[Mapbender-commits] r7139 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 18 06:01:48 EST 2010
Author: christoph
Date: 2010-11-18 03:01:48 -0800 (Thu, 18 Nov 2010)
New Revision: 7139
   trunk/mapbender/http/classes/class_wfs_1_1_factory.php
#722
Modified: trunk/mapbender/http/classes/class_wfs_1_1_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_1_factory.php	2010-11-16 14:37:08 UTC (rev 7138)
+++ trunk/mapbender/http/classes/class_wfs_1_1_factory.php	2010-11-18 11:01:48 UTC (rev 7139)
@@ -1,7 +1,7 @@
 <?php
 # $Id: class_wfs.php 3094 2008-10-01 13:52:35Z christoph $
 # http://www.mapbender.org/index.php/class_wfs.php
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
 # This program is free software; you can redistribute it and/or modify
 # it under the terms of the GNU General Public License as published by
@@ -26,61 +26,69 @@
  * Creates WFS 1.1 objects from a capabilities documents.
  * @return Wfs_1_1
 class Wfs_1_1_Factory extends WfsFactory {
 	protected function createFeatureTypeFromUrl ($aWfs, $featureTypeName, $featureTypeNsArray) {
 		$postData = "<?xml version=\"1.0\"?>\n".
-				"<DescribeFeatureType version=\"" . $aWfs->getVersion() . "\" " .
+				"<DescribeFeatureType version=\"" . $aWfs->getVersion() . "\" " .
 				"service=\"WFS\" xmlns=\"http://www.opengis.net/wfs\" ";
+		$nsUrl = $featureTypeNsArray["xmlns:" . $key];
+		if (!$nsUrl) {
+			$nsUrl = $featureTypeNsArray[$key];
 		if ($featuretype_name != $this->sepNameSpace($featureTypeName)) {
 			$key = "xmlns:" . $this->getNameSpace($featureTypeName);
-			$postData .= $key . "=\"" . $featureTypeNsArray[$key] . "\" ";
+			$postData .= $key . "=\"" . $nsUrl . "\" ";
-		$postData .= "><TypeName>" . $featureTypeName . "</TypeName>" .
+		$postData .= "><TypeName>" . $featureTypeName . "</TypeName>" .
 				"</DescribeFeatureType>";
 		$xml = $this->post($aWfs->describeFeatureType, $postData);
-		return $this->createFeatureTypeFromXml ($xml, $aWfs);
+		return $this->createFeatureTypeFromXml ($xml, $aWfs, $featureTypeName);
 	protected function createFeatureTypeFromUrlGet ($aWfs, $featureTypeName, $featureTypeNsArray) {
 		$key = $this->getNameSpace($featureTypeName);
+		if (!$nsUrl) {
 		$paramArray = array(
 			"SERVICE=WFS",
 			"VERSION=1.1.0",
 			"REQUEST=DescribeFeatureType",
 			"TYPENAME=" . urlencode($featureTypeName),
 			"NAMESPACE=" . urlencode(
-				"xmlns(" . $key . "=" . $featureTypeNsArray[$key] . ")"
+				"xmlns(" . $key . "=" . $nsUrl . ")"
 		$url = $aWfs->describeFeatureType .
 			$aWfs->getConjunctionCharacter($aWfs->describeFeatureType) .
 			implode("&", $paramArray);
 		$xml = $this->get($url);
-	protected function createFeatureTypeFromXml ($xml, $myWfs) {
+	protected function createFeatureTypeFromXml ($xml, $myWfs, $featureTypeName) {
 		$newFeatureType = new WfsFeatureType($myWfs);
 		$admin = new administration();
 		$values = $admin->parseXml($xml);
-		foreach ($values as $element) {
+		foreach ($values as $element) {
 			if ($this->sepNameSpace($element[tag]) == "schema" && $element[type] == "open") {
 				$section = "namespace";
-			if ($section == "namespace" && is_array($element[attributes])) {
+			if ($section == "namespace" && is_array($element[attributes])) {
 				while (list($k, $val) = each ($element[attributes])) {
    					if (substr($k, 0, 5) == "xmlns") {
    						$key = $this->sepNameSpace($k);
@@ -88,42 +96,42 @@
-			if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "open"){
-				$section = "complexcontent";
+			if($this->sepNameSpace($element[tag]) == "complexType" && $element[type] == "open" && $element[attributes]["name"] === $featureTypeName . "Type"){
+				$section = "complexType";
-			if($section == "complexcontent" && $this->sepNameSpace($element[tag]) == "element" && $element[attributes][name]){
+			if($section == "complexType" && $this->sepNameSpace($element[tag]) == "element" && $element[attributes][name]){
 				$newFeatureType->addElement(
-					$element[attributes]["name"],
+					$element[attributes]["name"],
 					$this->sepNameSpace($element[attributes]["type"])
-			if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "close"){
+			if($this->sepNameSpace($element[tag]) == "complexType" && $element[type] == "close"){
 				$section = "";
-		return $newFeatureType;
+		return $newFeatureType;
 	 * Creates WFS 1.0 objects from a capabilities documents.
 	 * @return Wfs_1_1
 	 * @param $xml String
 	public function createFromXml ($xml) {
 		try {
 			$myWfs = new Wfs_1_1();
 			$myWfs->getCapabilitiesDoc = $admin->char_encode($xml);
 			$myWfs->id = $this->createId();
 				$tag = $this->sepNameSpace(strtoupper($element[tag]));
 				if($tag == "WFS_CAPABILITIES" && $element[type] == "open"){
 					$myWfs->version = $element[attributes][version];
 					if ($myWfs->version !== "1.1.0") {
@@ -145,7 +153,7 @@
 				if($tag == "ACCESSCONSTRAINTS"){
 					$myWfs->accessconstraints = $element[value];
 				if($tag == "OPERATION" && $element[type] == "open"){
 					switch ($element[attributes][name]) {
 						case "GetCapabilities" :
@@ -166,7 +174,7 @@
 				if($section == "getcapabilities" && $tag == "GET"){
 					$myWfs->getCapabilities = html_entity_decode($element[attributes]["xlink:href"]);
 				# descriptFeatureType
 #				if($section == "describefeaturetype" && $tag == "POST"){
 #					$myWfs->describeFeatureType = html_entity_decode($element[attributes]["xlink:href"]);
@@ -176,7 +184,7 @@
 				if($section == "describefeaturetype" && $tag == "GET"){
 				# getFeature
 				if($section == "getfeature" && $tag == "POST"){
 					$myWfs->getFeature = html_entity_decode($element[attributes]["xlink:href"]);
@@ -188,7 +196,7 @@
 				if($tag == "OPERATION" && $element[type] == "close"){
-					$section = "";
+					$section = "";
 				if($tag == "FEATURETYPE" && $element[type] == "open"){
@@ -207,7 +215,7 @@
 				if($section == "featuretype" && $tag == "DEFAULTSRS"){
 					$featuretype_srs = $element[value];
-					$currentFeatureType = $this->createFeatureTypeFromUrl($myWfs, $featuretype_name, $featureTypeNsArray);
+					$currentFeatureType = $this->createFeatureTypeFromUrlGet($myWfs, $featuretype_name, $featureTypeNsArray);
 					if ($currentFeatureType !== null) {
 						$currentFeatureType->name = $featuretype_name;
 						$currentFeatureType->title = $featuretype_title;
@@ -229,7 +237,7 @@
 			return null;
 	public function createFromDb ($id) {
 		return parent::createFromDb($id, $myWfs);
More information about the Mapbender_commits mailing list
