[Mapbender-commits] r7478 -
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org
Thu Jan 27 11:30:29 EST 2011
Author: armin11
Date: 2011-01-27 08:30:29 -0800 (Thu, 27 Jan 2011)
New Revision: 7478
Removed:
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
bugfixing problems onunload
Deleted: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2011-01-27 15:20:50 UTC (rev 7477)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2011-01-27 16:30:29 UTC (rev 7478)
@@ -1,1682 +0,0 @@
-# SOME DESCRIPTIVE TITLE.
-# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
-# This file is distributed under the same license as the PACKAGE package.
-# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
-#, fuzzy
-msgid ""
-msgstr ""
-"Project-Id-Version: PACKAGE VERSION\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-12-17 11:39+0100\n"
-"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
-"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
-"Language-Team: LANGUAGE <LL at li.org>\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-#: printPDF.conf:13
-msgid "Download: Map as PDF..."
-msgstr "Download: Karte als PDF..."
-#: printPDF.conf:26
-msgid "print legend"
-msgstr "Legende drucken"
-#: printPDF.conf:30
-msgid "Legend"
-msgstr "Legende"
-#: printPDF.conf:31
-msgid "powered by Mapbender"
-msgstr "mit Unterstützung von Mapbender"
-#: printPDF.conf:60
-msgid "Print preview"
-msgstr "Druckansicht"
-#: printPDF.conf:63
-msgid "Scale 1:"
-msgstr "Maßstab 1:"
-#: printPDF.conf:64
-msgid "Date"
-msgstr "Datum"
-#: printPDF.conf:66
-msgid "Notes"
-msgstr "Notizen"
-#: printPDF.conf:73
-msgid ""
-"This copy has been generated automatically and is valid without signature."
-msgstr "Der Auszug wurde maschinell erzeugt. Er ist ohne Unterschrift gültig."
-#: printPDF.conf:74
-msgid ""
-"This copy is protected by law (Par. 3 Abs. 1 VermKatG NW). It can be "
-"duplicated, modified, published or be passed to third parties only in "
-"agreement with"
-msgstr ""
-"Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). "
-"Vervielfältigungen, Umarbeitungen, Veröffentlichungen oder die Weitergabe an "
-"Dritte nur mit Zustimmung des"
-#: printPDF.conf:75
-msgid ""
-"the publisher, except duplicates and modifications aimed at internal use of "
-"government agencies or private use."
-msgstr ""
-"Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur "
-"innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch."
-#: printPDF.conf:
-msgid "This copy is protected by law (Par. 3 Abs. 1 VermKatG NW)."
-msgstr "Dieser Auszug ist gesetzlich geschützt (Par. 3 Abs. 1 VermKatG NW)."
-#: printPDF.conf:
-msgid ""
-"It can be duplicated, modified, published or be passed to third parties only "
-"in"
-msgstr ""
-"Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit"
-#: printPDF.conf:
-msgid "agreement with the publisher except duplicates and modifications"
-msgstr ""
-"Zustimmung des Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen"
-#: printPDF.conf:
-msgid "aimed at internal use of government agencies or private use."
-msgstr ""
-"zur innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch."
-#: printPDF.conf:94
-msgid "Format"
-msgstr "Format"
-#: printPDF.conf:101
-msgid "Orientation"
-msgstr "Ausrichtung"
-#: printPDF.conf:102
-msgid "portrait"
-msgstr "Hochformat"
-#: printPDF.conf:103
-msgid "landscape"
-msgstr "Querformat"
-#: printPDF.conf:104
-msgid "Quality"
-msgstr "Qualität"
-#: printPDF.conf:105 printPDF.conf:106
-#, php-format
-msgid "Quality: %d dpi"
-msgstr "Qualität: %d dpi"
-#: printPDF.conf:108
-msgid "Comment"
-msgstr "Kommentar"
-msgid "max."
-msgstr "max."
-#: printPDF.conf:111
-msgid "print"
-msgstr "drucken"
-#: mod_printPDF.php:
-msgid "No format selected"
-msgstr "Bitte wählen Sie ein Format aus"
-#: mod_digitize_messages.php:18
-msgid "polygon"
-msgstr "Polygon"
-#: mod_digitize_messages.php:19
-msgid "line"
-msgstr "Linie"
-#: mod_digitize_messages.php:20
-msgid "point"
-msgstr "Punkt"
-#: mod_digitize_messages.php:21
-msgid "Not an integer value."
-msgstr "Kein Integer-Wert."
-#: mod_digitize_messages.php:22
-msgid "Not a double value."
-msgstr "Kein Double-Wert."
-#: mod_digitize_messages.php:23
-msgid "This field may not be empty."
-msgstr "Das Feld darf nicht leer sein."
-#: mod_digitize_messages.php:24
-msgid "Failure during form evaluation."
-msgstr "Fehler bei der Formularauswertung."
-#: mod_digitize_messages.php:25 ../http/php/mod_gazetteerMetadata.php:138
-#: ../http/php/mod_gazetteerMetadata.php:201
-#: ../http/php/mod_gazetteerMetadata.php:212
-msgid "An error occured."
-msgstr "Ein Fehler ist aufgetreten."
-#: mod_digitize_messages.php:26
-msgid ""
-"At least two geometries must be available. Only polygons are allowed in the "
-"geometry list."
-msgstr ""
-"Es müssen mindestens zwei Geometrien ausgewählt sein. Es sind nur Polygone "
-"erlaubt in der Geometrieliste."
-#: mod_digitize_messages.php:27
-msgid ""
-"Exactly two geometries must be available. The first geometry shall be a "
-"polygon or a line, the second geometry shall be a line."
-msgstr ""
-"Es müssen genau zwei Geometrien ausgewählt sein. Die erste Geometrie sollte "
-"ein Polygon oder eine Linie, die zweite Geometrie eine Linie sein."
-#: mod_digitize_messages.php:28
-msgid "Exactly two polygons must be available."
-msgstr "Es müssen genau zwei Polygone ausgewählt sein."
-#: mod_digitize_messages.php:29
-msgid "Exactly two lines must be available."
-msgstr "Es müssen genau zwei Linien ausgewählt sein."
-#: mod_digitize_messages.php:30
-msgid "Success."
-msgstr "Aktion erfolgreich beendet."
-#: mod_digitize_messages.php:31
-msgid "Delete geometry from database?"
-msgstr "Geometrie in der Datenbank löschen?"
-#: mod_digitize_messages.php:32
-msgid "Clear list of geometries?"
-msgstr "Soll die Geometrieliste wirklich geleert werden?"
-#: mod_digitize_messages.php:33
-msgid "Please select an entry."
-msgstr "Bitte treffen Sie eine Auswahl."
-#: mod_digitize_messages.php:34
-msgid "Save"
-msgstr "Speichern"
-#: mod_digitize_messages.php:35
-msgid "Update"
-msgstr "Aktualisieren"
-#: mod_digitize_messages.php:36
-msgid "Delete"
-msgstr "Löschen"
-#: mod_digitize_messages.php:37
-msgid "Abort"
-msgstr "Abbrechen"
-#: mod_digitize_messages.php:38
-msgid "Fatal error: EPSG mismatch. "
-msgstr "Schwerwiegender Fehler: ungleiche EPSGs."
-#: mod_digitize_messages.php:39
-msgid "No geometry selected!"
-msgstr "Keine Geometrie ausgewählt!"
