[Mapbender-commits] r7157 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Nov 24 11:17:11 EST 2010
Author: verenadiewald
Date: 2010-11-24 08:17:10 -0800 (Wed, 24 Nov 2010)
New Revision: 7157
trunk/mapbender/http/classes/class_map.php
added function wrapJsInTryCatch to check whether application contains an overview
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php 2010-11-24 14:46:04 UTC (rev 7156)
+++ trunk/mapbender/http/classes/class_map.php 2010-11-24 16:17:10 UTC (rev 7157)
@@ -611,6 +611,9 @@
return $currentMap;
+ private function wrapJsInTryCatch ($js) {
+ return "try { " . $js . "} catch (e) {}";
// Output
@@ -627,26 +630,39 @@
$this->frameName . "'];" .
"currentWmcMap.elementName = '" . $this->frameName . "';" .
"currentWmcMap.setWidth(" . $this->width . ");" .
- "currentWmcMap.setHeight(" . $this->height . ");";
+ "currentWmcMap.setHeight(" . $this->height . ");";
+ $registerMapString = $this->isOverview() ?
+ $this->wrapJsInTryCatch($registerMapString) : $registerMapString;
array_push($jsCodeArray, $registerMapString);
+ $emptyDivInMapString = "$('#' + currentWmcMap.elementName).css({border: '0px solid'}).children().empty();";
+ $emptyDivInMapString = $this->isOverview() ?
+ $this->wrapJsInTryCatch($emptyDivInMapString) : $emptyDivInMapString;
+ array_push($jsCodeArray, $emptyDivInMapString);
// if map is overview...
if ($this->isOverview) {
// ...set overview flag
$setOverviewFlagString = "currentWmcMap.isOverview = true;";
- array_push($jsCodeArray, $setOverviewFlagString);
+ array_push($jsCodeArray, $this->wrapJsInTryCatch($setOverviewFlagString));
// calculate extent
$calcExtentString = "currentWmcMap.setSrs(" .
$this->extent->toJavaScript() .
- array_push($jsCodeArray, $calcExtentString);
+ $calcExtentString = $this->isOverview() ?
+ $this->wrapJsInTryCatch($calcExtentString) : $calcExtentString;
+ array_push($jsCodeArray, $calcExtentString);
$setWmsString = "currentWmcMap.setWms(" . $wmsJson . ");";
+ $setWmsString = $this->isOverview() ?
+ $this->wrapJsInTryCatch($setWmsString) : $setWmsString;
array_push($jsCodeArray, $setWmsString);
$initWmsString = "currentWmcMap.initializeWms();";
+ $initWmsString = $this->isOverview() ?
+ $this->wrapJsInTryCatch($initWmsString) : $initWmsString;
array_push($jsCodeArray, $initWmsString);
return $jsCodeArray;
More information about the Mapbender_commits
