[Mapbender-commits] r7588 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Feb 14 03:59:02 EST 2011
Author: verenadiewald
Date: 2011-02-14 00:59:02 -0800 (Mon, 14 Feb 2011)
New Revision: 7588
trunk/mapbender/http/javascripts/mod_measure.php
use correct pos values to calculate dist for measuring
Modified: trunk/mapbender/http/javascripts/mod_measure.php
--- trunk/mapbender/http/javascripts/mod_measure.php 2011-02-14 08:17:30 UTC (rev 7587)
+++ trunk/mapbender/http/javascripts/mod_measure.php 2011-02-14 08:59:02 UTC (rev 7588)
@@ -224,15 +224,15 @@
var dist;
if(mod_measure_epsg=="EPSG:4326"){
//convert coordinates to radian
- var lon_from=(pos.x*Math.PI)/180;
- var lat_from=(pos.y*Math.PI)/180;
+ var lon_from=(pos[0]*Math.PI)/180;
+ var lat_from=(pos[1]*Math.PI)/180;
var lon_to=(mod_measure_RX[mod_measure_RX.length-1]*Math.PI)/180;
var lat_to=(mod_measure_RY[mod_measure_RY.length-1]*Math.PI)/180;
dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
else{
- var dist_x = Math.abs(mod_measure_RX[mod_measure_RX.length-1] - pos.x);
- var dist_y = Math.abs(mod_measure_RY[mod_measure_RY.length-1] - pos.y);
+ var dist_x = Math.abs(mod_measure_RX[mod_measure_RX.length-1] - pos[0]);
+ var dist_y = Math.abs(mod_measure_RY[mod_measure_RY.length-1] - pos[1]);
dist=Math.sqrt(dist_x*dist_x+dist_y*dist_y);
if(isNaN(dist) == false && mousepos.x > 0 && mousepos.x < mod_measure_width && mousepos.y > 0 && mousepos.y < mod_measure_height){
More information about the Mapbender_commits
