[Mapbender-commits] r7152 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Wed Nov 24 07:13:08 EST 2010
Author: verenadiewald
Date: 2010-11-24 04:13:08 -0800 (Wed, 24 Nov 2010)
New Revision: 7152
Added:
trunk/mapbender/resources/db/metadataGuiWmc.sql
gui for metadata editor wmc
Added: trunk/mapbender/resources/db/metadataGuiWmc.sql
--- trunk/mapbender/resources/db/metadataGuiWmc.sql (rev 0)
+++ trunk/mapbender/resources/db/metadataGuiWmc.sql 2010-11-24 12:13:08 UTC (rev 7152)
@@ -0,0 +1,245 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wmc_metadata','admin_wmc_metadata','GUI with tab, search modules',1);
+-- give root access to admin_wms_metadata
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wmc_metadata', 1, 'owner');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_position',1,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_submit',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_wmc_submit.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_submit','inputs','[
+ "method": "enable",
+ "linkedTo": [
+ "id": "mb_md_wmc_select",
+ "event": "selected"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mapframe1',1,1,'frame for a map','','div','','',230,55,200,200,3,'border:1px solid black;overflow:hidden;background-color:#ffffff;display:none;','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mapframe1','slippy','0','1 = Activates an animated, pseudo slippy map','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_jstree',1,1,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.js','','','http://www.jstree.com/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_jstree_checkbox',1,0,'jsTree checkbox plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js','','','http://www.jstree.com/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
+ font-family: Verdana;
+ font-size: 96%;
+label {
+ width: 250px;
+ height: 40px;
+ float: left;
+p {
+ clear: both;
+input {
+ font-weight: bold;
+ vertical-align: top;
+ width: 250px;
+ height: 25px;
+.metadata_span {
+ padding-right: 30px;
+.metadata_img {
+ width: 25px;
+ height: 25px;
+.metadata_selectbox {
+ height: 130px;
+ width: 250px;
+div#choose {
+ float: left;
+ width: 20%;
+ height:100%;
+div#layer {
+ margin-left: 20%;
+ width: 80%;
+div#preview {
+ width: 30%;
+ padding-top: 5px;
+ float: left;
+div#classification {
+ margin-left: 50%;
+ padding-top: 5px;
+ width: 50%;
+div#save {
+ margin-left: 45em;
+div#buttons {
+ float: left;
+div#selectbox {
+ margin-left: 312px;
+ padding-top: 20px;
+}','to define the color of the body','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','favicon','../img/favicon.ico','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','jq_datatables_css','../extensions/dataTables-1.5/media/css/site_jui.ccss.css','css-file for jQuery datatables','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','jq_datatables_css_ui','../extensions/dataTables-1.5/media/css/demo_table_jui.min.css','css-file for jQuery datatables','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_layout',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_pane','center','mb_tabs_horizontal','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_pane','css','../extensions/jquery.layout.all-1.2.0/jquery.layout.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_pane','south','mb_md_wmc_submit','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_select',2,1,'Select a WMC','Select WMC','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_wmc_select.js','','','jq_datatables','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_wmc_showOriginal.js','','','jq_ui_dialog','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_showOriginal','differentFromOriginalCss','.differentFromOriginal{
+background-color:#FFFACD;
+}','','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_showOriginal','inputs','[
+ "method": "init",
+ "title": "initialize",
+ "linkedTo": [
+ "id": "mb_md_wmc_edit",
+ "event": "showOriginalMetadata",
+ "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_edit',2,1,'Edit WMC metadata','Edit WMC metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'overflow:auto','','div','../plugins/mb_metadata_wmc_edit.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_edit','inputs','[
+ "method": "init",
+ "linkedTo": [
+ "event": "selected",
+ "attr": "wmcId"
+ "method": "serialize",
+ "linkedTo": [
+ "id": "mb_md_wmc_submit",
+ "event": "submit",
+ "attr": "callback"
+ "method": "fill",
+ "linkedTo": [
+ "id": "mb_md_wmc_showOriginal",
+ "event": "replaceMetadata",
+ "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_wmc_select,mb_md_wmc_edit','jq_ui_tabs','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_tabs_horizontal','inputs','[
+ "type": "id",
+ "method": "select",
+ "title": "Select a tab",
+ "linkedTo": [
+ "value": "mb_md_wmc_edit"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_featuretype',3,0,'Edit featuretype metadata','Edit featuretype metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_featuretype.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_featuretype','inputs','[
+ "method": "init",
+ "title": "initialize wfs data",
+ "linkedTo": [
+ "attr": "wmcId"
+ "linkedTo": [
+ "method": "fill",
+ "linkedTo": [
+ "attr": "data"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
More information about the Mapbender_commits
