[Mapbender-commits] r8089 - in branches/2.7/http/print: . classes
svn_mapbender at osgeo.org
Wed Aug 31 08:15:29 EDT 2011
Author: verenadiewald
Date: 2011-08-31 05:15:28 -0700 (Wed, 31 Aug 2011)
New Revision: 8089
branches/2.7/http/print/classes/mbMeasureDecorator.php
branches/2.7/http/print/print_functions.php
http://trac.osgeo.org/mapbender/ticket/855
Modified: branches/2.7/http/print/classes/mbMeasureDecorator.php
--- branches/2.7/http/print/classes/mbMeasureDecorator.php 2011-08-31 09:38:50 UTC (rev 8088)
+++ branches/2.7/http/print/classes/mbMeasureDecorator.php 2011-08-31 12:15:28 UTC (rev 8089)
@@ -41,7 +41,7 @@
$map_width = $mapInfo["width"];
// get the arrays, be aware of the different y-axis values
- $theFullArr = makeCoordPairs($x_value_str, $y_value_str);
+ $theFullArr = makeCoordPairsForFpdi($x_value_str, $y_value_str);
foreach ($theFullArr as $oneFullArr) {
$e = new mb_notice("mbMeasureDecorator: coordinates: ".implode(" ",array_values($oneFullArr)));
@@ -60,9 +60,9 @@
$this->pdf->objPdf->ClippingRect($mapOffset_left, $mapOffset_bottom, $map_width, $map_height, false);
if ($isClosed) {
$this->pdf->objPdf->Polygon($thePolyArr);
else {
- $theStrokePointPairs = makeStrokePointPairs($theFullArr);
+ $theStrokePointPairs = makeStrokePointPairs($theFullArr);
for($i = 0; $i < count($theStrokePointPairs); $i++) {
$line = $theStrokePointPairs[$i];
$e = new mb_notice("mbMeasureDecorator: line coordinates: ".implode(" ",$line));
Modified: branches/2.7/http/print/print_functions.php
--- branches/2.7/http/print/print_functions.php 2011-08-31 09:38:50 UTC (rev 8088)
+++ branches/2.7/http/print/print_functions.php 2011-08-31 12:15:28 UTC (rev 8089)
@@ -22,7 +22,7 @@
* @author M. Jansen <jansen at terrestris.de>, 2006-05-26
function makeCoordPairs($x_values, $y_values) {
- $arr_x = explode(",", $x_values);
+ $arr_x = explode(",", $x_values);
$arr_y = explode(",", $y_values);
$x_elems = count($arr_x);
$y_elems = count($arr_y);
@@ -31,20 +31,38 @@
if ($x_elems == $y_elems) {
for ($i = 0; $i < $x_elems; $i ++) {
- $the_return_arr[$i] = array(
- "real_x" => $arr_x[$i],
- "real_y" => $arr_y[$i],
- "pdf_x" => transformForPDF($arr_x[$i], "x"),
- "pdf_y" => transformForPDF($arr_y[$i], "y")
+ $the_return_arr[$i] = array(
+ "real_x" => $arr_x[$i],
+ "real_y" => $arr_y[$i],
+ "pdf_x" => transformForPDF($arr_x[$i], "x"),
+ "pdf_y" => transformForPDF($arr_y[$i], "y"));
return $the_return_arr;
} // end of function makeCoordPairs
+function makeCoordPairsForFpdi($x_values, $y_values) {
+ $arr_y = explode(",", $y_values);
+ $x_elems = count($arr_x);
+ $y_elems = count($arr_y);
+ $the_return_arr = array();
+ if ($x_elems == $y_elems) {
+ for ($i = 0; $i < $x_elems; $i ++) {
+ "pdf_x" => transformForPDFFpdi($arr_x[$i], "x"),
+ "pdf_y" => transformForPDFFpdi($arr_y[$i], "y"));
+ return $the_return_arr;
+} // end of function makeCoordPairsForFpdi
* Transforms given realworld-coordinate according to its type (X or Y)
* into a pdf-coordinate. Needs the variables $mapOffset_left, $mapOffset_bottom,
@@ -75,7 +93,7 @@
case 'y':
// calculate pdf y-pos:
$real_shown_height = $coord[3] - $coord[1];
- $ratio_to_display = $map_height / $real_shown_height;
+ $ratio_to_display = ($map_height / $real_shown_height);
$target_height = $theRealCoord - $coord[1];
$thePDFvalue = $mapOffset_bottom + ($target_height * $ratio_to_display);
break;
@@ -87,9 +105,50 @@
return $thePDFvalue;
} // end of function transformForPDF
+ * Use for new template print with lib fpdi:
+ * Transforms given realworld-coordinate according to its type (X or Y)
+ * into a pdf-coordinate. Needs the variables $mapOffset_left, $mapOffset_bottom,
+ * $map_height, $map_width, $coord to be defined in a global scope.
+ * @param float the realworld coordinate
+ * @param string type of coordinate either 'X' or 'Y'
+ * @see makeCoordPairsForFpdi [needs this function]
+ * @return float the pdf-coordinate
+ * @author V. Diewald
+function transformForPDFFpdi ($theRealCoord, $theType) {
+ global $mapOffset_left, $mapOffset_bottom, $map_height, $map_width, $coord;
+ $thePDFvalue = "";
+ switch (mb_strtolower($theType)) {
+ case 'x':
+ // calculate pdf x-pos:
+ $real_shown_width = $coord[2] - $coord[0];
+ $ratio_to_display = $map_width / $real_shown_width;
+ $target_width = $theRealCoord - $coord[0];
+ $thePDFvalue = $mapOffset_left + ($target_width * $ratio_to_display);
+ break;
+ case 'y':
+ // calculate pdf y-pos:
+ $real_shown_height = $coord[3] - $coord[1];
+ $target_height = $theRealCoord - $coord[1];
+ $thePDFvalue = $mapOffset_bottom +($map_height- ($target_height * $ratio_to_display));
+ break;
+ default:
+ // a non valid parameter was given
+ $thePDFvalue = $theRealCoord;
+ break;
+ return $thePDFvalue;
+} // end of function transformForPDFFpdi
* extracts PDF-relevant information from a full coordinates array
* and returns a transformed array
More information about the Mapbender_commits
