[Mapbender-commits] r7151 - in trunk/mapbender/http: classes plugins
svn_mapbender at osgeo.org
Wed Nov 24 07:11:35 EST 2010
Author: verenadiewald
Date: 2010-11-24 04:11:35 -0800 (Wed, 24 Nov 2010)
New Revision: 7151
Added:
trunk/mapbender/http/plugins/mb_metadata_wmc_edit.js
trunk/mapbender/http/plugins/mb_metadata_wmc_edit.php
trunk/mapbender/http/plugins/mb_metadata_wmc_select.js
trunk/mapbender/http/plugins/mb_metadata_wmc_showOriginal.html
trunk/mapbender/http/plugins/mb_metadata_wmc_showOriginal.js
trunk/mapbender/http/plugins/mb_metadata_wmc_submit.js
trunk/mapbender/http/plugins/mb_original_metadata_wmc_server.php
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/plugins/mb_metadata_wmc_server.php
metadata editor wmc
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2010-11-24 11:07:13 UTC (rev 7150)
+++ trunk/mapbender/http/classes/class_wmc.php 2010-11-24 12:11:35 UTC (rev 7151)
@@ -125,6 +125,8 @@
var $wmc_descriptionurl_type;
var $inspireCats;
+ var $isoTopicCats;
+ var $customCats;
public function __construct () {
$this->userId = Mapbender::session()->get("mb_user_id");
@@ -155,7 +157,7 @@
return false;
$this->createObjFromWMC_xml($doc);
- $sql = "SELECT wmc_timestamp, wmc_title, wmc_public " .
+ $sql = "SELECT wmc_timestamp, wmc_title, wmc_public, srs, minx, miny, maxx, maxy " .
"FROM mb_user_wmc WHERE wmc_serial_id = $1 AND (fkey_user_id = $2 OR wmc_public = 1)";
$v = array($wmcId, Mapbender::session()->get("mb_user_id"));
$t = array("i", "i");
@@ -167,6 +169,11 @@
$this->timestamp = $row[0];
$this->title = $row[1];
$this->public = $row[2];
+ $this->wmc_srs = $row[3];
+ $this->wmc_extent->minx = $row[4];
+ $this->wmc_extent->miny = $row[5];
+ $this->wmc_extent->maxx = $row[6];
+ $this->wmc_extent->maxy = $row[7];
return true;
return false;
@@ -253,8 +260,6 @@
return array_keys( array_flip(array_merge($wmcOwnerArray, $publicWmcIdArray)));
public function selectByUser ($user) {
$wmcArray = array();
@@ -323,6 +328,7 @@
while ($row = db_fetch_array($res)) {
$keywordArray[]= $row["keyword"];
return $keywordArray;
@@ -332,19 +338,19 @@
return array();
- $keywordArray = array();
+ $categoryArray = array();
$sql = "SELECT DISTINCT t.md_topic_category_id FROM " .
"md_topic_category AS t, wmc_md_topic_category AS w " .
"WHERE w.fkey_md_topic_category_id = t.md_topic_category_id " .
"AND w.fkey_wmc_serial_id = $1";
$v = array($id);
- $t = array("s");
+ $t = array("i");
$res = db_prep_query($sql, $v, $t);
- $keywordArray[]= $row["md_topic_category_id"];
+ $categoryArray[]= $row["md_topic_category_id"];
- return $keywordArray;
+ return $categoryArray;
private function compareWms ($a, $b) {
@@ -568,8 +574,6 @@
new mb_exception("WMC XML is broken.");
- $NewDoc = new DOMDocument();
$xpath = new DOMXPath($WMCDoc);
$xpath->registerNamespace("wmc","http://www.opengis.net/context");
$xpath->registerNamespace("mapbender","http://www.mapbender.org/context");
@@ -580,21 +584,24 @@
$DocKeywordLists = $xpath->query($query_KeywordList);
// we just use a single <general> element
- $NewKeywordList = new DOMElement('KeywordList','','http://opengis.net/context');
- $NewDoc->appendChild($NewKeywordList);
- foreach($this->keyword as $keyword) {
- $Keyword = new DOMElement('Keyword',$keyword, 'http://opengis.net/context');
+ $NewKeywordList = $WMCDoc->createElementNS('http://opengis.net/context', 'wmc:KeywordList');
+ $WMCDoc->appendChild($NewKeywordList);
+ foreach($this->wmc_keyword as $keyword) {
+ $Keyword = $WMCDoc->createElementNS('http://opengis.net/context', 'wmc:Keyword', $keyword);
$NewKeywordList->appendChild($Keyword);
$generalList = $xpath->query($query_general);
$general = $generalList->item(0);
if($DocKeywordLists->item(0)) {
- $general->replaceChild($NewKeywordList,$DocKeywordList->item(0));
- }else {
+ $tmpNode = $WMCDoc->importNode($DocKeywordLists->item(0),true);
+ $general->replaceChild($NewKeywordList,$tmpNode);
+ else {
$tmpNode = $WMCDoc->importNode($NewKeywordList,true);
$general->appendChild($tmpNode);
$this->xml = $WMCDoc->saveXML();
@@ -622,20 +629,28 @@
$v = array($this->xml, time(), $this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->minx,
$this->wmc_extent->maxx, $this->wmc_extent->maxy ,administration::convertOutgoingString($this->wmc_title), $this->userId, $this->wmc_id,$row[2]);
$t = array("s", "s","s","s","i","i","i","i", "s", "i", "i","s");
+ $res = db_prep_query($sql, $v, $t);
// need the database Id
$wmc_DB_ID = $row[3];
+ $delsqlCustomTopic = "DELETE FROM wmc_custom_category WHERE fkey_wmc_serial_id = $1;";
+ $delvCustomTopic = array($wmc_DB_ID);
+ $deltCustomTopic = array("s");
+ db_prep_query($delsqlCustomTopic, $delvCustomTopic,$deltCustomTopic);
+ $delsqlInspireTopic = "DELETE FROM wmc_inspire_category WHERE fkey_wmc_serial_id = $1;";
+ $delvInspireTopic= array($wmc_DB_ID);
+ $deltInspireTopic = array("s");
+ db_prep_query($delsqlInspireTopic, $delvInspireTopic,$deltInspireTopic);
$delsql = "DELETE FROM wmc_md_topic_category WHERE fkey_wmc_serial_id = $1;";
$delv = array($wmc_DB_ID);
$delt = array("s");
db_prep_query($delsql, $delv,$delt);
$delkwsql = "DELETE FROM wmc_keyword WHERE fkey_wmc_serial_id = $1;";
$delkwv = array($wmc_DB_ID);
$delkwt = array("s");
db_prep_query($delkwsql, $delkwv,$delkwt);
else {
$sql = "INSERT INTO mb_user_wmc (" .
