[Mapbender-commits] r7423 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 6 07:52:49 EST 2011
Author: armin11
Date: 2011-01-06 04:52:49 -0800 (Thu, 06 Jan 2011)
New Revision: 7423
   trunk/mapbender/http/javascripts/initWmcObj.php
Bugfixing - file_get_contents changed with class_connector - see user mailing list
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2011-01-05 10:46:57 UTC (rev 7422)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2011-01-06 12:52:49 UTC (rev 7423)
@@ -9,6 +9,7 @@
 require_once dirname(__FILE__)."/../../lib/class_GetApi.php";
 require_once dirname(__FILE__)."/../classes/class_elementVar.php";
 require_once(dirname(__FILE__) . "/../classes/class_tou.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
 function getConfiguration ($key) {
 //check if key param can be found in SESSION,
@@ -409,8 +410,9 @@
 	//check if tou has already been read - if not show them in the message
 	$resultOfCheck = $classTou->check('wms',$WMS['id']);
 	if ($resultOfCheck['accepted'] == 0) {
-		$tou .= $resourceSymbol." <a href='http://".$hostName."/mapbender/php/mod_showMetadata.php?resource=wms&layout=tabs&id=".$WMS['id']."&languageCode=".$languageCode."'>".$WMS['title']."</a><br>";
-		$tou .= file_get_contents("http://localhost/mapbender/php/mod_getServiceDisclaimer.php?resource=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true")."<br>";
+		$tou .= $resourceSymbol." <a href='../php/mod_showMetadata.php?resource=wms&layout=tabs&id=".$WMS['id']."&languageCode=".$languageCode."' target='_blank'>".$WMS['title']."</a><br>";
+		$touServiceConnector = new connector("http://localhost".$_SERVER['SCRIPT_NAME']."/../../php/mod_getServiceDisclaimer.php?resource=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true");
+		$tou .= $touServiceConnector->file;
 		//set the tou to be accepted - TODO maybe do this after the button which deletes the message window - from a ajax request.
 		$classTou->set('wms',$WMS['id']);
More information about the Mapbender_commits mailing list
