[Mapbender-commits] r7422 - in trunk/mapbender/http: classes
	geoportal php
    svn_mapbender at osgeo.org
    Wed Jan  5 05:46:57 EST 2011
Author: armin11
Date: 2011-01-05 02:46:57 -0800 (Wed, 05 Jan 2011)
New Revision: 7422
Added:
   trunk/mapbender/http/geoportal/mod_wfsConfSelect_client.php
   trunk/mapbender/http/geoportal/mod_wfs_gazetteer_importWfsConf.php
   trunk/mapbender/http/classes/class_metadata_new.php
   trunk/mapbender/http/php/mod_callMetadata.php
   trunk/mapbender/http/php/tagCloud.php
Bugfixes for search and modules for loading wfs-confs dynamically
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php	2011-01-05 09:42:41 UTC (rev 7421)
+++ trunk/mapbender/http/classes/class_metadata_new.php	2011-01-05 10:46:57 UTC (rev 7422)
@@ -84,16 +84,16 @@
 		$this->searchURL = $searchURL;
 		$this->hostName = $hostName;
 		$this->orderBy = $orderBy;
-		//definitions for tags
+		//definitions for generating tagClouds
 		$this->maxObjects = 15;
 		$this->maxFontSize = 30;
 		$this->maxWeight = 0;
 		$this->scale = 'linear';
+		$this->minFontSize = 10;
 		$this->tempFolder = TMPDIR; //TODO define another path - maybe the one which is given in mapbender.conf
 		if ($this->outputFormat == 'json'){
 			$this->json = new Mapbender_JSON;
@@ -1059,7 +1059,7 @@
 					'title' => $this->keywordTitle,
 					'tags' => array()
-				$this->inc = $this->maxFontSize/$this->maxObjects;//maybe 10 or 5 or ...
+				$this->inc = ($this->maxFontSize-$this->minFontSize)/$this->maxObjects;//maybe 10 or 5 or ...
 				//generate the list of category counts
 				$sqlCat = array();
 				//generate the sql for the keyword count
@@ -1081,26 +1081,21 @@
 					for ($j = 0; $j < count($keywordCounts); $j++) {
 						if ($this->scale == 'linear'){
 							//order in a linear scale desc
-							 $keywordCounts[$j]['count'] = $this->maxFontSize-($j*$this->inc);
+							$keywordCounts[$j]['count'] = $this->maxFontSize-($j*$this->inc);
 						} else {
 							//set weight prop to count
 							 $keywordCounts[$j]['count'] = $keywordCounts[$j]['count']*$this->maxFontSize/$this->maxWeight;
+	/*if ($scale == 'linear'){
+		$tags[$i]['weight'] = $maxFontSize-($i*$inc);
+	} else {
+		$tags[$i]['weight'] = $tags[$i]['weight']*$maxFontSize/$maxWeight;
-					//$this->maxWeight = $keywordCounts[0]['count'];
 					shuffle($keywordCounts);
 						$this->keyJSON->tagCloud->tags[$j]->title = $keywordCounts[$j]['keyword'];
-						//generate the weight:
-						//if ($this->scale == 'linear'){
-							//order in a linear scale desc
-							 $this->keyJSON->tagCloud->tags[$j]->weight = $keywordCounts[$j]['count'];
-						//} else {
-							//set weight prop to count
-							// $this->keyJSON->tagCloud->tags[$j]->weight = $keywordCounts[$j]['count']*$this->maxFontSize/$this->maxWeight;
-						//$this->keyJSON->tags[$j]->weight = $keywordCounts[$j]['count'];
+						$this->keyJSON->tagCloud->tags[$j]->weight = $keywordCounts[$j]['count'];
 						$paramValue = $this->getValueForParam('searchText', $this->searchURL);
 						//delete resources part from query and set some new one
 						$searchUrlKeywords = $this->delTotalFromQuery('searchResources',$this->searchURL);
@@ -1108,7 +1103,7 @@
 						$searchUrlKeywords .= '&searchResources='.$this->searchResources;
 						$e = new mb_exception("class_metadata_new: value ".$paramValue." for searchText param found");
 						$paramValue = urldecode($paramValue);
-						if ($paramValue == false) {
+						if ($paramValue == false || $paramValue == '*') {
 							$this->keyJSON->tagCloud->tags[$j]->url = $searchUrlKeywords."&searchText=".$keywordCounts[$j]['keyword'];
 						} else {
 							$this->keyJSON->tagCloud->tags[$j]->url = $this->addToQuery('searchText',$searchUrlKeywords,$keywordCounts[$j]['keyword'],$paramValue);
Added: trunk/mapbender/http/geoportal/mod_wfsConfSelect_client.php