@@ -645,10 +660,15 @@
$v = array(time(), $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $user->isPublic()?1:0,time(),time(),
$this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->miny, $this->wmc_extent->maxx, $this->wmc_extent->maxy);
$t = array("s", "i", "s", "s", "i", "s","s", "s","s","i","i","i", "i");
+ $sql = "SELECT max(wmc_serial_id) AS i FROM mb_user_wmc";
+ $res = db_query($sql);
+ $row = db_fetch_assoc($res);
+ $wmc_DB_ID = intval($row["i"]);
else {
"wmc_id, fkey_user_id, wmc, wmc_title, wmc_public, wmc_timestamp, wmc_timestamp_create, " .
"abstract, srs, minx, miny, maxx, maxy ".
@@ -656,11 +676,14 @@
$v = array(time(), $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $user->isPublic()?1:0, time(),time(),
- $res = db_prep_query($sql, $v, $t);
if (db_error()) {
$errMsg = "Error while saving WMC document '" . $this->wmc_title . "': " . db_error();
$result["success"] = false;
@@ -674,30 +697,25 @@
if(!isset($wmc_DB_ID)) { $wmc_DB_ID = $this->wmc_id; }
// update keywords
// if a keyword does not yet exist, create it
$keywordExistsSql = "SELECT keyword FROM keyword WHERE keyword = $1";
$keywordCreateSql = "INSERT INTO keyword (keyword) VALUES($1);";
$v = array($keyword);
$t = array("s");
- $res = db_prep_query($keywordExistsSql,$v,$t);
+ $res = db_prep_query($keywordExistsSql,$v,$t);
if(db_num_rows($res) == 0) {
$res = db_prep_query($keywordCreateSql,$v,$t);
if($a = db_error()) {
- $sql = "SELECT max(wmc_serial_id) AS i FROM mb_user_wmc";
- $res = db_query($sql);
- $row = db_fetch_assoc($res);
- $wmc_DB_ID = intval($row["i"]);
$keywordsql = <<<SQL
INSERT INTO wmc_keyword (fkey_keyword_id,fkey_wmc_serial_id)
SELECT keyword.keyword_id,$1 FROM keyword
- WHERE keyword = $2 AND NOT EXISTS (
- SELECT fkey_wmc_serial_id FROM wmc_keyword WHERE fkey_wmc_serial_id = $3
+ WHERE keyword = $2 AND keyword.keyword_id NOT IN (
+ SELECT fkey_keyword_id FROM wmc_keyword WHERE fkey_wmc_serial_id = $3
SQL;
$v = array($wmc_DB_ID, $keyword,$wmc_DB_ID);
@@ -705,19 +723,41 @@
$res = db_prep_query($keywordsql, $v, $t);
+ // update iso topic categories
+ $this->isoTopicCats = $this->isoTopicCats? $this->isoTopicCats: array();
+ foreach($this->isoTopicCats as $catId) {
+ $catSql = "INSERT INTO wmc_md_topic_category (fkey_wmc_serial_id, fkey_md_topic_category_id) VALUES ($1,$2)";
+ $v = array($wmc_DB_ID, $catId);
+ $t = array("s","s");
+ $res = db_prep_query($catSql, $v, $t);
- // update categories
+ // update inspire categories
$this->inspireCats = $this->inspireCats? $this->inspireCats: array();
foreach($this->inspireCats as $catId) {
- $catSql = "INSERT INTO wmc_md_topic_category (fkey_wmc_serial_id, fkey_md_topic_category_id) VALUES ($1,$2)";
+ $catSql = "INSERT INTO wmc_inspire_category (fkey_wmc_serial_id, fkey_inspire_category_id) VALUES ($1,$2)";
+ // update custom categories
+ $this->customCats = $this->customCats? $this->customCats: array();
+ foreach($this->customCats as $catId) {
+ $catSql = "INSERT INTO wmc_custom_category (fkey_wmc_serial_id, fkey_custom_category_id) VALUES ($1,$2)";
$result["success"] = true;
$msg = "WMC document '" . $this->wmc_title . "' has been saved.";
$result["message"] = $msg;
@@ -825,7 +865,7 @@
if ($currentUser->isPublic()) {
return false;
- $wmcId = $this->wmc_Id;
+ $wmcId = $this->wmc_id;
$public = $public ? 1 :0;
$sql = "UPDATE mb_user_wmc SET wmc_public = $1 WHERE wmc_serial_id = $2 AND fkey_user_id = $3;";