-#: mod_digitize_messages.php:40
-msgid ""
-"No valid line geometries for merging! Please check start and end points of "
-"your lines."
-msgstr ""
-"Keine gültigen Geometrien zum Verbinden! Bitte Start- und Endpunkte der "
-"Linien prüfen."
-#: mod_digitize_messages.php:41
-msgid "add point"
-msgstr "Punkt hinzufügen"
-#: mod_digitize_messages.php:42
-msgid "cancel editing"
-msgstr "Editieren abbrechen"
-#: mod_digitize_messages.php:43
-msgid "add line"
-msgstr "Linie hinzufügen"
-#: mod_digitize_messages.php:44 mod_digitize_messages.php:46
-msgid "finish line"
-msgstr "Linie abschliessen"
-#: mod_digitize_messages.php:45
-msgid "continue line"
-msgstr "Linie erweitern"
-#: mod_digitize_messages.php:47
-msgid "add polygon"
-msgstr "Polygon hinzufügen"
-#: mod_digitize_messages.php:48
-msgid "close polygon"
-msgstr "Polygon schliessen"
-#: mod_digitize_messages.php:49 mod_digitize_messages.php:50
-msgid "move basepoint"
-msgstr "Stützpunkt verschieben"
-#: mod_digitize_messages.php:51 mod_digitize_messages.php:52
-msgid "Insert basepoint"
-msgstr "Stützpunkt einfügen"
-#: mod_digitize_messages.php:53 mod_digitize_messages.php:54
-msgid "Delete basepoint"
-msgstr "Stützpunkt löschen"
-#: mod_digitize_messages.php:55 mod_digitize_messages.php:56
-msgid "clear list of geometries"
-msgstr "Geometrieliste leeren"
-#: mod_digitize_messages.php:57 mod_digitize_messages.php:58
-msgid ""
-"Merge two polygons into a single polygon (will be added to the geometry list)"
-msgstr ""
-"Zwei Polygone zu einem Polygon zusammenfügen (wird der Geometrieliste "
-"hinzugefügt)."
-#: mod_digitize_messages.php:59 mod_digitize_messages.php:60
-msgid ""
-"Split a polygon/line by a line (the new polygons/lines will be added to the "
-"geometry list)"
-msgstr ""
-"Polygon/Linie zerschneiden mit Hilfe einer Linie (neue Polygone/Linien "
-"werden zur Geometrienliste hinzugefügt)"
-#: mod_digitize_messages.php:61
-msgid ""
-"Combine two polygons (to create en- and exclave or to compute the difference)"
-msgstr ""
-"Verbinde zwei Polygone (zum Erstellen von En- oder Exklaven oder zum "
-"Berechnen der Differenz)"
-#: mod_digitize_messages.php:62
-msgid "Split geometries"
-msgstr "Geometrien zerschneiden"
-#: mod_digitize_messages.php:63 mod_digitize_messages.php:64
-msgid "Merge two lines into a single line"
-msgstr "Zwei Linien zu einer Linie zusammenfügen."
-#: mod_digitize_messages.php:65
-msgid "save / update / delete"
-msgstr "speichern / aktualisieren / löschen"
-#: mod_digitize_messages.php:66
-msgid "remove from workspace"
-msgstr "aus der Liste entfernen"
-#: mod_digitize_messages.php:67
-msgid "remove from database"
-msgstr "aus der Datenbank löschen"
-#: mod_digitize_messages.php:68
-msgid "clone this geometry"
-msgstr "dupliziere diese Geometrie"
-#: mod_digitize_messages.php:69
-msgid "click the first basepoint to close the polygon"
-msgstr "Auf den ersten Stützpunkt klicken, um das Polygon zu schliessen"
-#: mod_digitize_messages.php:70
-msgid "Current: "
-msgstr "Letztes Segment: "
-#: mod_digitize_messages.php:71
-msgid "Total: "
-msgstr "Gesamtlänge: "
-#: mod_digitize_messages.php:72
-msgid "new"
-msgstr "neu"
-#: mod_wfsSpatialRequest_messages.php:33
-msgid "select by rectangle"
-msgstr "Auswahl über Rechteck"
-#: mod_wfsSpatialRequest_messages.php:34
-msgid "select by polygon"
-msgstr "Auswahl über Polygon"
-#: mod_wfsSpatialRequest_messages.php:35
-msgid "select by point"
-msgstr "Auswahl über Punkt"
-#: mod_wfsSpatialRequest_messages.php:36
-msgid "select by extent"
-msgstr "Auswahl über Extent"
-#: mod_wfsSpatialRequest_messages.php:37
-msgid "open dialogue form"
-msgstr "Auswahlfenster öffnen"
-#: mod_wfsSpatialRequest_messages.php:38
-msgid "Invalid box!"
-msgstr "Ausschnitt ungültig!"
-#: /html/mod_treefolder2.php:56 http/html/mod_treefolderPlain.php:34
-#: ../http/html/mod_treefolderPlain.php:33
-#: ../http/html/mod_treefolderPlain.php:32
-msgid "Toggles the visibility of this service"
-msgstr "Sichtbarkeit des Layers an/aus"
-#: /html/mod_treefolder2.php:57 http/html/mod_treefolderPlain.php:35
-#: ../http/html/mod_treefolderPlain.php:34
-msgid "Toggles the queryability of this service"
-msgstr "Infoabfrage an/aus"
-#: /html/mod_treefolder2.php:58 http/html/mod_treefolderPlain.php:36
-#: ../http/html/mod_treefolderPlain.php:35
-msgid "Opens the layer context menu"
-msgstr "Öffnet das Layer Kontextmenü"
-#: /html/mod_treefolder2.php:59 http/html/mod_treefolderPlain.php:37
-#: ../http/html/mod_treefolderPlain.php:36
-msgid "Opens the WMS context menu"
-msgstr "Öffnet das WMS Kontextmenü"
-#: /html/mod_treefolder2.php:60 http/html/mod_treefolderPlain.php:38
-#: ../http/html/mod_treefolderPlain.php:37
-msgid "Removes the selected WMS"
-msgstr "Entfernt den gewählten Dienst"
-#: /html/mod_treefolder2.php:61 http/html/mod_treefolderPlain.php:39
-#: ../http/html/mod_treefolderPlain.php:38
-msgid "Moves the selection up"
-msgstr "selektierten Dienst nach oben verschieben"
-#: /html/mod_treefolder2.php:62 http/html/mod_treefolderPlain.php:40
-#: ../http/html/mod_treefolderPlain.php:39
-msgid "Moves the selection down"
-msgstr "selektierten Dienst nach unten verschieben"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:327
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:450
-msgid "WMS name"
-msgstr "WMS Name"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:328
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:451
-msgid "WMS abstract"
-msgstr "WMS Beschreibung"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:329
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:452
-msgid "Please select a WMS"
-msgstr "Bitte wählen Sie einen WMS aus"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:330
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:453
-msgid "Please select an application"
-msgstr "Bitte wählen Sie eine Applikation aus"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:331
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:454
-msgid "Please select a group"
-msgstr "Bitte wählen Sie eine Gruppe aus"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:332
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:455
-msgid "group abstract"
-msgstr "Beschreibung der Gruppe"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:333
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:456
-msgid "group name"
-msgstr "Name der Gruppe"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:334
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:457
-msgid "application abstract"
-msgstr "Beschreibung der Applikation"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:335
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:458
-msgid "application name"
-msgstr "Name der Anwendung"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:336
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:459
-msgid "no result"
-msgstr "kein Ergebnis"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:342
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:465
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:475
-msgid "Add WMS"
-msgstr "WMS hinzufügen"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:343
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:466
-msgid "Enter a Capabilities-URL of a WMS or select one or more WMS from list."