--- trunk/mapbender/http/geoportal/mod_wfsConfSelect_client.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_wfsConfSelect_client.php	2011-01-05 10:46:57 UTC (rev 7422)
@@ -0,0 +1,368 @@
+<?php
+# $Id: mod_wfs_gazetteer_client.php 1414 2008-01-17 08:55:06Z diewald $
+# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
+# http://www.mapbender.org/index.php/WFS_gazetteer
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+$gui_id = $_SESSION["mb_user_gui"];
+$e_target = $_REQUEST["e_target"];
+$e_id_css = $_REQUEST["e_id_css"];
+require(dirname(__FILE__)."/../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db($DB,$con);
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset='<?php echo CHARSET;?>'">
+<title>mod_wfs_gazetteer</title>
+<?php
+include '../include/dyn_css.php';
+<script type="text/javascript">
+<?php
+	echo "var targetString = '" . $e_target . "';";
+	echo "var wfsConfIdString = '" . $wfsConfIdString . "';";
+// Element var maxHighlightedPoints
+try{
+	if (maxHighlightedPoints){
+		maxHighlightedPoints = Number(maxHighlightedPoints);
+		if (isNaN(maxHighlightedPoints)) {
+			var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints must be a number.");
+catch(e){
+	maxHighlightedPoints = 0;
+	var e = new parent.Mb_warning("mod_wfs_gazetteer_client.php: Element var maxHighlightedPoints is not set, see 'edit element vars'.");
+// Helper functions
+ * Deletes all nodes under a specified node.
+function removeChildNodes(node) {
+	try {
+		while (node.childNodes.length > 0) {
+			var childNode = node.firstChild;
+			node.removeChild(childNode);
+	catch(e) {
+//		console.log(e);
+ * removes whitespaces and endlines before and after a string
+function trimString (str) {
+	return str.replace(/^\s+|\s+|\n+$/g, '');
+var targetArray = targetString.split(",");
+var global_wfsConfObj;
+var global_selectedWfsConfId;
+var searchPopup;
+// removed because initWfs is done on load wmc, which itself is done on init
+//parent.mb_registerInitFunctions("window.frames['"+this.name+"'].initModWfsGazetteer()");
+parent.mb_registerloadWmcSubFunctions("window.frames['"+this.name+"'].appendWfsConf(restoredWmcExtensionData.wfsConfIdString);window.frames['"+this.name+"'].initModWfsGazetteer()");
+function openwindow(Adresse) {
+	Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+	Fenster1.focus();
+function appendWfsConf(newWfsConfIdString) {
+	// merge with existing wfs conf ids
+	if (wfsConfIdString !== "" && typeof(wfsConfIdString) != "undefined") {
+		if (newWfsConfIdString !== "" && typeof(newWfsConfIdString) != "undefined") {
+			wfsConfIdString += "," + newWfsConfIdString;
+	else {
+			wfsConfIdString = newWfsConfIdString;
+		else {
+			wfsConfIdString = "";
+function fixConfString() {
+	if (wfsConfIdString && typeof(wfsConfIdString) == "string") {
+		var confIdArray = wfsConfIdString.split(",");
+		var newIdArray = [];
+		for (var i = 0; i < confIdArray.length; i++) {
+			var current = parseInt(confIdArray[i]);
+			if (!isNaN(current) && typeof(current) == "number") {
+				var found = false;
+				for (var j = 0; j < newIdArray.length && !found; j++) {
+					if (current == newIdArray[j]) {
+						found = true;
+				if (!found) {
+					newIdArray.push(current);
+		wfsConfIdString = newIdArray.join(",");
+	else {
+function initModWfsGazetteer() {
+	fixConfString();
+	deleteWfsInfo()
+	// delete WFS conf select box entries
+	removeChildNodes(document.getElementById("wfs_conf_sel"));
+	removeChildNodes(document.getElementById("wfs_messages"));
+	var url = "../x_geoportal/mod_wfsGazetteerEditor_server.php";
+	var properties = {command:"getWfsConf", wfsConfIdString:wfsConfIdString};
+	parent.mb_ajax_json(url , properties, function(json, status) {
+		global_wfsConfObj = json;
+		var wfsCount = 0;
+		for (var wfsConfId in global_wfsConfObj) {
+			global_selectedWfsConfId = wfsConfId;
+			if (typeof(global_wfsConfObj[wfsConfId] != 'function')) {
+				wfsCount++;
+		// If no WFS is available, display an error message...
