[Mapbender-commits] r7137 - in trunk/mapbender: core http/frames
svn_mapbender at osgeo.org
Tue Nov 16 08:05:35 EST 2010
Author: christoph
Date: 2010-11-16 05:05:35 -0800 (Tue, 16 Nov 2010)
New Revision: 7137
trunk/mapbender/core/globalSettings.php
trunk/mapbender/core/system.php
trunk/mapbender/http/frames/login.php
#720
Modified: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php 2010-11-16 12:36:59 UTC (rev 7136)
+++ trunk/mapbender/core/globalSettings.php 2010-11-16 13:05:35 UTC (rev 7137)
@@ -29,20 +29,11 @@
if (defined("SESSION_NAME") && is_string(SESSION_NAME)) {
// session_name(SESSION_NAME);
-session_start();
-// Add FirePHP for debugging only, supply a global $firephp
-if (defined("LOG_PHP_WITH_FIREPHP") && LOG_PHP_WITH_FIREPHP === "on") {
- require_once(dirname(__FILE__)."/../http/extensions/FirePHP-0.3/FirePHP.class.php");
- $firephp = FirePHP::getInstance(true);
// Basic Mapbender classes, for session handling etc.
-require_once(dirname(__FILE__)."/../lib/class_Mapbender.php");
+require_once dirname(__FILE__)."/../lib/class_Mapbender.php";
// define LC_MESSAGES if unknown (for Windows platforms)
@@ -50,87 +41,11 @@
if (!defined("LC_MESSAGES")) define("LC_MESSAGES", LC_CTYPE);
-// All data Mapbender handles internally are UTF-8
-mb_internal_encoding("UTF-8");
-// if magic quotes is on, automatically strip slashes
-// (non-recursive due to possible security hazard)
-if (get_magic_quotes_gpc()) {
- $in = array(&$_GET, &$_POST, &$_COOKIE, &$_REQUEST);
- while (list($k, $v) = each($in)) {
- foreach ($v as $key => $val) {
- if (!is_array($val)) {
- $in[$k][$key] = stripslashes($val);
- continue;
- $in[]= &$in[$k][$key];
- unset($in);
-// configuration file
-require_once(dirname(__FILE__)."/../conf/mapbender.conf");
-// until we have decided how to implement a public user,
-// use this constant. In Geoportal.rlp.de it was used as ANONYMOUS_USER
-if (!defined("PUBLIC_USER")) define("PUBLIC_USER", "");
-if (!defined("LOAD_JQUERY_FROM_GOOGLE")) define("LOAD_JQUERY_FROM_GOOGLE", false);
-// class for error handling
-DEFINE("LOG_DIR", dirname(__FILE__) . "/../log/");
-require_once(dirname(__FILE__)."/../http/classes/class_mb_exception.php");
// I18n wrapper function, gettext
-require_once(dirname(__FILE__) . "/../core/i18n.php");
-require_once(dirname(__FILE__) . "/../http/classes/class_locale.php");
+require_once dirname(__FILE__) . "/../core/i18n.php";
+require_once dirname(__FILE__) . "/../http/classes/class_locale.php";
$localeObj = new Mb_locale(Mapbender::session()->get("mb_lang"));
-// Do not display PHP errors
-ini_set("display_errors", "0");
-// AJAX wrapper
-require_once(dirname(__FILE__)."/../lib/ajax.php");
-// get real ip address, can be improved, see
-// http://roshanbh.com.np/2007/12/getting-real-ip-address-in-php.html
-function getRealIpAddr() {
- if (!empty($_SERVER['HTTP_CLIENT_IP'])) //check ip from share internet
- $ip=$_SERVER['HTTP_CLIENT_IP'];
- elseif (!empty($_SERVER['HTTP_X_FORWARDED_FOR'])) //to check ip is pass from proxy
- $ip=$_SERVER['HTTP_X_FORWARDED_FOR'];
- else
- $ip=$_SERVER['REMOTE_ADDR'];
- return $ip;
Modified: trunk/mapbender/core/system.php
--- trunk/mapbender/core/system.php 2010-11-16 12:36:59 UTC (rev 7136)
+++ trunk/mapbender/core/system.php 2010-11-16 13:05:35 UTC (rev 7137)
@@ -19,6 +19,11 @@
//define("SESSION_NAME", "TRUNK_SESSID");
+# configuration file
+require_once dirname(__FILE__)."/../conf/mapbender.conf";