-msgstr ""
-"Geben Sie eine Capabilities-URL ein oder wählen Sie einen der aufgelisteten "
-"Dienste."
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:344
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:467
-msgid ""
-"Notice: Be aware of the scale hints. Possibly you need to zoom in to display "
-"the added service."
-msgstr ""
-"Hinweis: Beachten Sie die logischen Zoomstufen. Möglicherweise müssen Sie "
-"den Maßstab wechseln, um die Ebenen des geladenen Dienstes zu sehen."
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:350
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:473
-msgid "Capabilities-URL"
-msgstr "Capabilities-URL"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:362
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:492
-msgid "List all WMS"
-msgstr "Liste aller WMS"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:363
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:493
-msgid "List WMS by Group"
-msgstr "WMS nach Gruppen sortiert"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:364
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:494
-msgid "List WMS by Application"
-msgstr "WMS nach Anwendungen sortiert"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:374
-msgid "Loading WMS"
-msgstr "Der WMS wird geladen"
-#: http/php/mod_createJSObjFromXML.php:33
-msgid ""
-"Error: The Capabilities Document could not be accessed. Please check whether "
-"the server is responding and accessible to Mapbender."
-msgstr ""
-"Fehler: Das Capabilities-Dokument ist nicht verfügbar. Bitte prüfen Sie, ob "
-"der Server antwortet und für Mapbender erreichbar ist."
-#: http/html/mod_treefolderPlain.php:33
-#: ../http/html/mod_treefolderPlain.php:31
-msgid "(De)activate this service"
-msgstr "Dienst (de)aktivieren"
-#: http/html/mod_treefolderPlain.php:144
-#: ../http/html/mod_treefolderPlain.php:143
-#: ../http/html/mod_treefolderPlain.php:199
-msgid "Move up"
-msgstr "rauf"
-#: http/html/mod_treefolderPlain.php:145
-#: ../http/html/mod_treefolderPlain.php:144
-#: ../http/html/mod_treefolderPlain.php:200
-msgid "Move down"
-msgstr "runter"
-#: http/html/mod_treefolderPlain.php:146
-#: ../http/html/mod_treefolderPlain.php:145
-#: ../http/html/mod_treefolderPlain.php:201
-msgid "Remove"
-msgstr "entfernen"
-#: http/html/mod_treefolderPlain.php:147
-#: ../http/html/mod_treefolderPlain.php:146
-#: ../http/html/mod_treefolderPlain.php:202
-msgid "Opacity up"
-msgstr "Transparenz verringern"
-#: http/html/mod_treefolderPlain.php:148
-#: ../http/html/mod_treefolderPlain.php:147
-#: ../http/html/mod_treefolderPlain.php:203
-msgid "Opacity down"
-msgstr "Transparenz erhöhen"
-#: http/html/mod_treefolderPlain.php:149
-#: ../http/html/mod_treefolderPlain.php:148
-#: ../http/html/mod_treefolderPlain.php:204
-msgid "Information"
-msgstr "Information"
-#: http/html/mod_treefolderPlain.php:150 http/html/mod_treefolderPlain.php:152
-#: ../http/html/mod_treefolderPlain.php:149
-#: ../http/html/mod_treefolderPlain.php:151
-#: ../http/html/mod_treefolderPlain.php:205
-#: ../http/html/mod_treefolderPlain.php:208
-msgid "Zoom"
-msgstr "auf Ebene zoomen"
-#: http/html/mod_treefolderPlain.php:151
-#: ../http/html/mod_treefolderPlain.php:150
-#: ../http/html/mod_treefolderPlain.php:206
-msgid "Hide menu"
-msgstr "schließen"
-#: conf/wfs_additional_spatial_search.conf:17
-msgid "Spatial filter is set."
-msgstr "räumlicher Filter gesetzt"
-#: conf/wfs_additional_spatial_search.conf:31
-msgid "Search results"
-msgstr "Suchergebnisse"
-#: conf/wfs_additional_spatial_search.conf:37
-msgid "Details"
-msgstr "Details"
-#: http/php/mb_listGUIs.php:59
-msgid "available applications"
-msgstr "Liste der verfügbaren Anwendungen"
-#: http/php/mb_listGUIs.php:82 ../http/php/mb_listGUIs.php:99
-msgid "Others"
-msgstr "Sonstige"
-#: ../http/html/mod_treefolderPlain.php:420
-#: ../http/html/mod_treefolderPlain.php:522
-msgid "You have to select the WMS you want to move up!"
-msgstr "Sie müssen den Dienst, den Sie nach oben schieben wollen, selektieren."
-#: ../http/html/mod_treefolderPlain.php:425
-#: ../http/html/mod_treefolderPlain.php:457
-#: ../http/html/mod_treefolderPlain.php:527
-#: ../http/html/mod_treefolderPlain.php:559
-msgid "Illegal move operation"
-msgstr "Ungültige Operation"
-#: ../http/html/mod_treefolderPlain.php:452
-#: ../http/html/mod_treefolderPlain.php:554
-msgid "You have to select the WMS you want to move down!"
-msgstr ""
-"Sie müssen den Dienst, den Sie nach unten schieben wollen, selektieren."
-#: ../http/html/mod_treefolderPlain.php:484
-#: ../http/html/mod_treefolderPlain.php:586
-msgid "You have to select the WMS you want to delete!"
-msgstr "Sie müssen den Dienst, den Sie entfernen wollen, selektieren."
-#: ../http/html/mod_treefolderPlain.php:488
-#: ../http/html/mod_treefolderPlain.php:590
-msgid "It is not possible to delete a single layer, please select a WMS!"
-msgstr ""
-"Es ist nicht möglich einen einzelnen Layer zu entfernen. Bitte selektieren "
-"Sie einen WMS!"
-#: ../http/html/mod_treefolderPlain.php:496
-#: ../http/html/mod_treefolderPlain.php:598
-msgid "Last WMS can not be removed."
-msgstr "Der letzte WMS kann nicht entfernt werden."
-#: ../http/html/mod_treefolderPlain.php:499
-#: ../http/html/mod_treefolderPlain.php:601
-msgid "Are you sure you want to remove"
-msgstr "Sind Sie sicher, dass Sie diesen Dienst entfernen wollen "
-#: http/javascripts/mod_measure.php:298
-msgid "Close polygon"
-#: http/javascripts/mod_measure.php:314
-msgid "Rubber"
-msgstr "Skizze löschen"
-#: http/javascripts/mod_measure.php:329
-msgid "Get area"
-msgstr "Fläche berechnen"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:411
-msgid "show metadata"
-msgstr "Metadaten anzeigen"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:420
-msgid "remove WFS Conf"
-msgstr "WFS Konfiguration entfernen"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:455
-msgid "Point"
-msgstr "Punkt"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:459
-msgid "Line"
-msgstr "Linie"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:463
-msgid "Polygon"
-msgstr "Polygon"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:621
-msgid "Different EPSG of map and wfs featuretype, no spatial request possible!"
-msgstr ""
-"Unterschiedliche EPSG von Karte und WFS FeatureType. Es ist keine räumliche "
-"möglich."