$v = array($public,$wmcId, $currentUser->id);
Added: trunk/mapbender/http/plugins/mb_metadata_wmc_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_wmc_edit.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_edit.js 2010-11-24 12:11:35 UTC (rev 7151)
@@ -0,0 +1,143 @@
+ * Package: mb_metadata_wmc_edit
+ * Description:
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $metadataEdit = $(this);
+var $metadataForm = $("<form>No WMC selected.</form>").appendTo($metadataEdit);
+var MetadataEditApi = function (o) {
+ var that = this;
+ var validator;
+ var formReady = false;
+ var wmcId;
+ this.events = {
+ showOriginalMetadata : new Mapbender.Event(),
+ submit: new Mapbender.Event()
+ this.valid = function () {
+ if (validator && validator.numberOfInvalids() > 0) {
+ $metadataForm.valid();
+ return false;
+ return true;
+ this.serialize = function (callback) {
+ $metadataForm.submit();
+ var data = null;
+ if (this.valid()) {
+ data = {
+ wmc: $metadataForm.easyform("serialize")
+ if ($.isFunction(callback)) {
+ callback(data);
+ return data !== null ? data.wmc : data;
+ // second optional parameter formData
+ var fillForm = function (obj) {
+ if (arguments.length >= 2) {
+ $metadataForm.easyform("reset");
+ $metadataForm.easyform("fill", arguments[1]);
+ that.valid();
+ return;
+ // get metadata from server
+ var req = new Mapbender.Ajax.Request({
+ url: "../plugins/mb_metadata_wmc_server.php",
+ method: "getWmcMetadata",
+ parameters: {
+ "id": obj
+ callback: function (obj, result, message) {
+ if (!result) {
+ return;
+ $metadataForm.easyform("fill", obj);
+ that.valid();
+ req.send();
+ this.fill = function (obj) {
+ var showOriginalMetadata = function () {
+ that.events.showOriginalMetadata.trigger({
+ data : {
+ wmcId : wmcId,
+ wmcData : $metadataForm.easyform("serialize")
+ this.init = function (obj) {
+ wmcId = obj;
+ var formData = arguments.length >= 2 ? arguments[1] : undefined;
+ if (!formReady) {
+ $metadataForm.load("../plugins/mb_metadata_wmc_edit.php", function () {
+ $metadataForm.find(".help-dialog").helpDialog();
+ $metadataForm.find(".original-metadata-wmc").bind("click", function() {
+ showOriginalMetadata();
+ validator = $metadataForm.validate({
+ submitHandler: function () {
+ return false;
+ if (formData !== undefined) {
+ fillForm(obj, formData);
+ else {
+ fillForm(obj);
+ formReady = true;
+ return;
+ fillForm(obj);
+ Mapbender.events.localize.register(function () {
+ if (!wmcId) {
+ return;
+ that.valid();
+ var formData = $metadataForm.easyform("serialize");
+ formReady = false;
+ that.init(wmcId, formData);
+ Mapbender.events.init.register(function () {
+ that.valid();
+$metadataEdit.mapbender(new MetadataEditApi(options));
Added: trunk/mapbender/http/plugins/mb_metadata_wmc_edit.php
--- trunk/mapbender/http/plugins/mb_metadata_wmc_edit.php (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_edit.php 2010-11-24 12:11:35 UTC (rev 7151)
@@ -0,0 +1,94 @@
+<?php
+ require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+ function displayCategories ($sql) {
+ if (Mapbender::session()->get("mb_lang") === "de") {
+ $sql = str_replace("category_code_en", "category_code_de", $sql);
+ $str = "";
+ while ($row = db_fetch_assoc($res)) {
+ $str .= "<option value='" . $row["id"] . "'>" .
+ htmlentities($row["name"], ENT_QUOTES, CHARSET) .
