[Mapbender-commits] r7549 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Thu Feb 10 06:03:54 EST 2011
Author: kmq
Date: 2011-02-10 03:03:54 -0800 (Thu, 10 Feb 2011)
New Revision: 7549
trunk/mapbender/resources/db/install.bat
trunk/mapbender/resources/db/install.sh
trunk/mapbender/resources/db/update.bat
trunk/mapbender/resources/db/update.sh
added 2.7rc1 to 2.7rc2
Modified: trunk/mapbender/resources/db/install.bat
--- trunk/mapbender/resources/db/install.bat 2011-02-10 10:01:16 UTC (rev 7548)
+++ trunk/mapbender/resources/db/install.bat 2011-02-10 11:03:54 UTC (rev 7549)
@@ -133,8 +133,10 @@
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6_to_2.6.1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
echo update to 2.6.2
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.6.2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo update to 2.7
+echo update to 2.7rc1
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.2_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo update to 2.7rc2
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.7rc1_to_2.7rc2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
echo update sequences
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_sequences.txt 2>> err_sequences.txt
Modified: trunk/mapbender/resources/db/install.sh
--- trunk/mapbender/resources/db/install.sh 2011-02-10 10:01:16 UTC (rev 7548)
+++ trunk/mapbender/resources/db/install.sh 2011-02-10 11:03:54 UTC (rev 7549)
@@ -137,6 +137,7 @@
pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql \
pgsql/$DBENCODING/update/update_2.6.1_to_2.6.2_pgsql_$DBENCODING.sql \
pgsql/$DBENCODING/update/update_2.6.2_to_2.7rc1_pgsql_$DBENCODING.sql \
+ pgsql/$DBENCODING/update/update_2.7rc_to_2.7rc2_pgsql_$DBENCODING.sql \
pgsql/pgsql_serial_set_sequences_2.7.sql \
> _install.sql
echo "inserting data (this might take a while longer)"
Modified: trunk/mapbender/resources/db/update.bat
--- trunk/mapbender/resources/db/update.bat 2011-02-10 10:01:16 UTC (rev 7548)
+++ trunk/mapbender/resources/db/update.bat 2011-02-10 11:03:54 UTC (rev 7549)
@@ -106,13 +106,13 @@
-echo update to 2.7
echo update to 2.7
psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo update to 2.7 rc2
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.7rc1_to_2.7rc2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
goto END:
Modified: trunk/mapbender/resources/db/update.sh
--- trunk/mapbender/resources/db/update.sh 2011-02-10 10:01:16 UTC (rev 7548)
+++ trunk/mapbender/resources/db/update.sh 2011-02-10 11:03:54 UTC (rev 7549)
@@ -97,13 +97,13 @@
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
echo "update to 2.6.2"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.1_to_2.6.2_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
- echo "update to 2.7"
+ echo "update to 2.7rc1"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.2_to_2.7rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+ echo "update to 2.7rc2"
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.7rc1_to_2.7rc2_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
echo "update sequences"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.7.sql $DBNAME >> log_update.txt 2>> err_update.txt
- echo "update to 2.7 rc2"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.7rc1_to_2.7rc2_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
#magic starts here
More information about the Mapbender_commits