+		if (wfsCount === 0) {
+			var msges = document.getElementById("wfs_messages");
+			var textNode = document.createTextNode("Kein WFS verfügbar. Über die Suche können Sie Dienste hinzuladen.");
+			msges.appendChild(textNode);
+			var selectbox = document.getElementById("wfs_conf_sel");
+			selectbox.style.display = "none";
+			hideWfsInfo();
+			var e = parent.Mb_exception("no wfs conf id available.");
+		// ...else, display a Select Box with available WFS.
+		else {
+			appendWfsConfSelectBox();
+			setWfsInfo();
+		parent.mb_setWmcExtensionData({"wfsConfIdString":wfsConfIdString});
+function deleteWfsInfo () {
+	// delete WFS conf info
+	removeChildNodes(document.getElementById("wfsInfo"));
+function hideWfsInfo () {
+	var wfsPreConfiguredOrEditor = document.getElementById("wfsPreConfiguredOrEditor");
+	wfsPreConfiguredOrEditor.style.display = 'none';
+	var wfsGeomTypeNode = document.getElementById("wfsGeomType");
+	wfsGeomTypeNode.style.display = "none";
+	var wfsInfoNode = document.getElementById("wfsInfo");
+	wfsInfoNode.style.display = "none";
+	var wfsRemoveNode = document.getElementById("wfsRemove");
+	wfsRemoveNode.style.display = "none";
+	var wfsSubmitNode = document.getElementById("wfsSubmit");
+	wfsSubmitNode.style.display = "none";
+	return;
+function setWfsInfo() {
+	// append bulb image
+	var bulbNode = document.getElementById("wfsInfo");
+	removeChildNodes(bulbNode);
+	var imgNode = document.createElement("img");
+	imgNode.id = "wfsInfoImg";
+	imgNode.src = "../x_geoportal/img/info.png";
+	imgNode.border = 0;
+	bulbNode.appendChild(imgNode);
+	bulbNode.href = "javascript:openwindow('../x_geoportal/mod_featuretypeMetadata.php?wfs_conf_id=" + global_selectedWfsConfId.toString() + "');";
+	bulbNode.style.display = "inline";
+	// set image (pre configured or editor)
+	var preConfigured = false;
+	for (var i=0; i < global_wfsConfObj[global_selectedWfsConfId].element.length; i++) {
+		if (parseInt(global_wfsConfObj[global_selectedWfsConfId].element[i].f_search)) {
+			preConfigured = true;
+			break;
+	if (preConfigured) {
+		wfsPreConfiguredOrEditor.src = "../x_geoportal/img/modul_suche.png";
+		wfsPreConfiguredOrEditor.title = "Modultyp: Suche";
+	else {
+		wfsPreConfiguredOrEditor.src = "../x_geoportal/img/modul_download.png";
+		wfsPreConfiguredOrEditor.title = "Modultyp: Download";
+	wfsPreConfiguredOrEditor.style.display = 'inline';
+	// set wfsGeomType image
+	var wfsGeomType = "";
+		if (parseInt(global_wfsConfObj[global_selectedWfsConfId].element[i].f_geom)) {
+			wfsGeomType = global_wfsConfObj[global_selectedWfsConfId].element[i].element_type;
+	if (wfsGeomType.match(/Point/)) {
+		wfsGeomTypeNode.src = "../x_geoportal/img/wfs_pkt.gif";
+		wfsGeomTypeNode.style.display = 'inline';
+		wfsGeomTypeNode.title = 'Geometrietyp: Punkt';
+	else if (wfsGeomType.match(/Line/)) {
+		wfsGeomTypeNode.src = "../x_geoportal/img/wfs_l.gif";
+		wfsGeomTypeNode.title = 'Geometrietyp: Linie';
+	else if (wfsGeomType.match(/Polygon/)) {
+		wfsGeomTypeNode.src = "../x_geoportal/img/wfs_p.gif";
+		wfsGeomTypeNode.title = 'Geometrietyp: Fläche';
+	else {
+		var e = new parent.Mb_exception("WFS gazetteer: geometry type unknown.");
+	// set image: remove this WFS
+	wfsRemoveNode.src = "../x_geoportal/img/modul_loeschen.png";
+	wfsRemoveNode.style.display = 'inline';