+ "</option>";
+ return $str;
+<div id="wmc">
+<fieldset>
+ <input name="wmc_id" id="wmc_id" type="hidden"/>
+ <legend><?php echo _mb("Service Level Metadata");?>: <img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Possibility to adapt and add informations in the separate WMC-Featuretype Metadata. The modified Metadata is stored in the database of the GeoPortal.rlp, outwardly these metadata overwrite the original Service-Metadata.");?>'}" src="../img/questionmark.png"></img></legend>
+ <p>
+ <label><?php echo _mb("Show original Service Metadata from last update");?></label>
+ <img class="original-metadata-wmc" src="../img/book.png"></img>
+ <img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("The original WMC-Metadata from the last update could be recovered or updated, so that the original Service-Metadata will be shown outward again.");?>'}" src="../img/questionmark.png"></img>
+ </p>
+ <p>
+ <label for="wmc_title"><?php echo _mb("WMC Title (OWS)");?>:</label>
+ <input name="wmc_title" id="wmc_title" class="required"/>
+ <img class="metadata_img" title="<?php echo _mb("Inspire");?>" src="../img/misc/inspire_eu_klein.png"></img>
+ </p>
+ <p>
+ <label for="wmc_abstract"><?php echo _mb("WMC Abstract (OWS)");?>:</label>
+ <input name="wmc_abstract" id="wmc_abstract"/>
+ </p>
+ <p>
+ <label for="wmc_keyword"><?php echo _mb("WMC Keywords (OWS)");?>:</label>
+ <input name="wmc_keyword" id="wmc_keyword"/>
+ </p>
+ <p>
+ <label for="public"><?php echo _mb("WMC is public");?>:</label>
+ <input name="public" id="public" type="checkbox"/>
+ </p>
+</fieldset>
+</div>
+<div id="preview">
+ <fieldset class="">
+ <div id="map"></div>
+ <div id="toolbar_upper"></div>
+ <div id="toolbar_lower"></div>
+ </fieldset>
+</div>
+<div id="classification">
+ <legend><?php echo _mb("Classification");?></legend>
+ <p>
+ <label for="isoTopicCats" class="label_classification"><?php echo _mb("ISO Topic Category");?>:</label>
+ <select class="metadata_selectbox" id="isoTopicCats" name="isoTopicCats" size="2" multiple="multiple">
+<?php
+ $sql = "SELECT md_topic_category_id AS id, md_topic_category_code_en AS name FROM md_topic_category";
+ echo displayCategories($sql);
+ </select>
+ </p>
+ <p>
+ <label for="inspireCats" class="label_classification"><?php echo _mb("INSPIRE Category");?>:</label>
+ <select class="metadata_selectbox" id="inspireCats" name="inspireCats" size="2" multiple="multiple">
+<?php
+ $sql = "SELECT inspire_category_id AS id, inspire_category_code_en AS name FROM inspire_category";
+ </select>
+ </p>
+ <p>
+ <label for="customCats" class="label_classification"><?php echo _mb("Custom Category");?>:</label>
+ <span class="metadata_span"></span>
+ <select class="metadata_selectbox" id="customCats" name="customCats" size="2" multiple="multiple">
+<?php
+ $sql = "SELECT custom_category_id AS id, custom_category_code_en AS name FROM custom_category";
+ </select>
+ </p>
+ </fieldset>
+</div>
Added: trunk/mapbender/http/plugins/mb_metadata_wmc_select.js
--- trunk/mapbender/http/plugins/mb_metadata_wmc_select.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_select.js 2010-11-24 12:11:35 UTC (rev 7151)
@@ -0,0 +1,104 @@
+ * Package: mb_metadata_wmc_select
+ * Description:
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * License:
+var $metadataSelect = $(this);
+$metadataSelect.prepend("<img src='../img/indicator_wheel.gif'>");
+var MetadataSelectApi = function (o) {
+ var table = null;
+ var that = this;
+ var fnGetSelected = function (oTableLocal){
+ var aReturn = [];
+ var aTrs = oTableLocal.fnGetNodes();
+ for ( var i=0 ; i<aTrs.length ; i++ ){
+ if ( $(aTrs[i]).hasClass('row_selected') ){
+ aReturn.push( aTrs[i] );
+ return aReturn;
+ this.getData = function () {
+ method: "getWmc",
+ parameters: {
+ if (!result) {
+ return;
+ $metadataSelect.find("img").remove();
+ var aoColumns = [];
+ for (var i in obj.header) {
+ if (obj.header[i] === "WMC ID") {
+ continue;
+ aoColumns.push({"sTitle": obj.header[i]});
+ // initialize datatables
+ table = $metadataSelect.find("table").dataTable({
+ "aoColumns": aoColumns,
+ "bJQueryUI": true,
+ "bAutoWidth": false
+ // add rows
+ for (var j in obj.data) {
+ var data = obj.data[j];
+ var wmcId = data[0];
+ data.shift();
+ var index = table.fnAddData(data);
+ var rowNode = table.fnGetNodes(index[0]);
+ $(rowNode).data("wmcId", wmcId);
