[Mapbender-commits] r7138 - in trunk/mapbender: conf core
http/frames
svn_mapbender at osgeo.org
Tue Nov 16 09:37:08 EST 2010
Author: christoph
Date: 2010-11-16 06:37:08 -0800 (Tue, 16 Nov 2010)
New Revision: 7138
trunk/mapbender/conf/mapbender.conf-dist
trunk/mapbender/core/globalSettings.php
trunk/mapbender/http/frames/login.php
#720
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist 2010-11-16 13:05:35 UTC (rev 7137)
+++ trunk/mapbender/conf/mapbender.conf-dist 2010-11-16 14:37:08 UTC (rev 7138)
@@ -172,6 +172,12 @@
define("PUBLIC_USER", "");
+# define a session name (useful for )
+#define("SESSION_NAME", "MAPBENDER");
###HACK for GLOBALS
$DBSERVER=DBSERVER;
$DB=DB;
Modified: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php 2010-11-16 13:05:35 UTC (rev 7137)
+++ trunk/mapbender/core/globalSettings.php 2010-11-16 14:37:08 UTC (rev 7138)
@@ -26,8 +26,9 @@
// initiates the session-handling
+session_start();
if (defined("SESSION_NAME") && is_string(SESSION_NAME)) {
-// session_name(SESSION_NAME);
+ session_name(SESSION_NAME);
Modified: trunk/mapbender/http/frames/login.php
--- trunk/mapbender/http/frames/login.php 2010-11-16 13:05:35 UTC (rev 7137)
+++ trunk/mapbender/http/frames/login.php 2010-11-16 14:37:08 UTC (rev 7138)
@@ -160,11 +160,14 @@
// if given user data is found in database, set session data (db_fetch_array returns false if no row is found)
if($row){
require_once dirname(__FILE__) . "/../../core/globalSettings.php";
- if (Mapbender::session()->get("mb_user_id") !== false && $row["mb_user_id"] !== Mapbender::session()->get("mb_user_id")) {
- session_write_close();
- session_id(sha1(mt_rand()));
- session_start();
+# These lines will create a new session if a user logs in who is not the owner
+# of the session. However, in Geoportal-RLP this is intended,
+# if (Mapbender::session()->get("mb_user_id") !== false && $row["mb_user_id"] !== Mapbender::session()->get("mb_user_id")) {
+# session_write_close();
+# session_id(sha1(mt_rand()));
+# session_start();
include(dirname(__FILE__) . "/../../conf/session.conf");
else {
More information about the Mapbender_commits