+	wfsRemoveNode.onclick = function () {
+		delete global_wfsConfObj[global_selectedWfsConfId];
+		setWfsConfIdString();
+		initModWfsGazetteer();
+	wfsSubmitNode.style.display = "display";
+function setWfsConfIdString() {
+	var str = [];
+			str.push(wfsConfId);
+	wfsConfIdString = str.join(",");
+function appendWfsConfSelectBox() {
+	var selectNode = document.getElementById("wfs_conf_sel");
+	selectNode.style.display = "block";
+	selectNode.onchange = function () {
+		global_selectedWfsConfId = this.value;
+		setWfsInfo();
+	var isSelected = false;
+		var optionNode = document.createElement("option");
+		optionNode.value = wfsConfId;
+		optionNode.innerHTML = global_wfsConfObj[wfsConfId].g_label;
+		if (!isSelected) {
+			optionNode.selected = true;
+			isSelected = true;
+		selectNode.appendChild(optionNode);
+function displayPopup(){
+	var e_id = "<?php echo $e_id_css; ?>";
+	var url = "../x_geoportal/mod_wfsGazetteerEditor_client.php?" +
+		"e_target=<?php echo $e_target; ?>" +
+		"&e_id_css=" + e_id;
+	if (typeof(searchPopup) == "undefined") {
+		searchPopup = new parent.mb_popup({title:global_wfsConfObj[global_selectedWfsConfId].g_label,
+			url:url, width:430, height:400, top:50, left:50, frameName:e_id + "_",
+			minTop:"document",minLeft:"document",maxRight:"document",maxBottom:"document",destroy:false});
+	else{
+		searchPopup.setUrl(url);
+		searchPopup.setTitle(global_wfsConfObj[global_selectedWfsConfId].g_label);
+	searchPopup.show();
+function openWfsEditor() {
+	displayPopup();
+	return false;
+</script>
+</head>
+<body leftmargin='0' topmargin='10'  bgcolor='#ffffff'>
+	<!-- WFS conf selector -->
+	<form name='selectWfsConfForm' id='selectWfsConfForm' onsubmit='return openWfsEditor();'>
+		<select id='wfs_conf_sel' name='wfs_conf_sel' style='display:none'>
+		</select>
+		<!-- WFS conf info -->
+		<img src = "" name='wfsPreConfiguredOrEditor' id='wfsPreConfiguredOrEditor' style='display:none'>
+		<img src = "" name='wfsGeomType' id='wfsGeomType' style='display:none'>
+		<img src = "" title='Modul löschen' name='wfsRemove' id='wfsRemove' style='display:none'>
+		<a name='wfsInfo' title='Informationen anzeigen' id='wfsInfo' style='display:none'></a>
+		<!-- opens the WFS editor -->
+		<br>
+		<input id='wfsSubmit' type='submit' value='Modul laden'>
+	</form>
+	<p id = "wfs_messages">
+	</p>
+</body>
+</html>
\ No newline at end of file
Added: trunk/mapbender/http/geoportal/mod_wfs_gazetteer_importWfsConf.php
--- trunk/mapbender/http/geoportal/mod_wfs_gazetteer_importWfsConf.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_wfs_gazetteer_importWfsConf.php	2011-01-05 10:46:57 UTC (rev 7422)
@@ -0,0 +1,70 @@
+<?php
+# $Id: mod_wfs_gazetteer_client.php 1044 2007-10-10 08:30:29Z baudson $
+session_start();
+$target = $_REQUEST["target"];
+//$e_id_css = $_REQUEST["e_id_css"];
+require_once("../../conf/mapbender.conf");
+//include '../include/dyn_css.php';
+function setWfsConfString() {
+<?php
+echo "\tvar gazetteerFrameId = '" . $e_id . "';\n";
+// if services were selected in search, append them to the wfs gazetteer
+echo "\tvar gazetteerWfsConfFromPortal = '" . $_REQUEST["portal_services_wfs"] . "';\n";
+// now done somewhere else
+//	var gazetteerWfsConfFromWMC = mb_getWmcExtensionData("wfsConfIdString");
+	//just initialise the gazetteer.