+ // make rows selectable
+ $metadataSelect.find("tbody").click(function (e) {
+ $(table.fnSettings().aoData).each(function (){
+ $(this.nTr).removeClass('row_selected');
+ $(e.target.parentNode).addClass('row_selected');
+ var selectedRow = fnGetSelected(table);
+ $metadataSelect.fadeOut(function () {
+ that.events.selected.trigger({
+ wmcId: $(selectedRow).data("wmcId")
+ $metadataSelect.show();
+ req.send();
+ this.events = {
+ selected: new Mapbender.Event()
+$metadataSelect.mapbender(new MetadataSelectApi(options));
+$metadataSelect.mapbender("getData");
\ No newline at end of file
Modified: trunk/mapbender/http/plugins/mb_metadata_wmc_server.php
--- trunk/mapbender/http/plugins/mb_metadata_wmc_server.php 2010-11-24 11:07:13 UTC (rev 7150)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_server.php 2010-11-24 12:11:35 UTC (rev 7151)
@@ -16,7 +16,9 @@
function getWmc ($wmcId = null) {
$user = new User(Mapbender::session()->get("mb_user_id"));
- $wmcIdArray = $user->getOwnedWmc();
+ $wmcIdArray = $user->getWmcByOwner();
+ //getAccessibleWmcs();
if (!is_array($wmcIdArray) || count($wmcIdArray) === 0) {
abort(_mb("No metadata sets available."));
@@ -26,28 +28,14 @@
return $wmcIdArray;
-/*function getFeaturetype ($featuretypeId = null) {
- $user = new User(Mapbender::session()->get("mb_user_id"));
- $wfsIdArray = $user->getOwnedWfs();
- if (!is_array($wfsIdArray) || count($wfsIdArray) === 0) {
- abort(_mb("No metadata sets available."));
- $wfsId = wfs::getWfsIdByFeaturetypeId($featuretypeId);
- if (is_null($wfsId) || !in_array($wfsId, $wfsIdArray)) {
- abort(_mb("You are not allowed to access this WFS " . $wfsId));
- return;
switch ($ajaxResponse->getMethod()) {
case "getWmc" :
- $wmcIdArray = getWfs();
+ $wmcIdArray = getWmc();
$wmcList = implode(",", $wmcIdArray);
$sql = <<<SQL
-SELECT mb_user_wmc.wmc_serial_id as wmc_id, mb_user_wmc.wmc_title, mb_user_wmc.wmc_timestamp FROM mb_user_wmc WHERE wmc_serial_id IN ($wmcList);
+SELECT mb_user_wmc.wmc_serial_id as wmc_id, mb_user_wmc.wmc_title, mb_user_wmc.wmc_timestamp, wmc_load_count.load_count FROM mb_user_wmc
+LEFT JOIN wmc_load_count ON wmc_load_count.fkey_wmc_serial_id = mb_user_wmc.wmc_serial_id WHERE wmc_serial_id IN ($wmcList);
SQL;
@@ -55,7 +43,8 @@
"header" => array(
"WMC ID",
"Titel",
- "Timestamp"
+ "Timestamp",
+ "Load Count"
"data" => array()
@@ -71,33 +60,31 @@
case "getWmcMetadata" :
$wmcId = $ajaxResponse->getParameter("id");
- getWmcs($wmcId);
$sql = <<<SQL
-SELECT wmc_serial_id as wmc_id, wmc_abstract, wmc_title
-individualname, positionname, providername, voice,
-wmc_timestamp, wmc_timestamp_create
+SELECT wmc_serial_id as wmc_id, abstract, wmc_title,
+wmc_timestamp, wmc_timestamp_create, wmc_public
FROM mb_user_wmc WHERE wmc_serial_id = $wmcId;
SQL;
- $resultObj = array();
+ $resultObj = array();
$resultObj['wmc_id'] = $row['wmc_id'];
- $resultObj['summary'] = $row['wmc_abstract'];
- $resultObj['title'] = $row['wfs_title'];
- $resultObj['fees'] = $row['fees'];
+ $resultObj['wmc_abstract'] = $row['abstract'];
+ $resultObj['wmc_title'] = $row['wmc_title'];
$resultObj['wmc_timestamp'] = $row['wmc_timestamp'] != "" ? date('d.m.Y', $row['wmc_timestamp']) : "";
$resultObj['wmc_timestamp_create'] = $row['wmc_timestamp_create'] != "" ? date('d.m.Y', $row['wmc_timestamp_create']) : "";
+ $resultObj['public'] = $row['wmc_public'] == 1 ? true : false;
$keywordSql = <<<SQL
SELECT DISTINCT keyword FROM keyword, wmc_keyword
WHERE keyword_id = fkey_keyword_id AND
-fkey_wmc_id = $wmcId ORDER BY keyword
+fkey_wmc_serial_id = $wmcId ORDER BY keyword
SQL;
@@ -107,54 +94,16 @@
$keywords[]= $keywordRow["keyword"];
- $resultObj["wmc_keywords"] = implode(", ", $keywords);
- $termsofuseSql = <<<SQL
-SELECT fkey_termsofuse_id FROM wfs_termsofuse WHERE fkey_wfs_id = $wfsId
-SQL;
+ $resultObj["wmc_keyword"] = implode(", ", $keywords);
- $termsofuseRes = db_query($termsofuseSql);
- if ($termsofuseRes) {
- $termsofuseRow = db_fetch_assoc($termsofuseRes);
- $resultObj["wfs_termsofuse"] = $termsofuseRow["fkey_termsofuse_id"];
- else {
- $resultObj["wfs_termsofuse"] = null;
- $ajaxResponse->setResult($resultObj);
- $ajaxResponse->setSuccess(true);
- break;
- case "getFeaturetypeMetadata" :
- $featuretypeId = $ajaxResponse->getParameter("id");
- getFeaturetype($featuretypeId);
$sql = <<<SQL