# mapbender version
define("MB_VERSION_NUMBER", "2.7");
@@ -105,15 +110,35 @@
function security_patch_log($file,$line) {
$h = fopen("../log/security_patch.log","a+");
if($h) {
- fwrite($h,date("Y.m.d H:i")." FILE : ".$file." | LINE : ".$line." | POST : ".implode(",",array_keys($_POST))." | GET : ".implode(",",array_keys($_GET))." | FILE : ".implode(",",array_keys($_FILE))." |\n");
- fclose($h);
+ fwrite($h,date("Y.m.d H:i")." FILE : ".$file." | LINE : ".$line." | POST : ".implode(",",array_keys($_POST))." | GET : ".implode(",",array_keys($_GET))." | FILE : ".implode(",",array_keys($_FILE))." |\n");
+ fclose($h);
+// get real ip address, can be improved, see
+// http://roshanbh.com.np/2007/12/getting-real-ip-address-in-php.html
+function getRealIpAddr() {
+ if (!empty($_SERVER['HTTP_CLIENT_IP'])) //check ip from share internet
+ $ip=$_SERVER['HTTP_CLIENT_IP'];
+ elseif (!empty($_SERVER['HTTP_X_FORWARDED_FOR'])) //to check ip is pass from proxy
+ $ip=$_SERVER['HTTP_X_FORWARDED_FOR'];
+ else
+ $ip=$_SERVER['REMOTE_ADDR'];
+ return $ip;
// database wrapper
-require_once(dirname(__FILE__) . "/../lib/database-pgsql.php");
+require_once dirname(__FILE__) . "/../lib/database-pgsql.php";
// establish database connection
@@ -121,4 +146,65 @@
$con = db_connect(DBSERVER, OWNER, PW);
db_select_db(DB, $con);
+// Add FirePHP for debugging only, supply a global $firephp
+if (defined("LOG_PHP_WITH_FIREPHP") && LOG_PHP_WITH_FIREPHP === "on") {
+ require_once(dirname(__FILE__)."/../http/extensions/FirePHP-0.3/FirePHP.class.php");
+ $firephp = FirePHP::getInstance(true);
+// All data Mapbender handles internally are UTF-8
+mb_internal_encoding("UTF-8");
+// if magic quotes is on, automatically strip slashes
+// (non-recursive due to possible security hazard)
+if (get_magic_quotes_gpc()) {
+ $in = array(&$_GET, &$_POST, &$_COOKIE, &$_REQUEST);
+ while (list($k, $v) = each($in)) {
+ foreach ($v as $key => $val) {
+ if (!is_array($val)) {
+ $in[$k][$key] = stripslashes($val);
+ continue;
+ $in[]= &$in[$k][$key];
+ unset($in);
+// until we have decided how to implement a public user,
+// use this constant. In Geoportal.rlp.de it was used as ANONYMOUS_USER
+if (!defined("PUBLIC_USER")) define("PUBLIC_USER", "");
+if (!defined("LOAD_JQUERY_FROM_GOOGLE")) define("LOAD_JQUERY_FROM_GOOGLE", false);
+// class for error handling
+DEFINE("LOG_DIR", dirname(__FILE__) . "/../log/");
+require_once dirname(__FILE__)."/../http/classes/class_mb_exception.php";
+// Do not display PHP errors
+ini_set("display_errors", "0");
+// AJAX wrapper
+require_once dirname(__FILE__)."/../lib/ajax.php";
Modified: trunk/mapbender/http/frames/login.php
--- trunk/mapbender/http/frames/login.php 2010-11-16 12:36:59 UTC (rev 7136)
+++ trunk/mapbender/http/frames/login.php 2010-11-16 13:05:35 UTC (rev 7137)
@@ -159,8 +159,13 @@
// if given user data is found in database, set session data (db_fetch_array returns false if no row is found)
if($row){
- require_once dirname(__FILE__)."/../../core/globalSettings.php";
- include(dirname(__FILE__)."/../../conf/session.conf");
+ require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+ if (Mapbender::session()->get("mb_user_id") !== false && $row["mb_user_id"] !== Mapbender::session()->get("mb_user_id")) {
+ session_write_close();
+ session_id(sha1(mt_rand()));
+ session_start();
+ include(dirname(__FILE__) . "/../../conf/session.conf");
else {
redirectToLogin($name);
More information about the Mapbender_commits