-msgid "Show metadata"
-#: ../http/html/mod_treefolderPlain.php:207
-msgid "Change style"
-msgstr "Stil ändern"
-#: ../http/html/mod_treefolderPlain.php:471
-msgid "Change layer style"
-msgstr "Layer Stil ändern"
-msgid "Please select a style"
-msgstr "Bitte wählen Sie einen Stil aus"
-#: ../http/html/mod_treefolderPlain.php:477
-msgid "Close"
-msgstr "schließen"
-#: ../http/html/mod_treefolderPlain.php:490
-msgid "There is no different style available for this layer."
-msgstr "Es liegen keine weiteren Stile für diesen Layer vor."
-msgid ""
-"Hint: Possibly you need to zoom in for showing layers from external map "
-"service. The operator of the external service is responsible for the display "
-"ranges. PortalU does not have a stake in this behaviour."
-msgstr ""
-"Hinweis: Möglicherweise müssen Sie in die Karte zoomen, um Layer von "
-"externen Diensten zu sehen.Der Administrator des externen Dienstes ist für "
-"die Anzeige verantwortlich."
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:479
-msgid "activate layers"
-msgstr "Ebenen des Kartendienstes aktivieren"
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:483
-msgid "zoom to extent"
-msgstr "auf Ausdehnung des Kartendiensten zoomen"
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:501
-#: ../http/javascripts/mod_searchCSW_ajax.php:507
-msgid "Loading"
-msgstr "Kartendienst wird geladen"
-#: ../http/php/mod_meetingPoint.php:42
-msgid "Your meeting point. Follow the link!"
-msgstr "Ihr Treffpunkt. Folgen Sie dem Link!"
-#: ../http/php/mod_meetingPoint.php:98
-msgid "Please click for the meeting point position!"
-msgstr "Bitte klicken Sie in die Karte, um einen Treffpunkt zu erzeugen."
-#: ../http/php/mod_meetingPoint.php:210
-msgid "Max characters"
-msgstr "Max. Eingabe"
-#: ../http/php/mod_meetingPoint.php:229
-msgid "Please define a text!"
-msgstr "Bitte geben Sie einen Text ein."
-#: ../http/php/mod_meetingPoint.php:323
-msgid "cancel"
-msgstr "Abbrechen"
-#: ../http/php/mod_gazetteerMetadata.php:150
-msgid "The added Service has more than"
-msgstr "Der hinzugefügte Dienst hat mehr als"
-#: ../http/php/mod_gazetteerMetadata.php:208
-msgid "The following Service has been added"
-msgstr "Der folgende Dienst wurde hinzugefügt"
-#: ../http/php/mod_gazetteerMetadata.php:234
-msgid "SelectKeyword"
-msgstr "Suchbegriff auswählen"
-#: ../http/php/mod_gazetteerMetadata.php:249
-#: ../http/plugins/mb_metadata_wmc_edit.php:31
-#: ../http/plugins/mb_metadata_wmc_server.php:57
-msgid "Metadata"
-msgstr "Metadatem"
-#: ../http/php/mod_gazetteerMetadata.php:267
-msgid "Searching"
-msgstr "Suche läuft"
-#: ../http/php/mod_gazetteerMetadata.php:317
-msgid "Load"
-msgstr "Laden"
-#: ../http/php/mod_gazetteerMetadata.php:342
-msgid "Add WMS and zoom to extent"
-msgstr "Kartendienst hinzuladen und auf Ausdehnung zoomen"
-#: ../http/php/mod_gazetteerMetadata.php:440
-msgid "keywords"
-msgstr "Suchbegriffe"
-msgid "layer. The layer of the MapService will NOT be activated."
-msgstr "Ebenen. Die Ebenen des Kartendienstes werden NICHT aktiviert."
-#: ../http/php/mod_SelectKeyword.php:24
-msgid "Select a keyword"
-msgstr "Wählen Sie einen Suchbegriff aus"
-#: ../http/php/mod_SelectKeyword.php:48
-msgid "Please double click to select a keyword."
-msgstr "Suchbegriff per Doppelklick auswählen."
-#: ../http/php/mod_gazetteerMetadata.php:262
-msgid "Please insert a keyword!"
-msgstr "Bitte geben Sie einen Suchbegriff an."
-#: ../http/javascripts/mod_searchCSW_ajax.php:89
-#: ../http/javascripts/mod_searchCSW_ajax.php:489
-msgid "+ Advanced"
-msgstr "+ Erweitert"
-#: ../http/javascripts/mod_searchCSW_ajax.php:107
-msgid "Title "
-msgstr "Titel"
-#: ../http/javascripts/mod_searchCSW_ajax.php:109
-msgid "Abstract"
-msgstr "Beschreibung"
-#: ../http/javascripts/mod_searchCSW_ajax.php:111
-msgid "Keywords"
-msgstr "Stichworte"
-#: ../http/javascripts/mod_searchCSW_ajax.php:121
-msgid "Lat-Min"
-msgstr "min. Lat"
-#: ../http/javascripts/mod_searchCSW_ajax.php:128
-msgid "Lon-Min"
-msgstr "min. Lon"
-#: ../http/javascripts/mod_searchCSW_ajax.php:133
-msgid "Lat-Max"
-msgstr "max. Lat"
-#: ../http/javascripts/mod_searchCSW_ajax.php:140
-msgid "Lon-Max"
-msgstr "max. Lon"
-#: ../http/javascripts/mod_searchCSW_ajax.php:161
-msgid "Getrecords Medium"
-msgstr "noch übersetzen Getrecords Medium"
-#: ../http/javascripts/mod_searchCSW_ajax.php:169
-msgid "Query Language"
-msgstr "noch Übersetzen: Query Language"
-#: ../http/javascripts/mod_searchCSW_ajax.php:184
-#: ../http/javascripts/mod_searchCSW_ajax.php:495
-msgid "+ Options"
-msgstr "+ Optionen"
-#: ../http/javascripts/mod_searchCSW_ajax.php:459
-msgid "Record Title"
-msgstr "Titel"
-#: ../http/javascripts/mod_searchCSW_ajax.php:460
-msgid "Record Abstract"
-#: ../http/javascripts/mod_searchCSW_ajax.php:461
-msgid "Returned Results..."
-msgstr "Erhaltene Treffer..."
-#: ../http/javascripts/mod_searchCSW_ajax.php:472
-msgid ""
-"Do a Basic or Advanced Search of Catalogs in the system. Please visit the "
-"Catalog Admin to add a Catalog"
-msgstr ""
-"Führen Sie eine einfache oder erweiterte Suche durch. Über die "
-"Administration können Sie auch einen Katalogdienst laden."