-SELECT featuretype_id, featuretype_name, featuretype_title, featuretype_abstract, featuretype_searchable
-FROM wfs_featuretype WHERE featuretype_id = $featuretypeId;
-SQL;
- while ($row = db_fetch_assoc($res)) {
- foreach ($row as $key => $value) {
- $resultObj[$key] = $value;
- $sql = <<<SQL
SELECT fkey_md_topic_category_id
WHERE fkey_wmc_serial_id = $wmcId
SQL;
- $resultObj["wmc_md_topic_category_id"][]= $row["fkey_md_topic_category_id"];
+ $resultObj["isoTopicCats"][]= $row["fkey_md_topic_category_id"];
$sql = <<<SQL
@@ -164,7 +113,7 @@
SQL;
- $resultObj["wmc_inspire_category_id"][]= $row["fkey_inspire_category_id"];
+ $resultObj["inspireCats"][]= $row["fkey_inspire_category_id"];
$sql = <<<SQL
@@ -174,90 +123,15 @@
SQL;
- $resultObj["wmc_custom_category_id"][]= $row["fkey_custom_category_id"];
+ $resultObj["customCats"][]= $row["fkey_custom_category_id"];
- $sql = <<<SQL
-SELECT keyword FROM keyword, wfs_featuretype_keyword
-WHERE keyword_id = fkey_keyword_id AND fkey_featuretype_id = $featuretypeId
-SQL;
- $resultObj["featuretype_keyword"] = array();
- $resultObj["featuretype_keyword"][]= $row["keyword"];
break;
- case "getFeaturetypeByWfs" :
- $wfsId = $ajaxResponse->getParameter("id");
-// getWms($wmsId);
- $sql = <<<SQL
-FROM wfs_featuretype WHERE fkey_wfs_id = $wfsId ORDER BY featuretype_id;
-SQL;
- $rows = array();
- $rows[] = $row;
- $left = 1;
- function createNode ($left, $right, $row) {
- return array(
- "left" => $left,
- "right" => $right,
- #"parent" => $row["layer_parent"] !== "" ? intval($row["layer_parent"]) : null,
- #"pos" => intval($row["layer_pos"]),
- "attr" => array (
- "featuretype_id" => intval($row["featuretype_id"]),
- "featuretype_name" => $row["featuretype_name"],
- "featuretype_title" => $row["featuretype_title"],
- "featuretype_abstract" => $row["featuretype_abstract"]
- function addSubTree ($rows, $i, $left) {
- $nodeArray = array();
- $addNewNode = true;
- for ($j = $i; $j < count($rows); $j++) {
- $row = $rows[$j];
- $pos = $j;
- // first node of subtree
- if ($addNewNode) {
- $nodeArray[]= createNode($left, null, $row);
- $addNewNode = false;
- else {
- $nodeArray[count($nodeArray)-1]["right"] = ++$left;
- $nodeArray[]= createNode(++$left, null, $row);
- if (is_null($nodeArray[count($nodeArray)-1]["right"])) {
- return $nodeArray;
- $nodeArray = addSubTree($rows, 0, 1);
- "nestedSets" => $nodeArray
- break;*/
case "save":
+ global $firephp;
$data = $ajaxResponse->getParameter("data");
try {
@@ -268,120 +142,67 @@
$ajaxResponse->setMessage(_mb("Invalid WMC ID."));
$ajaxResponse->send();
- getWmc($wmcId);
- //is that true for a wmc? control it
- $wfsFactory = new UniversalWfsFactory();
- $wfs = $wfsFactory->createFromDb($wfsId);
- if (is_null($wfs)) {
+ $wmcFactory = new WmcFactory();
+ $wmc = $wmcFactory->createFromDb($wmcId);
+ if (is_null($wmc)) {
$ajaxResponse->setSuccess(false);
- $ajaxResponse->setMessage(_mb("Invalid WFS ID."));
+ $ajaxResponse->setMessage(_mb("Invalid WMC ID."));
$columns = array(
- "summary",
- "title",
+ "wmc_abstract",
+ "wmc_title",
"wmc_keyword",
- "wmc_md_topic_category_id",
- "wmc_inspire_category_id",
- "wmc_custom_category_id"
+ "isoTopicCats",
+ "inspireCats",
+ "customCats",
+ "public"
foreach ($columns as $c) {
$value = $data->wmc->$c;
- //if (!is_null($value)) {
- // $wmc->$c = $value;
- if ($c === "summary") {
- $value = $data->wmc_abstract;
- elseif ($c === "title") {
- $value = $data->wmc_title;
- else {
- $value = $data->$c;
if ($c === "wmc_keyword") {
- $wmc->$c = explode(",", $value);
- foreach ($wmc->$c as &$val) {
- $val = trim($val);
+ $wmc->$c = explode(",", $value);
+ foreach ($wmc->$c as &$val) {
+ $val = trim($val);
+ if(!$value) {
+ $wmc->$c = array();
+ elseif ($c === "isoTopicCats"
+ || $c === "inspireCats"
+ || $c === "customCats"
+ if (!is_array($value)) {
+ if(!$value) {
- elseif ($c === "wmc_md_topic_category_id"
- || $c === "wmc_inspire_category_id"
- || $c === "wmc_custom_category_id"
- if (!is_array($value)) {
- $wmc->$c = array($value);
- else {
- $wmc->$c = $value;
else {
- if (!is_null($value)) {
+ $wmc->$c = array($value);
-/* try {
- $featuretypeId = intval($data->featuretype->featuretype_id);
- catch (Exception $e) {
-/* if ($featuretypeId) {
- $featuretype = $wfs->findFeatureTypeById($featuretypeId);
- if (!is_null($featuretype)) {
- $columns = array(
- "summary",
- "title",
- "featuretype_keyword",
