return false;
+	this.init = function (obj) {
-	this.init = function (wmsId) {
+		wmsId = obj;
 		if (!formReady) {
@@ -126,6 +109,8 @@
 		that.valid();
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.php
--- trunk/mapbender/http/plugins/mb_metadata_layer.php	2010-05-11 14:44:56 UTC (rev 6177)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.php	2010-05-11 15:55:35 UTC (rev 6178)
@@ -29,6 +29,8 @@
 <div id="layer">
 	<fieldset class="">
+		<input name="layer_name" id="layer_name" type="hidden"/>
 		<legend>Layer metadata</legend>
 		<p>
 			<label for="wms_title"><?php echo _mb("Show original Service Metadata from last update");?></label>
@@ -45,7 +47,7 @@
 	    	<label for="layer_title">Layer Title (WMS):</label>
 			<img class="metadata_img" src="../img/misc/inspire_eu_klein.png"></img>
 			<span class="metadata_span"></span>
-	    	<input name="layer_title" id="layer_title"/>
+	    	<input name="layer_title" id="layer_title" class="required" />
 		</p>
 		<p>
 	    	<label for="layer_abstract">Layer Abstract (WMS):</label>
@@ -54,10 +56,10 @@
 	    	<input name="layer_abstract" id="layer_abstract"/>
 		</p>
 		<p>
-	    	<label for="fkey_keyword_id">Layer Keywords (WMS):</label>
+	    	<label for="layer_keyword">Layer Keywords (WMS):</label>
-		   	<input name="fkey_keyword_id" id="fkey_keyword_id"/>
+		   	<input name="layer_keyword" id="layer_keyword"/>
 		</p>
 		<p>
 		    <div id="buttons">
@@ -94,9 +96,9 @@
 	<fieldset class="">
 		<legend>Classification</legend>
 		<p>
-		    <label for="fkey_md_topic_category_id" class="label_classification">ISO Topic Category:</label>
+		    <label for="layer_md_topic_category_id" class="label_classification">ISO Topic Category:</label>
-			<select class="metadata_selectbox" id="fkey_md_topic_category_id" name="fkey_md_topic_category_id" size="2" multiple="multiple">
+			<select class="metadata_selectbox" id="layer_md_topic_category_id" name="layer_md_topic_category_id" size="2" multiple="multiple">
 <?php
 	$sql = "SELECT md_topic_category_id AS id, md_topic_category_code_en AS name FROM md_topic_category";
 	echo displayCategories($sql);
@@ -104,9 +106,9 @@
 			</select>
 		</p>
 		<p>
-		    <label for="fkey_inspire_category_id" class="label_classification">INSPIRE Category:</label>
+		    <label for="layer_inspire_category_id" class="label_classification">INSPIRE Category:</label>
-			<select class="metadata_selectbox" id="fkey_inspire_category_id" name="fkey_inspire_category_id" size="2" multiple="multiple">
+			<select class="metadata_selectbox" id="layer_inspire_category_id" name="layer_inspire_category_id" size="2" multiple="multiple">
 <?php
 	$sql = "SELECT inspire_category_id AS id, inspire_category_code_en AS name FROM inspire_category";
@@ -114,9 +116,9 @@
 			</select>
 		</p>
 		<p>
-		    <label for="fkey_custom_category_id" class="label_classification">Custom Category:</label>
+		    <label for="layer_custom_category_id" class="label_classification">Custom Category:</label>
-			<select class="metadata_selectbox" id="fkey_custom_category_id" name="fkey_custom_category_id" size="2" multiple="multiple">
+			<select class="metadata_selectbox" id="layer_custom_category_id" name="layer_custom_category_id" size="2" multiple="multiple">
 <?php
 	$sql = "SELECT custom_category_id AS id, custom_category_code_en AS name FROM custom_category";
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2010-05-11 14:44:56 UTC (rev 6177)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2010-05-11 15:55:35 UTC (rev 6178)
@@ -33,7 +33,7 @@
 	$wmsId = wms::getWmsIdByLayerId($layerId);
 	if (is_null($wmsId) || !in_array($wmsId, $wmsIdArray)) {
-		abort(_mb("You are not allowed to access this WMS."));
+		abort(_mb("You are not allowed to access WMS " . $wmsId));
 	return;
@@ -146,8 +146,8 @@
 		$sql = <<<SQL
-SELECT layer_id, layer_title, layer_abstract, layer_searchable
-FROM layer WHERE wms_id = $wmsId;
+SELECT layer_id, layer_name, layer_title, layer_abstract, layer_searchable
+FROM layer WHERE layer_id = $layerId;
 SQL;
 		$res = db_query($sql);
@@ -155,51 +155,18 @@
 		$resultObj = array();
 		while ($row = db_fetch_assoc($res)) {
 			foreach ($row as $key => $value) {
-				$resultObj["layer:".$key] = $value;
+				$resultObj[$key] = $value;
-		$ajaxResponse->setResult($resultObj);
-		$ajaxResponse->setSuccess(true);
-		break;
-	case "getLayerKeywords" :
-		$layerId = $ajaxResponse->getParameter("id");
-		getLayer($layerId);
 		$sql = <<<SQL
-SELECT keyword, fkey_keyword_id FROM keyword, layer_keyword
-WHERE keyword_id = fkey_keyword_id AND fkey_layer_id = $layerId
-SQL;
-		$res = db_query($sql);