-#: ../http/javascripts/mod_searchCSW_ajax.php:480
-msgid "Search for "
-msgstr "Suche nach"
-#: ../http/javascripts/mod_searchCSW_ajax.php:500
-msgid "Search CSW"
-msgstr "Katalogsuche"
-#: ../http/javascripts/mod_searchCSW_ajax.php:102
-msgid "- Advanced"
-msgstr "- Erweitert"
-#: ../http/javascripts/mod_searchCSW_ajax.php:105
-msgid "Advanced Search"
-msgstr "Erweiterte Suche"
-#: ../http/javascripts/mod_searchCSW_ajax.php:154
-msgid "- Options"
-msgstr "- Optionen"
-#: ../http/javascripts/mod_searchCSW_ajax.php:159
-msgid "Number of Hits"
-msgstr "Anzahl der Treffer"
-#: ../http/javascripts/mod_searchCSW_ajax.php:171
-msgid "CQL"
-msgstr "CQL"
-#: ../http/javascripts/mod_searchCSW_ajax.php:172
-msgid "Filter"
-msgstr "Filter"
-#: ../http/javascripts/mod_searchCSW_ajax.php:478
-msgid "Capabilities"
-msgstr "noch übersetzen: Capabilities"
-#: ../http/javascripts/mod_searchCSW_ajax.php:470
-msgid "Catalog Search"
-#: ../http/javascripts/mod_searchCSW_ajax.php:31
-msgid "Search Catalog"
-msgstr "Suche starten"
-msgid "Name:"
-msgstr "xxxx"
-msgid "Firstname:"
-msgstr "Vorname:"
-msgid "Lastname:"
-msgstr "Nachname:"
-msgid "Usertype:"
-msgstr "Typ:"
-msgid "Germany"
-msgstr "Deutschland"
-msgid "my lines"
-msgstr "meine Linien"
-#: ../http/javascripts/mod_loadwmc.js:68
-msgid "List"
-msgstr "Liste"
-#: ../http/javascripts/mod_loadwmc.js:69
-msgid "Upload"
-msgstr "Laden"
-#: ../http/javascripts/mod_loadwmc.js:80
-msgid "WMC name"
-msgstr "WMS Name"
-#: ../http/javascripts/mod_loadwmc.js:81
-msgid "last update"
-msgstr "letzte Änderung"
-#: ../http/javascripts/mod_loadwmc.js:82
-msgid "created"
-msgstr "erstellt"
-#: ../http/javascripts/mod_loadwmc.js:83
-msgid "load"
-msgstr "laden"
-#: ../http/javascripts/mod_loadwmc.js:84
-msgid "merge"
-msgstr "mergen"
-#: ../http/javascripts/mod_loadwmc.js:85
-msgid "append"
-msgstr "hinzufügen"
-#: ../http/javascripts/mod_loadwmc.js:86
-msgid "public"
-msgstr "öffentlich"
-#: ../http/javascripts/mod_loadwmc.js:87
-msgid "show"
-msgstr "anzeigen"
-#: ../http/javascripts/mod_loadwmc.js:88
-#: ../http/javascripts/mod_loadwmc.js:294
-msgid "OpenLayers"
-msgstr "OpenLayers"
-#: ../http/javascripts/mod_loadwmc.js:89
-msgid "delete"
-msgstr "löschen"
-#: ../http/javascripts/mod_loadwmc.js:173
-msgid "load this WMC"
-msgstr "lade dieses WMC"
-#: ../http/javascripts/mod_loadwmc.js:175
-#: ../http/javascripts/mod_loadwmc.js:358
-msgid "WMC has been loaded successfully."
-msgstr "Das WMC wurde erfolgreich geladen."
-#: ../http/javascripts/mod_loadwmc.js:196
-msgid "merge WMC"
-msgstr "WMC zusammenfügen"
-#: ../http/javascripts/mod_loadwmc.js:198
-msgid "WMC has been merged successfully."
-msgstr "WMC wurde erfolgreich zusammengeführt."
-#: ../http/javascripts/mod_loadwmc.js:222
-msgid "append WMC"
-msgstr "WMC hinzufügen"
-#: ../http/javascripts/mod_loadwmc.js:224
-msgid "WMC has been appended successfully."
-msgstr "WMC wurde erfolgreich hinzugefügt"
-#: ../http/javascripts/mod_loadwmc.js:229
-msgid "currentState"
-msgstr "aktueller Stand"
-#: ../http/javascripts/mod_loadwmc.js:262
-msgid "display WMC XML"
-msgstr "WMC XML anzeigen"
-#: ../http/javascripts/mod_loadwmc.js:267
-msgid "WMC Document"
-msgstr "WMC Dokument"
-#: ../http/javascripts/mod_loadwmc.js:289
-msgid "export to OpenLayers"
-msgstr "nach OpenLayers exportieren"
-#: ../http/javascripts/mod_loadwmc.js:322
-msgid "delete this WMC"
-msgstr "WMC löschen"
-#: ../http/javascripts/mod_loadwmc.js:325
-msgid "Do you really want to delete WMC"
-msgstr "Wollen Sie dieses WMC wirklich löschen?"
-#: ../http/javascripts/mod_loadwmc.js:404
-msgid "load Service anyway?"
-msgstr "Dienst trotzdem laden?"
-#: ../http/javascripts/mod_zoomCoords.php:36
-msgid "Please type a number."
-msgstr "Bitte geben Sie die Koordinaten als Zahlen ein."
-#: ../http/javascripts/mod_zoomCoords.php:88
-msgid "ok"
-msgstr "ok"
-#: ../http/javascripts/mod_zoomCoords.php:91
-msgid "Longitude"
-msgstr "Rechtswert"
-#: ../http/javascripts/mod_zoomCoords.php:92
-msgid "Latitude"
-msgstr "Hochwert"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:10
-#: workspace/test27/http/plugins/mb_metadata_layer.php:34
-#: ../http/plugins/mb_metadata_edit.php:10
-#: ../http/plugins/mb_metadata_featuretype.php:34
-#: ../http/plugins/mb_metadata_layer.php:34
-#: ../http/plugins/mb_metadata_wfs_edit.php:10
-msgid "Show original Service Metadata from last update"
-msgstr "Originale Dienstmetadaten von letzter Aktualisierung anzeigen"
-#: workspace/test27/http/plugins/jq_upload_images.php:29
-#: workspace/test27/http/plugins/jq_upload.php:29
-#: ../http/plugins/jq_upload.php:29
-#, php-format
-msgid "Files with this extension are not allowed. Must be %s."
-msgstr ""
-"Dateien in diesem Format werden nicht unterstützt, wählen Sie eines der "
-"folgenden Bildformate: %s."
-#: workspace/test27/http/plugins/jq_upload_images.php:49
-#: workspace/test27/http/plugins/jq_upload.php:50
-#: ../http/plugins/jq_upload.php:50
-#, php-format
-msgid "Files with extension %s are not allowed. Must be %s."
-msgstr ""
-"Dateien in dem Format %s werden nicht unterstützt, wählen Sie eines der "
-#: workspace/test27/http/plugins/jq_upload_images.php:61
-#: workspace/test27/http/plugins/jq_upload.php:63
-#: ../http/plugins/jq_upload.php:63
-#, php-format
-msgid "File size limit (%s KB) exceeded."
-msgstr "Datei zu groß (maximal %s KB)."
-#: workspace/test27/http/plugins/jq_upload_images.php:75
-#: workspace/test27/http/plugins/jq_upload.php:78
-msgid "File could not be stored on server. Please contact the administrator."
-msgstr ""
-"Die Datei konnte nicht hochgeladen werden. Bitte wenden Sie sich an den "
-"Administrator."
-#: workspace/test27/http/plugins/jq_upload_images.php:80
-#: workspace/test27/http/plugins/jq_upload.php:83
-msgid "File has been uploaded."
-msgstr "Die Datei wurde erfolgreich hochgeladen."
