[Mapbender-commits] r7150 - in
trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui:
. minified
svn_mapbender at osgeo.org
Wed Nov 24 06:07:14 EST 2010
Author: christoph
Date: 2010-11-24 03:07:13 -0800 (Wed, 24 Nov 2010)
New Revision: 7150
trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.autocomplete.js
trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.autocomplete.min.js
applied this patch: http://bugs.jqueryui.com/ticket/5405
Modified: trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.autocomplete.js
--- trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.autocomplete.js 2010-11-24 11:00:45 UTC (rev 7149)
+++ trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.autocomplete.js 2010-11-24 11:07:13 UTC (rev 7150)
@@ -102,6 +102,13 @@
this.menu = $( "<ul></ul>" )
.addClass( "ui-autocomplete" )
.appendTo( "body", doc )
+ // prevent the close-on-blur in case of a "slow" click on the menu (long mousedown)
+ .mousedown(function() {
+ // use another timeout to make sure the blur-event-handler on the input was already triggered
+ setTimeout(function() {
+ clearTimeout( self.closing );
+ }, 13);
.menu({
focus: function( event, ui ) {
var item = ui.item.data( "item.autocomplete" );
Modified: trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.autocomplete.min.js
--- trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.autocomplete.min.js 2010-11-24 11:00:45 UTC (rev 7149)
+++ trunk/mapbender/http/extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.autocomplete.min.js 2010-11-24 11:07:13 UTC (rev 7150)
@@ -12,17 +12,24 @@
* jquery.ui.widget.js
* jquery.ui.position.js
-(function(e){e.widget("ui.autocomplete",{options:{minLength:1,delay:300},_create:function(){var a=this,b=this.element[0].ownerDocument;this.element.addClass("ui-autocomplete-input").attr("autocomplete","off").attr({role:"textbox","aria-autocomplete":"list","aria-haspopup":"true"}).bind("keydown.autocomplete",function(c){var d=e.ui.keyCode;switch(c.keyCode){case d.PAGE_UP:a._move("previousPage",c);break;case d.PAGE_DOWN:a._move("nextPage",c);break;case d.UP:a._move("previous",c);c.preventDefault();
-break;case d.DOWN:a._move("next",c);c.preventDefault();break;case d.ENTER:a.menu.active&&c.preventDefault();case d.TAB:if(!a.menu.active)return;a.menu.select(c);break;case d.ESCAPE:a.element.val(a.term);a.close(c);break;case d.LEFT:case d.RIGHT:case d.SHIFT:case d.CONTROL:case d.ALT:break;default:clearTimeout(a.searching);a.searching=setTimeout(function(){a.search(null,c)},a.options.delay);break}}).bind("focus.autocomplete",function(){a.selectedItem=null;a.previous=a.element.val()}).bind("blur.autocomplete",
-function(c){clearTimeout(a.searching);a.closing=setTimeout(function(){a.close(c);a._change(c)},150)});this._initSource();this.response=function(){return a._response.apply(a,arguments)};this.menu=e("<ul></ul>").addClass("ui-autocomplete").appendTo("body",b).menu({focus:function(c,d){d=d.item.data("item.autocomplete");false!==a._trigger("focus",null,{item:d})&&/^key/.test(c.originalEvent.type)&&a.element.val(d.value)},selected:function(c,d){d=d.item.data("item.autocomplete");false!==a._trigger("select",
-c,{item:d})&&a.element.val(d.value);a.close(c);c=a.previous;if(a.element[0]!==b.activeElement){a.element.focus();a.previous=c}a.selectedItem=d},blur:function(){a.menu.element.is(":visible")&&a.element.val(a.term)}}).zIndex(this.element.zIndex()+1).css({top:0,left:0}).hide().data("menu");e.fn.bgiframe&&this.menu.element.bgiframe()},destroy:function(){this.element.removeClass("ui-autocomplete-input").removeAttr("autocomplete").removeAttr("role").removeAttr("aria-autocomplete").removeAttr("aria-haspopup");
-this.menu.element.remove();e.Widget.prototype.destroy.call(this)},_setOption:function(a){e.Widget.prototype._setOption.apply(this,arguments);a==="source"&&this._initSource()},_initSource:function(){var a,b;if(e.isArray(this.options.source)){a=this.options.source;this.source=function(c,d){d(e.ui.autocomplete.filter(a,c.term))}}else if(typeof this.options.source==="string"){b=this.options.source;this.source=function(c,d){e.getJSON(b,c,d)}}else this.source=this.options.source},search:function(a,b){a=
