[Mapbender-commits] r7158 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Nov 24 11:18:25 EST 2010
Author: verenadiewald
Date: 2010-11-24 08:18:25 -0800 (Wed, 24 Nov 2010)
New Revision: 7158
trunk/mapbender/http/classes/class_wmc.php
added try/catch to check whether application contains an overview
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2010-11-24 16:17:10 UTC (rev 7157)
+++ trunk/mapbender/http/classes/class_wmc.php 2010-11-24 16:18:25 UTC (rev 7158)
@@ -1079,26 +1079,26 @@
// set visibility of ov map WMS (may be different from main)
if ($this->overviewMap !== null) {
for ($i = 0; $i < count($ovWmsArray[$wmsIndexOverview]->objLayer); $i++) {
- $visStr = "Mapbender.modules['".$this->overviewMap->getFrameName().
+ $visStr = "try { Mapbender.modules['".$this->overviewMap->getFrameName().
// "'].wms[" .$wmsIndexOverview . "].handleLayer(" .
// The above doesn't work.
// But there is only one WMS in the overview anyway! The index 0 is hard wired for now.
"'].wms[0].handleLayer(" .
"'" . $ovWmsArray[$wmsIndexOverview]->objLayer[$i]->layer_name . "', " .
"'visible', " .
- ($ovWmsArray[$wmsIndexOverview]->objLayer[$i]->gui_layer_visible ? 1 : 0) . ");";
+ ($ovWmsArray[$wmsIndexOverview]->objLayer[$i]->gui_layer_visible ? 1 : 0) . ")} catch (e) {};";
array_push($wmcJsArray, $visStr);
- array_push($wmcJsArray, "Mapbender.modules['".$this->overviewMap->getFrameName().
- "'].restateLayers(" . $ovWmsArray[$wmsIndexOverview]->wms_id . ");");
+ array_push($wmcJsArray, "try { Mapbender.modules['".$this->overviewMap->getFrameName().
+ "'].restateLayers(" . $ovWmsArray[$wmsIndexOverview]->wms_id . ");} catch (e) {};");
// .. request the map
array_push($wmcJsArray, "Mapbender.modules['".$this->mainMap->getFrameName().
"'].setMapRequest();");
- "'].setMapRequest();");
+ array_push($wmcJsArray, "try {Mapbender.modules['".$this->overviewMap->getFrameName().
+ "'].setMapRequest()} catch (e) {};");
array_push($wmcJsArray, "eventAfterLoadWMS.trigger();");
More information about the Mapbender_commits