- "featuretype_md_topic_category_id",
- "featuretype_inspire_category_id",
- "featuretype_custom_category_id"
- foreach ($columns as $c) {
- $value = $data->featuretype->featuretype_abstract;
- $value = $data->featuretype->featuretype_title;
- else {
- $value = $data->featuretype->$c;
- if ($c === "featuretype_keyword") {
- $featuretype->$c = explode(",", $value);
- foreach ($featuretype->$c as &$val) {
- elseif ($c === "featuretype_md_topic_category_id"
- || $c === "featuretype_inspire_category_id"
- || $c === "featuretype_custom_category_id"
- $featuretype->$c = array($value);
- else {
- $featuretype->$c = $value;
- else {
+ else {
+ $wmc->$c = $value;
- $wmc->update();
+ elseif ($c === "public") {
+ $public = $value == "on" ? true : false;
+ $wmc->setPublic($public);
+ else {
+ if (!is_null($value)) {
+ //$firephp->log($wmc->public);
+ $overwrite = 1;
+ $wmc->insert($overwrite);
$ajaxResponse->setMessage("Updated WMC metadata for ID " . $wmcId);
Added: trunk/mapbender/http/plugins/mb_metadata_wmc_showOriginal.html
--- trunk/mapbender/http/plugins/mb_metadata_wmc_showOriginal.html (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_showOriginal.html 2010-11-24 12:11:35 UTC (rev 7151)
@@ -0,0 +1,16 @@
+<fieldset class="ui-widget">
+ <legend>Original Service Level Metadata: </legend>
+ <p>
+ <label for="original_wmc_title">WMC Title (OWS):</label>
+ <input readonly name="original_wmc_title" id="original_wmc_title" class="required"/>
+ </p>
+ <p>
+ <label for="original_wmc_abstract">WMC Abstract (OWS):</label>
+ <input readonly name="original_wmc_abstract" id="original_wmc_abstract"/>
+ </p>
+ <p>
+ <label for="original_wmc_keyword">WMC Keywords (OWS):</label>
+ <input readonly name="original_wmc_keyword" id="original_wmc_keyword"/>
+ </p>
+</fieldset>
Added: trunk/mapbender/http/plugins/mb_metadata_wmc_showOriginal.js
--- trunk/mapbender/http/plugins/mb_metadata_wmc_showOriginal.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_showOriginal.js 2010-11-24 12:11:35 UTC (rev 7151)
@@ -0,0 +1,144 @@
+var $showOriginalDiv = $(this);
+var $originalMetadataForm = $("<form></form>").appendTo($showOriginalDiv);
+var $originalMetadataPopup = $("<div></div>");
+var ShowOriginalApi = function() {
+ var that = this;
+ var featuretypeName;
+ this.events = {
+ replaceMetadata : new Mapbender.Event()
+ var replaceMetadata = function (clickedAttr, attrVal) {
+ var returnObj = {};
+ returnObj[clickedAttr] = attrVal;
+ that.events.replaceMetadata.trigger({
+ data : returnObj
+ //remove background-color of replaced attr
+ $("#" + clickedAttr).removeClass("differentFromOriginal");
+ var replaceAllMetadata = function (obj) {
+ for(metadataAttr in obj) {
+ var attr = metadataAttr.split("original_");
+ returnObj[attr[1]] = obj[metadataAttr];
+ data : returnObj
+ //remove background-color of all replaced attr
+ $(".differentFromOriginal").removeClass("differentFromOriginal");
+ var mergeOriginalWithCurrentMetadata = function (originalObj,currentObj) {
+ var differenceFound = false;
+ for(metadataAttr in currentObj) {
+ var origMetadataAttr = "original_" + metadataAttr;
+ //some attr are excluded from check
+ if(metadataAttr != "wmc_id") {
+ if(!originalObj[origMetadataAttr]) {
+ originalObj[origMetadataAttr] = "";
+ if(currentObj[metadataAttr] == originalObj[origMetadataAttr]) {
+ $("#" + origMetadataAttr).parent().hide();
+ else if(currentObj[metadataAttr] == "" && originalObj[origMetadataAttr] == "") {
+ else {
+ //mark all attr in main form which are different
+ $("#" + metadataAttr).addClass("differentFromOriginal");
+ (function () {
+ var clickedAttr = metadataAttr;
+ var attrValue = $("#" + origMetadataAttr).val();
+ $("#" + origMetadataAttr).parent().append("<input type='button' value='Replace' id='replaceRecord_"+origMetadataAttr+"' />");
+ $("#replaceRecord_" +origMetadataAttr).addClass("ui-state-default ui-corner-all");
+ $("#replaceRecord_" +origMetadataAttr).bind("click", function () {
+ replaceMetadata(clickedAttr, attrValue);
+ var differenceFound = true;
+ if(differenceFound === false) {
+ $originalMetadataPopup.dialog("close");
+ var noDifferenceMsg = "No difference found.";
+ $("<div>" + noDifferenceMsg + "</div>").dialog(
+ title : "Show original metadata",
+ bgiframe: true,
+ autoOpen: true,
+ modal: false,
+ position : [600, 75],
+ buttons: {
+ "ok": function(){
+ $(this).dialog('close').remove();