-a!=null?a:this.element.val();if(a.length<this.options.minLength)return this.close(b);clearTimeout(this.closing);if(this._trigger("search")!==false)return this._search(a)},_search:function(a){this.term=this.element.addClass("ui-autocomplete-loading").val();this.source({term:a},this.response)},_response:function(a){if(a.length){a=this._normalize(a);this._suggest(a);this._trigger("open")}else this.close();this.element.removeClass("ui-autocomplete-loading")},close:function(a){clearTimeout(this.closing);
-if(this.menu.element.is(":visible")){this._trigger("close",a);this.menu.element.hide();this.menu.deactivate()}},_change:function(a){this.previous!==this.element.val()&&this._trigger("change",a,{item:this.selectedItem})},_normalize:function(a){if(a.length&&a[0].label&&a[0].value)return a;return e.map(a,function(b){if(typeof b==="string")return{label:b,value:b};return e.extend({label:b.label||b.value,value:b.value||b.label},b)})},_suggest:function(a){var b=this.menu.element.empty().zIndex(this.element.zIndex()+
-1),c;this._renderMenu(b,a);this.menu.deactivate();this.menu.refresh();this.menu.element.show().position({my:"left top",at:"left bottom",of:this.element,collision:"none"});a=b.width("").width();c=this.element.width();b.width(Math.max(a,c))},_renderMenu:function(a,b){var c=this;e.each(b,function(d,f){c._renderItem(a,f)})},_renderItem:function(a,b){return e("<li></li>").data("item.autocomplete",b).append("<a>"+b.label+"</a>").appendTo(a)},_move:function(a,b){if(this.menu.element.is(":visible"))if(this.menu.first()&&
-/^previous/.test(a)||this.menu.last()&&/^next/.test(a)){this.element.val(this.term);this.menu.deactivate()}else this.menu[a](b);else this.search(null,b)},widget:function(){return this.menu.element}});e.extend(e.ui.autocomplete,{escapeRegex:function(a){return a.replace(/([\^\$\(\)\[\]\{\}\*\.\+\?\|\\])/gi,"\\$1")},filter:function(a,b){var c=new RegExp(e.ui.autocomplete.escapeRegex(b),"i");return e.grep(a,function(d){return c.test(d.label||d.value||d)})}})})(jQuery);
-(function(e){e.widget("ui.menu",{_create:function(){var a=this;this.element.addClass("ui-menu ui-widget ui-widget-content ui-corner-all").attr({role:"listbox","aria-activedescendant":"ui-active-menuitem"}).click(function(b){if(e(b.target).closest(".ui-menu-item a").length){b.preventDefault();a.select(b)}});this.refresh()},refresh:function(){var a=this;this.element.children("li:not(.ui-menu-item):has(a)").addClass("ui-menu-item").attr("role","menuitem").children("a").addClass("ui-corner-all").attr("tabindex",
--1).mouseenter(function(b){a.activate(b,e(this).parent())}).mouseleave(function(){a.deactivate()})},activate:function(a,b){this.deactivate();if(this.hasScroll()){var c=b.offset().top-this.element.offset().top,d=this.element.attr("scrollTop"),f=this.element.height();if(c<0)this.element.attr("scrollTop",d+c);else c>f&&this.element.attr("scrollTop",d+c-f+b.height())}this.active=b.eq(0).children("a").addClass("ui-state-hover").attr("id","ui-active-menuitem").end();this._trigger("focus",a,{item:b})},deactivate:function(){if(this.active){this.active.children("a").removeClass("ui-state-hover").removeAttr("id");
-this._trigger("blur");this.active=null}},next:function(a){this.move("next",".ui-menu-item:first",a)},previous:function(a){this.move("prev",".ui-menu-item:last",a)},first:function(){return this.active&&!this.active.prev().length},last:function(){return this.active&&!this.active.next().length},move:function(a,b,c){if(this.active){a=this.active[a+"All"](".ui-menu-item").eq(0);a.length?this.activate(c,a):this.activate(c,this.element.children(b))}else this.activate(c,this.element.children(b))},nextPage:function(a){if(this.hasScroll())if(!this.active||
-this.last())this.activate(a,this.element.children(":first"));else{var b=this.active.offset().top,c=this.element.height(),d=this.element.children("li").filter(function(){var f=e(this).offset().top-b-c+e(this).height();return f<10&&f>-10});d.length||(d=this.element.children(":last"));this.activate(a,d)}else this.activate(a,this.element.children(!this.active||this.last()?":first":":last"))},previousPage:function(a){if(this.hasScroll())if(!this.active||this.first())this.activate(a,this.element.children(":last"));
-else{var b=this.active.offset().top,c=this.element.height();result=this.element.children("li").filter(function(){var d=e(this).offset().top-b+c-e(this).height();return d<10&&d>-10});result.length||(result=this.element.children(":first"));this.activate(a,result)}else this.activate(a,this.element.children(!this.active||this.first()?":last":":first"))},hasScroll:function(){return this.element.height()<this.element.attr("scrollHeight")},select:function(a){this._trigger("selected",a,{item:this.active})}})})(jQuery);