-#: workspace/test27/http/plugins/mb_i18n_server.php:48
-#: workspace/test27/http/plugins/mb_metadata_server.php:388
-#: workspace/test27/http/plugins/mb_original_metadata_server.php:172
-#: workspace/test27/http/plugins/mb_twitter.php:126
-#: ../http/plugins/mb_i18n_server.php:48
-#: ../http/plugins/mb_metadata_server.php:424
-#: ../http/plugins/mb_metadata_wfs_server.php:388
-#: ../http/plugins/mb_metadata_wmc_server.php:217
-#: ../http/plugins/mb_original_metadata_server.php:205
-#: ../http/plugins/mb_original_metadata_wfs_server.php:206
-#: ../http/plugins/mb_original_metadata_wmc_server.php:75
-#: ../http/plugins/mb_sql_server.php:36
-msgid "An unknown error occured."
-msgstr "Ein unkekannter Fehler ist aufgetreten."
-#: workspace/test27/http/plugins/mb_metadata_edit.php:8
-#: ../http/plugins/mb_metadata_edit.php:8
-#: ../http/plugins/mb_metadata_wfs_edit.php:8
-#: ../http/plugins/mb_metadata_wmc_edit.php:23
-msgid "Service Level Metadata"
-msgstr "Service Metadaten"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:12
-#: workspace/test27/http/plugins/mb_metadata_edit.php:57
-#: workspace/test27/http/plugins/mb_metadata_layer.php:32
-#: workspace/test27/http/plugins/mb_metadata_layer.php:36
-#: workspace/test27/http/plugins/mb_metadata_layer.php:62
-#: ../http/plugins/mb_metadata_edit.php:12
-#: ../http/plugins/mb_metadata_edit.php:57
-#: ../http/plugins/mb_metadata_featuretype.php:32
-#: ../http/plugins/mb_metadata_featuretype.php:36
-#: ../http/plugins/mb_metadata_featuretype.php:62
-#: ../http/plugins/mb_metadata_layer.php:32
-#: ../http/plugins/mb_metadata_layer.php:36
-#: ../http/plugins/mb_metadata_layer.php:62
-#: ../http/plugins/mb_metadata_wfs_edit.php:12
-#: ../http/plugins/mb_metadata_wfs_edit.php:57
-msgid "Help"
-msgstr "Hilfe"
-msgid ""
-"Possibility to adapt and add informations in the separate WMS-Layer "
-"Metadata. The modified Metadata is stored in the database of the GeoPortal."
-"rlp, outwardly these metadata overwrite the original Service-Metadata."
-msgstr ""
-"Möglichkeit der Überarbeitung und Ergänzung der WMS Metadaten. Die "
-"bearbeiteten Metadaten werden in der Datenbank des GeoPortal.rlp abgelegt "
-"und überschreiben nach Außen hin die originären Metadaten des WMS-Dienstes."
-msgid ""
-"The original WMS-Metadata from the last update could be recovered or "
-"updated, so that the original Service-Metadata will be shown outward again."
-msgstr ""
-"Anzeige der originären WMS Metadaten (Stand: letzte Aktualisierung) "
-"Hilfetext: Die originären Metadaten des WMS vom Stand der letzten "
-"Aktualisierung können wiederhergestellt bzw. aktualisiert und werden damit "
-"nach Außen sichtbar."
-#: workspace/test27/http/plugins/mb_metadata_edit.php:15
-#: ../http/plugins/mb_metadata_edit.php:15
-msgid "WMS Title (OWS)"
-msgstr "WMS-Titel (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:17
-#: workspace/test27/http/plugins/mb_metadata_edit.php:22
-#: workspace/test27/http/plugins/mb_metadata_edit.php:27
-#: workspace/test27/http/plugins/mb_metadata_edit.php:32
-#: workspace/test27/http/plugins/mb_metadata_edit.php:37
-#: workspace/test27/http/plugins/mb_metadata_edit.php:81
-#: workspace/test27/http/plugins/mb_metadata_edit.php:106
-#: workspace/test27/http/plugins/mb_metadata_edit.php:111
-#: workspace/test27/http/plugins/mb_metadata_edit.php:116
-#: workspace/test27/http/plugins/mb_metadata_layer.php:45
-#: workspace/test27/http/plugins/mb_metadata_layer.php:50
-#: workspace/test27/http/plugins/mb_metadata_layer.php:97
-#: workspace/test27/http/plugins/mb_metadata_layer.php:107
-#: ../http/plugins/mb_metadata_edit.php:17
-#: ../http/plugins/mb_metadata_edit.php:22
-#: ../http/plugins/mb_metadata_edit.php:27
-#: ../http/plugins/mb_metadata_edit.php:32
-#: ../http/plugins/mb_metadata_edit.php:37
-#: ../http/plugins/mb_metadata_edit.php:81
-#: ../http/plugins/mb_metadata_edit.php:106
-#: ../http/plugins/mb_metadata_edit.php:111
-#: ../http/plugins/mb_metadata_edit.php:116
-#: ../http/plugins/mb_metadata_featuretype.php:45
-#: ../http/plugins/mb_metadata_featuretype.php:50
-#: ../http/plugins/mb_metadata_featuretype.php:90
-#: ../http/plugins/mb_metadata_featuretype.php:101
-#: ../http/plugins/mb_metadata_layer.php:45
-#: ../http/plugins/mb_metadata_layer.php:50
-#: ../http/plugins/mb_metadata_layer.php:97
-#: ../http/plugins/mb_metadata_layer.php:108
-#: ../http/plugins/mb_metadata_wfs_edit.php:17
-#: ../http/plugins/mb_metadata_wfs_edit.php:22
-#: ../http/plugins/mb_metadata_wfs_edit.php:27
-#: ../http/plugins/mb_metadata_wfs_edit.php:32
-#: ../http/plugins/mb_metadata_wfs_edit.php:37
-#: ../http/plugins/mb_metadata_wfs_edit.php:81
-#: ../http/plugins/mb_metadata_wfs_edit.php:106
-#: ../http/plugins/mb_metadata_wfs_edit.php:111
-#: ../http/plugins/mb_metadata_wfs_edit.php:116
-#: ../http/plugins/mb_metadata_wmc_edit.php:36
-#: ../http/plugins/mb_metadata_wmc_edit.php:41
-#: ../http/plugins/mb_metadata_wmc_edit.php:46
-#: ../http/plugins/mb_metadata_wmc_edit.php:70
-#: ../http/plugins/mb_metadata_wmc_edit.php:81
-msgid "Inspire"
-msgstr "Inspire"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:20
-#: ../http/plugins/mb_metadata_edit.php:20
-msgid "WMS Abstract (OWS)"
-msgstr "WMS-Beschreibung (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:25
-#: ../http/plugins/mb_metadata_edit.php:25
-msgid "WMS Keywords (OWS)"
-msgstr "WMS Schlüsselwörter (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:30
-#: ../http/plugins/mb_metadata_edit.php:30
-msgid "WMS Fees (OWS)"
-msgstr "WMS Kosten/Gebühren (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:35
-#: ../http/plugins/mb_metadata_edit.php:35
-msgid "WMS AccessConstraints (OWS)"
-msgstr "WMS Zugriffsbeschränkung (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:48
-#: ../http/plugins/mb_metadata_edit.php:48
-msgid "WMS Predefined Licence (Registry)"
-msgstr "WMS vordefiniere Lizenzbedingungen (Registry)"
-msgid ""
-"Auswahl von vordefinierten Lizenzen hinsichtlich Gebühren und "
-"Zugriffsbeschränkungen."
