[Mapbender-commits] r7421 - in trunk/mapbender/http: css plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 5 04:42:41 EST 2011
Author: kmq
Date: 2011-01-05 01:42:41 -0800 (Wed, 05 Jan 2011)
New Revision: 7421
   trunk/mapbender/http/css/wfsconftree.css
   trunk/mapbender/http/plugins/wfsConfTree.js
added rmeove and meta buttons to wfsconftree
Modified: trunk/mapbender/http/css/wfsconftree.css
--- trunk/mapbender/http/css/wfsconftree.css	2011-01-05 09:41:06 UTC (rev 7420)
+++ trunk/mapbender/http/css/wfsconftree.css	2011-01-05 09:42:41 UTC (rev 7421)
@@ -98,8 +98,20 @@
 	background-image: url("../img/button_digitize/geomRemove.png");
 	background-repeat: no-repeat;
 	background-position: 0 0;
+	color: transparent;
+	width: 2em;
+ul.conftree li a.meta{
+	background-image: url("../img/tree_new/info.png");
+	background-repeat: no-repeat;
+	background-position: 0 0;
+	width: 2em;
+	display: inline-block;
 ul.conftree li.open, ul.conftree li.closed {
 /*	background-image: url("http://localhost:8888/vertical_dots.png");*/
 	background-repeat: repeat-x	;
Modified: trunk/mapbender/http/plugins/wfsConfTree.js
--- trunk/mapbender/http/plugins/wfsConfTree.js	2011-01-05 09:41:06 UTC (rev 7420)
+++ trunk/mapbender/http/plugins/wfsConfTree.js	2011-01-05 09:42:41 UTC (rev 7421)
@@ -62,23 +62,23 @@
 			switch(aWFSConf[i].wfs_conf_type){
 					/* search */
 					case "0":
-						$wfsconfEntry = $('<li><a href="#">Suche</a></li>');
+						$wfsconfEntry = $('<li class="search" ><a href="#" class="meta">metadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].g_label +'</a></li>');
 					break;
 					/* digitize */
 					case "1":
-						$wfsconfEntry = $('<li><a href="#">Erfassung</a></li>');
+						$wfsconfEntry = $('<li class="digitize" ><a href="#" class="meta">medadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].g_label +'</a></li>');
 					break;
 					/* download */
 					case "2":
-						$wfsconfEntry = $('<li><a href="#">Download</a></li>');
+						$wfsconfEntry = $('<li class="download" ><a href="#" class="meta">metadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].g_label +'</a></li>');
 					break;
 			$featuretypeList.append($wfsconfEntry);
-			$wfsconfEntry.find("a").click((function(wfsConf){
+			$wfsconfEntry.find("a.dialogopen").click((function(wfsConf){
 				return function(){
 				switch(wfsConf.wfs_conf_type){
@@ -106,6 +106,18 @@
 			})(aWFSConf[i]));
+			$wfsconfEntry.find("button.remove").click(function(){
+				// if this was the last entry in the featuregroup, remove it completely	...
+				if($(this).parent().siblings().size() == 0){
+					$(this).parent().parent().parent().remove();
+				}else{
+					//.. otherwise just rmeove the entry
+					$(this).parent().remove();
More information about the Mapbender_commits mailing list
