[Mapbender-commits] r6179 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 11 11:56:07 EDT 2010
Author: christoph
Date: 2010-05-11 11:56:07 -0400 (Tue, 11 May 2010)
New Revision: 6179
   trunk/mapbender/resources/db/metadataGui.sql
Modified: trunk/mapbender/resources/db/metadataGui.sql
--- trunk/mapbender/resources/db/metadataGui.sql	2010-05-11 15:55:35 UTC (rev 6178)
+++ trunk/mapbender/resources/db/metadataGui.sql	2010-05-11 15:56:07 UTC (rev 6179)
@@ -32,7 +32,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_tree',2,1,'Select a layer from a layer tree','Select a layer from a layer tree','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerTree.js','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'display:none;','','div','../plugins/mb_metadata_showOriginal.js','','','jq_ui_dialog','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_submit',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_submit.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_submit',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input disabled="disabled" type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_submit.js','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_select,mb_md_edit,mb_md_layer','jq_ui_tabs','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','',270,10,24,24,1,'','','','mod_pan.js','','mapframe1','','http://www.mapbender.org/index.php/Pan');
@@ -66,44 +66,54 @@
         height: 25px;
+fieldset {
+        margin-top: 10px;
 .metadata_span {
         padding-right: 30px;
         vertical-align: top;
-.metadata_img {
+.metadata_img, .help-dialog, .original-metadata-wms {
         width: 25px;
         height: 25px;
-        vertical-align: top;
+        vertical-align: middle;
 .metadata_selectbox {
-        height: 130px;
+        height: 66px;
         width: 250px;
+.label_classification {
+        width: 150px;
+        height: 40px;
+        float: left;
 div#choose {
         float: left;
-        width: 20%;
+        width: 35%;
         height:100%;
 div#layer {
-        margin-left: 20%;
-        width: 80%;
+        margin-left: 35%;
+        width: 65%;
 div#preview {
-        width: 30%;
+        width: 25%;
         padding-top: 5px;
         float: left;
 div#classification {
-        margin-left: 50%;
+        margin-left: 60%;
         padding-top: 5px;
-        width: 50%;
+        width: 40%;
 div#save {
@@ -281,6 +291,17 @@
 ]', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_submit', 'inputs', '[
+        "method": "enable",
+        "linkedTo": [
+                "id": "mb_md_select",
+                "event": "selected"
+]', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'center', 'mb_tabs_horizontal', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'south', 'mb_md_submit', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_tabs_horizontal', 'inputs', '[
More information about the Mapbender_commits mailing list
