[Mapbender-commits] r7477 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Thu Jan 27 10:20:50 EST 2011
Author: astrid_emde
Date: 2011-01-27 07:20:50 -0800 (Thu, 27 Jan 2011)
New Revision: 7477
trunk/mapbender/http/plugins/mb_measure_widget.php
SQL updated
Modified: trunk/mapbender/http/plugins/mb_measure_widget.php
--- trunk/mapbender/http/plugins/mb_measure_widget.php 2011-01-27 13:38:33 UTC (rev 7476)
+++ trunk/mapbender/http/plugins/mb_measure_widget.php 2011-01-27 15:20:50 UTC (rev 7477)
@@ -9,16 +9,49 @@
* - http/widgets/w_measure.js
* SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
- * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
- * > e_target, e_requires, e_url) VALUES('<appId>','measure_widget',2,1,
- * > 'Measure','Measure distance','img',
- * > '../img/button_blink_red/measure_off.png','',515,60,24,24,1,'','','',
- * > '../plugins/mb_measure_widget.js',
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
+ * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target,
+ * > e_requires, e_url) VALUES('<appId>','measure_widget',2,1,'Measure',
+ * > 'Measure distance','img','../img/button_blue_red/measure_off.png','',
+ * > NULL ,NULL ,NULL ,NULL ,1,'','','','../plugins/mb_measure_widget.php',
* > '../widgets/w_measure.js,../extensions/RaphaelJS/raphael-1.4.7.min.js',
- * > 'mapframe1','jq_ui_dialog,jq_ui_widget',
- * > 'http://www.mapbender.org/index.php/Measure');
+ * > 'mapframe1','jq_ui_dialog,jq_ui_widget','http://www.mapbender.org/index.php/Measure');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'lineStrokeDefault', '#C9F', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'lineStrokeSnapped', '#F30', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'lineStrokeWidthDefault', '3', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'lineStrokeWidthSnapped', '5', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'measurePointDiameter', '7', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'opacity', '0.4', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'pointFillDefault', '#CCF', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'pointFillSnapped', '#F90', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'polygonFillDefault', '#FFF', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'polygonFillSnapped', '#FC3', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'polygonStrokeWidthDefault', '1', '' ,'var');
+ * > context, var_type) VALUES('<appId>', 'measure_widget', 'polygonStrokeWidthSnapped', '5', '' ,'var');
* Help:
* http://www.mapbender.org/Measure_widget
More information about the Mapbender_commits