-		$resultObj = array(
-			"fkey_keyword_id" => array()
-		while ($row = db_fetch_assoc($res)) {
-			$resultObj["fkey_keyword_id"][]= array($row["fkey_keyword_id"], $row["keyword"]);
-		break;
-	case "getLayerCategories" :
-			"fkey_md_topic_category_id" => array(),
-			"fkey_inspire_category_id" => array(),
-			"fkey_custom_category_id" => array()
-		$sql = <<<SQL
 SELECT fkey_md_topic_category_id
 FROM layer_md_topic_category
 WHERE fkey_layer_id = $layerId
 SQL;
-			$resultObj["fkey_md_topic_category_id"][]= $row["fkey_md_topic_category_id"];
+			$resultObj["layer_md_topic_category_id"][]= $row["fkey_md_topic_category_id"];
 		$sql = <<<SQL
@@ -209,7 +176,7 @@
 SQL;
-			$resultObj["fkey_inspire_category_id"][]= $row["fkey_inspire_category_id"];
+			$resultObj["layer_inspire_category_id"][]= $row["fkey_inspire_category_id"];
 		$sql = <<<SQL
@@ -219,9 +186,20 @@
 SQL;
-			$resultObj["fkey_custom_category_id"][]= $row["fkey_custom_category_id"];
+			$resultObj["layer_custom_category_id"][]= $row["fkey_custom_category_id"];
+		$sql = <<<SQL
+SELECT keyword FROM keyword, layer_keyword
+WHERE keyword_id = fkey_keyword_id AND fkey_layer_id = $layerId
+SQL;
+		$res = db_query($sql);
+		$resultObj["layer_keyword"] = array();
+		while ($row = db_fetch_assoc($res)) {
+			$resultObj["layer_keyword"][]= $row["keyword"];
 		break;
@@ -342,7 +320,8 @@
 			"stateorprovince",
 			"postcode",
 			"country",
-			"contactelectronicmailaddress"
+			"contactelectronicmailaddress",
+			"wms_termsofuse"
 		foreach ($columns as $c) {
 			$value = $data->wms->$c;
@@ -362,15 +341,40 @@
 			if (!is_null($layer)) {
 				$columns = array(
 					"layer_abstract",
-					"layer_title"
+					"layer_title",
+					"layer_keyword",
+					"layer_md_topic_category_id",
+					"layer_inspire_category_id",
+					"layer_custom_category_id"
 					$value = $data->layer->$c;
-					if (!is_null($value)) {
-						$layer->$c = $value;
+					if ($c === "layer_keyword") {
+						$layer->$c = explode(",", $value);
+						foreach ($layer->$c as &$val) {
+							$val = trim($val);
+					elseif ($c === "layer_md_topic_category_id"
+						|| $c === "layer_inspire_category_id"
+						|| $c === "layer_custom_category_id"
+						if (!is_array($value)) {
+							$layer->$c = array($value);
+							$firephp->log($layer->$c);
+						else {
+							$layer->$c = $value;
+					else {
+						if (!is_null($value)) {
+				$firephp->log($layer);
Modified: trunk/mapbender/http/plugins/mb_metadata_submit.js
--- trunk/mapbender/http/plugins/mb_metadata_submit.js	2010-05-11 14:44:56 UTC (rev 6177)
+++ trunk/mapbender/http/plugins/mb_metadata_submit.js	2010-05-11 15:55:35 UTC (rev 6178)
@@ -5,16 +5,29 @@
 	var formData = {};
 	var serializeCallback = function (data) {
-		formData = $.extend(formData, data);
+		if (data === null) {
+			formData = null;
+			return;
+		if (formData !== null) {
+			formData = $.extend(formData, data);
+	this.enable = function () {
+		$submit.find("input[type='submit']").removeAttr("disabled");
 	this.submit = function () {
 		formData = {};
 		this.events.submit.trigger({
 			callback: serializeCallback
-//		console.log(formData);
+		if (formData === null) {
+			return;
@@ -24,8 +37,14 @@
 				if (!result) {
+					$("<div></div>").text(!message ? "An error occured." : message).dialog({
+						modal: true
 					return;
+				$("<div></div>").text(message).dialog({
+					modal: true
Modified: trunk/mapbender/lib/basic.js
--- trunk/mapbender/lib/basic.js	2010-05-11 14:44:56 UTC (rev 6177)
+++ trunk/mapbender/lib/basic.js	2010-05-11 15:55:35 UTC (rev 6178)
@@ -389,7 +389,16 @@
 			var f = $(this).serializeArray();
 			var r = {};
 			for (var i in f) {
-				r[f[i].name] = f[i].value;
+				var n = r[f[i].name];
+				if (n === undefined) {
+					r[f[i].name] = $(f[i]).val();
+				else if (n.length && typeof n === "object") {
+					r[f[i].name].push($(f[i]).val());
+				else {
+					r[f[i].name] = [n, $(f[i]).val()];
 			return r;
 		case "fill":
@@ -407,7 +416,29 @@
 	return this.each(function () {
 		if (data) {
 			for (var i in data) {
-				$(this[i]).val(data[i]);
+				if (!this[i]) {
+					continue;
+				var $node = $(this[i]);
+				if ($node.size() === 1) {
+					if ($node.get(0).tagName.toUpperCase() === "SELECT") {
+						$node.find("option").each(function () {
+							var $opt = $(this);
+							var value = data[i];
+							if (!value.length) {
+								value = [value];
+							for (var j in value) {
+								if ($opt.val() === value[j]) {
+									$opt.attr("selected", "selected");
+					else {
+						$node.val(data[i]);
 			return;
More information about the Mapbender_commits mailing list