+ var getOriginalMetadata = function (currentId, currentData) {
+ // get original metadata from server
+ url: "../plugins/mb_original_metadata_wmc_server.php",
+ method: "getOriginalMetadata",
+ parameters: {
+ "id": currentId
+ if (!result) {
+ return;
+ fillForm(obj);
+ mergeOriginalWithCurrentMetadata(obj,currentData);
+ req.send();
+ $originalMetadataForm.easyform("reset");
+ $originalMetadataForm.easyform("fill", obj);
+ $originalMetadataPopup.append($originalMetadataForm);
+ $originalMetadataPopup.dialog({
+ autoOpen : false,
+ draggable : true,
+ modal : true,
+ width : 600,
+ buttons: {
+ "close": function() {
+ $(this).dialog('close');
+ "replace all metadata": function() {
+ replaceAllMetadata(obj);
+ close: function() {
+ $originalMetadataPopup.dialog("open");
+ $originalMetadataForm.load("../plugins/mb_metadata_wmc_showOriginal.html", function () {
+ getOriginalMetadata(obj.wmcId, obj.wmcData);
+$showOriginalDiv.mapbender(new ShowOriginalApi());
Added: trunk/mapbender/http/plugins/mb_metadata_wmc_submit.js
--- trunk/mapbender/http/plugins/mb_metadata_wmc_submit.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_submit.js 2010-11-24 12:11:35 UTC (rev 7151)
@@ -0,0 +1,67 @@
+var $submit = $(this);
+var MetadataSubmitApi = function () {
+ var that = this;
+ var formData = {};
+ var serializeCallback = function (data) {
+ if (data === null) {
+ formData = null;
+ return;
+ if (formData !== null) {
+ formData = $.extend(formData, data);
+ this.enable = function () {
+ $submit.find("input[type='submit']").removeAttr("disabled");
+ this.submit = function () {
+ formData = {};
+ this.events.submit.trigger({
+ callback: serializeCallback
+ if (formData === null) {
+ return;
+ method: "save",
+ parameters: {
+ "data": formData
+ if (!result) {
+ $("<div></div>").text(!message ? "An error occured." : message).dialog({
+ modal: true
+ return;
+ $("<div></div>").text(message).dialog({
+ modal: true
+ req.send();
+ this.events = {
+ var init = function () {
+ $submit.find("input[type='submit']").bind("click", function () {
+ that.submit();
+ init();
+$submit.mapbender(new MetadataSubmitApi());
Added: trunk/mapbender/http/plugins/mb_original_metadata_wmc_server.php
--- trunk/mapbender/http/plugins/mb_original_metadata_wmc_server.php (rev 0)
+++ trunk/mapbender/http/plugins/mb_original_metadata_wmc_server.php 2010-11-24 12:11:35 UTC (rev 7151)
@@ -0,0 +1,80 @@
+<?php
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/../classes/class_user.php";
+require_once dirname(__FILE__) . "/../classes/class_wmc.php";
+$ajaxResponse = new AjaxResponse($_POST);
+function abort ($message) {
+ global $ajaxResponse;
+ $ajaxResponse->setSuccess(false);
+ $ajaxResponse->setMessage($message);
+ $ajaxResponse->send();
+ die;
+function getWmcMetadataFromXml($wmcDoc) {
+ $xmlDoc = new DOMDocument();
+ $xmlDoc->encoding = CHARSET;
+ $xmlDoc->preserveWhiteSpace = false;
+ $xmlDoc->loadXML($wmcDoc);
+ //define default resultObj
+ "original_wmc_title" => "",
+ "original_wmc_abstract" => "",
+ "original_wmc_keyword" => ""
+ $general_node = $xmlDoc->getElementsByTagName('General');
+ foreach ($general_node as $node) {
+ $children = $node->childNodes;
+ foreach($children as $child) {
+ if (strtoupper($child->nodeName) == "TITLE"){
+ $resultObj["original_wmc_title"] = $child->nodeValue;
+ if (strtoupper($child->nodeName) == "ABSTRACT"){
+ $resultObj["original_wmc_abstract"] = $child->nodeValue;
+ //childnode KeywordList
+ if (strtoupper($child->nodeName) == "WMC:KEYWORDLIST"){
+ $keywords_list = $child->childNodes;
+ $keywords = array();
+ foreach ($keywords_list as $keywordlist_child_node) {
+ $keyword = $keywordlist_child_node->nodeValue;
+ array_push($keywords, $keyword);
+ $resultObj["original_wmc_keyword"] = implode(", ", $keywords);
+ return $resultObj;
+switch ($ajaxResponse->getMethod()) {
+ case "getOriginalMetadata" :
+ $wmcId = $ajaxResponse->getParameter("id");
+ $sql = <<<SQL
+SELECT wmc FROM mb_user_wmc WHERE wmc_serial_id = $wmcId;
+SQL;
+ $row = db_fetch_array($res);
+ $wmc_doc = $row["wmc"];
+ $resultObj = getWmcMetadataFromXml($wmc_doc);
+ $ajaxResponse->setResult($resultObj);
+ $ajaxResponse->setSuccess(true);
+ break;
+ default:
+ $ajaxResponse->setMessage(_mb("An unknown error occured."));
+ break;
+$ajaxResponse->send();
More information about the Mapbender_commits