-msgstr ""
-#: workspace/test27/http/plugins/mb_metadata_edit.php:61
-#: ../http/plugins/mb_metadata_edit.php:61
-msgid "WMS Provider Section (OWS)"
-msgstr "Bereitstellende Organisation (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:63
-#: ../http/plugins/mb_metadata_edit.php:63
-#: ../http/plugins/mb_metadata_wfs_edit.php:63
-msgid "Contact Individual Name (OWS)"
-msgstr "Ansprechpartner (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:67
-#: ../http/plugins/mb_metadata_edit.php:67
-#: ../http/plugins/mb_metadata_wfs_edit.php:67
-msgid "Contact Position Name (OWS)"
-msgstr "Position des Ansprechpartners (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:71
-#: ../http/plugins/mb_metadata_edit.php:71
-#: ../http/plugins/mb_metadata_wfs_edit.php:71
-msgid "Contact Phone Voice (OWS)"
-msgstr "Telefonnummer (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:79
-#: ../http/plugins/mb_metadata_edit.php:79
-msgid "Contact Organisation (WMS)"
-msgstr "Organisation (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:84
-#: ../http/plugins/mb_metadata_edit.php:84
-msgid "Contact Address (WMS)"
-msgstr "Adresse (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:88
-#: ../http/plugins/mb_metadata_edit.php:88
-msgid "Contact City (WMS)"
-msgstr "Ort/Stadt (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:92
-#: ../http/plugins/mb_metadata_edit.php:92
-msgid "Contact State or Province (WMS) - ISO 3166-II"
-msgstr "Bundesland (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:96
-#: ../http/plugins/mb_metadata_edit.php:96
-msgid "Contact Post Code (WMS)"
-msgstr "PLZ (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:100
-#: ../http/plugins/mb_metadata_edit.php:100
-msgid "Contact Post Country (WMS) - ISO 3166"
-msgstr "Land (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:104
-#: ../http/plugins/mb_metadata_edit.php:104
-msgid "Contact Electronic Mail Address (WMS)"
-msgstr "e-mail (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:109
-#: ../http/plugins/mb_metadata_edit.php:109
-#: ../http/plugins/mb_metadata_wfs_edit.php:109
-msgid "Date of first registration (Registry)"
-msgstr "Datum der ersten Registrierung des WMS-Dienstes (Registry)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:114
-#: ../http/plugins/mb_metadata_edit.php:114
-#: ../http/plugins/mb_metadata_wfs_edit.php:114
-msgid "Date of last revision (Registry)"
-msgstr "Datum des letzten Updates des WMS-Dienstes (Registry)"
-msgid ""
-"Metadata. The modified Metadata will be stored in the database of the "
-"GeoPortal.rlp, outwardly these metadata overwrite the original Service-"
-"Metadata."
-msgstr ""
-"Möglichkeit der Überarbeitung und Ergänzung der in den einzelnen WMS-Layern "
-"enthaltenen Metadaten. Die bearbeiteten Metadaten werden in der Datenbank "
-"des GeoPortal.rlp abgelegt und überschreiben nach Außen hin die originären "
-"Metadaten des WMS-Dienstes."
-#: workspace/test27/http/plugins/mb_metadata_layer.php:39
-#: ../http/plugins/mb_metadata_layer.php:39
-msgid "Number of Layer (Registry)"
-msgstr "Identifikationsnummer des Layers (Registry)"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:44
-#: ../http/plugins/mb_metadata_layer.php:44
-msgid "Layer Title (WMS)"
-msgstr "Layertitel (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:49
-#: ../http/plugins/mb_metadata_layer.php:49
-msgid "Layer Abstract (WMS)"
-msgstr "Beschreibung (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:54
-#: ../http/plugins/mb_metadata_layer.php:54
-msgid "Layer Keywords (WMS)"
-msgstr "Schlüsselwörter (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:61
-#: ../http/plugins/mb_metadata_featuretype.php:61
-#: ../http/plugins/mb_metadata_layer.php:61
-msgid "Add Information about the underlying data"
-msgstr "Weitere standardisierte Informationen zum Layer (Datensatz-Metadaten)"
-msgid ""
-"Linking the WMS layer with metadata set (coupled resource), which describes "
-"the underlying informations of the representation in more detail (eg "
-"Actuality / quality). It occurs via a link to an already existing metadta "
-"set in a catalog or a simple metadata set will be generatetd using a "
-"Mapbender Layer Addon-Editor."
-msgstr ""
-"Verknüpfen des WMS-Layers mit einem Metadatensatzes (gekoppelte Ressource), "
-"der die der Darstellung zugrundeliegenden Informationen näher beschreibt (z."
-"B.: Aktualität/Qualität). Verknüpfung erfolgt entweder über Link zu einem "
-"schon in einem Katalog vorhandenen Metadatensatz oder über die Generierung "
-"des eines einfachen Metadatensatzes mittels Mapbender Layer-AddonEditor."
-#: ../http/plugins/mb_metadata_featuretype.php:65
-#: ../http/plugins/mb_metadata_layer.php:65
-msgid "Add new Metadata Record"
-msgstr "Metadatensatz erzeugen"
-#: ../http/plugins/mb_metadata_featuretype.php:68
-#: ../http/plugins/mb_metadata_layer.php:68
-msgid "Edit Metadata Linkage"
-msgstr "Metadatensatz editieren"
-#: ../http/plugins/mb_metadata_featuretype.php:71
-#: ../http/plugins/mb_metadata_layer.php:71
-msgid "Delete Metadata Linkage"
-msgstr "Metadatensatz löschen"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:86
-#: ../http/plugins/mb_metadata_layer.php:86
-#: ../http/plugins/mb_metadata_wmc_edit.php:57
-msgid "Preview"
-msgstr "Vorschau"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:94
-#: ../http/plugins/mb_metadata_featuretype.php:87
-#: ../http/plugins/mb_metadata_layer.php:94
-#: ../http/plugins/mb_metadata_wmc_edit.php:66
-msgid "Classification"
-msgstr "Klassifizierung"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:96
-#: ../http/plugins/mb_metadata_featuretype.php:89
-#: ../http/plugins/mb_metadata_layer.php:96
-#: ../http/plugins/mb_metadata_wmc_edit.php:68
-msgid "ISO Topic Category"
-msgstr "ISO-Kategorie"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:106
-#: ../http/plugins/mb_metadata_featuretype.php:100
-#: ../http/plugins/mb_metadata_layer.php:107
-#: ../http/plugins/mb_metadata_wmc_edit.php:80
-msgid "INSPIRE Category"
-msgstr "INSPIRE Kategorie"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:116
-#: ../http/plugins/mb_metadata_featuretype.php:111
-#: ../http/plugins/mb_metadata_layer.php:118
-#: ../http/plugins/mb_metadata_wmc_edit.php:91
-msgid "Custom Category"
-msgstr "Frei definierte Kategorie"
-#: workspace/test27/http/plugins/mb_metadata_server.php:20
-#: workspace/test27/http/plugins/mb_metadata_server.php:32
-#: ../http/plugins/mb_metadata_server.php:20
-#: ../http/plugins/mb_metadata_server.php:32
-#: ../http/plugins/mb_metadata_wfs_server.php:21
-#: ../http/plugins/mb_metadata_wfs_server.php:33
-#: ../http/plugins/mb_metadata_wmc_server.php:23
-msgid "No metadata sets available."