+(function($){$.widget("ui.autocomplete",{options:{minLength:1,delay:300},_create:function(){var self=this,doc=this.element[0].ownerDocument;this.element.addClass("ui-autocomplete-input").attr("autocomplete","off").attr({role:"textbox","aria-autocomplete":"list","aria-haspopup":"true"}).bind("keydown.autocomplete",function(event){var keyCode=$.ui.keyCode;switch(event.keyCode){case keyCode.PAGE_UP:self._move("previousPage",event);break;case keyCode.PAGE_DOWN:self._move("nextPage",event);break;case keyCode.UP:self._move("previous",event);event.preventDefault();break;case keyCode.DOWN:self._move("next",event);event.preventDefault();break;case keyCode.ENTER:if(self.menu.active){event.preventDefault();}
+case keyCode.TAB:if(!self.menu.active){return;}
+self.menu.select(event);break;case keyCode.ESCAPE:self.element.val(self.term);self.close(event);break;case keyCode.LEFT:case keyCode.RIGHT:case keyCode.SHIFT:case keyCode.CONTROL:case keyCode.ALT:break;default:clearTimeout(self.searching);self.searching=setTimeout(function(){self.search(null,event);},self.options.delay);break;}}).bind("focus.autocomplete",function(){self.selectedItem=null;self.previous=self.element.val();}).bind("blur.autocomplete",function(event){clearTimeout(self.searching);self.closing=setTimeout(function(){self.close(event);self._change(event);},150);});this._initSource();this.response=function(){return self._response.apply(self,arguments);};this.menu=$("<ul></ul>").addClass("ui-autocomplete").appendTo("body",doc).mousedown(function(){setTimeout(function(){clearTimeout(self.closing);},13);}).menu({focus:function(event,ui){var item=ui.item.data("item.autocomplete");if(false!==self._trigger("focus",null,{item:item})){if(/^key/.test(event.originalEvent.type
)){self.element.val(item.value);}}},selected:function(event,ui){var item=ui.item.data("item.autocomplete");if(false!==self._trigger("select",event,{item:item})){self.element.val(item.value);}
+self.close(event);var previous=self.previous;if(self.element[0]!==doc.activeElement){self.element.focus();self.previous=previous;}
+self.selectedItem=item;},blur:function(event,ui){if(self.menu.element.is(":visible")){self.element.val(self.term);}}}).zIndex(this.element.zIndex()+1).css({top:0,left:0}).hide().data("menu");if($.fn.bgiframe){this.menu.element.bgiframe();}},destroy:function(){this.element.removeClass("ui-autocomplete-input").removeAttr("autocomplete").removeAttr("role").removeAttr("aria-autocomplete").removeAttr("aria-haspopup");this.menu.element.remove();$.Widget.prototype.destroy.call(this);},_setOption:function(key){$.Widget.prototype._setOption.apply(this,arguments);if(key==="source"){this._initSource();}},_initSource:function(){var array,url;if($.isArray(this.options.source)){array=this.options.source;this.source=function(request,response){response($.ui.autocomplete.filter(array,request.term));};}else if(typeof this.options.source==="string"){url=this.options.source;this.source=function(request,response){$.getJSON(url,request,response);};}else{this.source=this.options.source;}},search:f
unction(value,event){value=value!=null?value:this.element.val();if(value.length<this.options.minLength){return this.close(event);}
+clearTimeout(this.closing);if(this._trigger("search")===false){return;}
+return this._search(value);},_search:function(value){this.term=this.element.addClass("ui-autocomplete-loading").val();this.source({term:value},this.response);},_response:function(content){if(content.length){content=this._normalize(content);this._suggest(content);this._trigger("open");}else{this.close();}
+this.element.removeClass("ui-autocomplete-loading");},close:function(event){clearTimeout(this.closing);if(this.menu.element.is(":visible")){this._trigger("close",event);this.menu.element.hide();this.menu.deactivate();}},_change:function(event){if(this.previous!==this.element.val()){this._trigger("change",event,{item:this.selectedItem});}},_normalize:function(items){if(items.length&&items[0].label&&items[0].value){return items;}
+return $.map(items,function(item){if(typeof item==="string"){return{label:item,value:item};}