+//	if (!gazetteerWfsConfFromPortal && !gazetteerWfsConfFromWMC) {
+//		console.log("no WFS conf from WMC and Portal");
+	// append WFS conf from WMC
+//	else if (!gazetteerWfsConfFromPortal && gazetteerWfsConfFromWMC) {
+//		console.log("WFS conf from WMC");
+//		window.frames[gazetteerFrameId].appendWfsConf(gazetteerWfsConfFromWMC);
+	// append WFS conf from portal
+//	else if (gazetteerWfsConfFromPortal && !gazetteerWfsConfFromWMC) {
+//		console.log("WFS conf from Portal");
+//		window.frames[gazetteerFrameId].appendWfsConf(gazetteerWfsConfFromPortal);
+	// append WFS conf from portal and WMC
+//	else if (gazetteerWfsConfFromPortal && gazetteerWfsConfFromWMC) {
+//		console.log("WFS conf from WMC and Portal");
+//		window.frames[gazetteerFrameId].appendWfsConf(gazetteerWfsConfFromPortal + "," + gazetteerWfsConfFromWMC);
+	if (gazetteerWfsConfFromPortal && gazetteerWfsConfFromPortal != null) {
+		window.frames[gazetteerFrameId].appendWfsConf(gazetteerWfsConfFromPortal);
+mb_registerloadWmcSubFunctions("setWfsConfString()");
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2011-01-05 09:42:41 UTC (rev 7421)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2011-01-05 10:46:57 UTC (rev 7422)
@@ -559,9 +559,9 @@
 		$resourceCategories['georss'] = 'KML/Newsfeeds';
 		$orderByTitle['header'] = 'Sortierung nach:';
-		$orderByTitle['id'] = 'ID';
-		$orderByTitle['title'] = 'Titel';
-		$orderByTitle['rank'] = 'Relevanz';
+		$orderByTitle['id'] = 'Identifizierungsnummer';
+		$orderByTitle['title'] = 'Alphabetisch';
+		$orderByTitle['rank'] = 'Nachfrage';
 		$orderByTitle['date'] = 'Letzte Änderung';
@@ -582,9 +582,9 @@
 		$orderByTitle['header'] = 'Sort by:';
-		$orderByTitle['title'] = 'title';
-		$orderByTitle['rank'] = 'relevance';
+		$orderByTitle['id'] = 'identification number';
+		$orderByTitle['title'] = 'alphabetically';
+		$orderByTitle['rank'] = 'demand';
 		$orderByTitle['date'] = 'last change';
         break;
@@ -604,9 +604,9 @@
-		$orderByTitle['id'] = 'identification';
        	break;
Modified: trunk/mapbender/http/php/tagCloud.php
--- trunk/mapbender/http/php/tagCloud.php	2011-01-05 09:42:41 UTC (rev 7421)
+++ trunk/mapbender/http/php/tagCloud.php	2011-01-05 10:46:57 UTC (rev 7422)
@@ -132,7 +132,7 @@
 		$maxWeight = (integer)$row['sum'];
 	if ($type == 'topicCategories') {
-		$tags[$i] = array('weight'  =>$row['sum'], 'tagname' =>$row[$showName], 'url'=>'http://'.$hostName.$pathToSearchScript.urlencode('searchText=e&resultTarget=file&outputFormat=json&isoCategories='.$row['md_topic_category_id'].'&languageCode='.$languageCode));
+		$tags[$i] = array('weight'  =>$row['sum'], 'tagname' =>$row[$showName], 'url'=>'http://'.$hostName.$pathToSearchScript.urlencode('searchText=*&resultTarget=file&outputFormat=json&isoCategories='.$row['md_topic_category_id'].'&languageCode='.$languageCode));
 	if ($type == 'keywords') {
 		$tags[$i] = array('weight'  =>$row['sum'], 'tagname' =>$row[$showName], 'url'=>'http://'.$hostName.$pathToSearchScript.urlencode('searchText='.$row[$showName].'&resultTarget=file&outputFormat=json&languageCode='.$languageCode));
More information about the Mapbender_commits