-msgstr "Keine Metadaten verfügbar."
-#: workspace/test27/http/plugins/mb_metadata_server.php:23
-#: ../http/plugins/mb_metadata_server.php:23
-msgid "You are not allowed to access this WMS."
-msgstr "Es ist Ihnen nicht gestattet auf diesen WMS zuzugreifen."
-#: workspace/test27/http/plugins/mb_metadata_server.php:36
-#: ../http/plugins/mb_metadata_server.php:36
-msgid "You are not allowed to access WMS "
-msgstr "Der Zugriff auf WMS-Dienste ist Ihnen nicht erlaubt."
-#: workspace/test27/http/plugins/mb_metadata_server.php:300
-#: ../http/plugins/mb_metadata_server.php:319
-msgid "Invalid WMS ID."
-msgstr "Ungültige WMS ID."
-#: workspace/test27/http/plugins/mb_twitter.php:22
-msgid ""
-"Element vars consumerKey and consumerSecret are not set. If you don't have "
-"them, get them from Twitter."
-msgstr ""
-"Die Elemente vars consumerKey und consumerSecret sind nicht definiert. Falls "
-"diese nicht vorliegen, können diese über Twitter ermittelt werden."
-#: workspace/test27/http/plugins/mb_twitter.php:64
-msgid "Signed in."
-msgstr "Angemeldet."
-#: workspace/test27/http/plugins/mb_twitter.php:69
-#: workspace/test27/http/plugins/mb_twitter.php:99
-msgid "Not signed in."
-msgstr "Nicht angemeldet."
-#: workspace/test27/http/plugins/mb_twitter.php:79
-#: workspace/test27/http/plugins/mb_twitter.php:116
-msgid "Could not connect to Twitter."
-msgstr "Verbindung zu Twitter fehlgeschlagen."
-#: workspace/test27/http/plugins/mb_twitter.php:92
-msgid "Signed out."
-msgstr "Abgemeldet."
-#: workspace/test27/http/plugins/mb_metadata_edit.php:75
-#: ../http/plugins/mb_metadata_edit.php:75
-#: ../http/plugins/mb_metadata_wfs_edit.php:75
-msgid "Contact Phone Fax (OWS)"
-msgstr ""
-msgid ""
-"Possibility to adapt and add informations in the separate WFS-Featuretype "
-"Metadata."
-msgstr ""
-msgid ""
-"The original WFS-Metadata from the last update could be recovered or "
-msgstr ""
-#: ../http/plugins/mb_metadata_featuretype.php:39
-msgid "Number of Featuretype (Registry)"
-msgstr ""
-#: ../http/plugins/mb_metadata_featuretype.php:44
-msgid "Featuretype Title (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_featuretype.php:49
-msgid "Featuretype Abstract (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_featuretype.php:54
-msgid "Featuretype Keywords (WFS)"
-msgstr ""
-msgid ""
-"Linking the WFS layer with metadata set (coupled resource), which describes "
-"set in a catalog or a simple metadata set will be generated using a "
-msgstr ""
-#: ../http/plugins/mb_metadata_featuretype.php:97
-#: ../http/plugins/mb_metadata_featuretype.php:108
-#: ../http/plugins/mb_metadata_featuretype.php:119
-#: ../http/plugins/mb_metadata_layer.php:104
-#: ../http/plugins/mb_metadata_layer.php:115
-#: ../http/plugins/mb_metadata_layer.php:126
-#: ../http/plugins/mb_metadata_wmc_edit.php:77
-#: ../http/plugins/mb_metadata_wmc_edit.php:88
-#: ../http/plugins/mb_metadata_wmc_edit.php:99
-msgid "Reset selection"
-msgstr ""
-msgid ""
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:15
-msgid "WFS Title (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:20
-msgid "WFS Abstract (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:25
-msgid "WFS Keywords (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:30
-msgid "WFS Fees (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:35
-msgid "WFS AccessConstraints (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:48
-msgid "WFS Predefined Licence (Registry)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:61
-msgid "WFS Provider Section (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:79
-msgid "Contact Organisation (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:84
-msgid "Contact Address (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:88
-msgid "Contact City (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:92
-msgid "Contact State or Province (WFS) - ISO 3166-II"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:96
-msgid "Contact Post Code (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:100
-msgid "Contact Post Country (WFS) - ISO 3166"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:104
-msgid "Contact Electronic Mail Address (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_server.php:24
-msgid "You are not allowed to access this WFS."
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_server.php:37
-msgid "You are not allowed to access this WFS "
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_server.php:286
-#: ../http/plugins/mb_metadata_wfs_server.php:295
-msgid "Invalid WFS ID."
-msgstr ""
-msgid ""
-"Possibility to adapt and add informations in the separate WMC-Featuretype "
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_edit.php:34
-msgid "WMC Title (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_edit.php:39
-msgid "WMC Abstract (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_edit.php:44
-msgid "WMC Keywords (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_edit.php:49
-msgid "WMC is public"
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_server.php:26
-msgid "You are not allowed to access this WMC."
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_server.php:147
-#: ../http/plugins/mb_metadata_wmc_server.php:155
-msgid "Invalid WMC ID."
-msgstr ""
-#: ../http/plugins/mb_sql_server.php:31
-msgid "You are not allowed to access this application."
-msgstr ""
-#: ../http/plugins/mb_measure_widget.php:47
-msgid "Click in the map to start measuring."
-msgstr "Klicken Sie in die Karte, um die Messung zu starten."
-#: ../http/plugins/mb_measure_widget.php:51
-msgid "Last point: "
-msgstr "letzter Stützpunkt"
-#: ../http/plugins/mb_measure_widget.php:54
-msgid "Current point: "
-msgstr "aktueller Stützpunkt"
-#: ../http/plugins/mb_measure_widget.php:57
-msgid "Distance (to last point): "
-msgstr "Entfernung zum letzten Punkt"
-#: ../http/plugins/mb_measure_widget.php:60
-msgid "Distance (total): "
-msgstr "Länge (gesamt)"
-#: ../http/plugins/mb_measure_widget.php:63
-#: ../http/javascripts/mod_coordsLookup.php:100
-msgid "Perimeter: "
-msgstr "Umring: "
-#: ../http/javascripts/mod_coordsLookup.php:90
-msgid "Spatial Reference System"
-msgstr "Räumliches Bezugssystem"
-#: ../http/javascripts/mod_coordsLookup.php:81
-msgid "zoom to coordinates"
-msgstr "Auf Koordinaten zoomen"
-#: ../http/javascripts/mod_coordsLookup.php:71
-msgid "coordinates"
-msgstr "Koordinaten"
-#: ../http/javascripts/mod_coordsLookup.php:128
-msgid "Invalid X coordinate! Must be a float or a DMS value!"
-msgstr "Ungültige X Koordinate! Erlaubt sind lediglich Fließkomma oder GMS Werte!"
-#: ../http/javascripts/mod_coordsLookup.php:139
-msgid "Invalid Y coordinate! Must be a float or a DMS value!"
-msgstr "Ungültige Y Koordinate! Erlaubt sind lediglich Fließkomma oder GMS Werte!"
-#: ../http/javascripts/mod_coordsLookup.php:147
-msgid "Invalid SRS!"
-msgstr "Ungültiges KBS!"
-#: ../http/plugins/mb_measure_widget.php:66
-msgid "Area: "
-msgstr "Fläche"
More information about the Mapbender_commits