+return $.extend({label:item.label||item.value,value:item.value||item.label},item);});},_suggest:function(items){var ul=this.menu.element.empty().zIndex(this.element.zIndex()+1),menuWidth,textWidth;this._renderMenu(ul,items);this.menu.deactivate();this.menu.refresh();this.menu.element.show().position({my:"left top",at:"left bottom",of:this.element,collision:"none"});menuWidth=ul.width("").width();textWidth=this.element.width();ul.width(Math.max(menuWidth,textWidth));},_renderMenu:function(ul,items){var self=this;$.each(items,function(index,item){self._renderItem(ul,item);});},_renderItem:function(ul,item){return $("<li></li>").data("item.autocomplete",item).append("<a>"+item.label+"</a>").appendTo(ul);},_move:function(direction,event){if(!this.menu.element.is(":visible")){this.search(null,event);return;}
+if(this.menu.first()&&/^previous/.test(direction)||this.menu.last()&&/^next/.test(direction)){this.element.val(this.term);this.menu.deactivate();return;}
+this.menu[direction](event);},widget:function(){return this.menu.element;}});$.extend($.ui.autocomplete,{escapeRegex:function(value){return value.replace(/([\^\$\(\)\[\]\{\}\*\.\+\?\|\\])/gi,"\\$1");},filter:function(array,term){var matcher=new RegExp($.ui.autocomplete.escapeRegex(term),"i");return $.grep(array,function(value){return matcher.test(value.label||value.value||value);});}});}(jQuery));(function($){$.widget("ui.menu",{_create:function(){var self=this;this.element.addClass("ui-menu ui-widget ui-widget-content ui-corner-all").attr({role:"listbox","aria-activedescendant":"ui-active-menuitem"}).click(function(event){if(!$(event.target).closest(".ui-menu-item a").length){return;}
+event.preventDefault();self.select(event);});this.refresh();},refresh:function(){var self=this;var items=this.element.children("li:not(.ui-menu-item):has(a)").addClass("ui-menu-item").attr("role","menuitem");items.children("a").addClass("ui-corner-all").attr("tabindex",-1).mouseenter(function(event){self.activate(event,$(this).parent());}).mouseleave(function(){self.deactivate();});},activate:function(event,item){this.deactivate();if(this.hasScroll()){var offset=item.offset().top-this.element.offset().top,scroll=this.element.attr("scrollTop"),elementHeight=this.element.height();if(offset<0){this.element.attr("scrollTop",scroll+offset);}else if(offset>elementHeight){this.element.attr("scrollTop",scroll+offset-elementHeight+item.height());}}
+this.active=item.eq(0).children("a").addClass("ui-state-hover").attr("id","ui-active-menuitem").end();this._trigger("focus",event,{item:item});},deactivate:function(){if(!this.active){return;}
+this.active.children("a").removeClass("ui-state-hover").removeAttr("id");this._trigger("blur");this.active=null;},next:function(event){this.move("next",".ui-menu-item:first",event);},previous:function(event){this.move("prev",".ui-menu-item:last",event);},first:function(){return this.active&&!this.active.prev().length;},last:function(){return this.active&&!this.active.next().length;},move:function(direction,edge,event){if(!this.active){this.activate(event,this.element.children(edge));return;}
+var next=this.active[direction+"All"](".ui-menu-item").eq(0);if(next.length){this.activate(event,next);}else{this.activate(event,this.element.children(edge));}},nextPage:function(event){if(this.hasScroll()){if(!this.active||this.last()){this.activate(event,this.element.children(":first"));return;}
+var base=this.active.offset().top,height=this.element.height(),result=this.element.children("li").filter(function(){var close=$(this).offset().top-base-height+$(this).height();return close<10&&close>-10;});if(!result.length){result=this.element.children(":last");}
+this.activate(event,result);}else{this.activate(event,this.element.children(!this.active||this.last()?":first":":last"));}},previousPage:function(event){if(this.hasScroll()){if(!this.active||this.first()){this.activate(event,this.element.children(":last"));return;}
+var base=this.active.offset().top,height=this.element.height();result=this.element.children("li").filter(function(){var close=$(this).offset().top-base+height-$(this).height();return close<10&&close>-10;});if(!result.length){result=this.element.children(":first");}
+this.activate(event,result);}else{this.activate(event,this.element.children(!this.active||this.first()?":last":":first"));}},hasScroll:function(){return this.element.height()<this.element.attr("scrollHeight");},select:function(event){this._trigger("selected",event,{item:this.active});}});}(jQuery));
\ No newline at end of file
More information about the Mapbender_commits
